# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 04:58:21 Tue, 18 Feb 2014 11:42:58 GMT Sebastian Huber [2cb0877] * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) bsp/leon3: Add and use LEON3_IrqCtrl_Lock Disabling of interrupts ... Tue, 18 Feb 2014 12:36:35 GMT Sebastian Huber [8a65a960] * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) score: _SMP_Inter_processor_interrupt_handler() Inline ... Tue, 18 Feb 2014 12:30:28 GMT Sebastian Huber [c4ff027] * cpukit/score/src/smp.c (modified) score: Wait for per-CPU state changes later Wait for per-CPU ... Tue, 18 Feb 2014 12:20:08 GMT Sebastian Huber [b1d08a58] * cpukit/score/src/smp.c (modified) score: Initialize per-CPU locks Tue, 18 Feb 2014 12:03:27 GMT Sebastian Huber [282bfd3] * cpukit/score/src/percpu.c (modified) * cpukit/score/src/smp.c (modified) score: Move _SMP_Handler_initialize() Tue, 18 Feb 2014 10:54:07 GMT Sebastian Huber [a171e0a8] * c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h (modified) bsp/leon3: Declare LEON3_IrqCtrl_EIrq only once Tue, 18 Feb 2014 10:52:48 GMT Sebastian Huber [f71f3d31] * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/eirq.c (modified) bsp/leon3: Declare leon3_ext_irq_init() in header Mon, 17 Feb 2014 14:12:43 GMT Sebastian Huber [4d9bd56] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/bspsmp.h (deleted) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/preinstall.am (modified) * cpukit/score/src/smp.c (modified) score: Rename rtems_smp_process_interrupt() Rename ... Mon, 17 Feb 2014 14:02:54 GMT Sebastian Huber [911b1d2] * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smp.c (modified) score: Rename rtems_smp_secondary_cpu_initialize() Rename ... Mon, 17 Feb 2014 13:56:51 GMT Sebastian Huber [6ca4f6a] * cpukit/sapi/src/exinit.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/smp.c (modified) score: Add and use Collect SMP ... Mon, 17 Feb 2014 13:31:32 GMT Sebastian Huber [f8ff2a0] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/shared/smp/smp_stub.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/src/smp.c (modified) score: Delete bsp_smp_broadcast_interrupt() Since the per-CPU SMP ... Mon, 17 Feb 2014 13:25:29 GMT Sebastian Huber [4627fcd] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/shared/smp/smp_stub.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/bspsmp.h (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/smp.c (modified) score: Rename bsp_smp_initialize() Rename bsp_smp_initialize() into ... Mon, 17 Feb 2014 13:12:21 GMT Sebastian Huber [2afe065] * cpukit/score/include/rtems/score/smp.h (modified) score: Remove ASM guard Mon, 17 Feb 2014 12:58:01 GMT Sebastian Huber [2cb95b5f] * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/src/smp.c (modified) score: Rename RTEMS_BSP_SMP_SHUTDOWN Rename RTEMS_BSP_SMP_SHUTDOWN ... Mon, 17 Feb 2014 12:46:11 GMT Sebastian Huber [9eec2f3] * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/src/smp.c (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Add RTEMS_FATAL_SOURCE_SMP Use rtems_fatal() instead of ... Mon, 17 Feb 2014 10:54:35 GMT Sebastian Huber [46d7fa5] * c/src/lib/libbsp/shared/include/fatal.h (modified) * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) bsp/leon3: Add and use fatal codes Mon, 17 Feb 2014 10:40:18 GMT Sebastian Huber [33cb8bf] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/fb-config.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl111-fb.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/ata-dma-pio-single.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/ata-instance.c (modified) * c/src/lib/libbsp/powerpc/gen5200/ide/ata.c (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/tm27.h (modified) * c/src/lib/libbsp/powerpc/gen5200/mscan/mscan.c (modified) * c/src/lib/libbsp/powerpc/gen5200/slicetimer/slicetimer.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/tod/pcf8563.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-esci.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-generic.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/console/console-linflex.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start-clock.c (modified) * c/src/lib/libbsp/preinstall.am (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shared/console_select.c (modified) * c/src/lib/libbsp/shared/include/fatal.h (added) * c/src/lib/libbsp/shared/include/generic-fatal.h (deleted) * c/src/lib/libbsp/shared/include/irq-generic.h (modified) * c/src/lib/libbsp/shared/src/irq-generic.c (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c (modified) * c/src/lib/libcpu/powerpc/mpc55xx/edma/edma.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * cpukit/sapi/src/fatalsrctext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Add RTEMS_FATAL_SOURCE_BSP Merge ... Mon, 17 Feb 2014 09:17:20 GMT Sebastian Huber [b39e055] * cpukit/sapi/src/exshutdown.c (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal23/Makefile.am (deleted) * testsuites/sptests/spfatal23/spfatal23.doc (deleted) * testsuites/sptests/spfatal23/spfatal23.scn (deleted) * testsuites/sptests/spfatal23/testcase.h (deleted) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) score: Delete INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP This error case ... Mon, 17 Feb 2014 09:10:27 GMT Sebastian Huber [8a6de83] * cpukit/sapi/src/exshutdown.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/smp.h (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/smp.c (modified) score: Move _SMP_Request_other_cores_to_shutdown() Move ... Mon, 17 Feb 2014 08:58:43 GMT Sebastian Huber [38ee758] * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/src/interr.c (modified) score: Disable ISR in _Internal_error_Occurred() Disable interrupts ... Wed, 12 Feb 2014 15:05:35 GMT Sebastian Huber [514705d] * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/exshutdown.c (modified) * cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * testsuites/sptests/spsize/size.c (modified) score: Delete _Thread_BSP_context Do not return to BSP context in ... Mon, 17 Feb 2014 08:47:12 GMT Sebastian Huber [92f50c3] * cpukit/sapi/src/exshutdown.c (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/src/interr.c (modified) * testsuites/libtests/heapwalk/init.c (modified) * testsuites/sptests/spfatal23/testcase.h (modified) score: Add SYSTEM_STATE_TERMINATED Merge systems states ... Mon, 17 Feb 2014 08:23:59 GMT Sebastian Huber [801b5d8] * c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/smp.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_initialize.c (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/vectors.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S (added) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) powerpc: Change interrupt disable implemetation Instead of SPRG0 (= ... Mon, 17 Feb 2014 12:24:55 GMT Sebastian Huber [c2934b96] * cpukit/score/src/isr.c (modified) * cpukit/score/src/percpu.c (modified) score: Move SMP interrupt stack initialization Move SMP interrupt ... Mon, 17 Feb 2014 18:19:06 GMT Jennifer Averett [2729c1c2] * testsuites/smptests/configure.ac (modified) smptests: Add check for affinity support in newlib. Mon, 17 Feb 2014 18:17:26 GMT Jennifer Averett [f38060b] * testsuites/psxtests/configure.ac (modified) psxtests: Correct bug in check of affinity support in newlib. Mon, 17 Feb 2014 18:15:19 GMT Jennifer Averett [57997d8] * cpukit/configure.ac (modified) cpukit: Correct bug in check of affinity support in newlib. Fri, 14 Feb 2014 11:57:53 GMT Sebastian Huber [ad7292f] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/smpbarrier.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/smpbarrierwait.c (added) * testsuites/smptests/smpatomic01/init.c (modified) * testsuites/smptests/smplock01/init.c (modified) score: Add SMP barrier Thu, 13 Feb 2014 14:43:03 GMT Sebastian Huber [0344ce03] * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/preinstall.am (modified) * cpukit/score/cpu/arm/rtems/score/cpusmplock.h (deleted) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/preinstall.am (modified) * cpukit/score/cpu/i386/rtems/score/cpusmplock.h (deleted) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/preinstall.am (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpusmplock.h (deleted) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/preinstall.am (modified) * cpukit/score/cpu/powerpc/rtems/score/cpusmplock.h (deleted) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/preinstall.am (modified) * cpukit/score/cpu/sparc/rtems/score/cpusmplock.h (deleted) * cpukit/score/include/rtems/score/smplock.h (modified) score: Use atomic API for SMP lock Use a ticket lock implementation ... Thu, 13 Feb 2014 14:39:18 GMT Sebastian Huber [7d066fc] * testsuites/smptests/smplock01/init.c (modified) smptests/smplock01: Use atomic operations Fri, 14 Feb 2014 10:18:13 GMT Sebastian Huber [8a9568d2] * cpukit/aclocal/check-atomic.m4 (deleted) * cpukit/configure.ac (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/preinstall.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/preinstall.am (modified) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) Require presence of for SMP support Fri, 14 Feb 2014 11:48:49 GMT Sebastian Huber [dcd97c7] * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/sparcv8-atomic.c (added) sparc: Add atomic support for SPARC V8 Use SWAP instruction with ... Fri, 14 Feb 2014 09:27:04 GMT Sebastian Huber [88ef740e] * c/src/lib/libbsp/sparc/leon3/include/amba.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) bsp/leon3: Declare amba_initialize() Fri, 14 Feb 2014 08:20:08 GMT Sebastian Huber [e644155a] * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) bsp/leon3: Do not define RTEMS_DEBUG Move vital code out of debug ... Thu, 13 Feb 2014 12:00:00 GMT Sebastian Huber [ad56361] * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/smp/getcpuid.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) sparc: Add LEON3_ASR17_PROCESSOR_INDEX_SHIFT Add ... Thu, 13 Feb 2014 14:38:52 GMT Sebastian Huber [945853b7] * cpukit/score/include/rtems/score/atomic.h (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (modified) * testsuites/smptests/smpatomic01/init.c (modified) score: Add Atomic_Uint Thu, 13 Feb 2014 13:28:50 GMT Sebastian Huber [cd2c655] * cpukit/score/include/rtems/score/cpustdatomic.h (modified) score: Fix warnings, C++ compatibility, fix typos Thu, 13 Feb 2014 12:08:46 GMT Sebastian Huber [6f90ef7] * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) score: Remove volatile from asm statements The instructions to get ... Wed, 12 Feb 2014 09:31:38 GMT Sebastian Huber [24bf11e] * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gba/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gp32/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/nds/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/bspstart.c (modified) * c/src/lib/libbsp/shared/cpucounterdiff.c (added) * c/src/lib/libbsp/shared/cpucounterread.c (added) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/cpucounter.c (added) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/counter.h (added) * cpukit/sapi/preinstall.am (modified) * cpukit/sapi/src/cpucounterconverter.c (added) * cpukit/sapi/src/delaynano.c (added) * cpukit/sapi/src/delayticks.c (added) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/Makefile.am (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/Makefile.am (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/Makefile.am (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpucounterread.c (added) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * doc/cpu_supplement/general.t (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spcpucounter01/Makefile.am (added) * testsuites/sptests/spcpucounter01/init.c (added) * testsuites/sptests/spcpucounter01/spcpucounter01.doc (added) * testsuites/sptests/spcpucounter01/spcpucounter01.scn (added) score: Add CPU counter support Add a CPU counter interface to allow ... Thu, 13 Feb 2014 09:04:05 GMT Sebastian Huber [382ea27b] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) bsps/arm: Fix Cortex-A9 MPCore nanoseconds handler Tue, 11 Feb 2014 13:48:35 GMT Sebastian Huber [ece9754] * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Increase CPU_STRUCTURE_ALIGNMENT to 32 Recent LEON4 systems ... Mon, 10 Feb 2014 11:37:26 GMT Sebastian Huber [e11d928] * testsuites/support/include/buffer_test_io.h (modified) testsuites: Add TESTS_USE_PRINTF Make it possible to use normal ... Fri, 07 Feb 2014 08:53:47 GMT Sebastian Huber [bab16de2] * c/src/lib/libbsp/powerpc/shared/startup/panic.c (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/src/statustext.c (moved) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/src/fatalsrctext.c (moved) * cpukit/sapi/src/interrtext.c (moved) * doc/ada_user/example.texi (modified) * doc/user/Makefile.am (modified) * doc/user/dirstat.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * testsuites/psxtests/psxfatal_support/init.c (modified) * testsuites/sptests/spfatal_support/init.c (modified) * testsuites/sptests/spinternalerror02/init.c (modified) score: Change debug helper functions Rename ... Wed, 05 Feb 2014 10:36:05 GMT Sebastian Huber [97cf623d] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) sparc: Save/restore only non-volatile context The ... Tue, 11 Feb 2014 09:08:21 GMT Sebastian Huber [62c5c4a5] * c/src/lib/libbsp/sparc/shared/amba/ambapp_find_by_idx.c (modified) bsps/sparc: Fix ambapp_find_by_idx() The expression "*pi++" ... Mon, 10 Feb 2014 11:21:24 GMT Sebastian Huber [0df8d7f2] * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) bsps/arm: Use Global Timer for Cortex-A9 MPCore Use the Global ... Mon, 10 Feb 2014 11:17:34 GMT Sebastian Huber [069e10c3] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) bsps/arm: Include missing header file Fri, 07 Feb 2014 07:55:02 GMT Sebastian Huber [01794eb] * cpukit/score/include/rtems/score/threadimpl.h (modified) score: Format _Thread_Get_maximum_internal_threads Fri, 07 Feb 2014 08:32:31 GMT Sebastian Huber [847fc79] * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) * c/src/lib/libbsp/sparc/leon3/make/custom/leon3_qemu.cfg (deleted) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds.leon3_qemu (deleted) Revert "bsp/leon3: New BSP variant leon3_qemu" This reverts commit ... Mon, 25 Nov 2013 07:46:19 GMT Sebastian Huber [7579e25] * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/amba/amba.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) * c/src/lib/libbsp/sparc/leon3/make/custom/leon3_qemu.cfg (added) * c/src/lib/libbsp/sparc/leon3/preinstall.am (modified) * c/src/lib/libbsp/sparc/leon3/startup/linkcmds.leon3_qemu (added) bsp/leon3: New BSP variant leon3_qemu Thu, 06 Feb 2014 07:39:51 GMT Sebastian Huber [224b888] * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspstart.c (modified) bsp/leon3: Declare bsp_debug_uart_init() in header Do not return a ... Wed, 05 Feb 2014 16:00:09 GMT Sebastian Huber [920a43e] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/src/statusdesc.c (added) * doc/user/Makefile.am (modified) * doc/user/dirstat.t (moved) * doc/user/example.texi (modified) * testsuites/sptests/spinternalerror02/init.c (modified) * testsuites/sptests/spinternalerror02/spinternalerror02.scn (modified) rtems: Add rtems_status_code_description() Wed, 05 Feb 2014 14:41:00 GMT Sebastian Huber [558cc8d] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/src/threadstartmultitasking.c (modified) score: _CPU_Context_switch_to_first_task_smp() Delete ... Wed, 05 Feb 2014 14:27:22 GMT Sebastian Huber [1c1c2a0] * c/src/lib/libbsp/shared/smp/smp_stub.c (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) bsps: Delete unused bsp_smp_delay() Wed, 05 Feb 2014 14:26:42 GMT Sebastian Huber [36a52ab] * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) bsp/leon3: Avoid magic delays for IPI broadcast Wed, 05 Feb 2014 14:15:51 GMT Sebastian Huber [3d77001] * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) * c/src/lib/libbsp/sparc/shared/start/start.S (modified) bsp/leon3: Fix SMP initialization Avoid usage of the same stack ... Wed, 05 Feb 2014 12:59:07 GMT Sebastian Huber [3ef2d17] * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) bsp/leon3: Install IPI handler early Install inter-processor ... Wed, 05 Feb 2014 12:53:34 GMT Sebastian Huber [d212acb7] * c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c (modified) bsp/leon3: Use printk() only if debug is enabled Wed, 05 Feb 2014 11:54:36 GMT Sebastian Huber [67f2a28] * testsuites/sptests/spsem01/init.c (modified) * testsuites/sptests/spsem02/init.c (modified) sptests/spsem0[12]: Use rtems_test_exit() Wed, 05 Feb 2014 10:01:09 GMT Sebastian Huber [20828099] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) bsps/sparc: Fix comment Tue, 04 Feb 2014 15:48:13 GMT Sebastian Huber [5ff6a9ca] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) bsps/sparc: Remove confusing nop Tue, 04 Feb 2014 15:44:50 GMT Sebastian Huber [f715433] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) bsps/sparc: Order load/store by increasing offsets This may ... Tue, 04 Feb 2014 15:33:45 GMT Sebastian Huber [a54179d2] * c/src/lib/libbsp/sparc/shared/irq_asm.S (modified) bsps/sparc: Fix comments Tue, 26 Nov 2013 08:11:57 GMT Sebastian Huber [1d5d6de] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/leon3/console/printk_support.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) bsp/leon3: Console driver changes Move declaration of global ... Tue, 26 Nov 2013 07:56:08 GMT Sebastian Huber [6fe6d017] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) bsp/leon3: Avoid copy and paste in console driver Tue, 26 Nov 2013 07:47:37 GMT Sebastian Huber [1e744ef] * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) bsp/leon3: Fix interrupt-driven console driver Tue, 28 Jan 2014 11:10:08 GMT Sebastian Huber [022851a] * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/__aeabi_read_tp.c (added) * cpukit/score/cpu/arm/__tls_get_addr.c (added) * cpukit/score/cpu/arm/armv7m-context-initialize.c (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/avr/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/rtems/score/cpu.h (modified) * cpukit/score/cpu/h8300/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32c/context_init.c (modified) * cpukit/score/cpu/m32c/rtems/score/cpu.h (modified) * cpukit/score/cpu/m32r/context_init.c (modified) * cpukit/score/cpu/m32r/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/__m68k_read_tp.c (added) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-context-initialize.c (modified) * cpukit/score/cpu/nios2/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/cpu.c (modified) * cpukit/score/cpu/v850/rtems/score/cpu.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/tls.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/wkspace.c (modified) * doc/cpu_supplement/Makefile.am (modified) * doc/cpu_supplement/arm.t (modified) * doc/cpu_supplement/avr.t (modified) * doc/cpu_supplement/bfin.t (modified) * doc/cpu_supplement/cpu_supplement.texi (modified) * doc/cpu_supplement/general.t (modified) * doc/cpu_supplement/h8300.t (added) * doc/cpu_supplement/i386.t (modified) * doc/cpu_supplement/lm32.t (modified) * doc/cpu_supplement/m32c.t (added) * doc/cpu_supplement/m32r.t (added) * doc/cpu_supplement/m68k.t (modified) * doc/cpu_supplement/microblaze.t (added) * doc/cpu_supplement/mips.t (modified) * doc/cpu_supplement/nios2.t (added) * doc/cpu_supplement/powerpc.t (modified) * doc/cpu_supplement/sh.t (modified) * doc/cpu_supplement/sparc.t (modified) * doc/cpu_supplement/sparc64.t (modified) * doc/cpu_supplement/v850.t (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sptls01/Makefile.am (added) * testsuites/sptests/sptls01/init.c (added) * testsuites/sptests/sptls01/sptls01.doc (added) * testsuites/sptests/sptls01/sptls01.scn (added) * testsuites/sptests/sptls02/Makefile.am (added) * testsuites/sptests/sptls02/init.cc (added) * testsuites/sptests/sptls02/sptls02.doc (added) * testsuites/sptests/sptls02/sptls02.scn (added) Add thread-local storage (TLS) support Tested and implemented on ... Tue, 28 Jan 2014 10:52:17 GMT Sebastian Huber [960fd85] * c/src/lib/libbsp/arm/gba/startup/linkcmds (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/avr/avrtest/startup/linkcmds (modified) * c/src/lib/libbsp/bfin/TLL6527M/startup/linkcmds (modified) * c/src/lib/libbsp/bfin/bf537Stamp/startup/linkcmds (modified) * c/src/lib/libbsp/bfin/eZKit533/startup/linkcmds (modified) * c/src/lib/libbsp/h8300/h8sim/startup/linkcmds (modified) * c/src/lib/libbsp/i386/pc386/startup/linkcmds (modified) * c/src/lib/libbsp/lm32/lm32_evr/startup/linkcmds (modified) * c/src/lib/libbsp/lm32/milkymist/startup/linkcmds (modified) * c/src/lib/libbsp/m32c/m32cbsp/startup/linkcmds (modified) * c/src/lib/libbsp/m32r/m32rsim/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram (modified) * c/src/lib/libbsp/m68k/csb360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/linkcmds.flash (modified) * c/src/lib/libbsp/m68k/mcf52235/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5225x/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/mcf5235/startup/linkcmdsram (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mcf5329/startup/linkcmdsflash (modified) * c/src/lib/libbsp/m68k/mrm332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mrm332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/startup/debugger (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/startup/rom (modified) * c/src/lib/libbsp/m68k/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/m68k/sim68000/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/uC5282/startup/linkcmds (modified) * c/src/lib/libbsp/mips/csb350/startup/linkcmds (modified) * c/src/lib/libbsp/mips/genmongoosev/startup/linkcmds (modified) * c/src/lib/libbsp/mips/hurricane/startup/linkcmds (modified) * c/src/lib/libbsp/mips/jmr3904/startup/linkcmds (modified) * c/src/lib/libbsp/mips/malta/startup/linkcmds (modified) * c/src/lib/libbsp/mips/rbtx4925/startup/linkcmds (modified) * c/src/lib/libbsp/mips/rbtx4938/startup/linkcmds (modified) * c/src/lib/libbsp/moxie/moxiesim/startup/linkcmds (modified) * c/src/lib/libbsp/nios2/nios2_iss/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/beatnik/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/ep1a/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/gen5200/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/qemuppc/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/score603e/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/ss555/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/tqm8xx/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/virtex4/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh1/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.ram (modified) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.rom (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds.rom (modified) * c/src/lib/libbsp/sh/gensh4/startup/linkcmds.rom2ram (modified) * c/src/lib/libbsp/sh/shsim/startup/linkcmds (modified) * c/src/lib/libbsp/sh/shsim/startup/linkcmds.sim (modified) * c/src/lib/libbsp/sparc/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/sparc64/shared/startup/linkcmds (modified) * c/src/lib/libbsp/v850/gdbv850sim/startup/linkcmds (modified) bsps: Thread-local storage (TLS) for linkcmds Wed, 29 Jan 2014 08:29:39 GMT Sebastian Huber [16a41cc] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/thread.c (modified) score: Add _Thread_Get_maximum_internal_threads() Tue, 28 Jan 2014 10:49:57 GMT Sebastian Huber [a49bc35] * cpukit/score/include/rtems/score/heap.h (modified) * testsuites/libtests/malloctest/init.c (modified) * testsuites/libtests/malloctest/malloctest.scn (modified) score: Add _Heap_Size_with_overhead() Tue, 28 Jan 2014 10:32:35 GMT Sebastian Huber [a850d04] * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/sptests/spwkspace/init.c (modified) * testsuites/sptests/spwkspace/spwkspace.doc (modified) * testsuites/sptests/spwkspace/spwkspace.scn (modified) score: Add _Workspace_Allocate_aligned() Mon, 03 Feb 2014 12:52:49 GMT Sebastian Huber [fe535885] * c/src/lib/libbsp/v850/gdbv850sim/startup/linkcmds (modified) bsp/v850: Use proper ABI in linkcmds Fri, 31 Jan 2014 18:28:47 GMT Joel Sherrill [ba386a6] * cpukit/libfs/src/dosfs/fat.c (modified) dosfs/fat.c: Remove use of register keyword Fri, 31 Jan 2014 18:28:02 GMT Joel Sherrill [cfbeaf6] * cpukit/libcsupport/src/calloc.c (modified) calloc.c: Remove use of register keyword Fri, 31 Jan 2014 17:03:24 GMT Joel Sherrill [e633f3b] * cpukit/posix/src/condsignalsupp.c (modified) * cpukit/posix/src/condwaitsupp.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/semclose.c (modified) * cpukit/posix/src/semdestroy.c (modified) * cpukit/posix/src/semgetvalue.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semunlink.c (modified) posix/*.c: Remove use of register keyword Fri, 31 Jan 2014 16:55:17 GMT Joel Sherrill [3a638ce] * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/dpmemdelete.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/regiongetfreeinfo.c (modified) * cpukit/rtems/src/regiongetinfo.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionresizesegment.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) rtems/*.c: Remove use of register keyword Mon, 03 Feb 2014 12:43:21 GMT Sebastian Huber [e1b96b8] * testsuites/libtests/block11/init.c (modified) libtests/block11: Use custom device driver Tue, 28 Jan 2014 03:02:35 GMT Chris Johns [e5d706c] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc702_smp.cfg (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zc706_smp.cfg (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_zedboard_smp.cfg (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.in (moved) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702 (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc702_smp (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706 (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zc706_smp (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_zedboard_smp (deleted) bsp/xilinx_zynq: Support configuraton of memory map. Remove SMP ... Fri, 31 Jan 2014 14:13:05 GMT Joel Sherrill [6dce1621] * c/src/lib/libbsp/shared/bootcard.c (modified) bootcard.c: Comment clean up Thu, 30 Jan 2014 15:01:07 GMT Sebastian Huber [fd49e3f] * c/src/lib/libbsp/sparc/shared/startup/linkcmds.base (modified) bsps/sparc: Fix linkcmds part of new network stack Thu, 30 Jan 2014 09:37:02 GMT Sebastian Huber [bba0e09] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps: Fix barrier section definitions Wed, 29 Jan 2014 08:06:07 GMT Sebastian Huber [6c3517f] * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) bsp/stm32f4: Use BSP_SMALL_MEMORY for a variant Wed, 29 Jan 2014 07:53:01 GMT Sebastian Huber [c26a945] * c/src/lib/libbsp/arm/lpc24xx/startup/fb-config.c (modified) bsp/lpc24xx: Fix compile error Fri, 17 Jan 2014 01:57:08 GMT Nick Withers [f334847b] * c/src/lib/libbsp/powerpc/shared/flash/flash.c (modified) * c/src/lib/libbsp/powerpc/shared/flash/flashPgm.h (modified) * c/src/lib/libbsp/powerpc/shared/flash/flashPgmPvt.h (modified) * c/src/lib/libbsp/powerpc/shared/flash/intelFlash.c (modified) * c/src/lib/libbsp/powerpc/shared/flash/spansionFlash.c (modified) powerpc/flash: give string variables const attribute Thu, 16 Jan 2014 03:21:10 GMT Nick Withers [a7775cb] * c/src/lib/libbsp/powerpc/beatnik/README (modified) * c/src/lib/libbsp/powerpc/mvme3100/README (modified) * c/src/lib/libbsp/powerpc/mvme5500/README.booting (modified) Add warnings to MOTLoad-equipped BSPs' READMEs that a "waitProbe", ... Thu, 23 Jan 2014 14:59:25 GMT Sebastian Huber [e16a7ba] * c/src/libchip/serial/README.ns16550 (modified) libchip/serial: Documentation Thu, 16 Jan 2014 12:05:13 GMT Sebastian Huber [5b34e7a] * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) IMFS: Improved support for generic nodes The ... Thu, 16 Jan 2014 12:02:50 GMT Sebastian Huber [45e82bb8] * cpukit/libfs/src/imfs/imfs_make_generic_node.c (modified) IMFS: Allow sockets as generic nodes Mon, 20 Jan 2014 02:00:35 GMT Nick Withers [a32f996b] * cpukit/libnetworking/lib/syslog.c (modified) Don't use unsafe buffer operations Don't use unsafe buffer ... Sat, 18 Jan 2014 23:42:17 GMT Chris Johns [6e6fd513] * testsuites/psxtests/psx13/test.c (modified) testsuite/psx13: Add linefeed to end of test message. The lack of a ... Tue, 14 Jan 2014 23:34:00 GMT Cynthia Rempel [d7f0533] * c/src/lib/libbsp/sh/gensh1/include/coverhd.h (modified) * c/src/lib/libbsp/sh/gensh2/include/coverhd.h (modified) libbsp sh: Add Doxygen file header to coverhd.h Tue, 14 Jan 2014 23:33:48 GMT Cynthia Rempel [279d83d3] * c/src/lib/libbsp/powerpc/haleakala/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/psim/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/tqm8xx/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/virtex4/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/virtex5/include/coverhd.h (modified) libbsp powerpc: Add Doxygen file header to coverhd.h Tue, 14 Jan 2014 23:33:33 GMT Cynthia Rempel [d5d1fae] * c/src/lib/libbsp/mips/hurricane/include/coverhd.h (modified) libbsp mips: Add Doxygen file header to coverhd.h Tue, 14 Jan 2014 23:33:04 GMT Cynthia Rempel [f6866007] * c/src/lib/libbsp/m68k/mcf5206elite/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/coverhd.h (modified) libbsp m68k: Add Doxygen file header to coverhd.h Tue, 14 Jan 2014 13:40:07 GMT Aleksandr Platonov [fc6a0ae] * c/src/lib/libcpu/shared/src/cache_manager.c (modified) rtems_cache_invalidate_multiple_instruction_lines According with ... Tue, 14 Jan 2014 08:43:53 GMT Sebastian Huber [3a7f588] * c/src/lib/libbsp/arm/shared/start/start.S (modified) bsps/arm: Use _ARMV4_Exception_interrupt This allows read-only ... Wed, 18 Dec 2013 10:47:07 GMT Sebastian Huber [eba0626] * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Use Normal memory for code and data Mon, 13 Jan 2014 12:18:26 GMT Sebastian Huber [4ec210fe] * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/arm/shared/include/start.h (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Use ALIGN_WITH_INPUT The ALIGN_WITH_INPUT helps to make ... Wed, 01 Jan 2014 18:42:55 GMT Sebastian Huber [8fdf4e57] * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/fb-config.c (added) bsp/lpc24xx: Add PL111 support Wed, 01 Jan 2014 18:42:15 GMT Sebastian Huber [3e75900] * c/src/lib/libbsp/arm/lpc24xx/include/lpc17xx.h (modified) bsp/lpc24xx: Add register definition
