# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 22:03:10 Mon, 26 Mar 2012 12:58:35 GMT Sebastian Huber [e4f88fc] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev-imfs.c (modified) * cpukit/libblock/src/blkdev-ioctl.c (modified) * cpukit/libblock/src/diskdevs.c (modified) libblock: Add rtems_bdbuf_set_block_size() The new function ... Mon, 26 Mar 2012 11:19:33 GMT Sebastian Huber [4de9e69] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) libblock: Change error status to fatal error Calling the bdbuf API ... Mon, 26 Mar 2012 10:56:01 GMT Sebastian Huber [3066e467] * cpukit/libblock/src/bdbuf.c (modified) libblock: Use unprotected chain operations The transfer chain is ... Mon, 26 Mar 2012 09:43:57 GMT Sebastian Huber [aaaa1b5] * cpukit/libblock/src/bdbuf.c (modified) libblock: Use unprotected chain operations The chains are protected ... Wed, 11 Jan 2012 13:37:24 GMT Sebastian Huber [2c96e46d] * cpukit/Makefile.am (modified) * cpukit/aclocal/enable-cxx.m4 (added) * cpukit/aclocal/prog-cxx.m4 (added) * cpukit/configure.ac (modified) * cpukit/gtest/Makefile.am (added) * cpukit/gtest/include/gtest/gtest-death-test.h (added) * cpukit/gtest/include/gtest/gtest-main.h (added) * cpukit/gtest/include/gtest/gtest-message.h (added) * cpukit/gtest/include/gtest/gtest-param-test.h (added) * cpukit/gtest/include/gtest/gtest-printers.h (added) * cpukit/gtest/include/gtest/gtest-spi.h (added) * cpukit/gtest/include/gtest/gtest-test-part.h (added) * cpukit/gtest/include/gtest/gtest-typed-test.h (added) * cpukit/gtest/include/gtest/gtest.h (added) * cpukit/gtest/include/gtest/gtest_pred_impl.h (added) * cpukit/gtest/include/gtest/gtest_prod.h (added) * cpukit/gtest/include/gtest/internal/gtest-death-test-internal.h (added) * cpukit/gtest/include/gtest/internal/gtest-filepath.h (added) * cpukit/gtest/include/gtest/internal/gtest-internal.h (added) * cpukit/gtest/include/gtest/internal/gtest-linked_ptr.h (added) * cpukit/gtest/include/gtest/internal/gtest-param-util-generated.h (added) * cpukit/gtest/include/gtest/internal/gtest-param-util.h (added) * cpukit/gtest/include/gtest/internal/gtest-port.h (added) * cpukit/gtest/include/gtest/internal/gtest-string.h (added) * cpukit/gtest/include/gtest/internal/gtest-tuple.h (added) * cpukit/gtest/include/gtest/internal/gtest-type-util.h (added) * cpukit/gtest/preinstall.am (added) * cpukit/gtest/src/gtest-all.cc (added) * cpukit/gtest/src/gtest-death-test.cc (added) * cpukit/gtest/src/gtest-filepath.cc (added) * cpukit/gtest/src/gtest-internal-inl.h (added) * cpukit/gtest/src/gtest-port.cc (added) * cpukit/gtest/src/gtest-printers.cc (added) * cpukit/gtest/src/gtest-test-part.cc (added) * cpukit/gtest/src/gtest-typed-test.cc (added) * cpukit/gtest/src/gtest.cc (added) Google C++ Testing Framework 1.6.0. Wed, 11 Jan 2012 13:32:49 GMT Sebastian Huber [34a706d9] * c/src/make/Makefile.am (modified) * c/src/make/bsp.mk.in (added) * c/src/make/configure.ac (modified) Support custom Makefiles. Wed, 11 Jan 2012 13:15:52 GMT Sebastian Huber [aab9483] * c/src/lib/libbsp/sparc/erc32/make/custom/erc32.cfg (modified) Disable optimization. Fri, 17 Feb 2012 21:29:58 GMT Ric Claus [4648ade] * cpukit/libmisc/shell/main_mdump.c (modified) PR 2021 - mdump address problem with volatile Fri, 30 Mar 2012 15:03:43 GMT Ric Claus [16a8616] * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (added) * c/src/lib/libbsp/powerpc/virtex4/bsp_specs (added) * c/src/lib/libbsp/powerpc/virtex4/clock/clock.c (added) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (added) * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (added) * c/src/lib/libbsp/powerpc/virtex4/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/virtex4/include/irq.h (added) * c/src/lib/libbsp/powerpc/virtex4/irq/irq_init.c (added) * c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg (added) * c/src/lib/libbsp/powerpc/virtex4/preinstall.am (added) * c/src/lib/libbsp/powerpc/virtex4/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/virtex4/startup/dummy_console.c (added) * c/src/lib/libbsp/powerpc/virtex4/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/virtex4/startup/start.S (added) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (added) * c/src/lib/libbsp/powerpc/virtex5/bsp_specs (added) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (added) * c/src/lib/libbsp/powerpc/virtex5/console/dummy_console.c (added) * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (added) * c/src/lib/libbsp/powerpc/virtex5/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/virtex5/include/irq.h (added) * c/src/lib/libbsp/powerpc/virtex5/irq/irq_init.c (added) * c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg (added) * c/src/lib/libbsp/powerpc/virtex5/preinstall.am (added) * c/src/lib/libbsp/powerpc/virtex5/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c (added) * c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/virtex5/startup/start.S (added) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/README (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_categories.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/debugmod.h (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.c (modified) * c/src/lib/libcpu/powerpc/shared/include/cpuIdent.h (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) Add Virtex4 and Virtex5 BSPs This commit covers at least PR2020, ... Fri, 30 Mar 2012 13:41:15 GMT Jennifer Averett [0b095f76] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/exar17d15x.c (added) * c/src/lib/libbsp/i386/pc386/console/exar17d15x.h (added) * c/src/lib/libbsp/i386/pc386/console/rtd316.c (added) * c/src/lib/libbsp/i386/pc386/console/rtd316.h (added) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * cpukit/sapi/inline/rtems/rbtree.inl (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-mpu-add-region.c (added) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/rtems/score/nios2-utility.h (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/inline/rtems/score/rbtree.inl (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/rbtreepeek.c (modified) * cpukit/score/src/scheduleredf.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) Resolve link problems with psim irq-server Add IRQ support ... Fri, 30 Mar 2012 13:38:14 GMT Jennifer Averett [97f82fc] * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) Resolve link problems with psim irq-server Fri, 30 Mar 2012 12:59:18 GMT Sebastian Huber [40b8f63a] * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/nios2-mpu-add-region.c (added) * cpukit/score/cpu/nios2/nios2-mpu-descriptor.c (modified) * cpukit/score/cpu/nios2/rtems/score/nios2-utility.h (modified) NIOS2: Add MPU support functions Fri, 30 Mar 2012 12:55:17 GMT Sebastian Huber [64d2c8ad] * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) NIOS2: Fix outermost interrupt check This fix is critical. The ... Fri, 30 Mar 2012 09:35:39 GMT Sebastian Huber [9fc284c] * cpukit/sapi/inline/rtems/rbtree.inl (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/inline/rtems/score/rbtree.inl (modified) * cpukit/score/src/rbtreepeek.c (modified) score/rbtree: Add const qualifier Fri, 30 Mar 2012 09:21:32 GMT Sebastian Huber [c6dbcd6] * cpukit/score/inline/rtems/score/rbtree.inl (modified) score/rbtree: C++ compatibility Fri, 30 Mar 2012 07:50:10 GMT Sebastian Huber [c6218c24] * cpukit/score/src/scheduleredf.c (modified) score/scheduleredf: Simplify and fix warning Fri, 30 Mar 2012 00:41:34 GMT Gedare Bloom [890358f] * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/inline/rtems/score/rbtree.inl (modified) * cpukit/score/src/rbtreeinsert.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) PR1994: RBTree Compare Result Change Change the meaning of the ... Thu, 29 Mar 2012 20:53:16 GMT Joel Sherrill [8d0913b8] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) PC386 - Add files missed in previous commit Thu, 29 Mar 2012 20:28:13 GMT Joel Sherrill [2cc30b0d] * c/src/lib/libbsp/i386/pc386/console/exar17d15x.c (added) * c/src/lib/libbsp/i386/pc386/console/exar17d15x.h (added) * c/src/lib/libbsp/i386/pc386/console/rtd316.c (added) * c/src/lib/libbsp/i386/pc386/console/rtd316.h (added) PC386 Add RTD316 and Exar 17D15x multi-port serial card support - ... Thu, 29 Mar 2012 11:52:16 GMT Daniel Hellstrom [2cee553] * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) LEON3: various cleanups in leon.h Removed old LEON2 definitions ... Thu, 29 Mar 2012 11:52:14 GMT Daniel Hellstrom [226771c] * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) LEON3: IRQ index mask was bad, but always shifted out anyway ... Thu, 29 Mar 2012 11:52:13 GMT Daniel Hellstrom [4fa6be9] * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) LEON3: clock timer indexing should be consequent Signed-off-by: ... Thu, 29 Mar 2012 17:07:30 GMT Jennifer Averett [752f876e] * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq.h (modified) Address Conflicts: c/src/lib/libbsp/powerpc/psim/startup/linkcmds Wed, 28 Mar 2012 08:49:27 GMT Daniel Hellstrom [0729e2a7] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/bspgetworkarea.c (modified) * c/src/lib/libbsp/sparc/shared/startup/early_malloc.c (added) SPARC: bsp_early_malloc() routine for startup memory allocation If ... Thu, 29 Mar 2012 11:52:12 GMT Daniel Hellstrom [b9d8cd33] * c/src/libchip/network/smc91111.c (modified) SMC91111: remove old unused LEON2/LEON3 intialization code ... Thu, 29 Mar 2012 11:52:11 GMT Daniel Hellstrom [d0dbcf8] * c/src/lib/libbsp/sparc/leon3/leon_greth/leon_greth.c (modified) LEON3: fix GRETH interrupt initialization bug Fixed a bug where the ... Thu, 29 Mar 2012 11:52:10 GMT Daniel Hellstrom [e6f327c] * c/src/libchip/network/greth.c (modified) GRETH: removed the use of rtems_set_clock() in auto-nego timeout ... Mon, 26 Mar 2012 20:42:38 GMT Gedare Bloom [e53aae2] * cpukit/sapi/include/confdefs.h (modified) * doc/user/Makefile.am (modified) * doc/user/conf.t (modified) * testsuites/samples/unlimited/system.h (modified) confdefs: Add declaration for unlimited objects. Adds to confdefs a ... Fri, 02 Dec 2011 09:53:35 GMT Daniel Hellstrom [39671330] * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/libchip/network/greth.c (modified) GRETH: added support for non-snooping GRETH 10/100 systems When ... Tue, 27 Mar 2012 15:37:00 GMT Sebastian Huber [f442e6b4] * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) ARM: PR2042: Provide stub for ARMv6-M Mon, 26 Mar 2012 10:54:36 GMT Sebastian Huber [4ee0fa87] * testsuites/libtests/block06/init.c (modified) libtests/block06: Increase stack size Sat, 24 Mar 2012 21:56:37 GMT Sebastian Huber [a73884e9] * c/src/lib/libbsp/arm/lm3s69xx/README (modified) bsp/lm3s69xx: Reflect new Qemu patch Sat, 24 Mar 2012 21:53:07 GMT Sebastian Huber [bd0fb473] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/irq/irq.c (deleted) * c/src/lib/libbsp/arm/lm3s69xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq-dispatch.c (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/shared/armv7m/include/armv7m-irq.h (added) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq-dispatch.c (added) * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (added) bsps: Shared ARMv7-M interrupt support Sat, 24 Mar 2012 21:01:08 GMT Sebastian Huber [0f31fddc] * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.c (modified) * c/src/lib/libbsp/arm/gba/Makefile.am (modified) * c/src/lib/libbsp/arm/gba/irq/irq.c (modified) * c/src/lib/libbsp/arm/gp32/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/lm32/shared/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c (modified) * c/src/lib/libbsp/shared/src/irq-default-handler.c (added) * c/src/lib/libcpu/arm/at91rm9200/irq/irq.c (modified) * c/src/lib/libcpu/arm/lpc22xx/irq/irq.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/irq/irq.c (modified) * c/src/lib/libcpu/arm/pxa255/irq/irq.c (modified) * c/src/lib/libcpu/arm/s3c24xx/irq/irq.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c (modified) bsps: Add shared default IRQ handler Sat, 24 Mar 2012 20:04:40 GMT Sebastian Huber [b2ee4d5f] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/preinstall.am (modified) bsp/lm3s69xx: Format Sat, 24 Mar 2012 19:57:21 GMT Sebastian Huber [954393ca] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/timer/timer.c (deleted) bsp/lm3s69xx: Use shared timer stub driver Sat, 24 Mar 2012 19:55:40 GMT Sebastian Huber [1ed238e] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/start/start.S (deleted) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstarthook.c (modified) bsp/lm3s69xx: Use shared start.S Sat, 24 Mar 2012 19:14:27 GMT Sebastian Huber [34c61517] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (moved) * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (modified) bsps: Shared ARMv7-M clock driver Sat, 24 Mar 2012 19:07:17 GMT Sebastian Huber [f9ec6004] * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) ARM: New define ARMV7M_EXCEPTION_PRIORITY_LOWEST Sat, 24 Mar 2012 19:06:49 GMT Sebastian Huber [3c0e7f9b] * c/src/lib/libbsp/arm/lm3s69xx/0005-target-arm-Fix-system_clock_scale-initial-value.patch (added) bsp/lm3s69xx: New Qemu patch Sat, 24 Mar 2012 16:33:22 GMT Sebastian Huber [5cc813f] * c/src/lib/libbsp/shared/include/irq-generic.h (modified) bsps: Provide optional prototype Sat, 24 Mar 2012 15:59:25 GMT Sebastian Huber [e8adc8e3] * c/src/lib/libbsp/arm/lpc24xx/misc/io.c (modified) bsp/lpc24xx: Use proper clock value Sat, 24 Mar 2012 15:58:31 GMT Sebastian Huber [f3cdf279] * c/src/lib/libbsp/arm/lpc24xx/include/io.h (modified) bsp/lpc24xx: More CAN pin definitions Mon, 06 Feb 2012 14:15:49 GMT Daniel Hellstrom [67b1ce4] * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/libchip/network/smc91111.c (modified) SMC91111: ERC32 was never supported by driver Moved the ... Mon, 06 Feb 2012 14:15:48 GMT Daniel Hellstrom [f636ba64] * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/include/irq.h (modified) shared-irq: add support for custom BSP vector verification ... Mon, 06 Feb 2012 14:15:47 GMT Daniel Hellstrom [b4dfce9b] * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) LEON3: spurious trap handler print out trap in hex instead ... Wed, 08 Feb 2012 14:57:03 GMT Daniel Hellstrom [80d01b3c] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/access/access.S (added) * c/src/lib/libcpu/sparc/access/access_le.c (added) * c/src/lib/libcpu/sparc/include/libcpu/access.h (added) * c/src/lib/libcpu/sparc/include/libcpu/byteorder.h (added) * c/src/lib/libcpu/sparc/preinstall.am (modified) SPARC: added libcpu lowlevel access and byteorder ... Fri, 16 Mar 2012 13:23:43 GMT Jennifer Averett [7e664023] * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) Added irq server and link commands for new libbsd support. Wed, 14 Mar 2012 17:06:13 GMT Gedare Bloom [67baf60] * c/src/lib/libcpu/sparc64/shared/score/interrupt.S (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) PR2041: sparc64: vector number not included in CPU_Interrupt_frame ... Wed, 14 Mar 2012 15:45:26 GMT Sebastian Huber [4868c771] * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_plx800_ram.cfg (added) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx_plx800_rom_int.cfg (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_plx800_ram (added) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_plx800_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-emc-dynamic.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-emc-static.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/start-config-pinsel.c (modified) bsp/lpc24xx: New BSP variant Fri, 09 Mar 2012 13:46:40 GMT Sebastian Huber [23ed785] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/flashdisk01/Makefile.am (added) * testsuites/libtests/flashdisk01/flashdisk01.doc (added) * testsuites/libtests/flashdisk01/flashdisk01.scn (added) * testsuites/libtests/flashdisk01/init.c (added) * testsuites/libtests/flashdisk01/test-file-system.c (added) * testsuites/libtests/flashdisk01/test-file-system.h (added) PR2040: libtests/flashdisk01: New test Wed, 14 Mar 2012 09:45:36 GMT Sebastian Huber [9f808d1f] * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Flash disk starvations statistic Wed, 14 Mar 2012 09:33:55 GMT Sebastian Huber [a757d0f] * cpukit/libblock/include/rtems/flashdisk.h (modified) * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Flash disk documentation Fri, 09 Mar 2012 13:45:08 GMT Sebastian Huber [a309a79] * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Fix return status Wed, 14 Mar 2012 07:45:53 GMT Sebastian Huber [c08072ce] * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Avoid erased blocks starvation The compaction ... Tue, 13 Mar 2012 13:52:57 GMT Sebastian Huber [f9fd0c2] * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Track number of erased blocks Tue, 13 Mar 2012 13:51:55 GMT Sebastian Huber [12806cd] * cpukit/libblock/src/flashdisk.c (modified) PR2040: libblock: Use segment control as parameter Fri, 09 Mar 2012 13:13:22 GMT Sebastian Huber [790f04d] * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) PR2039: Fix NULL pointer access In case rtems_bdbuf_read() returns ... Tue, 28 Feb 2012 14:37:31 GMT Sebastian Huber [113944fa] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsbdpart01/Makefile.am (added) * testsuites/fstests/fsbdpart01/fsbdpart01.doc (added) * testsuites/fstests/fsbdpart01/fsbdpart01.scn (added) * testsuites/fstests/fsbdpart01/init.c (added) fstests/fsbdpart01: New test Mon, 05 Mar 2012 15:22:33 GMT Sebastian Huber [3ab9c76d] * cpukit/libblock/src/media.c (modified) libblock: Use new API for disk media Mon, 05 Mar 2012 14:06:02 GMT Sebastian Huber [01211720] * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/blkdev-imfs.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/block11/Makefile.am (added) * testsuites/libtests/block11/block11.doc (added) * testsuites/libtests/block11/block11.scn (added) * testsuites/libtests/block11/init.c (added) * testsuites/libtests/configure.ac (modified) libblock: Add generic IMFS block device nodes New functions o ... Mon, 05 Mar 2012 13:39:53 GMT Sebastian Huber [291c9264] * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/src/blkdev-ioctl.c (added) * cpukit/libblock/src/blkdev.c (modified) libblock: Split file and simplify Mon, 05 Mar 2012 10:47:56 GMT Sebastian Huber [3ee7b84] * cpukit/libblock/include/rtems/diskdevs.h (modified) libblock: New support functions Add o ... Tue, 28 Feb 2012 16:19:49 GMT Sebastian Huber [796967c] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/include/rtems/bdpart.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/bdpart-create.c (modified) * cpukit/libblock/src/bdpart-read.c (modified) * cpukit/libblock/src/bdpart-register.c (modified) * cpukit/libblock/src/bdpart-write.c (modified) * cpukit/libblock/src/blkdev.c (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_format.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file-system.h (modified) * testsuites/libtests/block02/init.c (modified) * testsuites/libtests/block03/init.c (modified) * testsuites/libtests/block04/init.c (modified) * testsuites/libtests/block05/init.c (modified) * testsuites/libtests/block06/init.c (modified) * testsuites/libtests/block07/init.c (modified) * testsuites/libtests/block08/bdbuf_test1_1.c (modified) * testsuites/libtests/block08/bdbuf_test1_2.c (modified) * testsuites/libtests/block08/bdbuf_test1_3.c (modified) * testsuites/libtests/block08/bdbuf_test1_4.c (modified) * testsuites/libtests/block08/bdbuf_test1_5.c (modified) * testsuites/libtests/block08/bdbuf_test2_1.c (modified) * testsuites/libtests/block08/bdbuf_test2_2.c (modified) * testsuites/libtests/block08/bdbuf_test3_1.c (modified) * testsuites/libtests/block08/bdbuf_test3_2.c (modified) * testsuites/libtests/block08/bdbuf_test3_3.c (modified) * testsuites/libtests/block08/bdbuf_test4_1.c (modified) * testsuites/libtests/block08/bdbuf_test4_2.c (modified) * testsuites/libtests/block08/bdbuf_test4_3.c (modified) * testsuites/libtests/block08/bdbuf_tests.c (modified) * testsuites/libtests/block08/bdbuf_tests.h (modified) * testsuites/libtests/block08/test_disk.c (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/samples/fileio/init.c (modified) libblock: Change bdbuf API The functions o rtems_bdbuf_get(), o ... Tue, 28 Feb 2012 15:29:27 GMT Sebastian Huber [1024561] * cpukit/libblock/include/rtems/bdbuf.h (modified) libblock: Documentation Tue, 28 Feb 2012 14:59:04 GMT Sebastian Huber [c42b03f4] * cpukit/libblock/include/rtems/bdbuf.h (modified) * cpukit/libblock/src/bdbuf.c (modified) libblock: Remove superfluous volatile qualifier All these variables ... Tue, 28 Feb 2012 14:34:42 GMT Sebastian Huber [a3170f7] * cpukit/libblock/src/ide_part_table.c (modified) libblock: Discard extended partitions Discard the extended ... Tue, 28 Feb 2012 13:57:01 GMT Sebastian Huber [c93fc2b3] * cpukit/libblock/include/rtems/ide_part_table.h (modified) * cpukit/libblock/src/ide_part_table.c (modified) libblock: rtems_ide_part_table_initialize() API Tue, 28 Feb 2012 12:28:42 GMT Sebastian Huber [c649976] * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libmisc/shell/main_blksync.c (modified) * testsuites/libtests/block01/init.c (modified) libblock: New block IO control support functions Tue, 28 Feb 2012 12:03:15 GMT Sebastian Huber [4f3cbd9] * cpukit/libblock/include/rtems/blkdev.h (modified) * cpukit/libblock/src/blkdev.c (modified) libblock: New IO control RTEMS_BLKIO_GETDISKDEV Mon, 27 Feb 2012 16:23:05 GMT Sebastian Huber [03ad6b1d] * cpukit/libblock/src/ide_part_table.c (modified) libblock: Avoid bdbuf API Mon, 05 Mar 2012 09:02:52 GMT Sebastian Huber [5e88538] * cpukit/libblock/Makefile.am (modified) * cpukit/libblock/src/ramdisk-init.c (modified) * cpukit/libblock/src/ramdisk-register.c (added) libblock: Split file Mon, 05 Mar 2012 09:01:37 GMT Sebastian Huber [beea580] * cpukit/libblock/include/rtems/ramdisk.h (modified) * cpukit/libblock/src/ramdisk-driver.c (modified) libblock: Add optional free at delete request Mon, 05 Mar 2012 10:51:23 GMT Sebastian Huber [e998c985] * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) IMFS: Node specific stat handlers Mon, 05 Mar 2012 10:49:55 GMT Sebastian Huber [04ca77e] * cpukit/libfs/src/imfs/imfs.h (modified) IMFS: Generic device identifier Thu, 01 Mar 2012 10:51:34 GMT Sebastian Huber [c5392ef9] * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_make_generic_node.c (added) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsimfsgeneric01/Makefile.am (added) * testsuites/fstests/fsimfsgeneric01/fsimfsgeneric01.doc (added) * testsuites/fstests/fsimfsgeneric01/fsimfsgeneric01.scn (added) * testsuites/fstests/fsimfsgeneric01/init.c (added) IMFS: Add make generic node support Generic nodes are an ... Fri, 24 Feb 2012 16:08:06 GMT Sebastian Huber [699ac7c] * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) IMFS: Add and use node control Add and use structure ... Fri, 24 Feb 2012 15:40:19 GMT Sebastian Huber [70927458] * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) IMFS: New support functions Add and use IMFS_type() and ... Fri, 24 Feb 2012 08:21:04 GMT Sebastian Huber [6661435f] * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) IMFS: Removed superfluous imfs_dir_open() Thu, 23 Feb 2012 16:57:27 GMT Sebastian Huber [1bdff036] * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) IMFS: Reference counting for nodes The introduction of reference ... Tue, 21 Feb 2012 16:24:10 GMT Sebastian Huber [2e0ce55] * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) IMFS: Use unprotected chain operations Directory entry add or ... Tue, 21 Feb 2012 16:21:05 GMT Sebastian Huber [316507ab] * cpukit/libfs/src/imfs/imfs_directory.c (modified) IMFS: Lock the file system during directory reads Other threads may ... Tue, 21 Feb 2012 14:52:55 GMT Sebastian Huber [e00cca9b] * cpukit/libfs/src/imfs/imfs_creat.c (modified) * testsuites/sptests/spfifo01/init.c (modified) IMFS: Do not check for unsupported types Allow creation of nodes ... Tue, 13 Mar 2012 08:22:11 GMT Sebastian Huber [2563410] * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/_rename_r.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chmod.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/fchdir.c (modified) * cpukit/libcsupport/src/lchown.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lstat.c (modified) * cpukit/libcsupport/src/mknod.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/statvfs.c (modified) * cpukit/libcsupport/src/sup_fs_check_permissions.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path_generic.c (modified) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Filesystem: Rename defines o Removed RTEMS_LIBIO_PERMS_SEARCH. o ... Fri, 24 Feb 2012 16:39:27 GMT Sebastian Huber [4116fce6] * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_fdatasync.c (deleted) * cpukit/libfs/src/defaults/default_fsync.c (modified) * cpukit/libfs/src/defaults/default_fsync_success.c (added) * cpukit/libfs/src/defaults/default_handlers.c (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_fdatasync.c (deleted) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Filesystem: New defaults fsync_h and fdatasync_h New defaults ... Fri, 24 Feb 2012 12:42:06 GMT Sebastian Huber [bea7043c] * cpukit/libcsupport/include/rtems/libio.h (modified) Filesystem: Change node type enum values Move the ... Fri, 24 Feb 2012 08:54:44 GMT Sebastian Huber [a76c2373] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/src/defaults/default_lseek.c (modified) Filesystem: Change error indication Change error indication to ... Fri, 24 Feb 2012 08:53:22 GMT Sebastian Huber [adef4e4] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_lseek_success.c (added) Filesystem: New function New function ... Fri, 02 Mar 2012 09:18:10 GMT Sebastian Huber [3ba4f828] * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fchown.c (modified) * cpukit/libcsupport/src/sup_fs_eval_path.c (modified) * testsuites/fstests/fsrofs01/Makefile.am (added) * testsuites/fstests/fsrofs01/fsrofs01.doc (added) * testsuites/fstests/fsrofs01/fsrofs01.scn (added) * testsuites/fstests/fsrofs01/init.c (added) * testsuites/psxtests/psxfchx01/init.c (modified) * testsuites/psxtests/psxmount/test.c (modified) Filesystem: Read-only file system checks o Make sure EROFS is ... Tue, 13 Mar 2012 10:33:51 GMT Sebastian Huber [3b7c123] * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) * cpukit/include/rtems/fs.h (modified) * cpukit/include/rtems/userenv.h (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/_rename_r.c (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chmod.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/chroot.c (modified) * cpukit/libcsupport/src/clonenode.c (added) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/eval.c (deleted) * cpukit/libcsupport/src/fchdir.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fchown.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/freenode.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/lchown.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/lstat.c (modified) * cpukit/libcsupport/src/mknod.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/statvfs.c (modified) * cpukit/libcsupport/src/sup_fs_check_permissions.c (added) * cpukit/libcsupport/src/sup_fs_eval_path.c (added) * cpukit/libcsupport/src/sup_fs_eval_path_generic.c (added) * cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c (added) * cpukit/libcsupport/src/sup_fs_get_start_loc.c (deleted) * cpukit/libcsupport/src/sup_fs_get_sym_start_loc.c (deleted) * cpukit/libcsupport/src/sup_fs_is_separator.c (deleted) * cpukit/libcsupport/src/sup_fs_location.c (added) * cpukit/libcsupport/src/sup_fs_mount_iterate.c (added) * cpukit/libcsupport/src/sup_fs_next_token.c (added) * cpukit/libcsupport/src/sup_fs_node_type.c (added) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libcsupport/src/umask.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/defaults/default_are_nodes_equal.c (added) * cpukit/libfs/src/defaults/default_chown.c (modified) * cpukit/libfs/src/defaults/default_clone.c (added) * cpukit/libfs/src/defaults/default_eval_path.c (added) * cpukit/libfs/src/defaults/default_evalformake.c (deleted) * cpukit/libfs/src/defaults/default_evalpath.c (deleted) * cpukit/libfs/src/defaults/default_evaluate_link.c (deleted) * cpukit/libfs/src/defaults/default_fchmod.c (modified) * cpukit/libfs/src/defaults/default_fcntl.c (modified) * cpukit/libfs/src/defaults/default_freenode.c (modified) * cpukit/libfs/src/defaults/default_fstat.c (modified) * cpukit/libfs/src/defaults/default_fsunmount.c (modified) * cpukit/libfs/src/defaults/default_ftruncate.c (modified) * cpukit/libfs/src/defaults/default_ftruncate_directory.c (added) * cpukit/libfs/src/defaults/default_handlers.c (modified) * cpukit/libfs/src/defaults/default_link.c (modified) * cpukit/libfs/src/defaults/default_lock_and_unlock.c (added) * cpukit/libfs/src/defaults/default_mknod.c (modified) * cpukit/libfs/src/defaults/default_node_type.c (modified) * cpukit/libfs/src/defaults/default_open.c (modified) * cpukit/libfs/src/defaults/default_ops.c (modified) * cpukit/libfs/src/defaults/default_readlink.c (modified) * cpukit/libfs/src/defaults/default_rename.c (modified) * cpukit/libfs/src/defaults/default_rmnod.c (modified) * cpukit/libfs/src/defaults/default_statvfs.c (modified) * cpukit/libfs/src/defaults/default_symlink.c (modified) * cpukit/libfs/src/defaults/default_unlink.c (deleted) * cpukit/libfs/src/defaults/default_utime.c (modified) * cpukit/libfs/src/devfs/devclose.c (modified) * cpukit/libfs/src/devfs/devfs.h (modified) * cpukit/libfs/src/devfs/devfs_eval.c (modified) * cpukit/libfs/src/devfs/devfs_init.c (modified) * cpukit/libfs/src/devfs/devfs_mknod.c (modified) * cpukit/libfs/src/devfs/devfs_node_type.c (modified) * cpukit/libfs/src/devfs/devfs_show.c (modified) * cpukit/libfs/src/devfs/devioctl.c (modified) * cpukit/libfs/src/devfs/devopen.c (modified) * cpukit/libfs/src/devfs/devread.c (modified) * cpukit/libfs/src/devfs/devstat.c (modified) * cpukit/libfs/src/devfs/devwrite.c (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_eval.c (modified) * cpukit/libfs/src/dosfs/msdos_file.c (modified) * cpukit/libfs/src/dosfs/msdos_free.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_handlers_file.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * cpukit/libfs/src/dosfs/msdos_mknod.c (modified) * cpukit/libfs/src/dosfs/msdos_node_type.c (modified) * cpukit/libfs/src/dosfs/msdos_rename.c (modified) * cpukit/libfs/src/dosfs/msdos_rmnod.c (added) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/fifoimfs_init.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fifo.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_getchild.c (deleted) * cpukit/libfs/src/imfs/imfs_gtkn.c (deleted) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_load_tar.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (modified) * cpukit/libfs/src/imfs/imfs_rename.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unlink.c (deleted) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libfs/src/nfsclient/src/librtemsNfs.h (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-dir.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-link.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-shell.c (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_lsof.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/posix/src/sysconf.c (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fserror/test.c (modified) * testsuites/fstests/fsnofs01/Makefile.am (added) * testsuites/fstests/fsnofs01/fsnofs01.doc (added) * testsuites/fstests/fsnofs01/fsnofs01.scn (added) * testsuites/fstests/fsnofs01/init.c (added) * testsuites/fstests/mrfs_support/fs_support.c (modified) * testsuites/fstests/support/fstest_support.c (modified) * testsuites/libtests/devfs01/init.c (modified) * testsuites/libtests/devfs02/init.c (modified) * testsuites/libtests/devfs03/init.c (modified) * testsuites/psxtests/psxchroot01/test.c (modified) * testsuites/psxtests/psxfchx01/init.c (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psximfs02/init.c (modified) * testsuites/psxtests/psxmount/test.c (modified) * testsuites/psxtests/psxreaddir/test.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/sptests/spprivenv01/init.c (modified) Filesystem: Reference counting for locations o A new data ... Fri, 09 Mar 2012 16:28:39 GMT Joel Sherrill [0bda8b4] * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) Add missing BSD sections. Fri, 09 Mar 2012 14:47:32 GMT Sebastian Huber [c5a6e617] * c/src/lib/libbsp/powerpc/gen5200/start/start.S (modified) bsp/gen5200: Fix FPU initialization The change of the MSR[FP] ... Fri, 09 Mar 2012 14:46:07 GMT Sebastian Huber [3bd4656] * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) bsp/gen5200: Reflect clocks of new BRS5L hardware Tue, 06 Mar 2012 14:36:49 GMT Joel Sherrill [314d327] * c/src/lib/libbsp/lm32/shared/milkymist_framebuffer/framebuffer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/comloc.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/milkymist_usbinput.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/softusb-input.h (deleted) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/usbinput.c (modified) * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/resolv.h (modified) * cpukit/score/inline/rtems/score/rbtree.inl (modified) * cpukit/score/src/rbtreeextract.c (modified) * testsuites/ChangeLog (modified) * testsuites/psxtmtests/ChangeLog (modified) * testsuites/psxtmtests/psxtmmq01/init.c (modified) * testsuites/psxtmtests/psxtmmutex01/init.c (modified) * testsuites/psxtmtests/psxtmsem02/init.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) * testsuites/support/src/spin.c (modified) Merge branch 'master' of ssh://git.rtems.org/data/git/rtems Tue, 06 Mar 2012 14:25:39 GMT Werner Almesberger [47a45e5c] * c/src/lib/libbsp/lm32/milkymist/include/system_conf.h (modified) Milkymist - Increase SOFTUSB_PMEM_SIZE to 8 KB We increased PMEM to ... Sun, 04 Mar 2012 16:42:08 GMT Gedare Bloom [41d33b9] * cpukit/score/inline/rtems/score/rbtree.inl (modified) * cpukit/score/src/rbtreeextract.c (modified) score: Add _RBTree_Opposite_direction. Add a red-black tree helper ... Sun, 04 Mar 2012 13:48:10 GMT Gedare Bloom [a52be5ec] * testsuites/sptests/sprbtree01/init.c (modified) PR2034: sprbtree01: predecessor/successor imprecision The tests for ... Sat, 03 Mar 2012 21:02:33 GMT Sebastien Bourdeauducq [dc1a3b9] * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/milkymist_usbinput.h (modified) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/softusb-input.h (deleted) * c/src/lib/libbsp/lm32/shared/milkymist_usbinput/usbinput.c (modified) PR 2032: Milkymist USB: Ioctl interface for loading USB firmware ... Sat, 03 Mar 2012 20:50:53 GMT Xiangfu Liu [f0d2261] * c/src/lib/libbsp/lm32/shared/milkymist_framebuffer/framebuffer.c (modified) PR2029: Milkymist VGA: adjust video timings Slightly adjust video ... Fri, 02 Mar 2012 17:16:33 GMT Ralf Corsépius [ac165341] * testsuites/ChangeLog (modified) * testsuites/support/src/spin.c (modified) 2011-03-02 Ralf Corsépius * ...
