# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 12:15:30 Fri, 14 Jan 2011 10:48:57 GMT Sebastian Huber [f2c8c34] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.h (modified) 2011-01-14 Sebastian Huber ... Mon, 10 Jan 2011 16:14:07 GMT Joel Sherrill [e7620cbd] * doc/ChangeLog (modified) * doc/posix_users/posix_users.texi (modified) * doc/posix_users/signal.t (modified) 2011-01-10 Danila Bespalov [174ac5d] * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) Typo. Mon, 10 Jan 2011 14:19:32 GMT Sebastian Huber [683af8a] * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) 2011-01-09 Peer Stritzinger ... Mon, 10 Jan 2011 12:00:27 GMT Sebastian Huber [e62721c] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_categories.c (modified) 2011-01-09 Sebastian Huber ... Mon, 10 Jan 2011 06:07:18 GMT Ralf Corsepius [4ab0ffd] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/math/domath.c (modified) * testsuites/libtests/math/domath.in (modified) * testsuites/libtests/math/domathf.c (modified) * testsuites/libtests/math/domathl.c (modified) * testsuites/libtests/math/math.scn (modified) 2011-01-10 Ralf Corsépius * ... Mon, 10 Jan 2011 05:15:01 GMT Ralf Corsepius [83f7fd6] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/configure.ac (modified) 2011-01-10 Ralf Corsépius * ... Sun, 09 Jan 2011 08:17:42 GMT Ralf Corsepius [7f206d17] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sun, 09 Jan 2011 08:16:43 GMT Ralf Corsepius [d742765] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.19.0-rtems4.11-20110109.diff Sun, 09 Jan 2011 08:15:29 GMT Ralf Corsepius [9fbe66f3] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. Sun, 09 Jan 2011 08:14:28 GMT Ralf Corsepius [3877306] * contrib/crossrpms/patches/newlib-1.19.0-rtems4.11-20110109.diff (added) New (Add 32bit double tgamma fixes). Sat, 08 Jan 2011 21:01:47 GMT Joel Sherrill [c2cfe944] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psxaio02/init.c (modified) * testsuites/psxtests/psxaio02/system.h (modified) 2011-01-08 Alin Rus * ... Sat, 08 Jan 2011 21:01:32 GMT Joel Sherrill [6c48b535] * cpukit/ChangeLog (modified) * cpukit/posix/src/aio_cancel.c (modified) * cpukit/posix/src/aio_misc.c (modified) * cpukit/posix/src/aio_read.c (modified) 2011-01-08 Alin Rus * ... Fri, 07 Jan 2011 17:11:08 GMT Ralf Corsepius [609ec1b2] * contrib/crossrpms/patches/newlib-1.19.0-rtems4.11-20110107.diff (modified) Update. Fri, 07 Jan 2011 08:19:39 GMT Ralf Corsepius [ac18636] * contrib/crossrpms/patches/newlib-1.19.0-rtems4.11-20110107.diff (added) New. Fri, 07 Jan 2011 08:19:12 GMT Ralf Corsepius [2d0e0c9] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Fri, 07 Jan 2011 08:18:09 GMT Ralf Corsepius [b16b20d9] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) newlib-1.19.0-rtems4.11-20110107.diff. Abandon gcc-4.5.0, gcc-4.5.1. Fri, 07 Jan 2011 08:16:52 GMT Ralf Corsepius [358b757e] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump GCC_RPMREL. NEWLIB_VERS = 1.19.0. Reset NEWLIB_RPMREL. Fri, 07 Jan 2011 08:02:39 GMT Ralf Corsepius [2ff81e9d] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-binutils.spec (modified) Regenerate. Fri, 07 Jan 2011 08:01:01 GMT Ralf Corsepius [7d6fa95] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) Bump BINUTILS_RPMREL = 2. Fri, 07 Jan 2011 07:59:00 GMT Ralf Corsepius [ba696c19] * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/binutils-sources.add (modified) Add binutils-2.21-rtems4.11-20110107.diff. Fri, 07 Jan 2011 07:58:01 GMT Ralf Corsepius [9f1ab235] * contrib/crossrpms/patches/binutils-2.21-rtems4.11-20110107.diff (added) New. Fri, 07 Jan 2011 07:57:37 GMT Ralf Corsepius [ac948cd] * contrib/crossrpms/patches/binutils-2.20.1-rtems4.11-20100521.diff (deleted) * contrib/crossrpms/patches/binutils-2.20.1-rtems4.11-20100826.diff (deleted) * contrib/crossrpms/patches/binutils-2.20.90-rtems4.11-20101109.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.5.0-rtems4.11-20100609.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.5.1-rtems4.11-20100726.diff (deleted) * contrib/crossrpms/patches/gcc-core-4.5.1-rtems4.11-20100818.diff (deleted) Housekeeping. Thu, 06 Jan 2011 18:57:59 GMT Joel Sherrill [a7dc62ae] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) 2011-01-06 Joel Sherrill * ... Thu, 06 Jan 2011 14:34:08 GMT Joel Sherrill [5fbf42c] * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) 2011-01-06 Joel Sherrill * ... Tue, 04 Jan 2011 19:53:14 GMT Joel Sherrill [3030975] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/error.c (modified) 2011-01-04 Joel Sherrill * ... Tue, 04 Jan 2011 19:18:09 GMT Joel Sherrill [a84d456] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (modified) 2011-01-04 Joel Sherrill * ... Tue, 04 Jan 2011 18:38:58 GMT Joel Sherrill [8633e8f] * cpukit/ChangeLog (modified) * cpukit/posix/src/aio_cancel.c (modified) 2011-01-04 Joel Sherrill * ... Tue, 04 Jan 2011 18:32:59 GMT Joel Sherrill [f447932f] * cpukit/ChangeLog (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) 2011-01-04 Joel Sherrill * ... Tue, 04 Jan 2011 15:33:31 GMT Joel Sherrill [031785a] * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) 2011-01-04 Joel Sherrill * ... Mon, 03 Jan 2011 01:59:22 GMT Joel Sherrill [f989f1d] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psx05/init.c (modified) 2011-01-02 Joel Sherrill * ... Sun, 02 Jan 2011 16:12:02 GMT Joel Sherrill [e184e3d] * doc/ChangeLog (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/nt.t (modified) * doc/started/require.t (modified) * doc/started/sample.t (modified) 2011-01-02 Danila Bespalov [45c8fb6] * c/src/lib/libbsp/powerpc/gen83xx/network/network.c (modified) 2010-12-30 Sebastian Huber ... Thu, 30 Dec 2010 13:16:41 GMT Sebastian Huber [ce0922e] * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/tsec-config.h (added) * c/src/lib/libbsp/powerpc/gen83xx/include/u-boot-config.h (added) * c/src/lib/libbsp/powerpc/gen83xx/network/network.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/cpuinit.c (modified) 2010-12-30 Sebastian Huber ... Thu, 30 Dec 2010 13:12:03 GMT Sebastian Huber [4bb4925] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) 2010-12-30 Sebastian Huber ... Thu, 30 Dec 2010 13:09:47 GMT Sebastian Huber [1e86d1e] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc83xx/include/mpc83xx.h (modified) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.h (modified) 2010-12-30 Sebastian Huber ... Thu, 30 Dec 2010 13:04:24 GMT Sebastian Huber [5cace18] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/u-boot-config.h (added) * c/src/lib/libbsp/powerpc/gen5200/include/u-boot.h (deleted) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) 2010-12-30 Sebastian Huber ... Thu, 30 Dec 2010 13:01:13 GMT Sebastian Huber [eab47ad8] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/include/u-boot-board-info.h (moved) * c/src/lib/libbsp/powerpc/shared/uboot_dump_bdinfo.c (modified) 2010-12-30 Sebastian Huber ... Thu, 30 Dec 2010 12:58:39 GMT Sebastian Huber [9812d517] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bspgetworkarea.c (modified) * c/src/lib/libbsp/shared/include/u-boot.h (added) * c/src/lib/libbsp/shared/src/bsp-uboot-board-info.c (added) 2010-12-30 Sebastian Huber ... Wed, 29 Dec 2010 10:54:57 GMT Sebastian Huber [6175176] * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start.S (modified) 2010-12-29 Sebastian Huber ... Wed, 29 Dec 2010 10:52:03 GMT Sebastian Huber [47b0230] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/include/start.h (added) * c/src/lib/libbsp/powerpc/shared/src/bsp-start-zero.S (added) 2010-12-29 Sebastian Huber ... Wed, 29 Dec 2010 10:48:08 GMT Sebastian Huber [4e9d8ea] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) 2010-12-29 Sebastian Huber ... Wed, 29 Dec 2010 10:45:33 GMT Sebastian Huber [ef8dff0] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc55xx/include/mpc55xx.h (modified) * c/src/lib/libcpu/powerpc/mpc55xx/misc/copy.S (modified) 2010-12-29 Sebastian Huber ... Wed, 29 Dec 2010 09:51:18 GMT Sebastian Huber [644448f] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_categories.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) 2010-12-29 Sebastian Huber ... Wed, 29 Dec 2010 09:43:06 GMT Sebastian Huber [26a250a] * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.base (modified) 2010-12-29 Sebastian Huber ... Tue, 28 Dec 2010 09:55:57 GMT Sebastian Huber [d00b7a5a] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos_conv.c (modified) 2010-12-28 Sebastian Huber ... Tue, 28 Dec 2010 08:46:57 GMT Sebastian Huber [3ae5950] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) 2010-12-28 Sebastian Huber ... Mon, 27 Dec 2010 14:35:13 GMT Sebastian Huber [45edf78] * cpukit/ChangeLog (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) 2010-12-27 Sebastian Huber ... Sun, 26 Dec 2010 17:08:45 GMT Ralf Corsepius [9f82dfb] * contrib/crossrpms/patches/autoconf-2.66-611661.diff (deleted) Remove. Thu, 23 Dec 2010 12:50:55 GMT Sebastian Huber [6d9059f] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.c (modified) 2010-12-23 Sebastian Huber ... Wed, 22 Dec 2010 14:21:03 GMT Sebastian Huber [dbb3211a] * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/gwlcfm.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc5566evb.cfg (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/make/custom/mpc55xx.inc (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) 2010-12-22 Sebastian Huber ... Wed, 22 Dec 2010 14:13:03 GMT Sebastian Huber [b591952] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc.S (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c (modified) 2010-12-22 Sebastian Huber ... Fri, 17 Dec 2010 15:25:40 GMT Joel Sherrill [ffc3c64] * ChangeLog (modified) * configure.ac (modified) 2010-12-17 Joel Sherrill ... Fri, 17 Dec 2010 15:24:02 GMT Ralf Corsepius [e715ecbd] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Fri, 17 Dec 2010 15:22:35 GMT Ralf Corsepius [00ae84c0] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-4.5.2 (final). Fri, 17 Dec 2010 15:18:04 GMT Ralf Corsepius [42462e8d] * contrib/crossrpms/patches/gcc-core-4.5.2-rtems4.11-20101216.diff (added) Rebase patch for gcc-4.5.2. Fri, 17 Dec 2010 14:56:06 GMT Joel Sherrill [5aecf664] * cpukit/ChangeLog (modified) * cpukit/sapi/include/confdefs.h (modified) 2010-12-17 Joel Sherrill ... Fri, 17 Dec 2010 14:53:29 GMT Joel Sherrill [7accb65] * tools/schedsim/.cvsignore (added) * tools/schedsim/ChangeLog (added) * tools/schedsim/Makefile.am (added) * tools/schedsim/configure.ac (added) 2010-12-17 Joel Sherrill ... Fri, 17 Dec 2010 14:53:04 GMT Joel Sherrill [f9b0a390] * tools/schedsim/rtems/.cvsignore (added) * tools/schedsim/rtems/ChangeLog (modified) 2010-12-17 Joel Sherrill * ... Fri, 17 Dec 2010 14:51:56 GMT Joel Sherrill [4bc2c988] * tools/schedsim/rtems/ChangeLog (added) * tools/schedsim/rtems/Makefile.am (added) * tools/schedsim/rtems/interr.c (added) * tools/schedsim/rtems/rtems_init.c (added) * tools/schedsim/rtems/rtems_sched.h (added) * tools/schedsim/rtems/sched_cpu/cpu.c (added) * tools/schedsim/rtems/sched_cpu/cpu_asm.c (added) * tools/schedsim/rtems/sched_cpu/rtems/asm.h (added) * tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h (added) * tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h (added) * tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h (added) * tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h (added) * tools/schedsim/rtems/sched_cpu/rtems/score/types.h (added) * tools/schedsim/rtems/sched_cpu/rtems/stringto.h (added) * tools/schedsim/rtems/wkspace.c (added) 2010-12-17 Joel Sherrill ... Fri, 17 Dec 2010 14:49:40 GMT Joel Sherrill [abff6d2] * tools/schedsim/shell/.cvsignore (added) * tools/schedsim/shell/ChangeLog (added) * tools/schedsim/shell/Makefile.am (added) * tools/schedsim/shell/schedsim_priority/.cvsignore (added) * tools/schedsim/shell/schedsim_priority/Makefile.am (added) * tools/schedsim/shell/schedsim_priority/config.c (added) * tools/schedsim/shell/schedsim_priority/printheir_executing.c (added) * tools/schedsim/shell/schedsim_priority/schedsim.cc (added) * tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c (added) * tools/schedsim/shell/scripts/script01 (added) * tools/schedsim/shell/scripts/script02 (added) * tools/schedsim/shell/scripts/script03 (added) * tools/schedsim/shell/scripts/script04 (added) * tools/schedsim/shell/scripts/script05 (added) * tools/schedsim/shell/scripts/script06 (added) * tools/schedsim/shell/shared/.cvsignore (added) * tools/schedsim/shell/shared/Makefile.am (added) * tools/schedsim/shell/shared/commands.c (added) * tools/schedsim/shell/shared/getopt.c (added) * tools/schedsim/shell/shared/include/newlib/_ansi.h (added) * tools/schedsim/shell/shared/include/newlib/getopt.h (added) * tools/schedsim/shell/shared/include/shell.h (added) * tools/schedsim/shell/shared/lookup_semaphore.c (added) * tools/schedsim/shell/shared/lookup_task.c (added) * tools/schedsim/shell/shared/main_clocktick.c (added) * tools/schedsim/shell/shared/main_echo.c (added) * tools/schedsim/shell/shared/main_executing.c (added) * tools/schedsim/shell/shared/main_heir.c (added) * tools/schedsim/shell/shared/main_help.c (added) * tools/schedsim/shell/shared/main_rtemsinit.c (added) * tools/schedsim/shell/shared/main_semcreate.c (added) * tools/schedsim/shell/shared/main_semdelete.c (added) * tools/schedsim/shell/shared/main_semflush.c (added) * tools/schedsim/shell/shared/main_semobtain.c (added) * tools/schedsim/shell/shared/main_semrelease.c (added) * tools/schedsim/shell/shared/main_taskcreate.c (added) * tools/schedsim/shell/shared/main_taskdelete.c (added) * tools/schedsim/shell/shared/main_taskmode.c (added) * tools/schedsim/shell/shared/main_taskpriority.c (added) * tools/schedsim/shell/shared/main_taskresume.c (added) * tools/schedsim/shell/shared/main_tasksuspend.c (added) * tools/schedsim/shell/shared/main_taskwakeafter.c (added) * tools/schedsim/shell/shared/schedsim_shell.h (added) * tools/schedsim/shell/shared/shell_cmdset.c (added) * tools/schedsim/shell/shared/shell_makeargs.c (added) 2010-12-17 Joel Sherrill ... Thu, 16 Dec 2010 21:33:31 GMT Joel Sherrill [9f8115f9] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/math/Makefile.am (modified) * testsuites/libtests/math/init.c (modified) 2010-12-16 Joel Sherrill * ... Thu, 16 Dec 2010 20:42:53 GMT Joel Sherrill [1ae36f59] * doc/ChangeLog (modified) * doc/develenv/direct.t (modified) * doc/started_ada/.cvsignore (deleted) * doc/started_ada/Makefile.am (deleted) * doc/started_ada/buildada.t (deleted) * doc/started_ada/gdb.t (deleted) * doc/started_ada/intro.t (deleted) * doc/started_ada/require.t (deleted) * doc/started_ada/sample.t (deleted) * doc/started_ada/stamp-vti (deleted) * doc/started_ada/started_ada.texi (deleted) * doc/started_ada/tversions.texi (deleted) * doc/started_ada/version.texi (deleted) 2010-12-16 Joel Sherrill * ... Thu, 16 Dec 2010 18:59:54 GMT Joel Sherrill [132b8e9] * ChangeLog (modified) * SUPPORT (modified) 2010-12-16 Joel Sherrill * ... Thu, 16 Dec 2010 15:46:34 GMT Sebastian Huber [4e21c9a] * cpukit/ChangeLog (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) 2010-12-16 Sebastian Huber ... Thu, 16 Dec 2010 14:50:12 GMT Sebastian Huber [18657d1] * cpukit/ChangeLog (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/src/coretodget.c (modified) * cpukit/score/src/coretodgetuptime.c (modified) * cpukit/score/src/watchdognanoseconds.c (added) 2010-12-16 Sebastian Huber ... Thu, 16 Dec 2010 14:41:03 GMT Sebastian Huber [861ff1e] * c/src/lib/libbsp/arm/lpc32xx/startup/bspreset.c (modified) Added missing include file. Thu, 16 Dec 2010 13:35:26 GMT Sebastian Huber [6d4d934] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/shared/lpc/include/lpc-i2s.h (modified) * c/src/lib/libbsp/arm/shared/lpc/include/lpc-timer.h (modified) * c/src/lib/libbsp/arm/shared/lpc/network/lpc-ethernet.c (modified) 2010-12-16 Sebastian Huber ... Thu, 16 Dec 2010 13:35:06 GMT Sebastian Huber [cfe13cb] * c/src/lib/libbsp/arm/lpc32xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/include/bspopts.h.in (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc32xx.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/mmu.h (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/mmu.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspreset.c (modified) 2010-12-16 Sebastian Huber ... Thu, 16 Dec 2010 03:52:16 GMT Ralf Corsepius [5d2b63c] * contrib/crossrpms/cygwin/i686/Makefile.am (modified) * contrib/crossrpms/cygwin/i686/i686-pc-cygwin-zlib.spec (modified) Update to zlib-1.2.5-1. Tue, 14 Dec 2010 16:51:17 GMT Joel Sherrill [df631170] * doc/ChangeLog (modified) * doc/Makefile.am (modified) * doc/common/cpright.texi (modified) * doc/common/rtems.texi.in (modified) * doc/configure.ac (modified) * doc/cpu_supplement/.cvsignore (modified) * doc/started/Makefile.am (modified) * doc/started/binaries.t (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/intro.t (modified) * doc/started/nextstep.t (modified) * doc/started/nt.t (modified) * doc/started/require.t (modified) * doc/started/sample.t (modified) * doc/started/started.texi (modified) * doc/started/tversions.texi.in (deleted) * doc/started/version.texi (modified) 2010-12-14 Joel Sherrill * ... Sat, 11 Dec 2010 12:58:31 GMT Ralf Corsepius [8e03eb3] * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-gcc.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-gcc.spec (modified) Regenerate. Sat, 11 Dec 2010 12:57:50 GMT Ralf Corsepius [08146883] * contrib/crossrpms/rtems4.11/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/gcc-sources.add (modified) gcc-4.5.2 Sat, 11 Dec 2010 12:56:41 GMT Ralf Corsepius [fd623d5] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) GCC_VERS = 4.5.2 Sat, 11 Dec 2010 09:14:09 GMT Ralf Corsepius [814dd292] * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-binutils.spec (modified) * contrib/crossrpms/freebsd6.4/i586/i586-pc-freebsd6.4-gcc.spec (modified) * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-binutils.spec (modified) * contrib/crossrpms/freebsd7.3/i586/i586-pc-freebsd7.3-gcc.spec (modified) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-binutils.spec (modified) * contrib/crossrpms/freebsd8.0/i586/i586-pc-freebsd8.0-gcc.spec (modified) * contrib/crossrpms/freebsd8.0/x86_64/amd64-pc-freebsd8.0-binutils.spec (modified) * contrib/crossrpms/freebsd8.0/x86_64/amd64-pc-freebsd8.0-gcc.spec (modified) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-binutils.spec (modified) * contrib/crossrpms/freebsd8.1/i586/i586-pc-freebsd8.1-gcc.spec (modified) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-binutils.spec (modified) * contrib/crossrpms/freebsd8.1/x86_64/amd64-pc-freebsd8.1-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-binutils.spec (modified) * contrib/crossrpms/netbsd5.0.2/i386/i386-pc-netbsdelf5.0.2-gcc.spec (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/amd64-pc-netbsdelf5.0.2-binutils.spec (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/amd64-pc-netbsdelf5.0.2-gcc.spec (modified) Regenerate. Sat, 11 Dec 2010 09:12:01 GMT Ralf Corsepius [812a9bd] * contrib/crossrpms/freebsd6.4/i586/Makefile.am (modified) * contrib/crossrpms/freebsd7.3/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.0/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.0/x86_64/Makefile.am (modified) * contrib/crossrpms/freebsd8.1/i586/Makefile.am (modified) * contrib/crossrpms/freebsd8.1/x86_64/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/i386/Makefile.am (modified) * contrib/crossrpms/netbsd5.0.2/x86_64/Makefile.am (modified) Binutils-2.21. BINUTILS_RPMREL = 0.20101211.0. GCC_RPMREL = ... Sat, 11 Dec 2010 02:15:39 GMT Ralf Corsepius [8d8de6c2] * contrib/crossrpms/gcc/gccnewlib.add (modified) Add fedora 15. Remove fedora 12. Thu, 09 Dec 2010 10:02:22 GMT Ralf Corsepius [7831277] * contrib/crossrpms/rtems4.11/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.11/arm/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/arm/rtems-4.11-arm-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.11/avr/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/avr/rtems-4.11-avr-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.11/bfin/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/bfin/rtems-4.11-bfin-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.11/h8300/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/h8300/rtems-4.11-h8300-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.11/i386/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/i386/rtems-4.11-i386-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/lm32/Makefile.am (modified) * contrib/crossrpms/rtems4.11/lm32/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/lm32/rtems-4.11-lm32-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32c/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32c/rtems-4.11-m32c-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m32r/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m32r/rtems-4.11-m32r-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.11/m68k/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/m68k/rtems-4.11-m68k-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.11/mips/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/mips/rtems-4.11-mips-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/powerpc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/powerpc/rtems-4.11-powerpc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sh/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sh/rtems-4.11-sh-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc/rtems-4.11-sparc-rtems4.11-binutils.spec (modified) * contrib/crossrpms/rtems4.11/sparc64/Makefile.am (modified) * contrib/crossrpms/rtems4.11/sparc64/binutils-sources.add (modified) * contrib/crossrpms/rtems4.11/sparc64/rtems-4.11-sparc64-rtems4.11-binutils.spec (modified) binutils-2.21. Wed, 08 Dec 2010 10:32:05 GMT Sebastian Huber [f4e67ff7] * testsuites/samples/ChangeLog (modified) * testsuites/samples/loopback/init.c (modified) 2010-12-08 Sebastian Huber ... Wed, 08 Dec 2010 10:30:27 GMT Sebastian Huber [6c6b2f1] * cpukit/ChangeLog (modified) * cpukit/libmisc/dummy/dummy-networking.c (modified) * cpukit/libnetworking/loop.h (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) 2010-12-08 Sebastian Huber ... Mon, 06 Dec 2010 23:13:11 GMT Joel Sherrill [d810129] * c/src/lib/libbsp/arm/rtl22xx/ChangeLog (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx_t.cfg (modified) 2010-12-06 Joel Sherrill * ... Mon, 06 Dec 2010 16:45:43 GMT Joel Sherrill [4b0ac2c] * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) 2010-12-06 Joel Sherrill * ... Mon, 06 Dec 2010 16:35:53 GMT Joel Sherrill [65b185e] * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/README (modified) 2010-12-06 Joel Sherrill * ... Mon, 06 Dec 2010 16:35:31 GMT Joel Sherrill [519928c3] * testsuites/psxtmtests/.cvsignore (added) * testsuites/psxtmtests/ChangeLog (added) * testsuites/psxtmtests/Makefile.am (added) * testsuites/psxtmtests/README (added) * testsuites/psxtmtests/configure.ac (added) * testsuites/psxtmtests/psxtmmutex02/.cvsignore (added) * testsuites/psxtmtests/psxtmmutex02/Makefile.am (added) * testsuites/psxtmtests/psxtmmutex02/init.c (added) * testsuites/psxtmtests/psxtmmutex02/psxtmmutex02.doc (added) * testsuites/psxtmtests/psxtmtests_plan.csv (added) * testsuites/psxtmtests/psxtmthread01/.cvsignore (added) * testsuites/psxtmtests/psxtmthread01/Makefile.am (added) * testsuites/psxtmtests/psxtmthread01/init.c (added) * testsuites/psxtmtests/psxtmthread01/psxtmthread01.doc (added) * testsuites/psxtmtests/psxtmthread03/.cvsignore (added) * testsuites/psxtmtests/psxtmthread03/Makefile.am (added) * testsuites/psxtmtests/psxtmthread03/init.c (added) * testsuites/psxtmtests/psxtmthread03/psxtmthread03.doc (added) 2010-12-06 Joel Sherrill * ... Fri, 03 Dec 2010 20:34:24 GMT Joel Sherrill [57e278d] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/posix/src/signal_2.c (modified) 2010-12-03 Joel Sherrill * ... Fri, 03 Dec 2010 10:57:28 GMT Sebastian Huber [8353f94f] * c/src/lib/libbsp/arm/gba/ChangeLog (modified) Typo. Fri, 03 Dec 2010 10:52:07 GMT Sebastian Huber [8d992be9] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/bsp_specs (modified) * c/src/lib/libbsp/arm/csb336/start/start.S (modified) * c/src/lib/libbsp/arm/csb336/startup/linkcmds (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/bsp_specs (modified) * c/src/lib/libbsp/arm/edb7312/start/start.S (modified) * c/src/lib/libbsp/arm/edb7312/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gdbarmsim/ChangeLog (modified) * c/src/lib/libbsp/arm/gdbarmsim/bsp_specs (modified) * c/src/lib/libbsp/arm/gdbarmsim/start/start.S (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gumstix/ChangeLog (modified) * c/src/lib/libbsp/arm/gumstix/bsp_specs (modified) * c/src/lib/libbsp/arm/gumstix/start/start.S (modified) * c/src/lib/libbsp/arm/gumstix/startup/linkcmds (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 10:51:54 GMT Sebastian Huber [dda95953] * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/bsp_specs (modified) * c/src/lib/libbsp/arm/csb337/start/start.S (modified) * c/src/lib/libbsp/arm/csb337/startup/linkcmds.csb337 (modified) * c/src/lib/libbsp/arm/csb337/startup/linkcmds.csb637 (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 10:51:22 GMT Sebastian Huber [4651508] * c/src/lib/libbsp/arm/gba/ChangeLog (modified) * c/src/lib/libbsp/arm/gba/startup/linkcmds (modified) * c/src/lib/libbsp/arm/smdk2410/ChangeLog (modified) * c/src/lib/libbsp/arm/smdk2410/startup/linkcmds (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 10:50:52 GMT Sebastian Huber [dfee787] * c/src/lib/libbsp/arm/gp32/ChangeLog (modified) * c/src/lib/libbsp/arm/gp32/start/start.S (modified) * c/src/lib/libbsp/arm/gp32/startup/linkcmds (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 10:50:28 GMT Sebastian Huber [f990c1a] * c/src/lib/libbsp/arm/rtl22xx/ChangeLog (modified) * c/src/lib/libbsp/arm/rtl22xx/start/start.S (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/linkcmds (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 10:49:50 GMT Sebastian Huber [f2d1c4d] * c/src/lib/libbsp/arm/nds/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/Makefile.am (modified) * c/src/lib/libbsp/arm/nds/bsp_specs (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/jtypes.h (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/interruptDispatcher.S (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/interrupts.c (modified) * c/src/lib/libbsp/arm/nds/start/start.S (modified) * c/src/lib/libbsp/arm/nds/startup/bspgetworkarea.c (deleted) * c/src/lib/libbsp/arm/nds/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/nds/startup/linkcmds (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 10:16:38 GMT Sebastian Huber [90cc2ec] * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2362 (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc23xx_tli800 (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ea (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_ext (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_int (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 10:13:07 GMT Sebastian Huber [2eebf25c] * c/src/lib/libbsp/arm/lpc32xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_1 (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_2 (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_phycore (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 10:09:59 GMT Sebastian Huber [e792ecf] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 09:56:48 GMT Sebastian Huber [dd853a3] * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/bsp_specs (modified) * c/src/lib/libbsp/arm/lpc24xx/include/io.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lcd.h (added) * c/src/lib/libbsp/arm/lpc24xx/include/lpc24xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/io.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/lcd.c (added) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2362 (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc23xx_tli800 (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ea (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_ext (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_int (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 09:29:08 GMT Sebastian Huber [598a4505] * c/src/lib/libbsp/arm/lpc32xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/bsp_specs (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc32xx.h (modified) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_1 (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_2 (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_phycore (modified) 2010-12-03 Sebastian Huber ... Fri, 03 Dec 2010 09:23:52 GMT Sebastian Huber [a3579d3b] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/preinstall.am (added) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/arm/shared/include/start.h (modified) * c/src/lib/libbsp/arm/shared/lpc/include/lpc-i2s.h (added) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.armv4 (added) * c/src/lib/libbsp/arm/shared/startup/linkcmds.armv7 (added) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) 2010-12-03 Sebastian Huber ... Wed, 01 Dec 2010 05:43:07 GMT Ralf Corsepius [87b4f123] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/complex/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) 2010-12-01 Ralf Corsépius * ... Tue, 30 Nov 2010 17:13:28 GMT Joel Sherrill [95b18d0] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc55xx/edma/edma.c (modified) 2010-11-30 Joel Sherrill * ...
