# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 20:33:01 Tue, 11 Apr 2006 19:17:09 GMT Eric Norum [e846fc9] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c (modified) Add default exception handler. Mon, 10 Apr 2006 15:09:02 GMT Eric Norum [e1d44a8] * make/ChangeLog (modified) * make/custom/uC5282.cfg (modified) Keep the frame pointer since its presence makes various diagnostic ... Fri, 07 Apr 2006 01:16:55 GMT Joel Sherrill [5287d3e] * cpukit/ChangeLog (modified) * cpukit/posix/inline/rtems/posix/mutex.inl (modified) * cpukit/posix/inline/rtems/posix/timer.inl (modified) * cpukit/posix/macros/rtems/posix/cond.inl (modified) * cpukit/posix/macros/rtems/posix/mutex.inl (modified) * cpukit/posix/macros/rtems/posix/timer.inl (modified) 2006-04-06 Joel Sherrill * ... Fri, 07 Apr 2006 01:16:32 GMT Joel Sherrill [5fbb9097] * cpukit/ChangeLog (modified) * cpukit/score/inline/rtems/score/threadmp.inl (modified) * cpukit/score/macros/rtems/score/threadmp.inl (modified) * score/inline/rtems/score/threadmp.inl, ... Wed, 05 Apr 2006 20:12:51 GMT Joel Sherrill [73ad880] * c/src/lib/libbsp/powerpc/ChangeLog (modified) Fix formatting. Wed, 05 Apr 2006 20:11:57 GMT Joel Sherrill [56758965] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) 2006-04-05 Victor V. Vengerov ... Wed, 05 Apr 2006 20:09:33 GMT Joel Sherrill [0c30bc5] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/spsize/size.c (modified) 2006-04-05 Joel Sherrill ... Wed, 05 Apr 2006 20:08:59 GMT Joel Sherrill [52502994] * cpukit/ChangeLog (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/inline/rtems/score/threadmp.inl (modified) * cpukit/score/macros/rtems/score/threadmp.inl (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadqenqueue.c (modified) 2006-04-05 Joel Sherrill ... Sun, 02 Apr 2006 06:57:50 GMT Ralf Corsepius [c19b37d4] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) 2006-04-02 Ralf Corsépius * ... Mon, 27 Mar 2006 15:14:07 GMT Eric Norum [03f246fb] * cpukit/ChangeLog (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) Eliminate undesired sign-extension. Fri, 24 Mar 2006 20:07:57 GMT Eric Norum [84572474] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c (modified) Add missing reset cause bit. Thu, 23 Mar 2006 20:33:33 GMT Ralf Corsepius [23d2518] * cpukit/zlib/zlib.pc.in (added) This commit was generated by cvs2svn to compensate for changes in ... Thu, 23 Mar 2006 20:33:33 GMT Ralf Corsepius [267ecf0] * cpukit/zlib/zlib.pc.in (added) Import from zlib-1.2.4 Thu, 23 Mar 2006 13:21:05 GMT Ralf Corsepius [12f1d7d0] * contrib/crossrpms/rtems/gdb-sources.add (added) New. Thu, 23 Mar 2006 13:06:28 GMT Ralf Corsepius [e39da00d] * contrib/crossrpms/configure.ac (modified) Add defaults for non-standard $prefix. Wed, 22 Mar 2006 13:53:32 GMT Joel Sherrill [a71c31b] * c/src/lib/libbsp/mips/hurricane/ChangeLog (modified) * c/src/lib/libbsp/mips/hurricane/include/.cvsignore (added) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4925/include/.cvsignore (added) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (modified) * c/src/lib/libbsp/mips/rbtx4938/include/.cvsignore (added) 2006-03-22 Joel Sherrill * ... Fri, 17 Mar 2006 15:31:13 GMT Ralf Corsepius [26d61ce4] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/shared/interrupts/vectorexceptions.c (modified) 2006-03-17 Ralf Corsépius * ... Fri, 17 Mar 2006 13:14:52 GMT Ralf Corsepius [900ae6fd] * contrib/crossrpms/configure.ac (modified) * contrib/crossrpms/mkspec.am (modified) Apply @sysdirpattern@ Fri, 17 Mar 2006 13:13:46 GMT Ralf Corsepius [c3af37c] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/target-binutils.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/target-gcc.add (modified) * contrib/crossrpms/gcc/target-newlib.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/target-gdb.add (modified) Use %sysdir instead of %if %_prefix ==|!= /usr Fri, 17 Mar 2006 10:34:12 GMT Ralf Corsepius [c1a96804] * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/clock/clock.S (modified) * c/src/lib/libbsp/mips/hurricane/clock/clock.h (modified) * c/src/lib/libbsp/mips/hurricane/console/console.c (modified) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/include/coverhd.h (modified) * c/src/lib/libbsp/mips/hurricane/start/start.S (modified) * c/src/lib/libbsp/mips/hurricane/startup/bspclean.c (modified) * c/src/lib/libbsp/mips/hurricane/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/hurricane/startup/idttlb.S (modified) * c/src/lib/libbsp/mips/hurricane/startup/inittlb.c (modified) * c/src/lib/libbsp/mips/hurricane/startup/setvec.c (modified) * c/src/lib/libbsp/mips/hurricane/times (modified) * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) Misc. cosmetics. Fri, 17 Mar 2006 10:11:37 GMT Ralf Corsepius [674be421] * c/src/lib/libbsp/arm/armulator/include/bsp.h (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/c4x/c4xsim/include/bsp.h (modified) * c/src/lib/libbsp/h8300/h8sim/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/include/coverhd.h (modified) * c/src/lib/libbsp/i386/i386ex/start/80386ex.h (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vga.h (modified) * c/src/lib/libbsp/i386/pc386/console/ps2_drv.h (modified) * c/src/lib/libbsp/i386/pc386/console/serial_mouse.h (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/shared/comm/tty_drv.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq.h (modified) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/ts_386ex/include/coverhd.h (modified) * c/src/lib/libbsp/i386/ts_386ex/start/80386ex.h (modified) * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/shared/mvme/mvme16x_hw.h (modified) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen405/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen405/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/pcmcia_ide.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/helas403/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/ss555/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ss555/include/coverhd.h (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/include/coverhd.h (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/include/coverhd.h (modified) * c/src/lib/libbsp/sh/gensh4/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh4/include/coverhd.h (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) * c/src/lib/libbsp/sh/simsh4/include/bsp.h (modified) * c/src/lib/libbsp/sh/simsh4/include/coverhd.h (modified) * c/src/lib/libbsp/sh/simsh4/include/ramdisk.h (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/coverhd.h (modified) * c/src/lib/libbsp/sparc/erc32/include/erc32.h (modified) * c/src/lib/libbsp/sparc/leon2/include/coverhd.h (modified) * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/include/coverhd.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) Remove eof include file Fri, 17 Mar 2006 08:38:26 GMT Ralf Corsepius [a3de1b48] * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) 2006-03-17 Ralf Corsepius * ... Fri, 17 Mar 2006 05:24:30 GMT Ralf Corsepius [01a76a6] * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) 2006-03-17 Ralf Corsepius * ... Thu, 16 Mar 2006 18:12:27 GMT Ralf Corsepius [0c3269ce] * c/src/lib/libcpu/mips/preinstall.am (modified) Regenerate. Thu, 16 Mar 2006 18:11:32 GMT Ralf Corsepius [01d8a42] * c/src/lib/libcpu/mips/Makefile.am (modified) Cosmetics. Thu, 16 Mar 2006 18:10:19 GMT Ralf Corsepius [401fe875] * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/configure.ac (modified) 2006-03-16 Ralf Corsépius * ... Thu, 16 Mar 2006 18:07:22 GMT Ralf Corsepius [6cd6923] * c/src/lib/libcpu/mips/ChangeLog (modified) 2006-03-16 Ralf Corsépius * ... Thu, 16 Mar 2006 18:06:54 GMT Ralf Corsepius [3a3e5dae] * c/src/lib/libcpu/mips/rm52xx/include/rm5231.h (added) * c/src/lib/libcpu/mips/rm52xx/vectorisrs/maxvectors.c (added) * c/src/lib/libcpu/mips/rm52xx/vectorisrs/vectorisrs.c (added) * c/src/lib/libcpu/mips/tx49/include/tx4925.h (added) * c/src/lib/libcpu/mips/tx49/include/tx4938.h (added) * c/src/lib/libcpu/mips/tx49/vectorisrs/maxvectors.c (added) * c/src/lib/libcpu/mips/tx49/vectorisrs/vectorisrs.c (added) New (Submission by Bruce Robinson ). Thu, 16 Mar 2006 17:57:42 GMT Ralf Corsepius [b22b31fd] * c/src/lib/libbsp/mips/acinclude.m4 (modified) Regenerate. Thu, 16 Mar 2006 17:57:27 GMT Ralf Corsepius [da7d7c2] * c/src/lib/libbsp/mips/configure.ac (modified) AC_CONFIG_SRCDIR(csb350). Thu, 16 Mar 2006 17:57:12 GMT Ralf Corsepius [43b09557] * c/src/lib/libbsp/mips/ChangeLog (modified) 2006-03-16 Ralf Corsépius * ... Thu, 16 Mar 2006 17:43:00 GMT Ralf Corsepius [b7b487cb] * c/src/lib/libbsp/mips/rbtx4938/preinstall.am (added) New. Thu, 16 Mar 2006 17:42:47 GMT Ralf Corsepius [79b1dea5] * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) Add preinstall.am Thu, 16 Mar 2006 17:41:28 GMT Ralf Corsepius [4ba5ac6] * c/src/lib/libbsp/mips/rbtx4938/.cvsignore (added) * c/src/lib/libbsp/mips/rbtx4938/ChangeLog (added) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (added) * c/src/lib/libbsp/mips/rbtx4938/README (added) * c/src/lib/libbsp/mips/rbtx4938/bsp_specs (added) * c/src/lib/libbsp/mips/rbtx4938/clock/clockdrv.c (added) * c/src/lib/libbsp/mips/rbtx4938/clock/yamon_api.h (added) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (added) * c/src/lib/libbsp/mips/rbtx4938/console/console-io.c (added) * c/src/lib/libbsp/mips/rbtx4938/console/yamon_api.h (added) * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (added) * c/src/lib/libbsp/mips/rbtx4938/include/tm27.h (added) * c/src/lib/libbsp/mips/rbtx4938/liblnk/lnklib.S (added) * c/src/lib/libbsp/mips/rbtx4938/liblnk/pmon.S (added) * c/src/lib/libbsp/mips/rbtx4938/liblnk/regs.S (added) * c/src/lib/libbsp/mips/rbtx4938/start/start.S (added) * c/src/lib/libbsp/mips/rbtx4938/startup/bspclean.c (added) * c/src/lib/libbsp/mips/rbtx4938/startup/bspstart.c (added) * c/src/lib/libbsp/mips/rbtx4938/startup/exception.S (added) * c/src/lib/libbsp/mips/rbtx4938/startup/idtmem.S (added) * c/src/lib/libbsp/mips/rbtx4938/startup/idttlb.S (added) * c/src/lib/libbsp/mips/rbtx4938/startup/inittlb.c (added) * c/src/lib/libbsp/mips/rbtx4938/startup/linkcmds (added) New (Submission by Bruce Robinson ). Thu, 16 Mar 2006 17:36:21 GMT Ralf Corsepius [c6254224] * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) Add preinstall.am Thu, 16 Mar 2006 17:35:34 GMT Ralf Corsepius [991f9022] * c/src/lib/libbsp/mips/rbtx4925/preinstall.am (added) New. Thu, 16 Mar 2006 17:34:05 GMT Ralf Corsepius [15ebdf1f] * c/src/lib/libbsp/mips/rbtx4925/.cvsignore (added) * c/src/lib/libbsp/mips/rbtx4925/ChangeLog (added) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (added) * c/src/lib/libbsp/mips/rbtx4925/README (added) * c/src/lib/libbsp/mips/rbtx4925/bsp_specs (added) * c/src/lib/libbsp/mips/rbtx4925/clock/clockdrv.c (added) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (added) * c/src/lib/libbsp/mips/rbtx4925/console/console-io.c (added) * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (added) * c/src/lib/libbsp/mips/rbtx4925/include/tm27.h (added) * c/src/lib/libbsp/mips/rbtx4925/liblnk/lnklib.S (added) * c/src/lib/libbsp/mips/rbtx4925/liblnk/pmon.S (added) * c/src/lib/libbsp/mips/rbtx4925/liblnk/regs.S (added) * c/src/lib/libbsp/mips/rbtx4925/start/start.S (added) * c/src/lib/libbsp/mips/rbtx4925/startup/bspclean.c (added) * c/src/lib/libbsp/mips/rbtx4925/startup/bspstart.c (added) * c/src/lib/libbsp/mips/rbtx4925/startup/exception.S (added) * c/src/lib/libbsp/mips/rbtx4925/startup/idtmem.S (added) * c/src/lib/libbsp/mips/rbtx4925/startup/idttlb.S (added) * c/src/lib/libbsp/mips/rbtx4925/startup/inittlb.c (added) * c/src/lib/libbsp/mips/rbtx4925/startup/linkcmds (added) New (Submission by Bruce Robinson ) Thu, 16 Mar 2006 17:29:44 GMT Ralf Corsepius [128f3d0] * c/src/lib/libbsp/mips/hurricane/preinstall.am (added) New. Thu, 16 Mar 2006 17:18:20 GMT Ralf Corsepius [7283768] * c/src/lib/libbsp/mips/hurricane/.cvsignore (added) * c/src/lib/libbsp/mips/hurricane/ChangeLog (added) * c/src/lib/libbsp/mips/hurricane/Makefile.am (added) * c/src/lib/libbsp/mips/hurricane/README (added) * c/src/lib/libbsp/mips/hurricane/bsp_specs (added) * c/src/lib/libbsp/mips/hurricane/clock/ckinit.c (added) * c/src/lib/libbsp/mips/hurricane/clock/clock.S (added) * c/src/lib/libbsp/mips/hurricane/clock/clock.h (added) * c/src/lib/libbsp/mips/hurricane/configure.ac (added) * c/src/lib/libbsp/mips/hurricane/console/console.c (added) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (added) * c/src/lib/libbsp/mips/hurricane/include/coverhd.h (added) * c/src/lib/libbsp/mips/hurricane/include/tm27.h (added) * c/src/lib/libbsp/mips/hurricane/include/usc.h (added) * c/src/lib/libbsp/mips/hurricane/liblnk/lnklib.S (added) * c/src/lib/libbsp/mips/hurricane/liblnk/pmon.S (added) * c/src/lib/libbsp/mips/hurricane/liblnk/regs.S (added) * c/src/lib/libbsp/mips/hurricane/start/start.S (added) * c/src/lib/libbsp/mips/hurricane/startup/bspclean.c (added) * c/src/lib/libbsp/mips/hurricane/startup/bspstart.c (added) * c/src/lib/libbsp/mips/hurricane/startup/exception.S (added) * c/src/lib/libbsp/mips/hurricane/startup/ghlinkcmds (added) * c/src/lib/libbsp/mips/hurricane/startup/idtmem.S (added) * c/src/lib/libbsp/mips/hurricane/startup/idttlb.S (added) * c/src/lib/libbsp/mips/hurricane/startup/inittlb.c (added) * c/src/lib/libbsp/mips/hurricane/startup/linkcmds (added) * c/src/lib/libbsp/mips/hurricane/startup/setvec.c (added) * c/src/lib/libbsp/mips/hurricane/times (added) New (Submission by Bruce Robinson ). Thu, 16 Mar 2006 17:09:26 GMT Ralf Corsepius [e81ac77] * make/ChangeLog (modified) * make/custom/hurricane.cfg (added) * make/custom/rbtx4925.cfg (added) * make/custom/rbtx4938.cfg (added) 2006-03-16 Ralf Corsepius * ... Thu, 16 Mar 2006 11:22:00 GMT Ralf Corsepius [3a14c7b] * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/README (deleted) 2006-03-16 Ralf Corsepius * ... Thu, 16 Mar 2006 11:20:59 GMT Ralf Corsepius [b5e0694] * c/src/lib/libbsp/mips/ChangeLog (modified) 2006-03-16 Ralf Corsepius * ... Thu, 16 Mar 2006 11:18:43 GMT Ralf Corsepius [1a24742e] * c/src/lib/libbsp/mips/p4000/.cvsignore (deleted) * c/src/lib/libbsp/mips/p4000/ChangeLog (deleted) * c/src/lib/libbsp/mips/p4000/Makefile.am (deleted) * c/src/lib/libbsp/mips/p4000/README (deleted) * c/src/lib/libbsp/mips/p4000/bsp_specs (deleted) * c/src/lib/libbsp/mips/p4000/configure.ac (deleted) * c/src/lib/libbsp/mips/p4000/console/console.c (deleted) * c/src/lib/libbsp/mips/p4000/console/led.S (deleted) * c/src/lib/libbsp/mips/p4000/include/.cvsignore (deleted) * c/src/lib/libbsp/mips/p4000/include/bsp.h (deleted) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (deleted) * c/src/lib/libbsp/mips/p4000/include/tm27.h (deleted) * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (deleted) * c/src/lib/libbsp/mips/p4000/preinstall.am (deleted) * c/src/lib/libbsp/mips/p4000/start/start.S (deleted) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (deleted) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (deleted) * c/src/lib/libbsp/mips/p4000/startup/ghlinkcmds (deleted) * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (deleted) * c/src/lib/libbsp/mips/p4000/startup/idttlb.S (deleted) * c/src/lib/libbsp/mips/p4000/startup/inittlb.c (deleted) * c/src/lib/libbsp/mips/p4000/startup/linkcmds (deleted) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (deleted) * c/src/lib/libbsp/mips/p4000/times (deleted) * make/custom/p4000.cfg (deleted) * make/custom/p4600.cfg (deleted) * make/custom/p4650.cfg (deleted) Remove (abandoned). Thu, 16 Mar 2006 11:16:04 GMT Ralf Corsepius [c795467] * make/ChangeLog (modified) 2006-03-16 Ralf Corsepius * ... Thu, 16 Mar 2006 06:47:34 GMT Ralf Corsepius [f906d86] * contrib/crossrpms/binutils/binutils.add (modified) Require base-binutils if building infos. Thu, 16 Mar 2006 06:45:40 GMT Ralf Corsepius [bef3adb] * contrib/crossrpms/configure.ac (modified) Remove message erroniously checked in in previous change Thu, 16 Mar 2006 06:44:27 GMT Ralf Corsepius [77cd26d] * contrib/crossrpms/configure.ac (modified) Set defaults for ac_default_prefix Wed, 15 Mar 2006 17:42:31 GMT Ralf Corsepius [b224280] * contrib/crossrpms/configure.ac (modified) Increment version Wed, 15 Mar 2006 17:41:56 GMT Ralf Corsepius [cab09c0b] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/cygwin/target-w32api.add (added) * contrib/crossrpms/cygwin/w32api.add (added) Add w32api Sat, 11 Mar 2006 09:01:52 GMT Ralf Corsepius [760e8186] * contrib/crossrpms/gdb/build.add (modified) configure --enable-sim Sat, 11 Mar 2006 09:01:09 GMT Ralf Corsepius [aa005877] * contrib/crossrpms/gdb/install.add (modified) Use DESTDIR for gdb >= 6.3. Remove bogus lib*-sim.a Fri, 10 Mar 2006 13:47:18 GMT Ralf Corsepius [7f48ec7] * contrib/crossrpms/TODO (modified) Reflect having added --enable-infos Fri, 10 Mar 2006 13:45:05 GMT Ralf Corsepius [1a64d3e] * contrib/crossrpms/configure.ac (modified) Increment version Fri, 10 Mar 2006 13:44:30 GMT Ralf Corsepius [13501927] * contrib/crossrpms/binutils/base-binutils.add (modified) * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/binutils/build.add (modified) * contrib/crossrpms/binutils/install.add (modified) * contrib/crossrpms/gcc/base-g77.add (modified) * contrib/crossrpms/gcc/base-gcc.add (modified) * contrib/crossrpms/gcc/base-gcj.add (modified) * contrib/crossrpms/gcc/base-gfortran.add (modified) * contrib/crossrpms/gcc/base-gnat.add (modified) * contrib/crossrpms/gcc/base-newlib.add (modified) * contrib/crossrpms/gcc/build.add (modified) * contrib/crossrpms/gcc/gccnewlib.add (modified) * contrib/crossrpms/gcc/install.add (modified) * contrib/crossrpms/gdb/base-gdb.add (modified) * contrib/crossrpms/gdb/build.add (modified) * contrib/crossrpms/gdb/gdb.add (modified) * contrib/crossrpms/gdb/install.add (modified) Use %build_infos Fri, 10 Mar 2006 13:40:54 GMT Ralf Corsepius [a56035b] * contrib/crossrpms/mkspec.am (modified) Propagate build_infos to *.spec.ins Fri, 10 Mar 2006 06:24:55 GMT Ralf Corsepius [4d3e4476] * contrib/crossrpms/configure.ac (modified) Rework rpmprefix logic. Add --enable-infos/build_infos. Fri, 10 Mar 2006 06:24:23 GMT Ralf Corsepius [0605460] * contrib/crossrpms/README (modified) Add missing comma. Fri, 10 Mar 2006 06:06:10 GMT Ralf Corsepius [783e6007] * contrib/crossrpms/rtems/Makefile.am (modified) Add gdb Fri, 10 Mar 2006 06:04:31 GMT Ralf Corsepius [81f6a9ef] * contrib/crossrpms/Makefile.am (modified) Add gdb/*.add Fri, 10 Mar 2006 06:03:39 GMT Ralf Corsepius [59c3dfe] * contrib/crossrpms/gdb/base-gdb.add (added) * contrib/crossrpms/gdb/build.add (added) * contrib/crossrpms/gdb/gdb.add (added) * contrib/crossrpms/gdb/install.add (added) * contrib/crossrpms/gdb/prep.add (added) * contrib/crossrpms/gdb/rpm-install.add (added) * contrib/crossrpms/gdb/target-gdb.add (added) New. Fri, 10 Mar 2006 06:03:05 GMT Ralf Corsepius [c2f69fe] * contrib/crossrpms/NEWS (modified) 2006-03-10 Add preliminary rtems-gdb specs. ... Thu, 09 Mar 2006 06:12:54 GMT Ralf Corsepius [c6bfd5d2] * ChangeLog (modified) * acinclude.m4 (modified) 2006-03-09 Ralf Corsepius * ... Thu, 09 Mar 2006 05:11:22 GMT Ralf Corsepius [64391f1] * contrib/crossrpms/TODO (modified) Add note on Ada. Thu, 09 Mar 2006 05:07:57 GMT Ralf Corsepius [f26c821] * contrib/crossrpms/NEWS (modified) * contrib/crossrpms/TODO (modified) Update Thu, 09 Mar 2006 03:30:37 GMT Ralf Corsepius [9b7443c] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) Enable fortran and objc Wed, 08 Mar 2006 18:55:45 GMT Joel Sherrill [1ff385c] * cpukit/ChangeLog (modified) * cpukit/score/src/threadhandler.c (modified) 2006-03-08 Joel Sherrill PR ... Wed, 08 Mar 2006 18:53:44 GMT Joel Sherrill [15096905] * cpukit/ChangeLog (modified) * cpukit/itron/macros/rtems/itron/semaphore.inl (modified) * cpukit/itron/macros/rtems/itron/task.inl (modified) * cpukit/posix/macros/rtems/posix/cond.inl (modified) * cpukit/score/macros/rtems/score/heap.inl (modified) 2006-03-08 Joel Sherrill * ... Wed, 08 Mar 2006 18:51:44 GMT Joel Sherrill [bd86290d] * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/startup/linkcmds (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/ep1a/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/ss555/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ss555/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/startup/linkcmds (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon2/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon2/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon3/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds (modified) 2006-03-08 Joel Sherrill * ... Wed, 08 Mar 2006 18:51:26 GMT Joel Sherrill [7c11146a] * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/startup/linkcmds (modified) * c/src/lib/libbsp/sh/simsh4/startup/linkcmds-le (modified) * c/src/lib/libbsp/sh/simsh4/startup/linkcmds-le.coff (modified) 2006-03-08 Joel Sherrill * ... Wed, 08 Mar 2006 18:51:21 GMT Joel Sherrill [e46416d] * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds.rom (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds.rom2ram (modified) 2006-03-08 Joel Sherrill * ... Wed, 08 Mar 2006 18:51:12 GMT Joel Sherrill [84138c1] * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.ram (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.rom (modified) 2006-03-08 Joel Sherrill * ... Wed, 08 Mar 2006 18:50:56 GMT Joel Sherrill [4ba9e20] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (modified) 2006-03-08 Joel Sherrill * ... Wed, 08 Mar 2006 18:49:09 GMT Joel Sherrill [bb1626a] * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/gen405/startup/linkcmds.dl (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/helas403/startup/linkcmds.dl (modified) 2006-03-08 Joel Sherrill * ... Wed, 08 Mar 2006 18:49:05 GMT Joel Sherrill [c8e821cd] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/linkcmds.pm520 (modified) 2006-03-08 Joel Sherrill * ... Wed, 08 Mar 2006 14:10:16 GMT Joel Sherrill [0577849b] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2006-03-08 Joel Sherrill * ... Wed, 08 Mar 2006 09:22:44 GMT Ralf Corsepius [f7c8422] * contrib/crossrpms/mingw32/gcc-sources.add (modified) Deactivate PATCH0 (not required for gcc >= 4.1.0 Wed, 08 Mar 2006 09:21:42 GMT Ralf Corsepius [73d88d14] * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Activate fortran and objc Tue, 07 Mar 2006 22:26:53 GMT Joel Sherrill [27207213] * cpukit/ChangeLog (modified) Added PR825 reference. Tue, 07 Mar 2006 22:23:15 GMT Joel Sherrill [360d9da] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/termios.c (modified) 2006-03-07 Till Strauman ... Tue, 07 Mar 2006 22:10:35 GMT Joel Sherrill [77b0a73] * cpukit/ChangeLog (modified) * cpukit/score/src/watchdogtickle.c (modified) 2006-03-07 Steven Johnson ... Tue, 07 Mar 2006 22:05:22 GMT Joel Sherrill [d5ed9e1] * c/src/ChangeLog (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ide_controller.c (modified) 2006-03-07 Thomas Doerfler ... Tue, 07 Mar 2006 21:59:07 GMT Joel Sherrill [bea51c0] * ChangeLog (modified) * release_support (modified) 2006-03-07 Joel Sherrill PR ... Tue, 07 Mar 2006 21:26:23 GMT Joel Sherrill [0ebfac19] * cpukit/ChangeLog (modified) * cpukit/libblock/src/bdbuf.c (modified) 2006-03-07 Thomas Doerfler ... Tue, 07 Mar 2006 21:07:25 GMT Joel Sherrill [ab8394f6] * c/src/ChangeLog (modified) Add PRs. Tue, 07 Mar 2006 21:05:28 GMT Joel Sherrill [75bf564] * c/src/lib/libcpu/arm/ChangeLog (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) 2006-03-07 Lars Munch * ... Tue, 07 Mar 2006 21:02:45 GMT Joel Sherrill [d3490f27] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/libio.c (modified) 2006-03-07 Till Strauman ... Tue, 07 Mar 2006 20:47:53 GMT Joel Sherrill [f0ad529] * cpukit/ChangeLog (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) 2006-03-07 Joel Sherrill PR ... Tue, 07 Mar 2006 14:03:01 GMT Ralf Corsepius [a03debd5] * contrib/crossrpms/TODO (added) New. Tue, 07 Mar 2006 13:42:57 GMT Ralf Corsepius [c429c016] * contrib/crossrpms/gcc/target-c++.add (modified) * contrib/crossrpms/gcc/target-g77.add (modified) * contrib/crossrpms/gcc/target-gcj.add (modified) * contrib/crossrpms/gcc/target-gfortran.add (modified) * contrib/crossrpms/gcc/target-gnat.add (modified) * contrib/crossrpms/gcc/target-objc.add (modified) Use gcc_rpmvers for subpackage deps. Tue, 07 Mar 2006 09:02:11 GMT Ralf Corsepius [027c603] * contrib/crossrpms/gcc/gccnewlib.add (modified) Use %echo instead of %%echo in %expand Tue, 07 Mar 2006 05:28:35 GMT Ralf Corsepius [9087b7c] * contrib/crossrpms/configure.ac (modified) Fix main package name. Update version. Tue, 07 Mar 2006 05:26:26 GMT Ralf Corsepius [6eba5919] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Distribute local *.add files. Tue, 07 Mar 2006 05:26:08 GMT Ralf Corsepius [0166739] * contrib/crossrpms/rtems/Makefile.am (modified) Distribute local *.add files. Reflect having renamed *-libc.add into ... Tue, 07 Mar 2006 05:24:02 GMT Ralf Corsepius [29ffb1e7] * contrib/crossrpms/Makefile.am (modified) Reflect having renamed gcc/*-libc.add into gcc/*-newlib.add Tue, 07 Mar 2006 03:29:13 GMT Ralf Corsepius [d11d10fe] * contrib/crossrpms/gcc/base-libc.add (deleted) * contrib/crossrpms/gcc/target-libc.add (deleted) Renamed into *-newlib.add Tue, 07 Mar 2006 03:26:23 GMT Ralf Corsepius [2c7efaa7] * contrib/crossrpms/gcc/base-newlib.add (added) * contrib/crossrpms/gcc/target-newlib.add (added) Renamed from *-libc.add to *-newlib.add Mon, 06 Mar 2006 15:43:10 GMT Ralf Corsepius [ab163629] * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/rtems/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) GCC_VERS = 4.1.0 Mon, 06 Mar 2006 15:36:59 GMT Ralf Corsepius [5c8f5f66] * contrib/crossrpms/cygwin/Makefile.am (modified) * contrib/crossrpms/freebsd5.2/Makefile.am (modified) * contrib/crossrpms/freebsd6.0/Makefile.am (modified) * contrib/crossrpms/mingw32/Makefile.am (modified) * contrib/crossrpms/solaris2.7/Makefile.am (modified) Subst gcc_rpmvers for LIB packages. Mon, 06 Mar 2006 05:55:02 GMT Ralf Corsepius [c04a6103] * contrib/crossrpms/binutils/binutils.add (modified) * contrib/crossrpms/cygwin/libs.add (modified) * contrib/crossrpms/freebsd5.2/libs.add (modified) * contrib/crossrpms/freebsd6.0/libs.add (modified) * contrib/crossrpms/mingw32/libs.add (modified) * contrib/crossrpms/mingw32/w32api.add (modified) * contrib/crossrpms/solaris2.7/libs.add (modified) Remove stray blank in %expand to setup rpmvers. Sat, 04 Mar 2006 06:04:34 GMT Ralf Corsepius [503be14] * contrib/crossrpms/configure.ac (modified) Add osversion hack
