# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 18:17:55 Tue, 23 Jul 2013 09:03:13 GMT Sebastian Huber [caab339] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/optionsimpl.h (moved) * cpukit/rtems/preinstall.am (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) rtems: Create options implementation header Move implementation ... Tue, 23 Jul 2013 08:54:37 GMT Sebastian Huber [faa2f8c4] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/statusimpl.h (added) * cpukit/rtems/inline/rtems/rtems/status.inl (deleted) * cpukit/rtems/preinstall.am (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/rtemsobjectgetclassicname.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/status.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/sapi/src/extensionident.c (modified) rtems: Create status implementation header Move implementation ... Tue, 23 Jul 2013 08:38:11 GMT Sebastian Huber [93fb3cb0] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/rbtree.h (modified) * cpukit/score/include/rtems/score/rbtreeimpl.h (added) * cpukit/score/inline/rtems/score/rbtree.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/rbtreeextract.c (modified) * cpukit/score/src/rbtreefind.c (modified) * cpukit/score/src/rbtreeget.c (modified) * cpukit/score/src/rbtreeinsert.c (modified) * cpukit/score/src/rbtreeiterate.c (modified) * cpukit/score/src/rbtreenext.c (modified) * testsuites/libtests/rbheap01/init.c (modified) * testsuites/sptests/sprbtree01/init.c (modified) score: Create rbtree implementation header Move implementation ... Tue, 23 Jul 2013 08:04:19 GMT Sebastian Huber [ac252bdc] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/extensionimpl.h (moved) * cpukit/sapi/preinstall.am (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/sapi/src/extensiondata.c (modified) * cpukit/sapi/src/extensiondelete.c (modified) * cpukit/sapi/src/extensionident.c (modified) * testsuites/sptests/spsize/size.c (modified) sapi: Create extension implementation header Move implementation ... Tue, 23 Jul 2013 07:50:22 GMT Sebastian Huber [2445bda] * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/rbtree.h (modified) * cpukit/sapi/inline/rtems/rbtree.inl (deleted) * cpukit/sapi/preinstall.am (modified) * testsuites/sptests/sprbtree01/init.c (modified) sapi: Merge rbtree API into one file Tue, 23 Jul 2013 07:48:38 GMT Sebastian Huber [98c7eaca] * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/timespec.h (modified) * cpukit/sapi/inline/rtems/timespec.inl (deleted) * cpukit/sapi/preinstall.am (modified) sapi: Merge timespec API into one file Tue, 23 Jul 2013 07:44:47 GMT Sebastian Huber [b5ffa5e] * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/cbs.h (modified) * cpukit/sapi/inline/rtems/cbs.inl (deleted) * cpukit/sapi/preinstall.am (modified) sapi: Merge CBS API into one file Tue, 23 Jul 2013 07:15:12 GMT Sebastian Huber [be1b8a7] * cpukit/posix/src/cancelrun.c (modified) * cpukit/posix/src/cleanuppop.c (modified) posix: Include proper header file Mon, 22 Jul 2013 23:30:07 GMT Cynthia Rempel [1f6138e5] * doc/user/conf.t (modified) doc/user/conf.t: Fix SMP_MAXIMUM_PROCESSORS and add Go Configuration Mon, 22 Jul 2013 23:29:49 GMT Joel Sherrill [b885fe1] * doc/shell/Makefile.am (modified) doc/shell/Makefile.am: Fix dependency Mon, 22 Jul 2013 15:26:23 GMT Sebastian Huber [f6f4943] * cpukit/libnetworking/rtems/rtems_glue.c (modified) network: SMP support for network semaphore Sun, 21 Jul 2013 21:04:50 GMT Karel Gardas [dbce4c6] * c/src/lib/libbsp/arm/stm32f4/console/console-config.c (modified) bsp/stm32f4: fix typo in USART2 device name Mon, 22 Jul 2013 14:27:30 GMT Sebastian Huber [b1564cc] * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/chain.h (modified) * cpukit/sapi/inline/rtems/chain.inl (deleted) * cpukit/sapi/preinstall.am (modified) sapi: Merge chain implementation into one file Mon, 22 Jul 2013 14:01:53 GMT Sebastian Huber [a1ccc40] * cpukit/rtems/src/timerserver.c (modified) rtems: Basic SMP support for timer server Mon, 22 Jul 2013 13:13:29 GMT Sebastian Huber [2a3cff8] * cpukit/score/include/rtems/score/coremuteximpl.h (modified) score: _CORE_mutex_Check_dispatch_for_seize() Add SMP version of ... Mon, 22 Jul 2013 08:01:37 GMT Sebastian Huber [c2d6447] * cpukit/posix/src/ualarm.c (modified) posix: Protect ualarm() Use thread dispatch disable/enable to ... Mon, 22 Jul 2013 13:03:04 GMT Sebastian Huber [43f97f1] * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/ualarm.c (modified) posix: Statically init _POSIX_signals_Ualarm_timer Fri, 19 Jul 2013 15:18:42 GMT Sebastian Huber [a9cc1beb] * cpukit/posix/src/alarm.c (modified) posix: Protect alarm() Use thread dispatch disable/enable to ensure ... Mon, 22 Jul 2013 11:48:51 GMT Sebastian Huber [e2005af6] * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/psignal.c (modified) posix: Statically init _POSIX_signals_Alarm_timer Mon, 22 Jul 2013 09:10:43 GMT Sebastian Huber [0eae7ba9] * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * testsuites/sptests/spwatchdog/init.c (modified) score: Add WATCHDOG_INITIALIZER() Mon, 22 Jul 2013 08:21:03 GMT Sebastian Huber [4b48ece0] * cpukit/libmisc/capture/capture-cli.c (modified) * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/timercreate.c (modified) * cpukit/posix/src/timerdelete.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timerinserthelper.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/rtems/src/clockgettickssinceboot.c (modified) * cpukit/rtems/src/clocksetnsecshandler.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (added) * cpukit/score/inline/rtems/score/watchdog.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/corespinlockwait.c (modified) * cpukit/score/src/coretodget.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredfprioritycompare.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/threadblockingoperationcancel.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadqdequeuefifo.c (modified) * cpukit/score/src/threadqdequeuepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextractfifo.c (modified) * cpukit/score/src/threadqextractpriority.c (modified) * cpukit/score/src/threadreset.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/watchdogadjust.c (modified) * cpukit/score/src/watchdogadjusttochain.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdognanoseconds.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogreport.c (modified) * cpukit/score/src/watchdogreportchain.c (modified) * cpukit/score/src/watchdogtickle.c (modified) * testsuites/sptests/sp20/task1.c (modified) * testsuites/sptests/sp67/init.c (modified) * testsuites/sptests/spedfsched02/task1.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spwatchdog/init.c (modified) * testsuites/sptests/spwatchdog/task1.c (modified) score: Create watchdog implementation header Move implementation ... Mon, 22 Jul 2013 08:49:19 GMT Sebastian Huber [6e93dc4a] * cpukit/rtems/inline/rtems/rtems/part.inl (modified) * cpukit/sapi/include/rtems/chain.h (modified) * cpukit/sapi/inline/rtems/chain.inl (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/chainimpl.h (moved) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/inline/rtems/score/schedulerpriority.inl (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/chainappend.c (modified) * cpukit/score/src/chainappendempty.c (modified) * cpukit/score/src/chainextract.c (modified) * cpukit/score/src/chainget.c (modified) * cpukit/score/src/chaingetempty.c (modified) * cpukit/score/src/chaininsert.c (modified) * cpukit/score/src/chainnodecount.c (modified) * cpukit/score/src/chainprependempty.c (modified) * cpukit/score/src/objectactivecount.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqenqueuefifo.c (modified) * cpukit/score/src/threadqenqueuepriority.c (modified) * cpukit/score/src/threadqfirstfifo.c (modified) * cpukit/score/src/threadqfirstpriority.c (modified) score: Create chain implementation header Move implementation ... Mon, 22 Jul 2013 07:15:04 GMT Sebastian Huber [47ac81f] * cpukit/posix/src/setcancelstate.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/testcancel.c (modified) posix: Obtain _Thread_Executing in proper context Mon, 22 Jul 2013 07:11:43 GMT Sebastian Huber [918d5565] * testsuites/sptests/sp37/init.c (modified) sptests/sp37: Disable dispatch for clock tick Fri, 19 Jul 2013 15:18:15 GMT Sebastian Huber [768c5cee] * cpukit/posix/src/pthreadjoin.c (modified) posix: Obtain _Thread_Executing in proper context Fri, 19 Jul 2013 13:32:51 GMT Sebastian Huber [16243a2] * cpukit/score/include/rtems/score/coremuteximpl.h (modified) score: Avoid direct usage of _Thread_Executing Pass the executing ... Fri, 19 Jul 2013 13:24:04 GMT Sebastian Huber [c71b596] * cpukit/posix/include/rtems/posix/spinlockimpl.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/corespinlock.h (modified) * cpukit/score/include/rtems/score/corespinlockimpl.h (added) * cpukit/score/inline/rtems/score/corespinlock.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/corespinlock.c (modified) * cpukit/score/src/corespinlockrelease.c (modified) * cpukit/score/src/corespinlockwait.c (modified) score: Create spinlock implementation header Move implementation ... Fri, 19 Jul 2013 13:18:08 GMT Sebastian Huber [eb448eec] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/spinlock.h (modified) * cpukit/posix/include/rtems/posix/spinlockimpl.h (moved) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/pspin.c (modified) * cpukit/posix/src/pspindestroy.c (modified) * cpukit/posix/src/pspininit.c (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspinlocktranslatereturncode.c (modified) * cpukit/posix/src/pspintrylock.c (modified) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/sapi/src/posixapi.c (modified) posix: Create spinlock implementation header Move implementation ... Fri, 19 Jul 2013 13:08:53 GMT Sebastian Huber [f17c779] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/timer.h (modified) * cpukit/posix/include/rtems/posix/timerimpl.h (moved) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/ptimer.c (modified) * cpukit/posix/src/timercreate.c (modified) * cpukit/posix/src/timerdelete.c (modified) * cpukit/posix/src/timergetoverrun.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timerinserthelper.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/timertsr.c (modified) * cpukit/sapi/src/posixapi.c (modified) * testsuites/psxtests/psxtimer01/psxtimer.c (modified) posix: Create timer implementation header Move implementation ... Fri, 19 Jul 2013 13:00:11 GMT Sebastian Huber [982e9746] * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/score/include/rtems/score/corerwlockimpl.h (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) score: Avoid direct usage of _Thread_Executing Pass the executing ... Fri, 19 Jul 2013 12:48:57 GMT Sebastian Huber [cbdabc8] * cpukit/posix/include/rtems/posix/rwlockimpl.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/corerwlock.h (modified) * cpukit/score/include/rtems/score/corerwlockimpl.h (added) * cpukit/score/inline/rtems/score/corerwlock.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/corerwlocktimeout.c (modified) score: Create rwlock implementation header Move implementation ... Fri, 19 Jul 2013 12:39:45 GMT Sebastian Huber [0e8656b4] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/rwlock.h (modified) * cpukit/posix/include/rtems/posix/rwlockimpl.h (moved) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/prwlock.c (modified) * cpukit/posix/src/prwlockdestroy.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktranslatereturncode.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/sapi/src/posixapi.c (modified) posix: Create rwlock implementation header Move implementation ... Fri, 19 Jul 2013 12:33:56 GMT Sebastian Huber [0c5317d] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libgnat/adasupp.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/pthreadimpl.h (added) * cpukit/posix/inline/rtems/posix/pthread.inl (deleted) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/canceleval.c (modified) * cpukit/posix/src/cancelrun.c (modified) * cpukit/posix/src/cleanuppop.c (modified) * cpukit/posix/src/cleanuppush.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/kill_r.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalchecksignal.c (modified) * cpukit/posix/src/psignalclearprocesssignals.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadattrinit.c (modified) * cpukit/posix/src/pthreadattrsetguardsize.c (modified) * cpukit/posix/src/pthreadattrsetinheritsched.c (modified) * cpukit/posix/src/pthreadattrsetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrsetscope.c (modified) * cpukit/posix/src/pthreadattrsetstack.c (modified) * cpukit/posix/src/pthreadattrsetstacksize.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/setcancelstate.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/testcancel.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/sapi/src/posixapi.c (modified) * testsuites/psxtests/psxstack01/init.c (modified) * testsuites/psxtests/psxstack02/init.c (modified) posix: Create pthread implementation header Move implementation ... Fri, 19 Jul 2013 12:15:59 GMT Sebastian Huber [97552c98] * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/priorityimpl.h (moved) * cpukit/posix/inline/rtems/posix/priority.inl (deleted) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrgetprioceiling.c (modified) * cpukit/posix/src/mutexattrgetprotocol.c (modified) * cpukit/posix/src/mutexattrgetpshared.c (modified) * cpukit/posix/src/mutexattrgettype.c (modified) * cpukit/posix/src/mutexattrinit.c (modified) * cpukit/posix/src/mutexattrsetprioceiling.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexattrsettype.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlock.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/mutextrylock.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/psxpriorityisvalid.c (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/sched_getprioritymax.c (modified) * cpukit/posix/src/sched_getprioritymin.c (modified) * cpukit/posix/src/sched_getscheduler.c (modified) * cpukit/posix/src/sched_setparam.c (modified) * cpukit/posix/src/sched_setscheduler.c (modified) * cpukit/posix/src/sched_yield.c (modified) * cpukit/sapi/src/posixapi.c (modified) * testsuites/psxtests/psx05/init.c (modified) posix: Create priority implementation header Move implementation ... Fri, 19 Jul 2013 12:02:47 GMT Sebastian Huber [d8dd80e] * testsuites/smptests/smp08/tasks.c (modified) smptests/smp08: Print missing newline Fri, 19 Jul 2013 14:20:49 GMT Sebastian Huber [4cb8e597] * cpukit/posix/src/condwaitsupp.c (modified) score: Obtain _Thread_Executing in proper context Fri, 19 Jul 2013 10:08:02 GMT Sebastian Huber [35210b12] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/condimpl.h (added) * cpukit/posix/inline/rtems/posix/cond.inl (deleted) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/barrierattrdestroy.c (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/condattrdestroy.c (modified) * cpukit/posix/src/condattrgetpshared.c (modified) * cpukit/posix/src/condattrinit.c (modified) * cpukit/posix/src/condattrsetpshared.c (modified) * cpukit/posix/src/condbroadcast.c (modified) * cpukit/posix/src/conddefaultattributes.c (modified) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condget.c (modified) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/condsignal.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condtimedwait.c (modified) * cpukit/posix/src/condwait.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/rwlockattrdestroy.c (modified) * cpukit/sapi/src/posixapi.c (modified) posix: Create condition variable impl header Move implementation ... Fri, 19 Jul 2013 09:18:51 GMT Sebastian Huber [a9515722] * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) cpuuse: Add SMP support Fri, 19 Jul 2013 09:18:30 GMT Sebastian Huber [7d9a426] * cpukit/libcsupport/src/newlibc_reent.c (modified) libcsupport: Include missing header file Fri, 19 Jul 2013 09:07:37 GMT Sebastian Huber [0444947e] * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/score/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/src/corebarrierwait.c (modified) score: Avoid direct usage of _Thread_Executing Pass the executing ... Fri, 19 Jul 2013 09:00:19 GMT Sebastian Huber [bb2d9f9] * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/corebarrier.h (modified) * cpukit/score/include/rtems/score/corebarrierimpl.h (added) * cpukit/score/inline/rtems/score/corebarrier.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/corebarrierwait.c (modified) score: Create barrier implementation header Move implementation ... Fri, 19 Jul 2013 08:51:44 GMT Sebastian Huber [6b4a3770] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/barrier.h (modified) * cpukit/posix/include/rtems/posix/barrierimpl.h (moved) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/pbarrier.c (modified) * cpukit/posix/src/pbarrierdestroy.c (modified) * cpukit/posix/src/pbarrierinit.c (modified) * cpukit/posix/src/pbarriertranslatereturncode.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/sapi/src/posixapi.c (modified) posix: Create barrier implementation header Move implementation ... Fri, 19 Jul 2013 08:42:39 GMT Sebastian Huber [0b32bb8] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/barrier.h (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (moved) * cpukit/rtems/preinstall.am (modified) * cpukit/rtems/src/barrier.c (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/barrierdata.c (modified) * cpukit/rtems/src/barrierdelete.c (modified) * cpukit/rtems/src/barrierident.c (modified) * cpukit/rtems/src/barrierrelease.c (modified) * cpukit/rtems/src/barriertranslatereturncode.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) rtems: Create barrier implementation header Move implementation ... Fri, 19 Jul 2013 06:51:52 GMT Sebastian Huber [e64f164] * cpukit/score/include/rtems/score/basedefs.h (modified) score: Include in basedefs.h Thu, 18 Jul 2013 14:00:54 GMT Sebastian Huber [33a4a56] * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) score: Avoid direct usage of _Thread_Executing Pass the executing ... Thu, 18 Jul 2013 13:35:23 GMT Sebastian Huber [b5d514f] * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgqallocate.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqtranslatereturncode.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (added) * cpukit/score/inline/rtems/score/coremsg.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushsupp.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) score: Create message queue implementation header Move ... Thu, 18 Jul 2013 13:12:05 GMT Sebastian Huber [972a5c5f] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (added) * cpukit/posix/inline/rtems/posix/mqueue.inl (deleted) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/mqueue.c (modified) * cpukit/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/posix/src/mqueuereceive.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesend.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mqueuetimedreceive.c (modified) * cpukit/posix/src/mqueuetimedsend.c (modified) * cpukit/posix/src/mqueuetranslatereturncode.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/sapi/src/posixapi.c (modified) posix: Create message queue implementation header Move ... Thu, 18 Jul 2013 13:05:37 GMT Sebastian Huber [993a888] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/mon-queue.c (modified) * cpukit/libmisc/shell/main_wkspaceinfo.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (added) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (deleted) * cpukit/rtems/preinstall.am (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgdata.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqallocate.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqtranslatereturncode.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/sapi/include/rtems/sptables.h (modified) * cpukit/sapi/src/rtemsapi.c (modified) * testsuites/sptests/spsize/size.c (modified) rtems: Create message queue implementation header Move ... Thu, 18 Jul 2013 12:27:30 GMT Sebastian Huber [e36f2b8] * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/src/coresemseize.c (modified) * cpukit/score/src/mpci.c (modified) score: Avoid direct usage of _Thread_Executing Pass the executing ... Thu, 18 Jul 2013 12:26:58 GMT Sebastian Huber [570045ed] * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/src/coresem.c (modified) score: Add const qualifier Thu, 18 Jul 2013 12:14:04 GMT Sebastian Huber [c4f58558] * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (added) * cpukit/score/inline/rtems/score/coresem.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coresemflush.c (modified) * cpukit/score/src/coresemseize.c (modified) * cpukit/score/src/coresemsurrender.c (modified) * cpukit/score/src/mpci.c (modified) score: Create semaphore implementation header Move implementation ... Thu, 18 Jul 2013 11:55:12 GMT Sebastian Huber [c624c0e9] * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/posix/src/semaphoretranslatereturncode.c (modified) posix: Convert to inline function Thu, 18 Jul 2013 11:50:25 GMT Sebastian Huber [9c743e8e] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/semaphoreimpl.h (added) * cpukit/posix/inline/rtems/posix/semaphore.inl (deleted) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/posixtimespecabsolutetimeout.c (modified) * cpukit/posix/src/semaphore.c (modified) * cpukit/posix/src/semaphorecreatesupp.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/semaphoretranslatereturncode.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semdestroy.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/seminit.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semtimedwait.c (modified) * cpukit/posix/src/semtrywait.c (modified) * cpukit/posix/src/semunlink.c (modified) * cpukit/posix/src/semwait.c (modified) * cpukit/sapi/src/posixapi.c (modified) posix: Create semaphore implementation header Move implementation ... Thu, 18 Jul 2013 09:53:48 GMT Sebastian Huber [05e82bd7] * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smp04/Makefile.am (deleted) * testsuites/smptests/smp04/init.c (deleted) * testsuites/smptests/smp04/smp04.doc (deleted) * testsuites/smptests/smp04/smp04.scn (deleted) * testsuites/smptests/smp04/system.h (deleted) * testsuites/smptests/smpunsupported01/init.c (modified) score: Error for non-preemptible tasks on SMP A common use case for ... Thu, 18 Jul 2013 09:39:44 GMT Sebastian Huber [79d9523] * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) rtems: Error for task variables on SMP Task variables are not ... Thu, 18 Jul 2013 09:34:29 GMT Sebastian Huber [50ccf98] * cpukit/rtems/src/taskdelete.c (modified) * testsuites/smptests/smp08/init.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) rtems: Error for task delete on SMP Task deletion is currently not ... Thu, 18 Jul 2013 09:27:39 GMT Sebastian Huber [f913c79] * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpunsupported01/Makefile.am (added) * testsuites/smptests/smpunsupported01/init.c (added) * testsuites/smptests/smpunsupported01/smpunsupported01.doc (added) * testsuites/smptests/smpunsupported01/smpunsupported01.scn (added) sapi: Add rtems_configuration_is_smp_enabled() Add a configuration ... Thu, 18 Jul 2013 07:02:53 GMT Sebastian Huber [0bbd8fdc] * cpukit/score/include/rtems/score/isr.h (modified) score: Add and use _ISR_Get_nest_level() Thu, 18 Jul 2013 09:04:23 GMT Sebastian Huber [d0a97f2] * cpukit/rtems/src/intrcatch.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/inline/rtems/score/isr.inl (deleted) * cpukit/score/preinstall.am (modified) score: Move ISR catch support functions Delete now unused file ... Thu, 18 Jul 2013 09:03:10 GMT Sebastian Huber [45b572f] * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) score: Move ISR level content to single file Mon, 22 Jul 2013 07:18:17 GMT Sebastian Huber [1a30d442] * cpukit/libmisc/stackchk/check.c (modified) libmisc: Use _Thread_Get_executing() Fri, 19 Jul 2013 15:16:58 GMT Sebastian Huber [d566f33e] * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/sync.c (modified) libcsupport: Use _Thread_Get_executing() Mon, 22 Jul 2013 07:16:58 GMT Sebastian Huber [d7ce33f1] * testsuites/libtests/stackchk/blow.c (modified) * testsuites/psxtests/psxobj01/init.c (modified) * testsuites/psxtests/psxsignal05/init.c (modified) * testsuites/sptests/sp34/changepri.c (modified) * testsuites/sptests/sp35/priinv.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical16/init.c (modified) * testsuites/sptests/spthreadq01/init.c (modified) * testsuites/tmtests/tm25/task1.c (modified) testsuites: Use _Thread_Get_executing() Thu, 18 Jul 2013 14:22:54 GMT Sebastian Huber [5f7757b] * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalchecksignal.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) posix: Use _Thread_Get_executing() Thu, 18 Jul 2013 09:03:24 GMT Sebastian Huber [3b8d2fa4] * cpukit/rtems/src/rtemsobjectsetname.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) rtems: Use _Thread_Get_executing() Thu, 18 Jul 2013 10:43:49 GMT Sebastian Huber [02f73d4] * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/userextiterate.c (modified) score: Use _Thread_Get_executing() Thu, 18 Jul 2013 13:55:46 GMT Sebastian Huber [a9127a2e] * testsuites/libtests/termios01/init.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxfatal02/testcase.h (modified) * testsuites/psxtests/psxid01/init.c (modified) * testsuites/psxtests/psxsignal01/init.c (modified) * testsuites/sptests/spfatal12/testcase.h (modified) * testsuites/support/src/test_support.c (modified) testsuites: Include missing header files Thu, 18 Jul 2013 13:33:44 GMT Sebastian Huber [f2d9fda] * cpukit/libmisc/shell/shell_script.c (modified) shell: Include missing header file Thu, 18 Jul 2013 13:33:28 GMT Sebastian Huber [ca1d84e] * cpukit/libnetworking/netinet/in_pcb.c (modified) network: Include missing header file Thu, 18 Jul 2013 12:13:24 GMT Sebastian Huber [a1b47528] * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/src/aio_read.c (modified) * cpukit/posix/src/aio_write.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) posix: Include missing header files Thu, 18 Jul 2013 12:30:17 GMT Sebastian Huber [1e4f08b4] * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/percpu.c (modified) score: Include missing header files Fri, 19 Jul 2013 08:12:13 GMT Sebastian Huber [57c88056] * testsuites/smptests/smp02/init.c (modified) * testsuites/smptests/smp03/init.c (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp06/init.c (modified) * testsuites/smptests/smp07/init.c (modified) smptests: Be successful on one processor Thu, 18 Jul 2013 08:08:05 GMT Ralf Kirchner [2f589cc] * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) bsp/gen83xx: Fix BSP options for MPC8348EAMDS Wed, 17 Jul 2013 14:14:49 GMT Sebastian Huber [e7ce41bb] * cpukit/libcsupport/src/malloc_deferred.c (modified) * cpukit/libcsupport/src/realloc.c (modified) libcsupport: Do not use _ISR_Nest_level The ... Wed, 17 Jul 2013 14:12:19 GMT Sebastian Huber [401f1b9d] * cpukit/posix/src/pthreadself.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/systemeventreceive.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskself.c (modified) rtems, posix: Use _Thread_Get_executing() Wed, 17 Jul 2013 13:53:17 GMT Sebastian Huber [95e09afa] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/src/apimutexallocate.c (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexseizeintr.c (modified) score: Avoid direct usage of _Thread_Executing Pass the executing ... Wed, 17 Jul 2013 13:20:03 GMT Sebastian Huber [ac15b07] * cpukit/score/include/rtems/score/coremuteximpl.h (modified) score: Convert to inline function Wed, 17 Jul 2013 13:05:56 GMT Sebastian Huber [9728ef3] * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/src/mutextranslatereturncode.c (modified) posix: Convert to inline function Wed, 17 Jul 2013 13:01:03 GMT Sebastian Huber [15462a6f] * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) rtems: Convert to inline functions Wed, 17 Jul 2013 12:23:14 GMT Sebastian Huber [20e239c2] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrgetprioceiling.c (modified) * cpukit/posix/src/mutexattrgetprotocol.c (modified) * cpukit/posix/src/mutexattrgetpshared.c (modified) * cpukit/posix/src/mutexattrgettype.c (modified) * cpukit/posix/src/mutexattrinit.c (modified) * cpukit/posix/src/mutexattrsetprioceiling.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexattrsettype.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexget.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlock.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/mutextrylock.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (added) * cpukit/score/inline/rtems/score/coremutex.inl (deleted) * cpukit/score/preinstall.am (modified) * cpukit/score/src/apimutexallocate.c (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexflush.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexseizeintr.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) score: Create mutex implementation header Move implementation ... Wed, 17 Jul 2013 12:34:05 GMT Sebastian Huber [f9d533a5] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/muteximpl.h (added) * cpukit/posix/inline/rtems/posix/mutex.inl (deleted) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/barrierattrdestroy.c (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/condattrdestroy.c (modified) * cpukit/posix/src/condattrgetpshared.c (modified) * cpukit/posix/src/condattrinit.c (modified) * cpukit/posix/src/condattrsetpshared.c (modified) * cpukit/posix/src/condbroadcast.c (modified) * cpukit/posix/src/conddefaultattributes.c (modified) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condget.c (modified) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/condsignal.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condtimedwait.c (modified) * cpukit/posix/src/condwait.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/posix/src/mutexattrdestroy.c (modified) * cpukit/posix/src/mutexattrgetprioceiling.c (modified) * cpukit/posix/src/mutexattrgetprotocol.c (modified) * cpukit/posix/src/mutexattrgetpshared.c (modified) * cpukit/posix/src/mutexattrgettype.c (modified) * cpukit/posix/src/mutexattrinit.c (modified) * cpukit/posix/src/mutexattrsetprioceiling.c (modified) * cpukit/posix/src/mutexattrsetprotocol.c (modified) * cpukit/posix/src/mutexattrsetpshared.c (modified) * cpukit/posix/src/mutexattrsettype.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexget.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexlock.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutextimedlock.c (modified) * cpukit/posix/src/mutextranslatereturncode.c (modified) * cpukit/posix/src/mutextrylock.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/rwlockattrdestroy.c (modified) * cpukit/sapi/src/posixapi.c (modified) posix: Create mutex implementation header Move implementation ... Wed, 17 Jul 2013 11:52:00 GMT Sebastian Huber [2bbea657] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (moved) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdata.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/sapi/include/rtems/sptables.h (modified) * cpukit/sapi/src/rtemsapi.c (modified) * testsuites/sptests/spintrcritical01/init.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical16/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/tmtests/tm26/task1.c (modified) rtems: Create semaphore implementation header Move implementation ... Thu, 18 Jul 2013 07:42:46 GMT Sebastian Huber [0dd262d3] * testsuites/libtests/gxx01/gxx01.scn (modified) * testsuites/libtests/gxx01/init.c (modified) libtests/gxx01: Avoid random memory read/write Thu, 18 Jul 2013 07:50:43 GMT Sebastian Huber [cbfe05c] * cpukit/score/src/mpci.c (modified) score: Update due to API changes Thu, 13 Jun 2013 14:05:20 GMT Sebastian Huber [f7740e97] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/src/percpu.c (modified) smp: Rename _CPU_Processor_event_receive() Rename to ... Thu, 13 Jun 2013 14:00:54 GMT Sebastian Huber [07f6e419] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/src/percpu.c (modified) smp: Rename _CPU_Processor_event_broadcast() Rename to ... Thu, 13 Jun 2013 13:41:21 GMT Sebastian Huber [ca63ae2] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/shared/smp/smp_stub.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/src/smp.c (modified) smp: Add and use _CPU_SMP_Send_interrupt() Delete ... Fri, 14 Jun 2013 12:00:38 GMT Sebastian Huber [39e51758] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/i386/shared/smp/getcpuid.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/shared/smp/getcpuid.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/getcpuid.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/smp.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/smptests/smp01/init.c (modified) * testsuites/smptests/smp01/tasks.c (modified) * testsuites/smptests/smp02/init.c (modified) * testsuites/smptests/smp02/system.h (modified) * testsuites/smptests/smp02/tasks.c (modified) * testsuites/smptests/smp03/init.c (modified) * testsuites/smptests/smp04/init.c (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp06/init.c (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smp08/init.c (modified) * testsuites/smptests/smp08/tasks.c (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smpatomic01/tasks.c (modified) * testsuites/smptests/smpatomic02/tasks.c (modified) * testsuites/smptests/smpatomic03/tasks.c (modified) * testsuites/smptests/smpatomic04/tasks.c (modified) * testsuites/smptests/smpatomic05/tasks.c (modified) * testsuites/smptests/smpatomic06/tasks.c (modified) * testsuites/smptests/smpatomic07/tasks.c (modified) * testsuites/smptests/smplock01/init.c (modified) smp: Add and use _CPU_SMP_Get_current_processor() Add and use ... Thu, 13 Jun 2013 08:34:12 GMT Sebastian Huber [a7ce0ce] * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/src/smp.c (modified) smp: Delete RTEMS_BSP_SMP_CONTEXT_SWITCH_NECESSARY The thread ... Wed, 17 Jul 2013 09:44:55 GMT Sebastian Huber [9c9b62d8] * cpukit/libcsupport/src/newlibc_reent.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/src/threaddispatch.c (modified) score: Changes due to Newlib __DYNAMIC_REENT__ Delete ... Wed, 17 Jul 2013 09:03:02 GMT Sebastian Huber [f74d9496] * cpukit/score/include/rtems/score/thread.h (modified) score: Add _Thread_Get_executing() Thu, 25 Apr 2013 08:48:16 GMT Sebastian Huber [8b721d5] * cpukit/libcsupport/src/newlibc_reent.c (modified) libcsupport: Use _reclaim_reent() A Newlib including the following ... Mon, 15 Jul 2013 15:31:14 GMT WeiY [a04182c] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/genericatomicops.h (deleted) * cpukit/score/include/rtems/score/genericcpuatomic.h (deleted) * cpukit/score/inline/rtems/score/atomic.inl (deleted) * cpukit/score/preinstall.am (modified) clean up old atomic related files Mon, 15 Jul 2013 15:31:13 GMT WeiY [2e7f5798] * cpukit/aclocal/check-atomic.m4 (modified) * cpukit/configure.ac (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/preinstall.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpatomic01/Makefile.am (modified) * testsuites/smptests/smpatomic02/Makefile.am (modified) * testsuites/smptests/smpatomic03/Makefile.am (modified) * testsuites/smptests/smpatomic04/Makefile.am (modified) * testsuites/smptests/smpatomic05/Makefile.am (modified) * testsuites/smptests/smpatomic06/Makefile.am (modified) * testsuites/smptests/smpatomic07/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spatomic01/Makefile.am (modified) * testsuites/sptests/spatomic02/Makefile.am (modified) * testsuites/sptests/spatomic03/Makefile.am (modified) * testsuites/sptests/spatomic04/Makefile.am (modified) * testsuites/sptests/spatomic05/Makefile.am (modified) * testsuites/sptests/spatomic06/Makefile.am (modified) * testsuites/sptests/spatomic07/Makefile.am (modified) stdatomic.h support check when configure Mon, 15 Jul 2013 15:31:12 GMT WeiY [5186b55] * testsuites/smptests/smpatomic01/tasks.c (modified) * testsuites/smptests/smpatomic02/tasks.c (modified) * testsuites/smptests/smpatomic03/tasks.c (modified) * testsuites/smptests/smpatomic04/tasks.c (modified) * testsuites/smptests/smpatomic05/tasks.c (modified) * testsuites/smptests/smpatomic06/tasks.c (modified) * testsuites/smptests/smpatomic07/tasks.c (modified) smpatomic test case update Mon, 15 Jul 2013 15:31:11 GMT WeiY [a3e9c228] * testsuites/sptests/spatomic01/tasks.c (modified) * testsuites/sptests/spatomic02/tasks.c (modified) * testsuites/sptests/spatomic03/tasks.c (modified) * testsuites/sptests/spatomic04/tasks.c (modified) * testsuites/sptests/spatomic05/tasks.c (modified) * testsuites/sptests/spatomic06/tasks.c (modified) * testsuites/sptests/spatomic07/tasks.c (modified) spatomic test case update Mon, 15 Jul 2013 15:31:10 GMT WeiY [d61e54c2] * cpukit/score/cpu/arm/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/avr/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/i386/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/m32r/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/mips/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/sh/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpuatomic.h (modified) * cpukit/score/cpu/v850/rtems/score/cpuatomic.h (modified) update-all-architectures-to-new-atomic-implementation Mon, 15 Jul 2013 15:31:09 GMT WeiY [34229d5] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (added) * cpukit/score/preinstall.am (modified) A generic atomic implementation for smp architectures Mon, 15 Jul 2013 15:31:08 GMT WeiY [1180099] * cpukit/score/include/rtems/score/atomic.h (modified) New atomic API definition based on C11 atomic Wed, 17 Jul 2013 06:42:35 GMT Ric Claus [39234725] * c/src/lib/libbsp/arm/shared/arm-cp15-set-ttb-entries.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) bsps/arm: Fix for top of the address space
