# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 22:08:04 Tue, 11 Apr 2000 20:19:59 GMT Joel Sherrill [2e34e9f1] * c/src/tests/psxtests/psxfile01/psxfile01.scn (modified) Added note indicating source of expected assertion. Fri, 07 Apr 2000 19:39:27 GMT Joel Sherrill [206ca3ae] * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (modified) Honor no data cache macro setting. Problem reported by Wilfried ... Fri, 07 Apr 2000 19:10:44 GMT Joel Sherrill [09652b9f] * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/network/netexterns.h (deleted) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) Cleanup patch from John Cotton . Fri, 07 Apr 2000 19:04:12 GMT Joel Sherrill [f50952c] * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (modified) Patch from Charles-Antoine Gauthier after ... Fri, 07 Apr 2000 19:01:01 GMT Joel Sherrill [cc655a5] * c/src/libnetworking/net/if_loop.c (modified) Patch from Eric Norum to make the loopback ... Wed, 05 Apr 2000 19:39:01 GMT Joel Sherrill [755c630] * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) Cleanup patch rtems-rc-4.5.0-11-cvs.diff from Ralf Corsepius ... Wed, 05 Apr 2000 19:37:04 GMT Joel Sherrill [6e48c9b] * make/custom/Makefile.am (modified) Cleanup patch from Ralf Corsepius. Wed, 05 Apr 2000 19:32:36 GMT Joel Sherrill [0315b79b] * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unix.h (modified) * c/src/lib/libc/termios.c (modified) Added support for Cygwin. Wed, 05 Apr 2000 19:09:06 GMT Joel Sherrill [35ff211] * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) Now all m68k BSPs specify _RamBase. This is necessary for the shared ... Wed, 05 Apr 2000 18:24:48 GMT Joel Sherrill [bb734cc] * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/network/netexterns.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (modified) * make/custom/mvme167.cfg (modified) Patch from Charles-Antoine Gauthier to ... Wed, 05 Apr 2000 13:27:53 GMT cvs2git [ce70a16] * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/network/netexterns.h (added) * c/src/lib/libbsp/m68k/mvme167/network/network.c (added) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (added) * make/custom/Cygwin-posix.cfg (added) This commit was manufactured by cvs2svn to create branch ... Wed, 05 Apr 2000 13:10:57 GMT Joel Sherrill [cbbc442e] * aclocal/canonical-host.m4 (modified) Added cygwin as simulator port. Wed, 05 Apr 2000 12:55:10 GMT Joel Sherrill [0c67e4ac] * c/src/lib/libbsp/m68k/mvme167/README (modified) Patch from Charles-Antoine Gauthier to go ... Wed, 05 Apr 2000 12:51:51 GMT Joel Sherrill [12edad6] * automake/local.am (modified) * c/src/make/leaf.cfg (modified) Patch rtems-rc-4.5-10-cvs.diff from Ralf Corsepius [a899433e] * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) Patch rtems-rc-4.5.0-8-cvs.diff from Ralf Corsepius [ad3c8e8] * c/src/Makefile.am (modified) Patch rtems-rc-4.5.0-8-cvs.diff from Ralf Corsepius [a7c46db9] * c/src/exec/rtems/src/semdelete.c (modified) Fixed typo. Mon, 03 Apr 2000 20:01:31 GMT Joel Sherrill [c34eb10] * aclocal/target.m4 (modified) * automake/local.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/configure.in (modified) * c/src/make/main.cfg.in (modified) * configure.in (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/rxgen960.cfg (modified) Patch rtems-rc-4.5.0-7-cvs.diff from Ralf Corsepius [cc2ccd6e] * c/src/make/leaf.cfg (added) This commit was manufactured by cvs2svn to create branch ... Mon, 03 Apr 2000 19:01:31 GMT Joel Sherrill [562f5c8] * aclocal/canonical-target-name.m4 (modified) Added cygwin as mapping to unix port. Mon, 03 Apr 2000 17:30:31 GMT Joel Sherrill [7f02ee73] * c/src/libnetworking/rtems/rtems_syscall.c (modified) Patch from Eric Norum to prevent leaking ... Mon, 03 Apr 2000 15:31:17 GMT Joel Sherrill [33677ef5] * c/src/tests/libtests/termios/README (modified) * c/src/tests/libtests/termios/init.c (modified) Enhancements from Charles-Antoine Gauthier . Mon, 03 Apr 2000 14:44:39 GMT Joel Sherrill [effc2c4] * automake/host.am (modified) * automake/local.am (modified) * automake/subdirs.am (modified) * c/Makefile.am (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/wrapup/itron/Makefile.am (modified) * c/src/exec/wrapup/posix/Makefile.am (modified) * c/src/exec/wrapup/rtems/Makefile.am (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/include/Makefile.am (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/src/Makefile.am (modified) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/librtems++/src/Makefile.am (modified) * c/src/make/configure.in (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/base_sp/Makefile.am (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/support/wrapup/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * tools/update/ampolish (modified) Patch rtems-rc-4.5.0-6-cvs.diff from Ralf Corsepius [0d744ab] * make/custom/mvme2307.cfg (modified) Patch from Jay Kulpinski that makes sure ... Mon, 03 Apr 2000 13:57:34 GMT Joel Sherrill [52448f35] * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) Patch from Jay Kulpinski that addresses a ... Mon, 03 Apr 2000 13:24:38 GMT Joel Sherrill [d2d4372d] * c/src/lib/libc/termios.c (modified) Patch from Charles-Antoine Gauthier ... Mon, 03 Apr 2000 13:10:50 GMT Joel Sherrill [7ea9f1d] * c/src/exec/rtems/src/semdelete.c (modified) Patch from Eric Norum so simple binary semaphores ... Thu, 23 Mar 2000 13:57:13 GMT Joel Sherrill [969525fe] * c/src/lib/include/sys/termios.h (modified) Added missing include of required by added prototypes. Wed, 22 Mar 2000 14:04:02 GMT Joel Sherrill [94795bbd] * bootstrap (modified) * tools/update/acpolish (modified) * tools/update/rtems-polish.sh (modified) Patch rtems-rc-4.5.0-5-cvs.diff from Ralf Corsepius ... Tue, 21 Mar 2000 21:35:47 GMT Joel Sherrill [96cf1812] * c/src/exec/score/cpu/m68k/qsm.h (modified) * c/src/exec/score/cpu/m68k/sim.h (modified) Removed referecnes to BSP specific files. Other corrections will ... Tue, 21 Mar 2000 21:33:38 GMT Joel Sherrill [776d696] * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) Corrected mpc505/mpc509 support based on patch from Wilfried Busalski ... Tue, 21 Mar 2000 20:15:09 GMT Joel Sherrill [af7a0ed] * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) Patch from Eric Norum to correct calls to ... Tue, 21 Mar 2000 18:35:00 GMT Joel Sherrill [05a34668] * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) Patch from Gunter Magin where the type was ... Tue, 21 Mar 2000 18:05:29 GMT Joel Sherrill [abbf55b] * c/src/lib/libcpu/powerpc/mpc821/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) * c/src/lib/libcpu/sh/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/include/Makefile.am (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/machine/Makefile.am (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/vm/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/src/Makefile.am (modified) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/librtems++/src/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/custom/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/support/wrapup/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * make/Makefile.am (modified) * make/Templates/Makefile.am (modified) * make/compilers/Makefile.am (modified) * make/custom/Makefile.am (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts-ada/gnatnewlib/Makefile.am (modified) * scripts/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/unix/Makefile.am (modified) * tools/update/Makefile.am (modified) Ran ampolish after getting new version from Ralf Corsepius ... Tue, 21 Mar 2000 17:57:21 GMT Joel Sherrill [6f921ba] * Makefile.am (modified) * c/Makefile.am (modified) * c/make/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/wrapup/itron/Makefile.am (modified) * c/src/exec/wrapup/posix/Makefile.am (modified) * c/src/exec/wrapup/rtems/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/a29k/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/adasockets/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/unix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/a29k/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) Ran ampolish after getting new version from Ralf Corsepius ... Tue, 21 Mar 2000 17:11:40 GMT Joel Sherrill [67077a1] * automake/local.am (modified) * bootstrap (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/mptests/mp14/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/support/wrapup/Makefile.am (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/simhppa.cfg (modified) * make/leaf.cfg (modified) * tools/update/ampolish (modified) Patches rtems-rc-4.5.0-1.diff from Ralf Corsepius [15b6e46f] * c/src/exec/posix/src/waitpid.c (modified) Patch from Charles-Antoine Gauthier to fix ... Tue, 21 Mar 2000 15:36:48 GMT Joel Sherrill [d5666945] * c/src/lib/include/sys/termios.h (modified) After Charles-Antoine Gauthier spotted that ... Tue, 21 Mar 2000 15:06:04 GMT Joel Sherrill [d6b0477] * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) Patch from Gunter Magin . It seems to me ... Tue, 21 Mar 2000 15:05:19 GMT Joel Sherrill [218103d] * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) Patch from Gunter Magin . It seems to me ... Tue, 21 Mar 2000 14:46:40 GMT Joel Sherrill [477f347] * c/src/libnetworking/rtems_webserver/Makefile.am (modified) Problem reported by Chris Johns that webcomp.c was ... Tue, 29 Feb 2000 14:19:26 GMT Joel Sherrill [89fbb94] * VERSION (modified) changed version to 4.5.0-beta1c Mon, 28 Feb 2000 15:00:28 GMT Joel Sherrill [ac11ade] * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) Fixed one type and switched to including the correct Makefile support ... Fri, 25 Feb 2000 18:50:47 GMT Joel Sherrill [0ac81975] * automake/host.am (added) Patches rtems-rc-4.5.0-1.diff from Ralf Corsepius [02c31b9c] * Makefile.am (modified) Patches rtems-rc-4.5.0-1.diff from Ralf Corsepius [99eb585] * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/base_sp/Makefile.am (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * make/Makefile.am (modified) * make/Templates/Makefile.am (modified) * make/compilers/Makefile.am (modified) * make/custom/Makefile.am (modified) * make/custom/efi68k.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/ods68302.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * tools/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/sh/shgen.c (modified) * tools/cpu/unix/Makefile.am (modified) * tools/update/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/cipolish (modified) Patches rtems-rc-4.5.0-1.diff from Ralf Corsepius [77b2b0e] * automake/local.am (modified) * c/Makefile.am (modified) * c/make/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/include/Makefile.am (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) Patches rtems-rc-4.5.0-1.diff from Ralf Corsepius [06f190b] * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) Correcting them so they have a chance of working. They need to at ... Wed, 23 Feb 2000 16:01:11 GMT Joel Sherrill [7209360a] * c/src/libnetworking/rtems_webserver/Makefile.am (modified) Fix based on report from Jake Janovetz ... Wed, 23 Feb 2000 15:59:20 GMT Joel Sherrill [f362fa7] * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) Fixed based on report from Peter Pointner that ... Sat, 19 Feb 2000 15:46:40 GMT Joel Sherrill [06383557] * aclocal/prog-cxx.m4 (modified) * c/src/make/Makefile.am (modified) * c/src/make/main.cfg.in (modified) * make/main.cfg (modified) Patch rtems-rc-4.5.0-diff from Ralf Corsepius to address a problem ... Fri, 18 Feb 2000 14:30:56 GMT Joel Sherrill [2de8b1b] * c/src/tests/libtests/cpuuse/tswitch.c (modified) Small patch from Peter Pointner to correct ... Fri, 18 Feb 2000 13:53:06 GMT Joel Sherrill [15093362] * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) Patch from Eric Norum to address these issues: ... Wed, 16 Feb 2000 17:47:48 GMT Joel Sherrill [56616af3] * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * make/custom/pc386.cfg (modified) Patch rtems-rc-4.5.0-1.diff from Ralf Corsepius [319d298] * c/src/lib/libc/libio.c (modified) Changed <= to < to prevent overindexing array of file control blocks ... Fri, 11 Feb 2000 15:54:48 GMT cvs2git [d5e3931] * c/src/ada-tests/mptests/mp01/config.h (deleted) * c/src/ada-tests/mptests/mp01/mp01.adb (deleted) * c/src/ada-tests/mptests/mp01/mptest.adb (deleted) * c/src/ada-tests/mptests/mp01/mptest.ads (deleted) * c/src/ada-tests/mptests/mp01/node1/mp01.scn (deleted) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp01/node2/mp01.scn (deleted) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp02/mptest.adb (deleted) * c/src/ada-tests/mptests/mp02/mptest.ads (deleted) * c/src/ada-tests/mptests/mp02/node1/mp02.scn (deleted) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp02/node2/mp02.scn (deleted) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp03/mptest.adb (deleted) * c/src/ada-tests/mptests/mp03/mptest.ads (deleted) * c/src/ada-tests/mptests/mp03/node1/mp03.scn (deleted) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp03/node2/mp03.scn (deleted) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp04/mptest.adb (deleted) * c/src/ada-tests/mptests/mp04/mptest.ads (deleted) * c/src/ada-tests/mptests/mp04/node1/mp04.scn (deleted) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp04/node2/mp04.scn (deleted) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp05/mptest.adb (deleted) * c/src/ada-tests/mptests/mp05/mptest.ads (deleted) * c/src/ada-tests/mptests/mp05/node1/mp05.scn (deleted) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp05/node2/mp05.scn (deleted) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp06/mptest.adb (deleted) * c/src/ada-tests/mptests/mp06/mptest.ads (deleted) * c/src/ada-tests/mptests/mp06/node1/mp06.scn (deleted) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp06/node2/mp06.scn (deleted) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp07/mptest.adb (deleted) * c/src/ada-tests/mptests/mp07/mptest.ads (deleted) * c/src/ada-tests/mptests/mp07/node1/mp07.scn (deleted) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp07/node2/mp07.scn (deleted) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp08/mptest.adb (deleted) * c/src/ada-tests/mptests/mp08/mptest.ads (deleted) * c/src/ada-tests/mptests/mp08/node1/mp08.scn (deleted) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp08/node2/mp08.scn (deleted) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp09/mptest.adb (deleted) * c/src/ada-tests/mptests/mp09/mptest.ads (deleted) * c/src/ada-tests/mptests/mp09/node1/mp09.scn (deleted) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp09/node2/mp09.scn (deleted) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp10/mptest.adb (deleted) * c/src/ada-tests/mptests/mp10/mptest.ads (deleted) * c/src/ada-tests/mptests/mp10/node1/mp10.scn (deleted) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp10/node2/mp10.scn (deleted) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp11/mptest.adb (deleted) * c/src/ada-tests/mptests/mp11/mptest.ads (deleted) * c/src/ada-tests/mptests/mp11/node1/mp11.scn (deleted) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp11/node2/mp11.scn (deleted) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp12/mptest.adb (deleted) * c/src/ada-tests/mptests/mp12/mptest.ads (deleted) * c/src/ada-tests/mptests/mp12/node1/mp12.scn (deleted) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp12/node2/mp12.scn (deleted) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp13/mptest.adb (deleted) * c/src/ada-tests/mptests/mp13/mptest.ads (deleted) * c/src/ada-tests/mptests/mp13/node1/mp13.scn (deleted) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp13/node2/mp13.scn (deleted) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp14/mptest.adb (deleted) * c/src/ada-tests/mptests/mp14/mptest.ads (deleted) * c/src/ada-tests/mptests/mp14/node1/mp14.scn (deleted) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp14/node2/mp14.scn (deleted) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/samples/base_mp/mptest.adb (deleted) * c/src/ada-tests/samples/base_mp/mptest.ads (deleted) * c/src/ada-tests/samples/base_mp/node1/base_mp.scn (deleted) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/samples/base_mp/node2/base_mp.scn (deleted) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/samples/base_sp/base_sp.adb (deleted) * c/src/ada-tests/samples/base_sp/base_sp.scn (deleted) * c/src/ada-tests/samples/base_sp/config.h (deleted) * c/src/ada-tests/samples/base_sp/sptest.adb (deleted) * c/src/ada-tests/samples/base_sp/sptest.ads (deleted) * c/src/ada-tests/samples/hello/config.h (deleted) * c/src/ada-tests/samples/hello/hello.adb (deleted) * c/src/ada-tests/samples/hello/hello.scn (deleted) * c/src/ada-tests/samples/hello/sptest.adb (deleted) * c/src/ada-tests/samples/hello/sptest.ads (deleted) * c/src/ada-tests/samples/ticker/config.h (deleted) * c/src/ada-tests/samples/ticker/sptest.adb (deleted) * c/src/ada-tests/samples/ticker/sptest.ads (deleted) * c/src/ada-tests/samples/ticker/ticker.adb (deleted) * c/src/ada-tests/samples/ticker/ticker.scn (deleted) * c/src/ada-tests/sptests/sp01/config.h (deleted) * c/src/ada-tests/sptests/sp01/sp01.adb (deleted) * c/src/ada-tests/sptests/sp01/sp01.scn (deleted) * c/src/ada-tests/sptests/sp01/sptest.adb (deleted) * c/src/ada-tests/sptests/sp01/sptest.ads (deleted) * c/src/ada-tests/sptests/sp02/config.h (deleted) * c/src/ada-tests/sptests/sp02/sp02.adb (deleted) * c/src/ada-tests/sptests/sp02/sp02.scn (deleted) * c/src/ada-tests/sptests/sp02/sptest.adb (deleted) * c/src/ada-tests/sptests/sp02/sptest.ads (deleted) * c/src/ada-tests/sptests/sp03/config.h (deleted) * c/src/ada-tests/sptests/sp03/sp03.adb (deleted) * c/src/ada-tests/sptests/sp03/sp03.scn (deleted) * c/src/ada-tests/sptests/sp03/sptest.adb (deleted) * c/src/ada-tests/sptests/sp03/sptest.ads (deleted) * c/src/ada-tests/sptests/sp04/README (deleted) * c/src/ada-tests/sptests/sp04/config.h (deleted) * c/src/ada-tests/sptests/sp04/sp04.adb (deleted) * c/src/ada-tests/sptests/sp04/sp04.scn (deleted) * c/src/ada-tests/sptests/sp04/sptest.adb (deleted) * c/src/ada-tests/sptests/sp04/sptest.ads (deleted) * c/src/ada-tests/sptests/sp05/config.h (deleted) * c/src/ada-tests/sptests/sp05/sp05.adb (deleted) * c/src/ada-tests/sptests/sp05/sp05.scn (deleted) * c/src/ada-tests/sptests/sp05/sptest.adb (deleted) * c/src/ada-tests/sptests/sp05/sptest.ads (deleted) * c/src/ada-tests/sptests/sp06/config.h (deleted) * c/src/ada-tests/sptests/sp06/sp06.adb (deleted) * c/src/ada-tests/sptests/sp06/sp06.scn (deleted) * c/src/ada-tests/sptests/sp06/sptest.adb (deleted) * c/src/ada-tests/sptests/sp06/sptest.ads (deleted) * c/src/ada-tests/sptests/sp07/config.h (deleted) * c/src/ada-tests/sptests/sp07/sp07.adb (deleted) * c/src/ada-tests/sptests/sp07/sp07.scn (deleted) * c/src/ada-tests/sptests/sp07/sptest.adb (deleted) * c/src/ada-tests/sptests/sp07/sptest.ads (deleted) * c/src/ada-tests/sptests/sp08/config.h (deleted) * c/src/ada-tests/sptests/sp08/sp08.adb (deleted) * c/src/ada-tests/sptests/sp08/sp08.scn (deleted) * c/src/ada-tests/sptests/sp08/sptest.adb (deleted) * c/src/ada-tests/sptests/sp08/sptest.ads (deleted) * c/src/ada-tests/sptests/sp09/config.h (deleted) * c/src/ada-tests/sptests/sp09/sp09.adb (deleted) * c/src/ada-tests/sptests/sp09/sp09.scn (deleted) * c/src/ada-tests/sptests/sp09/sptest.adb (deleted) * c/src/ada-tests/sptests/sp09/sptest.ads (deleted) * c/src/ada-tests/sptests/sp11/config.h (deleted) * c/src/ada-tests/sptests/sp11/sp11.adb (deleted) * c/src/ada-tests/sptests/sp11/sp11.scn (deleted) * c/src/ada-tests/sptests/sp11/sptest.adb (deleted) * c/src/ada-tests/sptests/sp11/sptest.ads (deleted) * c/src/ada-tests/sptests/sp12/config.h (deleted) * c/src/ada-tests/sptests/sp12/sp12.adb (deleted) * c/src/ada-tests/sptests/sp12/sp12.scn (deleted) * c/src/ada-tests/sptests/sp12/sptest.adb (deleted) * c/src/ada-tests/sptests/sp12/sptest.ads (deleted) * c/src/ada-tests/sptests/sp13/config.h (deleted) * c/src/ada-tests/sptests/sp13/sp13.adb (deleted) * c/src/ada-tests/sptests/sp13/sp13.scn (deleted) * c/src/ada-tests/sptests/sp13/sptest.adb (deleted) * c/src/ada-tests/sptests/sp13/sptest.ads (deleted) * c/src/ada-tests/sptests/sp14/config.h (deleted) * c/src/ada-tests/sptests/sp14/sp14.adb (deleted) * c/src/ada-tests/sptests/sp14/sp14.scn (deleted) * c/src/ada-tests/sptests/sp14/sptest.adb (deleted) * c/src/ada-tests/sptests/sp14/sptest.ads (deleted) * c/src/ada-tests/sptests/sp15/config.h (deleted) * c/src/ada-tests/sptests/sp15/sp15.adb (deleted) * c/src/ada-tests/sptests/sp15/sp15.scn (deleted) * c/src/ada-tests/sptests/sp15/sptest.adb (deleted) * c/src/ada-tests/sptests/sp15/sptest.ads (deleted) * c/src/ada-tests/sptests/sp16/config.h (deleted) * c/src/ada-tests/sptests/sp16/sp16.adb (deleted) * c/src/ada-tests/sptests/sp16/sp16.scn (deleted) * c/src/ada-tests/sptests/sp16/sptest.adb (deleted) * c/src/ada-tests/sptests/sp16/sptest.ads (deleted) * c/src/ada-tests/sptests/sp17/config.h (deleted) * c/src/ada-tests/sptests/sp17/sp17.adb (deleted) * c/src/ada-tests/sptests/sp17/sp17.scn (deleted) * c/src/ada-tests/sptests/sp17/sptest.adb (deleted) * c/src/ada-tests/sptests/sp17/sptest.ads (deleted) * c/src/ada-tests/sptests/sp19/README (deleted) * c/src/ada-tests/sptests/sp19/config.h (deleted) * c/src/ada-tests/sptests/sp19/sp19.adb (deleted) * c/src/ada-tests/sptests/sp19/sp19.scn (deleted) * c/src/ada-tests/sptests/sp19/sptest.ads (deleted) * c/src/ada-tests/sptests/sp20/config.h (deleted) * c/src/ada-tests/sptests/sp20/sp20.adb (deleted) * c/src/ada-tests/sptests/sp20/sp20.scn (deleted) * c/src/ada-tests/sptests/sp20/sptest.adb (deleted) * c/src/ada-tests/sptests/sp20/sptest.ads (deleted) * c/src/ada-tests/sptests/sp21/config.h (deleted) * c/src/ada-tests/sptests/sp21/sp21.adb (deleted) * c/src/ada-tests/sptests/sp21/sp21.scn (deleted) * c/src/ada-tests/sptests/sp21/sptest.adb (deleted) * c/src/ada-tests/sptests/sp21/sptest.ads (deleted) * c/src/ada-tests/sptests/sp22/config.h (deleted) * c/src/ada-tests/sptests/sp22/sp22.adb (deleted) * c/src/ada-tests/sptests/sp22/sp22.scn (deleted) * c/src/ada-tests/sptests/sp22/sptest.adb (deleted) * c/src/ada-tests/sptests/sp22/sptest.ads (deleted) * c/src/ada-tests/sptests/sp23/config.h (deleted) * c/src/ada-tests/sptests/sp23/sp23.adb (deleted) * c/src/ada-tests/sptests/sp23/sp23.scn (deleted) * c/src/ada-tests/sptests/sp23/sptest.adb (deleted) * c/src/ada-tests/sptests/sp23/sptest.ads (deleted) * c/src/ada-tests/sptests/sp24/config.h (deleted) * c/src/ada-tests/sptests/sp24/sp24.adb (deleted) * c/src/ada-tests/sptests/sp24/sp24.scn (deleted) * c/src/ada-tests/sptests/sp24/sptest.adb (deleted) * c/src/ada-tests/sptests/sp24/sptest.ads (deleted) * c/src/ada-tests/sptests/sp25/config.h (deleted) * c/src/ada-tests/sptests/sp25/sp25.adb (deleted) * c/src/ada-tests/sptests/sp25/sp25.scn (deleted) * c/src/ada-tests/sptests/sp25/sptest.adb (deleted) * c/src/ada-tests/sptests/sp25/sptest.ads (deleted) * c/src/ada-tests/sptests/spsize/spsize.adb (deleted) * c/src/ada-tests/sptests/spsize/sptest.adb (deleted) * c/src/ada-tests/sptests/spsize/sptest.ads (deleted) * c/src/ada-tests/support/address_io.adb (deleted) * c/src/ada-tests/support/address_io.ads (deleted) * c/src/ada-tests/support/float_io.ads (deleted) * c/src/ada-tests/support/fp.inc (deleted) * c/src/ada-tests/support/init.c (deleted) * c/src/ada-tests/support/integer.inc (deleted) * c/src/ada-tests/support/rtems_calling_overhead.ads (deleted) * c/src/ada-tests/support/status_io.ads (deleted) * c/src/ada-tests/support/test_support.adb (deleted) * c/src/ada-tests/support/test_support.ads (deleted) * c/src/ada-tests/support/time_test_support.adb (deleted) * c/src/ada-tests/support/time_test_support.ads (deleted) * c/src/ada-tests/support/timer_driver.adb (deleted) * c/src/ada-tests/support/timer_driver.ads (deleted) * c/src/ada-tests/support/unsigned32_io.ads (deleted) * c/src/ada-tests/tmtests/tm01/config.h (deleted) * c/src/ada-tests/tmtests/tm01/tm01.adb (deleted) * c/src/ada-tests/tmtests/tm01/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm01/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm02/config.h (deleted) * c/src/ada-tests/tmtests/tm02/tm02.adb (deleted) * c/src/ada-tests/tmtests/tm02/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm02/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm03/config.h (deleted) * c/src/ada-tests/tmtests/tm03/tm03.adb (deleted) * c/src/ada-tests/tmtests/tm03/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm03/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm04/config.h (deleted) * c/src/ada-tests/tmtests/tm04/tm04.adb (deleted) * c/src/ada-tests/tmtests/tm04/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm04/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm05/config.h (deleted) * c/src/ada-tests/tmtests/tm05/tm05.adb (deleted) * c/src/ada-tests/tmtests/tm05/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm05/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm06/config.h (deleted) * c/src/ada-tests/tmtests/tm06/tm06.adb (deleted) * c/src/ada-tests/tmtests/tm06/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm06/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm07/config.h (deleted) * c/src/ada-tests/tmtests/tm07/tm07.adb (deleted) * c/src/ada-tests/tmtests/tm07/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm07/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm08/config.h (deleted) * c/src/ada-tests/tmtests/tm08/tm08.adb (deleted) * c/src/ada-tests/tmtests/tm08/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm08/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm09/config.h (deleted) * c/src/ada-tests/tmtests/tm09/tm09.adb (deleted) * c/src/ada-tests/tmtests/tm09/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm09/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm10/config.h (deleted) * c/src/ada-tests/tmtests/tm10/tm10.adb (deleted) * c/src/ada-tests/tmtests/tm10/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm10/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm11/config.h (deleted) * c/src/ada-tests/tmtests/tm11/tm11.adb (deleted) * c/src/ada-tests/tmtests/tm11/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm11/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm12/config.h (deleted) * c/src/ada-tests/tmtests/tm12/tm12.adb (deleted) * c/src/ada-tests/tmtests/tm12/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm12/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm13/config.h (deleted) * c/src/ada-tests/tmtests/tm13/tm13.adb (deleted) * c/src/ada-tests/tmtests/tm13/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm13/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm14/config.h (deleted) * c/src/ada-tests/tmtests/tm14/tm14.adb (deleted) * c/src/ada-tests/tmtests/tm14/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm14/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm15/config.h (deleted) * c/src/ada-tests/tmtests/tm15/tm15.adb (deleted) * c/src/ada-tests/tmtests/tm15/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm15/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm16/config.h (deleted) * c/src/ada-tests/tmtests/tm16/tm16.adb (deleted) * c/src/ada-tests/tmtests/tm16/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm16/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm17/config.h (deleted) * c/src/ada-tests/tmtests/tm17/tm17.adb (deleted) * c/src/ada-tests/tmtests/tm17/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm17/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm18/config.h (deleted) * c/src/ada-tests/tmtests/tm18/tm18.adb (deleted) * c/src/ada-tests/tmtests/tm18/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm18/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm19/config.h (deleted) * c/src/ada-tests/tmtests/tm19/tm19.adb (deleted) * c/src/ada-tests/tmtests/tm19/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm19/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm20/config.h (deleted) * c/src/ada-tests/tmtests/tm20/tm20.adb (deleted) * c/src/ada-tests/tmtests/tm20/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm20/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm21/config.h (deleted) * c/src/ada-tests/tmtests/tm21/tm21.adb (deleted) * c/src/ada-tests/tmtests/tm21/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm21/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm22/config.h (deleted) * c/src/ada-tests/tmtests/tm22/tm22.adb (deleted) * c/src/ada-tests/tmtests/tm22/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm22/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm23/config.h (deleted) * c/src/ada-tests/tmtests/tm23/tm23.adb (deleted) * c/src/ada-tests/tmtests/tm23/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm23/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm24/config.h (deleted) * c/src/ada-tests/tmtests/tm24/tm24.adb (deleted) * c/src/ada-tests/tmtests/tm24/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm24/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm25/config.h (deleted) * c/src/ada-tests/tmtests/tm25/tm25.adb (deleted) * c/src/ada-tests/tmtests/tm25/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm25/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm26/README (deleted) * c/src/ada-tests/tmtests/tm26/config.h (deleted) * c/src/ada-tests/tmtests/tm26/tm26.adb (deleted) * c/src/ada-tests/tmtests/tm26/tmtest.adp (deleted) * c/src/ada-tests/tmtests/tm26/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm27/README (deleted) * c/src/ada-tests/tmtests/tm27/config.h (deleted) * c/src/ada-tests/tmtests/tm27/tm27.adb (deleted) * c/src/ada-tests/tmtests/tm27/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm27/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm28/config.h (deleted) * c/src/ada-tests/tmtests/tm28/tm28.adb (deleted) * c/src/ada-tests/tmtests/tm28/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm28/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm29/config.h (deleted) * c/src/ada-tests/tmtests/tm29/tm29.adb (deleted) * c/src/ada-tests/tmtests/tm29/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm29/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tmck/config.h (deleted) * c/src/ada-tests/tmtests/tmck/tmck.adb (deleted) * c/src/ada-tests/tmtests/tmck/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tmck/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tmoverhd/README (deleted) * c/src/ada-tests/tmtests/tmoverhd/config.h (deleted) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (deleted) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (deleted) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (deleted) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (deleted) * c/src/ada/rtems.adb (deleted) * c/src/ada/rtems.ads (deleted) * c/src/exec/include/rtems/libio_.h (deleted) * c/src/exec/libcsupport/Makefile.am (deleted) * c/src/exec/libcsupport/include/chain.h (deleted) * c/src/exec/libcsupport/include/clockdrv.h (deleted) * c/src/exec/libcsupport/include/console.h (deleted) * c/src/exec/libcsupport/include/iosupp.h (deleted) * c/src/exec/libcsupport/include/motorola/mc68230.h (deleted) * c/src/exec/libcsupport/include/motorola/mc68681.h (deleted) * c/src/exec/libcsupport/include/ringbuf.h (deleted) * c/src/exec/libcsupport/include/rtems/assoc.h (deleted) * c/src/exec/libcsupport/include/rtems/error.h (deleted) * c/src/exec/libcsupport/include/rtems/libcsupport.h (deleted) * c/src/exec/libcsupport/include/rtems/libio.h (deleted) * c/src/exec/libcsupport/include/rtems/libio_.h (deleted) * c/src/exec/libcsupport/include/spurious.h (deleted) * c/src/exec/libcsupport/include/sys/filio.h (deleted) * c/src/exec/libcsupport/include/sys/ioctl.h (deleted) * c/src/exec/libcsupport/include/sys/sockio.h (deleted) * c/src/exec/libcsupport/include/sys/termios.h (deleted) * c/src/exec/libcsupport/include/sys/utime.h (deleted) * c/src/exec/libcsupport/include/sys/utsname.h (deleted) * c/src/exec/libcsupport/include/timerdrv.h (deleted) * c/src/exec/libcsupport/include/vmeintr.h (deleted) * c/src/exec/libcsupport/include/zilog/z8036.h (deleted) * c/src/exec/libcsupport/include/zilog/z8530.h (deleted) * c/src/exec/libcsupport/include/zilog/z8536.h (deleted) * c/src/exec/libcsupport/src/CASES (deleted) * c/src/exec/libcsupport/src/Makefile.am (deleted) * c/src/exec/libcsupport/src/README (deleted) * c/src/exec/libcsupport/src/TODO (deleted) * c/src/exec/libcsupport/src/__brk.c (deleted) * c/src/exec/libcsupport/src/__getpid.c (deleted) * c/src/exec/libcsupport/src/__gettod.c (deleted) * c/src/exec/libcsupport/src/__sbrk.c (deleted) * c/src/exec/libcsupport/src/__times.c (deleted) * c/src/exec/libcsupport/src/access.c (deleted) * c/src/exec/libcsupport/src/assoc.c (deleted) * c/src/exec/libcsupport/src/assocnamebad.c (deleted) * c/src/exec/libcsupport/src/base_fs.c (deleted) * c/src/exec/libcsupport/src/cfgetispeed.c (deleted) * c/src/exec/libcsupport/src/cfgetospeed.c (deleted) * c/src/exec/libcsupport/src/cfsetispeed.c (deleted) * c/src/exec/libcsupport/src/cfsetospeed.c (deleted) * c/src/exec/libcsupport/src/chdir.c (deleted) * c/src/exec/libcsupport/src/chmod.c (deleted) * c/src/exec/libcsupport/src/chown.c (deleted) * c/src/exec/libcsupport/src/close.c (deleted) * c/src/exec/libcsupport/src/closedir.c (deleted) * c/src/exec/libcsupport/src/creat.c (deleted) * c/src/exec/libcsupport/src/ctermid.c (deleted) * c/src/exec/libcsupport/src/dup.c (deleted) * c/src/exec/libcsupport/src/dup2.c (deleted) * c/src/exec/libcsupport/src/error.c (deleted) * c/src/exec/libcsupport/src/eval.c (deleted) * c/src/exec/libcsupport/src/fchmod.c (deleted) * c/src/exec/libcsupport/src/fcntl.c (deleted) * c/src/exec/libcsupport/src/fdatasync.c (deleted) * c/src/exec/libcsupport/src/fpathconf.c (deleted) * c/src/exec/libcsupport/src/fs_null_handlers.c (deleted) * c/src/exec/libcsupport/src/fstat.c (deleted) * c/src/exec/libcsupport/src/fsync.c (deleted) * c/src/exec/libcsupport/src/ftruncate.c (deleted) * c/src/exec/libcsupport/src/getcwd.c (deleted) * c/src/exec/libcsupport/src/getdents.c (deleted) * c/src/exec/libcsupport/src/getgrent.c (deleted) * c/src/exec/libcsupport/src/getpwent.c (deleted) * c/src/exec/libcsupport/src/hosterr.c (deleted) * c/src/exec/libcsupport/src/ioctl.c (deleted) * c/src/exec/libcsupport/src/isatty.c (deleted) * c/src/exec/libcsupport/src/libio.c (deleted) * c/src/exec/libcsupport/src/libio_sockets.c (deleted) * c/src/exec/libcsupport/src/link.c (deleted) * c/src/exec/libcsupport/src/lseek.c (deleted) * c/src/exec/libcsupport/src/lstat.c (deleted) * c/src/exec/libcsupport/src/malloc.c (deleted) * c/src/exec/libcsupport/src/mkdir.c (deleted) * c/src/exec/libcsupport/src/mkfifo.c (deleted) * c/src/exec/libcsupport/src/mknod.c (deleted) * c/src/exec/libcsupport/src/mount.c (deleted) * c/src/exec/libcsupport/src/newlibc.c (deleted) * c/src/exec/libcsupport/src/no_libc.c (deleted) * c/src/exec/libcsupport/src/no_posix.c (deleted) * c/src/exec/libcsupport/src/open.c (deleted) * c/src/exec/libcsupport/src/opendir.c (deleted) * c/src/exec/libcsupport/src/pathconf.c (deleted) * c/src/exec/libcsupport/src/pipe.c (deleted) * c/src/exec/libcsupport/src/read.c (deleted) * c/src/exec/libcsupport/src/readdir.c (deleted) * c/src/exec/libcsupport/src/readlink.c (deleted) * c/src/exec/libcsupport/src/rewinddir.c (deleted) * c/src/exec/libcsupport/src/rmdir.c (deleted) * c/src/exec/libcsupport/src/scandir.c (deleted) * c/src/exec/libcsupport/src/seekdir.c (deleted) * c/src/exec/libcsupport/src/stat.c (deleted) * c/src/exec/libcsupport/src/symlink.c (deleted) * c/src/exec/libcsupport/src/tcdrain.c (deleted) * c/src/exec/libcsupport/src/tcflow.c (deleted) * c/src/exec/libcsupport/src/tcflush.c (deleted) * c/src/exec/libcsupport/src/tcgetattr.c (deleted) * c/src/exec/libcsupport/src/tcgetprgrp.c (deleted) * c/src/exec/libcsupport/src/tcsendbreak.c (deleted) * c/src/exec/libcsupport/src/tcsetattr.c (deleted) * c/src/exec/libcsupport/src/tcsetpgrp.c (deleted) * c/src/exec/libcsupport/src/telldir.c (deleted) * c/src/exec/libcsupport/src/termios.c (deleted) * c/src/exec/libcsupport/src/termiosinitialize.c (deleted) * c/src/exec/libcsupport/src/termiosreserveresources.c (deleted) * c/src/exec/libcsupport/src/truncate.c (deleted) * c/src/exec/libcsupport/src/ttyname.c (deleted) * c/src/exec/libcsupport/src/ttyname_r.c (deleted) * c/src/exec/libcsupport/src/umask.c (deleted) * c/src/exec/libcsupport/src/unixlibc.c (deleted) * c/src/exec/libcsupport/src/unlink.c (deleted) * c/src/exec/libcsupport/src/unmount.c (deleted) * c/src/exec/libcsupport/src/utime.c (deleted) * c/src/exec/libcsupport/src/utsname.c (deleted) * c/src/exec/libcsupport/src/write.c (deleted) * c/src/exec/libfs/src/imfs/deviceio.c (deleted) * c/src/exec/libfs/src/imfs/imfs.h (deleted) * c/src/exec/libfs/src/imfs/imfs_chown.c (deleted) * c/src/exec/libfs/src/imfs/imfs_creat.c (deleted) * c/src/exec/libfs/src/imfs/imfs_debug.c (deleted) * c/src/exec/libfs/src/imfs/imfs_directory.c (deleted) * c/src/exec/libfs/src/imfs/imfs_eval.c (deleted) * c/src/exec/libfs/src/imfs/imfs_fchmod.c (deleted) * c/src/exec/libfs/src/imfs/imfs_fcntl.c (deleted) * c/src/exec/libfs/src/imfs/imfs_fdatasync.c (deleted) * c/src/exec/libfs/src/imfs/imfs_free.c (deleted) * c/src/exec/libfs/src/imfs/imfs_fsunmount.c (deleted) * c/src/exec/libfs/src/imfs/imfs_getchild.c (deleted) * c/src/exec/libfs/src/imfs/imfs_gtkn.c (deleted) * c/src/exec/libfs/src/imfs/imfs_handlers_device.c (deleted) * c/src/exec/libfs/src/imfs/imfs_handlers_directory.c (deleted) * c/src/exec/libfs/src/imfs/imfs_handlers_link.c (deleted) * c/src/exec/libfs/src/imfs/imfs_handlers_memfile.c (deleted) * c/src/exec/libfs/src/imfs/imfs_init.c (deleted) * c/src/exec/libfs/src/imfs/imfs_initsupp.c (deleted) * c/src/exec/libfs/src/imfs/imfs_link.c (deleted) * c/src/exec/libfs/src/imfs/imfs_mknod.c (deleted) * c/src/exec/libfs/src/imfs/imfs_mount.c (deleted) * c/src/exec/libfs/src/imfs/imfs_ntype.c (deleted) * c/src/exec/libfs/src/imfs/imfs_readlink.c (deleted) * c/src/exec/libfs/src/imfs/imfs_rmnod.c (deleted) * c/src/exec/libfs/src/imfs/imfs_stat.c (deleted) * c/src/exec/libfs/src/imfs/imfs_symlink.c (deleted) * c/src/exec/libfs/src/imfs/imfs_unixstub.c (deleted) * c/src/exec/libfs/src/imfs/imfs_unlink.c (deleted) * c/src/exec/libfs/src/imfs/imfs_unmount.c (deleted) * c/src/exec/libfs/src/imfs/imfs_utime.c (deleted) * c/src/exec/libfs/src/imfs/ioman.c (deleted) * c/src/exec/libfs/src/imfs/memfile.c (deleted) * c/src/exec/libfs/src/imfs/miniimfs_init.c (deleted) * c/src/exec/libnetworking/Makefile.am (deleted) * c/src/exec/libnetworking/README (deleted) * c/src/exec/libnetworking/arpa/Makefile.am (deleted) * c/src/exec/libnetworking/arpa/ftp.h (deleted) * c/src/exec/libnetworking/arpa/inet.h (deleted) * c/src/exec/libnetworking/arpa/nameser.h (deleted) * c/src/exec/libnetworking/arpa/nameser_compat.h (deleted) * c/src/exec/libnetworking/arpa/telnet.h (deleted) * c/src/exec/libnetworking/bpfilter.h (deleted) * c/src/exec/libnetworking/kern/Makefile.am (deleted) * c/src/exec/libnetworking/kern/kern_subr.c (deleted) * c/src/exec/libnetworking/kern/uipc_domain.c (deleted) * c/src/exec/libnetworking/kern/uipc_mbuf.c (deleted) * c/src/exec/libnetworking/kern/uipc_socket.c (deleted) * c/src/exec/libnetworking/kern/uipc_socket2.c (deleted) * c/src/exec/libnetworking/lib/Makefile.am (deleted) * c/src/exec/libnetworking/lib/README (deleted) * c/src/exec/libnetworking/lib/getprotoby.c (deleted) * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (deleted) * c/src/exec/libnetworking/lib/syslog.c (deleted) * c/src/exec/libnetworking/lib/tftpDriver.c (deleted) * c/src/exec/libnetworking/libc/Makefile.am (deleted) * c/src/exec/libnetworking/libc/addr2ascii.3 (deleted) * c/src/exec/libnetworking/libc/addr2ascii.c (deleted) * c/src/exec/libnetworking/libc/ascii2addr.c (deleted) * c/src/exec/libnetworking/libc/base64.c (deleted) * c/src/exec/libnetworking/libc/byteorder.3 (deleted) * c/src/exec/libnetworking/libc/ether_addr.c (deleted) * c/src/exec/libnetworking/libc/ethers.3 (deleted) * c/src/exec/libnetworking/libc/gethostbydns.c (deleted) * c/src/exec/libnetworking/libc/gethostbyht.c (deleted) * c/src/exec/libnetworking/libc/gethostbyname.3 (deleted) * c/src/exec/libnetworking/libc/gethostbynis.c (deleted) * c/src/exec/libnetworking/libc/gethostnamadr.c (deleted) * c/src/exec/libnetworking/libc/gethostname.c (deleted) * c/src/exec/libnetworking/libc/getnetbydns.c (deleted) * c/src/exec/libnetworking/libc/getnetbyht.c (deleted) * c/src/exec/libnetworking/libc/getnetbynis.c (deleted) * c/src/exec/libnetworking/libc/getnetent.3 (deleted) * c/src/exec/libnetworking/libc/getnetnamadr.c (deleted) * c/src/exec/libnetworking/libc/getproto.c (deleted) * c/src/exec/libnetworking/libc/getprotoent.3 (deleted) * c/src/exec/libnetworking/libc/getprotoent.c (deleted) * c/src/exec/libnetworking/libc/getprotoname.c (deleted) * c/src/exec/libnetworking/libc/getservbyname.c (deleted) * c/src/exec/libnetworking/libc/getservbyport.c (deleted) * c/src/exec/libnetworking/libc/getservent.3 (deleted) * c/src/exec/libnetworking/libc/getservent.c (deleted) * c/src/exec/libnetworking/libc/herror.c (deleted) * c/src/exec/libnetworking/libc/inet.3 (deleted) * c/src/exec/libnetworking/libc/inet_addr.c (deleted) * c/src/exec/libnetworking/libc/inet_lnaof.c (deleted) * c/src/exec/libnetworking/libc/inet_makeaddr.c (deleted) * c/src/exec/libnetworking/libc/inet_net_ntop.c (deleted) * c/src/exec/libnetworking/libc/inet_net_pton.c (deleted) * c/src/exec/libnetworking/libc/inet_neta.c (deleted) * c/src/exec/libnetworking/libc/inet_netof.c (deleted) * c/src/exec/libnetworking/libc/inet_network.c (deleted) * c/src/exec/libnetworking/libc/inet_ntoa.c (deleted) * c/src/exec/libnetworking/libc/inet_ntop.c (deleted) * c/src/exec/libnetworking/libc/inet_pton.c (deleted) * c/src/exec/libnetworking/libc/iso_addr.3 (deleted) * c/src/exec/libnetworking/libc/iso_addr.c (deleted) * c/src/exec/libnetworking/libc/linkaddr.3 (deleted) * c/src/exec/libnetworking/libc/linkaddr.c (deleted) * c/src/exec/libnetworking/libc/map_v4v6.c (deleted) * c/src/exec/libnetworking/libc/ns.3 (deleted) * c/src/exec/libnetworking/libc/ns_addr.c (deleted) * c/src/exec/libnetworking/libc/ns_name.c (deleted) * c/src/exec/libnetworking/libc/ns_netint.c (deleted) * c/src/exec/libnetworking/libc/ns_ntoa.c (deleted) * c/src/exec/libnetworking/libc/ns_parse.c (deleted) * c/src/exec/libnetworking/libc/ns_print.c (deleted) * c/src/exec/libnetworking/libc/ns_ttl.c (deleted) * c/src/exec/libnetworking/libc/nsap_addr.c (deleted) * c/src/exec/libnetworking/libc/rcmd.3 (deleted) * c/src/exec/libnetworking/libc/rcmd.c (deleted) * c/src/exec/libnetworking/libc/recv.c (deleted) * c/src/exec/libnetworking/libc/res_comp.c (deleted) * c/src/exec/libnetworking/libc/res_config.h (deleted) * c/src/exec/libnetworking/libc/res_data.c (deleted) * c/src/exec/libnetworking/libc/res_debug.c (deleted) * c/src/exec/libnetworking/libc/res_init.c (deleted) * c/src/exec/libnetworking/libc/res_mkquery.c (deleted) * c/src/exec/libnetworking/libc/res_mkupdate.c (deleted) * c/src/exec/libnetworking/libc/res_query.c (deleted) * c/src/exec/libnetworking/libc/res_send.c (deleted) * c/src/exec/libnetworking/libc/res_stubs.c (deleted) * c/src/exec/libnetworking/libc/res_update.c (deleted) * c/src/exec/libnetworking/libc/resolver.3 (deleted) * c/src/exec/libnetworking/libc/send.c (deleted) * c/src/exec/libnetworking/libc/strsep.c (deleted) * c/src/exec/libnetworking/loop.h (deleted) * c/src/exec/libnetworking/machine/Makefile.am (deleted) * c/src/exec/libnetworking/machine/conf.h (deleted) * c/src/exec/libnetworking/machine/cpu.h (deleted) * c/src/exec/libnetworking/machine/cpufunc.h (deleted) * c/src/exec/libnetworking/machine/endian.h (deleted) * c/src/exec/libnetworking/machine/in_cksum.h (deleted) * c/src/exec/libnetworking/machine/limits.h (deleted) * c/src/exec/libnetworking/machine/param.h (deleted) * c/src/exec/libnetworking/machine/types.h (deleted) * c/src/exec/libnetworking/machine/vmparam.h (deleted) * c/src/exec/libnetworking/net/Makefile.am (deleted) * c/src/exec/libnetworking/net/bpf.h (deleted) * c/src/exec/libnetworking/net/ethernet.h (deleted) * c/src/exec/libnetworking/net/if.c (deleted) * c/src/exec/libnetworking/net/if.h (deleted) * c/src/exec/libnetworking/net/if_arp.h (deleted) * c/src/exec/libnetworking/net/if_dl.h (deleted) * c/src/exec/libnetworking/net/if_ethersubr.c (deleted) * c/src/exec/libnetworking/net/if_llc.h (deleted) * c/src/exec/libnetworking/net/if_loop.c (deleted) * c/src/exec/libnetworking/net/if_ppp.h (deleted) * c/src/exec/libnetworking/net/if_types.h (deleted) * c/src/exec/libnetworking/net/netisr.h (deleted) * c/src/exec/libnetworking/net/ppp-comp.h (deleted) * c/src/exec/libnetworking/net/ppp_defs.h (deleted) * c/src/exec/libnetworking/net/radix.c (deleted) * c/src/exec/libnetworking/net/radix.h (deleted) * c/src/exec/libnetworking/net/raw_cb.c (deleted) * c/src/exec/libnetworking/net/raw_cb.h (deleted) * c/src/exec/libnetworking/net/raw_usrreq.c (deleted) * c/src/exec/libnetworking/net/route.c (deleted) * c/src/exec/libnetworking/net/route.h (deleted) * c/src/exec/libnetworking/net/rtsock.c (deleted) * c/src/exec/libnetworking/netdb.h (deleted) * c/src/exec/libnetworking/netinet/Makefile.am (deleted) * c/src/exec/libnetworking/netinet/icmp_var.h (deleted) * c/src/exec/libnetworking/netinet/if_ether.c (deleted) * c/src/exec/libnetworking/netinet/if_ether.h (deleted) * c/src/exec/libnetworking/netinet/igmp.c (deleted) * c/src/exec/libnetworking/netinet/igmp.h (deleted) * c/src/exec/libnetworking/netinet/igmp_var.h (deleted) * c/src/exec/libnetworking/netinet/in.c (deleted) * c/src/exec/libnetworking/netinet/in.h (deleted) * c/src/exec/libnetworking/netinet/in_cksum.c (deleted) * c/src/exec/libnetworking/netinet/in_cksum_i386.c (deleted) * c/src/exec/libnetworking/netinet/in_cksum_m68k.c (deleted) * c/src/exec/libnetworking/netinet/in_cksum_powerpc.c (deleted) * c/src/exec/libnetworking/netinet/in_pcb.c (deleted) * c/src/exec/libnetworking/netinet/in_pcb.h (deleted) * c/src/exec/libnetworking/netinet/in_proto.c (deleted) * c/src/exec/libnetworking/netinet/in_rmx.c (deleted) * c/src/exec/libnetworking/netinet/in_systm.h (deleted) * c/src/exec/libnetworking/netinet/in_var.h (deleted) * c/src/exec/libnetworking/netinet/ip.h (deleted) * c/src/exec/libnetworking/netinet/ip_divert.c (deleted) * c/src/exec/libnetworking/netinet/ip_fw.c (deleted) * c/src/exec/libnetworking/netinet/ip_fw.h (deleted) * c/src/exec/libnetworking/netinet/ip_icmp.c (deleted) * c/src/exec/libnetworking/netinet/ip_icmp.h (deleted) * c/src/exec/libnetworking/netinet/ip_input.c (deleted) * c/src/exec/libnetworking/netinet/ip_mroute.c (deleted) * c/src/exec/libnetworking/netinet/ip_mroute.h (deleted) * c/src/exec/libnetworking/netinet/ip_output.c (deleted) * c/src/exec/libnetworking/netinet/ip_var.h (deleted) * c/src/exec/libnetworking/netinet/raw_ip.c (deleted) * c/src/exec/libnetworking/netinet/tcp.h (deleted) * c/src/exec/libnetworking/netinet/tcp_debug.c (deleted) * c/src/exec/libnetworking/netinet/tcp_debug.h (deleted) * c/src/exec/libnetworking/netinet/tcp_fsm.h (deleted) * c/src/exec/libnetworking/netinet/tcp_input.c (deleted) * c/src/exec/libnetworking/netinet/tcp_output.c (deleted) * c/src/exec/libnetworking/netinet/tcp_seq.h (deleted) * c/src/exec/libnetworking/netinet/tcp_subr.c (deleted) * c/src/exec/libnetworking/netinet/tcp_timer.c (deleted) * c/src/exec/libnetworking/netinet/tcp_timer.h (deleted) * c/src/exec/libnetworking/netinet/tcp_usrreq.c (deleted) * c/src/exec/libnetworking/netinet/tcp_var.h (deleted) * c/src/exec/libnetworking/netinet/tcpip.h (deleted) * c/src/exec/libnetworking/netinet/udp.h (deleted) * c/src/exec/libnetworking/netinet/udp_usrreq.c (deleted) * c/src/exec/libnetworking/netinet/udp_var.h (deleted) * c/src/exec/libnetworking/nfs/Makefile.am (deleted) * c/src/exec/libnetworking/nfs/bootp_subr.c (deleted) * c/src/exec/libnetworking/nfs/krpc.h (deleted) * c/src/exec/libnetworking/nfs/nfs.h (deleted) * c/src/exec/libnetworking/nfs/nfsdiskless.h (deleted) * c/src/exec/libnetworking/nfs/nfsproto.h (deleted) * c/src/exec/libnetworking/nfs/rpcv2.h (deleted) * c/src/exec/libnetworking/nfs/xdr_subs.h (deleted) * c/src/exec/libnetworking/opt_ipfw.h (deleted) * c/src/exec/libnetworking/opt_mrouting.h (deleted) * c/src/exec/libnetworking/opt_tcpdebug.h (deleted) * c/src/exec/libnetworking/poll.h (deleted) * c/src/exec/libnetworking/resolv.h (deleted) * c/src/exec/libnetworking/rtems/Makefile.am (deleted) * c/src/exec/libnetworking/rtems/issetugid.c (deleted) * c/src/exec/libnetworking/rtems/rtems_bootp.c (deleted) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (deleted) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (deleted) * c/src/exec/libnetworking/rtems/rtems_glue.c (deleted) * c/src/exec/libnetworking/rtems/rtems_select.c (deleted) * c/src/exec/libnetworking/rtems/rtems_showicmpstat.c (deleted) * c/src/exec/libnetworking/rtems/rtems_showifstat.c (deleted) * c/src/exec/libnetworking/rtems/rtems_showipstat.c (deleted) * c/src/exec/libnetworking/rtems/rtems_showmbuf.c (deleted) * c/src/exec/libnetworking/rtems/rtems_showroute.c (deleted) * c/src/exec/libnetworking/rtems/rtems_showtcpstat.c (deleted) * c/src/exec/libnetworking/rtems/rtems_showudpstat.c (deleted) * c/src/exec/libnetworking/rtems/rtems_syscall.c (deleted) * c/src/exec/libnetworking/rtems/sghostname.c (deleted) * c/src/exec/libnetworking/rtems/tftp.h (deleted) * c/src/exec/libnetworking/sys/Makefile.am (deleted) * c/src/exec/libnetworking/sys/buf.h (deleted) * c/src/exec/libnetworking/sys/callout.h (deleted) * c/src/exec/libnetworking/sys/conf.h (deleted) * c/src/exec/libnetworking/sys/domain.h (deleted) * c/src/exec/libnetworking/sys/kernel.h (deleted) * c/src/exec/libnetworking/sys/libkern.h (deleted) * c/src/exec/libnetworking/sys/malloc.h (deleted) * c/src/exec/libnetworking/sys/mbuf.h (deleted) * c/src/exec/libnetworking/sys/mount.h (deleted) * c/src/exec/libnetworking/sys/param.h (deleted) * c/src/exec/libnetworking/sys/proc.h (deleted) * c/src/exec/libnetworking/sys/protosw.h (deleted) * c/src/exec/libnetworking/sys/queue.h (deleted) * c/src/exec/libnetworking/sys/reboot.h (deleted) * c/src/exec/libnetworking/sys/resourcevar.h (deleted) * c/src/exec/libnetworking/sys/rtprio.h (deleted) * c/src/exec/libnetworking/sys/select.h (deleted) * c/src/exec/libnetworking/sys/signalvar.h (deleted) * c/src/exec/libnetworking/sys/socket.h (deleted) * c/src/exec/libnetworking/sys/socketvar.h (deleted) * c/src/exec/libnetworking/sys/sysctl.h (deleted) * c/src/exec/libnetworking/sys/syslimits.h (deleted) * c/src/exec/libnetworking/sys/syslog.h (deleted) * c/src/exec/libnetworking/sys/systm.h (deleted) * c/src/exec/libnetworking/sys/ttydefaults.h (deleted) * c/src/exec/libnetworking/sys/ucred.h (deleted) * c/src/exec/libnetworking/sys/uio.h (deleted) * c/src/exec/libnetworking/syslog.h (deleted) * c/src/exec/libnetworking/vm/Makefile.am (deleted) * c/src/exec/libnetworking/vm/vm.h (deleted) * c/src/exec/libnetworking/vm/vm_extern.h (deleted) * c/src/exec/libnetworking/vm/vm_kern.h (deleted) * c/src/exec/libnetworking/vm/vm_param.h (deleted) * c/src/exec/libnetworking/wrapup/Makefile.am (deleted) * c/src/exec/librpc/Makefile.am (deleted) * c/src/exec/librpc/include/Makefile.am (deleted) * c/src/exec/librpc/include/rpc/Makefile.am (deleted) * c/src/exec/librpc/include/rpc/auth.h (deleted) * c/src/exec/librpc/include/rpc/clnt.h (deleted) * c/src/exec/librpc/include/rpc/rpc.h (deleted) * c/src/exec/librpc/include/rpc/rpc_msg.h (deleted) * c/src/exec/librpc/include/rpc/svc.h (deleted) * c/src/exec/librpc/include/rpc/svc_auth.h (deleted) * c/src/exec/librpc/include/rpc/types.h (deleted) * c/src/exec/librpc/include/rpc/xdr.h (deleted) * c/src/exec/librpc/src/Makefile.am (deleted) * c/src/exec/score/cpu/a29k/rtems/score/types.h (deleted) * c/src/exec/score/cpu/hppa1.1/rtems/score/types.h (deleted) * c/src/exec/score/cpu/i386/rtems/score/types.h (deleted) * c/src/exec/score/cpu/i960/rtems/score/types.h (deleted) * c/src/exec/score/cpu/m68k/rtems/score/types.h (deleted) * c/src/exec/score/cpu/mips/Makefile.am (deleted) * c/src/exec/score/cpu/mips/asm.h (deleted) * c/src/exec/score/cpu/mips/configure.in (deleted) * c/src/exec/score/cpu/mips/cpu.c (deleted) * c/src/exec/score/cpu/mips/cpu_asm.S (deleted) * c/src/exec/score/cpu/mips/cpu_asm.h (deleted) * c/src/exec/score/cpu/mips/idtcpu.h (deleted) * c/src/exec/score/cpu/mips/idtmon.h (deleted) * c/src/exec/score/cpu/mips/iregdef.h (deleted) * c/src/exec/score/cpu/mips/rtems.c (deleted) * c/src/exec/score/cpu/mips/rtems/Makefile.am (deleted) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (deleted) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (deleted) * c/src/exec/score/cpu/mips/rtems/score/mips.h (deleted) * c/src/exec/score/cpu/mips/rtems/score/mips64orion.h (deleted) * c/src/exec/score/cpu/mips/rtems/score/mipstypes.h (deleted) * c/src/exec/score/cpu/mips/rtems/score/types.h (deleted) * c/src/exec/score/cpu/mips64orion/rtems/score/types.h (deleted) * c/src/exec/score/cpu/no_cpu/rtems/score/types.h (deleted) * c/src/exec/score/cpu/powerpc/asm.h (deleted) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (deleted) * c/src/exec/score/cpu/powerpc/rtems/score/ppctypes.h (deleted) * c/src/exec/score/cpu/powerpc/rtems/score/types.h (deleted) * c/src/exec/score/cpu/sh/rtems/score/types.h (deleted) * c/src/exec/score/cpu/sparc/rtems/score/types.h (deleted) * c/src/exec/score/cpu/unix/rtems/score/types.h (deleted) * c/src/lib/include/rtems/assoc.h (deleted) * c/src/lib/include/rtems/error.h (deleted) * c/src/lib/include/rtems/libcsupport.h (deleted) * c/src/lib/include/rtems/libio.h (deleted) * c/src/lib/include/rtems/libio_.h (deleted) * c/src/lib/include/sys/filio.h (deleted) * c/src/lib/include/sys/ioctl.h (deleted) * c/src/lib/include/sys/sockio.h (deleted) * c/src/lib/include/sys/utsname.h (deleted) * c/src/lib/libbsp/i386/shared/irq/idt.c (deleted) * c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c (deleted) * c/src/lib/libbsp/mips/Makefile.am (deleted) * c/src/lib/libbsp/mips/README (deleted) * c/src/lib/libbsp/mips/configure.in (deleted) * c/src/lib/libbsp/mips/p4000/Makefile.am (deleted) * c/src/lib/libbsp/mips/p4000/README (deleted) * c/src/lib/libbsp/mips/p4000/bsp_specs (deleted) * c/src/lib/libbsp/mips/p4000/configure.in (deleted) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (deleted) * c/src/lib/libbsp/mips/p4000/console/console.c (deleted) * c/src/lib/libbsp/mips/p4000/console/led.S (deleted) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (deleted) * c/src/lib/libbsp/mips/p4000/include/bsp.h (deleted) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (deleted) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (deleted) * c/src/lib/libbsp/mips/p4000/liblnk/lnklib.S (deleted) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (deleted) * c/src/lib/libbsp/mips/p4000/start/start.S (deleted) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (deleted) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (deleted) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (deleted) * c/src/lib/libbsp/mips/p4000/startup/ghlinkcmds (deleted) * c/src/lib/libbsp/mips/p4000/startup/idtmem.S (deleted) * c/src/lib/libbsp/mips/p4000/startup/idttlb.S (deleted) * c/src/lib/libbsp/mips/p4000/startup/inittlb.c (deleted) * c/src/lib/libbsp/mips/p4000/startup/linkcmds (deleted) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (deleted) * c/src/lib/libbsp/mips/p4000/times (deleted) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (deleted) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (deleted) * c/src/lib/libbsp/powerpc/support/new_exception_processing/c_isr.inl (deleted) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.c (deleted) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.h (deleted) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu_asm.S (deleted) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (deleted) * c/src/lib/libbsp/powerpc/support/old_exception_processing/README (deleted) * c/src/lib/libbsp/powerpc/support/old_exception_processing/TODO (deleted) * c/src/lib/libbsp/powerpc/support/old_exception_processing/c_isr.inl (deleted) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.c (deleted) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.h (deleted) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu_asm.S (deleted) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (deleted) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ppccache.c (deleted) * c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems.S (deleted) * c/src/lib/libc/utsname.c (deleted) * c/src/lib/libcpu/i386/idt.c (deleted) * c/src/lib/libcpu/m68k/shared/misc/memcpy.c (deleted) * c/src/lib/libcpu/mips/Makefile.am (deleted) * c/src/lib/libcpu/mips/clock/Makefile.am (deleted) * c/src/lib/libcpu/mips/clock/ckinit.c (deleted) * c/src/lib/libcpu/mips/clock/clock.S (deleted) * c/src/lib/libcpu/mips/clock/clock.h (deleted) * c/src/lib/libcpu/mips/configure.in (deleted) * c/src/lib/libcpu/mips/timer/Makefile.am (deleted) * c/src/lib/libcpu/mips/timer/gettime.S (deleted) * c/src/lib/libcpu/mips/timer/timer.c (deleted) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (deleted) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (deleted) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (deleted) * c/src/lib/libcpu/powerpc/new_exception_processing/c_isr.inl (deleted) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu.c (deleted) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu.h (deleted) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu_asm.S (deleted) * c/src/lib/libcpu/powerpc/old-exceptions/README (deleted) * c/src/lib/libcpu/powerpc/old-exceptions/TODO (deleted) * c/src/lib/libcpu/powerpc/old-exceptions/cpu.c (deleted) * c/src/lib/libcpu/powerpc/old-exceptions/cpu_asm.S (deleted) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (deleted) * c/src/lib/libcpu/powerpc/old-exceptions/ppccache.c (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/README (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/TODO (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/c_isr.inl (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.c (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.h (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu_asm.S (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/rtems.S (deleted) * c/src/lib/libcpu/sh/sh7032/include/iosh7032.h (deleted) * c/src/lib/libcpu/sh/sh7032/include/ispsh7032.h (deleted) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (deleted) * c/src/lib/libcpu/sh/sh7032/score/ispsh7032.c (deleted) * c/src/lib/libcpu/sh/sh7045/include/io_types.h (deleted) * c/src/lib/libcpu/sh/sh7045/include/iosh7045.h (deleted) * c/src/lib/libcpu/sh/sh7045/include/ispsh7045.h (deleted) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (deleted) * c/src/lib/libcpu/sh/sh7045/score/ispsh7045.c (deleted) * c/src/lib/libcpu/sparc/include/erc32.h (deleted) * c/src/libchip/shmdr/README (deleted) * c/src/libchip/shmdr/addlq.c (deleted) * c/src/libchip/shmdr/cnvpkt.c (deleted) * c/src/libchip/shmdr/dump.c (deleted) * c/src/libchip/shmdr/fatal.c (deleted) * c/src/libchip/shmdr/getlq.c (deleted) * c/src/libchip/shmdr/getpkt.c (deleted) * c/src/libchip/shmdr/init.c (deleted) * c/src/libchip/shmdr/initlq.c (deleted) * c/src/libchip/shmdr/intr.c (deleted) * c/src/libchip/shmdr/mpci.h (deleted) * c/src/libchip/shmdr/mpisr.c (deleted) * c/src/libchip/shmdr/poll.c (deleted) * c/src/libchip/shmdr/receive.c (deleted) * c/src/libchip/shmdr/retpkt.c (deleted) * c/src/libchip/shmdr/send.c (deleted) * c/src/libchip/shmdr/setckvec.c (deleted) * c/src/libchip/shmdr/shm_driver.h (deleted) * c/src/libfs/src/imfs/deviceio.c (deleted) * c/src/libfs/src/imfs/imfs.h (deleted) * c/src/libfs/src/imfs/imfs_chown.c (deleted) * c/src/libfs/src/imfs/imfs_creat.c (deleted) * c/src/libfs/src/imfs/imfs_debug.c (deleted) * c/src/libfs/src/imfs/imfs_directory.c (deleted) * c/src/libfs/src/imfs/imfs_eval.c (deleted) * c/src/libfs/src/imfs/imfs_fchmod.c (deleted) * c/src/libfs/src/imfs/imfs_fcntl.c (deleted) * c/src/libfs/src/imfs/imfs_fdatasync.c (deleted) * c/src/libfs/src/imfs/imfs_free.c (deleted) * c/src/libfs/src/imfs/imfs_fsunmount.c (deleted) * c/src/libfs/src/imfs/imfs_getchild.c (deleted) * c/src/libfs/src/imfs/imfs_gtkn.c (deleted) * c/src/libfs/src/imfs/imfs_handlers_device.c (deleted) * c/src/libfs/src/imfs/imfs_handlers_directory.c (deleted) * c/src/libfs/src/imfs/imfs_handlers_link.c (deleted) * c/src/libfs/src/imfs/imfs_handlers_memfile.c (deleted) * c/src/libfs/src/imfs/imfs_init.c (deleted) * c/src/libfs/src/imfs/imfs_initsupp.c (deleted) * c/src/libfs/src/imfs/imfs_link.c (deleted) * c/src/libfs/src/imfs/imfs_mknod.c (deleted) * c/src/libfs/src/imfs/imfs_mount.c (deleted) * c/src/libfs/src/imfs/imfs_ntype.c (deleted) * c/src/libfs/src/imfs/imfs_readlink.c (deleted) * c/src/libfs/src/imfs/imfs_rmnod.c (deleted) * c/src/libfs/src/imfs/imfs_stat.c (deleted) * c/src/libfs/src/imfs/imfs_symlink.c (deleted) * c/src/libfs/src/imfs/imfs_unixstub.c (deleted) * c/src/libfs/src/imfs/imfs_unlink.c (deleted) * c/src/libfs/src/imfs/imfs_unmount.c (deleted) * c/src/libfs/src/imfs/imfs_utime.c (deleted) * c/src/libfs/src/imfs/ioman.c (deleted) * c/src/libfs/src/imfs/memfile.c (deleted) * c/src/libfs/src/imfs/miniimfs_init.c (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb.h (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_f.x (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_svc.c (deleted) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c (deleted) * c/src/make/README (deleted) * c/src/make/compilers/gcc-target-default.cfg (deleted) * c/src/make/directory.cfg (deleted) * c/src/make/host.cfg.in (deleted) * c/src/make/lib.cfg (deleted) * c/src/optman/rtems/Makefile.am (deleted) * c/src/optman/rtems/no-dpmem.c (deleted) * c/src/optman/rtems/no-event.c (deleted) * c/src/optman/rtems/no-mp.c (deleted) * c/src/optman/rtems/no-msg.c (deleted) * c/src/optman/rtems/no-part.c (deleted) * c/src/optman/rtems/no-region.c (deleted) * c/src/optman/rtems/no-rtmon.c (deleted) * c/src/optman/rtems/no-sem.c (deleted) * c/src/optman/rtems/no-signal.c (deleted) * c/src/optman/rtems/no-timer.c (deleted) * c/src/optman/sapi/Makefile.am (deleted) * c/src/optman/sapi/no-ext.c (deleted) * c/src/optman/sapi/no-io.c (deleted) * cpukit/Makefile.am (deleted) * cpukit/ada/rtems.adb (deleted) * cpukit/ada/rtems.ads (deleted) * cpukit/ftpd/Makefile.am (deleted) * cpukit/ftpd/ftpd.c (deleted) * cpukit/ftpd/ftpd.h (deleted) * cpukit/httpd/Makefile.am (deleted) * cpukit/httpd/asp.c (deleted) * cpukit/httpd/balloc.c (deleted) * cpukit/httpd/default.c (deleted) * cpukit/httpd/ej.h (deleted) * cpukit/httpd/ejlex.c (deleted) * cpukit/httpd/ejparse.c (deleted) * cpukit/httpd/form.c (deleted) * cpukit/httpd/h.c (deleted) * cpukit/httpd/handler.c (deleted) * cpukit/httpd/mime.c (deleted) * cpukit/httpd/misc.c (deleted) * cpukit/httpd/ringq.c (deleted) * cpukit/httpd/rom.c (deleted) * cpukit/httpd/rtems_webserver.h (deleted) * cpukit/httpd/security.c (deleted) * cpukit/httpd/socket.c (deleted) * cpukit/httpd/sym.c (deleted) * cpukit/httpd/uemf.c (deleted) * cpukit/httpd/uemf.h (deleted) * cpukit/httpd/url.c (deleted) * cpukit/httpd/value.c (deleted) * cpukit/httpd/wbase64.c (deleted) * cpukit/httpd/webcomp.c (deleted) * cpukit/httpd/webmain.c (deleted) * cpukit/httpd/webpage.c (deleted) * cpukit/httpd/webrom.c (deleted) * cpukit/httpd/webs.c (deleted) * cpukit/httpd/webs.h (deleted) * cpukit/httpd/websuemf.c (deleted) * cpukit/httpd/wsIntrn.h (deleted) * cpukit/include/rtems/libio_.h (deleted) * cpukit/itron/Makefile.am (deleted) * cpukit/itron/include/Makefile.am (deleted) * cpukit/itron/include/itron.h (deleted) * cpukit/itron/include/itronsys/README (deleted) * cpukit/itron/include/itronsys/eventflags.h (deleted) * cpukit/itron/include/itronsys/fmempool.h (deleted) * cpukit/itron/include/itronsys/intr.h (deleted) * cpukit/itron/include/itronsys/mbox.h (deleted) * cpukit/itron/include/itronsys/msgbuffer.h (deleted) * cpukit/itron/include/itronsys/network.h (deleted) * cpukit/itron/include/itronsys/port.h (deleted) * cpukit/itron/include/itronsys/semaphore.h (deleted) * cpukit/itron/include/itronsys/status.h (deleted) * cpukit/itron/include/itronsys/sysmgmt.h (deleted) * cpukit/itron/include/itronsys/task.h (deleted) * cpukit/itron/include/itronsys/time.h (deleted) * cpukit/itron/include/itronsys/types.h (deleted) * cpukit/itron/include/itronsys/vmempool.h (deleted) * cpukit/itron/include/rtems/itron/README (deleted) * cpukit/itron/include/rtems/itron/config.h (deleted) * cpukit/itron/include/rtems/itron/eventflags.h (deleted) * cpukit/itron/include/rtems/itron/fmempool.h (deleted) * cpukit/itron/include/rtems/itron/intr.h (deleted) * cpukit/itron/include/rtems/itron/itronapi.h (deleted) * cpukit/itron/include/rtems/itron/mbox.h (deleted) * cpukit/itron/include/rtems/itron/msgbuffer.h (deleted) * cpukit/itron/include/rtems/itron/network.h (deleted) * cpukit/itron/include/rtems/itron/object.h (deleted) * cpukit/itron/include/rtems/itron/port.h (deleted) * cpukit/itron/include/rtems/itron/semaphore.h (deleted) * cpukit/itron/include/rtems/itron/sysmgmt.h (deleted) * cpukit/itron/include/rtems/itron/task.h (deleted) * cpukit/itron/include/rtems/itron/time.h (deleted) * cpukit/itron/include/rtems/itron/vmempool.h (deleted) * cpukit/itron/inline/Makefile.am (deleted) * cpukit/itron/inline/rtems/itron/eventflags.inl (deleted) * cpukit/itron/inline/rtems/itron/fmempool.inl (deleted) * cpukit/itron/inline/rtems/itron/intr.inl (deleted) * cpukit/itron/inline/rtems/itron/mbox.inl (deleted) * cpukit/itron/inline/rtems/itron/msgbuffer.inl (deleted) * cpukit/itron/inline/rtems/itron/network.inl (deleted) * cpukit/itron/inline/rtems/itron/port.inl (deleted) * cpukit/itron/inline/rtems/itron/semaphore.inl (deleted) * cpukit/itron/inline/rtems/itron/sysmgmt.inl (deleted) * cpukit/itron/inline/rtems/itron/task.inl (deleted) * cpukit/itron/inline/rtems/itron/time.inl (deleted) * cpukit/itron/inline/rtems/itron/vmempool.inl (deleted) * cpukit/itron/src/Makefile.am (deleted) * cpukit/itron/src/TODO (deleted) * cpukit/itron/src/can_wup.c (deleted) * cpukit/itron/src/chg_pri.c (deleted) * cpukit/itron/src/cre_mbf.c (deleted) * cpukit/itron/src/cre_mbx.c (deleted) * cpukit/itron/src/cre_sem.c (deleted) * cpukit/itron/src/cre_tsk.c (deleted) * cpukit/itron/src/del_mbf.c (deleted) * cpukit/itron/src/del_mbx.c (deleted) * cpukit/itron/src/del_sem.c (deleted) * cpukit/itron/src/del_tsk.c (deleted) * cpukit/itron/src/dis_dsp.c (deleted) * cpukit/itron/src/ena_dsp.c (deleted) * cpukit/itron/src/eventflags.c (deleted) * cpukit/itron/src/exd_tsk.c (deleted) * cpukit/itron/src/ext_tsk.c (deleted) * cpukit/itron/src/fmempool.c (deleted) * cpukit/itron/src/frsm_tsk.c (deleted) * cpukit/itron/src/get_tid.c (deleted) * cpukit/itron/src/itronintr.c (deleted) * cpukit/itron/src/itronsem.c (deleted) * cpukit/itron/src/itrontime.c (deleted) * cpukit/itron/src/mbox.c (deleted) * cpukit/itron/src/mboxtranslatereturncode.c (deleted) * cpukit/itron/src/msgbuffer.c (deleted) * cpukit/itron/src/msgbuffertranslatereturncode.c (deleted) * cpukit/itron/src/network.c (deleted) * cpukit/itron/src/port.c (deleted) * cpukit/itron/src/prcv_mbf.c (deleted) * cpukit/itron/src/prcv_mbx.c (deleted) * cpukit/itron/src/preq_sem.c (deleted) * cpukit/itron/src/psnd_mbf.c (deleted) * cpukit/itron/src/rcv_mbf.c (deleted) * cpukit/itron/src/rcv_mbx.c (deleted) * cpukit/itron/src/ref_mbf.c (deleted) * cpukit/itron/src/ref_mbx.c (deleted) * cpukit/itron/src/ref_sem.c (deleted) * cpukit/itron/src/ref_tsk.c (deleted) * cpukit/itron/src/rel_wai.c (deleted) * cpukit/itron/src/rot_rdq.c (deleted) * cpukit/itron/src/rsm_tsk.c (deleted) * cpukit/itron/src/sig_sem.c (deleted) * cpukit/itron/src/slp_tsk.c (deleted) * cpukit/itron/src/snd_mbf.c (deleted) * cpukit/itron/src/snd_mbx.c (deleted) * cpukit/itron/src/sta_tsk.c (deleted) * cpukit/itron/src/sus_tsk.c (deleted) * cpukit/itron/src/sysmgmt.c (deleted) * cpukit/itron/src/task.c (deleted) * cpukit/itron/src/ter_tsk.c (deleted) * cpukit/itron/src/trcv_mbf.c (deleted) * cpukit/itron/src/trcv_mbx.c (deleted) * cpukit/itron/src/tslp_tsk.c (deleted) * cpukit/itron/src/tsnd_mbf.c (deleted) * cpukit/itron/src/twai_sem.c (deleted) * cpukit/itron/src/vmempool.c (deleted) * cpukit/itron/src/wai_sem.c (deleted) * cpukit/itron/src/wup_tsk.c (deleted) * cpukit/libcsupport/Makefile.am (deleted) * cpukit/libcsupport/include/chain.h (deleted) * cpukit/libcsupport/include/clockdrv.h (deleted) * cpukit/libcsupport/include/console.h (deleted) * cpukit/libcsupport/include/iosupp.h (deleted) * cpukit/libcsupport/include/motorola/mc68230.h (deleted) * cpukit/libcsupport/include/motorola/mc68681.h (deleted) * cpukit/libcsupport/include/ringbuf.h (deleted) * cpukit/libcsupport/include/rtems/assoc.h (deleted) * cpukit/libcsupport/include/rtems/error.h (deleted) * cpukit/libcsupport/include/rtems/libcsupport.h (deleted) * cpukit/libcsupport/include/rtems/libio.h (deleted) * cpukit/libcsupport/include/rtems/libio_.h (deleted) * cpukit/libcsupport/include/spurious.h (deleted) * cpukit/libcsupport/include/sys/filio.h (deleted) * cpukit/libcsupport/include/sys/ioctl.h (deleted) * cpukit/libcsupport/include/sys/sockio.h (deleted) * cpukit/libcsupport/include/sys/termios.h (deleted) * cpukit/libcsupport/include/sys/utime.h (deleted) * cpukit/libcsupport/include/sys/utsname.h (deleted) * cpukit/libcsupport/include/timerdrv.h (deleted) * cpukit/libcsupport/include/vmeintr.h (deleted) * cpukit/libcsupport/include/zilog/z8036.h (deleted) * cpukit/libcsupport/include/zilog/z8530.h (deleted) * cpukit/libcsupport/include/zilog/z8536.h (deleted) * cpukit/libcsupport/src/CASES (deleted) * cpukit/libcsupport/src/README (deleted) * cpukit/libcsupport/src/TODO (deleted) * cpukit/libcsupport/src/__brk.c (deleted) * cpukit/libcsupport/src/__getpid.c (deleted) * cpukit/libcsupport/src/__gettod.c (deleted) * cpukit/libcsupport/src/__sbrk.c (deleted) * cpukit/libcsupport/src/__times.c (deleted) * cpukit/libcsupport/src/access.c (deleted) * cpukit/libcsupport/src/assoc.c (deleted) * cpukit/libcsupport/src/assocnamebad.c (deleted) * cpukit/libcsupport/src/base_fs.c (deleted) * cpukit/libcsupport/src/cfgetispeed.c (deleted) * cpukit/libcsupport/src/cfgetospeed.c (deleted) * cpukit/libcsupport/src/cfsetispeed.c (deleted) * cpukit/libcsupport/src/cfsetospeed.c (deleted) * cpukit/libcsupport/src/chdir.c (deleted) * cpukit/libcsupport/src/chmod.c (deleted) * cpukit/libcsupport/src/chown.c (deleted) * cpukit/libcsupport/src/close.c (deleted) * cpukit/libcsupport/src/closedir.c (deleted) * cpukit/libcsupport/src/creat.c (deleted) * cpukit/libcsupport/src/ctermid.c (deleted) * cpukit/libcsupport/src/dup.c (deleted) * cpukit/libcsupport/src/dup2.c (deleted) * cpukit/libcsupport/src/error.c (deleted) * cpukit/libcsupport/src/eval.c (deleted) * cpukit/libcsupport/src/fchmod.c (deleted) * cpukit/libcsupport/src/fcntl.c (deleted) * cpukit/libcsupport/src/fdatasync.c (deleted) * cpukit/libcsupport/src/fpathconf.c (deleted) * cpukit/libcsupport/src/fs_null_handlers.c (deleted) * cpukit/libcsupport/src/fstat.c (deleted) * cpukit/libcsupport/src/fsync.c (deleted) * cpukit/libcsupport/src/ftruncate.c (deleted) * cpukit/libcsupport/src/getcwd.c (deleted) * cpukit/libcsupport/src/getdents.c (deleted) * cpukit/libcsupport/src/getgrent.c (deleted) * cpukit/libcsupport/src/getpwent.c (deleted) * cpukit/libcsupport/src/hosterr.c (deleted) * cpukit/libcsupport/src/ioctl.c (deleted) * cpukit/libcsupport/src/isatty.c (deleted) * cpukit/libcsupport/src/libio.c (deleted) * cpukit/libcsupport/src/libio_sockets.c (deleted) * cpukit/libcsupport/src/link.c (deleted) * cpukit/libcsupport/src/lseek.c (deleted) * cpukit/libcsupport/src/lstat.c (deleted) * cpukit/libcsupport/src/malloc.c (deleted) * cpukit/libcsupport/src/mkdir.c (deleted) * cpukit/libcsupport/src/mkfifo.c (deleted) * cpukit/libcsupport/src/mknod.c (deleted) * cpukit/libcsupport/src/mount.c (deleted) * cpukit/libcsupport/src/newlibc.c (deleted) * cpukit/libcsupport/src/no_libc.c (deleted) * cpukit/libcsupport/src/no_posix.c (deleted) * cpukit/libcsupport/src/open.c (deleted) * cpukit/libcsupport/src/opendir.c (deleted) * cpukit/libcsupport/src/pathconf.c (deleted) * cpukit/libcsupport/src/pipe.c (deleted) * cpukit/libcsupport/src/read.c (deleted) * cpukit/libcsupport/src/readdir.c (deleted) * cpukit/libcsupport/src/readlink.c (deleted) * cpukit/libcsupport/src/rewinddir.c (deleted) * cpukit/libcsupport/src/rmdir.c (deleted) * cpukit/libcsupport/src/scandir.c (deleted) * cpukit/libcsupport/src/seekdir.c (deleted) * cpukit/libcsupport/src/stat.c (deleted) * cpukit/libcsupport/src/symlink.c (deleted) * cpukit/libcsupport/src/tcdrain.c (deleted) * cpukit/libcsupport/src/tcflow.c (deleted) * cpukit/libcsupport/src/tcflush.c (deleted) * cpukit/libcsupport/src/tcgetattr.c (deleted) * cpukit/libcsupport/src/tcgetprgrp.c (deleted) * cpukit/libcsupport/src/tcsendbreak.c (deleted) * cpukit/libcsupport/src/tcsetattr.c (deleted) * cpukit/libcsupport/src/tcsetpgrp.c (deleted) * cpukit/libcsupport/src/telldir.c (deleted) * cpukit/libcsupport/src/termios.c (deleted) * cpukit/libcsupport/src/termiosinitialize.c (deleted) * cpukit/libcsupport/src/termiosreserveresources.c (deleted) * cpukit/libcsupport/src/truncate.c (deleted) * cpukit/libcsupport/src/ttyname.c (deleted) * cpukit/libcsupport/src/ttyname_r.c (deleted) * cpukit/libcsupport/src/umask.c (deleted) * cpukit/libcsupport/src/unixlibc.c (deleted) * cpukit/libcsupport/src/unlink.c (deleted) * cpukit/libcsupport/src/unmount.c (deleted) * cpukit/libcsupport/src/utime.c (deleted) * cpukit/libcsupport/src/utsname.c (deleted) * cpukit/libcsupport/src/write.c (deleted) * cpukit/libfs/src/imfs/deviceio.c (deleted) * cpukit/libfs/src/imfs/imfs.h (deleted) * cpukit/libfs/src/imfs/imfs_chown.c (deleted) * cpukit/libfs/src/imfs/imfs_creat.c (deleted) * cpukit/libfs/src/imfs/imfs_debug.c (deleted) * cpukit/libfs/src/imfs/imfs_directory.c (deleted) * cpukit/libfs/src/imfs/imfs_eval.c (deleted) * cpukit/libfs/src/imfs/imfs_fchmod.c (deleted) * cpukit/libfs/src/imfs/imfs_fcntl.c (deleted) * cpukit/libfs/src/imfs/imfs_fdatasync.c (deleted) * cpukit/libfs/src/imfs/imfs_free.c (deleted) * cpukit/libfs/src/imfs/imfs_fsunmount.c (deleted) * cpukit/libfs/src/imfs/imfs_getchild.c (deleted) * cpukit/libfs/src/imfs/imfs_gtkn.c (deleted) * cpukit/libfs/src/imfs/imfs_handlers_device.c (deleted) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (deleted) * cpukit/libfs/src/imfs/imfs_handlers_link.c (deleted) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (deleted) * cpukit/libfs/src/imfs/imfs_init.c (deleted) * cpukit/libfs/src/imfs/imfs_initsupp.c (deleted) * cpukit/libfs/src/imfs/imfs_link.c (deleted) * cpukit/libfs/src/imfs/imfs_mknod.c (deleted) * cpukit/libfs/src/imfs/imfs_mount.c (deleted) * cpukit/libfs/src/imfs/imfs_ntype.c (deleted) * cpukit/libfs/src/imfs/imfs_readlink.c (deleted) * cpukit/libfs/src/imfs/imfs_rmnod.c (deleted) * cpukit/libfs/src/imfs/imfs_stat.c (deleted) * cpukit/libfs/src/imfs/imfs_symlink.c (deleted) * cpukit/libfs/src/imfs/imfs_unixstub.c (deleted) * cpukit/libfs/src/imfs/imfs_unlink.c (deleted) * cpukit/libfs/src/imfs/imfs_unmount.c (deleted) * cpukit/libfs/src/imfs/imfs_utime.c (deleted) * cpukit/libfs/src/imfs/ioman.c (deleted) * cpukit/libfs/src/imfs/memfile.c (deleted) * cpukit/libfs/src/imfs/miniimfs_init.c (deleted) * cpukit/libmisc/Makefile.am (deleted) * cpukit/libmisc/README (deleted) * cpukit/libmisc/cpuuse/Makefile.am (deleted) * cpukit/libmisc/cpuuse/README (deleted) * cpukit/libmisc/cpuuse/cpuuse.c (deleted) * cpukit/libmisc/cpuuse/cpuuse.h (deleted) * cpukit/libmisc/dummy/Makefile.am (deleted) * cpukit/libmisc/dummy/README (deleted) * cpukit/libmisc/dummy/dummy.c (deleted) * cpukit/libmisc/dumpbuf/Makefile.am (deleted) * cpukit/libmisc/dumpbuf/dumpbuf.c (deleted) * cpukit/libmisc/dumpbuf/dumpbuf.h (deleted) * cpukit/libmisc/monitor/Makefile.am (deleted) * cpukit/libmisc/monitor/README (deleted) * cpukit/libmisc/monitor/mon-command.c (deleted) * cpukit/libmisc/monitor/mon-config.c (deleted) * cpukit/libmisc/monitor/mon-dname.c (deleted) * cpukit/libmisc/monitor/mon-driver.c (deleted) * cpukit/libmisc/monitor/mon-extension.c (deleted) * cpukit/libmisc/monitor/mon-itask.c (deleted) * cpukit/libmisc/monitor/mon-manager.c (deleted) * cpukit/libmisc/monitor/mon-monitor.c (deleted) * cpukit/libmisc/monitor/mon-mpci.c (deleted) * cpukit/libmisc/monitor/mon-object.c (deleted) * cpukit/libmisc/monitor/mon-prmisc.c (deleted) * cpukit/libmisc/monitor/mon-queue.c (deleted) * cpukit/libmisc/monitor/mon-server.c (deleted) * cpukit/libmisc/monitor/mon-symbols.c (deleted) * cpukit/libmisc/monitor/mon-task.c (deleted) * cpukit/libmisc/monitor/monitor.h (deleted) * cpukit/libmisc/monitor/symbols.h (deleted) * cpukit/libmisc/rtmonuse/Makefile.am (deleted) * cpukit/libmisc/rtmonuse/rtmonuse.c (deleted) * cpukit/libmisc/rtmonuse/rtmonuse.h (deleted) * cpukit/libmisc/stackchk/Makefile.am (deleted) * cpukit/libmisc/stackchk/README (deleted) * cpukit/libmisc/stackchk/check.c (deleted) * cpukit/libmisc/stackchk/internal.h (deleted) * cpukit/libmisc/stackchk/stackchk.h (deleted) * cpukit/libmisc/untar/Makefile.am (deleted) * cpukit/libmisc/untar/README (deleted) * cpukit/libmisc/untar/untar.c (deleted) * cpukit/libmisc/untar/untar.h (deleted) * cpukit/libmisc/wrapup/Makefile.am (deleted) * cpukit/libnetworking/Makefile.am (deleted) * cpukit/libnetworking/README (deleted) * cpukit/libnetworking/arpa/Makefile.am (deleted) * cpukit/libnetworking/arpa/ftp.h (deleted) * cpukit/libnetworking/arpa/inet.h (deleted) * cpukit/libnetworking/arpa/nameser.h (deleted) * cpukit/libnetworking/arpa/nameser_compat.h (deleted) * cpukit/libnetworking/arpa/telnet.h (deleted) * cpukit/libnetworking/bpfilter.h (deleted) * cpukit/libnetworking/kern/Makefile.am (deleted) * cpukit/libnetworking/kern/kern_subr.c (deleted) * cpukit/libnetworking/kern/uipc_domain.c (deleted) * cpukit/libnetworking/kern/uipc_mbuf.c (deleted) * cpukit/libnetworking/kern/uipc_socket.c (deleted) * cpukit/libnetworking/kern/uipc_socket2.c (deleted) * cpukit/libnetworking/lib/Makefile.am (deleted) * cpukit/libnetworking/lib/README (deleted) * cpukit/libnetworking/lib/getprotoby.c (deleted) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (deleted) * cpukit/libnetworking/lib/syslog.c (deleted) * cpukit/libnetworking/lib/tftpDriver.c (deleted) * cpukit/libnetworking/libc/Makefile.am (deleted) * cpukit/libnetworking/libc/addr2ascii.3 (deleted) * cpukit/libnetworking/libc/addr2ascii.c (deleted) * cpukit/libnetworking/libc/ascii2addr.c (deleted) * cpukit/libnetworking/libc/base64.c (deleted) * cpukit/libnetworking/libc/byteorder.3 (deleted) * cpukit/libnetworking/libc/ether_addr.c (deleted) * cpukit/libnetworking/libc/ethers.3 (deleted) * cpukit/libnetworking/libc/gethostbydns.c (deleted) * cpukit/libnetworking/libc/gethostbyht.c (deleted) * cpukit/libnetworking/libc/gethostbyname.3 (deleted) * cpukit/libnetworking/libc/gethostbynis.c (deleted) * cpukit/libnetworking/libc/gethostnamadr.c (deleted) * cpukit/libnetworking/libc/gethostname.c (deleted) * cpukit/libnetworking/libc/getnetbydns.c (deleted) * cpukit/libnetworking/libc/getnetbyht.c (deleted) * cpukit/libnetworking/libc/getnetbynis.c (deleted) * cpukit/libnetworking/libc/getnetent.3 (deleted) * cpukit/libnetworking/libc/getnetnamadr.c (deleted) * cpukit/libnetworking/libc/getproto.c (deleted) * cpukit/libnetworking/libc/getprotoent.3 (deleted) * cpukit/libnetworking/libc/getprotoent.c (deleted) * cpukit/libnetworking/libc/getprotoname.c (deleted) * cpukit/libnetworking/libc/getservbyname.c (deleted) * cpukit/libnetworking/libc/getservbyport.c (deleted) * cpukit/libnetworking/libc/getservent.3 (deleted) * cpukit/libnetworking/libc/getservent.c (deleted) * cpukit/libnetworking/libc/herror.c (deleted) * cpukit/libnetworking/libc/inet.3 (deleted) * cpukit/libnetworking/libc/inet_addr.c (deleted) * cpukit/libnetworking/libc/inet_lnaof.c (deleted) * cpukit/libnetworking/libc/inet_makeaddr.c (deleted) * cpukit/libnetworking/libc/inet_net_ntop.c (deleted) * cpukit/libnetworking/libc/inet_net_pton.c (deleted) * cpukit/libnetworking/libc/inet_neta.c (deleted) * cpukit/libnetworking/libc/inet_netof.c (deleted) * cpukit/libnetworking/libc/inet_network.c (deleted) * cpukit/libnetworking/libc/inet_ntoa.c (deleted) * cpukit/libnetworking/libc/inet_ntop.c (deleted) * cpukit/libnetworking/libc/inet_pton.c (deleted) * cpukit/libnetworking/libc/iso_addr.3 (deleted) * cpukit/libnetworking/libc/iso_addr.c (deleted) * cpukit/libnetworking/libc/linkaddr.3 (deleted) * cpukit/libnetworking/libc/linkaddr.c (deleted) * cpukit/libnetworking/libc/map_v4v6.c (deleted) * cpukit/libnetworking/libc/ns.3 (deleted) * cpukit/libnetworking/libc/ns_addr.c (deleted) * cpukit/libnetworking/libc/ns_name.c (deleted) * cpukit/libnetworking/libc/ns_netint.c (deleted) * cpukit/libnetworking/libc/ns_ntoa.c (deleted) * cpukit/libnetworking/libc/ns_parse.c (deleted) * cpukit/libnetworking/libc/ns_print.c (deleted) * cpukit/libnetworking/libc/ns_ttl.c (deleted) * cpukit/libnetworking/libc/nsap_addr.c (deleted) * cpukit/libnetworking/libc/rcmd.3 (deleted) * cpukit/libnetworking/libc/rcmd.c (deleted) * cpukit/libnetworking/libc/recv.c (deleted) * cpukit/libnetworking/libc/res_comp.c (deleted) * cpukit/libnetworking/libc/res_config.h (deleted) * cpukit/libnetworking/libc/res_data.c (deleted) * cpukit/libnetworking/libc/res_debug.c (deleted) * cpukit/libnetworking/libc/res_init.c (deleted) * cpukit/libnetworking/libc/res_mkquery.c (deleted) * cpukit/libnetworking/libc/res_mkupdate.c (deleted) * cpukit/libnetworking/libc/res_query.c (deleted) * cpukit/libnetworking/libc/res_send.c (deleted) * cpukit/libnetworking/libc/res_stubs.c (deleted) * cpukit/libnetworking/libc/res_update.c (deleted) * cpukit/libnetworking/libc/resolver.3 (deleted) * cpukit/libnetworking/libc/send.c (deleted) * cpukit/libnetworking/libc/strsep.c (deleted) * cpukit/libnetworking/loop.h (deleted) * cpukit/libnetworking/machine/Makefile.am (deleted) * cpukit/libnetworking/machine/conf.h (deleted) * cpukit/libnetworking/machine/cpu.h (deleted) * cpukit/libnetworking/machine/cpufunc.h (deleted) * cpukit/libnetworking/machine/endian.h (deleted) * cpukit/libnetworking/machine/in_cksum.h (deleted) * cpukit/libnetworking/machine/limits.h (deleted) * cpukit/libnetworking/machine/param.h (deleted) * cpukit/libnetworking/machine/types.h (deleted) * cpukit/libnetworking/machine/vmparam.h (deleted) * cpukit/libnetworking/net/Makefile.am (deleted) * cpukit/libnetworking/net/bpf.h (deleted) * cpukit/libnetworking/net/ethernet.h (deleted) * cpukit/libnetworking/net/if.c (deleted) * cpukit/libnetworking/net/if.h (deleted) * cpukit/libnetworking/net/if_arp.h (deleted) * cpukit/libnetworking/net/if_dl.h (deleted) * cpukit/libnetworking/net/if_ethersubr.c (deleted) * cpukit/libnetworking/net/if_llc.h (deleted) * cpukit/libnetworking/net/if_loop.c (deleted) * cpukit/libnetworking/net/if_ppp.h (deleted) * cpukit/libnetworking/net/if_types.h (deleted) * cpukit/libnetworking/net/netisr.h (deleted) * cpukit/libnetworking/net/ppp-comp.h (deleted) * cpukit/libnetworking/net/ppp_defs.h (deleted) * cpukit/libnetworking/net/radix.c (deleted) * cpukit/libnetworking/net/radix.h (deleted) * cpukit/libnetworking/net/raw_cb.c (deleted) * cpukit/libnetworking/net/raw_cb.h (deleted) * cpukit/libnetworking/net/raw_usrreq.c (deleted) * cpukit/libnetworking/net/route.c (deleted) * cpukit/libnetworking/net/route.h (deleted) * cpukit/libnetworking/net/rtsock.c (deleted) * cpukit/libnetworking/netdb.h (deleted) * cpukit/libnetworking/netinet/Makefile.am (deleted) * cpukit/libnetworking/netinet/icmp_var.h (deleted) * cpukit/libnetworking/netinet/if_ether.c (deleted) * cpukit/libnetworking/netinet/if_ether.h (deleted) * cpukit/libnetworking/netinet/igmp.c (deleted) * cpukit/libnetworking/netinet/igmp.h (deleted) * cpukit/libnetworking/netinet/igmp_var.h (deleted) * cpukit/libnetworking/netinet/in.c (deleted) * cpukit/libnetworking/netinet/in.h (deleted) * cpukit/libnetworking/netinet/in_cksum.c (deleted) * cpukit/libnetworking/netinet/in_cksum_i386.c (deleted) * cpukit/libnetworking/netinet/in_cksum_i386.h (deleted) * cpukit/libnetworking/netinet/in_cksum_m68k.c (deleted) * cpukit/libnetworking/netinet/in_cksum_m68k.h (deleted) * cpukit/libnetworking/netinet/in_cksum_powerpc.c (deleted) * cpukit/libnetworking/netinet/in_cksum_powerpc.h (deleted) * cpukit/libnetworking/netinet/in_pcb.c (deleted) * cpukit/libnetworking/netinet/in_pcb.h (deleted) * cpukit/libnetworking/netinet/in_proto.c (deleted) * cpukit/libnetworking/netinet/in_rmx.c (deleted) * cpukit/libnetworking/netinet/in_systm.h (deleted) * cpukit/libnetworking/netinet/in_var.h (deleted) * cpukit/libnetworking/netinet/ip.h (deleted) * cpukit/libnetworking/netinet/ip_divert.c (deleted) * cpukit/libnetworking/netinet/ip_fw.c (deleted) * cpukit/libnetworking/netinet/ip_fw.h (deleted) * cpukit/libnetworking/netinet/ip_icmp.c (deleted) * cpukit/libnetworking/netinet/ip_icmp.h (deleted) * cpukit/libnetworking/netinet/ip_input.c (deleted) * cpukit/libnetworking/netinet/ip_mroute.c (deleted) * cpukit/libnetworking/netinet/ip_mroute.h (deleted) * cpukit/libnetworking/netinet/ip_output.c (deleted) * cpukit/libnetworking/netinet/ip_var.h (deleted) * cpukit/libnetworking/netinet/raw_ip.c (deleted) * cpukit/libnetworking/netinet/tcp.h (deleted) * cpukit/libnetworking/netinet/tcp_debug.c (deleted) * cpukit/libnetworking/netinet/tcp_debug.h (deleted) * cpukit/libnetworking/netinet/tcp_fsm.h (deleted) * cpukit/libnetworking/netinet/tcp_input.c (deleted) * cpukit/libnetworking/netinet/tcp_output.c (deleted) * cpukit/libnetworking/netinet/tcp_seq.h (deleted) * cpukit/libnetworking/netinet/tcp_subr.c (deleted) * cpukit/libnetworking/netinet/tcp_timer.c (deleted) * cpukit/libnetworking/netinet/tcp_timer.h (deleted) * cpukit/libnetworking/netinet/tcp_usrreq.c (deleted) * cpukit/libnetworking/netinet/tcp_var.h (deleted) * cpukit/libnetworking/netinet/tcpip.h (deleted) * cpukit/libnetworking/netinet/udp.h (deleted) * cpukit/libnetworking/netinet/udp_usrreq.c (deleted) * cpukit/libnetworking/netinet/udp_var.h (deleted) * cpukit/libnetworking/nfs/Makefile.am (deleted) * cpukit/libnetworking/nfs/bootp_subr.c (deleted) * cpukit/libnetworking/nfs/krpc.h (deleted) * cpukit/libnetworking/nfs/nfs.h (deleted) * cpukit/libnetworking/nfs/nfsdiskless.h (deleted) * cpukit/libnetworking/nfs/nfsproto.h (deleted) * cpukit/libnetworking/nfs/rpcv2.h (deleted) * cpukit/libnetworking/nfs/xdr_subs.h (deleted) * cpukit/libnetworking/opt_ipfw.h (deleted) * cpukit/libnetworking/opt_mrouting.h (deleted) * cpukit/libnetworking/opt_tcpdebug.h (deleted) * cpukit/libnetworking/poll.h (deleted) * cpukit/libnetworking/resolv.h (deleted) * cpukit/libnetworking/rtems/Makefile.am (deleted) * cpukit/libnetworking/rtems/issetugid.c (deleted) * cpukit/libnetworking/rtems/rtems_bootp.c (deleted) * cpukit/libnetworking/rtems/rtems_bsdnet.h (deleted) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (deleted) * cpukit/libnetworking/rtems/rtems_glue.c (deleted) * cpukit/libnetworking/rtems/rtems_select.c (deleted) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (deleted) * cpukit/libnetworking/rtems/rtems_showifstat.c (deleted) * cpukit/libnetworking/rtems/rtems_showipstat.c (deleted) * cpukit/libnetworking/rtems/rtems_showmbuf.c (deleted) * cpukit/libnetworking/rtems/rtems_showroute.c (deleted) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (deleted) * cpukit/libnetworking/rtems/rtems_showudpstat.c (deleted) * cpukit/libnetworking/rtems/rtems_syscall.c (deleted) * cpukit/libnetworking/rtems/sghostname.c (deleted) * cpukit/libnetworking/rtems/tftp.h (deleted) * cpukit/libnetworking/sys/Makefile.am (deleted) * cpukit/libnetworking/sys/buf.h (deleted) * cpukit/libnetworking/sys/callout.h (deleted) * cpukit/libnetworking/sys/conf.h (deleted) * cpukit/libnetworking/sys/domain.h (deleted) * cpukit/libnetworking/sys/kernel.h (deleted) * cpukit/libnetworking/sys/libkern.h (deleted) * cpukit/libnetworking/sys/malloc.h (deleted) * cpukit/libnetworking/sys/mbuf.h (deleted) * cpukit/libnetworking/sys/mount.h (deleted) * cpukit/libnetworking/sys/param.h (deleted) * cpukit/libnetworking/sys/proc.h (deleted) * cpukit/libnetworking/sys/protosw.h (deleted) * cpukit/libnetworking/sys/queue.h (deleted) * cpukit/libnetworking/sys/reboot.h (deleted) * cpukit/libnetworking/sys/resourcevar.h (deleted) * cpukit/libnetworking/sys/rtprio.h (deleted) * cpukit/libnetworking/sys/select.h (deleted) * cpukit/libnetworking/sys/signalvar.h (deleted) * cpukit/libnetworking/sys/socket.h (deleted) * cpukit/libnetworking/sys/socketvar.h (deleted) * cpukit/libnetworking/sys/sysctl.h (deleted) * cpukit/libnetworking/sys/syslimits.h (deleted) * cpukit/libnetworking/sys/syslog.h (deleted) * cpukit/libnetworking/sys/systm.h (deleted) * cpukit/libnetworking/sys/ttydefaults.h (deleted) * cpukit/libnetworking/sys/ucred.h (deleted) * cpukit/libnetworking/sys/uio.h (deleted) * cpukit/libnetworking/syslog.h (deleted) * cpukit/libnetworking/vm/Makefile.am (deleted) * cpukit/libnetworking/vm/vm.h (deleted) * cpukit/libnetworking/vm/vm_extern.h (deleted) * cpukit/libnetworking/vm/vm_kern.h (deleted) * cpukit/libnetworking/vm/vm_param.h (deleted) * cpukit/libnetworking/wrapup/Makefile.am (deleted) * cpukit/librpc/Makefile.am (deleted) * cpukit/librpc/include/Makefile.am (deleted) * cpukit/librpc/include/rpc/Makefile.am (deleted) * cpukit/librpc/include/rpc/auth.h (deleted) * cpukit/librpc/include/rpc/clnt.h (deleted) * cpukit/librpc/include/rpc/rpc.h (deleted) * cpukit/librpc/include/rpc/rpc_msg.h (deleted) * cpukit/librpc/include/rpc/svc.h (deleted) * cpukit/librpc/include/rpc/svc_auth.h (deleted) * cpukit/librpc/include/rpc/types.h (deleted) * cpukit/librpc/include/rpc/xdr.h (deleted) * cpukit/librpc/src/Makefile.am (deleted) * cpukit/posix/Makefile.am (deleted) * cpukit/posix/include/Makefile.am (deleted) * cpukit/posix/include/aio.h (deleted) * cpukit/posix/include/devctl.h (deleted) * cpukit/posix/include/intr.h (deleted) * cpukit/posix/include/mqueue.h (deleted) * cpukit/posix/include/rtems/posix/cancel.h (deleted) * cpukit/posix/include/rtems/posix/cond.h (deleted) * cpukit/posix/include/rtems/posix/condmp.h (deleted) * cpukit/posix/include/rtems/posix/config.h (deleted) * cpukit/posix/include/rtems/posix/intr.h (deleted) * cpukit/posix/include/rtems/posix/key.h (deleted) * cpukit/posix/include/rtems/posix/mqueue.h (deleted) * cpukit/posix/include/rtems/posix/mqueuemp.h (deleted) * cpukit/posix/include/rtems/posix/mutex.h (deleted) * cpukit/posix/include/rtems/posix/mutexmp.h (deleted) * cpukit/posix/include/rtems/posix/posixapi.h (deleted) * cpukit/posix/include/rtems/posix/priority.h (deleted) * cpukit/posix/include/rtems/posix/psignal.h (deleted) * cpukit/posix/include/rtems/posix/pthread.h (deleted) * cpukit/posix/include/rtems/posix/pthreadmp.h (deleted) * cpukit/posix/include/rtems/posix/ptimer.h (deleted) * cpukit/posix/include/rtems/posix/semaphore.h (deleted) * cpukit/posix/include/rtems/posix/semaphoremp.h (deleted) * cpukit/posix/include/rtems/posix/threadsup.h (deleted) * cpukit/posix/include/rtems/posix/time.h (deleted) * cpukit/posix/include/rtems/posix/timer.h (deleted) * cpukit/posix/include/sched.h (deleted) * cpukit/posix/include/semaphore.h (deleted) * cpukit/posix/inline/Makefile.am (deleted) * cpukit/posix/inline/rtems/posix/cond.inl (deleted) * cpukit/posix/inline/rtems/posix/intr.inl (deleted) * cpukit/posix/inline/rtems/posix/key.inl (deleted) * cpukit/posix/inline/rtems/posix/mqueue.inl (deleted) * cpukit/posix/inline/rtems/posix/mutex.inl (deleted) * cpukit/posix/inline/rtems/posix/priority.inl (deleted) * cpukit/posix/inline/rtems/posix/pthread.inl (deleted) * cpukit/posix/inline/rtems/posix/semaphore.inl (deleted) * cpukit/posix/macros/Makefile.am (deleted) * cpukit/posix/src/Makefile.am (deleted) * cpukit/posix/src/README.mqueue (deleted) * cpukit/posix/src/adasupp.c (deleted) * cpukit/posix/src/aio.c (deleted) * cpukit/posix/src/alarm.c (deleted) * cpukit/posix/src/cancel.c (deleted) * cpukit/posix/src/cancelrun.c (deleted) * cpukit/posix/src/cleanuppop.c (deleted) * cpukit/posix/src/cleanuppush.c (deleted) * cpukit/posix/src/clockgetcpuclockid.c (deleted) * cpukit/posix/src/clockgetenableattr.c (deleted) * cpukit/posix/src/clockgetres.c (deleted) * cpukit/posix/src/clockgettime.c (deleted) * cpukit/posix/src/clocksetenableattr.c (deleted) * cpukit/posix/src/clocksettime.c (deleted) * cpukit/posix/src/cond.c (deleted) * cpukit/posix/src/condattrdestroy.c (deleted) * cpukit/posix/src/condattrgetpshared.c (deleted) * cpukit/posix/src/condattrinit.c (deleted) * cpukit/posix/src/condattrsetpshared.c (deleted) * cpukit/posix/src/condbroadcast.c (deleted) * cpukit/posix/src/conddefaultattributes.c (deleted) * cpukit/posix/src/conddestroy.c (deleted) * cpukit/posix/src/condinit.c (deleted) * cpukit/posix/src/condmp.c (deleted) * cpukit/posix/src/condsignal.c (deleted) * cpukit/posix/src/condsignalsupp.c (deleted) * cpukit/posix/src/condtimedwait.c (deleted) * cpukit/posix/src/condwait.c (deleted) * cpukit/posix/src/condwaitsupp.c (deleted) * cpukit/posix/src/devctl.c (deleted) * cpukit/posix/src/execl.c (deleted) * cpukit/posix/src/execle.c (deleted) * cpukit/posix/src/execlp.c (deleted) * cpukit/posix/src/execv.c (deleted) * cpukit/posix/src/execve.c (deleted) * cpukit/posix/src/execvp.c (deleted) * cpukit/posix/src/fork.c (deleted) * cpukit/posix/src/getegid.c (deleted) * cpukit/posix/src/geteuid.c (deleted) * cpukit/posix/src/getgid.c (deleted) * cpukit/posix/src/getgroups.c (deleted) * cpukit/posix/src/getlogin.c (deleted) * cpukit/posix/src/getpgrp.c (deleted) * cpukit/posix/src/getpid.c (deleted) * cpukit/posix/src/getppid.c (deleted) * cpukit/posix/src/getuid.c (deleted) * cpukit/posix/src/intr.c (deleted) * cpukit/posix/src/key.c (deleted) * cpukit/posix/src/keycreate.c (deleted) * cpukit/posix/src/keydelete.c (deleted) * cpukit/posix/src/keygetspecific.c (deleted) * cpukit/posix/src/keyrundestructors.c (deleted) * cpukit/posix/src/keysetspecific.c (deleted) * cpukit/posix/src/kill.c (deleted) * cpukit/posix/src/killinfo.c (deleted) * cpukit/posix/src/mqueue.c (deleted) * cpukit/posix/src/mqueueclose.c (deleted) * cpukit/posix/src/mqueuecreatesupp.c (deleted) * cpukit/posix/src/mqueuedeletesupp.c (deleted) * cpukit/posix/src/mqueuegetattr.c (deleted) * cpukit/posix/src/mqueuenametoid.c (deleted) * cpukit/posix/src/mqueuenotify.c (deleted) * cpukit/posix/src/mqueueopen.c (deleted) * cpukit/posix/src/mqueuereceive.c (deleted) * cpukit/posix/src/mqueuerecvsupp.c (deleted) * cpukit/posix/src/mqueuesend.c (deleted) * cpukit/posix/src/mqueuesendsupp.c (deleted) * cpukit/posix/src/mqueuesetattr.c (deleted) * cpukit/posix/src/mqueuetimedreceive.c (deleted) * cpukit/posix/src/mqueuetimedsend.c (deleted) * cpukit/posix/src/mqueuetranslatereturncode.c (deleted) * cpukit/posix/src/mqueueunlink.c (deleted) * cpukit/posix/src/mutex.c (deleted) * cpukit/posix/src/mutexattrdestroy.c (deleted) * cpukit/posix/src/mutexattrgetprioceiling.c (deleted) * cpukit/posix/src/mutexattrgetprotocol.c (deleted) * cpukit/posix/src/mutexattrgetpshared.c (deleted) * cpukit/posix/src/mutexattrinit.c (deleted) * cpukit/posix/src/mutexattrsetprioceiling.c (deleted) * cpukit/posix/src/mutexattrsetprotocol.c (deleted) * cpukit/posix/src/mutexattrsetpshared.c (deleted) * cpukit/posix/src/mutexdefaultattributes.c (deleted) * cpukit/posix/src/mutexdestroy.c (deleted) * cpukit/posix/src/mutexfromcorestatus.c (deleted) * cpukit/posix/src/mutexgetprioceiling.c (deleted) * cpukit/posix/src/mutexinit.c (deleted) * cpukit/posix/src/mutexlock.c (deleted) * cpukit/posix/src/mutexlocksupp.c (deleted) * cpukit/posix/src/mutexmp.c (deleted) * cpukit/posix/src/mutexsetprioceiling.c (deleted) * cpukit/posix/src/mutextimedlock.c (deleted) * cpukit/posix/src/mutextrylock.c (deleted) * cpukit/posix/src/mutexunlock.c (deleted) * cpukit/posix/src/nanosleep.c (deleted) * cpukit/posix/src/pause.c (deleted) * cpukit/posix/src/posixintervaltotimespec.c (deleted) * cpukit/posix/src/posixtimespecsubtract.c (deleted) * cpukit/posix/src/posixtimespectointerval.c (deleted) * cpukit/posix/src/psignal.c (deleted) * cpukit/posix/src/psignalchecksignal.c (deleted) * cpukit/posix/src/psignalclearprocesssignals.c (deleted) * cpukit/posix/src/psignalclearsignals.c (deleted) * cpukit/posix/src/psignalsetprocesssignals.c (deleted) * cpukit/posix/src/psignalunblockthread.c (deleted) * cpukit/posix/src/pthread.c (deleted) * cpukit/posix/src/pthreadatfork.c (deleted) * cpukit/posix/src/pthreadattrdestroy.c (deleted) * cpukit/posix/src/pthreadattrgetdetachstate.c (deleted) * cpukit/posix/src/pthreadattrgetinheritsched.c (deleted) * cpukit/posix/src/pthreadattrgetschedparam.c (deleted) * cpukit/posix/src/pthreadattrgetschedpolicy.c (deleted) * cpukit/posix/src/pthreadattrgetscope.c (deleted) * cpukit/posix/src/pthreadattrgetstackaddr.c (deleted) * cpukit/posix/src/pthreadattrgetstacksize.c (deleted) * cpukit/posix/src/pthreadattrinit.c (deleted) * cpukit/posix/src/pthreadattrsetdetachstate.c (deleted) * cpukit/posix/src/pthreadattrsetinheritsched.c (deleted) * cpukit/posix/src/pthreadattrsetschedparam.c (deleted) * cpukit/posix/src/pthreadattrsetschedpolicy.c (deleted) * cpukit/posix/src/pthreadattrsetscope.c (deleted) * cpukit/posix/src/pthreadattrsetstackaddr.c (deleted) * cpukit/posix/src/pthreadattrsetstacksize.c (deleted) * cpukit/posix/src/pthreadcreate.c (deleted) * cpukit/posix/src/pthreaddetach.c (deleted) * cpukit/posix/src/pthreadequal.c (deleted) * cpukit/posix/src/pthreadexit.c (deleted) * cpukit/posix/src/pthreadgetcpuclockid.c (deleted) * cpukit/posix/src/pthreadgetcputime.c (deleted) * cpukit/posix/src/pthreadgetschedparam.c (deleted) * cpukit/posix/src/pthreadjoin.c (deleted) * cpukit/posix/src/pthreadkill.c (deleted) * cpukit/posix/src/pthreadonce.c (deleted) * cpukit/posix/src/pthreadself.c (deleted) * cpukit/posix/src/pthreadsetcputime.c (deleted) * cpukit/posix/src/pthreadsetschedparam.c (deleted) * cpukit/posix/src/pthreadsigmask.c (deleted) * cpukit/posix/src/ptimer.c (deleted) * cpukit/posix/src/ptimer1.c (deleted) * cpukit/posix/src/sched.c (deleted) * cpukit/posix/src/semaphore.c (deleted) * cpukit/posix/src/semaphorecreatesupp.c (deleted) * cpukit/posix/src/semaphoredeletesupp.c (deleted) * cpukit/posix/src/semaphoremp.c (deleted) * cpukit/posix/src/semaphorenametoid.c (deleted) * cpukit/posix/src/semaphorewaitsupp.c (deleted) * cpukit/posix/src/semclose.c (deleted) * cpukit/posix/src/semdestroy.c (deleted) * cpukit/posix/src/semgetvalue.c (deleted) * cpukit/posix/src/seminit.c (deleted) * cpukit/posix/src/semopen.c (deleted) * cpukit/posix/src/sempost.c (deleted) * cpukit/posix/src/semtimedwait.c (deleted) * cpukit/posix/src/semtrywait.c (deleted) * cpukit/posix/src/semunlink.c (deleted) * cpukit/posix/src/semwait.c (deleted) * cpukit/posix/src/setcancelstate.c (deleted) * cpukit/posix/src/setcanceltype.c (deleted) * cpukit/posix/src/setpgid.c (deleted) * cpukit/posix/src/setsid.c (deleted) * cpukit/posix/src/sigaction.c (deleted) * cpukit/posix/src/sigaddset.c (deleted) * cpukit/posix/src/sigdelset.c (deleted) * cpukit/posix/src/sigemptyset.c (deleted) * cpukit/posix/src/sigfillset.c (deleted) * cpukit/posix/src/sigismember.c (deleted) * cpukit/posix/src/signal_2.c (deleted) * cpukit/posix/src/sigpending.c (deleted) * cpukit/posix/src/sigprocmask.c (deleted) * cpukit/posix/src/sigqueue.c (deleted) * cpukit/posix/src/sigsuspend.c (deleted) * cpukit/posix/src/sigtimedwait.c (deleted) * cpukit/posix/src/sigwait.c (deleted) * cpukit/posix/src/sigwaitinfo.c (deleted) * cpukit/posix/src/sleep.c (deleted) * cpukit/posix/src/sysconf.c (deleted) * cpukit/posix/src/testcancel.c (deleted) * cpukit/posix/src/time.c (deleted) * cpukit/posix/src/types.c (deleted) * cpukit/posix/src/wait.c (deleted) * cpukit/posix/src/waitpid.c (deleted) * cpukit/pppd/Makefile.am (deleted) * cpukit/pppd/README (deleted) * cpukit/pppd/STATUS (deleted) * cpukit/pppd/auth.c (deleted) * cpukit/pppd/cbcp.c (deleted) * cpukit/pppd/cbcp.h (deleted) * cpukit/pppd/ccp.c (deleted) * cpukit/pppd/ccp.h (deleted) * cpukit/pppd/chap.c (deleted) * cpukit/pppd/chap.h (deleted) * cpukit/pppd/chap_ms.c (deleted) * cpukit/pppd/chap_ms.h (deleted) * cpukit/pppd/chat.c (deleted) * cpukit/pppd/demand.c (deleted) * cpukit/pppd/fsm.c (deleted) * cpukit/pppd/fsm.h (deleted) * cpukit/pppd/ipcp.c (deleted) * cpukit/pppd/ipcp.h (deleted) * cpukit/pppd/ipxcp.c (deleted) * cpukit/pppd/ipxcp.h (deleted) * cpukit/pppd/lcp.c (deleted) * cpukit/pppd/lcp.h (deleted) * cpukit/pppd/magic.c (deleted) * cpukit/pppd/magic.h (deleted) * cpukit/pppd/md4.c (deleted) * cpukit/pppd/md4.h (deleted) * cpukit/pppd/md5.c (deleted) * cpukit/pppd/md5.h (deleted) * cpukit/pppd/options.c (deleted) * cpukit/pppd/patchlevel.h (deleted) * cpukit/pppd/pathnames.h (deleted) * cpukit/pppd/pppd.h (deleted) * cpukit/pppd/upap.c (deleted) * cpukit/pppd/upap.h (deleted) * cpukit/rtems/Makefile.am (deleted) * cpukit/rtems/include/Makefile.am (deleted) * cpukit/rtems/include/rtems.h (deleted) * cpukit/rtems/include/rtems/rtems/asr.h (deleted) * cpukit/rtems/include/rtems/rtems/attr.h (deleted) * cpukit/rtems/include/rtems/rtems/clock.h (deleted) * cpukit/rtems/include/rtems/rtems/config.h (deleted) * cpukit/rtems/include/rtems/rtems/dpmem.h (deleted) * cpukit/rtems/include/rtems/rtems/event.h (deleted) * cpukit/rtems/include/rtems/rtems/eventmp.h (deleted) * cpukit/rtems/include/rtems/rtems/eventset.h (deleted) * cpukit/rtems/include/rtems/rtems/intr.h (deleted) * cpukit/rtems/include/rtems/rtems/message.h (deleted) * cpukit/rtems/include/rtems/rtems/modes.h (deleted) * cpukit/rtems/include/rtems/rtems/mp.h (deleted) * cpukit/rtems/include/rtems/rtems/msgmp.h (deleted) * cpukit/rtems/include/rtems/rtems/options.h (deleted) * cpukit/rtems/include/rtems/rtems/part.h (deleted) * cpukit/rtems/include/rtems/rtems/partmp.h (deleted) * cpukit/rtems/include/rtems/rtems/ratemon.h (deleted) * cpukit/rtems/include/rtems/rtems/region.h (deleted) * cpukit/rtems/include/rtems/rtems/regionmp.h (deleted) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (deleted) * cpukit/rtems/include/rtems/rtems/sem.h (deleted) * cpukit/rtems/include/rtems/rtems/semmp.h (deleted) * cpukit/rtems/include/rtems/rtems/signal.h (deleted) * cpukit/rtems/include/rtems/rtems/signalmp.h (deleted) * cpukit/rtems/include/rtems/rtems/status.h (deleted) * cpukit/rtems/include/rtems/rtems/support.h (deleted) * cpukit/rtems/include/rtems/rtems/taskmp.h (deleted) * cpukit/rtems/include/rtems/rtems/tasks.h (deleted) * cpukit/rtems/include/rtems/rtems/timer.h (deleted) * cpukit/rtems/include/rtems/rtems/types.h (deleted) * cpukit/rtems/inline/Makefile.am (deleted) * cpukit/rtems/inline/rtems/rtems/asr.inl (deleted) * cpukit/rtems/inline/rtems/rtems/attr.inl (deleted) * cpukit/rtems/inline/rtems/rtems/dpmem.inl (deleted) * cpukit/rtems/inline/rtems/rtems/event.inl (deleted) * cpukit/rtems/inline/rtems/rtems/eventset.inl (deleted) * cpukit/rtems/inline/rtems/rtems/message.inl (deleted) * cpukit/rtems/inline/rtems/rtems/modes.inl (deleted) * cpukit/rtems/inline/rtems/rtems/options.inl (deleted) * cpukit/rtems/inline/rtems/rtems/part.inl (deleted) * cpukit/rtems/inline/rtems/rtems/ratemon.inl (deleted) * cpukit/rtems/inline/rtems/rtems/region.inl (deleted) * cpukit/rtems/inline/rtems/rtems/sem.inl (deleted) * cpukit/rtems/inline/rtems/rtems/status.inl (deleted) * cpukit/rtems/inline/rtems/rtems/support.inl (deleted) * cpukit/rtems/inline/rtems/rtems/tasks.inl (deleted) * cpukit/rtems/inline/rtems/rtems/timer.inl (deleted) * cpukit/rtems/macros/Makefile.am (deleted) * cpukit/rtems/macros/rtems/rtems/asr.inl (deleted) * cpukit/rtems/macros/rtems/rtems/attr.inl (deleted) * cpukit/rtems/macros/rtems/rtems/dpmem.inl (deleted) * cpukit/rtems/macros/rtems/rtems/event.inl (deleted) * cpukit/rtems/macros/rtems/rtems/eventset.inl (deleted) * cpukit/rtems/macros/rtems/rtems/message.inl (deleted) * cpukit/rtems/macros/rtems/rtems/modes.inl (deleted) * cpukit/rtems/macros/rtems/rtems/options.inl (deleted) * cpukit/rtems/macros/rtems/rtems/part.inl (deleted) * cpukit/rtems/macros/rtems/rtems/ratemon.inl (deleted) * cpukit/rtems/macros/rtems/rtems/region.inl (deleted) * cpukit/rtems/macros/rtems/rtems/sem.inl (deleted) * cpukit/rtems/macros/rtems/rtems/status.inl (deleted) * cpukit/rtems/macros/rtems/rtems/support.inl (deleted) * cpukit/rtems/macros/rtems/rtems/tasks.inl (deleted) * cpukit/rtems/macros/rtems/rtems/timer.inl (deleted) * cpukit/rtems/src/Makefile.am (deleted) * cpukit/rtems/src/attr.c (deleted) * cpukit/rtems/src/clockget.c (deleted) * cpukit/rtems/src/clockset.c (deleted) * cpukit/rtems/src/clocktick.c (deleted) * cpukit/rtems/src/clocktodtoseconds.c (deleted) * cpukit/rtems/src/clocktodvalidate.c (deleted) * cpukit/rtems/src/dpmem.c (deleted) * cpukit/rtems/src/dpmemcreate.c (deleted) * cpukit/rtems/src/dpmemdelete.c (deleted) * cpukit/rtems/src/dpmemexternal2internal.c (deleted) * cpukit/rtems/src/dpmemident.c (deleted) * cpukit/rtems/src/dpmeminternal2external.c (deleted) * cpukit/rtems/src/event.c (deleted) * cpukit/rtems/src/eventmp.c (deleted) * cpukit/rtems/src/eventreceive.c (deleted) * cpukit/rtems/src/eventseize.c (deleted) * cpukit/rtems/src/eventsend.c (deleted) * cpukit/rtems/src/eventsurrender.c (deleted) * cpukit/rtems/src/eventtimeout.c (deleted) * cpukit/rtems/src/intr.c (deleted) * cpukit/rtems/src/intrbody.c (deleted) * cpukit/rtems/src/intrcatch.c (deleted) * cpukit/rtems/src/mp.c (deleted) * cpukit/rtems/src/msg.c (deleted) * cpukit/rtems/src/msgmp.c (deleted) * cpukit/rtems/src/msgqallocate.c (deleted) * cpukit/rtems/src/msgqbroadcast.c (deleted) * cpukit/rtems/src/msgqcreate.c (deleted) * cpukit/rtems/src/msgqdelete.c (deleted) * cpukit/rtems/src/msgqflush.c (deleted) * cpukit/rtems/src/msgqgetnumberpending.c (deleted) * cpukit/rtems/src/msgqident.c (deleted) * cpukit/rtems/src/msgqreceive.c (deleted) * cpukit/rtems/src/msgqsend.c (deleted) * cpukit/rtems/src/msgqsubmit.c (deleted) * cpukit/rtems/src/msgqtranslatereturncode.c (deleted) * cpukit/rtems/src/msgqurgent.c (deleted) * cpukit/rtems/src/part.c (deleted) * cpukit/rtems/src/partcreate.c (deleted) * cpukit/rtems/src/partdelete.c (deleted) * cpukit/rtems/src/partgetbuffer.c (deleted) * cpukit/rtems/src/partident.c (deleted) * cpukit/rtems/src/partmp.c (deleted) * cpukit/rtems/src/partreturnbuffer.c (deleted) * cpukit/rtems/src/ratemon.c (deleted) * cpukit/rtems/src/ratemoncancel.c (deleted) * cpukit/rtems/src/ratemoncreate.c (deleted) * cpukit/rtems/src/ratemondelete.c (deleted) * cpukit/rtems/src/ratemongetstatus.c (deleted) * cpukit/rtems/src/ratemonident.c (deleted) * cpukit/rtems/src/ratemonperiod.c (deleted) * cpukit/rtems/src/ratemontimeout.c (deleted) * cpukit/rtems/src/region.c (deleted) * cpukit/rtems/src/regioncreate.c (deleted) * cpukit/rtems/src/regiondelete.c (deleted) * cpukit/rtems/src/regionextend.c (deleted) * cpukit/rtems/src/regiongetsegment.c (deleted) * cpukit/rtems/src/regiongetsegmentsize.c (deleted) * cpukit/rtems/src/regionident.c (deleted) * cpukit/rtems/src/regionmp.c (deleted) * cpukit/rtems/src/regionreturnsegment.c (deleted) * cpukit/rtems/src/rtclock.c (deleted) * cpukit/rtems/src/rtemstimer.c (deleted) * cpukit/rtems/src/sem.c (deleted) * cpukit/rtems/src/semcreate.c (deleted) * cpukit/rtems/src/semdelete.c (deleted) * cpukit/rtems/src/semflush.c (deleted) * cpukit/rtems/src/semident.c (deleted) * cpukit/rtems/src/semmp.c (deleted) * cpukit/rtems/src/semobtain.c (deleted) * cpukit/rtems/src/semrelease.c (deleted) * cpukit/rtems/src/semtranslatereturncode.c (deleted) * cpukit/rtems/src/signal.c (deleted) * cpukit/rtems/src/signalcatch.c (deleted) * cpukit/rtems/src/signalmp.c (deleted) * cpukit/rtems/src/signalsend.c (deleted) * cpukit/rtems/src/taskcreate.c (deleted) * cpukit/rtems/src/taskdelete.c (deleted) * cpukit/rtems/src/taskgetnote.c (deleted) * cpukit/rtems/src/taskident.c (deleted) * cpukit/rtems/src/taskinitusers.c (deleted) * cpukit/rtems/src/taskissuspended.c (deleted) * cpukit/rtems/src/taskmode.c (deleted) * cpukit/rtems/src/taskmp.c (deleted) * cpukit/rtems/src/taskrestart.c (deleted) * cpukit/rtems/src/taskresume.c (deleted) * cpukit/rtems/src/tasks.c (deleted) * cpukit/rtems/src/tasksetnote.c (deleted) * cpukit/rtems/src/tasksetpriority.c (deleted) * cpukit/rtems/src/taskstart.c (deleted) * cpukit/rtems/src/tasksuspend.c (deleted) * cpukit/rtems/src/taskvariableadd.c (deleted) * cpukit/rtems/src/taskvariabledelete.c (deleted) * cpukit/rtems/src/taskvariableget.c (deleted) * cpukit/rtems/src/taskwakeafter.c (deleted) * cpukit/rtems/src/taskwakewhen.c (deleted) * cpukit/rtems/src/timercancel.c (deleted) * cpukit/rtems/src/timercreate.c (deleted) * cpukit/rtems/src/timerdelete.c (deleted) * cpukit/rtems/src/timerfireafter.c (deleted) * cpukit/rtems/src/timerfirewhen.c (deleted) * cpukit/rtems/src/timerident.c (deleted) * cpukit/rtems/src/timerreset.c (deleted) * cpukit/sapi/Makefile.am (deleted) * cpukit/sapi/include/Makefile.am (deleted) * cpukit/sapi/include/confdefs.h (deleted) * cpukit/sapi/include/rtems/README (deleted) * cpukit/sapi/include/rtems/config.h (deleted) * cpukit/sapi/include/rtems/extension.h (deleted) * cpukit/sapi/include/rtems/fatal.h (deleted) * cpukit/sapi/include/rtems/init.h (deleted) * cpukit/sapi/include/rtems/io.h (deleted) * cpukit/sapi/include/rtems/mptables.h (deleted) * cpukit/sapi/include/rtems/sptables.h.in (deleted) * cpukit/sapi/inline/Makefile.am (deleted) * cpukit/sapi/inline/rtems/extension.inl (deleted) * cpukit/sapi/macros/Makefile.am (deleted) * cpukit/sapi/macros/rtems/extension.inl (deleted) * cpukit/sapi/src/Makefile.am (deleted) * cpukit/sapi/src/debug.c (deleted) * cpukit/sapi/src/exinit.c (deleted) * cpukit/sapi/src/extension.c (deleted) * cpukit/sapi/src/fatal.c (deleted) * cpukit/sapi/src/io.c (deleted) * cpukit/sapi/src/itronapi.c (deleted) * cpukit/sapi/src/posixapi.c (deleted) * cpukit/sapi/src/rtemsapi.c (deleted) * cpukit/score/Makefile.am (deleted) * cpukit/score/cpu/Makefile.am (deleted) * cpukit/score/cpu/a29k/Makefile.am (deleted) * cpukit/score/cpu/a29k/amd.ah (deleted) * cpukit/score/cpu/a29k/asm.h (deleted) * cpukit/score/cpu/a29k/cpu.c (deleted) * cpukit/score/cpu/a29k/cpu_asm.S (deleted) * cpukit/score/cpu/a29k/pswmacro.ah (deleted) * cpukit/score/cpu/a29k/register.ah (deleted) * cpukit/score/cpu/a29k/rtems/score/a29k.h (deleted) * cpukit/score/cpu/a29k/rtems/score/cpu.h (deleted) * cpukit/score/cpu/a29k/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/a29k/rtems/score/types.h (deleted) * cpukit/score/cpu/a29k/sig.S (deleted) * cpukit/score/cpu/hppa1.1/Makefile.am (deleted) * cpukit/score/cpu/hppa1.1/cpu.c (deleted) * cpukit/score/cpu/hppa1.1/cpu_asm.S (deleted) * cpukit/score/cpu/hppa1.1/rtems/score/cpu.h (deleted) * cpukit/score/cpu/hppa1.1/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (deleted) * cpukit/score/cpu/hppa1.1/rtems/score/types.h (deleted) * cpukit/score/cpu/i386/Makefile.am (deleted) * cpukit/score/cpu/i386/asm.h (deleted) * cpukit/score/cpu/i386/cpu.c (deleted) * cpukit/score/cpu/i386/cpu_asm.S (deleted) * cpukit/score/cpu/i386/rtems/asm.h (deleted) * cpukit/score/cpu/i386/rtems/score/cpu.h (deleted) * cpukit/score/cpu/i386/rtems/score/i386.h (deleted) * cpukit/score/cpu/i386/rtems/score/types.h (deleted) * cpukit/score/cpu/i960/Makefile.am (deleted) * cpukit/score/cpu/i960/asm.h (deleted) * cpukit/score/cpu/i960/cpu.c (deleted) * cpukit/score/cpu/i960/cpu_asm.S (deleted) * cpukit/score/cpu/i960/rtems/score/cpu.h (deleted) * cpukit/score/cpu/i960/rtems/score/i960.h (deleted) * cpukit/score/cpu/i960/rtems/score/types.h (deleted) * cpukit/score/cpu/m68k/Makefile.am (deleted) * cpukit/score/cpu/m68k/asm.h (deleted) * cpukit/score/cpu/m68k/cpu.c (deleted) * cpukit/score/cpu/m68k/cpu_asm.S (deleted) * cpukit/score/cpu/m68k/m68302.h (deleted) * cpukit/score/cpu/m68k/m68360.h (deleted) * cpukit/score/cpu/m68k/memcpy.c (deleted) * cpukit/score/cpu/m68k/qsm.h (deleted) * cpukit/score/cpu/m68k/rtems/asm.h (deleted) * cpukit/score/cpu/m68k/rtems/m68k/m68302.h (deleted) * cpukit/score/cpu/m68k/rtems/m68k/m68360.h (deleted) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (deleted) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (deleted) * cpukit/score/cpu/m68k/rtems/score/cpu.h (deleted) * cpukit/score/cpu/m68k/rtems/score/m68k.h (deleted) * cpukit/score/cpu/m68k/rtems/score/types.h (deleted) * cpukit/score/cpu/m68k/sim.h (deleted) * cpukit/score/cpu/mips/Makefile.am (deleted) * cpukit/score/cpu/mips/asm.h (deleted) * cpukit/score/cpu/mips/cpu.c (deleted) * cpukit/score/cpu/mips/cpu_asm.S (deleted) * cpukit/score/cpu/mips/idtcpu.h (deleted) * cpukit/score/cpu/mips/iregdef.h (deleted) * cpukit/score/cpu/mips/rtems/asm.h (deleted) * cpukit/score/cpu/mips/rtems/mips/idtcpu.h (deleted) * cpukit/score/cpu/mips/rtems/mips/iregdef.h (deleted) * cpukit/score/cpu/mips/rtems/score/cpu.h (deleted) * cpukit/score/cpu/mips/rtems/score/mips.h (deleted) * cpukit/score/cpu/mips/rtems/score/types.h (deleted) * cpukit/score/cpu/mips64orion/Makefile.am (deleted) * cpukit/score/cpu/mips64orion/asm.h (deleted) * cpukit/score/cpu/mips64orion/cpu.c (deleted) * cpukit/score/cpu/mips64orion/cpu_asm.S (deleted) * cpukit/score/cpu/mips64orion/cpu_asm.h (deleted) * cpukit/score/cpu/mips64orion/idtcpu.h (deleted) * cpukit/score/cpu/mips64orion/idtmon.h (deleted) * cpukit/score/cpu/mips64orion/iregdef.h (deleted) * cpukit/score/cpu/mips64orion/rtems/score/cpu.h (deleted) * cpukit/score/cpu/mips64orion/rtems/score/mips64orion.h (deleted) * cpukit/score/cpu/mips64orion/rtems/score/types.h (deleted) * cpukit/score/cpu/no_cpu/Makefile.am (deleted) * cpukit/score/cpu/no_cpu/asm.h (deleted) * cpukit/score/cpu/no_cpu/cpu.c (deleted) * cpukit/score/cpu/no_cpu/cpu_asm.c (deleted) * cpukit/score/cpu/no_cpu/rtems/asm.h (deleted) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (deleted) * cpukit/score/cpu/no_cpu/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (deleted) * cpukit/score/cpu/no_cpu/rtems/score/types.h (deleted) * cpukit/score/cpu/powerpc/Makefile.am (deleted) * cpukit/score/cpu/powerpc/asm.h (deleted) * cpukit/score/cpu/powerpc/rtems/asm.h (deleted) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (deleted) * cpukit/score/cpu/powerpc/rtems/score/types.h (deleted) * cpukit/score/cpu/sh/Makefile.am (deleted) * cpukit/score/cpu/sh/asm.h (deleted) * cpukit/score/cpu/sh/cpu.c (deleted) * cpukit/score/cpu/sh/rtems/asm.h (deleted) * cpukit/score/cpu/sh/rtems/score/cpu.h (deleted) * cpukit/score/cpu/sh/rtems/score/sh.h (deleted) * cpukit/score/cpu/sh/rtems/score/sh_io.h (deleted) * cpukit/score/cpu/sh/rtems/score/types.h (deleted) * cpukit/score/cpu/sparc/Makefile.am (deleted) * cpukit/score/cpu/sparc/README (deleted) * cpukit/score/cpu/sparc/asm.h (deleted) * cpukit/score/cpu/sparc/cpu.c (deleted) * cpukit/score/cpu/sparc/cpu_asm.S (deleted) * cpukit/score/cpu/sparc/rtems/asm.h (deleted) * cpukit/score/cpu/sparc/rtems/score/cpu.h (deleted) * cpukit/score/cpu/sparc/rtems/score/sparc.h (deleted) * cpukit/score/cpu/sparc/rtems/score/types.h (deleted) * cpukit/score/cpu/unix/Makefile.am (deleted) * cpukit/score/cpu/unix/cpu.c (deleted) * cpukit/score/cpu/unix/rtems/score/cpu.h (deleted) * cpukit/score/cpu/unix/rtems/score/types.h (deleted) * cpukit/score/cpu/unix/rtems/score/unix.h (deleted) * cpukit/score/include/Makefile.am (deleted) * cpukit/score/include/rtems/debug.h (deleted) * cpukit/score/include/rtems/score/address.h (deleted) * cpukit/score/include/rtems/score/apiext.h (deleted) * cpukit/score/include/rtems/score/bitfield.h (deleted) * cpukit/score/include/rtems/score/chain.h (deleted) * cpukit/score/include/rtems/score/context.h (deleted) * cpukit/score/include/rtems/score/copyrt.h (deleted) * cpukit/score/include/rtems/score/coremsg.h (deleted) * cpukit/score/include/rtems/score/coremutex.h (deleted) * cpukit/score/include/rtems/score/coresem.h (deleted) * cpukit/score/include/rtems/score/heap.h (deleted) * cpukit/score/include/rtems/score/interr.h (deleted) * cpukit/score/include/rtems/score/isr.h (deleted) * cpukit/score/include/rtems/score/mpci.h (deleted) * cpukit/score/include/rtems/score/mppkt.h (deleted) * cpukit/score/include/rtems/score/object.h (deleted) * cpukit/score/include/rtems/score/objectmp.h (deleted) * cpukit/score/include/rtems/score/priority.h (deleted) * cpukit/score/include/rtems/score/stack.h (deleted) * cpukit/score/include/rtems/score/states.h (deleted) * cpukit/score/include/rtems/score/sysstate.h (deleted) * cpukit/score/include/rtems/score/thread.h (deleted) * cpukit/score/include/rtems/score/threadmp.h (deleted) * cpukit/score/include/rtems/score/threadq.h (deleted) * cpukit/score/include/rtems/score/tod.h (deleted) * cpukit/score/include/rtems/score/tqdata.h (deleted) * cpukit/score/include/rtems/score/userext.h (deleted) * cpukit/score/include/rtems/score/watchdog.h (deleted) * cpukit/score/include/rtems/score/wkspace.h (deleted) * cpukit/score/include/rtems/system.h (deleted) * cpukit/score/inline/Makefile.am (deleted) * cpukit/score/inline/rtems/score/address.inl (deleted) * cpukit/score/inline/rtems/score/chain.inl (deleted) * cpukit/score/inline/rtems/score/coremsg.inl (deleted) * cpukit/score/inline/rtems/score/coremutex.inl (deleted) * cpukit/score/inline/rtems/score/coresem.inl (deleted) * cpukit/score/inline/rtems/score/heap.inl (deleted) * cpukit/score/inline/rtems/score/isr.inl (deleted) * cpukit/score/inline/rtems/score/mppkt.inl (deleted) * cpukit/score/inline/rtems/score/object.inl (deleted) * cpukit/score/inline/rtems/score/objectmp.inl (deleted) * cpukit/score/inline/rtems/score/priority.inl (deleted) * cpukit/score/inline/rtems/score/stack.inl (deleted) * cpukit/score/inline/rtems/score/states.inl (deleted) * cpukit/score/inline/rtems/score/sysstate.inl (deleted) * cpukit/score/inline/rtems/score/thread.inl (deleted) * cpukit/score/inline/rtems/score/threadmp.inl (deleted) * cpukit/score/inline/rtems/score/tod.inl (deleted) * cpukit/score/inline/rtems/score/tqdata.inl (deleted) * cpukit/score/inline/rtems/score/userext.inl (deleted) * cpukit/score/inline/rtems/score/watchdog.inl (deleted) * cpukit/score/inline/rtems/score/wkspace.inl (deleted) * cpukit/score/macros/Makefile.am (deleted) * cpukit/score/macros/README (deleted) * cpukit/score/macros/rtems/score/README (deleted) * cpukit/score/macros/rtems/score/address.inl (deleted) * cpukit/score/macros/rtems/score/chain.inl (deleted) * cpukit/score/macros/rtems/score/coremsg.inl (deleted) * cpukit/score/macros/rtems/score/coremutex.inl (deleted) * cpukit/score/macros/rtems/score/coresem.inl (deleted) * cpukit/score/macros/rtems/score/heap.inl (deleted) * cpukit/score/macros/rtems/score/isr.inl (deleted) * cpukit/score/macros/rtems/score/mppkt.inl (deleted) * cpukit/score/macros/rtems/score/object.inl (deleted) * cpukit/score/macros/rtems/score/objectmp.inl (deleted) * cpukit/score/macros/rtems/score/priority.inl (deleted) * cpukit/score/macros/rtems/score/stack.inl (deleted) * cpukit/score/macros/rtems/score/states.inl (deleted) * cpukit/score/macros/rtems/score/sysstate.inl (deleted) * cpukit/score/macros/rtems/score/thread.inl (deleted) * cpukit/score/macros/rtems/score/threadmp.inl (deleted) * cpukit/score/macros/rtems/score/tod.inl (deleted) * cpukit/score/macros/rtems/score/tqdata.inl (deleted) * cpukit/score/macros/rtems/score/userext.inl (deleted) * cpukit/score/macros/rtems/score/watchdog.inl (deleted) * cpukit/score/macros/rtems/score/wkspace.inl (deleted) * cpukit/score/src/Makefile.am (deleted) * cpukit/score/src/Unlimited.txt (deleted) * cpukit/score/src/apiext.c (deleted) * cpukit/score/src/chain.c (deleted) * cpukit/score/src/coremsg.c (deleted) * cpukit/score/src/coremsgbroadcast.c (deleted) * cpukit/score/src/coremsgclose.c (deleted) * cpukit/score/src/coremsgflush.c (deleted) * cpukit/score/src/coremsgflushsupp.c (deleted) * cpukit/score/src/coremsgflushwait.c (deleted) * cpukit/score/src/coremsginsert.c (deleted) * cpukit/score/src/coremsgseize.c (deleted) * cpukit/score/src/coremsgsubmit.c (deleted) * cpukit/score/src/coremutex.c (deleted) * cpukit/score/src/coremutexflush.c (deleted) * cpukit/score/src/coremutexseize.c (deleted) * cpukit/score/src/coremutexsurrender.c (deleted) * cpukit/score/src/coresem.c (deleted) * cpukit/score/src/coresemflush.c (deleted) * cpukit/score/src/coresemseize.c (deleted) * cpukit/score/src/coresemsurrender.c (deleted) * cpukit/score/src/coretod.c (deleted) * cpukit/score/src/coretodset.c (deleted) * cpukit/score/src/coretodtickle.c (deleted) * cpukit/score/src/coretodtoseconds.c (deleted) * cpukit/score/src/coretodvalidate.c (deleted) * cpukit/score/src/heap.c (deleted) * cpukit/score/src/heapallocate.c (deleted) * cpukit/score/src/heapextend.c (deleted) * cpukit/score/src/heapfree.c (deleted) * cpukit/score/src/heapsizeofuserarea.c (deleted) * cpukit/score/src/heapwalk.c (deleted) * cpukit/score/src/interr.c (deleted) * cpukit/score/src/isr.c (deleted) * cpukit/score/src/mpci.c (deleted) * cpukit/score/src/object.c (deleted) * cpukit/score/src/objectallocate.c (deleted) * cpukit/score/src/objectallocatebyindex.c (deleted) * cpukit/score/src/objectclearname.c (deleted) * cpukit/score/src/objectcomparenameraw.c (deleted) * cpukit/score/src/objectcomparenamestring.c (deleted) * cpukit/score/src/objectcopynameraw.c (deleted) * cpukit/score/src/objectcopynamestring.c (deleted) * cpukit/score/src/objectextendinformation.c (deleted) * cpukit/score/src/objectfree.c (deleted) * cpukit/score/src/objectget.c (deleted) * cpukit/score/src/objectgetbyindex.c (deleted) * cpukit/score/src/objectgetnext.c (deleted) * cpukit/score/src/objectinitializeinformation.c (deleted) * cpukit/score/src/objectmp.c (deleted) * cpukit/score/src/objectnametoid.c (deleted) * cpukit/score/src/objectshrinkinformation.c (deleted) * cpukit/score/src/thread.c (deleted) * cpukit/score/src/threadchangepriority.c (deleted) * cpukit/score/src/threadclearstate.c (deleted) * cpukit/score/src/threadclose.c (deleted) * cpukit/score/src/threadcreateidle.c (deleted) * cpukit/score/src/threaddelayended.c (deleted) * cpukit/score/src/threaddispatch.c (deleted) * cpukit/score/src/threadevaluatemode.c (deleted) * cpukit/score/src/threadget.c (deleted) * cpukit/score/src/threadhandler.c (deleted) * cpukit/score/src/threadidlebody.c (deleted) * cpukit/score/src/threadinitialize.c (deleted) * cpukit/score/src/threadloadenv.c (deleted) * cpukit/score/src/threadmp.c (deleted) * cpukit/score/src/threadq.c (deleted) * cpukit/score/src/threadqdequeue.c (deleted) * cpukit/score/src/threadqdequeuefifo.c (deleted) * cpukit/score/src/threadqdequeuepriority.c (deleted) * cpukit/score/src/threadqenqueue.c (deleted) * cpukit/score/src/threadqenqueuefifo.c (deleted) * cpukit/score/src/threadqenqueuepriority.c (deleted) * cpukit/score/src/threadqextract.c (deleted) * cpukit/score/src/threadqextractfifo.c (deleted) * cpukit/score/src/threadqextractpriority.c (deleted) * cpukit/score/src/threadqextractwithproxy.c (deleted) * cpukit/score/src/threadqfirst.c (deleted) * cpukit/score/src/threadqfirstfifo.c (deleted) * cpukit/score/src/threadqfirstpriority.c (deleted) * cpukit/score/src/threadqflush.c (deleted) * cpukit/score/src/threadqtimeout.c (deleted) * cpukit/score/src/threadready.c (deleted) * cpukit/score/src/threadreset.c (deleted) * cpukit/score/src/threadresettimeslice.c (deleted) * cpukit/score/src/threadrestart.c (deleted) * cpukit/score/src/threadresume.c (deleted) * cpukit/score/src/threadrotatequeue.c (deleted) * cpukit/score/src/threadsetpriority.c (deleted) * cpukit/score/src/threadsetstate.c (deleted) * cpukit/score/src/threadsettransient.c (deleted) * cpukit/score/src/threadstackallocate.c (deleted) * cpukit/score/src/threadstackfree.c (deleted) * cpukit/score/src/threadstart.c (deleted) * cpukit/score/src/threadstartmultitasking.c (deleted) * cpukit/score/src/threadsuspend.c (deleted) * cpukit/score/src/threadtickletimeslice.c (deleted) * cpukit/score/src/threadyieldprocessor.c (deleted) * cpukit/score/src/userext.c (deleted) * cpukit/score/src/watchdog.c (deleted) * cpukit/score/src/watchdogadjust.c (deleted) * cpukit/score/src/watchdoginsert.c (deleted) * cpukit/score/src/watchdogremove.c (deleted) * cpukit/score/src/watchdogtickle.c (deleted) * cpukit/score/src/wkspace.c (deleted) * cpukit/wrapup/Makefile.am (deleted) * cpukit/zlib/doc/rfc1950.txt (deleted) * cpukit/zlib/doc/rfc1951.txt (deleted) * cpukit/zlib/doc/rfc1952.txt (deleted) * doc/BAD.html (deleted) * doc/FAQ/FAQ.texi (deleted) * doc/FAQ/Makefile (deleted) * doc/FAQ/basic.t (deleted) * doc/FAQ/bsp.t (deleted) * doc/FAQ/concepts.t (deleted) * doc/FAQ/debug.t (deleted) * doc/FAQ/embeddedinfo.t (deleted) * doc/FAQ/endoftime.t (deleted) * doc/FAQ/entry (deleted) * doc/FAQ/freesw.t (deleted) * doc/FAQ/hwdebugaids.t (deleted) * doc/FAQ/projects.t (deleted) * doc/FAQ/tools.t (deleted) * doc/HELP.html (deleted) * doc/Make.config (deleted) * doc/Makefile (deleted) * doc/README (deleted) * doc/TODO (deleted) * doc/VERSION (deleted) * doc/ada_user/Makefile (deleted) * doc/ada_user/ada_user.texi (deleted) * doc/ada_user/example.texi (deleted) * doc/archgrey.gif (deleted) * doc/bsp_howto/Makefile (deleted) * doc/bsp_howto/adaintr.t (deleted) * doc/bsp_howto/analog.t (deleted) * doc/bsp_howto/bsp_howto.texi (deleted) * doc/bsp_howto/clock.t (deleted) * doc/bsp_howto/console.t (deleted) * doc/bsp_howto/discrete.t (deleted) * doc/bsp_howto/init.t (deleted) * doc/bsp_howto/intro.t (deleted) * doc/bsp_howto/linkcmds.t (deleted) * doc/bsp_howto/makefiles.t (deleted) * doc/bsp_howto/nvmem.t (deleted) * doc/bsp_howto/rtc.t (deleted) * doc/bsp_howto/shmsupp.t (deleted) * doc/bsp_howto/support.t (deleted) * doc/bsp_howto/target.t (deleted) * doc/bsp_howto/timer.t (deleted) * doc/common/cpright.texi (deleted) * doc/common/dvi.gif (deleted) * doc/common/oaronly.jpg (deleted) * doc/common/pdf.gif (deleted) * doc/common/pdf1.gif (deleted) * doc/common/ps.gif (deleted) * doc/common/setup.texi (deleted) * doc/common/timemac.texi (deleted) * doc/common/timetbl.t (deleted) * doc/common/timing.t (deleted) * doc/common/treedef.tex (deleted) * doc/common/up-arrow.gif (deleted) * doc/common/wksheets.t (deleted) * doc/develenv/Makefile (deleted) * doc/develenv/compile.texi (deleted) * doc/develenv/develenv.texi (deleted) * doc/develenv/direct.texi (deleted) * doc/develenv/intro.texi (deleted) * doc/develenv/sample.texi (deleted) * doc/develenv/utils.texi (deleted) * doc/do_docs (deleted) * doc/filesystem/Makefile (deleted) * doc/filesystem/filesystem.texi (deleted) * doc/filesystem/fsrequirements.t (deleted) * doc/filesystem/imfs.t (deleted) * doc/filesystem/init.t (deleted) * doc/filesystem/miniimfs.t (deleted) * doc/filesystem/mounting.t (deleted) * doc/filesystem/patheval.t (deleted) * doc/filesystem/preface.texi (deleted) * doc/filesystem/syscalls.t (deleted) * doc/filesystem/tftp.t (deleted) * doc/gnu_docs/Tool_Doc_Instructions (deleted) * doc/gnu_docs/gen_docs (deleted) * doc/gnu_docs/gnu_footer.html (deleted) * doc/gnu_docs/gnu_header.html (deleted) * doc/gnu_docs/index.html (deleted) * doc/gnu_docs/mk_install_dir (deleted) * doc/gnu_docs/refcard.html (deleted) * doc/gnu_docs/rtems_tools_index.html (deleted) * doc/index.html (deleted) * doc/itron3.0/Makefile (deleted) * doc/itron3.0/config.t (deleted) * doc/itron3.0/eventflags.t (deleted) * doc/itron3.0/fixedblock.t (deleted) * doc/itron3.0/gen_all (deleted) * doc/itron3.0/gen_section (deleted) * doc/itron3.0/gen_status_shell (deleted) * doc/itron3.0/interrupt.t (deleted) * doc/itron3.0/itron.texi (deleted) * doc/itron3.0/mailbox.t (deleted) * doc/itron3.0/memorypool.t (deleted) * doc/itron3.0/msgbuffer.t (deleted) * doc/itron3.0/network.t (deleted) * doc/itron3.0/preface.texi (deleted) * doc/itron3.0/rendezvous.t (deleted) * doc/itron3.0/semaphore.t (deleted) * doc/itron3.0/status.t (deleted) * doc/itron3.0/task.t (deleted) * doc/itron3.0/tasksync.t (deleted) * doc/itron3.0/time.t (deleted) * doc/networking/Makefile (deleted) * doc/networking/PCIreg.eps (deleted) * doc/networking/PCIreg.jpg (deleted) * doc/networking/PCIreg.pdf (deleted) * doc/networking/decdriver.t (deleted) * doc/networking/driver.t (deleted) * doc/networking/networkapp.t (deleted) * doc/networking/networkflow.eps (deleted) * doc/networking/networkflow.jpg (deleted) * doc/networking/networkflow.pdf (deleted) * doc/networking/networkflow.png (deleted) * doc/networking/networking.texi (deleted) * doc/networking/networktasks.t (deleted) * doc/networking/preface.texi (deleted) * doc/networking/recvbd.eps (deleted) * doc/networking/recvbd.jpg (deleted) * doc/networking/recvbd.pdf (deleted) * doc/networking/servers.t (deleted) * doc/networking/testing.t (deleted) * doc/new_chapters/Makefile (deleted) * doc/new_chapters/STATUS (deleted) * doc/new_chapters/TODO (deleted) * doc/new_chapters/adminiface.t (deleted) * doc/new_chapters/base.t (deleted) * doc/new_chapters/confspace.t (deleted) * doc/new_chapters/cpuuse.t (deleted) * doc/new_chapters/dumpcontrol.t (deleted) * doc/new_chapters/error.t (deleted) * doc/new_chapters/eventlog.t (deleted) * doc/new_chapters/gen_section (deleted) * doc/new_chapters/monitor.t (deleted) * doc/new_chapters/new_chapters.texi (deleted) * doc/new_chapters/rtmonuse.t (deleted) * doc/new_chapters/stackchk.t (deleted) * doc/oaronly.jpg (deleted) * doc/porting/Makefile (deleted) * doc/porting/codetuning.t (deleted) * doc/porting/cpuinit.t (deleted) * doc/porting/cpumodels.t (deleted) * doc/porting/developtools.t (deleted) * doc/porting/idlethread.t (deleted) * doc/porting/interrupts.t (deleted) * doc/porting/miscellaneous.t (deleted) * doc/porting/porting.texi (deleted) * doc/porting/preface.texi (deleted) * doc/porting/prioritybitmap.t (deleted) * doc/porting/sourcecode.t (deleted) * doc/porting/taskcontext.t (deleted) * doc/posix1003.1/Makefile (deleted) * doc/posix1003.1/ch01.t (deleted) * doc/posix1003.1/ch02.t (deleted) * doc/posix1003.1/ch03.t (deleted) * doc/posix1003.1/ch04.t (deleted) * doc/posix1003.1/ch05.t (deleted) * doc/posix1003.1/ch06.t (deleted) * doc/posix1003.1/ch07.t (deleted) * doc/posix1003.1/ch08.t (deleted) * doc/posix1003.1/ch09.t (deleted) * doc/posix1003.1/ch10.t (deleted) * doc/posix1003.1/ch11.t (deleted) * doc/posix1003.1/ch12.t (deleted) * doc/posix1003.1/ch13.t (deleted) * doc/posix1003.1/ch14.t (deleted) * doc/posix1003.1/ch15.t (deleted) * doc/posix1003.1/ch16.t (deleted) * doc/posix1003.1/ch17.t (deleted) * doc/posix1003.1/ch18.t (deleted) * doc/posix1003.1/posix1003_1.texi (deleted) * doc/posix1003.1/preface.texi (deleted) * doc/posix1003.1/summarize (deleted) * doc/posix_users/Makefile (deleted) * doc/posix_users/cancel.t (deleted) * doc/posix_users/clock.t (deleted) * doc/posix_users/cond.t (deleted) * doc/posix_users/cspecific.t (deleted) * doc/posix_users/device.t (deleted) * doc/posix_users/files.t (deleted) * doc/posix_users/gen_size_report (deleted) * doc/posix_users/io.t (deleted) * doc/posix_users/key.t (deleted) * doc/posix_users/libc.t (deleted) * doc/posix_users/libm.t (deleted) * doc/posix_users/memorymgmt.t (deleted) * doc/posix_users/message.t (deleted) * doc/posix_users/mutex.t (deleted) * doc/posix_users/posix_users.texi (deleted) * doc/posix_users/preface.texi (deleted) * doc/posix_users/procenv.t (deleted) * doc/posix_users/process.t (deleted) * doc/posix_users/sched.t (deleted) * doc/posix_users/semaphores.t (deleted) * doc/posix_users/signal.t (deleted) * doc/posix_users/status.t (deleted) * doc/posix_users/systemdb.t (deleted) * doc/posix_users/thread.t (deleted) * doc/posix_users/timer.t (deleted) * doc/relnotes/Makefile (deleted) * doc/relnotes/install.texi (deleted) * doc/relnotes/intro.texi (deleted) * doc/relnotes/probrep.texi (deleted) * doc/relnotes/relnotes.texi (deleted) * doc/relnotes/status.texi (deleted) * doc/rgdb_specs/Makefile (deleted) * doc/rgdb_specs/comm.t (deleted) * doc/rgdb_specs/conclusion.t (deleted) * doc/rgdb_specs/daemon.t (deleted) * doc/rgdb_specs/garde.eps (deleted) * doc/rgdb_specs/garde.pdf (deleted) * doc/rgdb_specs/gdbinternals.t (deleted) * doc/rgdb_specs/interfacing.t (deleted) * doc/rgdb_specs/intro.t (deleted) * doc/rgdb_specs/layers.eps (deleted) * doc/rgdb_specs/layers.jpg (deleted) * doc/rgdb_specs/layers.pdf (deleted) * doc/rgdb_specs/objectives.t (deleted) * doc/rgdb_specs/process.eps (deleted) * doc/rgdb_specs/process.jpg (deleted) * doc/rgdb_specs/process.pdf (deleted) * doc/rgdb_specs/revision.t (deleted) * doc/rgdb_specs/rgdb_specs.texi (deleted) * doc/rgdb_specs/seqbreak.eps (deleted) * doc/rgdb_specs/seqbreak.jpg (deleted) * doc/rgdb_specs/seqbreak.pdf (deleted) * doc/rgdb_specs/seqdetach.eps (deleted) * doc/rgdb_specs/seqdetach.jpg (deleted) * doc/rgdb_specs/seqdetach.pdf (deleted) * doc/rgdb_specs/seqinit.eps (deleted) * doc/rgdb_specs/seqinit.jpg (deleted) * doc/rgdb_specs/seqinit.pdf (deleted) * doc/rtems_footer.html (deleted) * doc/rtems_gdb/Makefile (deleted) * doc/rtems_gdb/commands.t (deleted) * doc/rtems_gdb/example.t (deleted) * doc/rtems_gdb/intro.t (deleted) * doc/rtems_gdb/rtems_gdb.texi (deleted) * doc/rtems_gdb/started.t (deleted) * doc/rtems_gdb/swarch.t (deleted) * doc/rtems_gdb/trouble.t (deleted) * doc/rtems_header.html (deleted) * doc/rtems_support.html (deleted) * doc/src2html/Makefile (deleted) * doc/src2html/RTEMS.test (deleted) * doc/started/Makefile (deleted) * doc/started/buildc.t (deleted) * doc/started/buildrt.t (deleted) * doc/started/gdb.t (deleted) * doc/started/intro.t (deleted) * doc/started/nt.t (deleted) * doc/started/pictures/bit_ada.jpg (deleted) * doc/started/pictures/bit_ada.vsd (deleted) * doc/started/pictures/bit_c.jpg (deleted) * doc/started/pictures/bit_c.vsd (deleted) * doc/started/pictures/scfile10.jpg (deleted) * doc/started/pictures/scfile10.vsd (deleted) * doc/started/pictures/scfile11.jpg (deleted) * doc/started/pictures/scfile11.vsd (deleted) * doc/started/pictures/scfile12.jpg (deleted) * doc/started/pictures/scfile12.vsd (deleted) * doc/started/pictures/scfile13.jpg (deleted) * doc/started/pictures/scfile13.vsd (deleted) * doc/started/pictures/scsfile1.jpg (deleted) * doc/started/pictures/scsfile1.vsd (deleted) * doc/started/pictures/scsfile2.jpg (deleted) * doc/started/pictures/scsfile2.vsd (deleted) * doc/started/pictures/scsfile3.jpg (deleted) * doc/started/pictures/scsfile3.vsd (deleted) * doc/started/pictures/scsfile4.jpg (deleted) * doc/started/pictures/scsfile4.vsd (deleted) * doc/started/pictures/scsfile5.jpg (deleted) * doc/started/pictures/scsfile5.vsd (deleted) * doc/started/pictures/scsfile6.jpg (deleted) * doc/started/pictures/scsfile6.vsd (deleted) * doc/started/pictures/scsfile7.jpg (deleted) * doc/started/pictures/scsfile7.vsd (deleted) * doc/started/pictures/scsfile8.jpg (deleted) * doc/started/pictures/scsfile8.vsd (deleted) * doc/started/pictures/scsfile9.jpg (deleted) * doc/started/pictures/scsfile9.vsd (deleted) * doc/started/pictures/sfile12c.jpg (deleted) * doc/started/pictures/sfile12c.vsd (deleted) * doc/started/require.t (deleted) * doc/started/sample.t (deleted) * doc/started/started.texi (deleted) * doc/started/versions.texi (deleted) * doc/started_ada/Makefile (deleted) * doc/started_ada/buildada.t (deleted) * doc/started_ada/buildrt.t (deleted) * doc/started_ada/gdb.t (deleted) * doc/started_ada/intro.t (deleted) * doc/started_ada/require.t (deleted) * doc/started_ada/sample.t (deleted) * doc/started_ada/started_ada.texi (deleted) * doc/started_ada/versions.texi (deleted) * doc/supplements/hppa1_1/Makefile (deleted) * doc/supplements/hppa1_1/SIMHPPA_TIMES (deleted) * doc/supplements/hppa1_1/bsp.t (deleted) * doc/supplements/hppa1_1/callconv.t (deleted) * doc/supplements/hppa1_1/cpumodel.t (deleted) * doc/supplements/hppa1_1/cputable.t (deleted) * doc/supplements/hppa1_1/fatalerr.t (deleted) * doc/supplements/hppa1_1/hppa1_1.texi (deleted) * doc/supplements/hppa1_1/intr_NOTIMES.t (deleted) * doc/supplements/hppa1_1/memmodel.t (deleted) * doc/supplements/hppa1_1/preface.texi (deleted) * doc/supplements/hppa1_1/timeSIMHPPA.t (deleted) * doc/supplements/i386/FORCE386_TIMES (deleted) * doc/supplements/i386/Makefile (deleted) * doc/supplements/i386/bsp.t (deleted) * doc/supplements/i386/callconv.t (deleted) * doc/supplements/i386/cpumodel.t (deleted) * doc/supplements/i386/cputable.t (deleted) * doc/supplements/i386/fatalerr.t (deleted) * doc/supplements/i386/i386.texi (deleted) * doc/supplements/i386/intr_NOTIMES.t (deleted) * doc/supplements/i386/memmodel.t (deleted) * doc/supplements/i386/preface.texi (deleted) * doc/supplements/i386/timeFORCE386.t (deleted) * doc/supplements/i960/CVME961_TIMES (deleted) * doc/supplements/i960/Makefile (deleted) * doc/supplements/i960/bsp.t (deleted) * doc/supplements/i960/callconv.t (deleted) * doc/supplements/i960/cpumodel.t (deleted) * doc/supplements/i960/cputable.t (deleted) * doc/supplements/i960/fatalerr.t (deleted) * doc/supplements/i960/i960.texi (deleted) * doc/supplements/i960/intr_NOTIMES.t (deleted) * doc/supplements/i960/memmodel.t (deleted) * doc/supplements/i960/preface.texi (deleted) * doc/supplements/i960/timeCVME961.t (deleted) * doc/supplements/m68k/MVME136_TIMES (deleted) * doc/supplements/m68k/Makefile (deleted) * doc/supplements/m68k/bsp.t (deleted) * doc/supplements/m68k/callconv.t (deleted) * doc/supplements/m68k/cpumodel.t (deleted) * doc/supplements/m68k/cputable.t (deleted) * doc/supplements/m68k/fatalerr.t (deleted) * doc/supplements/m68k/intr_NOTIMES.t (deleted) * doc/supplements/m68k/m68k.texi (deleted) * doc/supplements/m68k/memmodel.t (deleted) * doc/supplements/m68k/preface.texi (deleted) * doc/supplements/m68k/timeMVME136.t (deleted) * doc/supplements/m68k/timedata.t (deleted) * doc/supplements/mips64orion/BSP_TIMES (deleted) * doc/supplements/mips64orion/Makefile (deleted) * doc/supplements/mips64orion/bsp.t (deleted) * doc/supplements/mips64orion/callconv.t (deleted) * doc/supplements/mips64orion/cpumodel.t (deleted) * doc/supplements/mips64orion/cputable.t (deleted) * doc/supplements/mips64orion/fatalerr.t (deleted) * doc/supplements/mips64orion/intr_NOTIMES.t (deleted) * doc/supplements/mips64orion/memmodel.t (deleted) * doc/supplements/mips64orion/mips64orion.texi (deleted) * doc/supplements/mips64orion/preface.texi (deleted) * doc/supplements/mips64orion/timeBSP.t (deleted) * doc/supplements/powerpc/DMV177_TIMES (deleted) * doc/supplements/powerpc/Makefile (deleted) * doc/supplements/powerpc/PSIM_TIMES (deleted) * doc/supplements/powerpc/bsp.t (deleted) * doc/supplements/powerpc/callconv.t (deleted) * doc/supplements/powerpc/cpumodel.t (deleted) * doc/supplements/powerpc/cputable.t (deleted) * doc/supplements/powerpc/fatalerr.t (deleted) * doc/supplements/powerpc/intr_NOTIMES.t (deleted) * doc/supplements/powerpc/memmodel.t (deleted) * doc/supplements/powerpc/powerpc.texi (deleted) * doc/supplements/powerpc/preface.texi (deleted) * doc/supplements/powerpc/timeDMV177.t (deleted) * doc/supplements/powerpc/timePSIM.t (deleted) * doc/supplements/sh/BSP_TIMES (deleted) * doc/supplements/sh/Makefile (deleted) * doc/supplements/sh/bsp.t (deleted) * doc/supplements/sh/callconv.t (deleted) * doc/supplements/sh/cpumodel.t (deleted) * doc/supplements/sh/cputable.t (deleted) * doc/supplements/sh/fatalerr.t (deleted) * doc/supplements/sh/intr_NOTIMES.t (deleted) * doc/supplements/sh/memmodel.t (deleted) * doc/supplements/sh/preface.texi (deleted) * doc/supplements/sh/sh.texi (deleted) * doc/supplements/sh/timeBSP.t (deleted) * doc/supplements/sparc/ERC32_TIMES (deleted) * doc/supplements/sparc/Makefile (deleted) * doc/supplements/sparc/bsp.t (deleted) * doc/supplements/sparc/callconv.t (deleted) * doc/supplements/sparc/cpumodel.t (deleted) * doc/supplements/sparc/cputable.t (deleted) * doc/supplements/sparc/fatalerr.t (deleted) * doc/supplements/sparc/intr_NOTIMES.t (deleted) * doc/supplements/sparc/memmodel.t (deleted) * doc/supplements/sparc/preface.texi (deleted) * doc/supplements/sparc/sparc.texi (deleted) * doc/supplements/sparc/timeERC32.t (deleted) * doc/supplements/template/BSP_TIMES (deleted) * doc/supplements/template/Makefile (deleted) * doc/supplements/template/bsp.t (deleted) * doc/supplements/template/callconv.t (deleted) * doc/supplements/template/cpumodel.t (deleted) * doc/supplements/template/cputable.t (deleted) * doc/supplements/template/fatalerr.t (deleted) * doc/supplements/template/intr_NOTIMES.t (deleted) * doc/supplements/template/memmodel.t (deleted) * doc/supplements/template/preface.texi (deleted) * doc/supplements/template/template.texi (deleted) * doc/supplements/template/timeBSP.t (deleted) * doc/texinfo/texinfo.tex (deleted) * doc/tools/bmenu/Makefile (deleted) * doc/tools/bmenu/address.h (deleted) * doc/tools/bmenu/address.inl (deleted) * doc/tools/bmenu/base.h (deleted) * doc/tools/bmenu/chain.c (deleted) * doc/tools/bmenu/chain.h (deleted) * doc/tools/bmenu/chain.inl (deleted) * doc/tools/bmenu/isr.h (deleted) * doc/tools/bmenu/main.c (deleted) * doc/tools/bmenu/system.h (deleted) * doc/tools/pdl2texi/Makefile (deleted) * doc/tools/pdl2texi/address.h (deleted) * doc/tools/pdl2texi/address.inl (deleted) * doc/tools/pdl2texi/base.h (deleted) * doc/tools/pdl2texi/chain.c (deleted) * doc/tools/pdl2texi/chain.h (deleted) * doc/tools/pdl2texi/chain.inl (deleted) * doc/tools/pdl2texi/isr.h (deleted) * doc/tools/pdl2texi/main.c (deleted) * doc/tools/pdl2texi/s.d (deleted) * doc/tools/pdl2texi/sample.d (deleted) * doc/tools/pdl2texi/system.h (deleted) * doc/tools/pdl2texi/test_cases/enum.d (deleted) * doc/tools/pdl2texi/test_cases/enumbad.d (deleted) * doc/tools/pdl2texi/test_cases/table.d (deleted) * doc/tools/src2html/Makefile (deleted) * doc/tools/src2html1.4a/Ctags/C.c (deleted) * doc/tools/src2html1.4a/Ctags/Makefile (deleted) * doc/tools/src2html1.4a/Ctags/ctags.1 (deleted) * doc/tools/src2html1.4a/Ctags/ctags.c (deleted) * doc/tools/src2html1.4a/Ctags/ctags.h (deleted) * doc/tools/src2html1.4a/Ctags/fortran.c (deleted) * doc/tools/src2html1.4a/Ctags/lisp.c (deleted) * doc/tools/src2html1.4a/Ctags/print.c (deleted) * doc/tools/src2html1.4a/Ctags/strerror.c (deleted) * doc/tools/src2html1.4a/Ctags/tree.c (deleted) * doc/tools/src2html1.4a/Ctags/yacc.c (deleted) * doc/tools/src2html1.4a/Ctags/z.c (deleted) * doc/tools/src2html1.4a/FreeBSD/FreeBSD.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/FreeBSD.s2h (deleted) * doc/tools/src2html1.4a/FreeBSD/conf.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/ddb.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/i386.i386.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/i386.include.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/i386.isa.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/i386.stand.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/kern.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/net.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/netinet.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/nfs.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/stand.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/sys.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/ufs.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/vm.hdr (deleted) * doc/tools/src2html1.4a/Readme (deleted) * doc/tools/src2html1.4a/ctags-emacs/README (deleted) * doc/tools/src2html1.4a/ctags-emacs/ctags (deleted) * doc/tools/src2html1.4a/ctags-emacs/etags.c-ada-patch (deleted) * doc/tools/src2html1.4a/ctags-wr (deleted) * doc/tools/src2html1.4a/src2html (deleted) * doc/tools/src2html1.4a/src2html.1 (deleted) * doc/tools/src2html1.4a/src2html.cgi (deleted) * doc/tools/texi2www/Makefile (deleted) * doc/tools/texi2www/archive/texi2www-960103.tgz (deleted) * doc/tools/texi2www/dir-arrow.gif (deleted) * doc/tools/texi2www/missing-arrow.gif (deleted) * doc/tools/texi2www/next-arrow.gif (deleted) * doc/tools/texi2www/prev-arrow.gif (deleted) * doc/tools/texi2www/texi2dvi (deleted) * doc/tools/texi2www/texi2www (deleted) * doc/tools/texi2www/texi2www.texi (deleted) * doc/tools/texi2www/up-arrow.gif (deleted) * doc/tools/update (deleted) * doc/tools/word-replace (deleted) * doc/user/Makefile (deleted) * doc/user/bsp.t (deleted) * doc/user/c_user.texi (deleted) * doc/user/clock.t (deleted) * doc/user/concepts.t (deleted) * doc/user/conf.t (deleted) * doc/user/dirstat.texi (deleted) * doc/user/dpmem.t (deleted) * doc/user/event.t (deleted) * doc/user/example.texi (deleted) * doc/user/fatal.t (deleted) * doc/user/glossary.texi (deleted) * doc/user/init.t (deleted) * doc/user/intr.t (deleted) * doc/user/io.t (deleted) * doc/user/mp.t (deleted) * doc/user/msg.t (deleted) * doc/user/overview.t (deleted) * doc/user/part.t (deleted) * doc/user/preface.texi (deleted) * doc/user/region.t (deleted) * doc/user/rtemsarc.gif (deleted) * doc/user/rtemsarc.png (deleted) * doc/user/rtemspie.eps (deleted) * doc/user/rtemspie.gif (deleted) * doc/user/rtemspie.pdf (deleted) * doc/user/rtemspie.png (deleted) * doc/user/rtmon.t (deleted) * doc/user/schedule.t (deleted) * doc/user/sem.t (deleted) * doc/user/signal.t (deleted) * doc/user/states.eps (deleted) * doc/user/states.gif (deleted) * doc/user/states.pdf (deleted) * doc/user/states.png (deleted) * doc/user/task.t (deleted) * doc/user/timer.t (deleted) * doc/user/userext.t (deleted) * testsuites/Makefile.am (deleted) * testsuites/PROBLEMS (deleted) * testsuites/README (deleted) * testsuites/itrontests/Makefile.am (deleted) * testsuites/itrontests/README (deleted) * testsuites/itrontests/itronhello/Makefile.am (deleted) * testsuites/itrontests/itronhello/init.c (deleted) * testsuites/itrontests/itronhello/itronhello.doc (deleted) * testsuites/itrontests/itronhello/itronhello.scn (deleted) * testsuites/itrontests/itronhello/system.h (deleted) * testsuites/itrontests/itronmbf01/Makefile.am (deleted) * testsuites/itrontests/itronmbf01/init.c (deleted) * testsuites/itrontests/itronmbf01/itronmbf01.doc (deleted) * testsuites/itrontests/itronmbf01/itronmbf01.scn (deleted) * testsuites/itrontests/itronmbf01/system.h (deleted) * testsuites/itrontests/itronmbox01/Makefile.am (deleted) * testsuites/itrontests/itronmbox01/init.c (deleted) * testsuites/itrontests/itronmbox01/itronmbox01.doc (deleted) * testsuites/itrontests/itronmbox01/itronmbox01.scn (deleted) * testsuites/itrontests/itronmbox01/system.h (deleted) * testsuites/itrontests/itronsem01/Makefile.am (deleted) * testsuites/itrontests/itronsem01/init.c (deleted) * testsuites/itrontests/itronsem01/itronsem01.doc (deleted) * testsuites/itrontests/itronsem01/itronsem01.scn (deleted) * testsuites/itrontests/itronsem01/system.h (deleted) * testsuites/itrontests/itrontask01/Makefile.am (deleted) * testsuites/itrontests/itrontask01/init.c (deleted) * testsuites/itrontests/itrontask01/itrontask01.doc (deleted) * testsuites/itrontests/itrontask01/itrontask01.scn (deleted) * testsuites/itrontests/itrontask01/system.h (deleted) * testsuites/itrontests/itrontask01/task1.c (deleted) * testsuites/itrontests/itrontask02/Makefile.am (deleted) * testsuites/itrontests/itrontask02/dormant.c (deleted) * testsuites/itrontests/itrontask02/init.c (deleted) * testsuites/itrontests/itrontask02/itrontask02.doc (deleted) * testsuites/itrontests/itrontask02/itrontask02.scn (deleted) * testsuites/itrontests/itrontask02/system.h (deleted) * testsuites/itrontests/itrontask03/Makefile.am (deleted) * testsuites/itrontests/itrontask03/init.c (deleted) * testsuites/itrontests/itrontask03/itrontask03.doc (deleted) * testsuites/itrontests/itrontask03/itrontask03.scn (deleted) * testsuites/itrontests/itrontask03/preempt.c (deleted) * testsuites/itrontests/itrontask03/system.h (deleted) * testsuites/itrontests/itrontask03/task1.c (deleted) * testsuites/itrontests/itrontask03/task2.c (deleted) * testsuites/itrontests/itrontask03/task3.c (deleted) * testsuites/itrontests/itrontask04/Makefile.am (deleted) * testsuites/itrontests/itrontask04/init.c (deleted) * testsuites/itrontests/itrontask04/itrontask04.doc (deleted) * testsuites/itrontests/itrontask04/itrontask04.scn (deleted) * testsuites/itrontests/itrontask04/system.h (deleted) * testsuites/itrontests/itrontask04/task1.c (deleted) * testsuites/itrontests/itrontask04/task2.c (deleted) * testsuites/itrontests/itrontask04/task3.c (deleted) * testsuites/itrontests/itrontests.am (deleted) * testsuites/itrontests/itrontime01/Makefile.am (deleted) * testsuites/itrontests/itrontime01/init.c (deleted) * testsuites/itrontests/itrontime01/itrontime01.doc (deleted) * testsuites/itrontests/itrontime01/itrontime01.scn (deleted) * testsuites/itrontests/itrontime01/system.h (deleted) * testsuites/libtests/Makefile.am (deleted) * testsuites/libtests/README (deleted) * testsuites/libtests/cpuuse/Makefile.am (deleted) * testsuites/libtests/cpuuse/cpuuse.scn (deleted) * testsuites/libtests/cpuuse/init.c (deleted) * testsuites/libtests/cpuuse/system.h (deleted) * testsuites/libtests/cpuuse/task1.c (deleted) * testsuites/libtests/cpuuse/task2.c (deleted) * testsuites/libtests/cpuuse/task3.c (deleted) * testsuites/libtests/cpuuse/tswitch.c (deleted) * testsuites/libtests/libtests.am (deleted) * testsuites/libtests/malloctest/Makefile.am (deleted) * testsuites/libtests/malloctest/init.c (deleted) * testsuites/libtests/malloctest/system.h (deleted) * testsuites/libtests/malloctest/task1.c (deleted) * testsuites/libtests/monitor/Makefile.am (deleted) * testsuites/libtests/monitor/init.c (deleted) * testsuites/libtests/monitor/system.h (deleted) * testsuites/libtests/putenvtest/Makefile.am (deleted) * testsuites/libtests/putenvtest/init.c (deleted) * testsuites/libtests/rtems++/Init.cc (deleted) * testsuites/libtests/rtems++/Makefile.am (deleted) * testsuites/libtests/rtems++/System.h (deleted) * testsuites/libtests/rtems++/Task1.cc (deleted) * testsuites/libtests/rtems++/Task2.cc (deleted) * testsuites/libtests/rtems++/Task3.cc (deleted) * testsuites/libtests/rtems++/rtems++.doc (deleted) * testsuites/libtests/rtems++/rtems++.scn (deleted) * testsuites/libtests/rtmonuse/Makefile.am (deleted) * testsuites/libtests/rtmonuse/getall.c (deleted) * testsuites/libtests/rtmonuse/init.c (deleted) * testsuites/libtests/rtmonuse/rtmonuse.scn (deleted) * testsuites/libtests/rtmonuse/system.h (deleted) * testsuites/libtests/rtmonuse/task1.c (deleted) * testsuites/libtests/stackchk/Makefile.am (deleted) * testsuites/libtests/stackchk/blow.c (deleted) * testsuites/libtests/stackchk/init.c (deleted) * testsuites/libtests/stackchk/stackchk.scn (deleted) * testsuites/libtests/stackchk/system.h (deleted) * testsuites/libtests/stackchk/task1.c (deleted) * testsuites/libtests/termios/Makefile.am (deleted) * testsuites/libtests/termios/README (deleted) * testsuites/libtests/termios/init.c (deleted) * testsuites/mptests/Makefile.am (deleted) * testsuites/mptests/README (deleted) * testsuites/mptests/mp01/Makefile.am (deleted) * testsuites/mptests/mp01/init.c (deleted) * testsuites/mptests/mp01/node1/Makefile.am (deleted) * testsuites/mptests/mp01/node1/mp01.doc (deleted) * testsuites/mptests/mp01/node1/mp01.scn (deleted) * testsuites/mptests/mp01/node2/Makefile.am (deleted) * testsuites/mptests/mp01/node2/mp01.doc (deleted) * testsuites/mptests/mp01/node2/mp01.scn (deleted) * testsuites/mptests/mp01/system.h (deleted) * testsuites/mptests/mp01/task1.c (deleted) * testsuites/mptests/mp02/Makefile.am (deleted) * testsuites/mptests/mp02/init.c (deleted) * testsuites/mptests/mp02/node1/Makefile.am (deleted) * testsuites/mptests/mp02/node1/mp02.doc (deleted) * testsuites/mptests/mp02/node1/mp02.scn (deleted) * testsuites/mptests/mp02/node2/Makefile.am (deleted) * testsuites/mptests/mp02/node2/mp02.doc (deleted) * testsuites/mptests/mp02/node2/mp02.scn (deleted) * testsuites/mptests/mp02/system.h (deleted) * testsuites/mptests/mp02/task1.c (deleted) * testsuites/mptests/mp03/Makefile.am (deleted) * testsuites/mptests/mp03/delay.c (deleted) * testsuites/mptests/mp03/init.c (deleted) * testsuites/mptests/mp03/node1/Makefile.am (deleted) * testsuites/mptests/mp03/node1/mp03.doc (deleted) * testsuites/mptests/mp03/node1/mp03.scn (deleted) * testsuites/mptests/mp03/node2/Makefile.am (deleted) * testsuites/mptests/mp03/node2/mp03.doc (deleted) * testsuites/mptests/mp03/node2/mp03.scn (deleted) * testsuites/mptests/mp03/system.h (deleted) * testsuites/mptests/mp03/task1.c (deleted) * testsuites/mptests/mp04/Makefile.am (deleted) * testsuites/mptests/mp04/init.c (deleted) * testsuites/mptests/mp04/node1/Makefile.am (deleted) * testsuites/mptests/mp04/node1/mp04.doc (deleted) * testsuites/mptests/mp04/node1/mp04.scn (deleted) * testsuites/mptests/mp04/node2/Makefile.am (deleted) * testsuites/mptests/mp04/node2/mp04.doc (deleted) * testsuites/mptests/mp04/node2/mp04.scn (deleted) * testsuites/mptests/mp04/system.h (deleted) * testsuites/mptests/mp04/task1.c (deleted) * testsuites/mptests/mp05/Makefile.am (deleted) * testsuites/mptests/mp05/asr.c (deleted) * testsuites/mptests/mp05/init.c (deleted) * testsuites/mptests/mp05/node1/Makefile.am (deleted) * testsuites/mptests/mp05/node1/mp05.doc (deleted) * testsuites/mptests/mp05/node1/mp05.scn (deleted) * testsuites/mptests/mp05/node2/Makefile.am (deleted) * testsuites/mptests/mp05/node2/mp05.doc (deleted) * testsuites/mptests/mp05/node2/mp05.scn (deleted) * testsuites/mptests/mp05/system.h (deleted) * testsuites/mptests/mp05/task1.c (deleted) * testsuites/mptests/mp06/Makefile.am (deleted) * testsuites/mptests/mp06/init.c (deleted) * testsuites/mptests/mp06/node1/Makefile.am (deleted) * testsuites/mptests/mp06/node1/mp06.doc (deleted) * testsuites/mptests/mp06/node1/mp06.scn (deleted) * testsuites/mptests/mp06/node2/Makefile.am (deleted) * testsuites/mptests/mp06/node2/mp06.doc (deleted) * testsuites/mptests/mp06/node2/mp06.scn (deleted) * testsuites/mptests/mp06/system.h (deleted) * testsuites/mptests/mp06/task1.c (deleted) * testsuites/mptests/mp07/Makefile.am (deleted) * testsuites/mptests/mp07/init.c (deleted) * testsuites/mptests/mp07/node1/Makefile.am (deleted) * testsuites/mptests/mp07/node1/mp07.doc (deleted) * testsuites/mptests/mp07/node1/mp07.scn (deleted) * testsuites/mptests/mp07/node2/Makefile.am (deleted) * testsuites/mptests/mp07/node2/mp07.doc (deleted) * testsuites/mptests/mp07/node2/mp07.scn (deleted) * testsuites/mptests/mp07/system.h (deleted) * testsuites/mptests/mp07/task1.c (deleted) * testsuites/mptests/mp08/Makefile.am (deleted) * testsuites/mptests/mp08/init.c (deleted) * testsuites/mptests/mp08/node1/Makefile.am (deleted) * testsuites/mptests/mp08/node1/mp08.doc (deleted) * testsuites/mptests/mp08/node1/mp08.scn (deleted) * testsuites/mptests/mp08/node2/Makefile.am (deleted) * testsuites/mptests/mp08/node2/mp08.doc (deleted) * testsuites/mptests/mp08/node2/mp08.scn (deleted) * testsuites/mptests/mp08/system.h (deleted) * testsuites/mptests/mp08/task1.c (deleted) * testsuites/mptests/mp09/Makefile.am (deleted) * testsuites/mptests/mp09/init.c (deleted) * testsuites/mptests/mp09/node1/Makefile.am (deleted) * testsuites/mptests/mp09/node1/mp09.doc (deleted) * testsuites/mptests/mp09/node1/mp09.scn (deleted) * testsuites/mptests/mp09/node2/Makefile.am (deleted) * testsuites/mptests/mp09/node2/mp09.doc (deleted) * testsuites/mptests/mp09/node2/mp09.scn (deleted) * testsuites/mptests/mp09/recvmsg.c (deleted) * testsuites/mptests/mp09/sendmsg.c (deleted) * testsuites/mptests/mp09/system.h (deleted) * testsuites/mptests/mp09/task1.c (deleted) * testsuites/mptests/mp10/Makefile.am (deleted) * testsuites/mptests/mp10/init.c (deleted) * testsuites/mptests/mp10/node1/Makefile.am (deleted) * testsuites/mptests/mp10/node1/mp10.doc (deleted) * testsuites/mptests/mp10/node1/mp10.scn (deleted) * testsuites/mptests/mp10/node2/Makefile.am (deleted) * testsuites/mptests/mp10/node2/mp10.doc (deleted) * testsuites/mptests/mp10/node2/mp10.scn (deleted) * testsuites/mptests/mp10/system.h (deleted) * testsuites/mptests/mp10/task1.c (deleted) * testsuites/mptests/mp10/task2.c (deleted) * testsuites/mptests/mp10/task3.c (deleted) * testsuites/mptests/mp11/Makefile.am (deleted) * testsuites/mptests/mp11/init.c (deleted) * testsuites/mptests/mp11/node1/Makefile.am (deleted) * testsuites/mptests/mp11/node1/mp11.doc (deleted) * testsuites/mptests/mp11/node1/mp11.scn (deleted) * testsuites/mptests/mp11/node2/Makefile.am (deleted) * testsuites/mptests/mp11/node2/mp11.doc (deleted) * testsuites/mptests/mp11/node2/mp11.scn (deleted) * testsuites/mptests/mp11/system.h (deleted) * testsuites/mptests/mp12/Makefile.am (deleted) * testsuites/mptests/mp12/init.c (deleted) * testsuites/mptests/mp12/node1/Makefile.am (deleted) * testsuites/mptests/mp12/node1/mp12.doc (deleted) * testsuites/mptests/mp12/node1/mp12.scn (deleted) * testsuites/mptests/mp12/node2/Makefile.am (deleted) * testsuites/mptests/mp12/node2/mp12.doc (deleted) * testsuites/mptests/mp12/node2/mp12.scn (deleted) * testsuites/mptests/mp12/system.h (deleted) * testsuites/mptests/mp13/Makefile.am (deleted) * testsuites/mptests/mp13/init.c (deleted) * testsuites/mptests/mp13/node1/Makefile.am (deleted) * testsuites/mptests/mp13/node1/mp13.doc (deleted) * testsuites/mptests/mp13/node1/mp13.scn (deleted) * testsuites/mptests/mp13/node2/Makefile.am (deleted) * testsuites/mptests/mp13/node2/mp13.doc (deleted) * testsuites/mptests/mp13/node2/mp13.scn (deleted) * testsuites/mptests/mp13/system.h (deleted) * testsuites/mptests/mp13/task1.c (deleted) * testsuites/mptests/mp13/task2.c (deleted) * testsuites/mptests/mp14/Makefile.am (deleted) * testsuites/mptests/mp14/delay.c (deleted) * testsuites/mptests/mp14/evtask1.c (deleted) * testsuites/mptests/mp14/evtmtask.c (deleted) * testsuites/mptests/mp14/exit.c (deleted) * testsuites/mptests/mp14/init.c (deleted) * testsuites/mptests/mp14/msgtask1.c (deleted) * testsuites/mptests/mp14/node1/Makefile.am (deleted) * testsuites/mptests/mp14/node1/mp14.doc (deleted) * testsuites/mptests/mp14/node1/mp14.scn (deleted) * testsuites/mptests/mp14/node2/Makefile.am (deleted) * testsuites/mptests/mp14/node2/mp14.doc (deleted) * testsuites/mptests/mp14/node2/mp14.scn (deleted) * testsuites/mptests/mp14/pttask1.c (deleted) * testsuites/mptests/mp14/smtask1.c (deleted) * testsuites/mptests/mp14/system.h (deleted) * testsuites/mptests/mptests.am (deleted) * testsuites/psxtests/Makefile.am (deleted) * testsuites/psxtests/include/Makefile.am (deleted) * testsuites/psxtests/include/pmacros.h (deleted) * testsuites/psxtests/psx01/Makefile.am (deleted) * testsuites/psxtests/psx01/init.c (deleted) * testsuites/psxtests/psx01/psx01.scn (deleted) * testsuites/psxtests/psx01/system.h (deleted) * testsuites/psxtests/psx01/task.c (deleted) * testsuites/psxtests/psx02/Makefile.am (deleted) * testsuites/psxtests/psx02/init.c (deleted) * testsuites/psxtests/psx02/psx02.scn (deleted) * testsuites/psxtests/psx02/system.h (deleted) * testsuites/psxtests/psx02/task.c (deleted) * testsuites/psxtests/psx03/Makefile.am (deleted) * testsuites/psxtests/psx03/init.c (deleted) * testsuites/psxtests/psx03/psx03.scn (deleted) * testsuites/psxtests/psx03/system.h (deleted) * testsuites/psxtests/psx03/task.c (deleted) * testsuites/psxtests/psx04/Makefile.am (deleted) * testsuites/psxtests/psx04/init.c (deleted) * testsuites/psxtests/psx04/psx04.scn (deleted) * testsuites/psxtests/psx04/system.h (deleted) * testsuites/psxtests/psx04/task1.c (deleted) * testsuites/psxtests/psx04/task2.c (deleted) * testsuites/psxtests/psx04/task3.c (deleted) * testsuites/psxtests/psx05/Makefile.am (deleted) * testsuites/psxtests/psx05/init.c (deleted) * testsuites/psxtests/psx05/psx05.scn (deleted) * testsuites/psxtests/psx05/system.h (deleted) * testsuites/psxtests/psx05/task.c (deleted) * testsuites/psxtests/psx05/task2.c (deleted) * testsuites/psxtests/psx05/task3.c (deleted) * testsuites/psxtests/psx06/Makefile.am (deleted) * testsuites/psxtests/psx06/init.c (deleted) * testsuites/psxtests/psx06/psx06.scn (deleted) * testsuites/psxtests/psx06/system.h (deleted) * testsuites/psxtests/psx06/task.c (deleted) * testsuites/psxtests/psx06/task2.c (deleted) * testsuites/psxtests/psx07/Makefile.am (deleted) * testsuites/psxtests/psx07/init.c (deleted) * testsuites/psxtests/psx07/psx07.scn (deleted) * testsuites/psxtests/psx07/system.h (deleted) * testsuites/psxtests/psx07/task.c (deleted) * testsuites/psxtests/psx08/Makefile.am (deleted) * testsuites/psxtests/psx08/init.c (deleted) * testsuites/psxtests/psx08/psx08.scn (deleted) * testsuites/psxtests/psx08/system.h (deleted) * testsuites/psxtests/psx08/task1.c (deleted) * testsuites/psxtests/psx08/task2.c (deleted) * testsuites/psxtests/psx08/task3.c (deleted) * testsuites/psxtests/psx09/Makefile.am (deleted) * testsuites/psxtests/psx09/init.c (deleted) * testsuites/psxtests/psx09/psx09.scn (deleted) * testsuites/psxtests/psx09/system.h (deleted) * testsuites/psxtests/psx10/Makefile.am (deleted) * testsuites/psxtests/psx10/init.c (deleted) * testsuites/psxtests/psx10/psx10.scn (deleted) * testsuites/psxtests/psx10/system.h (deleted) * testsuites/psxtests/psx10/task.c (deleted) * testsuites/psxtests/psx10/task2.c (deleted) * testsuites/psxtests/psx10/task3.c (deleted) * testsuites/psxtests/psx11/Makefile.am (deleted) * testsuites/psxtests/psx11/init.c (deleted) * testsuites/psxtests/psx11/psx11.scn (deleted) * testsuites/psxtests/psx11/system.h (deleted) * testsuites/psxtests/psx11/task.c (deleted) * testsuites/psxtests/psx12/Makefile.am (deleted) * testsuites/psxtests/psx12/init.c (deleted) * testsuites/psxtests/psx12/psx12.scn (deleted) * testsuites/psxtests/psx12/system.h (deleted) * testsuites/psxtests/psx12/task.c (deleted) * testsuites/psxtests/psx13/Makefile.am (deleted) * testsuites/psxtests/psx13/main.c (deleted) * testsuites/psxtests/psx13/psx13.scn (deleted) * testsuites/psxtests/psx13/test.c (deleted) * testsuites/psxtests/psxcancel/Makefile.am (deleted) * testsuites/psxtests/psxcancel/init.c (deleted) * testsuites/psxtests/psxcancel/psxcancel.scn (deleted) * testsuites/psxtests/psxfile01/Makefile.am (deleted) * testsuites/psxtests/psxfile01/main.c (deleted) * testsuites/psxtests/psxfile01/psxfile01.scn (deleted) * testsuites/psxtests/psxfile01/test.c (deleted) * testsuites/psxtests/psxfile01/test_cat.c (deleted) * testsuites/psxtests/psxfile01/test_extend.c (deleted) * testsuites/psxtests/psxfile01/test_write.c (deleted) * testsuites/psxtests/psxhdrs/Makefile.am (deleted) * testsuites/psxtests/psxhdrs/clock01.c (deleted) * testsuites/psxtests/psxhdrs/clock02.c (deleted) * testsuites/psxtests/psxhdrs/clock03.c (deleted) * testsuites/psxtests/psxhdrs/clock04.c (deleted) * testsuites/psxtests/psxhdrs/clock05.c (deleted) * testsuites/psxtests/psxhdrs/clock06.c (deleted) * testsuites/psxtests/psxhdrs/cond01.c (deleted) * testsuites/psxtests/psxhdrs/cond02.c (deleted) * testsuites/psxtests/psxhdrs/cond03.c (deleted) * testsuites/psxtests/psxhdrs/cond04.c (deleted) * testsuites/psxtests/psxhdrs/cond05.c (deleted) * testsuites/psxtests/psxhdrs/cond06.c (deleted) * testsuites/psxtests/psxhdrs/cond07.c (deleted) * testsuites/psxtests/psxhdrs/cond08.c (deleted) * testsuites/psxtests/psxhdrs/cond09.c (deleted) * testsuites/psxtests/psxhdrs/cond10.c (deleted) * testsuites/psxtests/psxhdrs/key01.c (deleted) * testsuites/psxtests/psxhdrs/key02.c (deleted) * testsuites/psxtests/psxhdrs/key03.c (deleted) * testsuites/psxtests/psxhdrs/key04.c (deleted) * testsuites/psxtests/psxhdrs/mutex01.c (deleted) * testsuites/psxtests/psxhdrs/mutex02.c (deleted) * testsuites/psxtests/psxhdrs/mutex03.c (deleted) * testsuites/psxtests/psxhdrs/mutex04.c (deleted) * testsuites/psxtests/psxhdrs/mutex05.c (deleted) * testsuites/psxtests/psxhdrs/mutex06.c (deleted) * testsuites/psxtests/psxhdrs/mutex07.c (deleted) * testsuites/psxtests/psxhdrs/mutex08.c (deleted) * testsuites/psxtests/psxhdrs/mutex09.c (deleted) * testsuites/psxtests/psxhdrs/mutex10.c (deleted) * testsuites/psxtests/psxhdrs/mutex11.c (deleted) * testsuites/psxtests/psxhdrs/mutex12.c (deleted) * testsuites/psxtests/psxhdrs/mutex13.c (deleted) * testsuites/psxtests/psxhdrs/mutex14.c (deleted) * testsuites/psxtests/psxhdrs/mutex15.c (deleted) * testsuites/psxtests/psxhdrs/mutex16.c (deleted) * testsuites/psxtests/psxhdrs/proc01.c (deleted) * testsuites/psxtests/psxhdrs/proc02.c (deleted) * testsuites/psxtests/psxhdrs/proc03.c (deleted) * testsuites/psxtests/psxhdrs/proc04.c (deleted) * testsuites/psxtests/psxhdrs/proc05.c (deleted) * testsuites/psxtests/psxhdrs/proc06.c (deleted) * testsuites/psxtests/psxhdrs/proc07.c (deleted) * testsuites/psxtests/psxhdrs/proc08.c (deleted) * testsuites/psxtests/psxhdrs/proc09.c (deleted) * testsuites/psxtests/psxhdrs/proc10.c (deleted) * testsuites/psxtests/psxhdrs/proc11.c (deleted) * testsuites/psxtests/psxhdrs/proc12.c (deleted) * testsuites/psxtests/psxhdrs/proc13.c (deleted) * testsuites/psxtests/psxhdrs/proc14.c (deleted) * testsuites/psxtests/psxhdrs/pthread01.c (deleted) * testsuites/psxtests/psxhdrs/pthread02.c (deleted) * testsuites/psxtests/psxhdrs/pthread03.c (deleted) * testsuites/psxtests/psxhdrs/pthread04.c (deleted) * testsuites/psxtests/psxhdrs/pthread05.c (deleted) * testsuites/psxtests/psxhdrs/pthread06.c (deleted) * testsuites/psxtests/psxhdrs/pthread07.c (deleted) * testsuites/psxtests/psxhdrs/pthread08.c (deleted) * testsuites/psxtests/psxhdrs/pthread09.c (deleted) * testsuites/psxtests/psxhdrs/pthread10.c (deleted) * testsuites/psxtests/psxhdrs/pthread11.c (deleted) * testsuites/psxtests/psxhdrs/pthread12.c (deleted) * testsuites/psxtests/psxhdrs/pthread13.c (deleted) * testsuites/psxtests/psxhdrs/pthread14.c (deleted) * testsuites/psxtests/psxhdrs/pthread15.c (deleted) * testsuites/psxtests/psxhdrs/pthread16.c (deleted) * testsuites/psxtests/psxhdrs/pthread17.c (deleted) * testsuites/psxtests/psxhdrs/pthread18.c (deleted) * testsuites/psxtests/psxhdrs/pthread19.c (deleted) * testsuites/psxtests/psxhdrs/pthread20.c (deleted) * testsuites/psxtests/psxhdrs/pthread21.c (deleted) * testsuites/psxtests/psxhdrs/pthread22.c (deleted) * testsuites/psxtests/psxhdrs/pthread23.c (deleted) * testsuites/psxtests/psxhdrs/pthread24.c (deleted) * testsuites/psxtests/psxhdrs/pthread25.c (deleted) * testsuites/psxtests/psxhdrs/pthread26.c (deleted) * testsuites/psxtests/psxhdrs/pthread27.c (deleted) * testsuites/psxtests/psxhdrs/pthread28.c (deleted) * testsuites/psxtests/psxhdrs/pthread29.c (deleted) * testsuites/psxtests/psxhdrs/pthread30.c (deleted) * testsuites/psxtests/psxhdrs/pthread31.c (deleted) * testsuites/psxtests/psxhdrs/pthread32.c (deleted) * testsuites/psxtests/psxhdrs/pthread33.c (deleted) * testsuites/psxtests/psxhdrs/pthread34.c (deleted) * testsuites/psxtests/psxhdrs/pthread35.c (deleted) * testsuites/psxtests/psxhdrs/pthread36.c (deleted) * testsuites/psxtests/psxhdrs/sched01.c (deleted) * testsuites/psxtests/psxhdrs/sched02.c (deleted) * testsuites/psxtests/psxhdrs/sched03.c (deleted) * testsuites/psxtests/psxhdrs/sched04.c (deleted) * testsuites/psxtests/psxhdrs/sched05.c (deleted) * testsuites/psxtests/psxhdrs/sched06.c (deleted) * testsuites/psxtests/psxhdrs/sched07.c (deleted) * testsuites/psxtests/psxhdrs/sched08.c (deleted) * testsuites/psxtests/psxhdrs/signal01.c (deleted) * testsuites/psxtests/psxhdrs/signal02.c (deleted) * testsuites/psxtests/psxhdrs/signal03.c (deleted) * testsuites/psxtests/psxhdrs/signal04.c (deleted) * testsuites/psxtests/psxhdrs/signal05.c (deleted) * testsuites/psxtests/psxhdrs/signal06.c (deleted) * testsuites/psxtests/psxhdrs/signal07.c (deleted) * testsuites/psxtests/psxhdrs/signal08.c (deleted) * testsuites/psxtests/psxhdrs/signal09.c (deleted) * testsuites/psxtests/psxhdrs/signal10.c (deleted) * testsuites/psxtests/psxhdrs/signal11.c (deleted) * testsuites/psxtests/psxhdrs/signal12.c (deleted) * testsuites/psxtests/psxhdrs/signal13.c (deleted) * testsuites/psxtests/psxhdrs/signal14.c (deleted) * testsuites/psxtests/psxhdrs/signal15.c (deleted) * testsuites/psxtests/psxhdrs/signal16.c (deleted) * testsuites/psxtests/psxhdrs/signal17.c (deleted) * testsuites/psxtests/psxhdrs/signal18.c (deleted) * testsuites/psxtests/psxhdrs/signal19.c (deleted) * testsuites/psxtests/psxhdrs/signal20.c (deleted) * testsuites/psxtests/psxhdrs/signal21.c (deleted) * testsuites/psxtests/psxhdrs/signal22.c (deleted) * testsuites/psxtests/psxhdrs/time01.c (deleted) * testsuites/psxtests/psxhdrs/time02.c (deleted) * testsuites/psxtests/psxhdrs/time03.c (deleted) * testsuites/psxtests/psxhdrs/time04.c (deleted) * testsuites/psxtests/psxhdrs/time05.c (deleted) * testsuites/psxtests/psxhdrs/time06.c (deleted) * testsuites/psxtests/psxhdrs/time07.c (deleted) * testsuites/psxtests/psxhdrs/time08.c (deleted) * testsuites/psxtests/psxhdrs/time09.c (deleted) * testsuites/psxtests/psxhdrs/time10.c (deleted) * testsuites/psxtests/psxhdrs/time11.c (deleted) * testsuites/psxtests/psxhdrs/time12.c (deleted) * testsuites/psxtests/psxhdrs/time13.c (deleted) * testsuites/psxtests/psxhdrs/timer01.c (deleted) * testsuites/psxtests/psxhdrs/timer02.c (deleted) * testsuites/psxtests/psxhdrs/timer03.c (deleted) * testsuites/psxtests/psxhdrs/timer04.c (deleted) * testsuites/psxtests/psxhdrs/timer05.c (deleted) * testsuites/psxtests/psxhdrs/timer06.c (deleted) * testsuites/psxtests/psxmount/Makefile.am (deleted) * testsuites/psxtests/psxmount/main.c (deleted) * testsuites/psxtests/psxmount/psxmount.scn (deleted) * testsuites/psxtests/psxmount/test.c (deleted) * testsuites/psxtests/psxmsgq01/Makefile.am (deleted) * testsuites/psxtests/psxmsgq01/init.c (deleted) * testsuites/psxtests/psxmsgq01/psxmsgq01.scn (deleted) * testsuites/psxtests/psxmsgq01/system.h (deleted) * testsuites/psxtests/psxreaddir/Makefile.am (deleted) * testsuites/psxtests/psxreaddir/main.c (deleted) * testsuites/psxtests/psxreaddir/psxreaddir.scn (deleted) * testsuites/psxtests/psxreaddir/test.c (deleted) * testsuites/psxtests/psxsem01/Makefile.am (deleted) * testsuites/psxtests/psxsem01/init.c (deleted) * testsuites/psxtests/psxsem01/psxsem01.scn (deleted) * testsuites/psxtests/psxsem01/system.h (deleted) * testsuites/psxtests/psxstat/Makefile.am (deleted) * testsuites/psxtests/psxstat/main.c (deleted) * testsuites/psxtests/psxstat/psxstat.scn (deleted) * testsuites/psxtests/psxstat/test.c (deleted) * testsuites/psxtests/psxtests.am (deleted) * testsuites/psxtests/psxtime/Makefile.am (deleted) * testsuites/psxtests/psxtime/main.c (deleted) * testsuites/psxtests/psxtime/psxtime.scn (deleted) * testsuites/psxtests/psxtime/test.c (deleted) * testsuites/psxtests/psxtimer/Makefile.am (deleted) * testsuites/psxtests/psxtimer/psxtimer.c (deleted) * testsuites/psxtests/psxtimer/psxtimer.scn (deleted) * testsuites/psxtests/psxtimer/system.h (deleted) * testsuites/samples/Makefile.am (deleted) * testsuites/samples/README (deleted) * testsuites/samples/base_mp/Makefile.am (deleted) * testsuites/samples/base_mp/apptask.c (deleted) * testsuites/samples/base_mp/init.c (deleted) * testsuites/samples/base_mp/node1/Makefile.am (deleted) * testsuites/samples/base_mp/node1/base_mp.doc (deleted) * testsuites/samples/base_mp/node1/base_mp.scn (deleted) * testsuites/samples/base_mp/node2/Makefile.am (deleted) * testsuites/samples/base_mp/node2/base_mp.doc (deleted) * testsuites/samples/base_mp/node2/base_mp.scn (deleted) * testsuites/samples/base_mp/system.h (deleted) * testsuites/samples/base_sp/Makefile.am (deleted) * testsuites/samples/base_sp/apptask.c (deleted) * testsuites/samples/base_sp/base_sp.doc (deleted) * testsuites/samples/base_sp/base_sp.scn (deleted) * testsuites/samples/base_sp/init.c (deleted) * testsuites/samples/base_sp/system.h (deleted) * testsuites/samples/cdtest/Makefile.am (deleted) * testsuites/samples/cdtest/cdtest.scn (deleted) * testsuites/samples/cdtest/init.c (deleted) * testsuites/samples/cdtest/main.cc (deleted) * testsuites/samples/cdtest/system.h (deleted) * testsuites/samples/hello/Makefile.am (deleted) * testsuites/samples/hello/hello.doc (deleted) * testsuites/samples/hello/hello.scn (deleted) * testsuites/samples/hello/init.c (deleted) * testsuites/samples/hello/system.h (deleted) * testsuites/samples/minimum/Makefile.am (deleted) * testsuites/samples/minimum/init.c (deleted) * testsuites/samples/minimum/minimum.doc (deleted) * testsuites/samples/minimum/minimum.scn (deleted) * testsuites/samples/paranoia/Makefile.am (deleted) * testsuites/samples/paranoia/init.c (deleted) * testsuites/samples/paranoia/paranoia.c (deleted) * testsuites/samples/paranoia/paranoia.doc (deleted) * testsuites/samples/paranoia/system.h (deleted) * testsuites/samples/sample.am (deleted) * testsuites/samples/ticker/Makefile.am (deleted) * testsuites/samples/ticker/init.c (deleted) * testsuites/samples/ticker/system.h (deleted) * testsuites/samples/ticker/tasks.c (deleted) * testsuites/samples/ticker/ticker.doc (deleted) * testsuites/samples/ticker/ticker.scn (deleted) * testsuites/samples/unlimited/Makefile.am (deleted) * testsuites/samples/unlimited/init.c (deleted) * testsuites/samples/unlimited/system.h (deleted) * testsuites/samples/unlimited/test1.c (deleted) * testsuites/samples/unlimited/test2.c (deleted) * testsuites/samples/unlimited/test3.c (deleted) * testsuites/samples/unlimited/unlimited.doc (deleted) * testsuites/samples/unlimited/unlimited.scn (deleted) * testsuites/sptests/Makefile.am (deleted) * testsuites/sptests/README (deleted) * testsuites/sptests/sp01/Makefile.am (deleted) * testsuites/sptests/sp01/init.c (deleted) * testsuites/sptests/sp01/sp01.doc (deleted) * testsuites/sptests/sp01/sp01.scn (deleted) * testsuites/sptests/sp01/system.h (deleted) * testsuites/sptests/sp01/task1.c (deleted) * testsuites/sptests/sp02/Makefile.am (deleted) * testsuites/sptests/sp02/init.c (deleted) * testsuites/sptests/sp02/preempt.c (deleted) * testsuites/sptests/sp02/sp02.doc (deleted) * testsuites/sptests/sp02/sp02.scn (deleted) * testsuites/sptests/sp02/system.h (deleted) * testsuites/sptests/sp02/task1.c (deleted) * testsuites/sptests/sp02/task2.c (deleted) * testsuites/sptests/sp02/task3.c (deleted) * testsuites/sptests/sp03/Makefile.am (deleted) * testsuites/sptests/sp03/init.c (deleted) * testsuites/sptests/sp03/sp03.doc (deleted) * testsuites/sptests/sp03/sp03.scn (deleted) * testsuites/sptests/sp03/system.h (deleted) * testsuites/sptests/sp03/task1.c (deleted) * testsuites/sptests/sp03/task2.c (deleted) * testsuites/sptests/sp04/Makefile.am (deleted) * testsuites/sptests/sp04/init.c (deleted) * testsuites/sptests/sp04/sp04.doc (deleted) * testsuites/sptests/sp04/sp04.scn (deleted) * testsuites/sptests/sp04/system.h (deleted) * testsuites/sptests/sp04/task1.c (deleted) * testsuites/sptests/sp04/task2.c (deleted) * testsuites/sptests/sp04/task3.c (deleted) * testsuites/sptests/sp04/tswitch.c (deleted) * testsuites/sptests/sp05/Makefile.am (deleted) * testsuites/sptests/sp05/init.c (deleted) * testsuites/sptests/sp05/sp05.doc (deleted) * testsuites/sptests/sp05/sp05.scn (deleted) * testsuites/sptests/sp05/system.h (deleted) * testsuites/sptests/sp05/task1.c (deleted) * testsuites/sptests/sp05/task2.c (deleted) * testsuites/sptests/sp05/task3.c (deleted) * testsuites/sptests/sp06/Makefile.am (deleted) * testsuites/sptests/sp06/init.c (deleted) * testsuites/sptests/sp06/sp06.doc (deleted) * testsuites/sptests/sp06/sp06.scn (deleted) * testsuites/sptests/sp06/system.h (deleted) * testsuites/sptests/sp06/task1.c (deleted) * testsuites/sptests/sp06/task2.c (deleted) * testsuites/sptests/sp06/task3.c (deleted) * testsuites/sptests/sp07/Makefile.am (deleted) * testsuites/sptests/sp07/init.c (deleted) * testsuites/sptests/sp07/sp07.doc (deleted) * testsuites/sptests/sp07/sp07.scn (deleted) * testsuites/sptests/sp07/system.h (deleted) * testsuites/sptests/sp07/task1.c (deleted) * testsuites/sptests/sp07/task2.c (deleted) * testsuites/sptests/sp07/task3.c (deleted) * testsuites/sptests/sp07/task4.c (deleted) * testsuites/sptests/sp07/taskexit.c (deleted) * testsuites/sptests/sp07/tcreate.c (deleted) * testsuites/sptests/sp07/tdelete.c (deleted) * testsuites/sptests/sp07/trestart.c (deleted) * testsuites/sptests/sp07/tstart.c (deleted) * testsuites/sptests/sp08/Makefile.am (deleted) * testsuites/sptests/sp08/init.c (deleted) * testsuites/sptests/sp08/sp08.doc (deleted) * testsuites/sptests/sp08/sp08.scn (deleted) * testsuites/sptests/sp08/system.h (deleted) * testsuites/sptests/sp08/task1.c (deleted) * testsuites/sptests/sp09/Makefile.am (deleted) * testsuites/sptests/sp09/delay.c (deleted) * testsuites/sptests/sp09/init.c (deleted) * testsuites/sptests/sp09/isr.c (deleted) * testsuites/sptests/sp09/screen01.c (deleted) * testsuites/sptests/sp09/screen02.c (deleted) * testsuites/sptests/sp09/screen03.c (deleted) * testsuites/sptests/sp09/screen04.c (deleted) * testsuites/sptests/sp09/screen05.c (deleted) * testsuites/sptests/sp09/screen06.c (deleted) * testsuites/sptests/sp09/screen07.c (deleted) * testsuites/sptests/sp09/screen08.c (deleted) * testsuites/sptests/sp09/screen09.c (deleted) * testsuites/sptests/sp09/screen10.c (deleted) * testsuites/sptests/sp09/screen11.c (deleted) * testsuites/sptests/sp09/screen12.c (deleted) * testsuites/sptests/sp09/screen13.c (deleted) * testsuites/sptests/sp09/screen14.c (deleted) * testsuites/sptests/sp09/sp09.doc (deleted) * testsuites/sptests/sp09/sp09.scn (deleted) * testsuites/sptests/sp09/system.h (deleted) * testsuites/sptests/sp09/task1.c (deleted) * testsuites/sptests/sp09/task2.c (deleted) * testsuites/sptests/sp09/task3.c (deleted) * testsuites/sptests/sp09/task4.c (deleted) * testsuites/sptests/sp11/Makefile.am (deleted) * testsuites/sptests/sp11/init.c (deleted) * testsuites/sptests/sp11/sp11.doc (deleted) * testsuites/sptests/sp11/sp11.scn (deleted) * testsuites/sptests/sp11/system.h (deleted) * testsuites/sptests/sp11/task1.c (deleted) * testsuites/sptests/sp11/task2.c (deleted) * testsuites/sptests/sp11/timer.c (deleted) * testsuites/sptests/sp12/Makefile.am (deleted) * testsuites/sptests/sp12/init.c (deleted) * testsuites/sptests/sp12/pridrv.c (deleted) * testsuites/sptests/sp12/pritask.c (deleted) * testsuites/sptests/sp12/sp12.doc (deleted) * testsuites/sptests/sp12/sp12.scn (deleted) * testsuites/sptests/sp12/system.h (deleted) * testsuites/sptests/sp12/task1.c (deleted) * testsuites/sptests/sp12/task2.c (deleted) * testsuites/sptests/sp12/task3.c (deleted) * testsuites/sptests/sp12/task4.c (deleted) * testsuites/sptests/sp12/task5.c (deleted) * testsuites/sptests/sp13/Makefile.am (deleted) * testsuites/sptests/sp13/fillbuff.c (deleted) * testsuites/sptests/sp13/init.c (deleted) * testsuites/sptests/sp13/putbuff.c (deleted) * testsuites/sptests/sp13/sp13.doc (deleted) * testsuites/sptests/sp13/sp13.scn (deleted) * testsuites/sptests/sp13/system.h (deleted) * testsuites/sptests/sp13/task1.c (deleted) * testsuites/sptests/sp13/task2.c (deleted) * testsuites/sptests/sp13/task3.c (deleted) * testsuites/sptests/sp14/Makefile.am (deleted) * testsuites/sptests/sp14/asr.c (deleted) * testsuites/sptests/sp14/init.c (deleted) * testsuites/sptests/sp14/sp14.doc (deleted) * testsuites/sptests/sp14/sp14.scn (deleted) * testsuites/sptests/sp14/system.h (deleted) * testsuites/sptests/sp14/task1.c (deleted) * testsuites/sptests/sp14/task2.c (deleted) * testsuites/sptests/sp15/Makefile.am (deleted) * testsuites/sptests/sp15/init.c (deleted) * testsuites/sptests/sp15/sp15.doc (deleted) * testsuites/sptests/sp15/sp15.scn (deleted) * testsuites/sptests/sp15/system.h (deleted) * testsuites/sptests/sp15/task1.c (deleted) * testsuites/sptests/sp16/Makefile.am (deleted) * testsuites/sptests/sp16/init.c (deleted) * testsuites/sptests/sp16/sp16.doc (deleted) * testsuites/sptests/sp16/sp16.scn (deleted) * testsuites/sptests/sp16/system.h (deleted) * testsuites/sptests/sp16/task1.c (deleted) * testsuites/sptests/sp16/task2.c (deleted) * testsuites/sptests/sp16/task3.c (deleted) * testsuites/sptests/sp16/task4.c (deleted) * testsuites/sptests/sp16/task5.c (deleted) * testsuites/sptests/sp17/Makefile.am (deleted) * testsuites/sptests/sp17/asr.c (deleted) * testsuites/sptests/sp17/init.c (deleted) * testsuites/sptests/sp17/sp17.doc (deleted) * testsuites/sptests/sp17/sp17.scn (deleted) * testsuites/sptests/sp17/system.h (deleted) * testsuites/sptests/sp17/task1.c (deleted) * testsuites/sptests/sp17/task2.c (deleted) * testsuites/sptests/sp19/Makefile.am (deleted) * testsuites/sptests/sp19/first.c (deleted) * testsuites/sptests/sp19/fptask.c (deleted) * testsuites/sptests/sp19/fptest.h (deleted) * testsuites/sptests/sp19/init.c (deleted) * testsuites/sptests/sp19/inttest.h (deleted) * testsuites/sptests/sp19/sp19.doc (deleted) * testsuites/sptests/sp19/sp19.scn (deleted) * testsuites/sptests/sp19/system.h (deleted) * testsuites/sptests/sp19/task1.c (deleted) * testsuites/sptests/sp20/Makefile.am (deleted) * testsuites/sptests/sp20/getall.c (deleted) * testsuites/sptests/sp20/init.c (deleted) * testsuites/sptests/sp20/sp20.doc (deleted) * testsuites/sptests/sp20/sp20.scn (deleted) * testsuites/sptests/sp20/system.h (deleted) * testsuites/sptests/sp20/task1.c (deleted) * testsuites/sptests/sp21/Makefile.am (deleted) * testsuites/sptests/sp21/init.c (deleted) * testsuites/sptests/sp21/sp21.doc (deleted) * testsuites/sptests/sp21/sp21.scn (deleted) * testsuites/sptests/sp21/system.h (deleted) * testsuites/sptests/sp21/task1.c (deleted) * testsuites/sptests/sp22/Makefile.am (deleted) * testsuites/sptests/sp22/delay.c (deleted) * testsuites/sptests/sp22/init.c (deleted) * testsuites/sptests/sp22/prtime.c (deleted) * testsuites/sptests/sp22/sp22.doc (deleted) * testsuites/sptests/sp22/sp22.scn (deleted) * testsuites/sptests/sp22/system.h (deleted) * testsuites/sptests/sp22/task1.c (deleted) * testsuites/sptests/sp23/Makefile.am (deleted) * testsuites/sptests/sp23/init.c (deleted) * testsuites/sptests/sp23/sp23.doc (deleted) * testsuites/sptests/sp23/sp23.scn (deleted) * testsuites/sptests/sp23/system.h (deleted) * testsuites/sptests/sp23/task1.c (deleted) * testsuites/sptests/sp24/Makefile.am (deleted) * testsuites/sptests/sp24/init.c (deleted) * testsuites/sptests/sp24/resume.c (deleted) * testsuites/sptests/sp24/sp24.doc (deleted) * testsuites/sptests/sp24/sp24.scn (deleted) * testsuites/sptests/sp24/system.h (deleted) * testsuites/sptests/sp24/task1.c (deleted) * testsuites/sptests/sp25/Makefile.am (deleted) * testsuites/sptests/sp25/init.c (deleted) * testsuites/sptests/sp25/sp25.doc (deleted) * testsuites/sptests/sp25/sp25.scn (deleted) * testsuites/sptests/sp25/system.h (deleted) * testsuites/sptests/sp25/task1.c (deleted) * testsuites/sptests/sp26/Makefile.am (deleted) * testsuites/sptests/sp26/init.c (deleted) * testsuites/sptests/sp26/sp26.doc (deleted) * testsuites/sptests/sp26/sp26.scn (deleted) * testsuites/sptests/sp26/system.h (deleted) * testsuites/sptests/sp26/task1.c (deleted) * testsuites/sptests/sp27/Makefile.am (deleted) * testsuites/sptests/sp27/init.c (deleted) * testsuites/sptests/sp27/sp27.doc (deleted) * testsuites/sptests/sp27/sp27.scn (deleted) * testsuites/sptests/sp28/Makefile.am (deleted) * testsuites/sptests/sp28/init.c (deleted) * testsuites/sptests/sp28/sp28.doc (deleted) * testsuites/sptests/sp28/sp28.scn (deleted) * testsuites/sptests/sp29/Makefile.am (deleted) * testsuites/sptests/sp29/init.c (deleted) * testsuites/sptests/sp29/sp29.doc (deleted) * testsuites/sptests/sp29/sp29.scn (deleted) * testsuites/sptests/spfatal/Makefile.am (deleted) * testsuites/sptests/spfatal/README (deleted) * testsuites/sptests/spfatal/fatal.c (deleted) * testsuites/sptests/spfatal/init.c (deleted) * testsuites/sptests/spfatal/puterr.c (deleted) * testsuites/sptests/spfatal/spfatal.doc (deleted) * testsuites/sptests/spfatal/spfatal.scn (deleted) * testsuites/sptests/spfatal/system.h (deleted) * testsuites/sptests/spfatal/task1.c (deleted) * testsuites/sptests/spsize/Makefile.am (deleted) * testsuites/sptests/spsize/getint.c (deleted) * testsuites/sptests/spsize/init.c (deleted) * testsuites/sptests/spsize/size.c (deleted) * testsuites/sptests/spsize/size.scn (deleted) * testsuites/sptests/spsize/system.h (deleted) * testsuites/sptests/sptests.am (deleted) * testsuites/support/Makefile.am (deleted) * testsuites/support/include/tmacros.h (deleted) * testsuites/tmitrontests/Makefile.am (deleted) * testsuites/tmitrontests/README (deleted) * testsuites/tmitrontests/include/Makefile.am (deleted) * testsuites/tmitrontests/include/timesys.h (deleted) * testsuites/tmitrontests/tmitronsem01/Makefile.am (deleted) * testsuites/tmitrontests/tmitronsem01/init.c (deleted) * testsuites/tmitrontests/tmitronsem01/system.h (deleted) * testsuites/tmitrontests/tmitronsem01/tmitronsem01.doc (deleted) * testsuites/tmitrontests/tmitrontests.am (deleted) * testsuites/tmtests/Makefile.am (deleted) * testsuites/tmtests/README (deleted) * testsuites/tmtests/include/Makefile.am (deleted) * testsuites/tmtests/include/timesys.h (deleted) * testsuites/tmtests/tm01/Makefile.am (deleted) * testsuites/tmtests/tm01/system.h (deleted) * testsuites/tmtests/tm01/task1.c (deleted) * testsuites/tmtests/tm01/tm01.doc (deleted) * testsuites/tmtests/tm02/Makefile.am (deleted) * testsuites/tmtests/tm02/system.h (deleted) * testsuites/tmtests/tm02/task1.c (deleted) * testsuites/tmtests/tm02/tm02.doc (deleted) * testsuites/tmtests/tm03/Makefile.am (deleted) * testsuites/tmtests/tm03/system.h (deleted) * testsuites/tmtests/tm03/task1.c (deleted) * testsuites/tmtests/tm03/tm03.doc (deleted) * testsuites/tmtests/tm04/Makefile.am (deleted) * testsuites/tmtests/tm04/system.h (deleted) * testsuites/tmtests/tm04/task1.c (deleted) * testsuites/tmtests/tm04/tm04.doc (deleted) * testsuites/tmtests/tm05/Makefile.am (deleted) * testsuites/tmtests/tm05/system.h (deleted) * testsuites/tmtests/tm05/task1.c (deleted) * testsuites/tmtests/tm05/tm05.doc (deleted) * testsuites/tmtests/tm06/Makefile.am (deleted) * testsuites/tmtests/tm06/system.h (deleted) * testsuites/tmtests/tm06/task1.c (deleted) * testsuites/tmtests/tm06/tm06.doc (deleted) * testsuites/tmtests/tm07/Makefile.am (deleted) * testsuites/tmtests/tm07/system.h (deleted) * testsuites/tmtests/tm07/task1.c (deleted) * testsuites/tmtests/tm07/tm07.doc (deleted) * testsuites/tmtests/tm08/Makefile.am (deleted) * testsuites/tmtests/tm08/system.h (deleted) * testsuites/tmtests/tm08/task1.c (deleted) * testsuites/tmtests/tm08/tm08.doc (deleted) * testsuites/tmtests/tm09/Makefile.am (deleted) * testsuites/tmtests/tm09/system.h (deleted) * testsuites/tmtests/tm09/task1.c (deleted) * testsuites/tmtests/tm09/tm09.doc (deleted) * testsuites/tmtests/tm10/Makefile.am (deleted) * testsuites/tmtests/tm10/system.h (deleted) * testsuites/tmtests/tm10/task1.c (deleted) * testsuites/tmtests/tm10/tm10.doc (deleted) * testsuites/tmtests/tm11/Makefile.am (deleted) * testsuites/tmtests/tm11/system.h (deleted) * testsuites/tmtests/tm11/task1.c (deleted) * testsuites/tmtests/tm11/tm11.doc (deleted) * testsuites/tmtests/tm12/Makefile.am (deleted) * testsuites/tmtests/tm12/system.h (deleted) * testsuites/tmtests/tm12/task1.c (deleted) * testsuites/tmtests/tm12/tm12.doc (deleted) * testsuites/tmtests/tm13/Makefile.am (deleted) * testsuites/tmtests/tm13/system.h (deleted) * testsuites/tmtests/tm13/task1.c (deleted) * testsuites/tmtests/tm13/tm13.doc (deleted) * testsuites/tmtests/tm14/Makefile.am (deleted) * testsuites/tmtests/tm14/system.h (deleted) * testsuites/tmtests/tm14/task1.c (deleted) * testsuites/tmtests/tm14/tm14.doc (deleted) * testsuites/tmtests/tm15/Makefile.am (deleted) * testsuites/tmtests/tm15/system.h (deleted) * testsuites/tmtests/tm15/task1.c (deleted) * testsuites/tmtests/tm15/tm15.doc (deleted) * testsuites/tmtests/tm16/Makefile.am (deleted) * testsuites/tmtests/tm16/system.h (deleted) * testsuites/tmtests/tm16/task1.c (deleted) * testsuites/tmtests/tm16/tm16.doc (deleted) * testsuites/tmtests/tm17/Makefile.am (deleted) * testsuites/tmtests/tm17/system.h (deleted) * testsuites/tmtests/tm17/task1.c (deleted) * testsuites/tmtests/tm17/tm17.doc (deleted) * testsuites/tmtests/tm18/Makefile.am (deleted) * testsuites/tmtests/tm18/system.h (deleted) * testsuites/tmtests/tm18/task1.c (deleted) * testsuites/tmtests/tm18/tm18.doc (deleted) * testsuites/tmtests/tm19/Makefile.am (deleted) * testsuites/tmtests/tm19/system.h (deleted) * testsuites/tmtests/tm19/task1.c (deleted) * testsuites/tmtests/tm19/tm19.doc (deleted) * testsuites/tmtests/tm20/Makefile.am (deleted) * testsuites/tmtests/tm20/system.h (deleted) * testsuites/tmtests/tm20/task1.c (deleted) * testsuites/tmtests/tm20/tm20.doc (deleted) * testsuites/tmtests/tm21/Makefile.am (deleted) * testsuites/tmtests/tm21/system.h (deleted) * testsuites/tmtests/tm21/task1.c (deleted) * testsuites/tmtests/tm21/tm21.doc (deleted) * testsuites/tmtests/tm22/Makefile.am (deleted) * testsuites/tmtests/tm22/system.h (deleted) * testsuites/tmtests/tm22/task1.c (deleted) * testsuites/tmtests/tm22/tm22.doc (deleted) * testsuites/tmtests/tm23/Makefile.am (deleted) * testsuites/tmtests/tm23/system.h (deleted) * testsuites/tmtests/tm23/task1.c (deleted) * testsuites/tmtests/tm23/tm23.doc (deleted) * testsuites/tmtests/tm24/Makefile.am (deleted) * testsuites/tmtests/tm24/system.h (deleted) * testsuites/tmtests/tm24/task1.c (deleted) * testsuites/tmtests/tm24/tm24.doc (deleted) * testsuites/tmtests/tm25/Makefile.am (deleted) * testsuites/tmtests/tm25/system.h (deleted) * testsuites/tmtests/tm25/task1.c (deleted) * testsuites/tmtests/tm25/tm25.doc (deleted) * testsuites/tmtests/tm26/Makefile.am (deleted) * testsuites/tmtests/tm26/fptest.h (deleted) * testsuites/tmtests/tm26/system.h (deleted) * testsuites/tmtests/tm26/task1.c (deleted) * testsuites/tmtests/tm26/tm26.doc (deleted) * testsuites/tmtests/tm27/Makefile.am (deleted) * testsuites/tmtests/tm27/system.h (deleted) * testsuites/tmtests/tm27/task1.c (deleted) * testsuites/tmtests/tm27/tm27.doc (deleted) * testsuites/tmtests/tm28/Makefile.am (deleted) * testsuites/tmtests/tm28/system.h (deleted) * testsuites/tmtests/tm28/task1.c (deleted) * testsuites/tmtests/tm28/tm28.doc (deleted) * testsuites/tmtests/tm29/Makefile.am (deleted) * testsuites/tmtests/tm29/system.h (deleted) * testsuites/tmtests/tm29/task1.c (deleted) * testsuites/tmtests/tm29/tm29.doc (deleted) * testsuites/tmtests/tmck/Makefile.am (deleted) * testsuites/tmtests/tmck/system.h (deleted) * testsuites/tmtests/tmck/task1.c (deleted) * testsuites/tmtests/tmck/tmck.doc (deleted) * testsuites/tmtests/tmoverhd/Makefile.am (deleted) * testsuites/tmtests/tmoverhd/dumrtems.h (deleted) * testsuites/tmtests/tmoverhd/empty.c (deleted) * testsuites/tmtests/tmoverhd/system.h (deleted) * testsuites/tmtests/tmoverhd/testtask.c (deleted) * testsuites/tmtests/tmoverhd/tmoverhd.doc (deleted) * testsuites/tmtests/tmtests.am (deleted) * testsuites/tools/Makefile.am (deleted) * testsuites/tools/generic/Makefile.am (deleted) * testsuites/tools/generic/difftest.in (deleted) * testsuites/tools/generic/sorttimes.in (deleted) This commit was manufactured by cvs2svn to create branch ... Fri, 11 Feb 2000 15:54:47 GMT Joel Sherrill [562e7ed1] * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/lib/libc/imfs.h (modified) * c/src/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs.h (modified) Increased block size to 128 and added comments based on feedback from ... Fri, 11 Feb 2000 15:21:40 GMT Joel Sherrill [35ece2e] * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) Patch from Eric Norum based on working with Bob ... Fri, 11 Feb 2000 14:12:03 GMT Joel Sherrill [1249edfa] * make/custom/pc386.cfg (modified) Fixed typos introduced in last modification. Spotted by Erwin Rol ... Tue, 08 Feb 2000 22:35:00 GMT Joel Sherrill [fb196c3c] * VERSION (modified) changed version to 4.5.0-beta1a Tue, 08 Feb 2000 22:33:25 GMT Joel Sherrill [70810dc] * aclocal/canonicalize-tools.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/project-root.m4 (modified) * c/configure.in (modified) * c/make/Makefile.am (modified) * c/make/configure.in (modified) * c/src/configure.in (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/bare/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/hppa1.1/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/configure.in (modified) * c/src/lib/libbsp/i386/i386ex/configure.in (modified) * c/src/lib/libbsp/i386/pc386/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (modified) * c/src/lib/libbsp/i960/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/configure.in (modified) * c/src/lib/libbsp/m68k/dmv152/configure.in (modified) * c/src/lib/libbsp/m68k/efi332/configure.in (modified) * c/src/lib/libbsp/m68k/efi68k/configure.in (modified) * c/src/lib/libbsp/m68k/gen68302/configure.in (modified) * c/src/lib/libbsp/m68k/gen68340/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/configure.in (modified) * c/src/lib/libbsp/m68k/mvme136/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/ods68302/configure.in (modified) * c/src/lib/libbsp/mips/configure.in (modified) * c/src/lib/libbsp/mips/p4000/configure.in (modified) * c/src/lib/libbsp/mips64orion/configure.in (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.in (modified) * c/src/lib/libbsp/no_cpu/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/score603e/configure.in (modified) * c/src/lib/libbsp/sh/configure.in (modified) * c/src/lib/libbsp/sh/gensh1/configure.in (modified) * c/src/lib/libbsp/sh/gensh2/configure.in (modified) * c/src/lib/libbsp/sparc/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/unix/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/configure.in (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/configure.in (modified) * c/src/lib/libcpu/hppa1.1/configure.in (modified) * c/src/lib/libcpu/i386/configure.in (modified) * c/src/lib/libcpu/m68k/configure.in (modified) * c/src/lib/libcpu/mips/configure.in (modified) * c/src/lib/libcpu/mips64orion/configure.in (modified) * c/src/lib/libcpu/powerpc/configure.in (modified) * c/src/lib/libcpu/sh/configure.in (modified) * c/src/lib/libcpu/sparc/configure.in (modified) * c/src/libchip/configure.in (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libmisc/configure.in (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/librdbg/configure.in (modified) * c/src/librdbg/include/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librpc/configure.in (modified) * c/src/librtems++/configure.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/lib.cfg (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tools/configure.in (modified) * c/src/tests/tools/generic/configure.in (modified) * configure.in (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/src/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gen68360.cfg (modified) * make/lib.cfg (modified) * scripts-ada/configure.in (modified) * scripts/configure.in (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * tools/build/configure.in (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/configure.in (modified) * tools/update/cipolish (modified) * tools/update/configure.in (modified) Patches rtems-rc-20000204-0.diff from Ralf Corsepius [a976681e] * VERSION (modified) changed version to 4.5.0-beta1 Tue, 08 Feb 2000 18:38:00 GMT Joel Sherrill [e06d5aed] * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) Fixed typo. Tue, 08 Feb 2000 18:36:21 GMT Joel Sherrill [70d27f9] * INSTALL (modified) * README.configure (modified) * SUPPORT (modified) Updated. Tue, 08 Feb 2000 18:26:40 GMT Joel Sherrill [a9d04b1c] * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) Patch from Eric Norum to remove race conditions ... Tue, 08 Feb 2000 15:24:16 GMT Joel Sherrill [b33ab2b] * scripts/configure.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) Patch from David Fiddes to match his Cygwin ... Tue, 08 Feb 2000 14:01:31 GMT Joel Sherrill [c5206d0] * scripts/setup.def (modified) Updated version numbers. Tue, 08 Feb 2000 14:00:45 GMT Joel Sherrill [ee3c9e5] * make/custom/pc386.cfg (modified) Removed references to INSTALL_VARIANT. Mon, 07 Feb 2000 13:56:43 GMT Joel Sherrill [857761b] * Makefile.am (modified) Removed obsolete files from list. Fri, 04 Feb 2000 19:25:57 GMT Joel Sherrill [95d9072] * aclocal/check-files-in.m4 (deleted) * aclocal/check-makefile.m4 (deleted) Obsolete files. Removed per recommendation from Ralf Corsepius ... Fri, 04 Feb 2000 16:32:38 GMT Joel Sherrill [bf24479] * c/src/exec/rtems/src/semtranslatereturncode.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) Incorrect error status returned. Noted by Andrew Klossner ... Fri, 04 Feb 2000 16:09:38 GMT Joel Sherrill [edb2176] * c/src/exec/rtems/src/semtranslatereturncode.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) Incorrect error status returned. Noted by Andrew Klossner ... Fri, 04 Feb 2000 14:58:17 GMT Joel Sherrill [5da4d24] changed version to 20000204 Fri, 04 Feb 2000 14:01:57 GMT Joel Sherrill [3eb6410] * VERSION (modified) changed version to 20000204 Fri, 04 Feb 2000 14:00:43 GMT Joel Sherrill [9d457f5] changed version to 20000118a Thu, 03 Feb 2000 22:20:41 GMT Joel Sherrill [b452a40] * c/src/exec/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semcreate.c (modified) Changed behavior to match that expected by EPICS test code. Reported ... Thu, 03 Feb 2000 13:21:38 GMT Joel Sherrill [4bf1801] * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (added) * c/src/exec/libnetworking/kern/Makefile.am (added) * c/src/exec/libnetworking/lib/Makefile.am (added) * c/src/exec/libnetworking/libc/Makefile.am (added) * c/src/exec/libnetworking/machine/Makefile.am (added) * c/src/exec/libnetworking/net/Makefile.am (added) * c/src/exec/libnetworking/netinet/Makefile.am (added) * c/src/exec/libnetworking/nfs/Makefile.am (added) * c/src/exec/libnetworking/rtems/Makefile.am (added) * c/src/exec/libnetworking/sys/Makefile.am (added) * c/src/exec/libnetworking/vm/Makefile.am (added) * c/src/exec/libnetworking/wrapup/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/arpa/Makefile.am (added) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/include/Makefile.am (added) * c/src/libnetworking/include/Makefile.in (deleted) * c/src/libnetworking/kern/Makefile.am (added) * c/src/libnetworking/kern/Makefile.in (deleted) * c/src/libnetworking/lib/Makefile.am (added) * c/src/libnetworking/lib/Makefile.in (deleted) * c/src/libnetworking/libc/Makefile.am (added) * c/src/libnetworking/libc/Makefile.in (deleted) * c/src/libnetworking/machine/Makefile.am (added) * c/src/libnetworking/net/Makefile.am (added) * c/src/libnetworking/net/Makefile.in (deleted) * c/src/libnetworking/netinet/Makefile.am (added) * c/src/libnetworking/netinet/Makefile.in (deleted) * c/src/libnetworking/nfs/Makefile.am (added) * c/src/libnetworking/nfs/Makefile.in (deleted) * c/src/libnetworking/pppd/Makefile.am (added) * c/src/libnetworking/pppd/Makefile.in (deleted) * c/src/libnetworking/rtems/Makefile.am (added) * c/src/libnetworking/rtems/Makefile.in (deleted) * c/src/libnetworking/rtems_servers/Makefile.am (added) * c/src/libnetworking/rtems_servers/Makefile.in (deleted) * c/src/libnetworking/rtems_webserver/Makefile.am (added) * c/src/libnetworking/rtems_webserver/Makefile.in (deleted) * c/src/libnetworking/sys/Makefile.am (added) * c/src/libnetworking/vm/Makefile.am (added) * c/src/libnetworking/wrapup/Makefile.am (added) * c/src/libnetworking/wrapup/Makefile.in (deleted) * cpukit/ftpd/Makefile.am (added) * cpukit/httpd/Makefile.am (added) * cpukit/httpd/Makefile.in (deleted) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (added) * cpukit/libnetworking/kern/Makefile.am (added) * cpukit/libnetworking/lib/Makefile.am (added) * cpukit/libnetworking/libc/Makefile.am (added) * cpukit/libnetworking/machine/Makefile.am (added) * cpukit/libnetworking/net/Makefile.am (added) * cpukit/libnetworking/netinet/Makefile.am (added) * cpukit/libnetworking/nfs/Makefile.am (added) * cpukit/libnetworking/rtems/Makefile.am (added) * cpukit/libnetworking/sys/Makefile.am (added) * cpukit/libnetworking/vm/Makefile.am (added) * cpukit/libnetworking/wrapup/Makefile.am (added) * cpukit/pppd/Makefile.am (added) Patches rtems-rc-20000118-7.diff from Ralf Corsepius [1382cea3] * c/src/exec/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semcreate.c (modified) Fixed spelling errors. Wed, 02 Feb 2000 15:26:41 GMT Joel Sherrill [399432fa] * c/src/lib/libbsp/bsp.am (modified) * make/custom/mcp750.cfg (modified) Patch rtems-rc-20000118-6.diff from Ralf Corsepius [847dbbe] * c/src/lib/libbsp/Makefile.am (added) * c/src/lib/libbsp/Makefile.in (deleted) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/shmdr/Makefile.am (added) * c/src/lib/libbsp/shmdr/Makefile.in (deleted) * c/src/lib/libcpu/Makefile.am (added) * c/src/lib/libcpu/Makefile.in (deleted) * c/src/lib/libcpu/configure.in (modified) * scripts-ada/configure.in (modified) * scripts/configure.in (modified) * scripts/setup.def (modified) Patches rtems-rc-20000118-5.diff from Ralf Corsepius [8505e9b] * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) Removed references to non-existent include files. Mon, 31 Jan 2000 20:48:14 GMT Joel Sherrill [543452de] * scripts-ada/setup.def (modified) * scripts/setup.def (modified) Changed versions of newlib patch. Mon, 31 Jan 2000 19:28:39 GMT Joel Sherrill [819c7da8] * c/src/librdbg/src/ptrace.c (modified) Spelling corrected. Mon, 31 Jan 2000 19:28:18 GMT Joel Sherrill [bb18b95] * c/src/librdbg/src/ptrace.c (modified) Spelling corrected. Mon, 31 Jan 2000 15:27:02 GMT Joel Sherrill [4e36a2f] * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/mips/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (added) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (deleted) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (added) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (deleted) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (deleted) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (added) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/m68k/shared/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (added) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (deleted) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (added) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (added) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/configure.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (added) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (added) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (added) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (added) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (deleted) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips/clock/Makefile.am (modified) * c/src/lib/libcpu/mips/timer/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librpc/src/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/score/src/Makefile.am (modified) Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from ... Mon, 31 Jan 2000 15:22:23 GMT Joel Sherrill [8fbdf07] * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/base_sp/Makefile.am (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_sp/Makefile.am (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) Patch rtems-rc-20000118-2.diff from Ralf Corsepius [d7269fb] * c/src/lib/libbsp/hppa1.1/simhppa/tools/stamp-h.in (deleted) * tools/build/stamp-h.in (deleted) Ralf Corsepius caught some files in CVS ... Mon, 31 Jan 2000 15:15:10 GMT Joel Sherrill [4c46630] * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/configure.in (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/configure.in (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/configure.in (modified) * c/src/lib/libbsp/i386/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i960/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/m68k/configure.in (modified) * c/src/lib/libbsp/mips/configure.in (modified) * c/src/lib/libbsp/mips64orion/configure.in (modified) * c/src/lib/libbsp/no_cpu/configure.in (modified) * c/src/lib/libbsp/sh/configure.in (modified) * c/src/lib/libbsp/sparc/configure.in (modified) * c/src/lib/libbsp/unix/configure.in (modified) * c/src/lib/libcpu/a29k/clock/ckinit.c (modified) * c/src/lib/libcpu/a29k/clock/clock.h (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/timer.c (modified) * c/src/lib/libcpu/a29k/timer/timerisr.c (modified) * c/src/librpc/configure.in (modified) * c/src/librtems++/configure.in (modified) * make/custom/dmv152.cfg (modified) * make/custom/gensh2.cfg (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) Patch rtems-rc-20000118-1.diff from Ralf Corsepius [d2bc265b] * scripts-ada/README (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts-ada/gnatnewlib/Makefile.am (modified) * scripts-ada/gnatnewlib/gnatnewlib.spec.in (modified) * scripts-ada/setup.def (modified) Successfully built some RPMs. There is still a lot of work to do. Mon, 31 Jan 2000 14:46:38 GMT Joel Sherrill [8030d8a] * scripts/setup.def (modified) Updated versions. Mon, 31 Jan 2000 14:46:23 GMT Joel Sherrill [0261887] * make/custom/portsw.cfg (modified) Modifications from Ralf to be more like other custom files. There ... Mon, 31 Jan 2000 14:45:43 GMT Joel Sherrill [2fabda6] * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) Modification to properly support BSP aliases (pc[456]86). Mon, 31 Jan 2000 14:45:27 GMT Joel Sherrill [71aeab4d] * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) Suggested modification from Rosimildo da Silva ... Mon, 31 Jan 2000 14:43:38 GMT Joel Sherrill [49440a6e] * c/src/lib/libbsp/i386/pc386/configure.in (modified) Added AC_SUBST(RTEMS_BSP) so the makefiles properly honor the BSP ... Mon, 31 Jan 2000 14:42:18 GMT Joel Sherrill [8be7bef] * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) BSP now links although this change is untested. Fri, 28 Jan 2000 15:27:58 GMT Joel Sherrill [c01ba67] * c/src/lib/libbsp/sh/gensh2/README (modified) Patch from John M. Mills to include more ... Fri, 28 Jan 2000 00:02:09 GMT Joel Sherrill [9789cb89] * scripts-ada/binutils/binutils.spec.in (modified) * scripts-ada/gdb/gdb.spec.in (modified) Put Ada scripts in group gnatrtems. Thu, 27 Jan 2000 23:49:44 GMT Joel Sherrill [42ec72d] * scripts/Makefile.am (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/gccnewlib_c_only.spec.in (modified) * scripts/mkbinutils_subpackage_version (deleted) * scripts/mkgnatnewlibspec.in (deleted) * scripts/setup.def (modified) Removed gnat and made final cleanup. Thu, 27 Jan 2000 23:48:50 GMT Joel Sherrill [f82fee9] * scripts/gnatnewlib/Makefile.am (deleted) * scripts/gnatnewlib/gnatnewlib.spec.in (deleted) Patch rtems-rc-20000118-0.diff from Ralf Corsepius [71506054] * scripts-ada/binutils/binutils.spec.in (modified) * scripts-ada/buildall.in (modified) * scripts-ada/configure.in (modified) * scripts-ada/gdb/gdb.spec.in (modified) * scripts-ada/gnatnewlib/gnatnewlib.spec.in (modified) * scripts-ada/mkgdbspec.in (modified) * scripts-ada/mkgnatnewlibspec.in (modified) * scripts-ada/setup (modified) * scripts-ada/setup.def (modified) GNAT/RTEMS RPMs have built for the binutils/gnat/gcc combination and ...
