# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/17/24 12:19:16 Thu, 20 Jun 2013 12:33:19 GMT Sebastian Huber [c4cfc62] * c/src/lib/libbsp/powerpc/virtex/include/opbintctrl.h (modified) bsp/virtex: Use XPAR_INTC_SINGLE_BASEADDR This define is also ... Thu, 20 Jun 2013 12:32:12 GMT Sebastian Huber [dfb5805] * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) bsp/virtex: Remove unused configure macros Tue, 18 Jun 2013 14:42:25 GMT Sebastian Huber [53dc697] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Delete BSP_ask_for_reset and BSP_panic Tue, 18 Jun 2013 15:20:28 GMT Sebastian Huber [39c1534f] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/opbintctrl.h (modified) * c/src/lib/libbsp/powerpc/virtex/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c (modified) * c/src/lib/libbsp/powerpc/virtex/opbintctrl/opbintctrl.c (deleted) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Use generic interrupt support Tue, 18 Jun 2013 14:44:40 GMT Sebastian Huber [894e93f] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Fix header includes Tue, 18 Jun 2013 14:39:24 GMT Sebastian Huber [bee7612e] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex/timer/timer-config.c (added) bsp/virtex: Move timer config to new file Tue, 18 Jun 2013 14:27:42 GMT Sebastian Huber [48ab8465] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Do not use PPC403 TTY driver Tue, 18 Jun 2013 14:26:25 GMT Sebastian Huber [ad094f4] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Fix warnings Tue, 18 Jun 2013 14:25:53 GMT Sebastian Huber [b45397fb] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Delete bsp_XAssertHandler() Tue, 18 Jun 2013 14:24:10 GMT Sebastian Huber [ff538bbf] * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) bsp/virtex: Delete unused variables Tue, 18 Jun 2013 14:12:56 GMT Sebastian Huber [0ba2736] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/README (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg (modified) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/start/start.S (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex/startup/linkcmds (deleted) * c/src/lib/libbsp/powerpc/virtex/startup/linkcmds.in (added) bsp/virtex: Replace low-level BSP start code Use linkcmds.base. ... Tue, 18 Jun 2013 13:19:19 GMT Sebastian Huber [546c1056] * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/bsp_specs (modified) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (modified) * c/src/lib/libbsp/powerpc/virtex/start/start.S (moved) bsp/virtex: Rename file dlentry.S in start.S Use default bsp_specs file. Fri, 21 Jun 2013 15:16:37 GMT Sebastian Huber [509e0f3f] * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) bsps/powerpc: Add PPC405 support for shared clock Fri, 21 Jun 2013 14:19:46 GMT Sebastian Huber [7d0e88f2] * c/src/lib/libcpu/powerpc/ppc403/clock/clock_4xx.c (deleted) bsps/powerpc: Delete clock_4xx.c Fri, 21 Jun 2013 13:10:48 GMT Sebastian Huber [27b207a8] * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/shared/bspreset_fatal.c (deleted) bsps: Delete bspreset_fatal.c Use bspreset_loop.c instead. This ... Fri, 21 Jun 2013 07:18:01 GMT Chris Johns [1ebffa89] * cpukit/score/cpu/arm/armv4-exception-default.S (modified) arm: Fix default exception prologues Fri, 21 Jun 2013 07:16:19 GMT Sebastian Huber [4f1da72] * cpukit/libcsupport/src/resource_snapshot.c (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/src/heapgreedy.c (modified) score: _Heap_Protection_free_all_delayed_blocks() Add and use ... Tue, 18 Jun 2013 12:14:43 GMT Sebastian Huber [9165a5b0] * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) IMFS: Fix reference count for debug enabled Thu, 20 Jun 2013 09:03:45 GMT Sebastian Huber [f97f46ce] * c/src/libchip/serial/ns16550.c (modified) libchip/serial: Fix warning Tue, 18 Jun 2013 15:47:41 GMT Sebastian Huber [c9db7f9] * c/src/lib/libbsp/shared/console.c (modified) bsps: Use CONSOLE_DEVICE_NAME Tue, 18 Jun 2013 15:45:50 GMT Sebastian Huber [a4bc725e] * c/src/lib/libbsp/shared/console.c (modified) bsps: Remove debug output in shared console driver Thu, 20 Jun 2013 10:00:29 GMT Sebastian Huber [37220fac] * c/src/lib/libbsp/shared/console_select.c (modified) bsps: Do not use printk() in shared console driver Thu, 20 Jun 2013 09:57:34 GMT Sebastian Huber [6307b1a] * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shared/console_select.c (modified) * c/src/lib/libbsp/shared/include/generic-fatal.h (modified) bsps: Add fatal errors for shared console driver Thu, 20 Jun 2013 09:44:04 GMT Sebastian Huber [ade27c6] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c (modified) * c/src/lib/libbsp/preinstall.am (modified) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/shared/include/generic-fatal.h (added) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) bsps: Move bsp_generic_fatal_code to new file Add bsp_generic_fatal(). Thu, 20 Jun 2013 09:17:23 GMT Sebastian Huber [5f91272] * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_address.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_prologue.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) bsps/powerpc: Delete bsp_exceptions_in_RAM Delete ... Thu, 20 Jun 2013 15:52:16 GMT Joel Sherrill [6520aef1] * cpukit/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) sparc in_cksum: Use __sparc__ which is available in -ansi mode Thu, 20 Jun 2013 07:48:27 GMT Ric Claus [cddb8f4] * c/src/lib/libbsp/arm/shared/include/arm-gic.h (modified) bsps/arm: Fix some GIC functions Wed, 19 Jun 2013 09:20:06 GMT Sebastian Huber [9a037da9] * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Set vector base address if necessary Sun, 16 Jun 2013 13:40:03 GMT Jiri Gaisler [45fecbb6] * c/src/libchip/network/greth.c (modified) greth: do not advertise 1000M capability if MAC does not support it. Sun, 16 Jun 2013 13:28:20 GMT Jiri Gaisler [1bdc6d1] * c/src/libchip/network/greth.c (modified) greth: prefer full duplex if available Sat, 15 Jun 2013 22:13:41 GMT Jiri Gaisler [1f4ee30] * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum_sparc.h (added) Added in_cksum_sparc.h to optimize IP checksum calculations for SPARC. Wed, 19 Jun 2013 10:57:54 GMT Sebastian Huber [cb6b9ba] * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) bsp/xilinx-zynq: Use magic UART baud divisor Use a baud divisor ... Wed, 19 Jun 2013 10:57:26 GMT Sebastian Huber [3f6a823] * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) bsp/xilinx-zynq: Do not start transmitter break Tue, 18 Jun 2013 11:37:16 GMT Ralf Corsépius [67f89f2] * config.guess (modified) * depcomp (modified) Update from automake-1.13.3. Tue, 18 Jun 2013 07:18:21 GMT Sebastian Huber [49bc9f81] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsp/xilinx-zynq: Use second UART for console This is in now line ... Mon, 17 Jun 2013 08:21:48 GMT Sebastian Huber [010e4058] * testsuites/smptests/smpschedule01/init.c (modified) smptests/smpschedule01: Update due to API change Mon, 17 Jun 2013 08:12:26 GMT Sebastian Huber [c4a236a] * testsuites/sptests/sp02/system.h (modified) Revert "sptests/sp02: Fix maximum task count" This reverts commit ... Mon, 17 Jun 2013 07:57:42 GMT Sebastian Huber [cf46db85] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/shared/console_select_simple.c (added) bsps: Provide simple console selection Mon, 17 Jun 2013 07:57:08 GMT Sebastian Huber [9f868a16] * c/src/lib/libbsp/shared/console_private.h (modified) bsps: Add missing include Fri, 14 Jun 2013 13:30:37 GMT Sebastian Huber [961669d] * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpusmplock.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/inline/rtems/score/scheduler.inl (modified) documentation: Fix Doxygen comments Tue, 11 Jun 2013 08:00:25 GMT Sebastian Huber [8b222be] * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpschedule01/Makefile.am (added) * testsuites/smptests/smpschedule01/init.c (added) * testsuites/smptests/smpschedule01/smpschedule01.doc (added) * testsuites/smptests/smpschedule01/smpschedule01.scn (added) smptests/smpschedule01: New test Thu, 06 Jun 2013 13:41:00 GMT Sebastian Huber [a936aa49] * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/schedulersimplesmp.c (added) * cpukit/score/src/schedulersimplesmpblock.c (deleted) * cpukit/score/src/schedulersimplesmpschedule.c (deleted) * cpukit/score/src/schedulersimplesmpunblock.c (deleted) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) scheduler: New simple SMP scheduler implementation The new Simple ... Wed, 12 Jun 2013 09:39:49 GMT Sebastian Huber [8f420927] * cpukit/score/inline/rtems/score/schedulersimple.inl (modified) * cpukit/score/src/schedulersimplereadyqueueenqueue.c (modified) * cpukit/score/src/schedulersimplereadyqueueenqueuefirst.c (modified) scheduler: Simplify simple scheduler Add and use ... Thu, 06 Jun 2013 13:32:22 GMT Sebastian Huber [a344308] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/src/schedulerdefaulttick.c (moved) * cpukit/score/src/schedulersimplesmptick.c (deleted) scheduler: Add and use _Scheduler_default_Tick() Delete ... Mon, 10 Jun 2013 14:15:46 GMT Sebastian Huber [6eba7c85] * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/sched_yield.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/inline/rtems/score/scheduler.inl (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerprioritytick.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) scheduler: Specify thread of yield operation The yielding thread of ... Thu, 06 Jun 2013 13:28:41 GMT Sebastian Huber [1ccb64e1] * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/inline/rtems/score/scheduler.inl (modified) * cpukit/score/src/schedulerdefaultstartidle.c (added) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadstart.c (modified) scheduler: Add start idle thread operation Add and use ... Wed, 12 Jun 2013 15:06:51 GMT Sebastian Huber [477259c] * cpukit/score/src/threadcreateidle.c (modified) score: Simplify _Thread_Create_idle() Fri, 14 Jun 2013 12:26:34 GMT Sebastian Huber [edde99b] * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/libmisc/cpuuse/cpuusagereport.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/smp.h (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/smptests/smp01/init.c (modified) * testsuites/smptests/smp02/init.c (modified) * testsuites/smptests/smp03/init.c (modified) * testsuites/smptests/smp04/init.c (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp06/init.c (modified) * testsuites/smptests/smp08/init.c (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpatomic02/init.c (modified) * testsuites/smptests/smpatomic03/init.c (modified) * testsuites/smptests/smpatomic04/init.c (modified) * testsuites/smptests/smpatomic05/init.c (modified) * testsuites/smptests/smpatomic06/init.c (modified) * testsuites/smptests/smpatomic07/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) * testsuites/sptests/spsize/size.c (modified) score: Rename rtems_smp_get_number_of_processors() Rename in ... Wed, 12 Jun 2013 08:08:58 GMT Sebastian Huber [5c78940d] * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) score: Add and use _Thread_Dispatch_if_necessary() Delete ... Wed, 12 Jun 2013 07:25:39 GMT Sebastian Huber [49cdf40] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * cpukit/libcsupport/src/realloc.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/pheapwalk.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/support/include/tmacros.h (modified) score: Add and use _Thread_Dispatch_is_enabled() Delete ... Wed, 12 Jun 2013 09:29:12 GMT Sebastian Huber [ec978d9] * cpukit/score/inline/rtems/score/chain.inl (modified) * testsuites/sptests/spchain/init.c (modified) * testsuites/sptests/spchain/spchain.doc (modified) * testsuites/sptests/spchain/spchain.scn (modified) score: Add _Chain_Insert_ordered_unprotected() Tue, 11 Jun 2013 15:09:02 GMT Sebastian Huber [7a34ca37] * cpukit/rtems/src/taskmode.c (modified) rtems: Simplify rtems_task_mode() Fri, 14 Jun 2013 11:04:43 GMT Sebastian Huber [6f8adb0] * testsuites/sptests/sp02/system.h (modified) sptests/sp02: Fix maximum task count Sun, 09 Jun 2013 02:13:00 GMT Cynthia Rempel [873859a4] * doc/user/conf.t (modified) Make the default values easier for the configuration GUI to parse Wed, 12 Jun 2013 13:11:57 GMT Sebastian Huber [aabfcd0] * cpukit/score/src/threaddispatchdisablelevel.c (modified) smp: Fix _Thread_Dispatch_decrement_disable_level We must obtain ... Wed, 12 Jun 2013 07:16:30 GMT Sebastian Huber [df244cfc] * cpukit/score/src/threaddispatchdisablelevel.c (modified) smp: Protect decrement operation Tue, 11 Jun 2013 07:29:45 GMT Sebastian Huber [a8ef3bf0] * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/src/smp.c (modified) smp: Add and use _Per_CPU_Lock_acquire() Add and use ... Tue, 11 Jun 2013 07:26:30 GMT Sebastian Huber [f70526a7] * cpukit/score/include/rtems/score/isr.h (modified) score: Avoid cyclic include dependency Tue, 11 Jun 2013 07:23:35 GMT Sebastian Huber [1270440] * cpukit/score/include/rtems/score/threaddispatch.h (modified) score: Add missing include Mon, 10 Jun 2013 12:11:07 GMT Sebastian Huber [15f3a91] * c/src/libchip/serial/ns16550.c (modified) libchip: Use Termios API change for NS16550 This avoids a race ... Mon, 10 Jun 2013 12:07:13 GMT Sebastian Huber [6896ca2] * c/src/libchip/serial/ns16550.c (modified) libchip: Delete superfluous assignments Mon, 10 Jun 2013 12:22:28 GMT Sebastian Huber [65483f8] * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) termios: SMP support Mon, 10 Jun 2013 12:36:44 GMT Sebastian Huber [fed92f5f] * cpukit/libcsupport/src/termios.c (modified) * doc/bsp_howto/console.t (modified) termios: Notify driver about inactive transmit Returning this state ... Mon, 10 Jun 2013 12:24:52 GMT Sebastian Huber [7338299c] * cpukit/libcsupport/src/termios.c (modified) termios: Expand critical section Use interrupt disable/enable to ... Mon, 10 Jun 2013 12:18:57 GMT Sebastian Huber [58cde54] * cpukit/libcsupport/src/termios.c (modified) termios: Move wake up writer task action Mon, 10 Jun 2013 12:10:49 GMT Sebastian Huber [2a8713a] * cpukit/libcsupport/src/termios.c (modified) termios: Avoid second return path Mon, 10 Jun 2013 09:14:35 GMT Sebastian Huber [c7bc6d4] * cpukit/rtems/include/rtems/rtems/intr.h (modified) * doc/user/intr.t (modified) * testsuites/sptests/sp37/init.c (modified) rtems: Add interrupt locks Interrupt locks are low-level lock to ... Mon, 10 Jun 2013 09:12:39 GMT Sebastian Huber [3ccce23] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/preinstall.am (modified) score: Always provide Mon, 10 Jun 2013 08:10:43 GMT Sebastian Huber [aec0e195] * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-smp.m4 (modified) * c/src/aclocal/enable-multiprocessing.m4 (modified) * c/src/aclocal/enable-smp.m4 (modified) * cpukit/aclocal/enable-multiprocessing.m4 (modified) * cpukit/aclocal/enable-smp.m4 (modified) configure: Documentation Fri, 07 Jun 2013 09:50:37 GMT Sebastian Huber [18e2fbe7] * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (modified) smp: Fix PowerPC context switch Thu, 06 Jun 2013 13:42:47 GMT Sebastian Huber [7cf2ec6f] * cpukit/score/src/smp.c (modified) smp: Set state PER_CPU_STATE_UP on main processor Wed, 05 Jun 2013 09:48:57 GMT Sebastian Huber [2d2352b] * cpukit/libfs/src/pipe/fifo.c (modified) * cpukit/posix/src/canceleval.c (modified) * cpukit/posix/src/conddestroy.c (modified) * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/keydelete.c (modified) * cpukit/posix/src/keygetspecific.c (modified) * cpukit/posix/src/keysetspecific.c (modified) * cpukit/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueuegetattr.c (modified) * cpukit/posix/src/mqueuenotify.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mqueuesetattr.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexinit.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/pbarrierdestroy.c (modified) * cpukit/posix/src/pbarrierwait.c (modified) * cpukit/posix/src/prwlockdestroy.c (modified) * cpukit/posix/src/prwlockrdlock.c (modified) * cpukit/posix/src/prwlocktimedrdlock.c (modified) * cpukit/posix/src/prwlocktimedwrlock.c (modified) * cpukit/posix/src/prwlocktryrdlock.c (modified) * cpukit/posix/src/prwlocktrywrlock.c (modified) * cpukit/posix/src/prwlockunlock.c (modified) * cpukit/posix/src/prwlockwrlock.c (modified) * cpukit/posix/src/pspindestroy.c (modified) * cpukit/posix/src/pspinlock.c (modified) * cpukit/posix/src/pspintrylock.c (modified) * cpukit/posix/src/pspinunlock.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semdestroy.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/timercreate.c (modified) * cpukit/posix/src/timerdelete.c (modified) * cpukit/posix/src/timergetoverrun.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/rtems/src/barrierdelete.c (modified) * cpukit/rtems/src/barrierrelease.c (modified) * cpukit/rtems/src/barrierwait.c (modified) * cpukit/rtems/src/dpmemdelete.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventtimeout.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemongetstatistics.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemonresetstatistics.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/rtemsobjectsetname.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timergetinfo.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/sapi/src/extensiondelete.c (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/src/corerwlocktimeout.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/threaddelayended.c (modified) * cpukit/score/src/threadqtimeout.c (modified) score: Add and use _Objects_Put() Add and use ... Wed, 05 Jun 2013 09:48:28 GMT Sebastian Huber [54e9216] * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/src/objectgetisr.c (modified) score: Add _Objects_Put_for_get_isr_disable() Provide SMP support. ... Wed, 05 Jun 2013 08:34:05 GMT Sebastian Huber [c398c66] * cpukit/score/src/objectgetisr.c (modified) score: Align _Objects_Get_isr_disable() Align ISR disable/enable ... Wed, 05 Jun 2013 10:08:23 GMT Sebastian Huber [4fc370e] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (added) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/inline/rtems/score/coresem.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/corerwlocktimeout.c (modified) * cpukit/score/src/corespinlockwait.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/isrsmp.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threaddelayended.c (modified) * cpukit/score/src/threaddisabledispatch.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadqtimeout.c (modified) score: Move thread dispatch content to new file Move thread ... Wed, 05 Jun 2013 15:13:14 GMT Sebastian Huber [4f5baff] * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/src/coremutexseizeintr.c (modified) score: Simplify _CORE_mutex_Seize_interrupt_try* Wed, 05 Jun 2013 09:39:31 GMT Sebastian Huber [dcb4daf8] * cpukit/rtems/src/semobtain.c (modified) * cpukit/score/inline/rtems/score/coresem.inl (modified) score: Simplify _CORE_semaphore_Seize_isr_disable Wed, 05 Jun 2013 10:00:02 GMT Sebastian Huber [17ce103] * cpukit/score/src/threadcreateidle.c (modified) score: Simplify _Thread_Create_idle_helper() The ... Wed, 05 Jun 2013 12:09:38 GMT Sebastian Huber [62da44e] * cpukit/rtems/src/eventtimeout.c (modified) rtems: Move unnest dispatch after ISR enable This prevents a lock ... Wed, 05 Jun 2013 12:07:32 GMT Sebastian Huber [2f49cfdf] * cpukit/rtems/src/systemeventsend.c (modified) rtems: Fix system event send for remote threads Thu, 06 Jun 2013 10:07:50 GMT Sebastian Huber [9bfd7ff] * cpukit/libfs/src/dosfs/dosfs.h (modified) dosfs: Documentation Fri, 07 Jun 2013 14:26:10 GMT Sebastian Huber [1f3ce60] * cpukit/libcsupport/src/termios.c (modified) termios: Fix warning Tue, 04 Jun 2013 13:51:35 GMT Sebastian Huber [36ae561] * cpukit/libfs/src/nfsclient/src/librtemsNfs.h (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) nfsclient: Add rpcSetXIDs() Tue, 04 Jun 2013 13:43:39 GMT Sebastian Huber [a2854fd] * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.h (modified) nfsclient: Fix warnings Tue, 04 Jun 2013 13:34:49 GMT Sebastian Huber [442db915] * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) nfsclient: Delete superfluous mask operation Tue, 04 Jun 2013 12:57:04 GMT Sebastian Huber [c295e09] * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) nfsclient: Delete superfluous assignment Tue, 04 Jun 2013 11:56:19 GMT Sebastian Huber [cffa5b7] * cpukit/libblock/src/media.c (modified) libblock: Use UTF-8 converter in media manager Fri, 31 May 2013 08:49:59 GMT Ralf Kirchner [27170bae] * cpukit/libfs/src/dosfs/dosfs.h (modified) dosfs: Documentation Fri, 22 Mar 2013 14:14:11 GMT Ralf Kirchner [581c9982] * testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h (added) * testsuites/fstests/fsdosfsname01/image_bin_le_singlebyte.h (added) * testsuites/fstests/fsdosfsname01/init.c (modified) fsdsosfsname01: Ensure endian correctness Tue, 26 Feb 2013 14:58:42 GMT Ralf Kirchner [e148397] * testsuites/fstests/fsdosfsname01/create_files.cs (added) * testsuites/fstests/fsdosfsname01/create_image.sh (added) * testsuites/fstests/fsdosfsname01/files.h (added) * testsuites/fstests/fsdosfsname01/fsdosfsname01.doc (modified) * testsuites/fstests/fsdosfsname01/image.h (added) * testsuites/fstests/fsdosfsname01/init.c (modified) fsdosfsname01: Add compatibility tests Test handling of file names ... Tue, 26 Feb 2013 14:18:55 GMT Ralf Kirchner [52f3aa0] * testsuites/fstests/fsdosfsname01/fsdosfsname01.doc (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) fsdosfsname01: Add multibyte tests Test handling of file names and ... Thu, 23 May 2013 13:48:54 GMT Ralf Kirchner [83a4cbb] * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/msdos_conv_utf8.c (added) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: UTF-8 Support: Multibyte conversions Add optional conversion ... Tue, 26 Feb 2013 12:25:46 GMT Ralf Kirchner [2ee8b15] * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/utf8proc01/Makefile.am (added) * testsuites/libtests/utf8proc01/init.c (added) * testsuites/libtests/utf8proc01/utf8proc01.doc (added) * testsuites/libtests/utf8proc01/utf8proc01.scn (added) libtests: Add new test: utf8proc01 utf8proc is a library for ... Tue, 26 Feb 2013 11:00:34 GMT Ralf Kirchner [46b7f921] * cpukit/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/utf8proc/LICENSE (added) * cpukit/libmisc/utf8proc/README (added) * cpukit/libmisc/utf8proc/utf8proc.c (added) * cpukit/libmisc/utf8proc/utf8proc.h (added) * cpukit/libmisc/utf8proc/utf8proc_data.c (added) * cpukit/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) libmisc: Add utf8proc-v1.1.5 utf8proc is a small library for ... Tue, 26 Feb 2013 10:18:32 GMT Ralf Kirchner [ccd212e] * testsuites/fstests/Makefile.am (modified) * testsuites/fstests/configure.ac (modified) * testsuites/fstests/fsdosfsname01/Makefile.am (added) * testsuites/fstests/fsdosfsname01/fsdosfsname01.doc (added) * testsuites/fstests/fsdosfsname01/fsdosfsname01.scn (added) * testsuites/fstests/fsdosfsname01/init.c (added) fsdosfsname01: New test Test handling of file names and directory ... Wed, 22 May 2013 10:16:18 GMT Ralf Kirchner [d2e0bb3] * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libfs/src/dosfs/msdos.h (modified) * cpukit/libfs/src/dosfs/msdos_conv.c (modified) * cpukit/libfs/src/dosfs/msdos_conv_default.c (added) * cpukit/libfs/src/dosfs/msdos_create.c (modified) * cpukit/libfs/src/dosfs/msdos_dir.c (modified) * cpukit/libfs/src/dosfs/msdos_fsunmount.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/dosfs/msdos_initsupp.c (modified) * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: UTF-8 Support: UI, backwards compatibility User interface ... Mon, 03 Jun 2013 08:03:44 GMT Sebastian Huber [8bed603] * c/src/lib/libbsp/arm/lm3s69xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lm3s69xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstart.c (modified) bsp/lm3s69xx: Typos Mon, 03 Jun 2013 08:03:10 GMT Sebastian Huber [94c17af] * c/src/lib/libbsp/powerpc/qoriq/start/start.S (modified) bsp/qoriq: Add missing #ifdef RTEMS_SMP Fri, 31 May 2013 11:59:47 GMT Sebastian Huber [db42c079] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/README (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu_smp.cfg (added) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu (moved) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu_smp (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (added) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (added) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu (moved) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp (added) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add SMP support Fri, 31 May 2013 11:59:34 GMT Sebastian Huber [f2f211c5] * aclocal/enable-smp.m4 (modified) * c/src/aclocal/enable-smp.m4 (modified) * cpukit/aclocal/enable-smp.m4 (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/preinstall.am (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/rtems/score/cpusmplock.h (added) smp: Add ARM support
