# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/23/24 19:22:07 Tue, 16 Feb 2021 06:48:39 GMT Sebastian Huber [a52e5d9] * cpukit/include/rtems/rtems/asrdata.h (modified) * cpukit/rtems/src/signalcatch.c (modified) rtems: Remove unused ASR_Information::nest_level Update #4244. Tue, 16 Feb 2021 06:47:53 GMT Sebastian Huber [9d5d73b] * cpukit/include/rtems/rtems/modesimpl.h (modified) rtems: Remove unused _Modes_Change() Update #4244. Tue, 16 Feb 2021 06:47:20 GMT Sebastian Huber [600360d] * cpukit/include/rtems/rtems/modesimpl.h (modified) rtems: Remove unused _Modes_Mask_changed() Update #4244. Wed, 17 Feb 2021 08:02:31 GMT Sebastian Huber [f9a59164] * cpukit/include/rtems/score/threadimpl.h (modified) score: Add _Thread_Append_post_switch_action() Update #4244. Wed, 17 Feb 2021 07:05:37 GMT Sebastian Huber [fea848b] * cpukit/include/rtems/score/thread.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/score/src/threaddispatch.c (modified) score: Change thread action locking Require that the corresponding ... Mon, 15 Feb 2021 13:02:49 GMT Sebastian Huber [3e7d658] * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-1.yml (modified) * testsuites/validation/tc-signal-catch.c (added) * testsuites/validation/tc-signal-send.c (added) validation: Add signal manager tests Update #4244. Mon, 15 Feb 2021 08:14:41 GMT Sebastian Huber [f38c0de4] * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-1.yml (added) * testsuites/validation/ts-default.h (modified) * testsuites/validation/ts-validation-0.c (modified) * testsuites/validation/ts-validation-1.c (added) validation: Add Validation1 test suite Update #4244. Tue, 16 Feb 2021 22:39:30 GMT Ryan Long [fac1ff1] * bsps/shared/grlib/spw/grspw_pkt.c (modified) grspw_pkt.c: Fix Dereference before null check (CID #1399846) CID ... Tue, 16 Feb 2021 22:15:01 GMT Ryan Long [1fd56a96] * bsps/shared/grlib/tmtc/grtc.c (modified) grtc.c: Fix Dereference before null check (CID #1399840) CID ... Tue, 16 Feb 2021 21:41:25 GMT Ryan Long [4edcdf43] * bsps/shared/grlib/1553/b1553rt.c (modified) b1553rt.c: Fix Deference before null check (CID #1399830) CID ... Tue, 16 Feb 2021 21:20:04 GMT Ryan Long [eff3d7c] * bsps/shared/grlib/1553/b1553brm.c (modified) b1553brm.c: Fix Dereference before null check (CID #1399829) CID ... Wed, 24 Jun 2020 05:10:25 GMT Sebastian Huber [8b1b9872] * cpukit/include/rtems/rtems/asr.h (modified) * cpukit/include/rtems/rtems/signal.h (modified) rtems: Generate Change license to ... Wed, 10 Feb 2021 05:43:39 GMT Sebastian Huber [be603721] * cpukit/include/rtems/score/basedefs.h (modified) basedefs: Add RTEMS_ALIGNOF() Thu, 18 Feb 2021 14:35:13 GMT Ryan Long [fa25b73] * cpukit/libmisc/shell/shell.c (modified) shell.c: Fix Dereference before null check (CID #1467420) CID ... Mon, 22 Jun 2020 05:09:23 GMT Sebastian Huber [407e351] * cpukit/include/rtems/rtems/sem.h (modified) rtems: Generate Change license to BSD-2-Clause ... Mon, 22 Jun 2020 07:06:51 GMT Sebastian Huber [2768280] * cpukit/include/rtems/rtems/clock.h (modified) rtems: Generate Change license to ... Mon, 22 Jun 2020 06:39:29 GMT Sebastian Huber [0c4c035] * cpukit/include/rtems/rtems/barrier.h (modified) rtems: Generate Change license to ... Mon, 15 Feb 2021 12:57:37 GMT Sebastian Huber [97825da] * cpukit/include/rtems/rtems/object.h (modified) rtems: Clarify object services documentation Unify the wording ... Mon, 15 Feb 2021 12:57:37 GMT Sebastian Huber [7a1828ac] * cpukit/include/rtems/io.h (modified) rtems: Clarify IO manager documentation Unify the wording across ... Wed, 10 Feb 2021 05:44:12 GMT Sebastian Huber [bf3b9f45] * cpukit/include/rtems/rtems/part.h (modified) rtems: Clarify partition manager documentation Unify the wording ... Wed, 27 Jan 2021 05:10:16 GMT Sebastian Huber [f9dc44a] * cpukit/include/rtems/rtems/timer.h (modified) rtems: Clarify timer manager documentation Unify the wording across ... Wed, 27 Jan 2021 05:10:15 GMT Sebastian Huber [2730599c] * cpukit/include/rtems/rtems/event.h (modified) rtems: Clarify event manager documentation Unify the wording across ... Mon, 15 Feb 2021 22:27:14 GMT Chris Johns [026eb3db] * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) powerpc/motorola_powerpc: Add cache coherent memory to the allocator ... Mon, 15 Feb 2021 22:04:45 GMT Chris Johns [23aad64] * bsps/powerpc/motorola_powerpc/include/bsp.h (modified) powerpc/motorola_powerpc: Enable bus PCI support in LibBSD Updates #4245 Mon, 15 Feb 2021 22:01:57 GMT Chris Johns [6e3c6e04] * bsps/powerpc/include/libcpu/io.h (modified) powerpc/io: Make [out/in] le and be calls conditional - These calls ... Mon, 15 Feb 2021 22:01:32 GMT Chris Johns [85df127] * bsps/powerpc/shared/irq/i8259.c (modified) powerpc/shared: Fix warnings in i8259 PIC code. Sat, 13 Feb 2021 01:25:07 GMT Chris Johns [53abbbd0] * bsps/powerpc/shared/vme/bspVmeDmaList.c (modified) * bsps/powerpc/shared/vme/vmeTsi148.c (modified) * bsps/powerpc/shared/vme/vmeUniverse.c (modified) powerpc/shared: Fix warnings Sat, 13 Feb 2021 01:23:21 GMT Chris Johns [86f031d4] * bsps/powerpc/motorola_powerpc/include/tm27.h (modified) powerpc/motorola_powerpc: Fix tm27 warnings Sat, 13 Feb 2021 01:22:07 GMT Chris Johns [b5aef78] * cpukit/score/src/threadqops.c (modified) score: Fix warning in thread queue ops Fri, 12 Feb 2021 19:35:40 GMT Chris Johns [e1676c1] * bsps/powerpc/include/bsp/irq_supp.h (modified) * bsps/powerpc/motorola_powerpc/include/bsp/irq.h (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/shared/irq/i8259.c (modified) * bsps/powerpc/shared/irq/irq_init.c (modified) * bsps/powerpc/shared/irq/openpic_i8259_irq.c (modified) * bsps/powerpc/shared/irq/ppc-irq-generic.c (added) * spec/build/bsps/powerpc/motorola_powerpc/grp.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/obj.yml (modified) Update motorola_power to irq-generic interrupt management - Add ... Fri, 12 Feb 2021 18:50:36 GMT Ryan Long [f65d3384] * cpukit/libdebugger/rtems-debugger-threads.c (modified) rtems-debugger-threads.c: Fix three Dereference before null check ... Fri, 12 Feb 2021 18:43:43 GMT Ryan Long [3f4cdd8] * cpukit/libdebugger/rtems-debugger-target.c (modified) rtems-debugger-target.c: Fix Dereference before null check (CID ... Fri, 12 Feb 2021 20:38:23 GMT Ryan Long [14f5a05] * cpukit/libcsupport/src/consolesimpletask.c (modified) consolesimpletask.c: Fix Two Unchecked Return Values (CID #1437625 ... Fri, 12 Feb 2021 18:39:54 GMT Ryan Long [cc273ec1] * cpukit/include/rtems/score/assert.h (modified) Add macros to assert status and use it These macros are to be used ... Fri, 12 Feb 2021 20:09:38 GMT Chris Johns [426154f] * cpukit/rtems/src/workspacegreedy.c (modified) cputkit/rtems: Remove warning Tue, 09 Feb 2021 01:48:07 GMT Chris Johns [03dff201] * cpukit/Makefile.am (modified) * cpukit/include/rtems/malloc.h (modified) * cpukit/libcsupport/src/rtems_heap_greedy.c (modified) * cpukit/libcsupport/src/rtems_heap_sbrk_greedy.c (added) * cpukit/rtems/src/workspacegreedy.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) libcsupport: Add sbrk greedy support to consume all sbrk memory - ... Tue, 09 Feb 2021 07:17:21 GMT Sebastian Huber [570992dc] * bsps/riscv/riscv/console/console-config.c (modified) bsp/riscv: Re-license to BSD-2-Clause Change license to ... Mon, 14 Dec 2020 08:41:56 GMT Sebastian Huber [286ff586] * cpukit/include/rtems/score/basedefs.h (modified) basedefs: Add stringification of argument lists Change ... Sat, 06 Feb 2021 17:40:12 GMT G S Niteesh Babu [8b32f1d] * bsps/shared/ofw/ofw.c (modified) bsps/shared/ofw: Bug fixes Fixed bugs in rtems_ofw_get_prop, ... Sat, 06 Feb 2021 17:40:11 GMT G S Niteesh Babu [6da50db] * bsps/shared/ofw/ofw.c (modified) bsps/shared/ofw: Make rtems_ofw_get_effective_phandle iterative ... Sat, 06 Feb 2021 17:40:10 GMT G S Niteesh Babu [066687c4] * bsps/shared/ofw/ofw.c (modified) bsps/shared/ofw: Use strlcpy instead of strncpy Changed ... Sat, 06 Feb 2021 17:40:09 GMT G S Niteesh Babu [c4985b77] * bsps/shared/ofw/ofw.c (modified) bsps/shared/ofw: Fix coverity reported defects Fixed use after free ... Fri, 05 Feb 2021 09:15:48 GMT Sebastian Huber [fafc923] * testsuites/validation/tc-message-construct-errors.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) validation: Tweak construct error tests Unify the state names ... Thu, 04 Feb 2021 12:35:27 GMT Sebastian Huber [e59efd8] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-barrier-create.c (added) * testsuites/validation/tc-barrier-delete.c (added) * testsuites/validation/tc-barrier-release.c (added) * testsuites/validation/tc-barrier-wait.c (added) validation: Tests for barrier manager Fri, 05 Feb 2021 15:05:20 GMT Sebastian Huber [788fa86] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-rtems-objs.c (modified) libtest: Add T_get_thread_timer_state() Wed, 03 Feb 2021 16:21:23 GMT Sebastian Huber [c9ceff9] * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-object.c (added) validation: Add tests for rtems_build_name() Mon, 08 Feb 2021 06:27:34 GMT Chris Johns [7ca3b28] * cpukit/libcsupport/src/rtems_heap_greedy.c (modified) libcsupport: Have greedy allocations use consume extended memory - ... Mon, 25 Jan 2021 01:03:06 GMT Chris Johns [822cad89] * cpukit/include/rtems/libio.h (modified) * cpukit/libcsupport/src/open.c (modified) libcsupport: Add no_regular_file_mknod as a mount option to the mount ... Wed, 14 Oct 2020 06:14:21 GMT Chris Johns [ee14fdf] * bsps/powerpc/motorola_powerpc/bootloader/misc.c (modified) bsp/motorola_powerp: Print RTEMS_VERSION from the bootloader Sat, 06 Feb 2021 20:03:21 GMT Chris Johns [450e238] * bsps/powerpc/shared/irq/irq_init.c (modified) * bsps/powerpc/shared/irq/openpic_i8259_irq.c (modified) powerpc/shared: ISA bus bridge fails to enable the openpic irq - ... Fri, 05 Feb 2021 13:35:56 GMT Sebastian Huber [96ea09ac] * cpukit/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/src/corebarrierrelease.c (modified) * cpukit/score/src/corebarrierwait.c (modified) score: Add barrier thread queue operations This fixes a missing ... Fri, 05 Feb 2021 13:13:31 GMT Sebastian Huber [9477d9ae] * cpukit/headers.am (modified) * cpukit/include/rtems/score/threadqops.h (added) * cpukit/score/src/threadqops.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) score: Make FIFO thread queue ops public Update #4230. Fri, 05 Feb 2021 13:19:06 GMT Sebastian Huber [2b5ce23b] * cpukit/include/rtems/score/threadq.h (modified) * cpukit/score/src/threadqops.c (modified) score: Constify Thread_queue_First_operation Update #4230. Wed, 03 Feb 2021 05:08:21 GMT Sebastian Huber [aa0060f4] * cpukit/include/rtems/rtems/part.h (modified) rtems: Clarify partition manager documentation Unify the wording ... Tue, 02 Feb 2021 14:40:42 GMT Sebastian Huber [98549e45] * cpukit/include/rtems/score/object.h (modified) score: _Objects_Build_name() signed/unsigned char Change ... Tue, 02 Feb 2021 11:15:28 GMT Sebastian Huber [ca68cfc8] * cpukit/rtems/src/clockgettickspersecond.c (modified) rtems: Avoid duplicated implemenation Use the ... Tue, 02 Feb 2021 13:23:52 GMT Sebastian Huber [8a95e6f8] * cpukit/include/rtems/rtems/object.h (modified) * cpukit/rtems/src/rtemsbuildid.c (modified) * cpukit/rtems/src/rtemsbuildname.c (modified) * cpukit/rtems/src/rtemsobjectidapimaximum.c (modified) * cpukit/rtems/src/rtemsobjectidapiminimum.c (modified) * cpukit/rtems/src/rtemsobjectidgetapi.c (modified) * cpukit/rtems/src/rtemsobjectidgetclass.c (modified) * cpukit/rtems/src/rtemsobjectidgetindex.c (modified) * cpukit/rtems/src/rtemsobjectidgetnode.c (modified) * testsuites/sptests/sp43/init.c (modified) rtems: Rework object services API Add a "Constraints" paragraph to ... Fri, 29 Jan 2021 06:07:51 GMT Sebastian Huber [490e6e8] * cpukit/include/rtems/score/assert.h (modified) * cpukit/include/rtems/score/basedefs.h (modified) score: Define _Assert() for static analysis runs The goal is to ... Mon, 01 Feb 2021 13:18:58 GMT Sebastian Huber [8f7baef4] * cpukit/libtest/t-test-rtems-measure.c (modified) libtest: Remove double definition Mon, 01 Feb 2021 11:47:38 GMT Sebastian Huber [56494ed8] * cpukit/include/rtems/score/thread.h (modified) score: Clarify thread life state documentation Fri, 29 Jan 2021 07:22:31 GMT Sebastian Huber [05da65c] * cpukit/include/rtems/score/thread.h (modified) score: Document Thread_Life_state Tue, 12 Jan 2021 13:03:41 GMT Sebastian Huber [51e59d5] * cpukit/Makefile.am (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-eic-rsie-low-level.S (deleted) * spec/build/cpukit/cpunios2.yml (modified) nios2: Allow ISR nesting in dispatch variant Rename ... Tue, 12 Jan 2021 09:31:27 GMT Sebastian Huber [19acb3b] * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) nios2: Optimize ISR dispatch variant Use _Thread_Do_dispatch() in ... Tue, 12 Jan 2021 06:13:08 GMT Sebastian Huber [9165349d] * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h (modified) * cpukit/score/cpu/nios2/nios2-context-switch.S (modified) * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c (modified) nios2: Use Per_CPU_Control::isr_dispatch_disable Fri, 08 Jan 2021 08:04:22 GMT Sebastian Huber [c968b27] * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) nios2: Add TLS support Update #4214. Tue, 05 Jan 2021 13:56:25 GMT Sebastian Huber [e324f82] * cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c (modified) nios2: Make _ISR_Is_in_progress() weak This allows the BSP to ... Tue, 05 Jan 2021 09:53:35 GMT Sebastian Huber [98c95d1] * cpukit/score/cpu/nios2/nios2-eic-il-low-level.S (modified) * cpukit/score/cpu/nios2/nios2-eic-rsie-low-level.S (modified) nios2: Fix ISR dispatch variants The thread dispatch disabled level ... Fri, 29 Jan 2021 06:22:21 GMT Sebastian Huber [9523887] * cpukit/include/rtems/rtems/timerimpl.h (modified) rtems: Fix implicit type conversions This fix relates to a Coverity ... Fri, 29 Jan 2021 05:29:38 GMT Sebastian Huber [fe08e45] * cpukit/include/rtems/score/assert.h (modified) score: Remove unused _SMP_Assert() Thu, 28 Jan 2021 15:52:52 GMT Sebastian Huber [9e56c85] * cpukit/include/rtems/score/watchdogimpl.h (modified) score: Fix implicit type conversion This fix relates to a Coverity ... Thu, 28 Jan 2021 15:51:15 GMT Sebastian Huber [d52c4961] * cpukit/include/rtems/rtems/semimpl.h (modified) rtems: Fix explicit type conversion This fix relates to a Coverity ... Thu, 28 Jan 2021 15:43:55 GMT Sebastian Huber [23f4e5b] * cpukit/libtest/t-test-interrupt.c (modified) * cpukit/libtest/t-test-rtems.c (modified) libtest: Fix implicit type conversions This fix relates to a ... Thu, 28 Jan 2021 14:09:38 GMT Sebastian Huber [c4db00db] * cpukit/rtems/src/semrelease.c (modified) rtems: Mark value as used This fix relates to a Coverity issue ... Thu, 28 Jan 2021 14:06:48 GMT Sebastian Huber [0c99206] * cpukit/score/src/scheduleredfsmp.c (modified) score: Remove double assignment This fix relates to a Coverity ... Thu, 28 Jan 2021 14:03:55 GMT Sebastian Huber [3b8137b] * cpukit/libtest/t-test-rtems-measure.c (modified) libtest: Check return values with RTEMS_DEBUG This fix relates to a ... Thu, 28 Jan 2021 13:52:03 GMT Sebastian Huber [8d099f4a] * cpukit/include/rtems/score/smpimpl.h (modified) score: Remove superfluous type qualifier This fix relates to a ... Thu, 28 Jan 2021 13:50:11 GMT Sebastian Huber [2c050633] * cpukit/score/src/coremsgbroadcast.c (modified) score: Simplify _CORE_message_queue_Broadcast() This fix relates to ... Thu, 28 Jan 2021 13:36:13 GMT Sebastian Huber [ab97ea64] * bsps/sparc/leon3/console/printk_support.c (modified) bsp/leon3: Improve printk() support Use the idle stack to buffer ... Thu, 28 Jan 2021 11:55:52 GMT Sebastian Huber [3dcdb9c9] * cpukit/include/rtems/score/mrspimpl.h (modified) score: Simplify _MRSP_Wait_for_ownership() Do not shadow the ... Thu, 28 Jan 2021 10:59:44 GMT Sebastian Huber [5dc4f9c7] * cpukit/include/rtems/rtems/timerimpl.h (modified) score: Fix implicit type conversion This fix relates to a Coverity ... Thu, 28 Jan 2021 10:52:38 GMT Sebastian Huber [c44ab898] * bsps/sparc/leon3/clock/ckinit.c (modified) bsp/leon3: Fix incompatible function types This fix relates to a ... Thu, 28 Jan 2021 10:40:10 GMT Sebastian Huber [198e926] * cpukit/score/src/kern_tc.c (modified) kern_tc.c: Remove unused code This fix relates to a Coverity issue ... Thu, 28 Jan 2021 10:35:18 GMT Sebastian Huber [450c170] * cpukit/include/rtems/score/priorityimpl.h (modified) score: Add comments and asserts for clarification This fix relates ... Thu, 28 Jan 2021 10:29:12 GMT Sebastian Huber [64189a70] * cpukit/score/src/coremsgsubmit.c (modified) score: Fix _CORE_message_queue_Submit() indentation This fix ... Thu, 28 Jan 2021 10:26:11 GMT Sebastian Huber [dc2a6987] * bsps/sparc/leon3/start/bspclean.c (modified) bsp/leon3: Fix bsp_fatal_extension) indentation Remove superfluous ... Thu, 28 Jan 2021 10:17:51 GMT Sebastian Huber [395c15f] * cpukit/score/src/objectgetinfo.c (modified) score: Fix _Objects_Get_information() indentation This fix relates ... Wed, 27 Jan 2021 18:28:56 GMT Sebastian Huber [bf8d4b9] * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/taskconstruct.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Add _Thread_Get_objects_information() We do not need all the ... Fri, 29 Jan 2021 17:45:05 GMT Sebastian Huber [76eec484] * cpukit/include/rtems/score/objectdata.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/score/threadmp.h (modified) * cpukit/score/src/threadget.c (modified) score: Rename _Thread_Get_objects_information() Rename ... Thu, 28 Jan 2021 18:27:12 GMT Sebastian Huber [44ae183] * bsps/aarch64/include/dev/irq/arm-gic-arch.h (modified) bsps/aarch64: Add missing include Fixes: ... Thu, 28 Jan 2021 09:31:07 GMT Sebastian Huber [f8b6359] * bsps/sparc/leon3/include/bsp/irq.h (modified) bsp/leon3: Simplify bsp_interrupt_is_valid_vector() There is not ... Thu, 28 Jan 2021 08:48:21 GMT Sebastian Huber [fcbefb5] * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/msgqconstruct.c (modified) * cpukit/rtems/src/rtemsobjectsetname.c (modified) rtems: Use _Status_Get() This fixes implicit conversions between ... Thu, 28 Jan 2021 05:28:33 GMT Sebastian Huber [b361eabd] * bsps/arm/altera-cyclone-v/start/bsp_specs (modified) * bsps/arm/atsam/start/bsp_specs (modified) * bsps/arm/beagle/start/bsp_specs (modified) * bsps/arm/csb336/start/bsp_specs (modified) * bsps/arm/csb337/start/bsp_specs (modified) * bsps/arm/edb7312/start/bsp_specs (modified) * bsps/arm/gumstix/start/bsp_specs (modified) * bsps/arm/imx/start/bsp_specs (modified) * bsps/arm/lm3s69xx/start/bsp_specs (modified) * bsps/arm/lpc176x/start/bsp_specs (modified) * bsps/arm/lpc24xx/start/bsp_specs (modified) * bsps/arm/lpc32xx/start/bsp_specs (modified) * bsps/arm/raspberrypi/start/bsp_specs (modified) * bsps/arm/realview-pbx-a9/start/bsp_specs (modified) * bsps/arm/rtl22xx/start/bsp_specs (modified) * bsps/arm/smdk2410/start/bsp_specs (modified) * bsps/arm/stm32f4/start/bsp_specs (modified) * bsps/arm/stm32h7/start/bsp_specs (modified) * bsps/arm/tms570/start/bsp_specs (modified) * bsps/arm/xen/start/bsp_specs (modified) * bsps/arm/xilinx-zynq/start/bsp_specs (modified) * bsps/arm/xilinx-zynqmp/start/bsp_specs (modified) * bsps/bfin/TLL6527M/start/bsp_specs (modified) * bsps/bfin/bf537Stamp/start/bsp_specs (modified) * bsps/bfin/eZKit533/start/bsp_specs (modified) * bsps/i386/pc386/start/bsp_specs (modified) * bsps/lm32/lm32_evr/start/bsp_specs (modified) * bsps/lm32/milkymist/start/bsp_specs (modified) * bsps/m68k/av5282/start/bsp_specs (modified) * bsps/m68k/csb360/start/bsp_specs (modified) * bsps/m68k/gen68340/start/bsp_specs (modified) * bsps/m68k/gen68360/start/bsp_specs (modified) * bsps/m68k/genmcf548x/start/bsp_specs (modified) * bsps/m68k/mcf5206elite/start/bsp_specs (modified) * bsps/m68k/mcf52235/start/bsp_specs (modified) * bsps/m68k/mcf5225x/start/bsp_specs (modified) * bsps/m68k/mcf5235/start/bsp_specs (modified) * bsps/m68k/mcf5329/start/bsp_specs (modified) * bsps/m68k/mrm332/start/bsp_specs (modified) * bsps/m68k/mvme147/start/bsp_specs (modified) * bsps/m68k/mvme147s/start/bsp_specs (modified) * bsps/m68k/mvme162/start/bsp_specs (modified) * bsps/m68k/mvme167/start/bsp_specs (modified) * bsps/m68k/uC5282/start/bsp_specs (modified) * bsps/mips/csb350/start/bsp_specs (modified) * bsps/mips/hurricane/start/bsp_specs (modified) * bsps/mips/jmr3904/start/bsp_specs (modified) * bsps/mips/malta/start/bsp_specs (modified) * bsps/mips/rbtx4925/start/bsp_specs (modified) * bsps/mips/rbtx4938/start/bsp_specs (modified) * bsps/moxie/moxiesim/start/bsp_specs (modified) * bsps/nios2/nios2_iss/start/bsp_specs (modified) * bsps/no_cpu/no_bsp/start/bsp_specs (modified) * bsps/or1k/generic_or1k/start/bsp_specs (modified) * bsps/powerpc/beatnik/start/bsp_specs (modified) * bsps/powerpc/gen5200/start/bsp_specs (modified) * bsps/powerpc/gen83xx/start/bsp_specs (modified) * bsps/powerpc/haleakala/start/bsp_specs (modified) * bsps/powerpc/motorola_powerpc/start/bsp_specs (modified) * bsps/powerpc/mpc55xxevb/start/bsp_specs (modified) * bsps/powerpc/mpc8260ads/start/bsp_specs (modified) * bsps/powerpc/mvme3100/start/bsp_specs (modified) * bsps/powerpc/mvme5500/start/bsp_specs (modified) * bsps/powerpc/psim/start/bsp_specs (modified) * bsps/powerpc/qemuppc/start/bsp_specs (modified) * bsps/powerpc/qoriq/start/bsp_specs (modified) * bsps/powerpc/ss555/start/bsp_specs (modified) * bsps/powerpc/t32mppc/start/bsp_specs (modified) * bsps/powerpc/tqm8xx/start/bsp_specs (modified) * bsps/powerpc/virtex/start/bsp_specs (modified) * bsps/powerpc/virtex4/start/bsp_specs (modified) * bsps/powerpc/virtex5/start/bsp_specs (modified) * bsps/riscv/griscv/start/bsp_specs (modified) * bsps/riscv/riscv/start/bsp_specs (modified) * bsps/sh/gensh1/start/bsp_specs (modified) * bsps/sh/gensh2/start/bsp_specs (modified) * bsps/sh/gensh4/start/bsp_specs (modified) * bsps/sh/shsim/start/bsp_specs (modified) * bsps/sparc/erc32/start/bsp_specs (modified) * bsps/sparc/leon2/start/bsp_specs (modified) * bsps/sparc/leon3/start/bsp_specs (modified) * bsps/sparc64/niagara/start/bsp_specs (modified) * bsps/sparc64/usiii/start/bsp_specs (modified) * bsps/v850/gdbv850sim/start/bsp_specs (modified) * bsps/x86_64/amd64/start/bsp_specs (modified) bsps: Replace bsp_specs with an empty file This fixes an issue with ... Wed, 27 Jan 2021 15:42:14 GMT Sebastian Huber [e269e389] * cpukit/libtest/t-test.c (modified) libtest: Remove superfluous NULL pointer check This fix relates to ... Wed, 27 Jan 2021 15:41:00 GMT Sebastian Huber [426b6cd] * cpukit/libtest/t-test.c (modified) libtest: Use dependency injection This helps static analyzers. Wed, 27 Jan 2021 15:33:01 GMT Sebastian Huber [361ec320] * bsps/shared/cache/cacheimpl.h (modified) cacheimpl.h: Avoid potential dead code If CPU_DATA_CACHE_ALIGNMENT ... Wed, 27 Jan 2021 08:39:51 GMT Sebastian Huber [3272dcb] * cpukit/sapi/src/exinit.c (modified) Update copyright notice to 2021 Mon, 25 Jan 2021 08:27:22 GMT Sebastian Huber [b35ac99] * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/io.h (modified) * cpukit/include/rtems/rtems/attr.h (modified) * cpukit/include/rtems/rtems/config.h (modified) * cpukit/include/rtems/rtems/event.h (modified) * cpukit/include/rtems/rtems/modes.h (modified) * cpukit/include/rtems/rtems/object.h (modified) * cpukit/include/rtems/rtems/part.h (modified) * cpukit/include/rtems/rtems/status.h (modified) * cpukit/include/rtems/rtems/timer.h (modified) * cpukit/include/rtems/score/basedefs.h (modified) rtems: Add "Notes" paragraph header Place the paragraphs in the ... Thu, 07 Jan 2021 11:05:37 GMT Sebastian Huber [30c71c3] * cpukit/include/rtems/score/heap.h (modified) heap: Fix _Heap_Area_overhead() The first block must be a proper ... Fri, 08 Jan 2021 10:59:40 GMT Sebastian Huber [c734e86] * cpukit/sapi/src/cpucounterconverter.c (modified) cpucounter: Increase conversion accuracy The maximum frequency is ... Tue, 05 Jan 2021 09:45:28 GMT Sebastian Huber [9d2db27a] * wscript (modified) build: Add CPPFLAGS to assembler command line We use GCC to call ...
