# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/17/24 04:43:22 Thu, 13 Aug 1998 14:28:22 GMT Joel Sherrill [9898425] * c/src/lib/start/m68k/start.s (modified) Patch from Chris Johns to change the way in which the ... Thu, 13 Aug 1998 14:23:37 GMT Joel Sherrill [26e5cd4] * c/src/exec/score/cpu/m68k/m68k.h (modified) Patch from Chris Johns . Comments follow: Here is ... Thu, 13 Aug 1998 14:22:48 GMT Joel Sherrill [7e19c72b] * c/src/lib/start/m68k/start.s (modified) fixed spacing Wed, 12 Aug 1998 23:53:23 GMT Joel Sherrill [ae320e0] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Removed spurious prints and cleaned up XXX. Wed, 12 Aug 1998 23:10:38 GMT Joel Sherrill [9693fac4] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Added more debug information. There are probably debug prints left ... Wed, 12 Aug 1998 16:57:27 GMT Wade A Smith [3f9da79] * doc/new_chapters/confspace.t (modified) Updated the description section of the cfg_open and cfg_read routines Wed, 12 Aug 1998 16:28:17 GMT Joel Sherrill [4f38b713] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Fixed bug where the last link of the RDA was not initialized properly. Tue, 11 Aug 1998 22:50:07 GMT Wade A Smith [b032c17] * doc/new_chapters/adminiface.t (modified) Updated the description section of the admin_shutdown routine. Tue, 11 Aug 1998 22:34:41 GMT Wade A Smith [c40ad43] * doc/new_chapters/dumpcontrol.t (modified) Updated the description section for the dump_setpath routine. Tue, 11 Aug 1998 22:10:51 GMT Wade A Smith [2dd561a3] * doc/new_chapters/eventlog.t (modified) Updated the description section for the following routines: ... Tue, 11 Aug 1998 20:38:09 GMT Wade A Smith [09470e0] * doc/new_chapters/eventlog.t (modified) Updated the Description section for the following routines: ... Tue, 11 Aug 1998 14:20:26 GMT Joel Sherrill [7d07970] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Added SONIC_DEBUG_DESCRIPTORS and changed debug level. Mon, 10 Aug 1998 23:20:25 GMT Joel Sherrill [339737b] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Survives 16-20 packets. Appears to be ok on TX buffer management. ... Mon, 10 Aug 1998 22:35:04 GMT Wade A Smith [0cac61e] * doc/new_chapters/eventlog.t (modified) Update the description section for the log_write function. Mon, 10 Aug 1998 22:23:33 GMT Joel Sherrill [3fbd528] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Added prints Mon, 10 Aug 1998 22:01:23 GMT Wade A Smith [df8d3601] * doc/new_chapters/confspace.t (modified) Updated the Description section for the Configuration Space ... Mon, 10 Aug 1998 21:45:01 GMT Joel Sherrill [7344fba9] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.h (modified) Can now reply to multiple successive pings successfully without being ... Mon, 10 Aug 1998 21:27:33 GMT Joel Sherrill [c153a7b] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) replies to ping -- forced into prosmiscuous mode Mon, 10 Aug 1998 16:41:46 GMT Wade A Smith [9886290] * doc/new_chapters/confspace.t (modified) Added to the description section of the Configuration Space Operations. Mon, 10 Aug 1998 14:54:01 GMT Wade A Smith [b044905b] * doc/new_chapters/adminiface.t (modified) Documented the admin_shutdown function Mon, 10 Aug 1998 14:53:01 GMT Wade A Smith [ebc67925] * doc/new_chapters/eventlog.t (modified) Documented the following Event Logging routines: log_write, ... Mon, 10 Aug 1998 14:48:01 GMT Wade A Smith [8c82d8d1] * doc/new_chapters/dumpcontrol.t (modified) Documented the dump_setpath function. Mon, 10 Aug 1998 14:44:39 GMT Wade A Smith [e6bfa70] * doc/new_chapters/confspace.t (modified) Added documentation for the following Configuration Space Operations: ... Sat, 08 Aug 1998 17:57:23 GMT Joel Sherrill [0c0419a1] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Reordered some stuff. Sat, 08 Aug 1998 16:51:16 GMT Joel Sherrill [18c2320] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980808 Sat, 08 Aug 1998 16:37:43 GMT Joel Sherrill [870284d] * c/src/lib/libbsp/shared/console.c (modified) Corrected spacing. Sat, 08 Aug 1998 16:37:25 GMT Joel Sherrill [301a2a3c] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.h (modified) Changed debug level. Moved CAM Descriptor types to sonic.h. CAM ... Sat, 08 Aug 1998 16:26:35 GMT Joel Sherrill [7e2187f4] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 9800808 Thu, 06 Aug 1998 19:01:03 GMT Joel Sherrill [13451a3] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.h (modified) Removed SonicRegisters structure since we now use register indices ... Thu, 06 Aug 1998 19:01:02 GMT Joel Sherrill [e70a8f16] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Enabled specific types of debug info. Added pointer to RDA to sonic ... Thu, 06 Aug 1998 15:27:08 GMT Joel Sherrill [e995f3a1] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Changed debug enable macros to support individually enabling ... Thu, 06 Aug 1998 15:05:59 GMT Joel Sherrill [c23118b] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/todcfg.c (modified) Card Resource Register was a 16-bit register not a 32-bit one. Used ... Thu, 06 Aug 1998 00:24:52 GMT Joel Sherrill [308e18c] * c/src/lib/libbsp/powerpc/dmv177/console/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/conscfg.c (modified) * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/todcfg.c (modified) Added support for the Card Resource Register. The new probe routines ... Wed, 05 Aug 1998 23:57:35 GMT Joel Sherrill [0eb85ae] * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) Commented out the code which yields the CPU when the serial ... Wed, 05 Aug 1998 23:56:48 GMT Joel Sherrill [d4bf16c] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.h (modified) Added constants which made the multiple bit settings more readable ... Wed, 05 Aug 1998 23:56:13 GMT Joel Sherrill [dddc0557] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) DCR setting changed to match what the DY-4 Firmware initialized it ... Wed, 05 Aug 1998 16:51:39 GMT Joel Sherrill [bd8c8b2a] * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/start/start.s (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timer.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.s (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (added) * c/src/lib/libbsp/i386/shared/io/bspIo.h (added) * c/src/lib/libbsp/i386/shared/io/printk.c (added) * c/src/lib/libbsp/i386/shared/irq/irq.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/cpuModel.h (modified) * c/src/lib/libcpu/i386/displayCpu.c (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) Patch from Eric Valette which brings the ... Wed, 05 Aug 1998 15:44:09 GMT Joel Sherrill [0e3c0096] * make/custom/pc386.cfg (modified) changed load address Wed, 05 Aug 1998 15:15:46 GMT Joel Sherrill [ab0df696] * c/src/exec/score/cpu/i386/asm.h (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/bsp.h (modified) * c/src/lib/libbsp/i386/force386/startup/setvec.c (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/cpuModel.S (added) * c/src/lib/libcpu/i386/cpuModel.h (added) * c/src/lib/libcpu/i386/displayCpu.c (added) * c/src/lib/libcpu/i386/registers.h (added) * cpukit/score/cpu/i386/asm.h (modified) * cpukit/score/cpu/i386/rtems/asm.h (modified) Automatic CPU type detection code from Eric Valette ... Wed, 05 Aug 1998 15:12:03 GMT Joel Sherrill [5094711] * c/src/lib/libbsp/m68k/idp/console/duart.c (modified) Fixed name of Buffer so this would compile. Wed, 05 Aug 1998 15:11:33 GMT Joel Sherrill [4d11a92f] * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) Redid Makefiles to properly do a preinstall. There was remnants of ... Wed, 05 Aug 1998 15:10:18 GMT Joel Sherrill [b31fdf8] * c/Makefile.in (modified) Added print of the order in which the directories are preinstalled. Tue, 04 Aug 1998 19:25:14 GMT Joel Sherrill [16bed8a] * doc/new_chapters/Makefile (modified) * doc/new_chapters/adminiface.t (modified) * doc/new_chapters/base.texi (deleted) * doc/new_chapters/cancel.t (modified) * doc/new_chapters/confspace.t (modified) * doc/new_chapters/cspecific.t (modified) * doc/new_chapters/device.t (modified) * doc/new_chapters/dumpcontrol.t (modified) * doc/new_chapters/eventlog.t (modified) * doc/new_chapters/files.t (modified) * doc/new_chapters/gen_section (modified) * doc/new_chapters/io.t (modified) * doc/new_chapters/memorymgmt.t (modified) * doc/new_chapters/message.t (modified) * doc/new_chapters/procenv.t (modified) * doc/new_chapters/process.t (modified) * doc/new_chapters/semaphores.t (modified) * doc/new_chapters/systemdb.t (modified) More complete shells generated. Mon, 03 Aug 1998 21:01:21 GMT Joel Sherrill [7fc5d54e] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.h (modified) Switched to read/write register routines and added some basic debug help. Mon, 03 Aug 1998 18:30:21 GMT Joel Sherrill [832e33c] * doc/new_chapters/Makefile (modified) * doc/new_chapters/adminiface.t (added) * doc/new_chapters/cancel.t (added) * doc/new_chapters/confspace.t (added) * doc/new_chapters/cspecific.t (added) * doc/new_chapters/device.t (added) * doc/new_chapters/dumpcontrol.t (added) * doc/new_chapters/eventlog.t (added) * doc/new_chapters/files.t (added) * doc/new_chapters/gen_section (modified) * doc/new_chapters/io.t (added) * doc/new_chapters/memorymgmt.t (added) * doc/new_chapters/message.t (added) * doc/new_chapters/posix_users.texi (modified) * doc/new_chapters/procenv.t (modified) * doc/new_chapters/process.t (modified) * doc/new_chapters/semaphores.t (added) * doc/new_chapters/systemdb.t (added) Added many new chapters Mon, 03 Aug 1998 15:06:27 GMT Joel Sherrill [92ef225] * c/src/tests/sptests/sp12/system.h (modified) * testsuites/sptests/sp12/system.h (modified) Under allcoated task stacks. Sat, 01 Aug 1998 17:03:13 GMT Joel Sherrill [f1316c4] * doc/new_chapters/posix_users.texi (modified) Changed to be posix users "new" Sat, 01 Aug 1998 17:03:01 GMT Joel Sherrill [f6b9fc6] * doc/new_chapters/gen_section (modified) Added files and directories. Sat, 01 Aug 1998 17:02:50 GMT Joel Sherrill [2a41ab8] * doc/new_chapters/Makefile (modified) Fixed to add files and directories. Fixed so this is installed as ... Sat, 01 Aug 1998 16:36:26 GMT Joel Sherrill [c76d527] * doc/new_chapters/Makefile (modified) Added process and procenv. Sat, 01 Aug 1998 16:36:14 GMT Joel Sherrill [d502c15] * doc/new_chapters/posix_users.texi (modified) Added language variables. Sat, 01 Aug 1998 16:36:03 GMT Joel Sherrill [45c00d4] * doc/new_chapters/gen_section (modified) Now generates complete template for chapters. Sat, 01 Aug 1998 16:35:43 GMT Joel Sherrill [aa72f36] * doc/new_chapters/procenv.t (added) * doc/new_chapters/process.t (added) New files -- automatically gnerated templates. Sat, 01 Aug 1998 16:09:29 GMT Joel Sherrill [8ced79b3] * doc/new_chapters/gen_section (added) New file Sat, 01 Aug 1998 15:59:56 GMT Joel Sherrill [dfef768f] * doc/new_chapters/base.t (modified) Removed items which are now automatically generated. Sat, 01 Aug 1998 15:50:54 GMT Joel Sherrill [3c56251] * doc/new_chapters/base.t (added) New file. Sat, 01 Aug 1998 15:49:38 GMT Joel Sherrill [4ebb4862] * doc/new_chapters/clock.t (modified) * doc/new_chapters/cond.t (modified) * doc/new_chapters/key.t (modified) * doc/new_chapters/mutex.t (modified) * doc/new_chapters/posix_users.texi (modified) * doc/new_chapters/preface.texi (modified) * doc/new_chapters/sched.t (modified) * doc/new_chapters/signal.t (modified) * doc/new_chapters/thread.t (modified) Removed all node and menu information since this information is now ... Sat, 01 Aug 1998 15:48:29 GMT Joel Sherrill [c89fdeac] * doc/new_chapters/Makefile (modified) Modified so chapters are automatically generated. Sat, 01 Aug 1998 15:47:46 GMT Joel Sherrill [6b16b46] * doc/new_chapters/STATUS (added) New file Sat, 01 Aug 1998 15:43:28 GMT Joel Sherrill [02d8713] * doc/new_chapters/preface.texi (moved) Don't automatically generate this one. Sat, 01 Aug 1998 15:37:48 GMT Joel Sherrill [89e5a583] * doc/new_chapters/thread.texi (deleted) Moved to thread.t and node information automatically generated Sat, 01 Aug 1998 15:37:47 GMT Joel Sherrill [3dc05f7f] * doc/new_chapters/signal.texi (deleted) Moved to signal.t and node information automatically generated Sat, 01 Aug 1998 15:37:46 GMT Joel Sherrill [06f8ea66] * doc/new_chapters/sched.texi (deleted) Moved to sched.t and node information automatically generated Sat, 01 Aug 1998 15:37:45 GMT Joel Sherrill [ea16ebc8] * doc/new_chapters/preface.texi (deleted) Moved to preface.t and node information automatically generated Sat, 01 Aug 1998 15:37:44 GMT Joel Sherrill [0574b92c] * doc/new_chapters/mutex.texi (deleted) Moved to mutex.t and node information automatically generated Sat, 01 Aug 1998 15:37:43 GMT Joel Sherrill [090378d0] * doc/new_chapters/key.texi (deleted) Moved to key.t and node information automatically generated Sat, 01 Aug 1998 15:37:42 GMT Joel Sherrill [ed7ce41] * doc/new_chapters/cond.texi (deleted) Moved to cond.t and node information automatically generated Sat, 01 Aug 1998 15:37:41 GMT Joel Sherrill [f4e6ea3f] * doc/new_chapters/clock.texi (deleted) Moved to clock.t and node information automatically generated Sat, 01 Aug 1998 15:31:49 GMT Joel Sherrill [6c914e9] * doc/new_chapters/Makefile (modified) * doc/new_chapters/clock.t (added) * doc/new_chapters/cond.t (added) * doc/new_chapters/key.t (added) * doc/new_chapters/mutex.t (added) * doc/new_chapters/preface.t (added) * doc/new_chapters/sched.t (added) * doc/new_chapters/signal.t (added) * doc/new_chapters/thread.t (added) Added automatic generation of files. Sat, 01 Aug 1998 15:01:59 GMT Joel Sherrill [93e3b8a3] * c/src/tests/samples/Makefile.in (modified) Moved to network demos Sat, 01 Aug 1998 14:41:45 GMT Joel Sherrill [8c6e195] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Patch from David Fiddes to make ASFLAGS include ... Sat, 01 Aug 1998 14:41:20 GMT Joel Sherrill [906577f4] * c/src/lib/start/m68k/start.s (modified) Patch from David Fiddes to not use this file ... Sat, 01 Aug 1998 14:40:51 GMT Joel Sherrill [5ef4fae] * c/src/exec/score/cpu/m68k/asm.h (modified) * c/src/exec/score/cpu/m68k/rtems.s (modified) * cpukit/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) Merged patch from David Fiddes to add ColdFire ... Sat, 01 Aug 1998 14:39:24 GMT Joel Sherrill [f177865] * c/ACKNOWLEDGEMENTS (modified) Added Rod Barman (rodb@cs.ubc.ca) in credits for ColdFire. Thu, 30 Jul 1998 22:57:21 GMT Joel Sherrill [2889189] * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) Changed name of network driver. Thu, 30 Jul 1998 22:57:12 GMT Joel Sherrill [fa655207] * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) Added temporary include of dmv170.h Thu, 30 Jul 1998 22:56:56 GMT Joel Sherrill [4fbf114] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Added SONIC configuration information. Thu, 30 Jul 1998 22:56:17 GMT Joel Sherrill [56392179] * c/src/lib/libbsp/powerpc/dmv177/README.net (modified) Added a hint to continue writing this. Thu, 30 Jul 1998 21:30:46 GMT Joel Sherrill [d9bc023a] * c/src/lib/libchip/rtc/STATUS (modified) * c/src/libchip/rtc/STATUS (modified) Updated. Thu, 30 Jul 1998 21:27:51 GMT Joel Sherrill [509dc7c1] * c/src/lib/libbsp/shared/tod.c (modified) * c/src/lib/libbsp/shared/tod.h (modified) Added getRealTime() and setRealTime(). Reimplemented ... Thu, 30 Jul 1998 21:27:01 GMT Joel Sherrill [91af3e4] * c/src/lib/libbsp/powerpc/dmv177/tod/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/todcfg.c (modified) Changed clock rate from 32 Khz to 1 Mhz. Registers are at 8 byte ... Thu, 30 Jul 1998 21:26:25 GMT Joel Sherrill [a47bca7c] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Changed comment to be more polite. Thu, 30 Jul 1998 21:26:11 GMT Joel Sherrill [8e992e1] * c/src/lib/libbsp/powerpc/dmv177/README.net (modified) Updating to make more readable. Thu, 30 Jul 1998 19:51:03 GMT Joel Sherrill [192a1e0] * c/src/lib/libchip/rtc/README.ds1643 (added) * c/src/lib/libchip/rtc/README.m48t18 (added) * c/src/lib/libchip/serial/README.ns16550 (added) * c/src/lib/libchip/serial/README.xr88681 (added) * c/src/libchip/rtc/README.ds1643 (added) * c/src/libchip/rtc/README.m48t18 (added) * c/src/libchip/serial/README.ns16550 (added) * c/src/libchip/serial/README.xr88681 (added) New files. Thu, 30 Jul 1998 19:41:46 GMT Joel Sherrill [1aa4186] * c/src/lib/libbsp/powerpc/dmv177/timer/timer.c (modified) Spacing corrected. Thu, 30 Jul 1998 19:41:41 GMT Joel Sherrill [1a256e3] * c/src/lib/libbsp/powerpc/dmv177/README.net (added) New file based on email from DY-4 technical support. Thu, 30 Jul 1998 19:26:47 GMT Joel Sherrill [1c5f4e1] * c/src/lib/libbsp/powerpc/dmv177/QUIRKS (modified) Fixed spacing. Thu, 30 Jul 1998 19:25:54 GMT Joel Sherrill [8751f800] * c/src/lib/libbsp/powerpc/dmv177/README (modified) Updated to accurately reflect the dmv177. Thu, 30 Jul 1998 18:06:51 GMT Joel Sherrill [41d07439] * c/src/exec/score/cpu/i386/Makefile.in (modified) Patch from Eric Valette : Now that Joel ... Thu, 30 Jul 1998 16:07:54 GMT Joel Sherrill [7fd8641] * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/chain.h (deleted) Made chain.h shared Thu, 30 Jul 1998 16:05:14 GMT Joel Sherrill [3fdde4ce] * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/shared/tod.h (moved) Made tod.h shared Thu, 30 Jul 1998 15:56:59 GMT Joel Sherrill [032c100] * make/custom/dmv177.cfg (modified) Added HAS_RTC and enabled KA9Q. Wed, 29 Jul 1998 00:38:51 GMT Joel Sherrill [02733a96] * c/src/lib/libbsp/shared/tod.c (added) New file. Based on merged of shared libchip style console.c and the ... Wed, 29 Jul 1998 00:38:14 GMT Joel Sherrill [acac0e8] * c/src/lib/libbsp/shared/console.c (modified) Cleaned up comment. Modified open so it uses a local variable ... Wed, 29 Jul 1998 00:37:37 GMT Joel Sherrill [6a0f5ac2] * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) Added reference to shared TOD driver. Wed, 29 Jul 1998 00:18:11 GMT Joel Sherrill [c95e927] * c/src/lib/libchip/rtc/icm7170.h (modified) * c/src/lib/libchip/rtc/icm7170_reg.c (modified) * c/src/lib/libchip/rtc/m48t08.h (modified) * c/src/lib/libchip/rtc/m48t08_reg.c (modified) * c/src/libchip/rtc/icm7170.h (modified) * c/src/libchip/rtc/icm7170_reg.c (modified) * c/src/libchip/rtc/m48t08.h (modified) * c/src/libchip/rtc/m48t08_reg.c (modified) Added prototype for default register access routines to header files. ... Wed, 29 Jul 1998 00:17:01 GMT Joel Sherrill [ee306fd] * c/src/lib/libbsp/powerpc/dmv177/tod/config.c (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/todcfg.c (modified) Corrected to reflect the ICM7170 which is really on this board. Wed, 29 Jul 1998 00:16:44 GMT Joel Sherrill [55dcdfd] * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) Added config.c and deleted tod.c. Wed, 29 Jul 1998 00:16:32 GMT Joel Sherrill [e74735b2] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Simplified RTC base address. Wed, 29 Jul 1998 00:16:11 GMT Joel Sherrill [5217d5a] * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) Changed cast on RTC address and added base address of RTC fields as ...
