# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/17/24 04:07:46 Thu, 11 May 2017 10:54:46 GMT Daniel Hellstrom [818f10bc] * c/src/lib/libbsp/sparc/shared/tmtc/grtc.c (modified) leon, grtc: updated overrun condition handling The following ... Wed, 10 May 2017 10:39:23 GMT Daniel Hellstrom [6fdded2c] * c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c (modified) leon, gr1553bm: SMP support by using spin-locks Wed, 10 May 2017 08:46:01 GMT Daniel Hellstrom [3feae3b] * c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c (modified) leon, gr1553bc: SMP support by using spin-locks Since DMA buffers ... Tue, 09 May 2017 14:00:56 GMT Daniel Hellstrom [84e4d10c] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart.c (deleted) leon, apbuart: remove old RAW UART driver This driver was initially ... Tue, 09 May 2017 11:13:44 GMT Daniel Hellstrom [c92f402c] * c/src/lib/libbsp/sparc/shared/tmtc/grtm.c (modified) leon, grtm: SMP support by using spin-locks Mon, 08 May 2017 14:10:14 GMT Daniel Hellstrom [f767fe74] * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) leon, ahbstat: remove printf warnings Mon, 08 May 2017 12:58:41 GMT Daniel Hellstrom [ce76b9d2] * c/src/lib/libbsp/sparc/shared/pci/gr_701.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c (modified) * c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c (modified) leon, pci-peripherals: SMP support by spin-locks and updated genirq Fri, 05 May 2017 13:42:45 GMT Daniel Hellstrom [8670c464] * c/src/lib/libbsp/sparc/shared/include/genirq.h (modified) * c/src/lib/libbsp/sparc/shared/irq/genirq.c (modified) leon, genirq: SMP support for PCI peripherals The common interrupt ... Mon, 24 Apr 2017 14:39:49 GMT Martin Aberg [aa19873] * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) leon: allow SMP boot from any CPU Thu, 13 Apr 2017 12:12:31 GMT Martin Aberg [039edd2a] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: removed unused txerror, rxerror Thu, 13 Apr 2017 12:06:04 GMT Martin Aberg [ee078c21] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: fixed historical comment Tue, 11 Apr 2017 10:30:02 GMT Daniel Hellstrom [91541551] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: semaphore reset count required after flushing It is ... Tue, 11 Apr 2017 08:47:39 GMT Daniel Hellstrom [9855690] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: split hw_stop() into hw and sw stop this is to avoid ... Thu, 13 Apr 2017 12:08:50 GMT Martin Aberg [3a650d3b] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: RTEMS_NO_TIMEOUT on tx_sem Mon, 03 Apr 2017 11:27:49 GMT Martin Aberg [2d3d8f96] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) leon, grcan: redesigned bus-off and AHB error handling When bus-off ... Thu, 09 Mar 2017 14:44:08 GMT Daniel Hellstrom [ca4c4164] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) leon, grcan: updated device name and use it for ISR Thu, 26 Jan 2017 10:01:10 GMT Martin Aberg [05749690] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: fixed race on interrupt mask register There was a ... Thu, 26 Jan 2017 09:54:57 GMT Martin Aberg [5d367c56] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: unregister interrupt handler at close Mon, 13 Mar 2017 11:44:58 GMT Martin Aberg [c297060] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: protect statistics on copy to user Locking the stats ... Thu, 26 Jan 2017 09:52:31 GMT Martin Aberg [7b8a920] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) leon, grcan: use RTEMS 4.12 SMP interrupt lock Tue, 24 Jan 2017 10:16:41 GMT Martin Aberg [bc40b4d] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) leon, grcan: consistent indentation This commit does not contain ... Tue, 24 Jan 2017 09:00:07 GMT Martin Aberg [ad203e58] * c/src/lib/libbsp/sparc/shared/can/grcan.c (modified) * c/src/lib/libbsp/sparc/shared/include/grcan.h (modified) leon, grcan: function based user interface This commit preserves ... Thu, 27 Apr 2017 11:14:53 GMT Martin Aberg [229c4249] * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) bsp/leon3: Cleaner namespace for LEON3 debug UART Prefix BSP ... Tue, 25 Apr 2017 07:10:03 GMT Daniel Hellstrom [011efee8] * c/src/lib/libbsp/sparc/shared/irq/irq-shared.c (modified) leon, irq: single CPU SMP configuration does not need IPI ISR Tue, 25 Apr 2017 13:26:18 GMT Daniel Hellstrom [fa27fe5c] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: new option and change soft-reset logic for EDCL Mon, 24 Apr 2017 14:36:16 GMT Daniel Hellstrom [8ac070a] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: 10/100 modes should be assigned in fastest priority Mon, 24 Apr 2017 14:32:17 GMT Daniel Hellstrom [e6fbd26] * c/src/lib/libbsp/sparc/shared/include/greth.h (modified) * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: speed modes advertising now configurable Mon, 24 Apr 2017 13:10:41 GMT Daniel Hellstrom [12718134] * c/src/lib/libbsp/sparc/shared/include/greth.h (modified) * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: EDCL and DD is disabled during reset The EDCL and ... Sun, 07 May 2017 20:52:50 GMT Phong Pham [a9859d1] * c/src/lib/libbsp/shared/src/irq-generic.c (modified) interrupt vector indexing is assuming BSP_INTERRUPT_VECTOR_MIN = 0 ... Sun, 07 May 2017 21:13:24 GMT Phong Pham [f219adc] * c/src/libchip/serial/ns16550_p.h (modified) missing a couple register names + a #ifndef_ASM__ around serial.h ... Fri, 12 May 2017 08:08:34 GMT Sebastian Huber [00d98208] * testsuites/sptests/spprivenv01/init.c (modified) sptests/spprivenv01: Use default task mode There is no need to run ... Fri, 12 May 2017 06:35:36 GMT Sebastian Huber [f778b7f3] * cpukit/sapi/include/confdefs.h (modified) * testsuites/sptests/sp65/init.c (modified) confdefs.h: Use SMP scheduler only if necessary Update #3001. Thu, 11 May 2017 09:03:00 GMT Sebastian Huber [13097181] * cpukit/sapi/include/confdefs.h (modified) * testsuites/libtests/block08/system.h (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/spfatal29/testcase.h (modified) * testsuites/sptests/spintrcritical06/init.c (modified) * testsuites/sptests/spintrcritical15/init.c (modified) * testsuites/sptests/spmrsp01/init.c (modified) * testsuites/sptests/spsimplesched02/init.c (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm24/system.h (modified) confdefs.h: CONFIGURE_DISABLE_SMP_CONFIGURATION Enable the SMP ... Thu, 11 May 2017 07:53:05 GMT Sebastian Huber [0e494170] * c/src/lib/libbsp/arm/shared/include/arm-gic.h (modified) bsps/arm: Fix bit field offset in GIC support Update #3002. Wed, 10 May 2017 03:36:55 GMT Chris Johns [900c407] * testsuites/automake/subdirs.am (modified) testsuites: Build the tests in parallel if make is asked too. Wed, 10 May 2017 03:34:55 GMT Chris Johns [6130a47] * testsuites/libtests/dl01/Makefile.am (modified) * testsuites/libtests/dl02/Makefile.am (modified) * testsuites/libtests/dl04/Makefile.am (modified) * testsuites/libtests/dl05/Makefile.am (modified) * testsuites/libtests/mghttpd01/Makefile.am (modified) * testsuites/libtests/tar01/Makefile.am (modified) * testsuites/libtests/tar02/Makefile.am (modified) testsuites: Fix build dependences for generated files. Wed, 15 Mar 2017 18:31:00 GMT Gedare Bloom [87de70a2] * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/posix/include/rtems/posix/mmanimpl.h (modified) * cpukit/posix/include/rtems/posix/shm.h (modified) * cpukit/posix/include/rtems/posix/shmimpl.h (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) * cpukit/posix/src/shmheap.c (modified) * cpukit/posix/src/shmopen.c (modified) * cpukit/posix/src/shmunlink.c (modified) * cpukit/posix/src/shmwkspace.c (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/psxtests/psxshm02/system.h (modified) posix/mman: add mmap support for shm objects Update #2859. Mon, 13 Mar 2017 16:00:35 GMT Chris Johns [8290f95c] * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/mmanimpl.h (added) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/mmap.c (modified) * cpukit/posix/src/munmap.c (modified) posix: Add mmap/unmap support for mapping files. This version of ... Fri, 31 Mar 2017 19:23:47 GMT Gedare Bloom [bd9d5eb] * cpukit/posix/include/rtems/posix/shmimpl.h (modified) * cpukit/posix/src/shmopen.c (modified) posix/shm: replace threadq with mutex (allocator lock) Closes #2957. Wed, 15 Mar 2017 18:29:19 GMT Gedare Bloom [889eb76] * cpukit/posix/include/rtems/posix/shmimpl.h (modified) * cpukit/posix/src/shmopen.c (modified) posix/mman: update atime on shared memory read call Update #2859. Tue, 02 May 2017 08:19:34 GMT Sebastian Huber [e0627c69] * cpukit/configure.ac (modified) cpukit: Fix __RTEMS_REVISION__ define Thu, 13 Apr 2017 19:23:28 GMT Daniel Hellstrom [430949aa] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: let Gbit full duplex override half Thu, 13 Apr 2017 12:57:01 GMT Daniel Hellstrom [998e34ad] * c/src/lib/libbsp/sparc/shared/net/greth.c (modified) leon, greth: SMP support by using spin-lock protection Tue, 11 Apr 2017 11:55:02 GMT Martin Aberg [8927c0f] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, gptimer: offset intnum with subtimer index If separate ... Mon, 10 Apr 2017 17:07:04 GMT Martin Aberg [256e083f] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, gptimer: fixed probing separate interrupts Probing of ... Wed, 08 Mar 2017 11:59:07 GMT Javier Jalle [6234abe] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/l4stat.h (added) * c/src/lib/libbsp/sparc/shared/stat/l4stat.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, l4stat: Initial driver commit Tue, 07 Mar 2017 11:50:48 GMT Javier Jalle [21b3319f] * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp: Added L4STAT driver to ambapp ids Mon, 06 Mar 2017 12:08:04 GMT Martin Aberg [a8595605] * c/src/lib/libbsp/sparc/shared/can/occan.c (modified) leon, occan: Converted disable/enable to SMP locks This commit ... Thu, 19 Jan 2017 17:57:58 GMT Martin Aberg [c609ccea] * c/src/lib/libbsp/sparc/shared/amba/ahbstat.c (modified) leon, ahbstat: Use RTEMS 4.12 SMP interrupt lock Wed, 15 Mar 2017 13:38:21 GMT Javier Jalle [c241236] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) * c/src/lib/libbsp/sparc/shared/include/memscrub.h (added) * c/src/lib/libbsp/sparc/shared/scrub/memscrub.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, memscrub: add GR740 memory scrubber driver Wed, 15 Mar 2017 14:04:33 GMT Javier Jalle [d79429f] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/griommu.h (added) * c/src/lib/libbsp/sparc/shared/iommu/griommu.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, griommu: add GR740 IOMMU driver The driver is limited to the ... Wed, 15 Feb 2017 15:51:33 GMT Javier Jalle [3e948cc] * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp: Added GRIOMMU driver to ambapp ids Tue, 21 Feb 2017 08:14:46 GMT Javier Jalle [dfa86338] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/l2c.h (added) * c/src/lib/libbsp/sparc/shared/l2c/l2c.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) leon, l2cache: add GR740 L2-Cache driver Wed, 15 Mar 2017 13:58:04 GMT Javier Jalle [d24ed54] * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp: Added L2CACHE driver to ambapp ids Thu, 09 Feb 2017 13:09:17 GMT Javier Jalle [93c5e63] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/grpci2dma.h (added) * c/src/lib/libbsp/sparc/shared/pci/grpci2dma.c (added) leon, grpci2dma: add GR740 PCI DMA driver Wed, 15 Feb 2017 10:14:13 GMT Javier Jalle [31ba1f21] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) leon, grpci2: prepare for GRPCI2DMA driver Wed, 15 Feb 2017 10:09:23 GMT Javier Jalle [8e45d55] * c/src/lib/libbsp/sparc/shared/pci/grpci2.c (modified) leon, grpci2: Make driver SMP safe Fri, 17 Mar 2017 13:44:25 GMT Daniel Hellstrom [9631e5a9] * c/src/lib/libbsp/sparc/shared/amba/ambapp_names.c (modified) * c/src/lib/libbsp/sparc/shared/include/ambapp_ids.h (modified) leon, ambapp: updated AMBA PnP IDs and names database Tue, 14 Mar 2017 16:46:12 GMT Martin Aberg [e5e44bdb] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: Wait for shift register on close Do not disable ... Tue, 14 Mar 2017 16:27:57 GMT Martin Aberg [6860ddb] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: Optimized RX processing in ISR Limit the number of ... Mon, 13 Mar 2017 09:53:47 GMT Martin Aberg [3df6710] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: support termios task driven mode The APBUART control ... Fri, 10 Mar 2017 14:32:38 GMT Martin Aberg [f164a294] * c/src/lib/libbsp/sparc/shared/include/cons.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libbsp/sparc/shared/uart/cons.c (modified) leon, apbuart: Inherit HW parameters on sysconsole The cons layer ... Fri, 10 Mar 2017 13:03:11 GMT Martin Aberg [6e2e1299] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: Assign proper device name Always assign a ... Thu, 09 Mar 2017 17:51:47 GMT Martin Aberg [1fefc719] * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) leon, apbuart: RX delayed interrupt Utilize the APBUART RX delayed ... Wed, 01 Feb 2017 15:48:51 GMT Martin Aberg [fd9fb21] * c/src/lib/libbsp/sparc/shared/include/cons.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c (modified) * c/src/lib/libbsp/sparc/shared/uart/cons.c (modified) leon, cons: drvmgr cons interface uses new TERMIOS LEON driver ... Mon, 06 Mar 2017 10:14:23 GMT Martin Aberg [7cb93250] * c/src/lib/libbsp/sparc/shared/include/apbuart.h (modified) leon, apbuart: added register defines: FIFO, delay int The FIFOs ... Thu, 23 Feb 2017 15:33:21 GMT Martin Aberg [f600458d] * c/src/lib/libbsp/sparc/shared/include/tlib.h (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) leon, clock: new driver manager clock driver - Compatible with SMP ... Mon, 10 Apr 2017 12:52:16 GMT Daniel Hellstrom [78e56096] * c/src/lib/libbsp/sparc/shared/include/tlib.h (modified) * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, tlib: added timer width mask information Fri, 07 Apr 2017 06:31:48 GMT Daniel Hellstrom [ae203e0d] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_grlib.c (modified) * c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h (modified) leon, ambapp_bus: IRQ affinity for on-chip AMBAPP bus Fri, 07 Apr 2017 06:30:46 GMT Daniel Hellstrom [7075fb11] * cpukit/libdrvmgr/drvmgr.h (modified) * cpukit/libdrvmgr/drvmgr_drvinf.c (modified) drvmgr: ability to configure IRQ affinity Tue, 31 Jan 2017 09:13:41 GMT Javier Jalle [61788e76] * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/shared/include/gr_cpci_gr740.h (added) * c/src/lib/libbsp/sparc/shared/pci/gr_cpci_gr740.c (added) * cpukit/libdrvmgr/drvmgr_confdefs.h (modified) * cpukit/libpci/pci/ids_extra.h (modified) * cpukit/libpci/pci_bus.h (modified) leon, GR-CPCI-GR740: Added peripheral PCI driver Tue, 02 May 2017 06:06:12 GMT Sebastian Huber [6b42018e] * cpukit/libmisc/shell/print_heapinfo.c (modified) shell: Fix format specifiers Sat, 29 Apr 2017 13:20:28 GMT Pavel Pisa [0e6542fb] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/include/tms570lc4357-pins.h (added) bsp/tms570: include package balls and PINMMR registers mapping for ... Fri, 28 Apr 2017 16:11:14 GMT Joel Sherrill [20775247] * cpukit/include/rtems/inttypes.h (modified) rtems/inttypes.h: Add PRIdrtems_vector_number. Missed in previous commit Thu, 27 Apr 2017 23:52:01 GMT Joel Sherrill [12f9c5b7] * cpukit/posix/src/mutexinit.c (modified) posix/src/mutexinit.c: Reorder to make priority a scoped variable Wed, 26 Apr 2017 20:42:09 GMT Joel Sherrill [c16d45a5] * cpukit/posix/src/mutexinit.c (modified) posix/src/mutexinit.c: Reorder to make priority a scoped variable Wed, 26 Apr 2017 15:53:56 GMT Joel Sherrill [61568e6] * c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c (modified) virtex5/startup/dummy_console.c: Use and ... Wed, 26 Apr 2017 15:53:40 GMT Joel Sherrill [78eb6132] * testsuites/benchmarks/dhrystone/dhry_1.c (modified) dhrystone/dhry_1.c: Move assignment to before start of timer Wed, 26 Apr 2017 15:50:08 GMT Joel Sherrill [c0ea829] * c/src/lib/libbsp/powerpc/virtex4/startup/dummy_console.c (modified) virtex4/startup/dummy_console.c: Use and ... Wed, 26 Apr 2017 03:11:55 GMT Joel Sherrill [b73b952] * testsuites/libtests/block08/bdbuf_tests.c (modified) block08/bdbuf_tests.c: Add include of Wed, 26 Apr 2017 01:14:28 GMT Joel Sherrill [9e6ef36] * cpukit/include/rtems/inttypes.h (modified) * testsuites/libtests/block08/bdbuf_tests.c (modified) rtems/inttypes.h, block08: Add and use PRIdrtems_blkdev_bnum Wed, 26 Apr 2017 01:02:09 GMT Joel Sherrill [03e4be12] * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) score/cpu/or1k/rtems/score/cpu.h: Fix printf() format warning Wed, 26 Apr 2017 01:01:41 GMT Joel Sherrill [65807379] * cpukit/score/cpu/or1k/or1k-exception-frame-print.c (modified) score/cpu/or1k/or1k-exception-frame-print.c: Fix printf() format warning Wed, 26 Apr 2017 01:01:10 GMT Joel Sherrill [ab77827] * c/src/lib/libbsp/or1k/generic_or1k/irq/irq.c (modified) or1k/generic_or1k/irq/irq.c: Include and fix ... Tue, 25 Apr 2017 18:57:21 GMT Joel Sherrill [c723ee4] * cpukit/libdl/rtl-obj-cache.c (modified) libdl/rtl-obj-cache.c: Fix printf() format warning Tue, 25 Apr 2017 18:57:03 GMT Joel Sherrill [6601684f] * cpukit/posix/src/mutexinit.c (modified) posix/src/mutexinit.c: Fix used before initialized warning Tue, 25 Apr 2017 18:56:31 GMT Joel Sherrill [f6bd41e] * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) moxie/rtems/score/cpu.h: Fix printf() format warning Tue, 25 Apr 2017 18:39:50 GMT Joel Sherrill [fdfbb0a8] * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) epiphany/rtems/score/cpu.h: Fix printf() format warning Tue, 25 Apr 2017 16:42:18 GMT Joel Sherrill [7db09923] * c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c (modified) * cpukit/include/rtems/inttypes.h (modified) rtems/inttypes.h epiphany_sim/irq/irq.c: Add PRIdrtems_vector_number ... Tue, 25 Apr 2017 16:41:35 GMT Joel Sherrill [28e5749e] * cpukit/score/cpu/epiphany/cpu.c (modified) epiphany/cpu.c: Fix typo to eliminate warning Tue, 25 Apr 2017 16:40:21 GMT Joel Sherrill [786c365] * testsuites/psxtests/Makefile.am (modified) psxtests/Makefile.am: Disable tests which should not be built when ... Tue, 25 Apr 2017 16:22:25 GMT Joel Sherrill [55b967a] * testsuites/libtests/devnullfatal01/testcase.h (modified) devnullfatal01/testcase.h: Avoid redefinition of TESTS_USE_PRINTK Mon, 24 Apr 2017 17:00:43 GMT Joel Sherrill [b261dec] * cpukit/libmisc/xz/xz_config.h (modified) xz/xz_config.h: Address unable to inline warning Mon, 24 Apr 2017 17:00:15 GMT Joel Sherrill [485222e] * c/src/lib/libbsp/m68k/genmcf548x/irq/irq.c (modified) genmcf548x/irq/irq.c: Fix incompatible pointer warning Mon, 24 Apr 2017 16:18:47 GMT Joel Sherrill [3144292b] * cpukit/libdl/rtl-obj-cache.c (modified) libdl/rtl-obj-cache.c: Use PRIdoff_t to avoid printf() format ... Mon, 24 Apr 2017 16:18:03 GMT Joel Sherrill [0d01cdd6] * c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c (modified) sh/sh7750/sci/sh4uart.c: ix misleading indentation warning Mon, 24 Apr 2017 16:17:41 GMT Joel Sherrill [646df54c] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) powerpc/new-exceptions/bspsupport/ppc_exc_print.c: Fix printf() ... Mon, 24 Apr 2017 16:17:12 GMT Joel Sherrill [2808c26] * c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c (modified) powerpc/mpc5xx/console-generic/console-generic.c: Use updated struct ... Mon, 24 Apr 2017 16:16:37 GMT Joel Sherrill [3ed2cf60] * c/src/lib/libbsp/sparc/leon2/console/debugputs.c (modified) leon2/console/debugputs.c: Fix misleading indentation warning Mon, 24 Apr 2017 16:15:53 GMT Joel Sherrill [fd48b43] * c/src/lib/libbsp/powerpc/virtex5/startup/dummy_console.c (modified) virtex5/startup/dummy_console.c: Fix no prototype warning
