# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 19:46:05 Sat, 13 Jun 2015 13:29:04 GMT Sebastian Huber [80fca28] * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/timercreate.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/sptests/spwatchdog/init.c (modified) score: Add _Watchdog_Preinitialize() Add an assert to ensure that ... Sat, 13 Jun 2015 12:49:23 GMT Sebastian Huber [258d580c] * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/src/watchdogremove.c (modified) score: Delete unused state WATCHDOG_REMOVE_IT Fri, 12 Jun 2015 11:57:15 GMT Sebastian Huber [0562060] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sptasknopreempt01/Makefile.am (added) * testsuites/sptests/sptasknopreempt01/init.c (added) * testsuites/sptests/sptasknopreempt01/sptasknopreempt01.doc (added) * testsuites/sptests/sptasknopreempt01/sptasknopreempt01.scn (added) sptests/sptasknopreempt01: New test Update #2365. Tue, 09 Jun 2015 20:48:22 GMT Joel Sherrill [becbeda] * c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/console/fb_vga.c (modified) pc386/console/fb*.c: Use atomics to avoid dependency on pthreads ... Thu, 11 Jun 2015 08:44:18 GMT Sebastian Huber [aa2a62c] * cpukit/rtems/include/rtems/rtems/attrimpl.h (modified) rtems: Do not switch off the FP attribute This is necessary after ... Thu, 11 Jun 2015 07:56:18 GMT Sebastian Huber [f718e79] * cpukit/score/src/kern_tc.c (modified) Revert "timecounter: No _Timecounter_Tick_simple() for SMP" This ... Tue, 09 Jun 2015 19:31:27 GMT Sebastian Huber [46ae1d7a] * cpukit/score/src/kern_tc.c (modified) timecounter: No _Timecounter_Tick_simple() for SMP Tue, 09 Jun 2015 17:54:26 GMT Gedare Bloom [6f55315] * cpukit/rtems/include/rtems/rtems/clock.h (modified) cpukit/rtems: Fix doc for rtems_clock_get_ticks_per_second closes #2357. Tue, 09 Jun 2015 15:46:23 GMT Gedare Bloom [fecc911] * doc/user/conf.t (modified) doc: fix typo. closes #2361. Tue, 09 Jun 2015 11:49:56 GMT kib [e1d61fe] * cpukit/score/src/kern_tc.c (modified) timecounter: Synchronize with FreeBSD When updating/accessing the ... Mon, 04 May 2015 17:59:39 GMT ian [7e1a9ac] * cpukit/score/src/kern_tc.c (modified) timecounter: Synchronize with FreeBSD Implement a mechanism for ... Sat, 14 Mar 2015 23:16:12 GMT ian [cb6fde65] * cpukit/score/src/kern_tc.c (modified) timecounter: Synchronize with FreeBSD Use sbuf_printf() for sysctl ... Sat, 07 Mar 2015 18:23:32 GMT hselasky [b5b8116] * cpukit/score/src/kern_tc.c (modified) timecounter: Synchronize with FreeBSD Add mutex support to the ... Tue, 02 Jun 2015 19:41:26 GMT Sebastian Huber [2ccd150d] * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sptimecounter03/Makefile.am (added) * testsuites/sptests/sptimecounter03/init.c (added) * testsuites/sptests/sptimecounter03/sptimecounter03.doc (added) * testsuites/sptests/sptimecounter03/sptimecounter03.scn (added) sptests/sptimecounter03: New test Tue, 09 Jun 2015 12:52:53 GMT Sebastian Huber [7919f70] * cpukit/score/include/rtems/score/cpustdatomic.h (modified) score: Fix compiler memory barriers for atomic ops Tue, 09 Jun 2015 05:45:51 GMT Sebastian Huber [30f8412] * c/src/lib/libbsp/sparc/shared/timer/tlib_ckinit.c (modified) bsps/sparc: tlib clock driver timecounter support Tue, 09 Jun 2015 07:28:36 GMT Sebastian Huber [b88d346f] * testsuites/sptests/spcontext01/init.c (modified) sptests/spcontext01: Add second volatile clobber Do a volatile ... Sat, 30 May 2015 15:48:27 GMT Sebastian Huber [a51b352] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Add SPARC_USE_SAFE_FP_SUPPORT The SPARC ABI is a bit special ... Tue, 02 Jun 2015 19:43:54 GMT Sebastian Huber [335e5ca] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) score: Add Thread_Control::is_fp Store the floating-point unit ... Wed, 03 Jun 2015 08:07:23 GMT Sebastian Huber [b2765075] * testsuites/sptests/spcontext01/init.c (modified) * testsuites/sptests/spcontext01/spcontext01.scn (modified) sptests/spcontext01: Improve output Tue, 02 Jun 2015 22:20:54 GMT Sebastian Huber [f455cdea] * cpukit/score/include/rtems/score/context.h (modified) rtems: Change CONTEXT_FP_SIZE define Define CONTEXT_FP_SIZE to zero ... Tue, 02 Jun 2015 12:32:58 GMT Sebastian Huber [43d7005] * testsuites/smptests/smpscheduler02/init.c (modified) smptests/smpscheduler02: Reduce required CPU count Tue, 02 Jun 2015 12:22:03 GMT Sebastian Huber [2c14e67] * testsuites/smptests/smpmrsp01/init.c (modified) smptests/smpmrsp01: Reduce required CPU count Tue, 02 Jun 2015 12:10:05 GMT Sebastian Huber [f48b73de] * testsuites/smptests/smpscheduler03/init.c (modified) smptests/smpscheduler03: Use proper lock Tue, 02 Jun 2015 12:01:29 GMT Sebastian Huber [863dcf4] * cpukit/score/src/threaddispatchdisablelevel.c (modified) score: Remove assert With the introduction of fine grained locking ... Tue, 02 Jun 2015 11:57:35 GMT Sebastian Huber [f9a2d36] * cpukit/posix/src/timerinserthelper.c (modified) posix: Fix _POSIX_Timer_Insert_helper() locking Close #2358. Fri, 29 May 2015 13:54:27 GMT Alexander Krutwig [2764bd43] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Disable FPU in interrupt context Update #2270. Fri, 29 May 2015 13:54:29 GMT Sebastian Huber [1f6cdba6] * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc: Remove superfluous FP enable The FP context save/restore ... Fri, 29 May 2015 13:54:28 GMT Sebastian Huber [8a1dc71b] * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc: Avoid new window for FP save/restore Update #2270. Fri, 29 May 2015 19:20:31 GMT Sebastian Huber [18d18e1] * testsuites/tmtests/tm26/task1.c (modified) tmtests/tm26: Fix context switch to FP task It is wrong to restore ... Fri, 29 May 2015 15:51:38 GMT Sebastian Huber [b17fb17a] * testsuites/tmtests/tm26/task1.c (modified) Revert "tmtests/tm26: Avoid NULL pointer access" There is no NULL ... Fri, 29 May 2015 08:18:19 GMT Alexander Krutwig [4a5a4504] * cpukit/score/cpu/sparc/sparc-context-validate.S (modified) sparc: Improve _CPU_Context_validate() Write the pattern only once ... Fri, 29 May 2015 12:18:32 GMT Sebastian Huber [5611839] * testsuites/tmtests/tm26/task1.c (modified) tmtests/tm26: Avoid NULL pointer access Fri, 29 May 2015 13:03:02 GMT Sebastian Huber [8f6a3145] * cpukit/posix/src/clockgettime.c (modified) posix: Fix clock_gettime() The ... Fri, 29 May 2015 06:59:41 GMT Sebastian Huber [aff220d] * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) bsps/powerpc: Fix potential integer overflow Update #2356. Tue, 19 May 2015 14:56:28 GMT Ben Gras [3b8e395] * MAINTAINERS (modified) MAINTAINERS: added self Sun, 03 May 2015 09:55:55 GMT ragunath [d55d7a0] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/rtc.c (added) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) * c/src/lib/libcpu/arm/shared/include/omap3.h (modified) beagle bsp: RTC support for BBB Tue, 10 Mar 2015 13:54:30 GMT Gedare Bloom [92422be] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: avoid buffer-overread. closes #2292. Wed, 27 May 2015 10:48:22 GMT Sebastian Huber [9d0913d1] * testsuites/libtests/i2c01/init.c (modified) libtests/i2c01: Avoid stack overflow Wed, 27 May 2015 09:43:44 GMT Sebastian Huber [ec84273d] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/apimutex.h (modified) * cpukit/score/src/apimutexisowner.c (moved) * testsuites/support/include/tmacros.h (modified) score: Replace _API_Mutex_Is_locked() Replace ... Wed, 27 May 2015 08:46:30 GMT Sebastian Huber [ffe14b26] * cpukit/sapi/include/confdefs.h (modified) sapi: Fix workspace size estimate Reserve a full minimum block to ... Wed, 27 May 2015 07:04:25 GMT Sebastian Huber [3f1bf0c] * cpukit/sapi/include/confdefs.h (modified) sapi: Fix workspace size estimate Wed, 27 May 2015 06:55:51 GMT Sebastian Huber [67901a82] * cpukit/sapi/include/confdefs.h (modified) sapi: Simplify confdefs.h The _Configure_From_workspace() already ... Tue, 26 May 2015 13:17:50 GMT Sebastian Huber [ee4e7f0] * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/preinstall.am (modified) * cpukit/wrapup/Makefile.am (modified) * testsuites/fstests/jffs2_fserror/Makefile.am (modified) * testsuites/fstests/jffs2_fslink/Makefile.am (modified) * testsuites/fstests/jffs2_fspatheval/Makefile.am (modified) * testsuites/fstests/jffs2_fspermission/Makefile.am (modified) * testsuites/fstests/jffs2_fsrdwr/Makefile.am (modified) * testsuites/fstests/jffs2_fsscandir01/Makefile.am (modified) * testsuites/fstests/jffs2_fssymlink/Makefile.am (modified) * testsuites/fstests/jffs2_fstime/Makefile.am (modified) jffs2: Move into separate library In case the zlib compression was ... Mon, 25 May 2015 17:09:35 GMT Hesham ALMatary [5774c414] * c/src/lib/libbsp/or1k/generic_or1k/include/irq.h (modified) generic_or1k: Fix a typo in a comment Mon, 25 May 2015 17:09:18 GMT Hesham ALMatary [5b1a10a] * c/src/lib/libbsp/or1k/generic_or1k/bsp_specs (modified) * c/src/lib/libbsp/or1k/generic_or1k/start/start.S (modified) generic_or1k: Use the correct bsp_specs file Sat, 23 May 2015 17:32:35 GMT Jan Dolezal [6f793108] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) i386/pc386: default graphics driver changed from VGA to VESA based ... Sat, 23 May 2015 17:32:00 GMT Jan Dolezal [56399c3b] * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/fb_default_mode.h (added) * c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (modified) i386/pc386/VESA framebuffer driver: modified and extended ... Tue, 26 May 2015 15:17:03 GMT Joel Sherrill [7c5f37d] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/include/rtems/endian.h (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * testsuites/sptests/spcontext01/init.c (modified) * testsuites/sptests/spcontext01/spcontext01.scn (modified) Merge branch 'master' of ssh://dispatch.rtems.org/data/git/rtems Tue, 26 May 2015 12:13:44 GMT Sebastian Huber [76030c7] * cpukit/score/cpu/sparc/cpu.c (modified) sparc: Add static assertion Tue, 26 May 2015 12:09:11 GMT Sebastian Huber [422de7f7] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc: Delete unused CONTEXT_CONTROL_SIZE Tue, 26 May 2015 12:08:11 GMT Sebastian Huber [139c0dc] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) sparc: Delete unused ISF_STACK_FRAME_OFFSET Tue, 26 May 2015 12:03:35 GMT Sebastian Huber [fedc6828] * cpukit/score/cpu/sparc/cpu.c (modified) sparc: Add static offset assertions Tue, 19 May 2015 12:40:17 GMT Alexander Krutwig [cba07fc] * testsuites/sptests/spcontext01/init.c (modified) * testsuites/sptests/spcontext01/spcontext01.scn (modified) sptests/spcontext01: Test deferred FP context Tue, 26 May 2015 08:02:27 GMT Sebastian Huber [1045422] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) bsps/sparc: Delete unused local labels Tue, 26 May 2015 08:01:29 GMT Sebastian Huber [26ffb8c2] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) bsps/sparc: Change tabs to spaces Fri, 22 May 2015 06:17:37 GMT Sebastian Huber [1cfae28] * cpukit/include/rtems/endian.h (modified) rtems/endian.h: Reduce header dependencies Thu, 21 May 2015 23:08:32 GMT Joel Sherrill [24acc6d] * SUPPORT (deleted) * VERSION (deleted) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/bsp_specs (modified) * c/src/lib/libbsp/arm/beagle/bsp_specs (modified) * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/csb336/bsp_specs (modified) * c/src/lib/libbsp/arm/csb337/bsp_specs (modified) * c/src/lib/libbsp/arm/edb7312/bsp_specs (modified) * c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/gba/bsp_specs (modified) * c/src/lib/libbsp/arm/gba/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/bsp_specs (modified) * c/src/lib/libbsp/arm/gp32/bsp_specs (modified) * c/src/lib/libbsp/arm/gumstix/bsp_specs (modified) * c/src/lib/libbsp/arm/lm3s69xx/bsp_specs (modified) * c/src/lib/libbsp/arm/lpc176x/bsp_specs (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc24xx/bsp_specs (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc32xx/bsp_specs (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/nds/bsp_specs (modified) * c/src/lib/libbsp/arm/nds/clock/clock.c (modified) * c/src/lib/libbsp/arm/raspberrypi/bsp_specs (modified) * c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs (modified) * c/src/lib/libbsp/arm/rtl22xx/bsp_specs (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (modified) * c/src/lib/libbsp/arm/smdk2410/bsp_specs (modified) * c/src/lib/libbsp/arm/stm32f4/bsp_specs (modified) * c/src/lib/libbsp/arm/tms570/bsp_specs (modified) * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/bsp_specs (modified) * c/src/lib/libbsp/bfin/TLL6527M/bsp_specs (modified) * c/src/lib/libbsp/bfin/bf537Stamp/bsp_specs (modified) * c/src/lib/libbsp/bfin/eZKit533/bsp_specs (modified) * c/src/lib/libbsp/epiphany/Makefile.am (added) * c/src/lib/libbsp/epiphany/acinclude.m4 (added) * c/src/lib/libbsp/epiphany/configure.ac (added) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (added) * c/src/lib/libbsp/epiphany/epiphany_sim/README (added) * c/src/lib/libbsp/epiphany/epiphany_sim/bsp_specs (added) * c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac (added) * c/src/lib/libbsp/epiphany/epiphany_sim/console/console-io.c (added) * c/src/lib/libbsp/epiphany/epiphany_sim/include/bsp.h (added) * c/src/lib/libbsp/epiphany/epiphany_sim/include/bspopts.h (added) * c/src/lib/libbsp/epiphany/epiphany_sim/include/irq.h (added) * c/src/lib/libbsp/epiphany/epiphany_sim/include/tm27.h (added) * c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c (added) * c/src/lib/libbsp/epiphany/epiphany_sim/make/custom/epiphany_sim.cfg (added) * c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am (added) * c/src/lib/libbsp/epiphany/epiphany_sim/start/start.S (added) * c/src/lib/libbsp/epiphany/epiphany_sim/startup/linkcmds (added) * c/src/lib/libbsp/epiphany/epiphany_sim/timer/timer.c (added) * c/src/lib/libbsp/epiphany/preinstall.am (added) * c/src/lib/libbsp/epiphany/shared/include/linker-symbols.h (added) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/m32r/m32rsim/bsp_specs (modified) * c/src/lib/libbsp/m68k/av5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/gen68360/clock/clock.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/mips/csb350/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/genmongoosev/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4925/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/shared/clock/clockdrv.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/clock/clock.c (modified) * c/src/lib/libbsp/or1k/generic_or1k/clock/clockdrv.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh1-testsuite.tcfg (modified) * c/src/lib/libbsp/sh/shsim/make/custom/simsh2e-testsuite.tcfg (modified) * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) * c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) * cpukit/configure.ac (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libcsupport/src/kill_noposix.c (modified) * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/libcsupport/src/sup_fs_location.c (modified) * cpukit/libcsupport/src/umask.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) * cpukit/posix/include/rtems/posix/rwlockimpl.h (modified) * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/condinit.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/mqueuerecvsupp.c (modified) * cpukit/posix/src/mqueuesendsupp.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/posixtimespecabsolutetimeout.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/timerdelete.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timerinserthelper.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/timertsr.c (modified) * cpukit/posix/src/ualarm.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/regionimpl.h (modified) * cpukit/rtems/include/rtems/rtems/timerimpl.h (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockgetuptimenanoseconds.c (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (deleted) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/clocksetnsecshandler.c (deleted) * cpukit/rtems/src/clocktick.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetfreeinfo.c (modified) * cpukit/rtems/src/regiongetinfo.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/regionprocessqueue.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/rtems/src/timerserver.c (modified) * cpukit/rtems/src/timerserverfireafter.c (modified) * cpukit/rtems/src/timerserverfirewhen.c (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/bsd.h (added) * cpukit/sapi/include/rtems/timecounter.h (added) * cpukit/sapi/preinstall.am (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/tcsimpleinstall.c (added) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/epiphany/Makefile.am (added) * cpukit/score/cpu/epiphany/cpu.c (added) * cpukit/score/cpu/epiphany/epiphany-context-initialize.c (added) * cpukit/score/cpu/epiphany/epiphany-context-switch.S (added) * cpukit/score/cpu/epiphany/epiphany-exception-handler.S (added) * cpukit/score/cpu/epiphany/preinstall.am (added) * cpukit/score/cpu/epiphany/rtems/asm.h (added) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (added) * cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h (added) * cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h (added) * cpukit/score/cpu/epiphany/rtems/score/epiphany.h (added) * cpukit/score/cpu/epiphany/rtems/score/types.h (added) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (added) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (added) * cpukit/score/include/rtems/score/assert.h (modified) * cpukit/score/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/include/rtems/score/coremsgimpl.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/corerwlockimpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/mpciimpl.h (modified) * cpukit/score/include/rtems/score/mrsp.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/score/profiling.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/include/rtems/score/threadsync.h (deleted) * cpukit/score/include/rtems/score/timecounter.h (added) * cpukit/score/include/rtems/score/timecounterimpl.h (added) * cpukit/score/include/rtems/score/timespec.h (modified) * cpukit/score/include/rtems/score/timestamp.h (modified) * cpukit/score/include/rtems/score/timestamp64.h (deleted) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/todimpl.h (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/include/sys/_ffcounter.h (added) * cpukit/score/include/sys/timeffc.h (added) * cpukit/score/include/sys/timepps.h (added) * cpukit/score/include/sys/timetc.h (added) * cpukit/score/include/sys/timex.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushsupp.c (deleted) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/corerwlockrelease.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coresemflush.c (deleted) * cpukit/score/src/coresemseize.c (deleted) * cpukit/score/src/coresemsurrender.c (deleted) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodadjust.c (modified) * cpukit/score/src/coretodget.c (deleted) * cpukit/score/src/coretodgetuptimetimespec.c (deleted) * cpukit/score/src/coretodsecondssinceepoch.c (deleted) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/debugisownerofallocator.c (modified) * cpukit/score/src/kern_tc.c (added) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/opt_compat.h (added) * cpukit/score/src/opt_ffclock.h (added) * cpukit/score/src/opt_ntp.h (added) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/schedulerchangeroot.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/smplock.c (added) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threaddelayended.c (deleted) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqops.c (added) * cpukit/score/src/threadqprocesstimeout.c (deleted) * cpukit/score/src/threadqtimeout.c (deleted) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadsetpriority.c (modified) * cpukit/score/src/threadtimeout.c (moved) * cpukit/score/src/timespecgetasnanoseconds.c (modified) * cpukit/score/src/ts64addto.c (deleted) * cpukit/score/src/ts64divide.c (deleted) * cpukit/score/src/ts64equalto.c (deleted) * cpukit/score/src/ts64getnanoseconds.c (deleted) * cpukit/score/src/ts64getseconds.c (deleted) * cpukit/score/src/ts64lessthan.c (deleted) * cpukit/score/src/ts64set.c (deleted) * cpukit/score/src/ts64settozero.c (deleted) * cpukit/score/src/ts64subtract.c (deleted) * cpukit/score/src/ts64totimespec.c (deleted) * cpukit/score/src/ts64totimeval.c (deleted) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/watchdogadjust.c (modified) * cpukit/score/src/watchdogadjusttochain.c (deleted) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtick.c (added) * cpukit/score/src/watchdogtickle.c (deleted) * doc/bsp_howto/clock.t (modified) * doc/cpu_supplement/Makefile.am (modified) * doc/cpu_supplement/cpu_supplement.texi (modified) * doc/cpu_supplement/epiphany.t (added) * doc/cpu_supplement/sparc.t (modified) * doc/user/msg.t (modified) * testsuites/psxtests/psxualarm/init.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp37/init.c (modified) * testsuites/sptests/spclock_err01/init.c (modified) * testsuites/sptests/spintrcritical01/init.c (modified) * testsuites/sptests/spintrcritical08/init.c (modified) * testsuites/sptests/spintrcritical09/init.c (modified) * testsuites/sptests/spintrcritical10/init.c (modified) * testsuites/sptests/spintrcritical16/init.c (modified) * testsuites/sptests/spintrcritical17/init.c (modified) * testsuites/sptests/spintrcritical17/spintrcritical17.doc (modified) * testsuites/sptests/spintrcritical20/init.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spthreadq01/init.c (modified) * testsuites/sptests/sptimecounter01/Makefile.am (added) * testsuites/sptests/sptimecounter01/init.c (added) * testsuites/sptests/sptimecounter01/sptimecounter01.doc (added) * testsuites/sptests/sptimecounter01/sptimecounter01.scn (added) * testsuites/sptests/sptimecounter02/Makefile.am (added) * testsuites/sptests/sptimecounter02/init.c (added) * testsuites/sptests/sptimecounter02/sptimecounter02.doc (added) * testsuites/sptests/sptimecounter02/sptimecounter02.scn (added) * testsuites/sptests/spwatchdog/init.c (modified) Merge branch 'master' of ssh://dispatch.rtems.org/data/git/rtems Wed, 20 May 2015 08:51:02 GMT Hesham ALMatary [10504d3c] * doc/cpu_supplement/Makefile.am (modified) * doc/cpu_supplement/cpu_supplement.texi (modified) * doc/cpu_supplement/epiphany.t (added) doc: Add new documentation section for Epiphany architecture Thu, 21 May 2015 16:53:53 GMT Hesham ALMatary [6f71dcb7] * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/epiphany/Makefile.am (added) * c/src/lib/libbsp/epiphany/acinclude.m4 (added) * c/src/lib/libbsp/epiphany/configure.ac (added) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (added) * c/src/lib/libbsp/epiphany/epiphany_sim/README (added) * c/src/lib/libbsp/epiphany/epiphany_sim/bsp_specs (added) * c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac (added) * c/src/lib/libbsp/epiphany/epiphany_sim/console/console-io.c (added) * c/src/lib/libbsp/epiphany/epiphany_sim/include/bsp.h (added) * c/src/lib/libbsp/epiphany/epiphany_sim/include/bspopts.h (added) * c/src/lib/libbsp/epiphany/epiphany_sim/include/irq.h (added) * c/src/lib/libbsp/epiphany/epiphany_sim/include/tm27.h (added) * c/src/lib/libbsp/epiphany/epiphany_sim/irq/irq.c (added) * c/src/lib/libbsp/epiphany/epiphany_sim/make/custom/epiphany_sim.cfg (added) * c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am (added) * c/src/lib/libbsp/epiphany/epiphany_sim/start/start.S (added) * c/src/lib/libbsp/epiphany/epiphany_sim/startup/linkcmds (added) * c/src/lib/libbsp/epiphany/epiphany_sim/timer/timer.c (added) * c/src/lib/libbsp/epiphany/preinstall.am (added) * c/src/lib/libbsp/epiphany/shared/include/linker-symbols.h (added) Epiphany: Add the first epiphany_sim BSP v4 This BSP in intended to ... Thu, 21 May 2015 16:52:56 GMT Hesham ALMatary [66a5000d] * cpukit/configure.ac (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/score/cpu/Makefile.am (modified) * cpukit/score/cpu/epiphany/Makefile.am (added) * cpukit/score/cpu/epiphany/cpu.c (added) * cpukit/score/cpu/epiphany/epiphany-context-initialize.c (added) * cpukit/score/cpu/epiphany/epiphany-context-switch.S (added) * cpukit/score/cpu/epiphany/epiphany-exception-handler.S (added) * cpukit/score/cpu/epiphany/preinstall.am (added) * cpukit/score/cpu/epiphany/rtems/asm.h (added) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (added) * cpukit/score/cpu/epiphany/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/epiphany/rtems/score/cpuatomic.h (added) * cpukit/score/cpu/epiphany/rtems/score/epiphany-utility.h (added) * cpukit/score/cpu/epiphany/rtems/score/epiphany.h (added) * cpukit/score/cpu/epiphany/rtems/score/types.h (added) cpukit: Add Epiphany architecture port v4 Thu, 21 May 2015 12:55:15 GMT Joel Sherrill [63c68cfc] * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetfreeinfo.c (modified) * cpukit/rtems/src/regiongetinfo.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) region*.c: Ensure return_status is set when RTEMS_MULTIPROCESSING is ... Thu, 21 May 2015 12:54:57 GMT Joel Sherrill [60e4c00] * c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c (modified) arm/s3c24xx/clock/clockdrv.c: Remove unused variable warning Thu, 21 May 2015 12:54:35 GMT Joel Sherrill [562c1b1b] * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) arm/lpc22xx/clock/clockdrv.c: Remove unused variable warning Thu, 21 May 2015 12:54:12 GMT Joel Sherrill [efd351d] * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) powerpc/shared/clock/clock.c: Remove unused variable warning Thu, 21 May 2015 12:53:41 GMT Joel Sherrill [68592d54] * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) mpc55xxevb/clock/clock-config.c: Remove unused variable warning Thu, 21 May 2015 12:52:21 GMT Joel Sherrill [4004d97] * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) mcf5225x/clock/clock.c: Remove unused variable warning Thu, 21 May 2015 12:52:02 GMT Joel Sherrill [2a605f6] * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) mcf52235/clock/clock.c: Remove unused variable warning Thu, 21 May 2015 12:51:36 GMT Joel Sherrill [5a9c3c1] * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) pc386/clock/ckinit.c: Remove prototyped but not defined warning Thu, 21 May 2015 12:51:01 GMT Joel Sherrill [52258f1] * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (modified) arm/shared/lpc/clock/lpc-clock-config.c: Remove unused variable warning Wed, 20 May 2015 22:02:19 GMT Joel Sherrill [221031e] * cpukit/libcsupport/src/kill_noposix.c (modified) kill_noposix.c: Remove obsolete __kill() Wed, 20 May 2015 19:12:52 GMT Joel Sherrill [1c0663b4] * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235-testsuite.tcfg (modified) mcf52235-testsuite.tcfg: Add syscall01 Wed, 20 May 2015 17:11:41 GMT Joel Sherrill [0afac6a] * c/src/lib/libbsp/arm/altera-cyclone-v/bsp_specs (modified) * c/src/lib/libbsp/arm/beagle/bsp_specs (modified) * c/src/lib/libbsp/arm/csb336/bsp_specs (modified) * c/src/lib/libbsp/arm/csb337/bsp_specs (modified) * c/src/lib/libbsp/arm/edb7312/bsp_specs (modified) * c/src/lib/libbsp/arm/gba/bsp_specs (modified) * c/src/lib/libbsp/arm/gdbarmsim/bsp_specs (modified) * c/src/lib/libbsp/arm/gp32/bsp_specs (modified) * c/src/lib/libbsp/arm/gumstix/bsp_specs (modified) * c/src/lib/libbsp/arm/lm3s69xx/bsp_specs (modified) * c/src/lib/libbsp/arm/lpc176x/bsp_specs (modified) * c/src/lib/libbsp/arm/lpc24xx/bsp_specs (modified) * c/src/lib/libbsp/arm/lpc32xx/bsp_specs (modified) * c/src/lib/libbsp/arm/nds/bsp_specs (modified) * c/src/lib/libbsp/arm/raspberrypi/bsp_specs (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs (modified) * c/src/lib/libbsp/arm/rtl22xx/bsp_specs (modified) * c/src/lib/libbsp/arm/smdk2410/bsp_specs (modified) * c/src/lib/libbsp/arm/stm32f4/bsp_specs (modified) * c/src/lib/libbsp/arm/tms570/bsp_specs (modified) * c/src/lib/libbsp/arm/xilinx-zynq/bsp_specs (modified) * c/src/lib/libbsp/bfin/TLL6527M/bsp_specs (modified) * c/src/lib/libbsp/bfin/bf537Stamp/bsp_specs (modified) * c/src/lib/libbsp/bfin/eZKit533/bsp_specs (modified) * c/src/lib/libbsp/m32r/m32rsim/bsp_specs (modified) Multiple bsp_specs: Change *(old_endfile) to %(old_endfile) Fix ... Wed, 20 May 2015 17:08:53 GMT Joel Sherrill [64f7724] * README (modified) * SUPPORT (deleted) * VERSION (deleted) Top files: Update and prep for release branch Wed, 20 May 2015 17:08:15 GMT Joel Sherrill [22e576d] * c/src/lib/libbsp/sh/shsim/make/custom/simsh2e-testsuite.tcfg (modified) simsh2e-testsuite.tcfg: Add fileio Wed, 20 May 2015 17:08:00 GMT Joel Sherrill [bb997dd9] * c/src/lib/libbsp/sh/shsim/make/custom/simsh1-testsuite.tcfg (modified) simsh1-testsuite.tcfg: Add fileio Thu, 21 May 2015 15:27:34 GMT Sebastian Huber [9588946] * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) bsp/tms570: Typo Fri, 24 Apr 2015 14:05:50 GMT Alexander Krutwig [1c59cad] * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/sparc-context-validate.S (added) * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (added) sparc: Add support for sptests/spcontext01 Implement ... Tue, 05 May 2015 13:32:03 GMT Alexander Krutwig [a9c4f15d] * doc/cpu_supplement/sparc.t (modified) doc: Clarify SPARC floating point ABI Wed, 01 Apr 2015 13:33:25 GMT Alexander Krutwig [75acd9e] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/gba/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/lpc176x/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/lpc32xx/include/lpc-clock-config.h (modified) * c/src/lib/libbsp/arm/nds/clock/clock.c (modified) * c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (modified) * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/milkymist_clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/av5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/gen68360/clock/clock.c (modified) * c/src/lib/libbsp/m68k/genmcf548x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf52235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5225x/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5235/clock/clock.c (modified) * c/src/lib/libbsp/m68k/mcf5329/clock/clock.c (modified) * c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/mips/csb350/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/genmongoosev/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/jmr3904/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4925/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/rbtx4938/clock/clockdrv.c (modified) * c/src/lib/libbsp/mips/shared/clock/clockdrv.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/clock/clock.c (modified) * c/src/lib/libbsp/or1k/generic_or1k/clock/clockdrv.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/shared/clock/clock.c (modified) * c/src/lib/libbsp/shared/clock_driver_simidle.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon2/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc64/shared/clock/ckinit.c (modified) * c/src/lib/libcpu/arm/at91rm9200/clock/clock.c (modified) * c/src/lib/libcpu/arm/lpc22xx/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/mc9328mxl/clock/clockdrv.c (modified) * c/src/lib/libcpu/arm/pxa255/clock/clock.c (modified) * c/src/lib/libcpu/arm/s3c24xx/clock/clockdrv.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (modified) bsps: Convert clock drivers to use a timecounter Update #2271. Tue, 12 May 2015 12:32:47 GMT Alexander Krutwig [7cd2484] * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/src/clockgettime.c (modified) * cpukit/posix/src/posixtimespecabsolutetimeout.c (modified) * cpukit/posix/src/timergettime.c (modified) * cpukit/posix/src/timersettime.c (modified) * cpukit/posix/src/timertsr.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/src/clockgetuptime.c (modified) * cpukit/rtems/src/clockgetuptimenanoseconds.c (modified) * cpukit/rtems/src/clockgetuptimeseconds.c (deleted) * cpukit/rtems/src/clockgetuptimetimeval.c (modified) * cpukit/rtems/src/clocksetnsecshandler.c (deleted) * cpukit/rtems/src/clocktick.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/timespec.h (modified) * cpukit/score/include/rtems/score/timestamp.h (modified) * cpukit/score/include/rtems/score/timestamp64.h (deleted) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/todimpl.h (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodadjust.c (modified) * cpukit/score/src/coretodget.c (deleted) * cpukit/score/src/coretodgetuptimetimespec.c (deleted) * cpukit/score/src/coretodsecondssinceepoch.c (deleted) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/kern_tc.c (modified) * cpukit/score/src/timespecgetasnanoseconds.c (modified) * cpukit/score/src/ts64addto.c (deleted) * cpukit/score/src/ts64divide.c (deleted) * cpukit/score/src/ts64equalto.c (deleted) * cpukit/score/src/ts64getnanoseconds.c (deleted) * cpukit/score/src/ts64getseconds.c (deleted) * cpukit/score/src/ts64lessthan.c (deleted) * cpukit/score/src/ts64set.c (deleted) * cpukit/score/src/ts64settozero.c (deleted) * cpukit/score/src/ts64subtract.c (deleted) * cpukit/score/src/ts64totimespec.c (deleted) * cpukit/score/src/ts64totimeval.c (deleted) * cpukit/score/src/watchdogtick.c (added) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spclock_err01/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/sptimecounter02/Makefile.am (added) * testsuites/sptests/sptimecounter02/init.c (added) * testsuites/sptests/sptimecounter02/sptimecounter02.doc (added) * testsuites/sptests/sptimecounter02/sptimecounter02.scn (added) timecounter: Use in RTEMS Replace timestamp implementation with ... Mon, 20 Apr 2015 09:08:22 GMT Alexander Krutwig [31be416] * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/bsd.h (added) * cpukit/sapi/include/rtems/timecounter.h (added) * cpukit/sapi/preinstall.am (modified) * cpukit/sapi/src/tcsimpleinstall.c (added) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/timecounter.h (added) * cpukit/score/include/rtems/score/timecounterimpl.h (added) * cpukit/score/include/sys/timeffc.h (modified) * cpukit/score/include/sys/timetc.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/kern_tc.c (modified) * doc/bsp_howto/clock.t (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sptimecounter01/Makefile.am (added) * testsuites/sptests/sptimecounter01/init.c (added) * testsuites/sptests/sptimecounter01/sptimecounter01.doc (added) * testsuites/sptests/sptimecounter01/sptimecounter01.scn (added) timecounter: Port to RTEMS New test sptests/timecounter01. Update ... Tue, 12 May 2015 10:12:18 GMT Alexander Krutwig [cc693845] * cpukit/score/src/kern_tc.c (modified) timecounter: Honor FFCLOCK define Update #2271. Tue, 12 May 2015 10:10:04 GMT Alexander Krutwig [664f844] * cpukit/score/include/sys/timetc.h (modified) * cpukit/score/src/kern_tc.c (modified) timecounter: Use uint32_t instead of u_int FreeBSD assumes that ... Thu, 19 Mar 2015 10:38:14 GMT Alexander Krutwig [4117cd1] * cpukit/score/include/sys/_ffcounter.h (added) * cpukit/score/include/sys/timeffc.h (added) * cpukit/score/include/sys/timepps.h (added) * cpukit/score/include/sys/timetc.h (added) * cpukit/score/include/sys/timex.h (added) * cpukit/score/src/kern_tc.c (added) * cpukit/score/src/opt_compat.h (added) * cpukit/score/src/opt_ffclock.h (added) * cpukit/score/src/opt_ntp.h (added) timecounter: Import from FreeBSD Update #2271. Tue, 12 May 2015 08:15:21 GMT Sebastian Huber [33e30f39] * testsuites/smptests/smpscheduler03/init.c (modified) smptests/smpscheduler03: Restructure Restructure to avoid large ... Mon, 11 May 2015 13:11:00 GMT Sebastian Huber [9eb056f] * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) rtems: Avoid Giant lock for events Mon, 11 May 2015 13:02:51 GMT Sebastian Huber [20b423c6] * testsuites/psxtests/psxualarm/init.c (modified) psxualarm: Avoid endless signal handling Increase the ualarm timer ... Mon, 18 May 2015 09:09:14 GMT Sebastian Huber [d5423295] * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/profiling.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/threadqenqueue.c (modified) score: _Thread_Dispatch_disable_critical() Thread dispatching is ... Mon, 11 May 2015 12:56:49 GMT Sebastian Huber [aa05cfbb] * cpukit/posix/src/nanosleep.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/src/threaddelayended.c (deleted) score: Replace _Thread_Delay_ended() Use _Thread_Timeout() instead. ... Mon, 11 May 2015 12:56:12 GMT Sebastian Huber [d8752860] * cpukit/score/include/rtems/score/threadqimpl.h (modified) * testsuites/sptests/spthreadq01/init.c (modified) score: Add static initializers for thread queues Mon, 11 May 2015 08:14:31 GMT Sebastian Huber [9052f88] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/src/smplock.c (added) score: Do not inline SMP lock if profiling enabled This reduces the ... Mon, 04 May 2015 08:00:50 GMT Sebastian Huber [7a70a09] * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) score: Delete _Objects_Put_for_get_isr_disable() This function is ... Thu, 07 May 2015 12:02:46 GMT Sebastian Huber [a816f084] * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/score/include/rtems/score/mrsp.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/src/schedulerchangeroot.c (modified) score: Fine grained locking for MrsP Update #2273. Wed, 06 May 2015 12:25:09 GMT Sebastian Huber [80f376d] * cpukit/rtems/src/clocktick.c (modified) * testsuites/sptests/sp37/init.c (modified) score: Remove Giant lock in rtems_clock_tick() Update #2307. Tue, 05 May 2015 11:05:54 GMT Sebastian Huber [900d337f] * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/schedulercbs.c (modified) * cpukit/score/src/schedulercbsreleasejob.c (modified) * cpukit/score/src/scheduleredfreleasejob.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadsetpriority.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) score: Rework _Thread_Change_priority() Move the writes to ... Sat, 02 May 2015 12:27:24 GMT Sebastian Huber [4438ac25] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/debugisownerofallocator.c (modified) score: Fine grained locking for mutexes Update #2273. Sat, 02 May 2015 12:06:38 GMT Sebastian Huber [d12b313] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/src/coresemsurrender.c (deleted) score: Inline _CORE_semaphore_Surrender() Sat, 02 May 2015 12:04:21 GMT Sebastian Huber [b76dd97] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/src/coresemflush.c (deleted) score: Inline _CORE_semaphore_Flush() Sat, 02 May 2015 12:02:20 GMT Sebastian Huber [cfa5aab] * cpukit/posix/src/semaphorewaitsupp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/src/coresemseize.c (deleted) * cpukit/score/src/mpci.c (modified) score: Delete _CORE_semaphore_Seize() Rename ...
