# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 17:15:17 Fri, 09 Aug 2019 05:45:06 GMT Sebastian Huber [da1b471] * cpukit/dev/serial/sc16is752.c (modified) dev/sc16is752: Write to right register Sat, 17 Aug 2019 16:58:53 GMT Sebastian Huber [4a9a58e] * cpukit/include/rtems/recordclient.h (modified) record: Add rtems_record_client_set_handler() Sat, 17 Aug 2019 12:49:42 GMT Sebastian Huber [c91f6f5] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) * testsuites/libtests/record02/init.c (modified) record: Pass bintime to client handlers This is a minor optimization. Sat, 17 Aug 2019 12:34:59 GMT Sebastian Huber [1733102] * cpukit/libtrace/record/record-client.c (modified) record: Simplify client visit() Sat, 17 Aug 2019 12:28:41 GMT Sebastian Huber [5c37f03f] * cpukit/libtrace/record/record-client.c (modified) record: Remove superfluous cast Sat, 17 Aug 2019 11:25:57 GMT Sebastian Huber [2ef2c14] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) record: Increase client robustness Do nothing after errors. Fri, 16 Aug 2019 16:40:55 GMT Sebastian Huber [52c8ac7b] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) * testsuites/libtests/record02/init.c (modified) * testsuites/libtests/record02/record02.scn (modified) record: Improve overflow handling In case of a ring buffer ... Fri, 16 Aug 2019 05:40:05 GMT Sebastian Huber [b2c060a5] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) record: Detect also large overflows Fri, 16 Aug 2019 18:12:03 GMT Sebastian Huber [d3c4d48] * cpukit/include/rtems/recordclient.h (modified) * cpukit/libtrace/record/record-client.c (modified) record: Simplify rtems_record_client_context Mon, 12 Aug 2019 03:58:31 GMT Chris Johns [15b6f44d] * bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c (modified) arm/tlb: Fix the MP affinity check to invalidate ASIDs. - The TI's ... Sun, 11 Aug 2019 22:56:37 GMT Chris Johns [df256505] * cpukit/libdebugger/rtems-debugger-arm.c (modified) libdebugger/arm: Support ROM tables. - Parse the ROM taables if ... Tue, 06 Aug 2019 10:00:56 GMT Chris Johns [a4d7e4ce] * bsps/arm/raspberrypi/start/bspgetworkarea.c (modified) * bsps/arm/raspberrypi/start/bspstart.c (modified) * bsps/arm/raspberrypi/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) arm/raspberry: Set the workspace based on the mailbox version. - ... Sun, 04 Aug 2019 23:58:07 GMT Chris Johns [9cb19ded] * bsps/arm/raspberrypi/start/linkcmds.in (moved) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) libdl/debugger: Fix the broken list delete when unloading an object ... Fri, 02 Aug 2019 20:57:01 GMT Vijay Kumar Banerjee [886956a] * bsps/arm/beagle/start/bspstart.c (modified) * bsps/arm/beagle/start/linkcmds.beagle (modified) bsp/beagle: Add nocache section Closes #3780 Tue, 06 Aug 2019 05:47:57 GMT Sebastian Huber [cc91fae] * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-userext.c (modified) * testsuites/libtests/record01/init.c (modified) record: Change thread name encoding This scheme is easier to decode. Tue, 30 Jul 2019 10:43:15 GMT Chris Johns [8c66acc8] * cpukit/libdl/rtl-mdreloc-arm.c (modified) libdl/arm: Add support for ARM trampolines Closes #3776 Tue, 30 Jul 2019 19:14:16 GMT Christian Mauderer [163927e5] * bsps/arm/beagle/gpio/bbb-gpio.c (modified) bsps/beagle: Remove dead code from GPIO. Remove static stuff that ... Tue, 25 Jun 2019 11:16:27 GMT Chris Johns [7d4f74e] * bsps/arm/beagle/start/bspdebug.c (added) * bsps/arm/beagle/start/bspdebug.h (added) * bsps/arm/beagle/start/bspstart.c (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) arm/beagle: Add libdebugger support. - Port the jbang code from C++ ... Tue, 25 Jun 2019 11:07:40 GMT Chris Johns [cb1e8497] * cpukit/Makefile.am (modified) * cpukit/include/rtems/debugger/rtems-debugger-bsp.h (added) * cpukit/libdebugger/rtems-debugger-arm.c (modified) * cpukit/libdebugger/rtems-debugger-bsp.c (added) * cpukit/libdebugger/rtems-debugger-server.c (modified) * cpukit/libdebugger/rtems-debugger-threads.c (modified) libdebugger: ARM fixes for Cortex-A8 and ARM mode. - Fix destorying ... Tue, 25 Jun 2019 10:48:51 GMT Chris Johns [98d6792] * bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c (modified) arm: Select the TLB invalidate based on the core's Id variant. ... Tue, 23 Jul 2019 13:41:54 GMT Vaibhav Gupta [57e01735] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxndbm01/init.c (added) * testsuites/psxtests/psxndbm01/psxndbm01.doc (added) * testsuites/psxtests/psxndbm01/psxndbm01.scn (added) psxtests: Add ndbm test suite Joel Sherrill ... Mon, 29 Jul 2019 05:22:03 GMT Sebastian Huber [c5fd79cd] * bsps/arm/raspberrypi/start/bspstarthooks.c (modified) * bsps/arm/raspberrypi/start/linkcmds (modified) arm/raspberrypi: Fix linker map Add NULL-pointer protection. Make ... Fri, 26 Jul 2019 14:36:10 GMT Sebastian Huber [036717ed] * cpukit/include/rtems/recorddata.h (modified) * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-text.c (modified) * cpukit/libtrace/record/record-userext.c (modified) * testsuites/libtests/record01/init.c (modified) record: Add support for thread names Tue, 30 Jul 2019 04:24:00 GMT Sebastian Huber [5ee70c5] * bsps/shared/start/bspfatal-default.c (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/libmisc/stackchk/check.c (modified) Add and use THREAD_DEFAULT_MAXIMUM_NAME_SIZE Sat, 27 Jul 2019 23:12:53 GMT Chris Johns [5a678de] * cpukit/libdl/rtl-mdreloc-arm.c (modified) * testsuites/libtests/dl01/dl-load.c (modified) libdl/arm: Fix ARM mode trampoline parsing of relocs - No need to ... Fri, 26 Jul 2019 06:12:20 GMT Sebastian Huber [1e6380b] * bsps/arm/shared/start/bsp-start-in-hyp-support.S (deleted) * bsps/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) bsps/arm: Move HYP to SVC change to start.S This fixes the ... Fri, 26 Jul 2019 05:59:27 GMT Sebastian Huber [0ee2125] * bsps/arm/shared/start/bsp-start-init-registers.S (deleted) * bsps/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) bsps/arm: Move register init to start.S This makes it easier to ... Fri, 26 Jul 2019 05:54:05 GMT Sebastian Huber [0f5c1d53] * bsps/arm/shared/start/start.S (modified) bsps/arm: Remove register init for ARMv7-M There are no known ... Mon, 22 Jul 2019 17:52:46 GMT Joel Sherrill [6eae5860] * testsuites/samples/ticker/init.c (modified) ticker/init.c: Error should say clock set not get Wed, 17 Jul 2019 12:19:04 GMT Chris Johns [270c5df5] * c/src/make/Makefile.am (modified) * c/src/make/Makefile.inc.in (modified) * make/custom/default.cfg (modified) * make/main.cfg (modified) Makefile.inc: Add support for staged builds. - Allow the RTEMS_ROOT ... Wed, 03 Jul 2019 02:18:18 GMT Chris Johns [c4d89de] * cpukit/include/rtems/score/interr.h (modified) score/interr: Fix comments. Fri, 05 Jul 2019 07:03:58 GMT Sebastian Huber [e9c83b4] * bsps/bfin/TLL6527M/headers.am (modified) * bsps/bfin/bf537Stamp/headers.am (modified) * bsps/bfin/eZKit533/headers.am (modified) * bsps/headers.am (modified) * bsps/lm32/lm32_evr/headers.am (modified) * bsps/lm32/milkymist/headers.am (modified) * bsps/m68k/av5282/headers.am (modified) * bsps/m68k/csb360/headers.am (modified) * bsps/m68k/gen68340/headers.am (modified) * bsps/m68k/gen68360/headers.am (modified) * bsps/m68k/mcf5206elite/headers.am (modified) * bsps/m68k/mcf52235/headers.am (modified) * bsps/m68k/mcf5225x/headers.am (modified) * bsps/m68k/mcf5235/headers.am (modified) * bsps/m68k/mcf5329/headers.am (modified) * bsps/m68k/mrm332/headers.am (modified) * bsps/m68k/mvme147/headers.am (modified) * bsps/m68k/mvme147s/headers.am (modified) * bsps/m68k/mvme162/headers.am (modified) * bsps/m68k/mvme167/headers.am (modified) * bsps/m68k/uC5282/headers.am (modified) * bsps/moxie/moxiesim/headers.am (modified) * bsps/nios2/nios2_iss/headers.am (modified) * bsps/no_cpu/no_bsp/headers.am (modified) * bsps/sh/gensh1/headers.am (modified) * bsps/sh/gensh2/headers.am (modified) * bsps/sh/gensh4/headers.am (modified) * bsps/sh/shsim/headers.am (modified) * bsps/sparc64/headers.am (modified) * bsps/sparc64/niagara/headers.am (modified) * bsps/sparc64/usiii/headers.am (modified) * bsps/v850/gdbv850sim/headers.am (modified) bsps: Regenerate headers.am Update #3269. Tue, 02 Jul 2019 08:44:18 GMT Chris Johns [5cbee18] * cpukit/libmisc/dummy/default-configuration.c (modified) misc/rtemsdefaultconfig: Add bdbuf so libbsd can be used with configure. Mon, 24 Jun 2019 20:16:59 GMT Christian Mauderer [b89d6cc] * bsps/arm/beagle/i2c/bbb-i2c.c (modified) * bsps/arm/beagle/include/bsp/i2c.h (modified) * bsps/arm/include/libcpu/am335x.h (modified) bsp/beagle: Partial re-write of I2C driver. The old driver worked ... Fri, 28 Jun 2019 06:30:11 GMT Sebastian Huber [5803f37] * cpukit/include/rtems/capture.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) * cpukit/include/rtems/score/schedulernodeimpl.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/libdebugger/rtems-debugger-threads.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) score: Add and use _Thread_Get_unmapped_priority(). Add and use ... Tue, 25 Jun 2019 08:43:55 GMT Chris Johns [c43071f] * bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) arm: Return the current handler from arm_cp15_set_exception_handler ... Thu, 27 Jun 2019 12:34:23 GMT Sebastian Huber [9b858ee] * bsps/powerpc/motorola_powerpc/bootloader/ppcboot.lds (modified) bsp/motorola_powerpc: Fix linker command file Fix the __size symbol ... Wed, 26 Jun 2019 05:57:50 GMT Sebastian Huber [54ac945] * cpukit/libdebugger/rtems-debugger-threads.c (modified) libdebugger: Unmap thread priorities Fri, 21 Jun 2019 04:58:19 GMT Sebastian Huber [dc581f2] * bsps/arm/atsam/contrib/libraries/libboard/source/board_memories.c (modified) * bsps/arm/atsam/include/bsp/atsam-clock-config.h (modified) * bsps/arm/atsam/start/sdram-config.c (modified) bsp/atsam: Enable configuration of SDRAMC_LPR Thu, 13 Jun 2019 19:29:24 GMT Vaibhav Gupta [d9fcb22] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxinttypes01/init.c (added) * testsuites/psxtests/psxinttypes01/psxinttypes01.doc (added) * testsuites/psxtests/psxinttypes01/psxinttypes01.scn (added) psxtests: Add psxinttypes01 for methods Wed, 22 May 2019 14:29:33 GMT Joel Sherrill [373cd1c5] * cpukit/include/rtems/confdefs.h (modified) rtems/confdefs.h: Fix typo Tue, 18 Jun 2019 10:52:53 GMT Sebastian Huber [a67b9b06] * bsps/arm/atsam/include/bsp/power.h (modified) * bsps/arm/atsam/start/power-wait.c (added) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) atsam: Add ATSAM_POWER_WAIT_MODE Tue, 18 Jun 2019 09:31:48 GMT Sebastian Huber [522cde4] * bsps/arm/atsam/start/power-rtc.c (modified) atsam: Enable fast startup via RTC alarm Tue, 18 Jun 2019 09:10:55 GMT Sebastian Huber [bb24892] * bsps/arm/atsam/start/power.c (modified) bsp/atsam: Use proper API Fri, 14 Jun 2019 05:41:36 GMT Sebastian Huber [2be6ab7f] * cpukit/dev/serial/sc16is752.c (modified) * cpukit/include/dev/serial/sc16is752.h (modified) dev/sc16is752: Add set/get EFCR IO controls Fri, 14 Jun 2019 05:35:21 GMT Sebastian Huber [6ff1da40] * cpukit/dev/serial/sc16is752-regs.h (modified) * cpukit/dev/serial/sc16is752.c (modified) * cpukit/include/dev/serial/sc16is752.h (modified) dev/sc16is752: Add RS485 mode variants Thu, 13 Jun 2019 06:44:04 GMT Sebastian Huber [d7d0bba] * bsps/arm/atsam/net/if_atsam.c (modified) * bsps/arm/atsam/start/bspstarthooks.c (modified) bsp/atsam: Do not disable the WDT The watchdog timer (WDT) can be ... Wed, 12 Jun 2019 10:53:22 GMT Sebastian Huber [ee36616] * bsps/arm/atsam/include/bsp/power.h (modified) * bsps/arm/atsam/start/power-rtc.c (modified) bsp/atsam: Improve RTC power driver Accept a time interval up to 24h. Wed, 12 Jun 2019 10:51:20 GMT Sebastian Huber [5d4a81f5] * bsps/arm/atsam/contrib/libraries/libchip/source/rtc.c (modified) bsp/atsam: Fix RTC_SetTimeAlarm() Set the alarm time according to ... Wed, 12 Jun 2019 05:22:38 GMT zhengxiaojun [38b29232] * cpukit/libdl/rtl-rap.c (modified) libdl/rap: fix RAP file load error. Thu, 06 Jun 2019 12:57:54 GMT Maksim E. Kozlov [2a720f4] * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc: Fix mistakenly cleared PSR[EF] bit. The superfluously ... Wed, 05 Jun 2019 19:22:36 GMT Maksim E. Kozlov [a3818705] * cpukit/score/cpu/sparc/syscall.S (modified) sparc: Fix missed restoring of PSR in syscall_lazy_fp_switch It is ... Thu, 06 Jun 2019 05:53:09 GMT Sebastian Huber [7d7cbf3c] * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) sparc: Improve _CPU_Context_validate() Use the FPU and check that ... Tue, 04 Jun 2019 10:04:55 GMT Sebastian Huber [98fc6014] * bsps/arm/lpc24xx/include/bsp/io.h (modified) bsp/lpc24xx: Fix LPC24XX_IO_PORT_COUNT Mon, 27 May 2019 08:14:48 GMT Sebastian Huber [f419349] * bsps/powerpc/motorola_powerpc/bootloader/ppcboot.lds (modified) bsps/powerpc: Adjust ppcboot.lds The GNU ld had a couple of changes ... Mon, 27 May 2019 05:35:07 GMT Sebastian Huber [20bd667] * bsps/shared/grlib/net/greth.c (modified) * bsps/shared/net/greth2.c (modified) bsps: Fix warnings in greth Wed, 22 May 2019 05:51:14 GMT Sebastian Huber [10251b3] * cpukit/include/rtems/score/objectdata.h (modified) score: Compact objects class indices Tue, 14 May 2019 00:34:32 GMT Chris Johns [327e45da] * cpukit/include/rtems/rtl/rtl-sym.h (modified) * cpukit/libdl/rtl-obj.c (modified) * cpukit/libdl/rtl-sym.c (modified) libdl: Sort object file symbols and use a binary search to find - ... Mon, 20 May 2019 07:15:36 GMT Sebastian Huber [5fa893e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpunicastaction.c (added) * testsuites/smptests/smpmulticast01/init.c (modified) * testsuites/smptests/smpmulticast01/smpmulticast01.scn (modified) score: Add _SMP_Unicast_action() Mon, 20 May 2019 07:06:48 GMT Sebastian Huber [41cddcc] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Add _Per_CPU_Wait_for_job() Thu, 02 May 2019 03:29:27 GMT Sebastian Huber [9b8e85e2] * cpukit/include/rtems/score/smpimpl.h (modified) score: Remove superfluous include Sun, 28 Apr 2019 12:31:10 GMT Sebastian Huber [577293f0] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpipi01/init.c (modified) score: Add _SMP_Synchronize() Sun, 28 Apr 2019 12:15:45 GMT Sebastian Huber [bf867c55] * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) score: Remove unused SMP_MESSAGE_TEST All uses were replaced by ... Sat, 27 Apr 2019 10:39:25 GMT Sebastian Huber [fe24820e] * testsuites/smptests/smpipi01/init.c (modified) smpipi01: Use per-CPU jobs for IPI flood test Sun, 28 Apr 2019 12:43:19 GMT Sebastian Huber [21e691b] * testsuites/smptests/smpipi01/init.c (modified) smpipi01: Ensure IPI works on all processors Fri, 19 Apr 2019 12:34:50 GMT Sebastian Huber [7cb881f] * testsuites/smptests/smpipi01/init.c (modified) smpipi01: Use per-CPU jobs for pending IPI test Fri, 19 Apr 2019 09:02:02 GMT Sebastian Huber [c63e8bb] * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Modify _Per_CPU_Perform_jobs() Process only the jobs ... Fri, 19 Apr 2019 09:01:31 GMT Sebastian Huber [85d6e845] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Add _Per_CPU_Add_job() Thu, 18 Apr 2019 06:38:00 GMT Sebastian Huber [8fa14da0] * cpukit/include/rtems/score/percpu.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Move per-processor job data structures This enables re-use ... Thu, 18 Apr 2019 05:38:13 GMT Sebastian Huber [1a971d8] * bsps/i386/pc386/clock/ckinit.c (modified) * bsps/i386/pc386/start/smp-imps.c (modified) * cpukit/include/rtems/score/smpimpl.h (modified) score: Remove SMP_MESSAGE_CLOCK_TICK Use _SMP_Multicast_action() ... Thu, 18 Apr 2019 05:08:32 GMT Sebastian Huber [3b2481f] * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Simplify _SMP_Multicast_action() Move resposibility to ... Sun, 28 Apr 2019 12:29:21 GMT Sebastian Huber [7fdf48a] * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Add _SMP_Othercast_action() Thu, 18 Apr 2019 04:47:01 GMT Sebastian Huber [65870044] * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Add _SMP_Broadcast_action() Wed, 17 Apr 2019 09:05:26 GMT Sebastian Huber [9f52acb5] * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) smptests: Move SMP broadcast action test case Sat, 20 Apr 2019 08:09:43 GMT Sebastian Huber [317997f] * testsuites/smptests/smpmulticast01/init.c (modified) smpmulticast01: Use T_TEST_CASE() Thu, 18 Apr 2019 04:31:33 GMT Sebastian Huber [4f06863] * cpukit/score/src/smpmulticastaction.c (modified) score: Use dedicated lock for per-CPU jobs Fri, 17 May 2019 07:21:03 GMT Sebastian Huber [b4f895e] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/rtems/src/rtemsobjectgetapiclassname.c (modified) posix: Remove unused OBJECTS_POSIX_INTERRUPTS Sat, 11 May 2019 12:57:39 GMT Sebastian Huber [45d0659] * bsps/bfin/TLL6527M/include/bsp/irq.h (added) * bsps/bfin/bf537Stamp/include/bsp/irq.h (added) * bsps/bfin/eZKit533/include/bsp/irq.h (added) * bsps/include/bsp/irq-default.h (added) * bsps/lm32/lm32_evr/include/bsp/irq.h (added) * bsps/lm32/milkymist/include/bsp/irq.h (added) * bsps/m68k/av5282/include/bsp/irq.h (added) * bsps/m68k/csb360/include/bsp/irq.h (added) * bsps/m68k/gen68340/include/bsp/irq.h (added) * bsps/m68k/gen68360/include/bsp/irq.h (added) * bsps/m68k/mcf5206elite/include/bsp/irq.h (added) * bsps/m68k/mcf52235/include/bsp/irq.h (added) * bsps/m68k/mcf5225x/include/bsp/irq.h (added) * bsps/m68k/mcf5235/include/bsp/irq.h (added) * bsps/m68k/mcf5329/include/bsp/irq.h (added) * bsps/m68k/mrm332/include/bsp/irq.h (added) * bsps/m68k/mvme147/include/bsp/irq.h (added) * bsps/m68k/mvme147s/include/bsp/irq.h (added) * bsps/m68k/mvme162/include/bsp/irq.h (added) * bsps/m68k/mvme167/include/bsp/irq.h (added) * bsps/m68k/uC5282/include/bsp/irq.h (added) * bsps/moxie/moxiesim/include/bsp/irq.h (added) * bsps/nios2/nios2_iss/include/bsp/irq.h (added) * bsps/no_cpu/no_bsp/include/bsp/irq.h (added) * bsps/powerpc/beatnik/include/bsp/irq.h (modified) * bsps/powerpc/haleakala/include/bsp/irq.h (modified) * bsps/powerpc/motorola_powerpc/include/bsp/irq.h (modified) * bsps/powerpc/mvme3100/include/bsp/irq.h (modified) * bsps/powerpc/mvme5500/include/bsp/irq.h (modified) * bsps/powerpc/ss555/include/bsp/irq.h (modified) * bsps/powerpc/virtex4/include/bsp/irq.h (modified) * bsps/powerpc/virtex5/include/bsp/irq.h (modified) * bsps/sh/gensh1/include/bsp/irq.h (added) * bsps/sh/gensh2/include/bsp/irq.h (added) * bsps/sh/gensh4/include/bsp/irq.h (added) * bsps/sh/shsim/include/bsp/irq.h (added) * bsps/shared/irq-default-sources.am (added) * bsps/shared/irq/irq-default.c (added) * bsps/sparc64/niagara/include/bsp/irq.h (added) * bsps/sparc64/usiii/include/bsp/irq.h (added) * bsps/v850/gdbv850sim/include/bsp/irq.h (added) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Always build generic interrupt support This makes it possible ... Thu, 18 Apr 2019 04:29:57 GMT Sebastian Huber [327ae9ac] * cpukit/score/src/smpmulticastaction.c (modified) score: Fix per-CPU job done handling Fri, 10 May 2019 12:38:28 GMT Sebastian Huber [cc060f0] * cpukit/libmisc/shell/shell.c (modified) shell: Avoid rtems_error() Do not use the rtems_error() function ... Tue, 14 May 2019 07:04:05 GMT Sebastian Huber [b446457] * bsps/arm/lm3s69xx/config/lm3s69xx.inc (modified) * bsps/arm/lpc176x/config/lpc1768_mbed.cfg (modified) * bsps/arm/lpc24xx/config/lpc17xx.inc (modified) * bsps/arm/lpc24xx/config/lpc40xx.inc (modified) * bsps/arm/stm32f4/config/stm32f105rc.cfg (modified) * bsps/arm/stm32f4/config/stm32f4.cfg (modified) bsps/arm: Adjust machine flags for ARMv7-M Update machine flags for ... Tue, 14 May 2019 00:15:51 GMT Chris Johns [d0f627d] * cpukit/libdl/rtl-elf.c (modified) libdl: Fix size bug in loading symbols. This was introduced in ... Mon, 13 May 2019 00:46:45 GMT Chris Johns [74883be5] * cpukit/libdl/rtl-elf.c (modified) libdl: Fix loading symbol that reference unknown sections. - Make ... Mon, 13 May 2019 22:39:55 GMT Chris Johns [0b698ba5] * cpukit/include/rtems/score/rbtree.h (modified) doxygen: score: Fix block comment end marker. Thu, 18 Apr 2019 08:19:23 GMT Andreas Dachsberger [f49618d] * cpukit/include/rtems/score/percpudata.h (modified) doxygen: score: adjust doc in percpudata.h to doxygen guidelines ... Thu, 18 Apr 2019 08:13:25 GMT Andreas Dachsberger [3238c162] * cpukit/include/rtems/score/smp.h (modified) doxygen: score: adjust doc in smp.h to doxygen guidelines Update #3706. Thu, 18 Apr 2019 07:54:49 GMT Andreas Dachsberger [1bd608b] * cpukit/include/rtems/score/onceimpl.h (modified) doxygen: score: adjust doc in onceimpl.h to doxygen guidelines ... Thu, 18 Apr 2019 07:43:41 GMT Andreas Dachsberger [2463c10] * cpukit/include/rtems/score/muteximpl.h (modified) doxygen: score: adjust doc in muteximpl.h to doxygen guidelines ... Thu, 18 Apr 2019 07:38:47 GMT Andreas Dachsberger [7b90bb5] * cpukit/include/rtems/score/wkspace.h (modified) doxygen: score: adjust doc in wkspace.h to doxygen guidelines ... Thu, 18 Apr 2019 07:31:27 GMT Andreas Dachsberger [904c2312] * cpukit/include/rtems/score/watchdogticks.h (modified) doxygen: score: adjust doc in watchdogticks.h to doxygen guidelines ... Thu, 18 Apr 2019 07:30:32 GMT Andreas Dachsberger [c53ec8c4] * cpukit/include/rtems/score/watchdogimpl.h (modified) doxygen: score: adjust doc in watchdogimpl.h to doxygen guidelines ... Thu, 18 Apr 2019 06:58:48 GMT Andreas Dachsberger [eb84cc3f] * cpukit/include/rtems/score/watchdog.h (modified) doxygen: score: adjust doc in watchdog.h to doxygen guidelines ... Thu, 18 Apr 2019 06:57:32 GMT Andreas Dachsberger [7d2cc98] * cpukit/include/rtems/score/userextimpl.h (modified) doxygen: score: adjust doc in userextimpl.h to doxygen guidelines ... Thu, 18 Apr 2019 06:37:02 GMT Andreas Dachsberger [5791a3c] * cpukit/include/rtems/score/todimpl.h (modified) doxygen: score: adjust doc in todimpl.h to doxygen guidelines ... Thu, 18 Apr 2019 06:28:21 GMT Andreas Dachsberger [5c91b54b] * cpukit/include/rtems/score/tls.h (modified) doxygen: score: adjust doc in tls.h to doxygen guidelines Update #3706. Thu, 18 Apr 2019 06:12:07 GMT Andreas Dachsberger [4a693e7] * cpukit/include/rtems/score/timestampimpl.h (modified) doxygen: score: adjust doc in timestampimpl.h to doxygen guidelines ... Wed, 17 Apr 2019 15:51:55 GMT Andreas Dachsberger [1b5ba76] * cpukit/include/rtems/score/timestamp.h (modified) doxygen: score: adjust doc in timestamp.h to doxygen guidelines ... Wed, 17 Apr 2019 15:50:38 GMT Andreas Dachsberger [bded63fc] * cpukit/include/rtems/score/timespec.h (modified) doxygen: score: adjust doc in timespec.h to doxygen guidelines ... Wed, 17 Apr 2019 15:42:41 GMT Andreas Dachsberger [3e98049] * cpukit/include/rtems/score/timecounterimpl.h (modified) doxygen: score: adjust doc in timecounterimpl.h to doxygen guidelines ... Wed, 17 Apr 2019 15:40:14 GMT Andreas Dachsberger [843879d0] * cpukit/include/rtems/score/timecounter.h (modified) doxygen: score: adjust doc in timecounter.h to doxygen guidelines ...
