# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/01/24 19:06:30 Mon, 03 Aug 2020 10:16:51 GMT Sebastian Huber [95d37b6] * bsps/arm/shared/start/arm-a9mpcore-smp.c (modified) bsps/arm: Use _Assert() Fri, 26 Jan 2018 03:30:05 GMT eadler [208ebf2] * cpukit/libmisc/shell/main_dd.c (modified) dd(1): Use a local swapbytes() function. swab(3) has restrict ... Thu, 20 Aug 2020 06:31:47 GMT Sebastian Huber [79fb536] * testsuites/sptests/spintrcritical23/init.c (modified) spintrcritical23: Fix unused variable warnings Thu, 20 Aug 2020 06:31:30 GMT Sebastian Huber [218053d] * testsuites/sptests/sp37/init.c (modified) sp37: Fix unused variable warnings Tue, 18 Aug 2020 15:52:56 GMT Aschref Ben Thabet [65e027c9] * testsuites/psxtests/psxkey01/system.h (modified) psxkey01: Fix configuration Key_ID array must have the right size, ... Tue, 18 Aug 2020 15:31:21 GMT Aschref Ben Thabet [cbfdcba] * cpukit/libdl/rtl-archive.c (modified) * cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c (modified) Fix -Wchar-subscripts warnings The argument to the ctype functions ... Wed, 19 Aug 2020 04:47:38 GMT Sebastian Huber [05d5772] * cpukit/include/adainclude/rtems.ads (modified) ada: Add missing attributes Mon, 17 Aug 2020 10:29:24 GMT Sebastian Huber [593a67f6] * cpukit/include/rtems/rtems/attr.h (modified) rtems: Use unique option values The RTEMS_BARRIER_AUTOMATIC_RELEASE ... Fri, 14 Aug 2020 07:56:51 GMT Sebastian Huber [c7289484] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/init.c (modified) * testsuites/libtests/ttest01/test-plan.c (modified) libtest: Add T_push_plan() and T_pop_plan() Update #3199. Thu, 13 Aug 2020 17:00:47 GMT Sebastian Huber [13acd90] * cpukit/libtest/t-test-thread-switch.c (modified) libtest: Use a destructor Do not set up a new test steps ... Thu, 13 Aug 2020 09:33:47 GMT Sebastian Huber [72960bc7] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/test-destructor.c (modified) * testsuites/libtests/ttest01/test-plan.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) libtest: Change T_step() and T_assert_step() Normally, the expected ... Thu, 13 Aug 2020 07:59:19 GMT Sebastian Huber [5383d4db] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/init.c (modified) * testsuites/libtests/ttest01/test-fixture.c (modified) * testsuites/libtests/ttest02/init.c (modified) libtest: Add fixture steps Support a new test plan for each nested ... Thu, 13 Aug 2020 08:09:30 GMT Sebastian Huber [33eb113] * cpukit/libtest/t-test.c (modified) libtest: Add T_check_steps() Update #3199. Thu, 13 Aug 2020 07:01:32 GMT Sebastian Huber [cbc1ba3] * cpukit/libtest/t-test.c (modified) libtest: Use line buffer in T_check() Update #3199. Thu, 13 Aug 2020 05:44:25 GMT Sebastian Huber [5d614fd] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) libtest: Add T_puts() Update #3199. Thu, 13 Aug 2020 05:45:29 GMT Sebastian Huber [a7af34d0] * cpukit/libtest/t-test.c (modified) libtest: Add T_do_is_runner() Update #3199. Thu, 13 Aug 2020 05:33:17 GMT Sebastian Huber [e67eff2] * cpukit/libtest/t-test.c (modified) libtest: Add output buffer drain and fill Update #3199. Wed, 12 Aug 2020 14:57:39 GMT Sebastian Huber [5a8114c6] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/test-fixture.c (modified) libtest: Change fixture scope method Return the produced character ... Tue, 11 Aug 2020 08:41:26 GMT Aschref Ben Thabet [5869c647] * cpukit/include/rtems/printer.h (modified) rtems/printer.h Fix build warnings -Wclass-memaccess Mon, 27 Jul 2020 01:23:19 GMT Chris Johns [3ec5f20] * bsps/powerpc/include/libcpu/io.h (modified) powerpc/io: The eieio() function clashes with FreeBSD. Change. Sun, 28 Jun 2020 00:21:45 GMT Kinsey Moore [14749c45] * cpukit/posix/src/shmunlink.c (modified) posix: Only check shm_unlink obj_err if necessary In the nominal ... Tue, 11 Aug 2020 08:03:25 GMT Sebastian Huber [01677dd] * testsuites/sptests/spintrcritical23/init.c (modified) spintrcritical23: Restore runner priority Tue, 11 Aug 2020 07:45:53 GMT Aschref Ben Thabet [5d7ab6b] * testsuites/libtests/dl10/dl-load.c (modified) libtests/dl10: Delete unused functions Fri, 07 Aug 2020 18:30:39 GMT Sebastian Huber [c1354f0] * cpukit/Makefile.am (modified) * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-thread-switch.c (added) * testsuites/libtests/ttest02/init.c (modified) libtest: Add T_thread_switch_record() Add support to record thread ... Fri, 07 Aug 2020 18:30:09 GMT Sebastian Huber [20c79bf] * cpukit/libtest/t-test-interrupt.c (modified) libtest: Constify Update #3199. Fri, 07 Aug 2020 05:31:19 GMT Sebastian Huber [6626ed50] * Doxyfile (modified) Doxyfile: Change version to 6.0.0 Update #4020. Sat, 08 Aug 2020 08:07:32 GMT Chris Johns [20b1bdb] * cpukit/libmisc/shell/shell.c (modified) shell: Only clear std handles when the shell task exits Clearing ... Fri, 07 Aug 2020 16:07:52 GMT Sebastian Huber [f933b65] * cpukit/libtest/t-test-rtems-context.c (modified) libtest: Improve T_check_task_context Update #3199. Thu, 06 Aug 2020 12:30:51 GMT Sebastian Huber [e812f81] * cpukit/doxygen/appl-config.h (added) Document application configuration options Add a new directory for ... Thu, 06 Aug 2020 17:44:39 GMT Sebastian Huber [6894e2f4] * cpukit/headers.am (modified) * cpukit/include/rtems/doxygen-appl-config.h (deleted) Remove accidentally committed file Thu, 06 Aug 2020 17:12:55 GMT Sebastian Huber [32f1f747] * cpukit/libtest/t-test-interrupt.c (modified) * testsuites/libtests/ttest02/init.c (modified) libtest: Fix T_interrupt_test() in SMP configs Update #3199. Wed, 05 Aug 2020 11:54:33 GMT Aschref Ben Thabet [6c4ca83] * testsuites/psxtests/psxhdrs/string/stpncpy.c (modified) * testsuites/psxtests/psxhdrs/string/strncpy.c (modified) psxhdrs/strncpy/stpncpy: Fix string turncation warning Since we ... Wed, 05 Aug 2020 07:18:27 GMT Sebastian Huber [d2c98c1] * cpukit/include/dev/serial/sc16is752.h (modified) dev/sc16is752: Fix declaration Mon, 03 Aug 2020 07:42:25 GMT Sebastian Huber [1b421585] * bsps/arm/atsam/include/bsp/sc16is752.h (modified) * bsps/arm/atsam/spi/sc16is752.c (modified) arm/atsam: Make interrupt server configurable The external UART ... Tue, 04 Aug 2020 10:27:54 GMT Sebastian Huber [81631de] * testsuites/smptests/smpschededf02/init.c (modified) smpschededf02: Document reset() function Mon, 03 Aug 2020 09:46:48 GMT Sebastian Huber [9566538] * cpukit/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosinitialize.c (modified) termios: Make rtems_termios_ttyMutex private This mutex is used to ... Mon, 03 Aug 2020 08:25:53 GMT Sebastian Huber [2ae557eb] * cpukit/include/rtems/score/basedefs.h (modified) score: Use flexible-array member for C99 and later This addresses ... Mon, 03 Aug 2020 12:18:33 GMT Christian Mauderer [87fdb20] * cpukit/include/rtems/dosfs.h (modified) * cpukit/libblock/src/media.c (modified) * cpukit/libfs/src/dosfs/msdos_init.c (modified) dosfs: Fix memory leak on failed mounts. Currently if mount fails, ... Wed, 08 Jul 2020 08:53:26 GMT Christian Mauderer [6014fad] * bsps/arm/beagle/i2c/bbb-i2c.c (modified) bsps/beagle: Remove some debug output from I2C. Sat, 01 Aug 2020 12:30:10 GMT Sebastian Huber [29e7a069] * bsps/shared/dev/i2c/spi-memdrv.c (modified) dev/spi-memdrv: Fix use of uninit mem_param_ptr Thu, 30 Jul 2020 08:30:15 GMT Sebastian Huber [c60942ea] * bsps/shared/irq/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) rtems: Add rtems_interrupt_server_create() Add ... Mon, 20 Jul 2020 05:46:53 GMT Christian Mauderer [02c9eb85] * bsps/shared/start/bsp-fdt.c (modified) bsps/fdt: Make sure data is cache aligned The cache of the fdt blob ... Fri, 17 Jul 2020 05:54:44 GMT Christian Mauderer [29a73d8] * bsps/arm/imx/spi/imx-ecspi.c (modified) bsp/imx: Use GPIOs for SPI CS The chip select lines of the iMX SPI ... Fri, 17 Jul 2020 05:54:43 GMT Christian Mauderer [0f4b911c] * bsps/arm/imx/gpio/imx-gpio.c (added) * bsps/arm/imx/headers.am (modified) * bsps/arm/imx/include/bsp/imx-gpio.h (added) * bsps/arm/imx/include/bsp/irq.h (modified) * bsps/arm/imx/start/bspstart.c (modified) * bsps/include/bsp/fatal.h (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) bsp/imx: Add a GPIO driver Update 3869 Thu, 30 Jul 2020 17:29:23 GMT Sebastian Huber [a3bcc79] * bsps/lm32/lm32_evr/headers.am (modified) * bsps/lm32/lm32_evr/include/bsp/irq.h (deleted) * bsps/lm32/milkymist/headers.am (modified) * bsps/lm32/milkymist/include/bsp/irq.h (deleted) bsps/lm32: Use shared Having a duplicate header with ... Thu, 30 Jul 2020 12:47:03 GMT Aschref Ben Thabet [699f465c] * testsuites/psxtests/psxhdrs/string/strncat.c (modified) psxhdrs/strncat: Fix string truncation warning Wed, 22 Jul 2020 12:41:51 GMT Jan Sommer [21c7e3a] * cpukit/score/cpu/i386/cpu_asm.S (modified) i386: Fix possible race condition on first context restore Make ... Fri, 24 Jul 2020 05:31:24 GMT Sebastian Huber [4444094d] * testsuites/sptests/spmisc01/strong.c (modified) spmisc01: Include missing header file Update #4032. Wed, 08 Apr 2020 08:28:47 GMT Sebastian Huber [7746b0de] * cpukit/libcsupport/src/free.c (modified) * cpukit/libcsupport/src/malloc_deferred.c (modified) * cpukit/libcsupport/src/malloc_p.h (modified) malloc: Make deferred free support optional Only include the ... Wed, 08 Apr 2020 08:20:51 GMT Sebastian Huber [6f94a83] * cpukit/include/rtems/score/basedefs.h (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spmisc01/init.c (modified) * testsuites/sptests/spmisc01/spmisc01.h (added) * testsuites/sptests/spmisc01/strong.c (added) score: Add RTEMS_WEAK Update #4032. Tue, 21 Jul 2020 06:45:03 GMT Sebastian Huber [b2ff5fe] * testsuites/sptests/spintrcritical_support/intrcritical.c (deleted) * testsuites/sptests/spintrcritical_support/intrcritical.h (deleted) spintrcritical_support: Remove This test support was replaced by ... Mon, 20 Jul 2020 05:45:51 GMT Sebastian Huber [6b795cd7] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical24/init.c (modified) * testsuites/sptests/spintrcritical24/spintrcritical24.scn (modified) spintrcritical24: Use T_interrupt_test() Tue, 21 Jul 2020 05:32:10 GMT Sebastian Huber [23b9debe] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/sptests/spintrcritical23/spintrcritical23.scn (modified) spintrcritical23: Use T_interrupt_test() Sat, 18 Jul 2020 20:55:51 GMT Sebastian Huber [1414e71] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/sptests/spintrcritical22/spintrcritical22.scn (modified) spintrcritical22: Use T_interrupt_test() Mon, 20 Jul 2020 10:51:49 GMT Sebastian Huber [59ee3020] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical21/init.c (modified) * testsuites/sptests/spintrcritical21/spintrcritical21.scn (modified) * testsuites/sptests/spintrcritical21/system.h (deleted) spintrcritical21: Use T_interrupt_test() Tue, 21 Jul 2020 05:19:30 GMT Sebastian Huber [38636e23] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical20/init.c (modified) * testsuites/sptests/spintrcritical20/spintrcritical20.scn (modified) spintrcritical20: Use T_interrupt_test() Mon, 20 Jul 2020 13:57:08 GMT Sebastian Huber [aebdd1da] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical18/init.c (modified) * testsuites/sptests/spintrcritical18/spintrcritical18.scn (modified) spintrcritical18: Use T_interrupt_test() Mon, 20 Jul 2020 17:18:16 GMT Sebastian Huber [031e824] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical16/init.c (modified) * testsuites/sptests/spintrcritical16/spintrcritical16.scn (modified) spintrcritical16: Use T_interrupt_test() Mon, 20 Jul 2020 15:44:42 GMT Sebastian Huber [1c2e05d4] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical15/init.c (modified) * testsuites/sptests/spintrcritical15/spintrcritical15.scn (modified) spintrcritical15: Use T_interrupt_test() Mon, 20 Jul 2020 14:35:04 GMT Sebastian Huber [5020a28] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical13/spintrcritical13.scn (modified) * testsuites/sptests/spintrcritical13/spintrcritical13impl.h (modified) * testsuites/sptests/spintrcritical14/spintrcritical14.scn (modified) spintrcritical13/14: Use T_interrupt_test() Mon, 20 Jul 2020 13:24:21 GMT Sebastian Huber [8cbba449] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical11/spintrcritical11.scn (modified) * testsuites/sptests/spintrcritical11/spintrcritical11impl.h (modified) * testsuites/sptests/spintrcritical12/spintrcritical12.scn (modified) spintrcritical11/12: Use T_interrupt_test() Sat, 18 Jul 2020 20:22:16 GMT Sebastian Huber [be2f9d7] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical10/spintrcritical10.scn (modified) spintrcritical10: Use T_interrupt_test() Mon, 20 Jul 2020 14:12:02 GMT Sebastian Huber [a231276] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical09/spintrcritical09.scn (modified) spintrcritical09: Use T_interrupt_test() Mon, 20 Jul 2020 12:00:31 GMT Sebastian Huber [5f66ac86] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical08/spintrcritical08.scn (modified) spintrcritical08: Use T_interrupt_test() Mon, 20 Jul 2020 10:13:06 GMT Sebastian Huber [28313958] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spintrcritical06/init.c (deleted) * testsuites/sptests/spintrcritical06/spintrcritical06.doc (deleted) * testsuites/sptests/spintrcritical06/spintrcritical06.scn (deleted) * testsuites/sptests/spintrcritical06/spintrcritical06impl.h (deleted) * testsuites/sptests/spintrcritical07/init.c (deleted) * testsuites/sptests/spintrcritical07/spintrcritical07.doc (deleted) * testsuites/sptests/spintrcritical07/spintrcritical07.scn (deleted) spintrcritical06/spintrcritical07: Remove tests These two tests ... Mon, 20 Jul 2020 11:07:46 GMT Sebastian Huber [21f7333] * testsuites/psxtests/psxintrcritical01/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/spintrcritical01/spintrcritical01.scn (modified) * testsuites/sptests/spintrcritical01/spintrcritical01impl.h (modified) * testsuites/sptests/spintrcritical02/spintrcritical02.scn (modified) * testsuites/sptests/spintrcritical03/spintrcritical03.scn (modified) * testsuites/sptests/spintrcritical04/spintrcritical04.scn (modified) * testsuites/sptests/spintrcritical05/spintrcritical05.scn (modified) spintrcritical01/2/3/4/5: Use T_interrupt_test() Mon, 20 Jul 2020 09:50:53 GMT Sebastian Huber [857a65d] * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psxintrcritical01/init.c (modified) * testsuites/psxtests/psxintrcritical01/psxintrcritical01.scn (modified) psxintrcritical01: Use T_interrupt_test() Fri, 17 Jul 2020 17:42:32 GMT Sebastian Huber [cc3fd8fc] * cpukit/Makefile.am (modified) * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-interrupt.c (added) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/ttest02/init.c (added) * testsuites/libtests/ttest02/ttest02.doc (added) * testsuites/libtests/ttest02/ttest02.scn (added) libtest: Add T_interrupt_test() Update #3199. Sat, 18 Jul 2020 18:09:11 GMT Sebastian Huber [c9d2405] * cpukit/Makefile.am (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/libtest/testrun.c (added) libtest: Add rtems_test_run() Update #3199. Mon, 20 Jul 2020 05:28:07 GMT Sebastian Huber [dddc9a58] * cpukit/include/rtems/test.h (modified) libtest: Add quiet assert NULL pointer checks Update #3199. Fri, 17 Jul 2020 19:24:56 GMT Sebastian Huber [467ef5b4] * cpukit/include/rtems/test.h (modified) libtest: Add T_unreachable() Update #3199. Sat, 18 Jul 2020 12:41:36 GMT Sebastian Huber [d702c9f4] * cpukit/include/rtems/test.h (modified) * testsuites/libtests/ttest01/init.c (modified) * testsuites/libtests/ttest01/test-checks.c (modified) libtest: Make check message optional This macro magic is in line ... Sat, 18 Jul 2020 14:05:42 GMT Sebastian Huber [35d9af69] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-checks-eno.c (modified) * cpukit/libtest/t-test-checks-psx.c (modified) * cpukit/libtest/t-test-checks.c (modified) * cpukit/libtest/t-test-rtems-context.c (modified) * cpukit/libtest/t-test-rtems-fds.c (modified) * cpukit/libtest/t-test-rtems-heap.c (modified) * cpukit/libtest/t-test-rtems-objs.c (modified) * cpukit/libtest/t-test-rtems-posix-keys.c (modified) * cpukit/libtest/t-test-rtems.c (modified) * cpukit/libtest/t-test.c (modified) libtest: Add T_CHECK_FMT Rename internal function T_check_true() to ... Fri, 17 Jul 2020 19:21:16 GMT Sebastian Huber [7781404] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) libtest: Add T_stop() Update #3199. Thu, 16 Apr 2020 10:22:06 GMT Sebastian Huber [34e4df55] * cpukit/Makefile.am (modified) * cpukit/libtest/t-test-rtems-objs.c (modified) * cpukit/libtest/t-test-rtems-posix-keys.c (added) * cpukit/libtest/t-test-rtems.h (added) libtest: Split POSIX Keys support Update #3199. Fri, 26 Jun 2020 05:44:55 GMT Sebastian Huber [63e4278] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) libtest: Add T_get_scope() Update #3199. Tue, 09 Jun 2020 13:55:22 GMT Sebastian Huber [cb3c6bdc] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/init.c (modified) * testsuites/libtests/ttest01/test-fixture.c (modified) libtest: Add push/pop fixture support Update #3199. Mon, 08 Jun 2020 08:04:55 GMT Sebastian Huber [6b27e32] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/init.c (modified) * testsuites/libtests/ttest01/test-fixture.c (modified) libtest: Support custom scope messages via fixture Update #3199. Thu, 16 Apr 2020 14:06:59 GMT Sebastian Huber [c081c68] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) libtest: Add T_make_runner() Update #3199. Fri, 17 Jul 2020 12:49:42 GMT Sebastian Huber [af92665] * cpukit/Makefile.am (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-busy-tick.c (added) * cpukit/libtest/testbusy.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) libtest: Add T_get_one_clock_tick_busy() Update #3199. Fri, 17 Jul 2020 12:40:36 GMT Sebastian Huber [e3e3b871] * cpukit/Makefile.am (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-busy.c (added) * cpukit/libtest/testbusy.c (modified) * testsuites/sptests/spintrcritical_support/intrcritical.c (modified) libtest: Add T_busy() Update #3199. Fri, 17 Jul 2020 11:46:24 GMT Sebastian Huber [361404e8] * cpukit/headers.am (modified) * cpukit/include/rtems/test.h (moved) * cpukit/libtest/t-test-checks-eno.c (modified) * cpukit/libtest/t-test-checks-psx.c (modified) * cpukit/libtest/t-test-checks.c (modified) * cpukit/libtest/t-test-hash-sha256.c (modified) * cpukit/libtest/t-test-malloc.c (modified) * cpukit/libtest/t-test-rtems-context.c (modified) * cpukit/libtest/t-test-rtems-fds.c (modified) * cpukit/libtest/t-test-rtems-heap.c (modified) * cpukit/libtest/t-test-rtems-measure.c (modified) * cpukit/libtest/t-test-rtems-objs.c (modified) * cpukit/libtest/t-test-rtems.c (modified) * cpukit/libtest/t-test-time.c (modified) * cpukit/libtest/t-test.c (modified) * testsuites/libtests/ttest01/init.c (modified) * testsuites/libtests/ttest01/test-assert.c (modified) * testsuites/libtests/ttest01/test-checks.c (modified) * testsuites/libtests/ttest01/test-destructor.c (modified) * testsuites/libtests/ttest01/test-eno.c (modified) * testsuites/libtests/ttest01/test-example.c (modified) * testsuites/libtests/ttest01/test-fixture.c (modified) * testsuites/libtests/ttest01/test-leak.c (modified) * testsuites/libtests/ttest01/test-log.c (modified) * testsuites/libtests/ttest01/test-malloc.c (modified) * testsuites/libtests/ttest01/test-plan.c (modified) * testsuites/libtests/ttest01/test-psx.c (modified) * testsuites/libtests/ttest01/test-rtems.c (modified) * testsuites/libtests/ttest01/test-simple.c (modified) * testsuites/libtests/ttest01/test-step.c (modified) * testsuites/libtests/ttest01/test-task-context.c (modified) * testsuites/libtests/ttest01/test-time.c (modified) * testsuites/libtests/ttest01/test-verbosity.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) libtest: Move to Update #3199. Fri, 17 Jul 2020 11:36:49 GMT Sebastian Huber [9de8d61] * cpukit/headers.am (modified) * cpukit/include/rtems/doxygen-appl-config.h (added) * cpukit/include/rtems/test-info.h (moved) * cpukit/libtest/testbeginend.c (modified) * cpukit/libtest/testbusy.c (modified) * cpukit/libtest/testextension.c (modified) * cpukit/libtest/testparallel.c (modified) * cpukit/libtest/testwrappers.c (modified) * testsuites/ada/support/initimpl.h (modified) * testsuites/libtests/block08/system.h (modified) * testsuites/libtests/block09/init.c (modified) * testsuites/libtests/block10/init.c (modified) * testsuites/libtests/capture01/system.h (modified) * testsuites/libtests/dl01/dl01-o1.c (modified) * testsuites/libtests/dl02/dl02-o1.c (modified) * testsuites/libtests/dl02/dl02-o2.c (modified) * testsuites/libtests/dl05/dl05-o5.cc (modified) * testsuites/libtests/dl06/dl06-o1.c (modified) * testsuites/libtests/dl06/dl06-o2.c (modified) * testsuites/libtests/dl07/dl07-o1.c (modified) * testsuites/libtests/dl07/dl07-o2.c (modified) * testsuites/libtests/dl07/dl07-o3.c (modified) * testsuites/libtests/dl07/dl07-o4.c (modified) * testsuites/libtests/dl07/dl07-o5.c (modified) * testsuites/libtests/dl08/dl08-o1.c (modified) * testsuites/libtests/dl08/dl08-o2.c (modified) * testsuites/libtests/dl08/dl08-o3.c (modified) * testsuites/libtests/dl08/dl08-o4.c (modified) * testsuites/libtests/dl08/dl08-o5.c (modified) * testsuites/libtests/dl08/dl08-o6-123456789-123456789.c (modified) * testsuites/libtests/dl09/dl09-o1.c (modified) * testsuites/libtests/dl09/dl09-o2.c (modified) * testsuites/libtests/dl09/dl09-o3.c (modified) * testsuites/libtests/dl09/dl09-o4.c (modified) * testsuites/libtests/dl09/dl09-o5.c (modified) * testsuites/libtests/dl10/dl10-o1.c (modified) * testsuites/libtests/dl10/dl10-o2.c (modified) * testsuites/libtests/dl10/dl10-o3.c (modified) * testsuites/libtests/dl10/dl10-o4.c (modified) * testsuites/libtests/dl10/dl10-o5.c (modified) * testsuites/libtests/dl10/dl10-o6.c (modified) * testsuites/libtests/mathl/init.c (modified) * testsuites/psxtests/psxbarrier01/main.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/psxtests/psxfenv01/init.c (modified) * testsuites/psxtests/psxinttypes01/init.c (modified) * testsuites/psxtests/psxndbm01/init.c (modified) * testsuites/psxtests/psxrwlock01/main.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/capture/system.h (modified) * testsuites/samples/cdtest/main.cc (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/fileio/system.h (modified) * testsuites/samples/iostream/system.h (modified) * testsuites/samples/nsecs/system.h (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/pppd/system.h (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/smptests/smpscheduler05/init.c (modified) * testsuites/smptests/smpscheduler06/init.c (modified) * testsuites/smptests/smpscheduler07/init.c (modified) * testsuites/sptests/spheapprot/init.c (modified) * testsuites/sptests/sptimecounter02/init.c (modified) * testsuites/sptests/sptimecounter03/init.c (modified) * testsuites/sptests/sptimecounter04/init.c (modified) * testsuites/support/include/buffer_test_io.h (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/tmfine01/init.c (modified) * testsuites/tmtests/tmonetoone/init.c (modified) libtest: to Rename this header ... Thu, 23 Jul 2020 06:42:59 GMT Sebastian Huber [33314eb] * bsps/powerpc/shared/clock/clock-ppc-dec.c (modified) * bsps/shared/dev/clock/clockimpl.h (modified) bsps/clock: Fix fast idle clock tick support If we interrupt a ... Tue, 21 Jul 2020 13:22:55 GMT Sebastian Huber [1fab972] * cpukit/include/rtems/score/threadimpl.h (modified) score: Improve _Thread_Start() description Thu, 09 Jul 2020 08:21:29 GMT Christian Mauderer [3a95a07d] * cpukit/include/rtems/media.h (modified) * cpukit/libblock/src/media.c (modified) media-server: Add ability for retry. This adds the possibility to ... Fri, 03 Jul 2020 12:31:47 GMT Jan Sommer [9cb107c9] * bsps/i386/pc386/start/smp-imps.c (modified) bsps/pc386: Fix IPI for non-consecutive APICIDs - properly use the ... Thu, 28 May 2020 13:48:35 GMT Sebastian Huber [a3ed4219] * cpukit/include/rtems/score/thread.h (modified) score: Remove deprecated Thread This type was deprecated in RTEMS ... Mon, 11 May 2020 13:10:19 GMT Sebastian Huber [53a5af2] * cpukit/include/rtems/score/basedefs.h (modified) rtems: Remove deprecated proc_ptr definition Close #3586. Mon, 11 May 2020 13:08:55 GMT Sebastian Huber [2adf328] * cpukit/include/rtems/rtems/types.h (modified) * cpukit/include/rtems/score/basedefs.h (modified) rtems: Remove support for RTEMS_DEPRECATED_TYPES Close #3584. Thu, 28 May 2020 13:36:23 GMT Sebastian Huber [312fcf2] * cpukit/include/rtems/rtems/types.h (modified) rtems: Remove rtems_thread_cpu_usage_t This type was deprecated in ... Thu, 28 May 2020 13:35:41 GMT Sebastian Huber [1546b1c0] * cpukit/include/rtems/rtems/types.h (modified) rtems: Remove region_information_block This type was deprecated in ... Thu, 28 May 2020 13:35:09 GMT Sebastian Huber [f8998f1] * cpukit/include/rtems/rtems/types.h (modified) rtems: Remove rtems_context_fp This type was deprecated in RTEMS ... Thu, 28 May 2020 13:34:23 GMT Sebastian Huber [df2dac3] * cpukit/include/rtems/rtems/types.h (modified) rtems: Remove rtems_context This type was deprecated in RTEMS 5.1. ... Thu, 28 May 2020 13:32:44 GMT Sebastian Huber [65dc040] * cpukit/include/rtems/rtems/ratemon.h (modified) rtems: Remove rtems_rate_monotonic_period_time_t This type was ... Thu, 28 May 2020 13:31:40 GMT Sebastian Huber [6a3fcd4] * cpukit/include/rtems/extension.h (modified) * cpukit/include/rtems/score/userext.h (modified) rtems: Remove deprecated rtems_extension This type was deprecated ... Thu, 28 May 2020 13:30:33 GMT Sebastian Huber [13a4b880] * cpukit/include/rtems/rtems/tasks.h (modified) rtems: Remove rtems_get_processor_count() This function was ... Thu, 28 May 2020 13:29:43 GMT Sebastian Huber [e4215e43] * cpukit/include/rtems/rtems/tasks.h (modified) rtems: Remove rtems_get_current_processor() This function was ... Thu, 28 May 2020 13:24:19 GMT Sebastian Huber [dc4879b] * cpukit/include/rtems/io.h (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * testsuites/sptests/sp21/init.c (modified) rtems: Remove deprecated rtems_io_lookup_name() Close #3420. Mon, 11 May 2020 06:27:45 GMT Sebastian Huber [39c2e28] * cpukit/headers.am (modified) * cpukit/include/rtems.h (modified) * cpukit/include/rtems/system.h (deleted) rtems: Remove deprecated Close #3980.
