# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 20:27:21 Fri, 09 Dec 2011 13:04:48 GMT Ralf Corsepius [da13f46] * cpukit/ChangeLog (modified) * cpukit/libblock/src/flashdisk.c (modified) * cpukit/libblock/src/nvdisk.c (modified) 2011-12-09 Ralf Corsépius * ... Fri, 09 Dec 2011 11:37:45 GMT Ralf Corsepius [102e936] * cpukit/ChangeLog (modified) * cpukit/rtems/src/rtemsobjectsetname.c (modified) 2011-12-09 Ralf Corsépius * ... Fri, 09 Dec 2011 07:36:41 GMT Ralf Corsepius [1059b760] * cpukit/ChangeLog (modified) * cpukit/rtems/src/rtemsobjectgetclassicname.c (modified) 2011-12-09 Ralf Corsépius * ... Fri, 09 Dec 2011 07:21:02 GMT Chris Johns [8504f124] * cpukit/ChangeLog (modified) * cpukit/libfs/src/rfs/rtems-rfs-file.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.h (modified) * cpukit/libfs/src/rfs/rtems-rfs-trace.c (modified) 2011-12-09 Chris Johns PR ... Fri, 09 Dec 2011 07:20:28 GMT Ralf Corsepius [ba5df99c] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.c (modified) * c/src/lib/libbsp/i386/pc386/console/vgacons.h (modified) 2011-12-09 Ralf Corsépius * ... Fri, 09 Dec 2011 07:16:48 GMT Ralf Corsepius [884a5813] * c/src/ChangeLog (modified) * c/src/libchip/network/if_fxp.c (modified) 2011-12-09 Ralf Corsépius * ... Fri, 09 Dec 2011 05:57:06 GMT Ralf Corsepius [06d28d6] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/ftp01/Makefile.am (modified) 2011-12-09 Ralf Corsépius * ... Thu, 08 Dec 2011 21:42:36 GMT Joel Sherrill [57bbd5c] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:40:23 GMT Joel Sherrill [5fa9b70] * c/src/make/ChangeLog (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/leaf.cfg (modified) * c/src/make/target.cfg.in (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:39:52 GMT Joel Sherrill [bbf8816] * c/src/ChangeLog (modified) * c/src/optman/.cvsignore (deleted) * c/src/optman/Makefile.am (deleted) * c/src/optman/preinstall.am (deleted) * c/src/optman/rtems/no-barrier.c (deleted) * c/src/optman/rtems/no-dpmem.c (deleted) * c/src/optman/rtems/no-event.c (deleted) * c/src/optman/rtems/no-mp.c (deleted) * c/src/optman/rtems/no-msg.c (deleted) * c/src/optman/rtems/no-part.c (deleted) * c/src/optman/rtems/no-region.c (deleted) * c/src/optman/rtems/no-rtmon.c (deleted) * c/src/optman/rtems/no-sem.c (deleted) * c/src/optman/rtems/no-signal.c (deleted) * c/src/optman/rtems/no-timer.c (deleted) * c/src/optman/sapi/no-ext.c (deleted) * c/src/optman/sapi/no-io.c (deleted) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:39:13 GMT Joel Sherrill [50bb5c5f] * make/ChangeLog (modified) * make/Templates/Makefile.leaf (modified) * make/leaf.cfg (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:38:46 GMT Joel Sherrill [448f657] * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tm30/Makefile.am (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:38:41 GMT Joel Sherrill [d13eb6b] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp10/Makefile.am (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp18/Makefile.am (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp2038/Makefile.am (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp27a/Makefile.am (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp30/Makefile.am (modified) * testsuites/sptests/sp31/Makefile.am (modified) * testsuites/sptests/sp32/Makefile.am (modified) * testsuites/sptests/sp33/Makefile.am (modified) * testsuites/sptests/sp34/Makefile.am (modified) * testsuites/sptests/sp35/Makefile.am (modified) * testsuites/sptests/sp36/Makefile.am (modified) * testsuites/sptests/sp37/Makefile.am (modified) * testsuites/sptests/sp38/Makefile.am (modified) * testsuites/sptests/sp39/Makefile.am (modified) * testsuites/sptests/sp40/Makefile.am (modified) * testsuites/sptests/sp41/Makefile.am (modified) * testsuites/sptests/sp42/Makefile.am (modified) * testsuites/sptests/sp43/Makefile.am (modified) * testsuites/sptests/sp44/Makefile.am (modified) * testsuites/sptests/sp45/Makefile.am (modified) * testsuites/sptests/sp46/Makefile.am (modified) * testsuites/sptests/sp47/Makefile.am (modified) * testsuites/sptests/sp48/Makefile.am (modified) * testsuites/sptests/sp49/Makefile.am (modified) * testsuites/sptests/sp50/Makefile.am (modified) * testsuites/sptests/sp51/Makefile.am (modified) * testsuites/sptests/sp52/Makefile.am (modified) * testsuites/sptests/sp53/Makefile.am (modified) * testsuites/sptests/sp54/Makefile.am (modified) * testsuites/sptests/sp55/Makefile.am (modified) * testsuites/sptests/sp56/Makefile.am (modified) * testsuites/sptests/sp57/Makefile.am (modified) * testsuites/sptests/sp58/Makefile.am (modified) * testsuites/sptests/sp59/Makefile.am (modified) * testsuites/sptests/sp60/Makefile.am (modified) * testsuites/sptests/sp62/Makefile.am (modified) * testsuites/sptests/sp63/Makefile.am (modified) * testsuites/sptests/sp64/Makefile.am (modified) * testsuites/sptests/sp65/Makefile.am (modified) * testsuites/sptests/sp66/Makefile.am (modified) * testsuites/sptests/sp67/Makefile.am (modified) * testsuites/sptests/sp68/Makefile.am (modified) * testsuites/sptests/sp69/Makefile.am (modified) * testsuites/sptests/sp70/Makefile.am (modified) * testsuites/sptests/sp71/Makefile.am (modified) * testsuites/sptests/sp72/Makefile.am (modified) * testsuites/sptests/sp73/Makefile.am (modified) * testsuites/sptests/sp74/Makefile.am (modified) * testsuites/sptests/sp75/Makefile.am (modified) * testsuites/sptests/sp76/Makefile.am (modified) * testsuites/sptests/spassoc01/Makefile.am (modified) * testsuites/sptests/spcbssched01/Makefile.am (modified) * testsuites/sptests/spcbssched02/Makefile.am (modified) * testsuites/sptests/spcbssched03/Makefile.am (modified) * testsuites/sptests/spchain/Makefile.am (modified) * testsuites/sptests/spclockget/Makefile.am (modified) * testsuites/sptests/spcoverage/Makefile.am (modified) * testsuites/sptests/spedfsched01/Makefile.am (modified) * testsuites/sptests/spedfsched02/Makefile.am (modified) * testsuites/sptests/spedfsched03/Makefile.am (modified) * testsuites/sptests/sperror01/Makefile.am (modified) * testsuites/sptests/sperror02/Makefile.am (modified) * testsuites/sptests/sperror03/Makefile.am (modified) * testsuites/sptests/spfatal01/Makefile.am (modified) * testsuites/sptests/spfatal02/Makefile.am (modified) * testsuites/sptests/spfatal03/Makefile.am (modified) * testsuites/sptests/spfatal04/Makefile.am (modified) * testsuites/sptests/spfatal05/Makefile.am (modified) * testsuites/sptests/spfatal06/Makefile.am (modified) * testsuites/sptests/spfatal07/Makefile.am (modified) * testsuites/sptests/spfatal08/Makefile.am (modified) * testsuites/sptests/spfatal09/Makefile.am (modified) * testsuites/sptests/spfatal10/Makefile.am (modified) * testsuites/sptests/spfatal11/Makefile.am (modified) * testsuites/sptests/spfatal12/Makefile.am (modified) * testsuites/sptests/spfatal13/Makefile.am (modified) * testsuites/sptests/spfatal14/Makefile.am (modified) * testsuites/sptests/spfatal15/Makefile.am (modified) * testsuites/sptests/spfatal16/Makefile.am (modified) * testsuites/sptests/spfatal17/Makefile.am (modified) * testsuites/sptests/spfatal18/Makefile.am (modified) * testsuites/sptests/spfatal19/Makefile.am (modified) * testsuites/sptests/spfatal20/Makefile.am (modified) * testsuites/sptests/spfatal21/Makefile.am (modified) * testsuites/sptests/spfatal22/Makefile.am (modified) * testsuites/sptests/spfatal23/Makefile.am (modified) * testsuites/sptests/spfatal24/Makefile.am (modified) * testsuites/sptests/spfatal25/Makefile.am (modified) * testsuites/sptests/spfifo01/Makefile.am (modified) * testsuites/sptests/spfifo02/Makefile.am (modified) * testsuites/sptests/spfifo03/Makefile.am (modified) * testsuites/sptests/spfifo04/Makefile.am (modified) * testsuites/sptests/spfifo05/Makefile.am (modified) * testsuites/sptests/spheapprot/Makefile.am (modified) * testsuites/sptests/spintrcritical01/Makefile.am (modified) * testsuites/sptests/spintrcritical02/Makefile.am (modified) * testsuites/sptests/spintrcritical03/Makefile.am (modified) * testsuites/sptests/spintrcritical04/Makefile.am (modified) * testsuites/sptests/spintrcritical05/Makefile.am (modified) * testsuites/sptests/spintrcritical06/Makefile.am (modified) * testsuites/sptests/spintrcritical07/Makefile.am (modified) * testsuites/sptests/spintrcritical08/Makefile.am (modified) * testsuites/sptests/spintrcritical09/Makefile.am (modified) * testsuites/sptests/spintrcritical10/Makefile.am (modified) * testsuites/sptests/spintrcritical11/Makefile.am (modified) * testsuites/sptests/spintrcritical12/Makefile.am (modified) * testsuites/sptests/spintrcritical13/Makefile.am (modified) * testsuites/sptests/spintrcritical14/Makefile.am (modified) * testsuites/sptests/spintrcritical15/Makefile.am (modified) * testsuites/sptests/spintrcritical16/Makefile.am (modified) * testsuites/sptests/spintrcritical17/Makefile.am (modified) * testsuites/sptests/spmkdir/Makefile.am (modified) * testsuites/sptests/spmountmgr01/Makefile.am (modified) * testsuites/sptests/spnotepad01/Makefile.am (modified) * testsuites/sptests/spnsext01/Makefile.am (modified) * testsuites/sptests/spobjgetnext/Makefile.am (modified) * testsuites/sptests/spprintk/Makefile.am (modified) * testsuites/sptests/spprivenv01/Makefile.am (modified) * testsuites/sptests/sprbtree01/Makefile.am (modified) * testsuites/sptests/spsimplesched01/Makefile.am (modified) * testsuites/sptests/spsimplesched02/Makefile.am (modified) * testsuites/sptests/spsimplesched03/Makefile.am (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spstkalloc/Makefile.am (modified) * testsuites/sptests/spthreadq01/Makefile.am (modified) * testsuites/sptests/spwatchdog/Makefile.am (modified) * testsuites/sptests/spwkspace/Makefile.am (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:38:31 GMT Joel Sherrill [341aaf8] * testsuites/smptests/ChangeLog (modified) * testsuites/smptests/smp01/Makefile.am (modified) * testsuites/smptests/smp02/Makefile.am (modified) * testsuites/smptests/smp03/Makefile.am (modified) * testsuites/smptests/smp04/Makefile.am (modified) * testsuites/smptests/smp05/Makefile.am (modified) * testsuites/smptests/smp06/Makefile.am (modified) * testsuites/smptests/smp07/Makefile.am (modified) * testsuites/smptests/smp08/Makefile.am (modified) * testsuites/smptests/smp09/Makefile.am (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:38:29 GMT Joel Sherrill [cd06294a] * testsuites/samples/ChangeLog (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_sp/Makefile.am (modified) * testsuites/samples/capture/Makefile.am (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/fileio/Makefile.am (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/iostream/Makefile.am (modified) * testsuites/samples/loopback/Makefile.am (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/nsecs/Makefile.am (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/pppd/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/unlimited/Makefile.am (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:38:26 GMT Joel Sherrill [2b7b14f] * testsuites/psxtmtests/ChangeLog (modified) * testsuites/psxtmtests/psxtmbarrier01/Makefile.am (modified) * testsuites/psxtmtests/psxtmbarrier02/Makefile.am (modified) * testsuites/psxtmtests/psxtmbarrier03/Makefile.am (modified) * testsuites/psxtmtests/psxtmkey01/Makefile.am (modified) * testsuites/psxtmtests/psxtmkey02/Makefile.am (modified) * testsuites/psxtmtests/psxtmmq01/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex01/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex02/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex03/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex04/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex05/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex06/Makefile.am (modified) * testsuites/psxtmtests/psxtmmutex07/Makefile.am (modified) * testsuites/psxtmtests/psxtmnanosleep01/Makefile.am (modified) * testsuites/psxtmtests/psxtmnanosleep02/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock01/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock02/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock03/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock04/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock05/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock06/Makefile.am (modified) * testsuites/psxtmtests/psxtmrwlock07/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem01/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem02/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem03/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem04/Makefile.am (modified) * testsuites/psxtmtests/psxtmsem05/Makefile.am (modified) * testsuites/psxtmtests/psxtmsleep01/Makefile.am (modified) * testsuites/psxtmtests/psxtmsleep02/Makefile.am (modified) * testsuites/psxtmtests/psxtmthread01/Makefile.am (modified) * testsuites/psxtmtests/psxtmthread03/Makefile.am (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:38:23 GMT Joel Sherrill [1b8f204f] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx14/Makefile.am (modified) * testsuites/psxtests/psx15/Makefile.am (modified) * testsuites/psxtests/psx16/Makefile.am (modified) * testsuites/psxtests/psxaio01/Makefile.am (modified) * testsuites/psxtests/psxaio02/Makefile.am (modified) * testsuites/psxtests/psxaio03/Makefile.am (modified) * testsuites/psxtests/psxalarm01/Makefile.am (modified) * testsuites/psxtests/psxautoinit01/Makefile.am (modified) * testsuites/psxtests/psxautoinit02/Makefile.am (modified) * testsuites/psxtests/psxbarrier01/Makefile.am (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxcancel01/Makefile.am (modified) * testsuites/psxtests/psxchroot01/Makefile.am (modified) * testsuites/psxtests/psxclassic01/Makefile.am (modified) * testsuites/psxtests/psxcleanup/Makefile.am (modified) * testsuites/psxtests/psxcleanup01/Makefile.am (modified) * testsuites/psxtests/psxclock/Makefile.am (modified) * testsuites/psxtests/psxcond01/Makefile.am (modified) * testsuites/psxtests/psxeintr_join/Makefile.am (modified) * testsuites/psxtests/psxenosys/Makefile.am (modified) * testsuites/psxtests/psxfatal01/Makefile.am (modified) * testsuites/psxtests/psxfatal02/Makefile.am (modified) * testsuites/psxtests/psxfchx01/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxfile02/Makefile.am (modified) * testsuites/psxtests/psxfilelock01/Makefile.am (modified) * testsuites/psxtests/psxgetrusage01/Makefile.am (modified) * testsuites/psxtests/psxid01/Makefile.am (modified) * testsuites/psxtests/psximfs01/Makefile.am (modified) * testsuites/psxtests/psximfs02/Makefile.am (modified) * testsuites/psxtests/psxintrcritical01/Makefile.am (modified) * testsuites/psxtests/psxitimer/Makefile.am (modified) * testsuites/psxtests/psxkey01/Makefile.am (modified) * testsuites/psxtests/psxkey02/Makefile.am (modified) * testsuites/psxtests/psxkey03/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq02/Makefile.am (modified) * testsuites/psxtests/psxmsgq03/Makefile.am (modified) * testsuites/psxtests/psxmsgq04/Makefile.am (modified) * testsuites/psxtests/psxmutexattr01/Makefile.am (modified) * testsuites/psxtests/psxobj01/Makefile.am (modified) * testsuites/psxtests/psxpasswd01/Makefile.am (modified) * testsuites/psxtests/psxpasswd02/Makefile.am (modified) * testsuites/psxtests/psxpipe01/Makefile.am (modified) * testsuites/psxtests/psxrdwrv/Makefile.am (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxrwlock01/Makefile.am (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsignal01/Makefile.am (modified) * testsuites/psxtests/psxsignal02/Makefile.am (modified) * testsuites/psxtests/psxsignal03/Makefile.am (modified) * testsuites/psxtests/psxsignal04/Makefile.am (modified) * testsuites/psxtests/psxsignal05/Makefile.am (modified) * testsuites/psxtests/psxsignal06/Makefile.am (modified) * testsuites/psxtests/psxspin01/Makefile.am (modified) * testsuites/psxtests/psxspin02/Makefile.am (modified) * testsuites/psxtests/psxstack01/Makefile.am (modified) * testsuites/psxtests/psxstack02/Makefile.am (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxsysconf/Makefile.am (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtimer01/Makefile.am (modified) * testsuites/psxtests/psxtimer02/Makefile.am (modified) * testsuites/psxtests/psxtimes01/Makefile.am (modified) * testsuites/psxtests/psxualarm/Makefile.am (modified) * testsuites/psxtests/psxusleep/Makefile.am (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:38:16 GMT Joel Sherrill [d0566390] * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:38:12 GMT Joel Sherrill [6f9ce8f4] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/block01/Makefile.am (modified) * testsuites/libtests/block02/Makefile.am (modified) * testsuites/libtests/block03/Makefile.am (modified) * testsuites/libtests/block04/Makefile.am (modified) * testsuites/libtests/block05/Makefile.am (modified) * testsuites/libtests/block06/Makefile.am (modified) * testsuites/libtests/block07/Makefile.am (modified) * testsuites/libtests/block08/Makefile.am (modified) * testsuites/libtests/block09/Makefile.am (modified) * testsuites/libtests/block10/Makefile.am (modified) * testsuites/libtests/bspcmdline01/Makefile.am (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/devfs01/Makefile.am (modified) * testsuites/libtests/devfs02/Makefile.am (modified) * testsuites/libtests/devfs03/Makefile.am (modified) * testsuites/libtests/devfs04/Makefile.am (modified) * testsuites/libtests/deviceio01/Makefile.am (modified) * testsuites/libtests/devnullfatal01/Makefile.am (modified) * testsuites/libtests/dumpbuf01/Makefile.am (modified) * testsuites/libtests/ftp01/Makefile.am (modified) * testsuites/libtests/gxx01/Makefile.am (modified) * testsuites/libtests/heapwalk/Makefile.am (modified) * testsuites/libtests/malloc02/Makefile.am (modified) * testsuites/libtests/malloc03/Makefile.am (modified) * testsuites/libtests/malloc04/Makefile.am (modified) * testsuites/libtests/malloc05/Makefile.am (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor02/Makefile.am (modified) * testsuites/libtests/mouse01/Makefile.am (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/stackchk01/Makefile.am (modified) * testsuites/libtests/stringto01/Makefile.am (modified) * testsuites/libtests/tar01/Makefile.am (modified) * testsuites/libtests/tar02/Makefile.am (modified) * testsuites/libtests/tar03/Makefile.am (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/termios01/Makefile.am (modified) * testsuites/libtests/termios02/Makefile.am (modified) * testsuites/libtests/termios03/Makefile.am (modified) * testsuites/libtests/termios04/Makefile.am (modified) * testsuites/libtests/termios05/Makefile.am (modified) * testsuites/libtests/termios06/Makefile.am (modified) * testsuites/libtests/termios07/Makefile.am (modified) * testsuites/libtests/termios08/Makefile.am (modified) * testsuites/libtests/tztest/Makefile.am (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 21:38:08 GMT Joel Sherrill [d7bd47b] * testsuites/fstests/ChangeLog (modified) * testsuites/fstests/imfs_fserror/Makefile.am (modified) * testsuites/fstests/imfs_fslink/Makefile.am (modified) * testsuites/fstests/imfs_fspatheval/Makefile.am (modified) * testsuites/fstests/imfs_fspermission/Makefile.am (modified) * testsuites/fstests/imfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/imfs_fssymlink/Makefile.am (modified) * testsuites/fstests/imfs_fstime/Makefile.am (modified) * testsuites/fstests/mdosfs_fserror/Makefile.am (modified) * testsuites/fstests/mdosfs_fspatheval/Makefile.am (modified) * testsuites/fstests/mdosfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/mdosfs_fstime/Makefile.am (modified) * testsuites/fstests/mimfs_fserror/Makefile.am (modified) * testsuites/fstests/mimfs_fslink/Makefile.am (modified) * testsuites/fstests/mimfs_fspatheval/Makefile.am (modified) * testsuites/fstests/mimfs_fspermission/Makefile.am (modified) * testsuites/fstests/mimfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/mimfs_fssymlink/Makefile.am (modified) * testsuites/fstests/mimfs_fstime/Makefile.am (modified) * testsuites/fstests/mrfs_fserror/Makefile.am (modified) * testsuites/fstests/mrfs_fslink/Makefile.am (modified) * testsuites/fstests/mrfs_fspatheval/Makefile.am (modified) * testsuites/fstests/mrfs_fspermission/Makefile.am (modified) * testsuites/fstests/mrfs_fsrdwr/Makefile.am (modified) * testsuites/fstests/mrfs_fssymlink/Makefile.am (modified) * testsuites/fstests/mrfs_fstime/Makefile.am (modified) 2011-12-08 Joel Sherrill ... Thu, 08 Dec 2011 14:17:07 GMT Ralf Corsepius [ef92e48c] * c/src/ChangeLog (modified) * c/src/libchip/network/sonic.c (modified) 2011-12-08 Ralf Corsépius * ... Thu, 08 Dec 2011 14:15:06 GMT Ralf Corsepius [cc42039] * cpukit/ChangeLog (modified) * cpukit/rtems/src/rtemsobjectgetname.c (modified) 2011-12-08 Ralf Corsépius * ... Thu, 08 Dec 2011 14:13:55 GMT Ralf Corsepius [0042168] * cpukit/ChangeLog (modified) * cpukit/sapi/src/getversionstring.c (modified) 2011-12-08 Ralf Corsépius * ... Thu, 08 Dec 2011 14:12:27 GMT Ralf Corsepius [4b41d3d4] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/termios.c (modified) 2011-12-08 Ralf Corsépius * ... Thu, 08 Dec 2011 08:57:57 GMT Ralf Corsepius [58451f1c] * cpukit/ChangeLog (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/src/pthreadgetcputime.c (deleted) * cpukit/posix/src/pthreadsetcputime.c (deleted) 2011-12-08 Ralf Corsépius ... Thu, 08 Dec 2011 08:49:19 GMT Ralf Corsepius [fd7d65d] * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psx07/init.c (modified) 2011-12-08 Ralf Corsépius ... Thu, 08 Dec 2011 05:36:27 GMT Ralf Corsepius [438a893] * cpukit/ChangeLog (modified) * cpukit/ftpd/ftpd.c (modified) 2011-12-08 Ralf Corsépius * ... Thu, 08 Dec 2011 05:35:14 GMT Ralf Corsepius [8709c3e4] * cpukit/ChangeLog (modified) 2011-12-08 Ralf Corsépius * ... Thu, 08 Dec 2011 05:09:04 GMT Ralf Corsepius [56059905] * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) 2011-12-08 Ralf Corsépius * ... Wed, 07 Dec 2011 23:03:39 GMT Joel Sherrill [5b65c95] * testsuites/psxtmtests/ChangeLog (modified) * testsuites/psxtmtests/psxtmtests_plan.csv (modified) 2011-12-07 Joel Sherrill * ... Wed, 07 Dec 2011 20:08:42 GMT Joel Sherrill [e6584da] * doc/ChangeLog (modified) * doc/user/conf.t (modified) 2011-12-07 Joel Sherrill ... Wed, 07 Dec 2011 20:04:05 GMT Joel Sherrill [a756eff] * doc/ChangeLog (modified) * doc/user/conf.t (modified) 2011-12-07 Joel Sherrill * ... Wed, 07 Dec 2011 18:46:05 GMT Ralf Corsepius [b9f91658] * cpukit/ChangeLog (modified) * cpukit/rtems/src/rtemsobjectapiminimumclass.c (modified) 2011-12-07 Ralf Corsépius * ... Wed, 07 Dec 2011 18:13:14 GMT Ralf Corsepius [ff335a37] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/umon/monlib.c (modified) * c/src/lib/libbsp/shared/umon/tfsDriver.c (modified) 2011-12-07 Ralf Corsépius * ... Wed, 07 Dec 2011 18:10:52 GMT Ralf Corsepius [3bbffec7] * c/src/lib/libbsp/arm/csb337/ChangeLog (modified) * c/src/lib/libbsp/arm/csb337/startup/umonsupp.c (modified) 2011-12-07 Ralf Corsépius * ... Wed, 07 Dec 2011 17:23:04 GMT Ralf Corsepius [a16bc1c] * cpukit/ChangeLog (modified) Fix typo. Wed, 07 Dec 2011 17:21:35 GMT Ralf Corsepius [c4e1e32] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/sup_fs_is_separator.c (modified) 2011-12-07 Ralf Corsépius * ... Wed, 07 Dec 2011 07:11:31 GMT Ralf Corsepius [adfc907] * cpukit/ChangeLog (modified) * cpukit/rtems/src/workspace.c (modified) 2011-12-07 Ralf Corsépius * ... Wed, 07 Dec 2011 06:49:32 GMT Ralf Corsepius [a1399ba] * cpukit/ChangeLog (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) 2011-12-07 Ralf Corsépius ... Wed, 07 Dec 2011 06:46:19 GMT Ralf Corsepius [5876a99] * cpukit/ChangeLog (modified) * cpukit/libnetworking/libc/ns_parse.c (modified) 2011-12-07 Ralf Corsépius * ... Wed, 07 Dec 2011 05:19:07 GMT Ralf Corsepius [ce373088] * cpukit/ChangeLog (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) 2011-12-07 Ralf Corsépius * ... Tue, 06 Dec 2011 15:45:06 GMT Ralf Corsepius [e31173c] * cpukit/ChangeLog (modified) * cpukit/rtems/src/ratemonperiod.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 15:42:00 GMT Ralf Corsepius [39bcf257] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/pipe.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 15:39:29 GMT Ralf Corsepius [9e9fb50] * c/src/ChangeLog (modified) * c/src/libchip/ide/ata.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 15:22:13 GMT Ralf Corsepius [13a69b9] * cpukit/ChangeLog (modified) * cpukit/libmisc/stackchk/check.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 15:20:50 GMT Ralf Corsepius [47528a8f] * cpukit/ChangeLog (modified) * cpukit/libfs/src/pipe/pipe.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 15:12:48 GMT Joel Sherrill [abdeac2a] * doc/.cvsignore (modified) * doc/ChangeLog (modified) * doc/Makefile.am (modified) * doc/README (modified) * doc/ada_user/.cvsignore (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/bsp_howto/.cvsignore (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/configure.ac (modified) * doc/cpu_supplement/.cvsignore (modified) * doc/cpu_supplement/cpu_supplement.texi (modified) * doc/cpu_supplement/preface.texi (modified) * doc/develenv/.cvsignore (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/intro.texi (modified) * doc/filesystem/.cvsignore (modified) * doc/filesystem/filesystem.texi (modified) * doc/filesystem/preface.texi (modified) * doc/index.html.in (modified) * doc/main.am (modified) * doc/networking/.cvsignore (modified) * doc/networking/networking.texi (modified) * doc/networking/preface.texi (modified) * doc/porting/.cvsignore (modified) * doc/porting/porting.texi (modified) * doc/porting/preface.texi (modified) * doc/posix1003.1/.cvsignore (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix_users/.cvsignore (modified) * doc/posix_users/posix_users.texi (modified) * doc/posix_users/preface.texi (modified) * doc/project.am (modified) * doc/rtems_footer.html.in (deleted) * doc/rtems_header.html.in (deleted) * doc/shell/.cvsignore (modified) * doc/shell/preface.texi (modified) * doc/shell/shell.texi (modified) * doc/started/.cvsignore (modified) * doc/started/started.texi (modified) * doc/texi2html_init.in (added) * doc/user/.cvsignore (modified) * doc/user/c_user.texi (modified) * doc/user/dirstat.texi (modified) * doc/user/example.texi (modified) * doc/user/glossary.texi (modified) * doc/user/preface.texi (modified) 2011-12-06 Joel Sherrill ... Tue, 06 Dec 2011 15:12:43 GMT Joel Sherrill [7c69a43f] * doc/tools/ChangeLog (modified) * doc/tools/Makefile.am (modified) * doc/tools/bmenu/bmenu2.c (modified) * doc/tools/configure.ac (modified) * doc/tools/texi2www/ChangeLog (deleted) * doc/tools/texi2www/Makefile.am (deleted) * doc/tools/texi2www/dir-arrow.gif (deleted) * doc/tools/texi2www/missing-arrow.gif (deleted) * doc/tools/texi2www/next-arrow.gif (deleted) * doc/tools/texi2www/prev-arrow.gif (deleted) * doc/tools/texi2www/texi2dvi (deleted) * doc/tools/texi2www/texi2www (deleted) * doc/tools/texi2www/texi2www.texi (deleted) * doc/tools/texi2www/up-arrow.gif (deleted) 2011-12-06 Joel Sherrill ... Tue, 06 Dec 2011 15:12:41 GMT Joel Sherrill [158cdfa] * doc/relnotes/.cvsignore (modified) * doc/relnotes/ChangeLog (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) 2011-12-06 Joel Sherrill ... Tue, 06 Dec 2011 15:12:39 GMT Joel Sherrill [64e0f6ca] * doc/new_chapters/.cvsignore (modified) * doc/new_chapters/ChangeLog (modified) * doc/new_chapters/new_chapters.texi (modified) 2011-12-06 Joel Sherrill ... Tue, 06 Dec 2011 14:23:26 GMT Sebastian Huber [a89ae540] * cpukit/ChangeLog (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/protectedheap.h (modified) * cpukit/score/src/heapgetinfo.c (modified) * cpukit/score/src/heapiterate.c (added) * cpukit/score/src/pheapiterate.c (added) 2011-12-06 Sebastian Huber ... Tue, 06 Dec 2011 14:06:39 GMT Sebastian Huber [7e0ef0f7] * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) 2011-12-06 Sebastian Huber ... Tue, 06 Dec 2011 14:01:55 GMT Sebastian Huber [f41fb2b] * c/src/lib/libbsp/arm/lpc32xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc32xx.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/nand-mlc.h (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc (modified) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_mzx_stage_1.cfg (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/emc.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/i2c.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/system-clocks.c (added) * c/src/lib/libbsp/arm/lpc32xx/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (modified) 2011-12-06 Sebastian Huber ... Tue, 06 Dec 2011 13:52:48 GMT Sebastian Huber [6dbbe5b8] * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx.inc (modified) 2011-12-06 Sebastian Huber ... Tue, 06 Dec 2011 13:39:12 GMT Ralf Corsepius [ee89b319] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/flockfile.c (modified) * cpukit/libcsupport/src/ftrylockfile.c (modified) * cpukit/libcsupport/src/funlockfile.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 13:35:12 GMT Ralf Corsepius [3e0a98a] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/envlock.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 08:21:38 GMT Sebastian Huber [13760c8] * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/spedfsched02/init.c (modified) * testsuites/sptests/spedfsched02/task1.c (modified) 2011-12-06 Petr Benes PR ... Tue, 06 Dec 2011 08:15:32 GMT Ralf Corsepius [b317c391] * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 08:05:34 GMT Ralf Corsepius [16ef51e] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/envlock.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 08:02:31 GMT Ralf Corsepius [01d79ed] * cpukit/ChangeLog (modified) * cpukit/libmisc/serdbg/serdbg.h (modified) * cpukit/libmisc/serdbg/serdbgcnf.h (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 08:00:24 GMT Ralf Corsepius [3ab21dce] * cpukit/ChangeLog (modified) * cpukit/libmisc/mouse/serial_mouse.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 07:57:10 GMT Ralf Corsepius [96d3f26e] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/malloc_sbrk_helpers.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 07:34:48 GMT Ralf Corsepius [6425dc5] * cpukit/ChangeLog (modified) * cpukit/libmisc/monitor/mon-network.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 07:12:42 GMT Ralf Corsepius [04bf7cb] * cpukit/ChangeLog (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbsdestroyserver.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetapprovedbudget.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetparameters.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/schedulercbssetparameters.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 07:08:45 GMT Ralf Corsepius [e2bcb32] * cpukit/ChangeLog (modified) * cpukit/posix/src/pspinlocktranslatereturncode.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 07:05:54 GMT Ralf Corsepius [46ae58a5] * cpukit/ChangeLog (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 06:39:03 GMT Ralf Corsepius [145c9343] * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) 2011-12-06 Ralf Corsépius * ... Tue, 06 Dec 2011 06:35:24 GMT Ralf Corsepius [2186f401] * c/src/ChangeLog (modified) * c/src/libchip/serial/mc68681.c (modified) 2011-12-06 Ralf Corsépius * ... Mon, 05 Dec 2011 21:34:18 GMT Joel Sherrill [b4f5d4dc] * doc/ChangeLog (modified) * doc/ada_user/version.texi (modified) * doc/bsp_howto/version.texi (modified) * doc/cpu_supplement/version.texi (modified) * doc/develenv/version.texi (modified) * doc/filesystem/version.texi (modified) * doc/networking/version.texi (modified) * doc/porting/version.texi (modified) * doc/posix1003.1/version.texi (modified) * doc/posix_users/version.texi (modified) * doc/shell/version.texi (modified) * doc/started/version.texi (modified) * doc/user/version.texi (modified) 2011-12-05 Joel Sherrill * ... Mon, 05 Dec 2011 21:34:13 GMT Joel Sherrill [3de564d] * doc/new_chapters/ChangeLog (modified) * doc/new_chapters/version.texi (modified) * doc/relnotes/ChangeLog (modified) * doc/relnotes/version.texi (modified) 2011-12-05 Joel Sherrill * ... Mon, 05 Dec 2011 17:31:19 GMT Ralf Corsepius [e8f0541] * cpukit/ChangeLog (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture.h (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 17:01:30 GMT Ralf Corsepius [540eec6e] * cpukit/ChangeLog (modified) * cpukit/rtems/src/rtemsobjectapimaximumclass.c (modified) * cpukit/sapi/src/exshutdown.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 16:53:55 GMT Ralf Corsepius [060092c0] * cpukit/ChangeLog (modified) * cpukit/libmisc/mouse/mouse_parser.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 15:22:51 GMT Gedare Bloom [96d29be] * c/src/lib/libbsp/lm32/shared/ChangeLog (modified) 2011-12-05 Gedare Bloom * ... Mon, 05 Dec 2011 15:21:50 GMT Gedare Bloom [51441425] * c/src/lib/libbsp/lm32/shared/ChangeLog (modified) * c/src/lib/libbsp/lm32/shared/milkymist_midi/midi.c (modified) 2011-12-05 Sebastien Bourdeauducq * ... Mon, 05 Dec 2011 14:20:38 GMT Ralf Corsepius [df4669f] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/lchown.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 13:51:06 GMT Ralf Corsepius [b929b39e] * cpukit/ChangeLog (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/sapi/include/confdefs.h (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 13:02:01 GMT Ralf Corsepius [53aceab] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/monitor02/init.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 09:46:57 GMT Ralf Corsepius [32f5014b] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/shell.h (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 09:21:11 GMT Sebastian Huber [5d64fef2] * c/src/ChangeLog (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata_util.c (modified) 2011-12-05 Sebastian Huber ... Mon, 05 Dec 2011 08:54:35 GMT Ralf Corsepius [a19ccd7] * cpukit/ChangeLog (modified) * cpukit/rtems/src/tasks.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 08:53:18 GMT Ralf Corsepius [8348518] * cpukit/ChangeLog (modified) * cpukit/rtems/src/taskinitusers.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 08:52:07 GMT Ralf Corsepius [76f1677] * cpukit/ChangeLog (modified) * cpukit/posix/src/pthread.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 08:50:56 GMT Ralf Corsepius [e42e069] * cpukit/ChangeLog (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 08:49:06 GMT Ralf Corsepius [166b02df] * cpukit/ChangeLog (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 05:17:45 GMT Ralf Corsepius [98c1e0d] * cpukit/ChangeLog (modified) * cpukit/posix/src/pthreadatfork.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 05:15:38 GMT Ralf Corsepius [e511f6d0] * cpukit/ChangeLog (modified) * cpukit/posix/src/mqueuetranslatereturncode.c (modified) * cpukit/posix/src/mutextranslatereturncode.c (modified) * cpukit/posix/src/semaphoretranslatereturncode.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 05:11:21 GMT Ralf Corsepius [7729910] * cpukit/ChangeLog (modified) * cpukit/posix/src/mqueuenotify.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 05:09:50 GMT Ralf Corsepius [33385b14] * cpukit/ChangeLog (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 05:06:50 GMT Ralf Corsepius [7f0c1fd5] * cpukit/ChangeLog (modified) * cpukit/libcsupport/src/termios.c (modified) 2011-12-05 Ralf Corsépius * ... Mon, 05 Dec 2011 05:04:49 GMT Ralf Corsepius [3237e88] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/main_mv.c (modified) 2011-12-05 Ralf Corsépius * ... Sun, 04 Dec 2011 18:27:40 GMT Ralf Corsepius [a8ed055] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/main_cp.c (modified) 2011-12-04 Ralf Corsépius * ... Sun, 04 Dec 2011 18:25:45 GMT Ralf Corsepius [4326cdee] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/main_ls.c (modified) 2011-12-04 Ralf Corsépius * ... Sun, 04 Dec 2011 18:24:15 GMT Ralf Corsepius [c15f25e] * cpukit/ChangeLog (modified) 2011-12-04 Ralf Corsépius * ... Sun, 04 Dec 2011 18:22:14 GMT Ralf Corsepius [cb2464b] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/main_rm.c (modified) 2011-12-04 Ralf Corsépius * ... Sun, 04 Dec 2011 18:20:23 GMT Ralf Corsepius [d7417a51] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/pwcache.c (modified) 2011-12-04 Ralf Corsépius * ... Sun, 04 Dec 2011 18:18:52 GMT Ralf Corsepius [5383441c] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/internal.h (modified) 2011-12-04 Ralf Corsépius * ... Sun, 04 Dec 2011 11:57:51 GMT Ralf Corsepius [94547d1] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/print-ls.c (modified) * cpukit/libmisc/shell/pwcache.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libmisc/shell/shell_cmdset.c (modified) * cpukit/libmisc/shell/shell_makeargs.c (modified) * cpukit/libmisc/shell/write_file.c (modified) 2011-12-04 Ralf Corsépius * ... Sun, 04 Dec 2011 10:22:51 GMT Ralf Corsepius [3421e520] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/main_help.c (modified) * cpukit/libmisc/shell/main_hexdump.c (modified) * cpukit/libmisc/shell/main_id.c (modified) * cpukit/libmisc/shell/main_ifconfig.c (modified) * cpukit/libmisc/shell/main_ln.c (modified) * cpukit/libmisc/shell/main_logoff.c (modified) * cpukit/libmisc/shell/main_ls.c (modified) * cpukit/libmisc/shell/main_mallocinfo.c (modified) * cpukit/libmisc/shell/main_medit.c (modified) * cpukit/libmisc/shell/main_mfill.c (modified) * cpukit/libmisc/shell/main_mkdir.c (modified) * cpukit/libmisc/shell/main_mknod.c (modified) * cpukit/libmisc/shell/main_mmove.c (modified) * cpukit/libmisc/shell/main_mount.c (modified) * cpukit/libmisc/shell/main_msdosfmt.c (modified) * cpukit/libmisc/shell/main_mv.c (modified) * cpukit/libmisc/shell/main_mwdump.c (modified) * cpukit/libmisc/shell/main_netstats.c (modified) * cpukit/libmisc/shell/main_perioduse.c (modified) * cpukit/libmisc/shell/main_pwd.c (modified) * cpukit/libmisc/shell/main_rm.c (modified) * cpukit/libmisc/shell/main_rmdir.c (modified) * cpukit/libmisc/shell/main_route.c (modified) * cpukit/libmisc/shell/main_setenv.c (modified) * cpukit/libmisc/shell/main_sleep.c (modified) * cpukit/libmisc/shell/main_stackuse.c (modified) * cpukit/libmisc/shell/main_time.c (modified) * cpukit/libmisc/shell/main_tty.c (modified) * cpukit/libmisc/shell/main_umask.c (modified) * cpukit/libmisc/shell/main_unmount.c (modified) * cpukit/libmisc/shell/main_unsetenv.c (modified) * cpukit/libmisc/shell/main_whoami.c (modified) * cpukit/libmisc/shell/main_wkspaceinfo.c (modified) * libmisc/shell/main_help.c: Make rtems_shell_help_cmd, ... Sun, 04 Dec 2011 09:51:48 GMT Ralf Corsepius [f1d9293e] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/cmds.c (modified) * cpukit/libmisc/shell/main_alias.c (modified) * cpukit/libmisc/shell/main_blksync.c (modified) * cpukit/libmisc/shell/main_cat.c (modified) * cpukit/libmisc/shell/main_chdir.c (modified) * cpukit/libmisc/shell/main_chmod.c (modified) * cpukit/libmisc/shell/main_chroot.c (modified) * cpukit/libmisc/shell/main_cp.c (modified) * cpukit/libmisc/shell/main_cpuuse.c (modified) * cpukit/libmisc/shell/main_date.c (modified) * cpukit/libmisc/shell/main_dd.c (modified) * cpukit/libmisc/shell/main_echo.c (modified) * cpukit/libmisc/shell/main_getenv.c (modified) * cpukit/libmisc/shell/main_halt.c (modified) 2011-12-04 Ralf Corsépius * ...
