# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 05/23/24 11:53:12 Mon, 06 Oct 2014 05:25:10 GMT Sebastian Huber [d5cc923f] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/preinstall.am (modified) * c/src/lib/libbsp/shared/console-termios-init.c (added) * c/src/lib/libbsp/shared/include/console-termios.h (added) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps: Add Termios console driver initialization Add a simple ... Tue, 07 Oct 2014 14:28:04 GMT Sebastian Huber [7fd5e89] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * doc/bsp_howto/console.t (modified) * testsuites/libtests/termios01/init.c (modified) termios: Partially hide rtems_termios_tty Move interrupt lock to ... Tue, 07 Oct 2014 14:27:51 GMT Sebastian Huber [a830cb8] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * doc/bsp_howto/console.t (modified) * testsuites/libtests/termios01/init.c (modified) termios: Separate flow control from normal handler Tue, 07 Oct 2014 12:51:39 GMT Sebastian Huber [ff7217b] * cpukit/libcsupport/src/termios.c (modified) termios: Fix transmit daemon Do not call ... Mon, 06 Oct 2014 12:00:03 GMT Daniel Hellstrom [74f5eaf] * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) erc32,leon2: replace bsp_reset with SPARC fatal handler Now that a ... Wed, 21 May 2014 07:37:16 GMT Daniel Hellstrom [5e92a40a] * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspclean.c (added) * c/src/lib/libbsp/sparc/leon3/startup/bspreset.c (deleted) LEON3: use CPU_Fatal_halt for halt By removing the bsp_reset() ... Tue, 20 May 2014 15:45:07 GMT Daniel Hellstrom [9bd7b3b1] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/startup/bsp_fatal_halt.c (added) * c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_halt.c (added) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) SPARC: Fatal_halt use source and exit codes The Fatal_halt handler ... Mon, 19 May 2014 15:27:55 GMT Daniel Hellstrom [ce4a7ae] * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * c/src/lib/libbsp/sparc/shared/startup/bsp_fatal_exit.c (added) SPARC: add BSP specific error handler Instead of calling the system ... Wed, 21 May 2014 11:11:54 GMT Daniel Hellstrom [dfc2786d] * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) SPARC BSPs: remove BSP_fatal_return unreached code Fri, 03 Oct 2014 22:55:12 GMT Chris Johns [56ed56a6] * cpukit/libmisc/shell/main_ping.c (modified) libmisc/shell: Remove the need for -lm when linking from the ping ... Sun, 21 Sep 2014 18:07:41 GMT Tomasz Gregorek [7db6953] * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h (modified) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (modified) * c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c (modified) bsp/stm32f4XXXX: System clock configuration Added simple math to ... Wed, 01 Oct 2014 13:16:23 GMT Moroz.Oleg [9a8b2984] * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) Fix assertion "BUF != NULL" for i386 BSP_uart_termios_write_com1 ... Wed, 01 Oct 2014 11:53:03 GMT Daniel Cederman [93b000e] * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/sparc/leon3/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) * c/src/lib/libbsp/sparc/shared/irq/irq-shared.c (modified) bsp/leon3: Replace the define LEON3_MP_IRQ with a weakly linked ... Tue, 30 Sep 2014 09:26:50 GMT Sebastian Huber [456eab7d] * cpukit/pppd/ipcp.c (modified) pppd: Import change from NetBSD This avoids the use of ... Tue, 23 Sep 2014 12:20:35 GMT Sebastian Huber [805360b] * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/pppd/rtemspppd.h (modified) * testsuites/samples/pppd/netconfig.h (modified) pppd: Fix warnings Tue, 30 Sep 2014 09:25:57 GMT Sebastian Huber [33739be] * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) libnetworking: Update due to Termios changes Fri, 19 Sep 2014 19:20:35 GMT Hesham ALMatary [fbe59f7] * c/src/lib/libbsp/or1k/or1ksim/console/uart.c (modified) or1ksim: Console: implement uart_read_polled Implement ... Fri, 19 Sep 2014 14:55:09 GMT Hesham ALMatary [5464752f] * cpukit/score/cpu/or1k/or1k-context-initialize.c (modified) or1k fix bug: Initialize thread context with higher stack address. ... Tue, 23 Sep 2014 08:45:23 GMT Sebastian Huber [79bbb1cb] * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/cache_.h (added) * c/src/lib/libbsp/m68k/genmcf548x/startup/bspstart.c (modified) bsp/genmcf548x: Use inline cache implementation Tue, 23 Sep 2014 08:36:02 GMT Sebastian Huber [c3bf343] * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) bsp/genmcf548x: Delete duplicate network config Tue, 23 Sep 2014 06:01:56 GMT Sebastian Huber [5323247] * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) m68k: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC Converting 64-bit ... Tue, 23 Sep 2014 05:57:56 GMT Sebastian Huber [30e5e765] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC Converting 64-bit ... Mon, 22 Sep 2014 10:01:49 GMT Sebastian Huber [dadd7cd] * cpukit/score/include/rtems/score/thread.h (modified) score: Delete Thread_Wait_information::Block2n This field is no ... Fri, 19 Sep 2014 12:19:55 GMT Sebastian Huber [90ce69b] * cpukit/score/src/threadqdequeue.c (modified) score: Critical fix for _Thread_queue_Dequeue() Do not return NULL ... Fri, 19 Sep 2014 12:18:00 GMT Sebastian Huber [6f1e1b3] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spintrcritical22/Makefile.am (added) * testsuites/sptests/spintrcritical22/init.c (added) * testsuites/sptests/spintrcritical22/spintrcritical22.doc (added) * testsuites/sptests/spintrcritical22/spintrcritical22.scn (added) sptests/spintrcritical22: New test Thu, 18 Sep 2014 13:57:03 GMT Joel Sherrill [b422c549] * doc/shell/Makefile.am (modified) * doc/shell/network.t (modified) * doc/shell/shell.texi (modified) doc/shell: Correct build issues from ... Thu, 18 Sep 2014 13:33:33 GMT Sebastian Huber [386d8b5] * cpukit/score/cpu/sparc/sparcv8-atomic.c (modified) sparc: Add comment Thu, 18 Sep 2014 09:07:41 GMT Sebastian Huber [bdd6082] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/preinstall.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/preinstall.am (modified) * c/src/lib/libbsp/or1k/or1ksim/Makefile.am (modified) * c/src/lib/libbsp/or1k/or1ksim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/preinstall.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/preinstall.am (modified) bsps: Fix build error Fix build error introduced in ... Thu, 18 Sep 2014 06:09:09 GMT Sebastian Huber [15d7261b] * cpukit/telnetd/telnetd.c (modified) telnetd: Use socklen_t Wed, 17 Sep 2014 08:28:13 GMT Sebastian Huber [8f0a2c9] * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smpload01/smpload01.scn (modified) smptests/smpload01: Report profiling only once Rely on test ... Wed, 17 Sep 2014 05:21:35 GMT Sebastian Huber [c040b113] * cpukit/libmisc/redirector/stdio-redirect.c (modified) * cpukit/libmisc/redirector/stdio-redirect.h (modified) redirector: Rename rtems_stdio_redirect_t Rename ... Tue, 16 Sep 2014 22:40:48 GMT Joel Sherrill [2195a95f] * cpukit/libmisc/Makefile.am (modified) Libmisc/Makefile.am: Build with networking disabled Thu, 04 Sep 2014 20:41:21 GMT Joel Sherrill [f535fe53] * c/src/lib/libbsp/m68k/mvme162/tod/tod.c (modified) * c/src/lib/libbsp/shared/tod.c (modified) * c/src/lib/libcpu/bfin/clock/rtc.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/tod.h (moved) * cpukit/libcsupport/preinstall.am (modified) tod.h -> libcsupport like other driver and helper prototype files ... Thu, 04 Sep 2014 20:39:41 GMT Joel Sherrill [f641b15] * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) Revert: rtems-rfs-buffer.c: Correct printf() format specifiers to ... Thu, 04 Sep 2014 15:08:25 GMT Joel Sherrill [6cd2074] * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) pc386/.../bsp.h: Do not include crt.h crt.h defines such lovely ... Thu, 04 Sep 2014 13:59:49 GMT Joel Sherrill [8fbe2e6] * c/src/lib/libbsp/arm/edb7312/timer/timer.c (modified) * c/src/lib/libbsp/arm/gba/timer/timer.c (modified) * c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/timer.c (modified) * c/src/lib/libbsp/arm/lpc32xx/misc/timer.c (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/timer.c (modified) * c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_timer/timer.c (modified) * c/src/lib/libbsp/lm32/shared/timer/timer.c (modified) * c/src/lib/libbsp/m32c/m32cbsp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mcf52235/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mcf5329/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mrm332/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timer.c (modified) * c/src/lib/libbsp/mips/csb350/timer/timer.c (modified) * c/src/lib/libbsp/mips/genmongoosev/timer/timer.c (modified) * c/src/lib/libbsp/mips/jmr3904/timer/timer.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (modified) * c/src/lib/libbsp/or1k/or1ksim/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/timer/timer.c (modified) * c/src/lib/libbsp/shared/timerstub.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon2/timer/timer.c (modified) * c/src/lib/libbsp/sparc/leon3/timer/timer.c (modified) * c/src/lib/libcpu/arm/at91rm9200/timer/timer.c (modified) * c/src/lib/libcpu/arm/lpc22xx/timer/timer.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/timer/timer.c (modified) * c/src/lib/libcpu/arm/pxa255/timer/timer.c (modified) * c/src/lib/libcpu/arm/s3c24xx/timer/timer.c (modified) * c/src/lib/libcpu/bfin/timer/timer.c (modified) * c/src/lib/libcpu/m68k/mcf5206/timer/timer.c (modified) * c/src/lib/libcpu/m68k/mcf5206/timer/timerisr.S (modified) * c/src/lib/libcpu/m68k/mcf5272/timer/timer.c (modified) * c/src/lib/libcpu/m68k/mcf5272/timer/timerisr.S (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc5xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7032/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7750/timer/timer.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/timerdrv.h (deleted) * cpukit/libcsupport/preinstall.am (modified) * cpukit/sapi/include/confdefs.h (modified) * doc/bsp_howto/timer.t (modified) * testsuites/psxtmtests/psxtmbarrier01/init.c (modified) * testsuites/psxtmtests/psxtmbarrier02/init.c (modified) * testsuites/psxtmtests/psxtmbarrier03/init.c (modified) * testsuites/psxtmtests/psxtmbarrier04/init.c (modified) * testsuites/psxtmtests/psxtmcond01/init.c (modified) * testsuites/psxtmtests/psxtmcond02/init.c (modified) * testsuites/psxtmtests/psxtmcond03/init.c (modified) * testsuites/psxtmtests/psxtmcond04/init.c (modified) * testsuites/psxtmtests/psxtmcond05/init.c (modified) * testsuites/psxtmtests/psxtmcond06/init.c (modified) * testsuites/psxtmtests/psxtmcond07/init.c (modified) * testsuites/psxtmtests/psxtmcond08/init.c (modified) * testsuites/psxtmtests/psxtmkey01/init.c (modified) * testsuites/psxtmtests/psxtmkey02/init.c (modified) * testsuites/psxtmtests/psxtmmq01/init.c (modified) * testsuites/psxtmtests/psxtmmutex01/init.c (modified) * testsuites/psxtmtests/psxtmmutex02/init.c (modified) * testsuites/psxtmtests/psxtmmutex03/init.c (modified) * testsuites/psxtmtests/psxtmmutex04/init.c (modified) * testsuites/psxtmtests/psxtmmutex05/init.c (modified) * testsuites/psxtmtests/psxtmmutex06/init.c (modified) * testsuites/psxtmtests/psxtmmutex07/init.c (modified) * testsuites/psxtmtests/psxtmnanosleep01/init.c (modified) * testsuites/psxtmtests/psxtmnanosleep02/init.c (modified) * testsuites/psxtmtests/psxtmrwlock01/init.c (modified) * testsuites/psxtmtests/psxtmrwlock02/init.c (modified) * testsuites/psxtmtests/psxtmrwlock03/init.c (modified) * testsuites/psxtmtests/psxtmrwlock04/init.c (modified) * testsuites/psxtmtests/psxtmrwlock05/init.c (modified) * testsuites/psxtmtests/psxtmrwlock06/init.c (modified) * testsuites/psxtmtests/psxtmrwlock07/init.c (modified) * testsuites/psxtmtests/psxtmsem01/init.c (modified) * testsuites/psxtmtests/psxtmsem02/init.c (modified) * testsuites/psxtmtests/psxtmsem03/init.c (modified) * testsuites/psxtmtests/psxtmsem04/init.c (modified) * testsuites/psxtmtests/psxtmsem05/init.c (modified) * testsuites/psxtmtests/psxtmsleep01/init.c (modified) * testsuites/psxtmtests/psxtmsleep02/init.c (modified) * testsuites/psxtmtests/psxtmthread02/init.c (modified) * testsuites/psxtmtests/psxtmthread03/init.c (modified) * testsuites/psxtmtests/psxtmthread04/init.c (modified) * testsuites/psxtmtests/psxtmthread05/init.c (modified) * testsuites/psxtmtests/psxtmthread06/init.c (modified) * testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c (modified) * testsuites/rhealstone/rhilatency/ilatency.c (modified) * testsuites/rhealstone/rhmlatency/mlatency.c (modified) * testsuites/rhealstone/rhsemshuffle/semshuffle.c (modified) * testsuites/rhealstone/rhtaskpreempt/taskpreempt.c (modified) * testsuites/rhealstone/rhtaskswitch/taskswitch.c (modified) * testsuites/support/src/tmtests_support.c (modified) Use correct prototype of benchmark_timer_read() This change starts ... Tue, 16 Sep 2014 17:30:46 GMT Hesham ALMatary [c080c343] * c/src/lib/libbsp/or1k/or1ksim/Makefile.am (modified) * c/src/lib/libbsp/or1k/or1ksim/preinstall.am (modified) * c/src/lib/libbsp/or1k/or1ksim/sim.cfg (modified) * c/src/lib/libbsp/or1k/or1ksim/startup/bspstart.c (added) * c/src/lib/libbsp/or1k/shared/include/cache_.h (added) * c/src/lib/libcpu/or1k/Makefile.am (modified) * c/src/lib/libcpu/or1k/preinstall.am (modified) * c/src/lib/libcpu/or1k/shared/cache/cache.c (added) * c/src/lib/libcpu/or1k/shared/cache/cache_.h (modified) or1k: New cache manager. Implement new cache functions for or1k and ... Mon, 15 Sep 2014 22:33:33 GMT Hesham ALMatary [bbecf04] * c/src/lib/libbsp/or1k/or1ksim/README (modified) or1ksim: Update README Modify README to provide instruction on how ... Mon, 15 Sep 2014 22:33:31 GMT Hesham ALMatary [d2c76160] * c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c (modified) or1ksim: Implement cpu counter functions. Mon, 15 Sep 2014 22:33:30 GMT Hesham ALMatary [e0aef221] * cpukit/score/cpu/or1k/or1k-exception-handler-low.S (modified) score/cpu/or1k: Follow no_cpu ISR_Handler algorithm. This patch ... Mon, 15 Sep 2014 22:33:29 GMT Hesham ALMatary [5f56d267] * c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c (modified) or1ksim: work-around to make or1ksim tick timer accurate. This ... Mon, 15 Sep 2014 22:33:28 GMT Hesham ALMatary [eb14fc2b] * c/src/lib/libbsp/or1k/or1ksim/start/start.S (modified) * cpukit/score/cpu/or1k/or1k-context-initialize.c (modified) * cpukit/score/cpu/or1k/or1k-exception-handler-low.S (modified) OpenRISC: Account for red-zone (fixup printf bug). This patch ... Tue, 16 Sep 2014 13:43:15 GMT Sebastian Huber [7f8a978] * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp07/buffered_io.c (deleted) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.scn (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/sp07/task4.c (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp07/tdelete.c (modified) * testsuites/sptests/sp07/trestart.c (modified) * testsuites/sptests/sp07/tstart.c (modified) sptests/sp07: Minimize thread dispatch latency Do not use sprintf() ... Thu, 11 Sep 2014 15:55:34 GMT Daniel Cederman [6e1206a] * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpcache01/smpcache01.doc (modified) * testsuites/smptests/smpcache01/smpcache01.scn (modified) smptests/smpcache01: Remove invalidation of data cache lines from ... Mon, 15 Sep 2014 00:14:01 GMT Chris Johns [fc9f8f5] * doc/shell/file.t (modified) doc: Sort the shell file commands into alphabetical order. Sun, 14 Sep 2014 23:10:45 GMT Chris Johns [b299960] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_md5.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) * doc/shell/file.t (modified) shell: Add an md5 hash command for files. This command lets you get ... Sun, 14 Sep 2014 22:50:28 GMT Chris Johns [ebf9a05] * cpukit/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/redirector/stdio-redirect.c (added) * cpukit/libmisc/redirector/stdio-redirect.h (added) * cpukit/preinstall.am (modified) libmisc: Add a stdio redirector helper. This module makes it easy ... Sun, 14 Sep 2014 22:00:18 GMT Chris Johns [a8fa078] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_ping.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) * cpukit/libmisc/shell/sysexits.h (added) * doc/shell/network.t (modified) shell: Add a ping command. The ping code is taken from a recent ... Fri, 12 Sep 2014 11:31:50 GMT Sebastian Huber [1434dbd6] * doc/cpu_supplement/sparc.t (modified) doc: Clarify ABI in SPARC CPU supplement Fri, 12 Sep 2014 14:04:40 GMT Sebastian Huber [f9eca790] * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) sptests/spintrcritical_support: Optimize busy loop Fri, 12 Sep 2014 14:04:01 GMT Sebastian Huber [73b5d8bf] * testsuites/sptests/spintrcritical10/init.c (modified) sptests/spintrcritical10: Avoid undefined memory Thu, 11 Sep 2014 13:05:02 GMT Sebastian Huber [74493f05] * c/src/lib/libbsp/arm/csb336/make/custom/csb336.cfg (modified) * c/src/lib/libbsp/arm/csb337/make/custom/csb337.cfg (modified) * c/src/lib/libbsp/arm/edb7312/make/custom/edb7312.cfg (modified) * c/src/lib/libbsp/arm/gba/make/custom/gba.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136jfs.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm920.cfg (modified) * c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg (modified) * c/src/lib/libbsp/arm/gumstix/make/custom/gumstix.cfg (modified) * c/src/lib/libbsp/arm/nds/make/custom/nds.cfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx.cfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx_t.cfg (modified) * c/src/lib/libbsp/arm/smdk2410/make/custom/smdk2410.cfg (modified) bsps/arm: Delete obsolete compiler flags These flags are obsolete ... Thu, 11 Sep 2014 11:04:42 GMT Sebastian Huber [4c9f02d] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: Check error status Thu, 11 Sep 2014 07:10:16 GMT Sebastian Huber [c48cf0bd] * c/src/lib/libbsp/mips/shared/irq/vectorexceptions.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) score: Rename _BSP_Exception_frame_print() Rename ... Thu, 11 Sep 2014 07:07:36 GMT Sebastian Huber [6e0000c] * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) powerpc: Delete PPC_BSP_HAS_FIXED_PR288 Thu, 11 Sep 2014 05:33:16 GMT Sebastian Huber [f3508c44] * testsuites/tmtests/tmcontext01/init.c (modified) tmtests/tmcontext01: Improve cache dirty function Increment by ... Wed, 10 Sep 2014 14:17:02 GMT Sebastian Huber [ecf64a5e] * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-clock.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (modified) bsps/arm: Add a9mpcore_clock_initialize_early() This is necessary ... Wed, 10 Sep 2014 13:08:52 GMT Hesham ALMatary [0facefc] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) or1k: Let CPU/BSP Fatal handler have access to source This patchs ... Wed, 10 Sep 2014 12:46:03 GMT Sebastian Huber [e09f8b08] * testsuites/sptests/spfatal07/testcase.h (modified) sptests/spfatal07: Fix end of test message Wed, 04 Jun 2014 09:23:34 GMT Daniel Hellstrom [f82752a4] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-fatal-halt.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/src/interr.c (modified) Let CPU/BSP Fatal handler have access to source Without the source ... Wed, 10 Sep 2014 09:15:44 GMT Sebastian Huber [12ab8d6] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: Fix get cache size Wed, 10 Sep 2014 09:10:04 GMT Sebastian Huber [4768ae0f] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: Fix invalidate instruction cache Do not invalidate the ... Wed, 10 Sep 2014 08:42:47 GMT Sebastian Huber [0cd13bce] * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/console/console-config.c (modified) bsp/altera-cyclone-v: Add BSP_USE_UART_INTERRUPTS Wed, 10 Sep 2014 08:41:35 GMT Sebastian Huber [90f44cd2] * c/src/lib/libbsp/arm/shared/include/arm-gic-tm27.h (modified) bsps/arm: Fix GIC tm27 support Tue, 09 Sep 2014 13:48:21 GMT Federico Casares [f59e64f2] * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram.cfg (modified) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (added) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth.cfg (added) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed_ahb_ram_eth (added) arm/lpc176x: Adding "eth" linker script section. Tue, 09 Sep 2014 15:13:51 GMT Sebastian Huber [4984ee4] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp39/Makefile.am (deleted) * testsuites/sptests/spintrcritical21/Makefile.am (added) * testsuites/sptests/spintrcritical21/init.c (moved) * testsuites/sptests/spintrcritical21/spintrcritical21.doc (moved) * testsuites/sptests/spintrcritical21/spintrcritical21.scn (moved) * testsuites/sptests/spintrcritical21/system.h (moved) sptests/sp39: Convert to sptests/spintrcritical21 Use interrupt ... Tue, 09 Sep 2014 14:49:20 GMT Sebastian Huber [b5f9ad2] * testsuites/psxtests/psxonce01/system.h (modified) psxtests/psxonce01: Use test extension Tue, 09 Sep 2014 13:18:01 GMT Sebastian Huber [5674767f] * c/src/lib/libbsp/powerpc/qoriq/include/tm27.h (modified) bsp/qoriq: Fix tm27 support Mon, 08 Sep 2014 13:18:07 GMT Sebastian Huber [8028089] * testsuites/psxtests/psxintrcritical01/init.c (modified) * testsuites/sptests/spintrcritical01/init.c (modified) * testsuites/sptests/spintrcritical06/init.c (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical11/init.c (modified) * testsuites/sptests/spintrcritical13/init.c (modified) * testsuites/sptests/spintrcritical15/init.c (modified) * testsuites/sptests/spintrcritical16/init.c (modified) * testsuites/sptests/spintrcritical18/init.c (modified) * testsuites/sptests/spintrcritical20/init.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.h (modified) tests: Rework interrupt critical tests This avoids test durations ... Mon, 08 Sep 2014 12:13:31 GMT Pavel Pisa [80ad7090] * cpukit/score/include/rtems/score/basedefs.h (modified) score: More strict RTEMS_DEQUALIFY implementation. This ... Mon, 08 Sep 2014 08:19:42 GMT Sebastian Huber [6821a629] * c/src/aclocal/prog-cxx.m4 (modified) * testsuites/aclocal/prog-cxx.m4 (modified) Add -std=gnu++11 to CXXFLAGS if SMP is enabled This is necessary to ... Mon, 08 Sep 2014 07:50:35 GMT Sebastian Huber [d11e6efe] * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) clockdrv_shell.h: Fix warning Fri, 05 Sep 2014 11:33:57 GMT Sebastian Huber [8d30713d] * testsuites/tmtests/tmcontext01/init.c (modified) tmtests/tmcontext01: Improve cache dirty function Fri, 05 Sep 2014 07:48:11 GMT Sebastian Huber [33676c8c] * doc/cpu_supplement/arm.t (modified) doc/arm: Update floating point unit support Fri, 05 Sep 2014 07:47:37 GMT Sebastian Huber [b8662cf] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) bsps/arm: Do not build unused file Fri, 05 Sep 2014 07:27:56 GMT Sebastian Huber [b802353] * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) bsp/leon3: Include missing header file Fri, 05 Sep 2014 07:27:41 GMT Sebastian Huber [07b4594] * testsuites/sptests/spcontext01/init.c (modified) sptests/spcontext01: Fix warning Fri, 05 Sep 2014 07:13:46 GMT Sebastian Huber [05ac47d] * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/src/keysetspecific.c (modified) posix: Use RTEMS_DECONST() Fri, 05 Sep 2014 07:13:23 GMT Sebastian Huber [4d5250c] * cpukit/posix/src/pthreadattrsetaffinitynp.c (modified) posix: Fix warning Fri, 05 Sep 2014 07:12:59 GMT Sebastian Huber [8dab980] * cpukit/libcsupport/src/sup_fs_deviceio.c (modified) libcsupport: Use RTEMS_DECONST() Fri, 05 Sep 2014 07:12:34 GMT Sebastian Huber [ddf8d12] * c/src/libchip/network/dwmac-desc-enh.c (modified) libchip/dwmac: Use RTEMS_DEVOLATILE() Fri, 05 Sep 2014 06:32:28 GMT Sebastian Huber [a72f16e] * cpukit/score/include/rtems/score/basedefs.h (modified) score: Add RTEMS_DECONST|DEVOLATILE|DEQUALIFY() Tue, 05 Aug 2014 20:48:01 GMT Jennifer Averett [2a86615] * cpukit/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/capture/capture_buffer.c (added) * cpukit/libmisc/capture/capture_buffer.h (added) * cpukit/libmisc/capture/capture_user_extension.c (modified) * cpukit/libmisc/capture/captureimpl.h (modified) * cpukit/preinstall.am (modified) capture: Add support for variable length records. Tue, 22 Jul 2014 14:40:54 GMT Jennifer Averett [133962b] * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/capture_user_extension.c (added) * cpukit/libmisc/capture/captureimpl.h (added) capture: Split user extension methods out. Fri, 05 Sep 2014 06:24:52 GMT Sebastian Huber [b2356837] * testsuites/tmtests/tmcontext01/plot.py (modified) tmtests/tmcontext01: Plot a legend Fri, 05 Sep 2014 03:29:45 GMT Chris Johns [960c9f0] * tools/build/rtems-bin2c.c (modified) tools: Remove invalid cpp characters from the header guards. The ... Thu, 04 Sep 2014 17:55:39 GMT Hesham ALMatary [bc35eeca] * cpukit/score/cpu/or1k/preinstall.am (modified) Regenerate preinstall.am for score/cpu/or1k This patch regenerates ... Wed, 03 Sep 2014 16:02:30 GMT Joel Sherrill [4d69276] * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) nios2_iss/Makefile.am: Add cache Wed, 03 Sep 2014 15:21:21 GMT Joel Sherrill [a864016f] * testsuites/sptests/spcpuset01/init.c (modified) * testsuites/sptests/spcpuset01/test.c (modified) spcpuset01: Use %zd for size_t to eliminate warning Wed, 03 Sep 2014 15:16:43 GMT Joel Sherrill [de549c3] * testsuites/psxtmtests/psxtmcond01/init.c (modified) * testsuites/psxtmtests/psxtmcond02/init.c (modified) * testsuites/psxtmtests/psxtmcond03/init.c (modified) * testsuites/psxtmtests/psxtmcond04/init.c (modified) * testsuites/psxtmtests/psxtmcond05/init.c (modified) * testsuites/psxtmtests/psxtmcond06/init.c (modified) * testsuites/psxtmtests/psxtmcond08/init.c (modified) * testsuites/psxtmtests/psxtmthread02/init.c (modified) * testsuites/psxtmtests/psxtmthread04/init.c (modified) * testsuites/psxtmtests/psxtmthread05/init.c (modified) * testsuites/psxtmtests/psxtmthread06/init.c (modified) Misc psxtmtests: Use uint32_t not long for end_time to match printf() ... Wed, 03 Sep 2014 15:07:28 GMT Joel Sherrill [9aa6ddf] * testsuites/sptests/spfreechain01/init.c (modified) spfreechain01/init.c: Use %zd for size_t to eliminate warning Wed, 03 Sep 2014 14:59:37 GMT Joel Sherrill [06ac8b71] * cpukit/libmisc/shell/shell.c (modified) shell.c: Add cast to match printf() expectations for width specifier Wed, 03 Sep 2014 14:59:10 GMT Joel Sherrill [2dd1e75e] * cpukit/libfs/src/rfs/rtems-rfs-buffer.c (modified) rtems-rfs-buffer.c: Correct printf() format specifiers to eliminate ... Tue, 02 Sep 2014 17:30:25 GMT Joel Sherrill [e1462e1] * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/fptest.h (modified) sp19: Eliminate warnings Tue, 02 Sep 2014 17:30:01 GMT Joel Sherrill [ce134f74] * c/src/lib/libbsp/powerpc/score603e/start/start.S (modified) score603e/start/start.S: Add start symbol to eliminate warning Tue, 02 Sep 2014 17:29:42 GMT Joel Sherrill [ae03ad26] * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmds (modified) mcf5235/.../linkcmds: Use dram region consistently like other ... Tue, 02 Sep 2014 23:07:36 GMT Joel Sherrill [3bff410] * cpukit/score/include/rtems/score/assert.h (modified) rtems/score/assert.h: Rework to allow use of NDEBUG Tue, 02 Sep 2014 23:07:15 GMT Joel Sherrill [9d95ef9] * cpukit/posix/src/mprotect.c (modified) mprotect.c: Remove warning for no prototype Tue, 02 Sep 2014 23:06:57 GMT Joel Sherrill [78364c7d] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) tms570/Makefile.am: Remove bad networking build info Tue, 02 Sep 2014 23:05:15 GMT Joel Sherrill [4761761c] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add tests which do not link with debug ...
