# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/16/24 02:14:14 Wed, 03 Mar 2021 20:52:30 GMT Ryan Long [1f29ee4] * bsps/shared/grlib/can/satcan.c (modified) satcan.c: Fix Unsigned compared against 0 (CID #1399768) CID ... Tue, 02 Mar 2021 18:25:53 GMT Ryan Long [f8047788] * bsps/sparc/shared/pci/gr_cpci_gr740.c (modified) gr_cpci_gr740.c: Unchecked return value from library (CID #1437630) ... Tue, 02 Mar 2021 18:17:15 GMT Ryan Long [5f0a7ceb] * bsps/shared/grlib/pci/gr_tmtc_1553.c (modified) gr_tmtc_1553.c: Unchecked return value from library (CID #1399785) ... Tue, 02 Mar 2021 18:10:59 GMT Ryan Long [4c0d9c5a] * bsps/shared/grlib/pci/gr_701.c (modified) gr_701.c: Unchecked return value from library (CID #1399783) CID ... Tue, 02 Mar 2021 18:08:37 GMT Ryan Long [91e38f8] * bsps/shared/grlib/pci/gr_rasta_adcdac.c (modified) gr_rasta_adcdac.c: Fix Unchecked return value from library (CID ... Tue, 02 Mar 2021 18:05:57 GMT Ryan Long [17d525b5] * bsps/shared/grlib/pci/gr_rasta_tmtc.c (modified) gr_rasta_tmtc.c: Fix Unchecked return value from library (CID ... Tue, 02 Mar 2021 18:01:43 GMT Ryan Long [570b558] * bsps/sparc/shared/pci/gr_leon4_n2x.c (modified) gr_leon4_n2x.c: Fix Unchecked return value from library (CID ... Mon, 01 Mar 2021 21:33:10 GMT Ryan Long [0d33d10] * cpukit/libpci/pci_cfg_read.c (modified) pci_cfg_read.c: Fix Missing break in switch (CID #1399723) CID ... Tue, 02 Mar 2021 17:50:59 GMT Ryan Long [b84ce61] * bsps/shared/grlib/pci/gr_rasta_io.c (modified) gr_rasta_io.c: Fix Unchecked return value from library (CID #1399763) ... Tue, 02 Mar 2021 17:40:36 GMT Ryan Long [04436013] * bsps/shared/grlib/pci/gr_rasta_spw_router.c (modified) gr_rasta_spw_router.c: Fix Unchecked return value from library (CID ... Mon, 01 Mar 2021 21:06:41 GMT Ryan Long [c7eb89f8] * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) cpuusagetop.c: Fix three Missing break in switch Coverity errors ... Mon, 01 Mar 2021 20:33:06 GMT Ryan Long [13d6fae] * bsps/shared/grlib/tmtc/grtc.c (modified) grtc.c: Fix four Missing break in switch Coverity errors CID ... Mon, 01 Mar 2021 16:06:48 GMT Ryan Long [1eaf4e46] * bsps/shared/grlib/spw/grspw.c (modified) grspw.c: Fix Unchecked return value (CID #1399781) CID 1399781: ... Mon, 22 Feb 2021 15:39:59 GMT Jan Sommer [6ebf376b] * bsps/shared/dev/serial/zynq-uart.c (modified) bsps/shared: Allow setting baud rate for zynq uart Sat, 20 Feb 2021 03:29:27 GMT Kinsey Moore [f662420] * spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml (modified) spec/aarch64: Rename ZynqMP QEMU BSPs The current ZynqMP BSPs don't ... Fri, 08 Jan 2021 16:13:42 GMT Kinsey Moore [a27ba3f] * bsps/aarch64/shared/start/start.S (modified) bsps/aarch64: Add support for EL2 start Add the stub necessary to ... Mon, 15 Feb 2021 15:05:10 GMT Kinsey Moore [9951cee] * bsps/aarch64/shared/start/start.S (modified) * cpukit/score/cpu/aarch64/aarch64-exception-default.S (modified) bsps/aarch64: RTEMS_DEBUG stack alignment faults Run with stack ... Fri, 08 Jan 2021 01:39:20 GMT Kinsey Moore [9d77c0f4] * spec/build/bsps/arm/raspberrypi/grp.yml (modified) * spec/build/bsps/optstarthyp.yml (moved) spec: Move hypervisor start for use by AArch64 AArch64 on hardware ... Mon, 11 Jan 2021 17:56:36 GMT Alex White [07297812] * spec/build/bsps/aarch64/a53/tsta53.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml (modified) spec/aarch64: Remove sp37 from intermittent tests Mon, 11 Jan 2021 16:23:16 GMT Alex White [9aff7e56] * cpukit/score/cpu/aarch64/cpu.c (modified) * cpukit/score/cpu/aarch64/include/rtems/score/cpu.h (modified) score/aarch64: Fix interrupt level reads Mon, 15 Feb 2021 16:51:37 GMT Kinsey Moore [bbc9974a] * cpukit/include/rtems/linkersets.h (modified) cpukit: Explicitly enforce alignment requirements According to ... Tue, 02 Mar 2021 20:11:49 GMT Kinsey Moore [2ee12f02] * bsps/aarch64/xilinx-zynqmp/include/tm27.h (modified) * bsps/include/dev/irq/arm-gic-tm27.h (modified) bsps: Allow override of ARM TM27 IRQs ZynqMP hardware appears to ... Fri, 19 Feb 2021 14:34:48 GMT Kinsey Moore [6bfbfb5] * bsps/aarch64/shared/start/linkcmds.base (modified) * spec/build/bsps/aarch64/a53/linkcmds_ilp32.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml (modified) bsps/aarch64: Resolve usage of SUBALIGN() Remove usage of ... Thu, 04 Mar 2021 07:12:47 GMT Sebastian Huber [61d688bf] * cpukit/score/cpu/aarch64/cpu_asm.S (modified) aarch64: Fix context switch The ... Wed, 03 Mar 2021 08:23:20 GMT Sebastian Huber [5248395] * cpukit/include/rtems/score/context.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/tlsallocsize.c (modified) score: Ensure stack alignment requirement Make sure that a ... Wed, 03 Mar 2021 08:36:45 GMT Sebastian Huber [1de00d6] * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems/confdefs/threads.h (modified) * testsuites/sptests/spfatal33/init.c (modified) CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE Ensure that ... Wed, 03 Mar 2021 09:27:52 GMT Sebastian Huber [8fe59be] * spec/build/bsps/aarch64/a53/tsta53.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml (modified) * testsuites/validation/tc-message-construct-errors.c (modified) validation: Fix for 64-bit targets Closes #4179. Wed, 03 Mar 2021 07:04:55 GMT Sebastian Huber [30f6fd5b] * cpukit/include/rtems/rtems/tasks.h (modified) rtems: Fix RTEMS_TASK_STORAGE_ALIGNMENT Make sure we meet the stack ... Wed, 03 Mar 2021 07:39:33 GMT Sebastian Huber [4a765b47] * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/src/percpuasm.c (modified) score: Enforce CPU_STACK_ALIGNMENT requirements Clarify ... Thu, 25 Feb 2021 08:47:08 GMT Jan Sommer [a510e243] * MAINTAINERS (modified) MAINTAINERS: Add myself to write after approval Tue, 02 Mar 2021 11:31:45 GMT Sebastian Huber [83b1b25d] * cpukit/rtems/src/signalcatch.c (modified) * testsuites/validation/tc-signal-catch.c (modified) rtems: Simplify rtems_signal_catch() In uniprocessor ... Tue, 02 Mar 2021 09:55:10 GMT Sebastian Huber [9a13f37] * cpukit/rtems/src/signalsend.c (modified) rtems: Simplify _Signal_Action_handler() Use the invariant that an ... Tue, 23 Feb 2021 08:18:40 GMT James Fitzsimons [320cb42] * bsps/arm/beagle/include/bsp/bbb-pwm.h (modified) * bsps/arm/beagle/include/bsp/pwmss.h (modified) * bsps/arm/beagle/include/bsp/qep.h (modified) * bsps/arm/beagle/pwm/pwm.c (modified) * bsps/arm/beagle/pwmss/pwmss.c (modified) * bsps/arm/beagle/qep/qep.c (modified) bsps/beagle: Updating licences to latest BSD 2 clause Tue, 23 Feb 2021 08:18:39 GMT James Fitzsimons [db86c3eb] * bsps/arm/beagle/headers.am (modified) * bsps/arm/beagle/include/bsp/bbb-pwm.h (modified) * bsps/arm/beagle/include/bsp/pwmss.h (added) * bsps/arm/beagle/include/bsp/qep.h (added) * bsps/arm/beagle/pwm/pwm.c (modified) * bsps/arm/beagle/pwmss/pwmss.c (added) * bsps/arm/beagle/qep/qep.c (added) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * spec/build/bsps/arm/beagle/obj.yml (modified) bsps/beagle: Adding QEP driver support to BeagleBoneBlack BSP Tue, 02 Mar 2021 06:54:17 GMT Sebastian Huber [c0c4b8b] * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-delete.c (modified) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-barrier-wait.c (modified) * testsuites/validation/tc-message-construct-errors.c (modified) * testsuites/validation/tc-signal-catch.c (modified) * testsuites/validation/tc-signal-send.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) * testsuites/validation/tc-task-create-errors.c (modified) validation: Format comment blocks Mon, 01 Mar 2021 07:12:54 GMT Sebastian Huber [441824a] * cpukit/score/src/objectnametoid.c (modified) score: Simplify _Objects_Name_to_id_u32() Remove superfluous check ... Mon, 01 Mar 2021 09:00:26 GMT Sebastian Huber [2ad03de] * testsuites/validation/tc-task-construct-errors.c (modified) * testsuites/validation/tc-task-create-errors.c (modified) validation: Add comments to task tests Wed, 24 Feb 2021 16:59:32 GMT Sebastian Huber [81fcf16] * testsuites/validation/tc-message-construct-errors.c (modified) validation: Add comments to message queue tests Split up post-condition. Mon, 01 Mar 2021 09:00:26 GMT Sebastian Huber [54c9630] * testsuites/validation/tc-signal-catch.c (modified) * testsuites/validation/tc-signal-send.c (modified) validation: Add comments to signal tests Wed, 24 Feb 2021 16:59:32 GMT Sebastian Huber [34f279aa] * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-delete.c (modified) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-barrier-wait.c (modified) validation: Add comments to barrier tests Unify code sections ... Fri, 26 Feb 2021 11:34:21 GMT Sebastian Huber [08cbd4ba] * cpukit/include/rtems/score/stackimpl.h (modified) * spec/build/testsuites/validation/validation-0.yml (modified) * testsuites/validation/tc-task-create-errors.c (added) score: Fix _Stack_Extend_size() Check for an integer overflow. Add ... Fri, 26 Feb 2021 11:34:08 GMT Sebastian Huber [9dad735] * testsuites/validation/tc-task-construct-errors.c (modified) validation: Improve task construct error tests Fri, 26 Feb 2021 23:54:37 GMT Chris Johns [96918af] * bsps/powerpc/motorola_powerpc/bootloader/ppcboot.lds (modified) powerpc/motorola_power: Place any common data in the .bss section - ... Wed, 24 Feb 2021 06:04:36 GMT Chris Johns [75fb7a0e] * bsps/powerpc/motorola_powerpc/bootloader/ppcboot.lds (modified) powerpc/motorola_power: Link all text sections into the executable ... Sat, 27 Feb 2021 06:09:01 GMT Vijay Kumar Banerjee [f0f8c111] * cpukit/libcsupport/src/getgrent.c (modified) * cpukit/libtrace/record/record-client.c (modified) getgrent.c, record-client.c: Add missing includes for assert.h Fri, 19 Feb 2021 22:34:26 GMT Ryan Long [e2002659] * cpukit/libdebugger/rtems-debugger-threads.c (modified) rtems-debugger-threads.c: Fix Unchecked return value error (CID ... Fri, 19 Feb 2021 22:30:13 GMT Ryan Long [e5e58da] * cpukit/libcsupport/src/getgrent.c (modified) getgrent.c: Fix Unchecked return value error (CID #1459004) CID ... Fri, 19 Feb 2021 22:24:05 GMT Ryan Long [be3b87d] * cpukit/libtrace/record/record-client.c (modified) record-client.c: Fix Unchecked return value (CID #1456677) CID ... Fri, 19 Feb 2021 22:06:38 GMT Ryan Long [1b322a6] * cpukit/libcsupport/src/printertask.c (modified) printertask.c: Fix Unchecked return value (CID #1399710) CID ... Fri, 26 Feb 2021 08:56:39 GMT Sebastian Huber [2428a8ca] * cpukit/headers.am (modified) * spec/build/cpukit/librtemscpu.yml (modified) build: Install Update #4267. Fri, 26 Feb 2021 08:48:41 GMT Sebastian Huber [de7df04] * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (modified) * bsps/i386/pc386/start/bspgetworkarea.c (modified) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (modified) * bsps/powerpc/tqm8xx/start/bspgetworkarea.c (modified) * bsps/shared/start/bspgetworkarea-default.c (modified) bsps: Fix legacy build Thu, 25 Feb 2021 18:08:52 GMT Sebastian Huber [1ac4a85] * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskconstruct.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) score: Fix thread initialization Close the thread object if a ... Wed, 24 Feb 2021 13:45:47 GMT Sebastian Huber [c96644e8] * cpukit/libtest/t-test-hash-sha256.c (modified) * testsuites/libtests/ttest01/init.c (modified) libtest: Print SHA256 hash in base64url Tue, 23 Feb 2021 18:47:02 GMT Sebastian Huber [74eff26c] * cpukit/libtest/t-test.c (modified) * spec/build/bsps/m68k/mcf52235/tstmcf52235.yml (modified) * testsuites/libtests/ttest01/init.c (modified) libtest: Report target hash Update #4267. Tue, 23 Feb 2021 17:53:42 GMT Sebastian Huber [7480c34] * bsps/shared/start/gettargethash-default.c (added) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xen/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/griscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * spec/build/bsps/aarch64/a53/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/atsam/bspatsam.yml (modified) * spec/build/bsps/arm/beagle/obj.yml (modified) * spec/build/bsps/arm/csb336/bspcsb336.yml (modified) * spec/build/bsps/arm/csb337/obj.yml (modified) * spec/build/bsps/arm/edb7312/bspedb7312.yml (modified) * spec/build/bsps/arm/fvp/obj.yml (modified) * spec/build/bsps/arm/gumstix/bspgumstix.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/imxrt/bspimxrt.yml (modified) * spec/build/bsps/arm/lm3s69xx/obj.yml (modified) * spec/build/bsps/arm/lpc176x/obj.yml (modified) * spec/build/bsps/arm/lpc24xx/obj.yml (modified) * spec/build/bsps/arm/lpc32xx/obj.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml (modified) * spec/build/bsps/arm/rtl22xx/obj.yml (modified) * spec/build/bsps/arm/smdk2410/bspsmdk2410.yml (modified) * spec/build/bsps/arm/stm32f4/obj.yml (modified) * spec/build/bsps/arm/stm32h7/bspstm32h7.yml (modified) * spec/build/bsps/arm/tms570/obj.yml (modified) * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) * spec/build/bsps/bfin/TLL6527M/bsptll6527m.yml (modified) * spec/build/bsps/bfin/bf537Stamp/bspbf537stamp.yml (modified) * spec/build/bsps/bfin/eZKit533/bspezkit533.yml (modified) * spec/build/bsps/i386/pc386/obj.yml (modified) * spec/build/bsps/lm32/lm32_evr/obj.yml (modified) * spec/build/bsps/lm32/milkymist/bspmilkymist.yml (modified) * spec/build/bsps/m68k/av5282/bspav5282.yml (modified) * spec/build/bsps/m68k/csb360/bspcsb360.yml (modified) * spec/build/bsps/m68k/gen68340/bspgen68340.yml (modified) * spec/build/bsps/m68k/gen68360/obj.yml (modified) * spec/build/bsps/m68k/genmcf548x/obj.yml (modified) * spec/build/bsps/m68k/mcf5206elite/bspmcf5206elite.yml (modified) * spec/build/bsps/m68k/mcf52235/bspmcf52235.yml (modified) * spec/build/bsps/m68k/mcf5225x/bspmcf5225x.yml (modified) * spec/build/bsps/m68k/mcf5235/bspmcf5235.yml (modified) * spec/build/bsps/m68k/mcf5329/bspmcf5329.yml (modified) * spec/build/bsps/m68k/mrm332/bspmrm332.yml (modified) * spec/build/bsps/m68k/mvme147/bspmvme147.yml (modified) * spec/build/bsps/m68k/mvme147s/bspmvme147s.yml (modified) * spec/build/bsps/m68k/mvme162/obj.yml (modified) * spec/build/bsps/m68k/mvme167/bspmvme167.yml (modified) * spec/build/bsps/m68k/uC5282/bspuc5282.yml (modified) * spec/build/bsps/mips/csb350/bspcsb350.yml (modified) * spec/build/bsps/mips/hurricane/bsphurricane.yml (modified) * spec/build/bsps/mips/jmr3904/bspjmr3904.yml (modified) * spec/build/bsps/mips/malta/bspmalta.yml (modified) * spec/build/bsps/mips/rbtx4925/bsprbtx4925.yml (modified) * spec/build/bsps/mips/rbtx4938/bsprbtx4938.yml (modified) * spec/build/bsps/moxie/moxiesim/bspmoxiesim.yml (modified) * spec/build/bsps/nios2/nios2_iss/bspnios2iss.yml (modified) * spec/build/bsps/or1k/generic_or1k/bspgenericor1k.yml (modified) * spec/build/bsps/powerpc/beatnik/bspbeatnik.yml (modified) * spec/build/bsps/powerpc/gen5200/obj.yml (modified) * spec/build/bsps/powerpc/gen83xx/obj.yml (modified) * spec/build/bsps/powerpc/haleakala/bsphaleakala.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/obj.yml (modified) * spec/build/bsps/powerpc/mpc55xxevb/obj.yml (modified) * spec/build/bsps/powerpc/mpc8260ads/bspmpc8260ads.yml (modified) * spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml (modified) * spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml (modified) * spec/build/bsps/powerpc/psim/bsppsim.yml (modified) * spec/build/bsps/powerpc/qemuppc/bspqemuppc.yml (modified) * spec/build/bsps/powerpc/qoriq/obj.yml (modified) * spec/build/bsps/powerpc/ss555/bspss555.yml (modified) * spec/build/bsps/powerpc/t32mppc/bspt32mppc.yml (modified) * spec/build/bsps/powerpc/tqm8xx/obj.yml (modified) * spec/build/bsps/powerpc/virtex/bspvirtex.yml (modified) * spec/build/bsps/powerpc/virtex4/bspvirtex4.yml (modified) * spec/build/bsps/powerpc/virtex5/bspvirtex5.yml (modified) * spec/build/bsps/riscv/griscv/obj.yml (modified) * spec/build/bsps/riscv/riscv/obj.yml (modified) * spec/build/bsps/sh/gensh1/bspgensh1.yml (modified) * spec/build/bsps/sh/gensh2/bspgensh2.yml (modified) * spec/build/bsps/sh/gensh4/bspgensh4.yml (modified) * spec/build/bsps/sh/shsim/obj.yml (modified) * spec/build/bsps/sparc/erc32/bsperc32.yml (modified) * spec/build/bsps/sparc/leon2/obj.yml (modified) * spec/build/bsps/sparc/leon3/obj.yml (modified) * spec/build/bsps/sparc64/niagara/bspniagara.yml (modified) * spec/build/bsps/sparc64/usiii/bspusiii.yml (modified) * spec/build/bsps/v850/gdbv850sim/obj.yml (modified) * spec/build/bsps/x86_64/amd64/bspamd64.yml (modified) bsps: Add default rtems_get_target_hash() Update #4267. Wed, 24 Feb 2021 12:25:46 GMT Sebastian Huber [bc6ffc3] * cpukit/include/rtems/sysinit.h (modified) * cpukit/sapi/src/sysinitverbose.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) Add system initialization step for target hash Update #4267. Tue, 23 Feb 2021 11:47:38 GMT Sebastian Huber [fb17af27] * cpukit/include/rtems/config.h (modified) rtems: Add rtems_get_target_hash() Update #4267. Tue, 23 Feb 2021 13:53:40 GMT Sebastian Huber [dea125d0] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/hash.h (added) * cpukit/score/src/hash.c (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add Hash Handler Update #4267. Tue, 23 Feb 2021 12:25:00 GMT Sebastian Huber [5f8bc83] * cpukit/include/rtems/score/io.h (modified) * cpukit/score/src/iobase64.c (modified) * testsuites/sptests/spprintk/init.c (modified) score: Add _IO_Base64url() Update #4267. Tue, 23 Feb 2021 09:58:08 GMT Sebastian Huber [da8ad67e] * cpukit/libtest/t-test.c (modified) libtest: Report build label Update #4269. Tue, 23 Feb 2021 09:58:56 GMT Sebastian Huber [d8bfa5a] * cpukit/Makefile.am (modified) * cpukit/include/rtems/config.h (modified) * cpukit/sapi/src/getbuildlabel.c (added) * spec/build/cpukit/cpuopts.yml (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/optbuildlabel.yml (added) rtems: Add rtems_get_build_label() Update #4269. Wed, 24 Feb 2021 12:12:27 GMT Sebastian Huber [d138a790] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/sapi/src/sysinitverbose.c (modified) config: Adjust stack allocator initialization Use the right system ... Wed, 24 Feb 2021 10:13:30 GMT Sebastian Huber [32b0d6f8] * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (modified) * bsps/i386/pc386/start/bspgetworkarea.c (modified) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (modified) * bsps/powerpc/tqm8xx/start/bspgetworkarea.c (modified) * bsps/shared/start/bspgetworkarea-default.c (modified) bsps: Change license to BSD-2-Clause of some files Change license ... Tue, 23 Feb 2021 18:38:38 GMT Sebastian Huber [e8284a34] * spec/build/bsps/aarch64/a53/obj.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml (modified) * spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml (modified) * spec/build/bsps/arm/imx/bspimx.yml (modified) * spec/build/bsps/arm/imxrt/bspimxrt.yml (modified) * spec/build/bsps/arm/raspberrypi/obj.yml (modified) * spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml (modified) * spec/build/bsps/arm/stm32h7/bspstm32h7.yml (modified) * spec/build/bsps/arm/xen/bspxen.yml (modified) * spec/build/bsps/arm/xilinx-zynq/obj.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) * spec/build/bsps/bfin/obj.yml (modified) * spec/build/bsps/m68k/objfpsp.yml (modified) * spec/build/bsps/obj.yml (modified) * spec/build/bsps/objdevserialzynq.yml (modified) * spec/build/bsps/objgrlib.yml (modified) * spec/build/bsps/objirqdflt.yml (modified) * spec/build/bsps/objnosmp.yml (modified) * spec/build/bsps/powerpc/obj.yml (modified) * spec/build/bsps/powerpc/objexc.yml (modified) * spec/build/bsps/powerpc/objvme.yml (modified) * spec/build/cpukit/cpuaarch64.yml (modified) * spec/build/cpukit/cpuarm.yml (modified) * spec/build/cpukit/cpubfin.yml (modified) * spec/build/cpukit/cpui386.yml (modified) * spec/build/cpukit/cpulm32.yml (modified) * spec/build/cpukit/cpum68k.yml (modified) * spec/build/cpukit/cpumips.yml (modified) * spec/build/cpukit/cpumoxie.yml (modified) * spec/build/cpukit/cpuriscv.yml (modified) * spec/build/cpukit/cpuv850.yml (modified) * spec/build/cpukit/libdebugger.yml (modified) * spec/build/cpukit/libftpd.yml (modified) * spec/build/cpukit/librtemscpu.yml (modified) * spec/build/cpukit/librtemstest.yml (modified) * spec/build/cpukit/libtelnetd.yml (modified) * spec/build/cpukit/objdl.yml (modified) * spec/build/cpukit/objdrvmgr.yml (modified) * spec/build/cpukit/objnet.yml (modified) * spec/build/cpukit/objpci.yml (modified) * spec/build/cpukit/objpsxsgnl.yml (modified) * spec/build/cpukit/objshell.yml (modified) * spec/build/testsuites/benchmarks/dhrystone.yml (modified) * spec/build/testsuites/libtests/block08.yml (modified) * spec/build/testsuites/libtests/complex.yml (modified) * spec/build/testsuites/libtests/math.yml (modified) * spec/build/testsuites/libtests/mathf.yml (modified) * spec/build/testsuites/libtests/mathl.yml (modified) * spec/build/testsuites/libtests/mouse01.yml (modified) * spec/build/testsuites/libtests/rtmonuse.yml (modified) * spec/build/testsuites/libtests/termios06.yml (modified) * spec/build/testsuites/libtests/termios07.yml (modified) * spec/build/testsuites/libtests/termios08.yml (modified) * spec/build/testsuites/libtests/termios10.yml (modified) * spec/build/testsuites/libtests/termios11.yml (modified) * spec/build/testsuites/libtests/uid01.yml (modified) * spec/build/testsuites/mptests/mp03node1.yml (modified) * spec/build/testsuites/mptests/mp03node2.yml (modified) * spec/build/testsuites/mptests/mp05node1.yml (modified) * spec/build/testsuites/mptests/mp05node2.yml (modified) * spec/build/testsuites/mptests/mp09node1.yml (modified) * spec/build/testsuites/mptests/mp09node2.yml (modified) * spec/build/testsuites/mptests/mp14node1.yml (modified) * spec/build/testsuites/mptests/mp14node2.yml (modified) * spec/build/testsuites/psxtests/libpsxhdrs.yml (modified) * spec/build/testsuites/psxtests/psxmmap01.yml (modified) * spec/build/testsuites/samples/basempnode1.yml (modified) * spec/build/testsuites/samples/basempnode2.yml (modified) * spec/build/testsuites/samples/basesp.yml (modified) * spec/build/testsuites/samples/nsecs.yml (modified) * spec/build/testsuites/smptests/smpscheduler05.yml (modified) * spec/build/testsuites/smptests/smpscheduler06.yml (modified) * spec/build/testsuites/smptests/smpscheduler07.yml (modified) * spec/build/testsuites/sptests/sp02.yml (modified) * spec/build/testsuites/sptests/sp12.yml (modified) * spec/build/testsuites/sptests/sp13.yml (modified) * spec/build/testsuites/sptests/sp14.yml (modified) * spec/build/testsuites/sptests/sp17.yml (modified) * spec/build/testsuites/sptests/sp19.yml (modified) * spec/build/testsuites/sptests/sp20.yml (modified) * spec/build/testsuites/sptests/sp22.yml (modified) * spec/build/testsuites/sptests/spcbssched03.yml (modified) * spec/build/testsuites/sptests/spclockerr01.yml (modified) * spec/build/testsuites/sptests/spcpuset01.yml (modified) * spec/build/testsuites/sptests/spedfsched02.yml (modified) * spec/build/testsuites/sptests/spedfsched03.yml (modified) * spec/build/testsuites/sptests/splinkersets01.yml (modified) * spec/build/testsuites/sptests/spsize.yml (modified) * spec/build/testsuites/sptests/spwatchdog.yml (modified) * spec/build/testsuites/tmtests/tm01.yml (modified) * spec/build/testsuites/tmtests/tm02.yml (modified) * spec/build/testsuites/tmtests/tm03.yml (modified) * spec/build/testsuites/tmtests/tm04.yml (modified) * spec/build/testsuites/tmtests/tm05.yml (modified) * spec/build/testsuites/tmtests/tm06.yml (modified) * spec/build/testsuites/tmtests/tm07.yml (modified) * spec/build/testsuites/tmtests/tm08.yml (modified) * spec/build/testsuites/tmtests/tm09.yml (modified) * spec/build/testsuites/tmtests/tm10.yml (modified) * spec/build/testsuites/tmtests/tm11.yml (modified) * spec/build/testsuites/tmtests/tm12.yml (modified) * spec/build/testsuites/tmtests/tm13.yml (modified) * spec/build/testsuites/tmtests/tm14.yml (modified) * spec/build/testsuites/tmtests/tm15.yml (modified) * spec/build/testsuites/tmtests/tm16.yml (modified) * spec/build/testsuites/tmtests/tm17.yml (modified) * spec/build/testsuites/tmtests/tm18.yml (modified) * spec/build/testsuites/tmtests/tm19.yml (modified) * spec/build/testsuites/tmtests/tm20.yml (modified) * spec/build/testsuites/tmtests/tm21.yml (modified) * spec/build/testsuites/tmtests/tm22.yml (modified) * spec/build/testsuites/tmtests/tm23.yml (modified) * spec/build/testsuites/tmtests/tm24.yml (modified) * spec/build/testsuites/tmtests/tm25.yml (modified) * spec/build/testsuites/tmtests/tm26.yml (modified) * spec/build/testsuites/tmtests/tm27.yml (modified) * spec/build/testsuites/tmtests/tm28.yml (modified) * spec/build/testsuites/tmtests/tm29.yml (modified) * spec/build/testsuites/tmtests/tm30.yml (modified) * spec/build/testsuites/tmtests/tm31.yml (modified) * spec/build/testsuites/tmtests/tm32.yml (modified) * spec/build/testsuites/tmtests/tm33.yml (modified) * spec/build/testsuites/tmtests/tm34.yml (modified) * spec/build/testsuites/tmtests/tm35.yml (modified) * spec/build/testsuites/tmtests/tm36.yml (modified) * spec/build/testsuites/tmtests/tmck.yml (modified) build: Sort source lists Use the Python sorted() function to sort ... Sun, 21 Feb 2021 16:48:04 GMT Sebastian Huber [006c702] * testsuites/validation/tc-message-construct-errors.c (modified) validation: Simplify message queue construct tests Fri, 19 Feb 2021 20:31:34 GMT Sebastian Huber [fd838603] * testsuites/validation/tc-barrier-create.c (modified) validation: Add missing barrier create test case Sun, 21 Feb 2021 16:26:31 GMT Sebastian Huber [5be6e61] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-rtems-objs.c (modified) libtest: Add support to seize/surrender objects Fri, 19 Feb 2021 20:41:18 GMT Sebastian Huber [d6a649d5] * cpukit/include/rtems/rtems/sem.h (modified) * cpukit/include/rtems/rtems/timer.h (modified) * cpukit/include/rtems/rtems/types.h (modified) rtems: Move rtems_task_priority definition This type is not only ... Sun, 21 Feb 2021 09:58:15 GMT Sebastian Huber [88543ade] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/corebarrierimpl.h (modified) * cpukit/score/src/corebarrierrelease.c (deleted) * spec/build/cpukit/librtemscpu.yml (modified) score: Remove _CORE_barrier_Do_flush() Call ... Sun, 21 Feb 2021 09:21:26 GMT Sebastian Huber [3cbdf19] * cpukit/include/rtems/score/corebarrier.h (modified) * cpukit/include/rtems/score/corebarrierimpl.h (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/score/src/corebarrier.c (modified) * cpukit/score/src/corebarrierwait.c (modified) score: Simplify core barrier Use the number of threads which must ... Sun, 21 Feb 2021 09:47:36 GMT Sebastian Huber [0b263b0e] * cpukit/include/rtems/score/objectimpl.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/barriercreate.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/msgqconstruct.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/taskconstruct.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/sapi/src/extensioncreate.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Remove _Objects_Open() Use the type safe _Objects_Open_u32() ... Tue, 23 Feb 2021 09:04:51 GMT Sebastian Huber [3353820b] * wscript (modified) build: Fix format in wscript Sat, 20 Feb 2021 13:28:17 GMT Sebastian Huber [508f8682] * cpukit/rtems/src/taskmode.c (modified) rtems: Simplify rtems_task_mode() Do the preemption and ASR ... Tue, 16 Feb 2021 11:58:36 GMT Sebastian Huber [a7e180b] * cpukit/rtems/src/signalsend.c (modified) rtems: Avoid potential recursion in ASR handling Do the mode ... Tue, 16 Feb 2021 11:58:02 GMT Sebastian Huber [08adc0d] * cpukit/include/rtems/rtems/modesimpl.h (modified) * cpukit/rtems/src/taskmode.c (modified) rtems: Add _Modes_Apply_timeslice_to_thread() Update #4244. Tue, 16 Feb 2021 09:27:03 GMT Sebastian Huber [8778a0e] * cpukit/include/rtems/rtems/modesimpl.h (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/taskmode.c (modified) rtems: New errors for rtems_signal_catch() Ensure that no invalid ... Fri, 19 Feb 2021 08:48:14 GMT Sebastian Huber [1739bd2] * cpukit/include/rtems/rtems/modesimpl.h (modified) * cpukit/rtems/src/taskmode.c (modified) rtems: Remove _Modes_Set_interrupt_level() This call just ... Wed, 17 Feb 2021 07:00:29 GMT Sebastian Huber [b207b37] * cpukit/posix/src/psignalunblockthread.c (modified) posix: Remove superfluous check The api pointer is never NULL. ... Tue, 16 Feb 2021 07:15:10 GMT Sebastian Huber [f6a97f5] * cpukit/headers.am (modified) * cpukit/include/rtems/rtems/asrdata.h (modified) * cpukit/include/rtems/rtems/asrimpl.h (deleted) * cpukit/include/rtems/rtems/signalimpl.h (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskmode.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) rtems: Simplify signal handling Remove superfluous ... Wed, 17 Feb 2021 08:05:53 GMT Sebastian Huber [74ca8b7] * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalsend.c (modified) rtems: Move _Signal_Action_handler() Move _Signal_Action_handler() ... Tue, 16 Feb 2021 06:48:39 GMT Sebastian Huber [a52e5d9] * cpukit/include/rtems/rtems/asrdata.h (modified) * cpukit/rtems/src/signalcatch.c (modified) rtems: Remove unused ASR_Information::nest_level Update #4244. Tue, 16 Feb 2021 06:47:53 GMT Sebastian Huber [9d5d73b] * cpukit/include/rtems/rtems/modesimpl.h (modified) rtems: Remove unused _Modes_Change() Update #4244. Tue, 16 Feb 2021 06:47:20 GMT Sebastian Huber [600360d] * cpukit/include/rtems/rtems/modesimpl.h (modified) rtems: Remove unused _Modes_Mask_changed() Update #4244. Wed, 17 Feb 2021 08:02:31 GMT Sebastian Huber [f9a59164] * cpukit/include/rtems/score/threadimpl.h (modified) score: Add _Thread_Append_post_switch_action() Update #4244. Wed, 17 Feb 2021 07:05:37 GMT Sebastian Huber [fea848b] * cpukit/include/rtems/score/thread.h (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/score/src/threaddispatch.c (modified) score: Change thread action locking Require that the corresponding ... Mon, 15 Feb 2021 13:02:49 GMT Sebastian Huber [3e7d658] * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-1.yml (modified) * testsuites/validation/tc-signal-catch.c (added) * testsuites/validation/tc-signal-send.c (added) validation: Add signal manager tests Update #4244. Mon, 15 Feb 2021 08:14:41 GMT Sebastian Huber [f38c0de4] * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/testsuites/validation/grp.yml (modified) * spec/build/testsuites/validation/validation-1.yml (added) * testsuites/validation/ts-default.h (modified) * testsuites/validation/ts-validation-0.c (modified) * testsuites/validation/ts-validation-1.c (added) validation: Add Validation1 test suite Update #4244. Tue, 16 Feb 2021 22:39:30 GMT Ryan Long [fac1ff1] * bsps/shared/grlib/spw/grspw_pkt.c (modified) grspw_pkt.c: Fix Dereference before null check (CID #1399846) CID ... Tue, 16 Feb 2021 22:15:01 GMT Ryan Long [1fd56a96] * bsps/shared/grlib/tmtc/grtc.c (modified) grtc.c: Fix Dereference before null check (CID #1399840) CID ... Tue, 16 Feb 2021 21:41:25 GMT Ryan Long [4edcdf43] * bsps/shared/grlib/1553/b1553rt.c (modified) b1553rt.c: Fix Deference before null check (CID #1399830) CID ... Tue, 16 Feb 2021 21:20:04 GMT Ryan Long [eff3d7c] * bsps/shared/grlib/1553/b1553brm.c (modified) b1553brm.c: Fix Dereference before null check (CID #1399829) CID ... Wed, 24 Jun 2020 05:10:25 GMT Sebastian Huber [8b1b9872] * cpukit/include/rtems/rtems/asr.h (modified) * cpukit/include/rtems/rtems/signal.h (modified) rtems: Generate Change license to ... Wed, 10 Feb 2021 05:43:39 GMT Sebastian Huber [be603721] * cpukit/include/rtems/score/basedefs.h (modified) basedefs: Add RTEMS_ALIGNOF() Thu, 18 Feb 2021 14:35:13 GMT Ryan Long [fa25b73] * cpukit/libmisc/shell/shell.c (modified) shell.c: Fix Dereference before null check (CID #1467420) CID ... Mon, 22 Jun 2020 05:09:23 GMT Sebastian Huber [407e351] * cpukit/include/rtems/rtems/sem.h (modified) rtems: Generate Change license to BSD-2-Clause ... Mon, 22 Jun 2020 07:06:51 GMT Sebastian Huber [2768280] * cpukit/include/rtems/rtems/clock.h (modified) rtems: Generate Change license to ... Mon, 22 Jun 2020 06:39:29 GMT Sebastian Huber [0c4c035] * cpukit/include/rtems/rtems/barrier.h (modified) rtems: Generate Change license to ... Mon, 15 Feb 2021 12:57:37 GMT Sebastian Huber [97825da] * cpukit/include/rtems/rtems/object.h (modified) rtems: Clarify object services documentation Unify the wording ... Mon, 15 Feb 2021 12:57:37 GMT Sebastian Huber [7a1828ac] * cpukit/include/rtems/io.h (modified) rtems: Clarify IO manager documentation Unify the wording across ... Wed, 10 Feb 2021 05:44:12 GMT Sebastian Huber [bf3b9f45] * cpukit/include/rtems/rtems/part.h (modified) rtems: Clarify partition manager documentation Unify the wording ...
