# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 21:09:20 Mon, 21 Mar 2016 14:02:58 GMT Daniel Hellstrom [61cc024a] * c/src/lib/libbsp/sparc/shared/timer/gptimer.c (modified) leon, gptimer: start/reset must take RS and IP into account Mon, 21 Mar 2016 12:50:27 GMT Daniel Hellstrom [b109add] * c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus.c (modified) leon: Fix ambapp_bus OCCAN device registeration order NOTE that ... Tue, 27 Oct 2015 11:41:50 GMT Martin Aberg [6ecad1d] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: Preserve DMA address enable at start. The EN bit ... Tue, 20 Oct 2015 09:25:06 GMT Martin Aberg [a48bfc0f] * c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h (modified) leon, grspw_pkt: Fixed txpkt flag for link error There was a mixup ... Tue, 30 Jun 2015 13:00:51 GMT Martin Aberg [3395ca99] * c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: Fixed parameter check in grspw_dma_open() Mon, 13 Apr 2015 07:01:54 GMT Daniel Hellstrom [4431f7d] * c/src/lib/libbsp/sparc/shared/include/gr1553b.h (modified) leon, gr1553b: RT status words register declarations fix The fix ... Fri, 02 Jan 2015 12:18:33 GMT Daniel Hellstrom [d745297] * c/src/lib/libbsp/sparc/shared/include/gr1553b.h (modified) leon, gr1553b: comment cleanup Fri, 02 Jan 2015 12:17:18 GMT Daniel Hellstrom [91df5a69] * cpukit/libpci/pci_access.c (modified) libpci: code cleanup Fri, 02 Jan 2015 12:16:10 GMT Daniel Hellstrom [be66bbc1] * c/src/lib/libbsp/sparc/shared/spw/grspw.c (modified) leon, grspw: rxPktSize must set DMA RX max length Fri, 03 Mar 2017 08:04:12 GMT Sebastian Huber [cb056d0] * testsuites/samples/cdtest/main.cc (modified) cdtest: Print begin of test only once Thu, 02 Mar 2017 15:53:45 GMT Sebastian Huber [c0dafd7b] * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) bsp/qoriq: Use at most 2GiB of RAM Thu, 02 Mar 2017 14:25:34 GMT Sebastian Huber [d3f60af] * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/mmu-config.c (modified) bsp/qoriq: Adjust workspace according to FDT Thu, 02 Mar 2017 14:20:52 GMT Sebastian Huber [35136d3] * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq.inc (modified) bsp/qoriq: Use -O2 Thu, 02 Mar 2017 14:20:19 GMT Sebastian Huber [62f16ad] * c/src/lib/libbsp/powerpc/qoriq/make/custom/qoriq.inc (modified) bsp/qoriq: Enable linker garbage collection Thu, 02 Mar 2017 14:17:35 GMT Sebastian Huber [891b834f] * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) bsp/qoriq: Do not overwrite configured baud Thu, 02 Mar 2017 10:57:28 GMT Sebastian Huber [805d7213] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) powerpc: Fix warnings Thu, 02 Mar 2017 10:54:58 GMT Sebastian Huber [09dab28d] * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S (modified) powerpc: Fix interrupt thread dispatch Update #2751. Thu, 02 Mar 2017 06:54:52 GMT Sebastian Huber [1f618ab0] * cpukit/libcsupport/src/posix_devctl.c (modified) posix_devctl: Fix for pre C99 Use __restrict just like in ... Wed, 01 Mar 2017 10:31:57 GMT Sebastian Huber [08d85992] * c/src/lib/libbsp/powerpc/gen5200/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/gen5200/nvram/nvram.c (modified) * c/src/lib/libbsp/powerpc/shared/showbats.c (modified) * c/src/lib/libbsp/powerpc/shared/uboot_dump_bdinfo.c (modified) bsps/powerpc: Fix warnings Mon, 27 Feb 2017 10:50:30 GMT Sebastian Huber [a60db69] * cpukit/libfs/src/dosfs/msdos_format.c (modified) dosfs: Fix FAT32 formatter The second FAT entry contains a bit to ... Mon, 27 Feb 2017 09:40:49 GMT Sebastian Huber [267de79a] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) dosfs: Directories should have a file size of 0 Close #2755. Tue, 28 Feb 2017 08:12:13 GMT Sebastian Huber [f71ccc34] * cpukit/libcsupport/src/termios.c (modified) termios: Simplify some calculations Use the modular arithmetic ... Fri, 24 Feb 2017 13:56:51 GMT Sebastian Huber [902ffed] * testsuites/libtests/termios09/init.c (modified) termios09: Test send callback Fri, 24 Feb 2017 13:44:04 GMT Sebastian Huber [36635433] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios09/init.c (modified) termios: Implement non-blocking write Thu, 23 Feb 2017 14:43:41 GMT Sebastian Huber [a165a96] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios09/init.c (modified) termios: Make write POSIX compatible Currently only blocking ... Thu, 23 Feb 2017 14:19:47 GMT Sebastian Huber [c41b47e3] * cpukit/libcsupport/src/termios.c (modified) termios: Introduce doTransmit() Thu, 23 Feb 2017 13:04:24 GMT Sebastian Huber [5244d31e] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios09/init.c (modified) termios: Simplify oproc() Call rtems_termios_puts() only once. ... Fri, 24 Feb 2017 10:46:26 GMT Sebastian Huber [06d14667] * testsuites/libtests/termios09/init.c (modified) termios09: Test output post processing Fri, 24 Feb 2017 09:29:05 GMT Sebastian Huber [c80f6aa9] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios09/init.c (modified) termios: Fix infinite loop in receive path In canonical mode, the ... Thu, 23 Feb 2017 10:35:44 GMT Sebastian Huber [9fa0f54] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios09/init.c (modified) termios: Change receive callback invocation Call the receive ... Thu, 23 Feb 2017 08:38:54 GMT Sebastian Huber [49d8f653] * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) termios: Change tty_rcvwakeup to bool Optimize callout invocation check. Thu, 23 Feb 2017 09:35:16 GMT Sebastian Huber [9f69ac2] * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/termios09/Makefile.am (added) * testsuites/libtests/termios09/init.c (added) * testsuites/libtests/termios09/termios09.doc (added) * testsuites/libtests/termios09/termios09.scn (added) termios: Ignore carriage return early if desired In case carriage ... Thu, 23 Feb 2017 09:06:52 GMT Sebastian Huber [bb087cb0] * cpukit/libcsupport/src/termios.c (modified) termios: Protect raw input buffer with device lock Use the device ... Thu, 23 Feb 2017 08:12:36 GMT Sebastian Huber [d60c2d79] * cpukit/libcsupport/src/termios.c (modified) termios: Simplify rtems_termios_read_tty() Remove dead code. ... Tue, 21 Feb 2017 08:01:49 GMT Sebastian Huber [5bfeddc0] * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libfs/src/defaults/default_kqfilter.c (modified) * cpukit/libfs/src/defaults/default_poll.c (modified) termios: Add kqueue() and poll() support Real implementation is ... Tue, 21 Feb 2017 07:58:29 GMT Sebastian Huber [c833970] * cpukit/score/include/rtems/score/basedefs.h (modified) score: Add RTEMS_WEAK_ALIAS() Tue, 21 Feb 2017 14:25:03 GMT Sebastian Huber [3398602] * c/src/lib/libbsp/shared/src/irq-server.c (modified) * cpukit/include/rtems/irq-extension.h (modified) Add rtems_interrupt_server_request_submit() This function may be ... Wed, 22 Feb 2017 08:01:40 GMT Sebastian Huber [11f0d52] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart-regs.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart.h (modified) bsp/xilinx-zynq: Add interrupt support to UART Tue, 21 Feb 2017 09:30:30 GMT Sebastian Huber [6b2fcc4] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/console-config.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/debug-console.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart-regs.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspreset.c (modified) bsp/xilinx-zynq: Use new Termios device driver Tue, 21 Feb 2017 11:10:43 GMT Sebastian Huber [c54769e7] * testsuites/sptests/spextensions01/init.c (modified) spextensions01: Fix extension create order Update #2692. Mon, 10 Aug 2015 04:21:02 GMT Nick Withers [df184eb] * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libfs/src/nfsclient/src/rpcio.c (modified) Remove old CVS keywords Update #2388. Wed, 15 Feb 2017 12:41:02 GMT Sebastian Huber [7318e7db] * c/src/lib/libbsp/arm/lpc24xx/ssp/ssp.c (modified) bsp/lpc24xx: Remove debug output Wed, 15 Feb 2017 12:39:02 GMT Sebastian Huber [6afeeda] * c/src/lib/libbsp/powerpc/mvme5500/pci/detect_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/vectors/exceptionhandler.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/probeMemEnd.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeUniverse.c (modified) bsps/powerpc: Fix warnings Wed, 15 Feb 2017 12:28:02 GMT Sebastian Huber [f6f764c1] * c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/pci/generic_clear_hberrs.c (modified) * c/src/lib/libbsp/shared/vmeUniverse/vmeTsi148.c (modified) bsps/powerpc: Fix warnings Wed, 15 Feb 2017 12:22:36 GMT Sebastian Huber [c847451b] * cpukit/sapi/include/rtems/fatal.h (modified) sapi: Fix warnings Wed, 15 Feb 2017 12:14:40 GMT Sebastian Huber [32292d5d] * c/src/lib/libcpu/powerpc/mpc83xx/gtm/gtm.c (modified) bsps/powerpc: Fix warning Wed, 15 Feb 2017 12:05:27 GMT Sebastian Huber [661be20] * cpukit/libmisc/shell/hexdump-conv.c (modified) * cpukit/libmisc/shell/hexdump-odsyntax.c (modified) shell: Fix warnings Wed, 15 Feb 2017 11:57:56 GMT Sebastian Huber [bc744618] * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon2/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/spurious.c (modified) bsps/sparc: Fix warnings Wed, 15 Feb 2017 10:19:50 GMT Sebastian Huber [f5cf2fe] * cpukit/libdl/rtl-mdreloc-powerpc.c (modified) libdl: Fix warning Wed, 15 Feb 2017 10:12:40 GMT Sebastian Huber [444cb5c] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Fix prototype Wed, 15 Feb 2017 10:09:50 GMT Sebastian Huber [73f8d93] * c/src/lib/libbsp/powerpc/psim/network/if_sim.c (modified) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.c (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_print.c (modified) * c/src/lib/libcpu/powerpc/shared/src/stack.c (modified) bsps/powerpc: Fix warnings Wed, 15 Feb 2017 10:09:32 GMT Sebastian Huber [7a462cc] * cpukit/score/src/threadinitialize.c (modified) score: Fix warning Tue, 14 Feb 2017 10:30:00 GMT Sebastian Huber [611f9262] * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/psxtests/psxfatal_support/system.h (modified) psxtests: Fix warnings Tue, 14 Feb 2017 10:10:40 GMT Sebastian Huber [468e9a4] * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) monitor: Print short and long task names Print wait object ... Tue, 14 Feb 2017 09:05:24 GMT Sebastian Huber [71ac0a6] * testsuites/sptests/spqreslib/init.c (modified) spqreslib: Remove invalid test cases Tue, 14 Feb 2017 09:03:42 GMT Sebastian Huber [ad25f10] * testsuites/sptests/spcbssched02/init.c (modified) spcbssched02: Remove invalid test cases Tue, 14 Feb 2017 08:57:22 GMT Sebastian Huber [ecf53c8] * testsuites/psxtests/psxsem01/init.c (modified) psxsem01: Fix warning Wed, 01 Feb 2017 13:10:18 GMT Sebastian Huber [54835ae] * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/sapi/include/confdefs.h (modified) * testsuites/smptests/smp01/system.h (modified) * testsuites/smptests/smp02/system.h (modified) * testsuites/smptests/smp03/system.h (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smp08/system.h (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpcapture01/init.c (modified) * testsuites/smptests/smpcapture02/init.c (modified) * testsuites/smptests/smpclock01/init.c (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal06/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/smptests/smpipi01/init.c (modified) * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) * testsuites/smptests/smpmigration01/init.c (modified) * testsuites/smptests/smpmigration02/init.c (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmutex01/init.c (modified) * testsuites/smptests/smpmutex02/init.c (modified) * testsuites/smptests/smppsxaffinity01/init.c (modified) * testsuites/smptests/smppsxaffinity02/init.c (modified) * testsuites/smptests/smppsxmutex01/init.c (modified) * testsuites/smptests/smppsxsignal01/init.c (modified) * testsuites/smptests/smpschedaffinity01/init.c (modified) * testsuites/smptests/smpschedaffinity02/init.c (modified) * testsuites/smptests/smpschedaffinity03/init.c (modified) * testsuites/smptests/smpschedaffinity04/init.c (modified) * testsuites/smptests/smpschedaffinity05/init.c (modified) * testsuites/smptests/smpschedsem01/init.c (modified) * testsuites/smptests/smpscheduler01/init.c (modified) * testsuites/smptests/smpscheduler02/init.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/smptests/smpscheduler04/init.c (modified) * testsuites/smptests/smpsignal01/init.c (modified) * testsuites/smptests/smpstrongapa01/init.c (modified) * testsuites/smptests/smpswitchextension01/init.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) * testsuites/smptests/smpwakeafter01/init.c (modified) * testsuites/sptests/sptimecounter02/init.c (modified) * testsuites/sptests/sptimecounter03/init.c (modified) * testsuites/tmtests/tmcontext01/init.c (modified) * testsuites/tmtests/tmfine01/init.c (modified) Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS Rename ... Tue, 14 Feb 2017 07:58:33 GMT Sebastian Huber [c341463] * testsuites/support/include/tmacros.h (modified) tmacros.h: Fix print defines Tue, 14 Feb 2017 07:54:51 GMT Sebastian Huber [9333de2f] * testsuites/sptests/sppagesize/init.c (modified) sppagesize: Include missing header file Tue, 14 Feb 2017 07:46:22 GMT Sebastian Huber [5eee718] * cpukit/libmisc/shell/main_ping.c (modified) shell: Fix warnings Tue, 14 Feb 2017 07:42:48 GMT Sebastian Huber [6dbbafc6] * cpukit/score/src/threadname.c (modified) score: Fix warning in _Thread_Set_name() Mon, 13 Feb 2017 14:13:02 GMT Sebastian Huber [d9c65429] * cpukit/libfs/src/dosfs/msdos_misc.c (modified) * testsuites/fstests/fsdosfsname01/init.c (modified) dosfs: Fix msdos_find_file_in_directory() For a filename match the ... Fri, 03 Feb 2017 10:24:30 GMT Sebastian Huber [239dd35f] * testsuites/smptests/smp03/tasks.c (modified) * testsuites/smptests/smp08/init.c (modified) * testsuites/smptests/smp08/tasks.c (modified) * testsuites/smptests/smpschedaffinity05/init.c (modified) smptests: Fix warnings Wed, 01 Feb 2017 13:48:17 GMT Sebastian Huber [07d71279] * cpukit/sapi/include/confdefs.h (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/spstkalloc02/init.c (modified) Prefix confdefs.h internal def with an underscore Close #2895. Fri, 03 Feb 2017 09:49:13 GMT Sebastian Huber [85ed95e] * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) termios: Fix static device initalization This enables early ... Fri, 03 Feb 2017 07:57:18 GMT Sebastian Huber [bbfbfc8] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadscheduler.c (modified) score: Move _Thread_Scheduler_ask_for_help() Move ... Thu, 02 Feb 2017 15:24:05 GMT Sebastian Huber [ca1e546e] * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/schedulerpriority.h (modified) * cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h (modified) * cpukit/score/include/rtems/score/schedulerprioritysmp.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) * cpukit/score/include/rtems/score/schedulerstrongapa.h (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/scheduleredfunblock.c (modified) * cpukit/score/src/scheduleredfyield.c (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulerprioritysmp.c (modified) * cpukit/score/src/schedulerpriorityunblock.c (modified) * cpukit/score/src/schedulerpriorityyield.c (modified) * cpukit/score/src/schedulersimplesmp.c (modified) * cpukit/score/src/schedulersimpleunblock.c (modified) * cpukit/score/src/schedulersimpleyield.c (modified) * cpukit/score/src/schedulerstrongapa.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) score: Improve scheduler helping protocol Only register ask for ... Fri, 03 Feb 2017 09:16:40 GMT Sebastian Huber [e2b1c47d] * cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S (modified) sparc: Fix volatile clobber Do not adjust the stack pointer, since ... Fri, 03 Feb 2017 07:43:56 GMT Sebastian Huber [d4ff66e] * cpukit/sapi/include/confdefs.h (modified) confdefs.h: Simplify Thu, 02 Feb 2017 22:44:31 GMT Kevin Kirspel [f9db6fd] * cpukit/sapi/include/confdefs.h (modified) confdefs.h: Only define _CONFIGURE_SMP_APPLICATION if RTEMS_SMP defined Thu, 02 Feb 2017 08:16:53 GMT Sebastian Huber [6dd96af] * cpukit/rtems/include/rtems.h (modified) rtems: Fix RTEMS_NO_TIMEOUT define Cast the internal ... Wed, 01 Feb 2017 11:11:33 GMT Sebastian Huber [f95fa387] * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * testsuites/smptests/smp01/system.h (modified) * testsuites/smptests/smp02/system.h (modified) * testsuites/smptests/smp03/system.h (modified) * testsuites/smptests/smp05/init.c (modified) * testsuites/smptests/smp07/init.c (modified) * testsuites/smptests/smp08/system.h (modified) * testsuites/smptests/smp09/init.c (modified) * testsuites/smptests/smpaffinity01/init.c (modified) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpcapture01/init.c (modified) * testsuites/smptests/smpcapture02/init.c (modified) * testsuites/smptests/smpclock01/init.c (modified) * testsuites/smptests/smpfatal01/init.c (modified) * testsuites/smptests/smpfatal02/init.c (modified) * testsuites/smptests/smpfatal04/init.c (modified) * testsuites/smptests/smpfatal05/init.c (modified) * testsuites/smptests/smpfatal06/init.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) * testsuites/smptests/smpipi01/init.c (modified) * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) * testsuites/smptests/smpmigration01/init.c (modified) * testsuites/smptests/smpmigration02/init.c (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpmutex01/init.c (modified) * testsuites/smptests/smpmutex02/init.c (modified) * testsuites/smptests/smppsxaffinity01/init.c (modified) * testsuites/smptests/smppsxaffinity02/init.c (modified) * testsuites/smptests/smppsxmutex01/init.c (modified) * testsuites/smptests/smppsxsignal01/init.c (modified) * testsuites/smptests/smpschedaffinity01/init.c (modified) * testsuites/smptests/smpschedaffinity02/init.c (modified) * testsuites/smptests/smpschedaffinity03/init.c (modified) * testsuites/smptests/smpschedaffinity04/init.c (modified) * testsuites/smptests/smpschedaffinity05/init.c (modified) * testsuites/smptests/smpschedsem01/init.c (modified) * testsuites/smptests/smpscheduler01/init.c (modified) * testsuites/smptests/smpscheduler02/init.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/smptests/smpscheduler04/init.c (modified) * testsuites/smptests/smpsignal01/init.c (modified) * testsuites/smptests/smpstrongapa01/init.c (modified) * testsuites/smptests/smpswitchextension01/init.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/smptests/smpunsupported01/init.c (modified) * testsuites/smptests/smpwakeafter01/init.c (modified) * testsuites/sptests/sptimecounter02/init.c (modified) * testsuites/sptests/sptimecounter03/init.c (modified) * testsuites/tmtests/tmcontext01/init.c (modified) * testsuites/tmtests/tmfine01/init.c (modified) Remove CONFIGURE_SMP_APPLICATION Enable the SMP support if ... Wed, 01 Feb 2017 12:00:15 GMT Sebastian Huber [70f559d8] * cpukit/rtems/include/rtems/rtems/tasks.h (modified) rtems: Fix RTEMS_MAXIMUM_PRIORITY define Cast the internal ... Tue, 31 Jan 2017 08:01:37 GMT Sebastian Huber [f7ba2945] * cpukit/libmisc/monitor/mon-task.c (modified) monitor: Add support for BSD wakeup messages Tue, 31 Jan 2017 07:08:24 GMT Sebastian Huber [e366f77] * cpukit/libcsupport/src/assocthreadstatestostring.c (modified) * cpukit/libmisc/monitor/mon-task.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/posix/include/rtems/posix/condimpl.h (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/coresemimpl.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierwait.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/corerwlock.c (modified) * cpukit/score/src/corerwlockobtainread.c (modified) * cpukit/score/src/corerwlockobtainwrite.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadwaitgetid.c (modified) score: Add _Thread_queue_Object_name Add the special thread queue ... Tue, 31 Jan 2017 08:37:54 GMT Sebastian Huber [70488f56] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Fix _Thread_Initialize() Mon, 30 Jan 2017 18:34:28 GMT Kuan-Hsun Chen [166a9f67] * testsuites/sptests/spedfsched04/Makefile.am (modified) * testsuites/sptests/spedfsched04/init.c (modified) * testsuites/sptests/spedfsched04/spedfsched04.scn (modified) * testsuites/sptests/sprmsched01/Makefile.am (modified) * testsuites/sptests/sprmsched01/init.c (modified) * testsuites/sptests/sprmsched01/sprmsched01.scn (modified) sprmsched01/spedfsched04: Revise Instead of using the target time ... Mon, 30 Jan 2017 11:29:31 GMT Sebastian Huber [c5430e06] * cpukit/score/include/rtems/score/rbtree.h (modified) score: Fix unused parameter warning Close #2890. Mon, 30 Jan 2017 10:24:57 GMT Stavros Passas [575c2e21] * cpukit/libmisc/stackchk/stackchk.h (modified) Complete STACK_CHECKER_EXTENSION. Fixes #2889 Mon, 30 Jan 2017 10:33:31 GMT Christian Mauderer [180107e9] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/armv7m/startup/armv7m-cpucounter.c (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) bsps/arm: Fix Cortex-M DWT CPU counter. It is necessary to enable ... Fri, 27 Jan 2017 22:15:50 GMT Kuan-Hsun Chen [0794197] * cpukit/rtems/src/ratemontimeout.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sprmsched02/Makefile.am (added) * testsuites/sptests/sprmsched02/init.c (added) * testsuites/sptests/sprmsched02/sprmsched02.doc (added) * testsuites/sptests/sprmsched02/sprmsched02.scn (added) rtems: Fix _Rate_monotonic_Renew_deadline() Prepare a precondition ... Fri, 27 Jan 2017 07:06:06 GMT Sebastian Huber [4ea92d1e] * cpukit/score/include/rtems/score/heap.h (modified) score: Clarify _Heap_Extend() Update #1747. Fri, 27 Jan 2017 06:42:29 GMT Sebastian Huber [abc963d] * cpukit/score/include/rtems/score/heap.h (modified) score: Fix typo Thu, 26 Jan 2017 10:06:50 GMT Sebastian Huber [6f6da82c] * cpukit/score/include/rtems/score/userextimpl.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * cpukit/score/src/userextiterate.c (modified) * testsuites/sptests/spextensions01/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) score: Fix user extensions order Use forward and reverse order for ... Thu, 26 Jan 2017 10:05:00 GMT Sebastian Huber [d1505a1] * cpukit/sapi/include/rtems/extension.h (modified) sapi: Add rtems_task_terminate_extension Wed, 25 Jan 2017 20:47:48 GMT Kuan-Hsun Chen [d7feb86] * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * testsuites/sptests/sp69/init.c (modified) * testsuites/sptests/sp69/sp69.doc (modified) * testsuites/sptests/sp69/sp69.scn (modified) Remove rtems_rate_monotonic_postponed_job_count() Add a variable ... Wed, 25 Jan 2017 13:32:02 GMT Sebastian Huber [27bfcd8] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/src/threadinitialize.c (modified) score: Delete _CPU_Context_Fp_start() Since the FP area pointer is ... Wed, 25 Jan 2017 10:46:51 GMT Sebastian Huber [7cb7454f] * testsuites/psxtests/psxshm01/init.c (modified) * testsuites/psxtests/psxshm02/init.c (modified) psxtests: Relax shared memory tests There is currently no proper ... Wed, 25 Jan 2017 10:45:49 GMT Sebastian Huber [090bdc7e] * cpukit/posix/src/shmopen.c (modified) posix: Fix use of uninitialized variable Update #2859. Wed, 25 Jan 2017 10:16:02 GMT Sebastian Huber [23a11b6] * testsuites/sptests/spedfsched04/Makefile.am (modified) * testsuites/sptests/spedfsched04/init.c (modified) * testsuites/sptests/spedfsched04/system.h (deleted) * testsuites/sptests/spedfsched04/tasks.c (deleted) sptests/spedfsched04: Merge and fix Merge into one file and fix ... Tue, 24 Jan 2017 14:40:31 GMT Kevin Kirspel [b43c2e8] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) Adding ARM VFP V2 support Tue, 24 Jan 2017 14:34:47 GMT Sebastian Huber [29e08d4] * testsuites/sptests/sprmsched01/Makefile.am (modified) * testsuites/sptests/sprmsched01/init.c (modified) * testsuites/sptests/sprmsched01/system.h (deleted) * testsuites/sptests/sprmsched01/tasks.c (deleted) sptests/sprmsched01: Merge and fix Merge into one file and fix ... Tue, 24 Jan 2017 14:05:22 GMT Sebastian Huber [b8d6eb7] * cpukit/rtems/src/ratemonperiod.c (modified) rtems: rtems_rate_monotonic_postponed_job_count() Use proper ... Tue, 24 Jan 2017 14:04:11 GMT Sebastian Huber [625bd6a] * cpukit/rtems/src/ratemonperiod.c (modified) rtems: Fix _Rate_monotonic_Release_postponed_job() Use proper ... Tue, 24 Jan 2017 13:37:42 GMT Sebastian Huber [1240aade] * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) rtems: Fix _Rate_monotonic_Renew_deadline() Make ... Tue, 24 Jan 2017 09:07:57 GMT Sebastian Huber [6af2221] * testsuites/fstests/fsscandir01/init.c (modified) fsscandir01: Check MAXNAMLEN and NAME_MAX Update #1394. Tue, 24 Jan 2017 08:43:20 GMT Sebastian Huber [436a4b3] * testsuites/smptests/smpsignal01/init.c (modified) * testsuites/smptests/smpsignal01/smpsignal01.doc (modified) smptests/smpsignal01: Check signal ISR level Close #2751. Mon, 23 Jan 2017 14:04:44 GMT Sebastian Huber [3d20f5fb] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Relax CPU_STACK_ALIGNMENT Close #2352. Mon, 23 Jan 2017 07:12:18 GMT Sebastian Huber [4aa23c96] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIAN Use de-facto standard ...
