# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/15/24 23:51:01 Mon, 27 Sep 2004 22:28:43 GMT Joel Sherrill [fafdf95] * doc/user/ChangeLog (modified) * doc/user/overview.t (modified) 2004-09-27 Joel Sherrill PR 683/doc ... Mon, 27 Sep 2004 22:26:31 GMT Joel Sherrill [38d354d3] * doc/started/ChangeLog (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/sample.t (modified) 2004-09-27 Joel Sherrill PR ... Mon, 27 Sep 2004 22:14:43 GMT Joel Sherrill [df5f3ca] * cpukit/libmisc/ChangeLog (modified) * cpukit/libmisc/stackchk/check.c (modified) 2004-09-27 Joel Sherrill PR ... Mon, 27 Sep 2004 21:57:50 GMT Joel Sherrill [d49e8f8] * c/src/lib/libbsp/powerpc/shared/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (modified) 2004-09-27 Greg Menke PR ... Mon, 27 Sep 2004 21:53:46 GMT Joel Sherrill [a3fab15a] * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/startup/linkcmds (modified) 2004-09-27 Joel Sherrill PR ... Mon, 27 Sep 2004 21:52:24 GMT Joel Sherrill [993b7d1] * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.c (modified) 2004-09-27 Joel Sherrill PR ... Mon, 27 Sep 2004 21:49:18 GMT Joel Sherrill [dd7db0f] * c/src/lib/libbsp/i386/shared/ChangeLog (modified) * c/src/lib/libbsp/i386/shared/pci/pcibios.c (modified) 2003-11-01 Greg Menke PR ... Mon, 27 Sep 2004 17:36:01 GMT Joel Sherrill [5ef84356] * c/src/lib/libbsp/powerpc/shared/ChangeLog (modified) Spacing. Mon, 27 Sep 2004 17:33:07 GMT Joel Sherrill [d3f0606] * c/src/libchip/ChangeLog (modified) * c/src/libchip/network/dec21140.c (modified) 2004-04-09 Greg Menke PR ... Fri, 17 Sep 2004 16:59:37 GMT Joel Sherrill [8ad28737] * cpukit/libmisc/ChangeLog (modified) * cpukit/libmisc/dumpbuf/dumpbuf.h (modified) * cpukit/libmisc/fsmount/fsmount.h (modified) * cpukit/libmisc/rtmonuse/rtmonuse.h (modified) * cpukit/libmisc/serdbg/serdbg.h (modified) * cpukit/libmisc/serdbg/serdbgcnf.h (modified) * cpukit/libmisc/serdbg/termios_printk.h (modified) * cpukit/libmisc/serdbg/termios_printk_cnf.h (modified) * cpukit/libmisc/untar/untar.h (modified) 2004-09-17 Joel Sherrill PR ... Fri, 17 Sep 2004 16:38:05 GMT Joel Sherrill [b92e6124] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) 2004-09-17 Till Strauman ... Mon, 06 Sep 2004 03:39:16 GMT Ralf Corsepius [506ac56] * scripts/ChangeLog (modified) * scripts/autotools/autoconf-rtems.spec.in (modified) 2004-09-06 Ralf Corsepius * ... Tue, 24 Aug 2004 01:07:30 GMT Jay Monkman [069bf75] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) 2004-08-23 Jay Monkman PR 671/bsps ... Thu, 19 Aug 2004 08:41:25 GMT Ralf Corsepius [f485c56b] * c/src/tests/support/include/.cvsignore (deleted) Remove. Thu, 19 Aug 2004 08:25:48 GMT Ralf Corsepius [8230fa81] * c/src/lib/libcpu/i960/include/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8260/include/.cvsignore (deleted) * c/src/lib/libcpu/powerpc/mpc8xx/include/.cvsignore (deleted) * doc/images/.cvsignore (deleted) * make/Templates/.cvsignore (deleted) * make/compilers/.cvsignore (deleted) Remove. Wed, 18 Aug 2004 12:41:03 GMT Ralf Corsepius [fa2acf9] * ChangeLog (modified) * config-ml.in (modified) 2004-08-18 Ralf Corsepius ... Wed, 18 Aug 2004 07:38:49 GMT Ralf Corsepius [64bd5e35] * ChangeLog (modified) * acinclude.m4 (modified) * aclocal/ppc.m4 (modified) * aclocal/target.m4 (modified) 2004-08-18 Ralf Corsepius * ... Wed, 18 Aug 2004 07:37:19 GMT Ralf Corsepius [cdbe374] * ChangeLog (modified) * acinclude.m4 (modified) 2004-08-18 Ralf Corsepius * ... Wed, 18 Aug 2004 07:34:50 GMT Ralf Corsepius [3950f549] * c/src/ChangeLog (modified) * c/src/acinclude.m4 (modified) 2004-08-17 Ralf Corsepius * ... Wed, 18 Aug 2004 07:28:27 GMT Ralf Corsepius [ba8c439] * cpukit/ChangeLog (modified) 2004-08-18 Ralf Corsepius * ... Wed, 18 Aug 2004 07:26:52 GMT Ralf Corsepius [98b30aa] * aclocal/bsp-alias.m4 (modified) * aclocal/bsp-arg-enable.m4 (modified) * aclocal/canonical-host.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-cpu.m4 (modified) * aclocal/check-custom-bsp.m4 (modified) * aclocal/check-cxx.m4 (modified) * aclocal/check-itron.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-networking.m4 (modified) * aclocal/check-newlib.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/check-rdbg.m4 (modified) * aclocal/check-tool.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/gcc-isystem.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * aclocal/i386-gas-code16.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/path-ksh.m4 (modified) * aclocal/path-perl.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/target.m4 (modified) * aclocal/tool-paths.m4 (modified) * cpukit/aclocal/canonical-host.m4 (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/canonicalize-tools.m4 (modified) * cpukit/aclocal/check-cpu.m4 (modified) * cpukit/aclocal/check-itron.m4 (modified) * cpukit/aclocal/check-multiprocessing.m4 (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/aclocal/check-newlib.m4 (modified) * cpukit/aclocal/check-posix.m4 (modified) * cpukit/aclocal/check-tool.m4 (modified) * cpukit/aclocal/enable-bare.m4 (modified) * cpukit/aclocal/enable-inlines.m4 (modified) * cpukit/aclocal/enable-itron.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-networking.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) * cpukit/aclocal/env-rtemscpu.m4 (modified) * cpukit/aclocal/gcc-isystem.m4 (modified) * cpukit/aclocal/gcc-pipe.m4 (modified) * cpukit/aclocal/multi.m4 (modified) * cpukit/aclocal/multilib.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/aclocal/rtems-debug.m4 (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/aclocal/sysv-ipc.m4 (modified) Fix m4-underquoting. Wed, 18 Aug 2004 07:23:15 GMT Ralf Corsepius [1bdb08c] * ChangeLog (modified) 2004-08-18 Ralf Corsepius * ... Sun, 25 Jul 2004 14:59:40 GMT Joel Sherrill [9bbeed5] * cpukit/score/ChangeLog (modified) * cpukit/score/src/threaddispatch.c (modified) 2004-07-25 Thomas Rauscher PR ... Sun, 25 Jul 2004 14:53:30 GMT Joel Sherrill [0f20ef5] * cpukit/score/ChangeLog (modified) * cpukit/score/src/threadinitialize.c (modified) 2004-07-25 Victor Vengerov ... Sat, 24 Jul 2004 17:52:40 GMT Joel Sherrill [0ca88a1] * cpukit/rtems/ChangeLog (modified) * cpukit/rtems/src/eventsurrender.c (modified) 2004-07-24 Mick Davis PR ... Sat, 24 Jul 2004 17:39:24 GMT Joel Sherrill [8c829996] * cpukit/score/ChangeLog (modified) * cpukit/score/src/objectmp.c (modified) 2004-07-24 Joel Sherrill PR ... Sat, 24 Jul 2004 17:35:34 GMT Joel Sherrill [046f0094] * cpukit/score/ChangeLog (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadstackallocate.c (modified) 2004-07-24 Joel Sherrill PR ... Sat, 24 Jul 2004 17:20:16 GMT Joel Sherrill [5080235] * cpukit/score/ChangeLog (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) 2004-07-24 Joel Sherrill PR ... Sat, 24 Jul 2004 17:19:12 GMT Joel Sherrill [e3da667] * cpukit/rtems/ChangeLog (modified) * doc/user/ChangeLog (modified) Fix format. Sat, 24 Jul 2004 17:08:38 GMT Joel Sherrill [38198f30] * doc/user/ChangeLog (modified) * doc/user/signal.t (modified) 2004-07-24 Joel Sherrill PR ... Sat, 24 Jul 2004 17:08:17 GMT Joel Sherrill [7feb6f9] * cpukit/rtems/ChangeLog (modified) * cpukit/rtems/src/signalsend.c (modified) 2004-07-24 Joel Sherrill PR ... Wed, 14 Jul 2004 21:05:38 GMT Joel Sherrill [e18303d9] * cpukit/score/ChangeLog (modified) * cpukit/score/src/coremsg.c (modified) 2004-07-14 Joel Sherrill PR ... Wed, 14 Jul 2004 14:32:23 GMT Joel Sherrill [72dfb96] * cpukit/rtems/ChangeLog (modified) * cpukit/rtems/src/taskident.c (modified) 2004-07-14 Joel Sherrill PR ... Tue, 29 Jun 2004 13:55:09 GMT Joel Sherrill [469c41a] * cpukit/rtems/ChangeLog (modified) * cpukit/rtems/src/msgqcreate.c (modified) 2004-06-29 Joel Sherrill PR ... Tue, 29 Jun 2004 13:53:57 GMT Joel Sherrill [6fbf5c39] * doc/user/ChangeLog (modified) * doc/user/msg.t (modified) 2004-06-29 Joel Sherrill PR ... Tue, 08 Jun 2004 13:53:29 GMT Joel Sherrill [304d1a5] * cpukit/sapi/ChangeLog (modified) * cpukit/sapi/include/confdefs.h (modified) 2004-06-08 Joel Sherrill * ... Sat, 22 May 2004 15:14:03 GMT Joel Sherrill [01c96bfb] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) 2004-05-22 Till Strauman ... Fri, 21 May 2004 20:16:39 GMT Joel Sherrill [cfc43898] * cpukit/posix/ChangeLog (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/ptimer1.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigsuspend.c (modified) 2004-05-21 Joel Sherrill PR 628/rtems ... Fri, 21 May 2004 20:12:26 GMT Joel Sherrill [0732eb4] * cpukit/posix/ChangeLog (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) 2004-05-21 Joel Sherrill PR 629/rtems ... Fri, 21 May 2004 16:04:44 GMT Joel Sherrill [e2ce15fc] * doc/user/ChangeLog (modified) * doc/user/task.t (modified) 2004-05-21 Joel Sherrill PR 627/doc ... Fri, 21 May 2004 15:26:20 GMT Joel Sherrill [f7219b2] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) 2004-05-21 Till Strauman * PR ... Fri, 21 May 2004 15:21:13 GMT Joel Sherrill [922db65] * c/src/libchip/ChangeLog (modified) Fix formatting so script sees PR. Fri, 21 May 2004 15:09:43 GMT Joel Sherrill [640f1cb] * c/src/libchip/ChangeLog (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) * c/src/libchip/network/if_fxp.c (modified) 2004-05-21 Till Strauman * ... Fri, 21 May 2004 15:03:22 GMT Joel Sherrill [e2f50f9d] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) 2004-05-21 Till Strauman ... Thu, 06 May 2004 19:22:02 GMT Joel Sherrill [ca6c741] * doc/user/ChangeLog (modified) * doc/user/clock.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/sem.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) 2004-05-06 Joel Sherrill PR ... Thu, 06 May 2004 19:20:44 GMT Joel Sherrill [df54012] * cpukit/score/ChangeLog (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/src/coretodvalidate.c (modified) * cpukit/score/src/objectnametoid.c (modified) 2004-05-06 Joel Sherrill PR ... Thu, 06 May 2004 19:20:04 GMT Joel Sherrill [17bbadd] * cpukit/rtems/ChangeLog (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/src/clockget.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsubmit.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) 2004-05-06 Joel Sherrill PR ... Fri, 09 Apr 2004 14:52:27 GMT Joel Sherrill [424f2e40] * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) 2004-04-09 Joel Sherrill PR ... Thu, 08 Apr 2004 23:11:45 GMT Joel Sherrill [fbe21ef] * VERSION (modified) 2004-04-08 Joel Sherrill * VERSION: ... Thu, 08 Apr 2004 23:11:44 GMT Joel Sherrill [24a8fb3] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2004-04-08 Joel Sherrill * ... Thu, 08 Apr 2004 22:48:01 GMT Joel Sherrill [107459f] * cpukit/score/cpu/sparc/ChangeLog (modified) Add missing PR604 reference. Thu, 08 Apr 2004 22:08:49 GMT Joel Sherrill [4a74b03] * scripts/ChangeLog (modified) * scripts/autotools/autoconf-rtems.spec.in (modified) * scripts/setup.def (modified) 2004-04-08 Joel Sherrill PR ... Wed, 07 Apr 2004 13:09:40 GMT Joel Sherrill [91a52b3] * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.h (modified) 2004-04-07 Joel Sherrill PR ... Sat, 03 Apr 2004 16:36:01 GMT Joel Sherrill [59db174d] * c/src/libnetworking/ChangeLog (modified) 2004-04-03 Wilfried Busalski ... Sat, 03 Apr 2004 16:33:21 GMT Joel Sherrill [869f6029] * c/src/libnetworking/pppd/chat.c (modified) 2004-04-03 Wilfried Busalski ... Sat, 03 Apr 2004 16:29:06 GMT Joel Sherrill [9cec3485] * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2004-04-03 Art Ferrer PR ... Thu, 01 Apr 2004 00:14:59 GMT Ralf Corsepius [81cc5b2] * c/src/lib/libbsp/powerpc/shared/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) 2004-02-10 Ralf Corsepius PR ... Tue, 30 Mar 2004 19:46:24 GMT Joel Sherrill [04b4b38] * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) 2004-03-30 David Querbach PR ... Tue, 30 Mar 2004 19:21:24 GMT Joel Sherrill [6a15087] * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/sp32/init.c (modified) 2004-03-30 David Querbach PR ... Fri, 05 Mar 2004 17:58:18 GMT Joel Sherrill [c3e88cad] * cpukit/sapi/ChangeLog (modified) * cpukit/sapi/include/confdefs.h (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 15:49:39 GMT Joel Sherrill [8a41da41] * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/psxtests/psxmsgq01/init.c (modified) * c/src/tests/psxtests/psxtimer/psxtimer.c (modified) 2004-03-05 Joel Sherrill * ... Fri, 05 Mar 2004 15:45:32 GMT Joel Sherrill [d1266a59] * doc/ChangeLog (modified) * doc/FAQ/FAQ.texi (modified) * doc/FAQ/Makefile.am (modified) * doc/FAQ/embeddedinfo.t (deleted) 2004-03-05 Joel Sherrill PR 576/doc ... Fri, 05 Mar 2004 15:30:57 GMT Joel Sherrill [30529eb7] * c/src/lib/libbsp/m68k/shared/ChangeLog (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (modified) 2004-03-05 Joel Sherrill PR ... Thu, 26 Feb 2004 17:23:58 GMT Joel Sherrill [1a17efb] * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) 2004-02-26 Andreas Karlsson ... Thu, 26 Feb 2004 17:04:27 GMT Joel Sherrill [9a93d54] * cpukit/rtems/ChangeLog (modified) * cpukit/rtems/src/eventtimeout.c (modified) 2004-02-26 Thomas Rauscher [70e27c2d] * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm27/task1.c (modified) 2004-02-26 Joel Sherrill PR ... Thu, 26 Feb 2004 14:29:02 GMT Joel Sherrill [ec8472e0] * cpukit/posix/ChangeLog (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) 2004-02-26 Joel Sherrill PR ... Thu, 26 Feb 2004 14:26:19 GMT Joel Sherrill [4e0498e] * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/psxtests/psxmsgq01/init.c (modified) * c/src/tests/psxtests/psxmsgq01/psxmsgq01.scn (modified) 2004-02-26 Sébastien Barré PR ... Tue, 10 Feb 2004 13:32:17 GMT Ralf Corsepius [a4454ed] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) 2004-02-10 Ralf Corsepius * ... Tue, 10 Feb 2004 13:26:19 GMT Ralf Corsepius [04aa02d] * scripts/ChangeLog (modified) * scripts/configure.ac (modified) 2004-02-10 Ralf Corsepius * ... Tue, 10 Feb 2004 13:24:23 GMT Ralf Corsepius [fe051913] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/configure.ac (modified) * scripts/rtems/rtems-source.add (modified) * scripts/rtemsdoc/.cvsignore (modified) * scripts/rtemsdoc/Makefile.am (modified) * scripts/rtemsdoc/header.add (modified) * scripts/rtemsdoc/mkspec.in (deleted) * scripts/rtemsdoc/rtemsdoc.add (modified) * scripts/rtemsdoc/supplement.add.in (modified) * scripts/rtemsdoc/templ.add.in (modified) 2004-02-10 Ralf Corsepius * ... Tue, 10 Feb 2004 12:07:40 GMT Ralf Corsepius [ede694c] * doc/ChangeLog (modified) * doc/index.html.in (modified) 2004-02-10 Ralf Corsepius * ... Tue, 10 Feb 2004 08:00:51 GMT Ralf Corsepius [1620d02] * c/src/lib/libbsp/powerpc/shared/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (deleted) 2004-02-10 Ralf Corsepius PR ... Mon, 09 Feb 2004 14:03:44 GMT Joel Sherrill [38c7e481] * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/Makefile.am (added) 2004-02-09 Joel Sherrill PR ... Mon, 09 Feb 2004 13:34:14 GMT Ralf Corsepius [d1bcf10] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/common/common.add.in (modified) * scripts/configure.ac (modified) 2004-02-09 Ralf Corsepius * ... Mon, 09 Feb 2004 13:21:25 GMT cvs2git [e4669c7] * aclocal/rpm.m4 (added) * scripts/rtems/rtems-source.add (added) This commit was manufactured by cvs2svn to create branch ... Wed, 04 Feb 2004 01:35:54 GMT Joel Sherrill [9a1fa0a] * ChangeLog (modified) 2004-02-03 Joel Sherrill * VERSION: ... Wed, 04 Feb 2004 01:35:41 GMT Joel Sherrill [68dcc43] * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/start/regs.S (modified) 2004-02-03 Ralf Corsepius PR ... Wed, 04 Feb 2004 00:56:15 GMT Joel Sherrill [7de339e] 2004-02-03 Joel Sherrill * VERSION: ... Wed, 04 Feb 2004 00:56:14 GMT Joel Sherrill [3eb80eb5] * ChangeLog (modified) 2004-02-03 Joel Sherrill * ... Wed, 04 Feb 2004 00:53:09 GMT Joel Sherrill [09bc3c9b] * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/Makefile.am (deleted) 2004-02-03 Joel Sherrill * ... Wed, 04 Feb 2004 00:43:01 GMT Joel Sherrill [042ea565] * ChangeLog (modified) 2004-02-03 Joel Sherrill * VERSION: ... Wed, 04 Feb 2004 00:43:00 GMT Joel Sherrill [0ddf39a4] * ChangeLog (modified) * cpukit/ChangeLog (modified) 2004-02-03 Joel Sherrill * ... Wed, 04 Feb 2004 00:39:47 GMT Joel Sherrill [6ffa9a57] * c/src/tests/support/ChangeLog (modified) * c/src/tests/support/include/buffer_test_io.h (modified) 2004-02-03 Joel Sherrill * ... Wed, 04 Feb 2004 00:34:00 GMT Joel Sherrill [f347da9] * doc/ChangeLog (modified) * doc/FAQ/basic.t (modified) * doc/HELP.html (modified) * doc/gnu_docs/gnu_footer.html (modified) * doc/gnu_docs/index.html (modified) * doc/gnu_docs/refcard.html (modified) * doc/gnu_docs/rtems_tools_index.html (modified) * doc/index.html.in (modified) * doc/rtems_footer.html.in (modified) * doc/rtems_header.html.in (modified) * doc/rtems_support.html.in (modified) * doc/started/binaries.t (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/intro.t (modified) * doc/started/require.t (modified) * doc/started/sample.t (modified) * doc/started/tversions.texi.in (modified) 2004-02-03 Joel Sherrill * ... Tue, 03 Feb 2004 04:29:16 GMT Ralf Corsepius [feefe322] * doc/ChangeLog (modified) Add missing ChangeLog entry Sun, 01 Feb 2004 16:43:52 GMT Ralf Corsepius [d9ffe4a0] * doc/common/rtems.texi.in (modified) * doc/configure.ac (modified) * doc/started/binaries.t (modified) 2004-02-01 Ralf Corsepius * ... Sun, 01 Feb 2004 08:30:20 GMT Ralf Corsepius [9ef78daa] * ChangeLog (modified) 2004-02-01 Ralf Corsepius * ... Sun, 01 Feb 2004 07:10:47 GMT Ralf Corsepius [e2c2d19] * doc/started/ChangeLog (modified) * doc/started/binaries.t (modified) * doc/started/buildc.t (modified) 2004-02-01 Ralf Corsepius * ... Sun, 01 Feb 2004 07:07:57 GMT Ralf Corsepius [c7b8c3d] * doc/ChangeLog (modified) * doc/common/rtems.texi.in (modified) * doc/configure.ac (modified) 2004-02-01 Ralf Corsepius * ... Fri, 30 Jan 2004 14:43:05 GMT Joel Sherrill [7e23f208] * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/if_pppvar.h (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) 2004-01-30 Wilfried Busalski ... Fri, 23 Jan 2004 19:53:53 GMT Joel Sherrill [06a31dab] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2004-01-23 Joel Sherrill * ... Fri, 23 Jan 2004 18:14:50 GMT Joel Sherrill [97c9e41] * scripts/ChangeLog (modified) 2004-01-21 Joel Sherrill * ... Fri, 23 Jan 2004 13:33:29 GMT Joel Sherrill [19958a4] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2004-01-23 Joel Sherrill * ... Thu, 22 Jan 2004 23:54:24 GMT Joel Sherrill [a0352792] * ChangeLog (modified) * cpukit/ChangeLog (modified) Remove entries for failed release attempts. Wed, 21 Jan 2004 14:30:55 GMT Joel Sherrill [422ec85] * scripts/configure.ac (modified) 2004-01-21 Joel Sherrill * ... Wed, 21 Jan 2004 12:38:44 GMT Joel Sherrill [90f29e41] * scripts/ChangeLog (modified) Added PR number. Tue, 20 Jan 2004 16:28:07 GMT Joel Sherrill [d832a61] * ChangeLog (modified) 2004-01-20 Joel Sherrill * VERSION: ... Tue, 20 Jan 2004 16:28:06 GMT Joel Sherrill [dcce87b] * ChangeLog (modified) * cpukit/ChangeLog (modified) 2004-01-20 Joel Sherrill * ... Tue, 20 Jan 2004 16:21:37 GMT Joel Sherrill [c5dc20e9] * doc/ChangeLog (modified) * doc/Makefile.am (modified) 2004-01-20 Joel Sherrill PR ...
