# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/17/24 03:33:18 Thu, 19 Feb 2009 19:27:58 GMT Joel Sherrill [78fe958] * cpukit/ChangeLog (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) 2009-02-19 Joel Sherrill * ... Thu, 19 Feb 2009 19:25:53 GMT Joel Sherrill [66913da2] * c/src/ChangeLog (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) 2009-02-19 Joel Sherrill * ... Thu, 19 Feb 2009 19:20:51 GMT Joel Sherrill [0a90bf2] * doc/ChangeLog (modified) * doc/shell/rtems.t (modified) 2009-02-19 Joel Sherrill * ... Thu, 19 Feb 2009 18:54:00 GMT Joel Sherrill [4e54befe] * cpukit/ChangeLog (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/shell/main_halt.c (added) * cpukit/libmisc/shell/shellconfig.h (modified) 2009-02-19 Joel Sherrill * ... Thu, 19 Feb 2009 16:49:17 GMT Ralf Corsepius [16e6f5b] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/cpukit-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Thu, 19 Feb 2009 16:49:02 GMT Ralf Corsepius [aa941f8] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/binutils.am (modified) * contrib/crossrpms/rtems4.10/cpukit.am (modified) * contrib/crossrpms/rtems4.10/gcc.am (modified) * contrib/crossrpms/rtems4.10/gdb.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mipstx39/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Move %{?dist} handling to rtems4.10/*.am. Thu, 19 Feb 2009 16:11:21 GMT Ralf Corsepius [327c70b2] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) Update. Thu, 19 Feb 2009 15:12:07 GMT Ralf Corsepius [5c24de44] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL, NEWLIB_RPMREL. Thu, 19 Feb 2009 15:08:06 GMT Ralf Corsepius [c752ccb8] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090219.diff (added) 2009-02-16 Ralf Corsépius * ... Tue, 17 Feb 2009 20:39:44 GMT Joel Sherrill [94dd4f6] * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) 2009-02-17 Joel Sherrill * ... Tue, 17 Feb 2009 18:37:02 GMT Joel Sherrill [f6cef3a] * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) 2009-02-17 Till Straumann ... Tue, 17 Feb 2009 18:35:09 GMT Joel Sherrill [49633b9] * make/ChangeLog (modified) * make/custom/mvme167.cfg (modified) 2009-02-17 Till Straumann ... Tue, 17 Feb 2009 18:32:33 GMT Joel Sherrill [2235066] * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) 2009-02-17 Till Straumann ... Tue, 17 Feb 2009 15:09:57 GMT Joel Sherrill [e399e9d6] * cpukit/ChangeLog (modified) * cpukit/libmisc/shell/main_netstats.c (modified) 2009-02-17 Joel Sherrill ... Tue, 17 Feb 2009 14:37:34 GMT Joel Sherrill [9c2af12] * make/ChangeLog (modified) * make/custom/uC5282.cfg (modified) 2009-02-17 Joel Sherrill * ... Tue, 17 Feb 2009 12:43:53 GMT Ralf Corsepius [f969fcb] * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) 2009-02-17 Ralf Corsépius * ... Fri, 13 Feb 2009 20:47:27 GMT Joel Sherrill [ef06d30] * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) 2009-02-13 Joel Sherrill * ... Fri, 13 Feb 2009 14:20:58 GMT Joel Sherrill [9b974cf4] * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) 2009-02-13 Joel Sherrill * ... Thu, 12 Feb 2009 15:58:02 GMT Joel Sherrill [72f4b246] * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:57:29 GMT Joel Sherrill [2a0a791f] * c/src/lib/libbsp/m68k/uC5282/ChangeLog (modified) * c/src/lib/libbsp/m68k/uC5282/clock/clock.c (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:57:15 GMT Joel Sherrill [06f3a3ef] * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:57:05 GMT Joel Sherrill [6994cd9] * c/src/lib/libbsp/powerpc/gen5200/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:57:00 GMT Joel Sherrill [326220e] * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/shared/misc/m68kidle.c (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:56:42 GMT Joel Sherrill [3aaf479] * cpukit/ChangeLog (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadidlebody.c (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:56:16 GMT Joel Sherrill [6d869df] * doc/ChangeLog (modified) * doc/porting/idlethread.t (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:55:55 GMT Joel Sherrill [cca8379] * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/ChangeLog (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu.c (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:55:54 GMT Joel Sherrill [59b68bd] * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) 2009-02-12 Joel Sherrill * ... Thu, 12 Feb 2009 15:55:36 GMT Joel Sherrill [8bbead13] * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/cpu.c (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/cpu.c (modified) 2009-02-12 Joel Sherrill * ... Wed, 11 Feb 2009 23:06:55 GMT Joel Sherrill [6748b76c] * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/tod.c (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 21:53:38 GMT Joel Sherrill [094e520] * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/stackchk/stackchk.scn (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 21:48:42 GMT Joel Sherrill [45d107ec] * cpukit/ChangeLog (modified) * cpukit/sapi/src/exinit.c (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 21:45:05 GMT Joel Sherrill [c03e2bc] * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/ChangeLog (modified) * cpukit/score/cpu/avr/cpu.c (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/ChangeLog (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/cpu.c (modified) * cpukit/score/cpu/c4x/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/cpu.c (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/ChangeLog (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/ChangeLog (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/ChangeLog (modified) * cpukit/score/cpu/m32r/cpu.c (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/ChangeLog (modified) * cpukit/score/cpu/nios2/cpu.c (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 21:44:59 GMT Joel Sherrill [ef1be69] * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 20:39:22 GMT Joel Sherrill [e8cba4c] * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/shared/irq/irq.h (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 20:37:51 GMT Joel Sherrill [e856d14] * make/ChangeLog (modified) * make/custom/h8sxsim.cfg (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 19:49:34 GMT Joel Sherrill [938c666e] * c/src/lib/libbsp/mips/csb350/ChangeLog (modified) * c/src/lib/libbsp/mips/csb350/startup/linkcmds (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 19:48:25 GMT Joel Sherrill [c63fde5c] * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 19:35:30 GMT Joel Sherrill [9cf17fb] * cpukit/score/cpu/m32c/ChangeLog (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 19:35:09 GMT Joel Sherrill [ef47bc78] * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 19:33:44 GMT Joel Sherrill [65e8f25] * cpukit/ChangeLog (modified) * cpukit/libmisc/stackchk/check.c (modified) 2009-02-11 Joel Sherrill ... Wed, 11 Feb 2009 19:30:24 GMT Joel Sherrill [a0d22251] * cpukit/ChangeLog (modified) * cpukit/sapi/src/exinit.c (modified) 2009-02-11 Joel Sherrill * ... Wed, 11 Feb 2009 16:36:29 GMT Joel Sherrill [819ca0e1] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (modified) 2009-02-11 Matt Rippa PR 1352/bsps ... Wed, 11 Feb 2009 16:20:00 GMT Joel Sherrill [fe26418] * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) 2009-02-11 Till Straumann ... Wed, 11 Feb 2009 16:13:56 GMT Joel Sherrill [e7c99cfe] * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/shared/console/bspreset.c (modified) 2009-02-11 Matt Rippa PR 1362/bsps ... Wed, 11 Feb 2009 13:21:10 GMT Ralf Corsepius [b34eb57] * cpukit/libnetworking/kern/kern_subr.c (modified) * cpukit/libnetworking/sys/uio.h (modified) Partial update from FreeBSD. Wed, 11 Feb 2009 07:25:20 GMT Ralf Corsepius [e2d78b0b] * c/src/lib/libbsp/powerpc/tqm8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/tqm8xx/bsp_specs (modified) 2009-02-11 Ralf Corsépius * ... Wed, 11 Feb 2009 05:21:46 GMT Ralf Corsepius [d605a2c2] * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/sd-card-init.c (modified) 2009-02-11 Ralf Corsépius * ... Wed, 11 Feb 2009 05:20:20 GMT Ralf Corsepius [33b11fb] * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c (modified) 2009-02-11 Ralf Corsépius * ... Wed, 11 Feb 2009 05:18:54 GMT Ralf Corsepius [934307a] * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/tests/tests.c (modified) 2009-02-11 Ralf Corsépius * ... Wed, 11 Feb 2009 03:40:12 GMT Ralf Corsepius [a45054b9] * cpukit/ChangeLog (modified) 2009-02-11 Ralf Corsépius * ... Wed, 11 Feb 2009 03:39:59 GMT Ralf Corsepius [dce90eae] * cpukit/libnetworking/sys/kernel.h (modified) Remove PSEUDO_* (Unused, not in FreeBSD). Wed, 11 Feb 2009 03:37:30 GMT Ralf Corsepius [86dab8c] * cpukit/ChangeLog (modified) 2009-02-11 Ralf Corsépius * ... Wed, 11 Feb 2009 03:37:21 GMT Ralf Corsepius [781c7d9] * cpukit/libnetworking/sys/kernel.h (modified) Remove struct linker_set (Unused). Wed, 11 Feb 2009 03:36:19 GMT Ralf Corsepius [aa71c07] * cpukit/ChangeLog (modified) 2009-02-11 Ralf Corsépius * ... Wed, 11 Feb 2009 03:36:07 GMT Ralf Corsepius [2dc5992d] * cpukit/libnetworking/net/if_loop.c (modified) Remove PSEUDO_SET (Unused). Wed, 11 Feb 2009 03:07:44 GMT Ralf Corsepius [110f3f3c] * cpukit/ChangeLog (modified) 2009-02-11 Ralf Corsépius * ... Wed, 11 Feb 2009 03:07:33 GMT Ralf Corsepius [fb1ff66] * cpukit/libnetworking/kern/uipc_domain.c (modified) Remove domain_set (Unused). Wed, 11 Feb 2009 02:58:27 GMT Ralf Corsepius [8eca719] * cpukit/ChangeLog (modified) * cpukit/libnetworking/sys/kernel.h (modified) 2009-02-11 Ralf Corsépius * ... Wed, 11 Feb 2009 01:48:41 GMT Ralf Corsepius [5d49762] * cpukit/ChangeLog (modified) * cpukit/libnetworking/sys/kernel.h (modified) 2009-02-11 Ralf Corsépius * ... Tue, 10 Feb 2009 10:27:37 GMT Ralf Corsepius [1792c7a] * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) 2009-02-10 Ralf Corsépius * ... Tue, 10 Feb 2009 10:03:14 GMT Ralf Corsepius [2e3f12c4] * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) 2009-02-10 Ralf Corsépius * ... Tue, 10 Feb 2009 10:03:08 GMT Ralf Corsepius [e45dff7] * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) Add prototypes. Tue, 10 Feb 2009 09:11:06 GMT Ralf Corsepius [1df408f] * cpukit/ChangeLog (modified) 2009-02-10 Ralf Corsépius * ... Tue, 10 Feb 2009 09:10:51 GMT Ralf Corsepius [7931bbb2] * cpukit/libnetworking/vm/vm.h (modified) Cosmetics from FreeBSD. Tue, 10 Feb 2009 08:51:43 GMT Ralf Corsepius [b1b425e4] * cpukit/ChangeLog (modified) 2009-02-10 Ralf Corsépius * ... Tue, 10 Feb 2009 08:51:33 GMT Ralf Corsepius [b9c4861] * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Remove struct vm_page, vm_page_t, boolean_t (Unused). Tue, 10 Feb 2009 08:25:27 GMT Ralf Corsepius [96c57dba] * cpukit/ChangeLog (modified) 2009-02-10 Ralf Corsépius * ... Tue, 10 Feb 2009 08:25:06 GMT Ralf Corsepius [0d37bf1] * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/nfsclient/nfsdiskless.h (modified) Cosmetics from FreeBSD. Tue, 10 Feb 2009 08:21:44 GMT Ralf Corsepius [282e6fd0] * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Remove struct file (Unused). Mon, 09 Feb 2009 22:18:43 GMT Ralf Corsepius [bc182456] * cpukit/ChangeLog (modified) 2009-02-09 Ralf Corsépius * ... Mon, 09 Feb 2009 22:18:30 GMT Ralf Corsepius [d239d986] * cpukit/libnetworking/sys/socketvar.h (modified) Remove struct file, soo_ioctl, soo_select, soo_stat, getsock (Unused). Sat, 07 Feb 2009 08:45:12 GMT Ralf Corsepius [2659fa26] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-gcc.spec (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-gcc.spec (modified) Regenerate. Fri, 06 Feb 2009 23:33:01 GMT Ralf Corsepius [65205315] * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (modified) Regenerate. Fri, 06 Feb 2009 23:17:55 GMT Ralf Corsepius [872775d3] * contrib/crossrpms/patches/newlib-1.17.0-rtems4.10-20090206.diff (added) Remove newlib/libc/include/sched.h Fri, 06 Feb 2009 23:07:43 GMT Ralf Corsepius [d9e5793] * contrib/crossrpms/rtems4.10/arm/rtems-4.10-arm-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/avr/rtems-4.10-avr-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/bfin/rtems-4.10-bfin-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/h8300/rtems-4.10-h8300-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/i386/rtems-4.10-i386-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/m32c/rtems-4.10-m32c-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/m32r/rtems-4.10-m32r-rtems4.10-cpukit.spec (added) * contrib/crossrpms/rtems4.10/m68k/rtems-4.10-m68k-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/mips/rtems-4.10-mips-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/powerpc/rtems-4.10-powerpc-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sh/rtems-4.10-sh-rtems4.10-cpukit.spec (modified) * contrib/crossrpms/rtems4.10/sparc/rtems-4.10-sparc-rtems4.10-cpukit.spec (modified) Regenerate. Fri, 06 Feb 2009 23:06:35 GMT Ralf Corsepius [bdd38fe1] * contrib/crossrpms/rtems4.10/arm/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/avr/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/bfin/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/h8300/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/i386/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32c/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m32r/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/m68k/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/mips/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/powerpc/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sh/gcc-sources.add (modified) * contrib/crossrpms/rtems4.10/sparc/gcc-sources.add (modified) newlib-1.17.0-rtems4.10-20090206.diff Fri, 06 Feb 2009 23:05:02 GMT Ralf Corsepius [c84b47f] * contrib/crossrpms/cpukit/build.add (modified) * contrib/crossrpms/cpukit/cpukit.add (modified) * contrib/crossrpms/cpukit/rpm-install.add (modified) * contrib/crossrpms/cpukit/target-cpukit.add (modified) Rework. Fri, 06 Feb 2009 23:04:47 GMT Ralf Corsepius [95159f95] * contrib/crossrpms/rtems4.10/arm/Makefile.am (modified) * contrib/crossrpms/rtems4.10/avr/Makefile.am (modified) * contrib/crossrpms/rtems4.10/bfin/Makefile.am (modified) * contrib/crossrpms/rtems4.10/h8300/Makefile.am (modified) * contrib/crossrpms/rtems4.10/i386/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32c/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m32r/Makefile.am (modified) * contrib/crossrpms/rtems4.10/m68k/Makefile.am (modified) * contrib/crossrpms/rtems4.10/mips/Makefile.am (modified) * contrib/crossrpms/rtems4.10/powerpc/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sh/Makefile.am (modified) * contrib/crossrpms/rtems4.10/sparc/Makefile.am (modified) Bump GCC_RPMREL, NEWLIB_RPMREL. Rework CPUKIT*. Fri, 06 Feb 2009 21:02:59 GMT Ralf Corsepius [ffce01bb] * cpukit/preinstall.am (modified) Regenerate. Fri, 06 Feb 2009 21:02:40 GMT Ralf Corsepius [f0dd01f] * cpukit/ChangeLog (modified) 2009-02-06 Ralf Corsépius * ... Fri, 06 Feb 2009 21:02:31 GMT Ralf Corsepius [2a6b824] * cpukit/posix/include/sched.h (modified) * cpukit/posix/src/sched_getparam.c (modified) Make sched_getparam() POSIX compliant. Fri, 06 Feb 2009 20:45:46 GMT Ralf Corsepius [7079f53] * cpukit/ChangeLog (modified) 2009-02-06 Ralf Corsépius * ... Fri, 06 Feb 2009 17:23:33 GMT Ralf Corsepius [465b36f9] * cpukit/Makefile.am (modified) Remove tar.h. Fri, 06 Feb 2009 12:38:49 GMT Ralf Corsepius [cd5e926] * ChangeLog (modified) * Makefile.maint (modified) 2009-02-06 Ralf Corsépius * ... Fri, 06 Feb 2009 11:56:17 GMT Ralf Corsepius [3f426966] * make/Makefile.am (modified) Regenerate list of custom/*.cfg. Fri, 06 Feb 2009 11:36:41 GMT Ralf Corsepius [70d7dc22] * ChangeLog (modified) * Makefile.maint (modified) 2009-02-06 Ralf Corsépius * ... Fri, 06 Feb 2009 09:29:07 GMT Ralf Corsepius [3158138] * c/src/lib/libbsp/powerpc/mvme5500/ChangeLog (modified) 2009-02-06 Ralf Corsépius * ... Fri, 06 Feb 2009 09:28:56 GMT Ralf Corsepius [11a342d7] * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) Add network_CPPFLAGS += -D__BSD_VISIBLE. Fri, 06 Feb 2009 08:02:05 GMT Ralf Corsepius [0c00595] * cpukit/ChangeLog (modified) 2009-02-06 Ralf Corsépius * ... Fri, 06 Feb 2009 07:58:21 GMT Ralf Corsepius [a8f71b8] * cpukit/aclocal/canonical-target-name.m4 (modified) * cpukit/aclocal/enable-posix.m4 (modified) Remove comment referring to HPUX. Fri, 06 Feb 2009 05:54:51 GMT Ralf Corsepius [9ae1165] * ChangeLog (modified) * aclocal/canonical-target-name.m4 (modified) 2009-02-06 Ralf Corsépius * ... Fri, 06 Feb 2009 05:52:04 GMT Ralf Corsepius [cb29d6f] * make/ChangeLog (modified) 2009-02-06 Ralf Corsépius * ... Fri, 06 Feb 2009 05:47:44 GMT Ralf Corsepius [d229ed0] * make/ChangeLog (modified) * make/Makefile.am (modified) 2009-02-06 Ralf Corsépius * ... Fri, 06 Feb 2009 05:46:24 GMT Ralf Corsepius [d721841] * make/ChangeLog (modified) 2009-02-06 Ralf Corsépius * ... Fri, 06 Feb 2009 05:46:09 GMT Ralf Corsepius [7d04202] * make/custom/HPUX9-posix.cfg (deleted) Remove. Thu, 05 Feb 2009 15:59:32 GMT Ralf Corsepius [9c9bd756] * ChangeLog (modified) 2009-02-05 Ralf Corsépius * ... Thu, 05 Feb 2009 15:59:19 GMT Ralf Corsepius [f3e077e] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) Remove pck6 BSP. Thu, 05 Feb 2009 15:57:42 GMT Ralf Corsepius [2843700] * make/ChangeLog (modified) * make/custom/pck6.cfg (deleted) 2009-02-05 Ralf Corsépius * ... Thu, 05 Feb 2009 05:45:55 GMT Ralf Corsepius [bcf8ee2] * cpukit/ChangeLog (modified) * cpukit/libnetworking/lib/ftpfs.c (modified) 2009-02-05 Sebastian Huber ... Thu, 05 Feb 2009 05:19:24 GMT Ralf Corsepius [5d1285b] * cpukit/ChangeLog (modified) 2009-02-05 Ralf Corsépius * ...
