# # ChangeLog for / in rtems # # Generated by Trac 1.2.1.dev0 # 06/15/24 20:21:13 Sat, 27 Mar 2021 17:08:13 GMT Sebastian Huber [1e62e15f] * cpukit/score/src/wkspace.c (modified) score: Add an assert to _Workspace_Free() Sat, 27 Mar 2021 10:15:43 GMT Sebastian Huber [e0aba8cb] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/psxtests/psxclassic01/init.c (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/spconfig01/init.c (modified) * testsuites/validation/ts-default.h (modified) score: Fix task stack initialization Do not adjust the stack area ... Sat, 27 Mar 2021 14:55:49 GMT Joel Sherrill [d4d2f648] * cpukit/libcsupport/src/pwdgrp.c (modified) pwdgrp.c: Change to simply ignore return value from mkdir(/etc) At ... Thu, 21 Jan 2021 15:53:55 GMT Christian Mauderer [fd639b8] * cpukit/libfs/src/dosfs/fat.c (modified) * cpukit/libfs/src/dosfs/fat.h (modified) * cpukit/libfs/src/dosfs/fat_file.c (modified) dosfs: Use peek support This speeds up reading fragmented files. ... Tue, 19 Jan 2021 14:33:35 GMT Christian Mauderer [6ae79e6] * cpukit/include/rtems/bdbuf.h (modified) * cpukit/include/rtems/diskdevs.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libblock/src/blkdev-print-stats.c (modified) * testsuites/fstests/fsdosfswrite01/init.c (modified) * testsuites/libtests/block14/block14.scn (modified) * testsuites/libtests/block14/init.c (modified) libblock: Add rtems_bdbuf_peek() Adds a peek function that allows ... Wed, 24 Mar 2021 12:57:43 GMT Joel Sherrill [62bbb0c] * cpukit/libmisc/uuid/gen_uuid.c (modified) gen_uuid.c: Revert previous patch ... Tue, 23 Mar 2021 16:25:15 GMT Ryan Long [37fc651] * cpukit/libcsupport/src/pwdgrp.c (modified) pwdgrp.c: Remove _Assert. /etc may already exist Removed the ... Fri, 19 Mar 2021 11:12:09 GMT Jan Sommer [1343fb5f] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) bsps/riscv: Add per cpu clock interrupt - Fixes failure of test ... Mon, 22 Mar 2021 09:45:33 GMT Sebastian Huber [fec2b724] * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-delete.c (modified) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-barrier-wait.c (modified) * testsuites/validation/tc-signal-catch.c (modified) * testsuites/validation/tc-signal-send.c (modified) validation: Use support functions Sun, 21 Mar 2021 12:26:53 GMT Sebastian Huber [8afe3323] * spec/build/testsuites/validation/validation-0.yml (modified) * spec/build/testsuites/validation/validation-1.yml (modified) * testsuites/validation/tc-support.c (added) * testsuites/validation/tc-support.h (added) validation: Add test case support functions Thu, 18 Mar 2021 02:50:56 GMT G S Niteesh Babu [bd9e45d9] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) rtems-fdt/rtems-fdt.c: Fix bug in loop termination The while loop, ... Sat, 13 Mar 2021 11:02:03 GMT G S Niteesh Babu [5607464] * bsps/arm/beagle/start/bspstart.c (modified) * bsps/include/arm/ti/ti_pinmux.h (modified) * bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c (modified) * bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c (modified) * spec/build/bsps/obj.yml (modified) bsp/beagle: Ported Beagle pinmux driver to RTEMS The following ... Sat, 13 Mar 2021 11:02:02 GMT G S Niteesh Babu [7589f1e0] * bsps/arm/beagle/start/bsp-soc-detect.c (added) * bsps/arm/beagle/start/bsp-soc-detect.h (added) * bsps/arm/beagle/start/bspstart.c (modified) * bsps/include/arm/ti/ti_cpuid.h (added) * spec/build/bsps/arm/beagle/obj.yml (modified) bsps/beagle: Added SOC detection using FDT Detects the SOC type ... Sat, 13 Mar 2021 11:02:01 GMT G S Niteesh Babu [5c656ead] * bsps/include/arm/ti/am335x/am335x_scm_padconf.h (added) * bsps/include/arm/ti/ti_pinmux.h (added) * bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c (added) * bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c (added) bsp/beagle: Import Beagle pinmux from FreeBSD This patch imports ... Sat, 13 Mar 2021 11:02:00 GMT G S Niteesh Babu [fc712906] * bsps/include/ofw/ofw.h (modified) * bsps/shared/ofw/ofw.c (modified) bsps/shared/ofw: Add rtems_ofw_is_node_compatible This patch ... Thu, 04 Feb 2021 13:27:50 GMT Christian Mauderer [65ab1cda] * bsps/arm/imxrt/dts/imxrt1050-evkb.c (modified) * bsps/arm/imxrt/include/fsl_qtmr.h (modified) * bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi (modified) * bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_qtmr.c (modified) bsps/arm/imxrt: Add FDT and FDT helper for QTMR Makes it simpler to ... Wed, 17 Mar 2021 07:09:49 GMT Sebastian Huber [53bd5e32] * cpukit/rtems/src/signalcatch.c (modified) rtems: Relax mode checks in rtems_signal_catch() Check only for ... Tue, 16 Mar 2021 08:32:58 GMT Sebastian Huber [fa1e7ea] * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-delete.c (modified) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-barrier-wait.c (modified) * testsuites/validation/tc-message-construct-errors.c (modified) * testsuites/validation/tc-signal-catch.c (modified) * testsuites/validation/tc-signal-send.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) * testsuites/validation/tc-task-create-errors.c (modified) validation: Reduce source code/rodata size Use a common wording for ... Fri, 19 Mar 2021 15:48:43 GMT Sebastian Huber [eb1cd40] * spec/build/bsps/arm/lpc24xx/tstlpc2362.yml (modified) build: Add test exclude for arm/lpc2362 Thu, 18 Mar 2021 09:37:23 GMT Sebastian Huber [50abce31] * cpukit/rtems/src/taskmode.c (modified) rtems: Fix rtems_task_mode() Do the ASR and preemption mode change ... Fri, 12 Mar 2021 14:13:27 GMT Sebastian Huber [b4eb937] * cpukit/rtems/src/semcreate.c (modified) rtems: Improve semaphore create error checks Do not mix checks for ... Fri, 12 Mar 2021 13:37:10 GMT Sebastian Huber [4ebdbee] * cpukit/include/rtems/rtems/sem.h (modified) * cpukit/include/rtems/score/mrspimpl.h (modified) * testsuites/smptests/smpmrsp01/init.c (modified) rtems: Allow initially locked MrsP semaphores Rejecting initially ... Fri, 12 Mar 2021 13:16:30 GMT Sebastian Huber [0965b7c8] * cpukit/include/rtems/rtems/sem.h (modified) * cpukit/rtems/src/semcreate.c (modified) * testsuites/smptests/smpfatal03/init.c (modified) * testsuites/smptests/smpmrsp01/init.c (modified) * testsuites/smptests/smpscheduler02/init.c (modified) * testsuites/sptests/spmrsp01/init.c (modified) * testsuites/tmtests/tmfine01/init.c (modified) rtems: Require RTEMS_PRIORITY for MrsP semaphores MrsP semaphores ... Tue, 16 Mar 2021 11:15:14 GMT Sebastian Huber [5d752e7b] * testsuites/sptests/sp14/task1.c (modified) sp14: Fix for SMP or robust thread dispatch Close #4343. Fri, 12 Mar 2021 07:31:35 GMT Sebastian Huber [c9a41b00] * cpukit/include/rtems/posix/pthreadimpl.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/psxtransschedparam.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/score/src/threadinitialize.c (modified) score: Add Thread_Configuration::cpu_time_budget Move the CPU time ... Fri, 12 Mar 2021 07:12:02 GMT Sebastian Huber [5babc54] * spec/build/testsuites/validation/validation-1.yml (modified) * testsuites/validation/tc-task-construct-errors.c (modified) * testsuites/validation/tc-task-create-errors.c (modified) validation: Task create/construct Run the task create/construct ... Thu, 11 Mar 2021 20:40:03 GMT Sebastian Huber [586e06e] * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-delete.c (modified) * testsuites/validation/tc-message-construct-errors.c (modified) * testsuites/validation/tc-signal-catch.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) * testsuites/validation/tc-task-create-errors.c (modified) validation: Improve wording Wed, 03 Feb 2021 21:34:16 GMT Eshan dhawan [a26a326] * spec/build/testsuites/psxtests/grp.yml (modified) * spec/build/testsuites/psxtests/psxftw01.yml (added) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtests/psxftw01/init.c (added) * testsuites/psxtests/psxftw01/psxftw01.doc (added) * testsuites/psxtests/psxftw01/psxftw01.scn (added) * testsuites/psxtests/psxftw01/psxftw01.tar (added) Test suite for FTW.H methods Signed-off-by: Eshan Dhawan ... Tue, 21 Apr 2020 09:57:50 GMT Daniel Hellstrom [b2da982] * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/headers.am (modified) * cpukit/score/cpu/sparc/include/libcpu/grlib-tn-0018.h (added) * cpukit/score/cpu/sparc/include/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) * cpukit/score/cpu/sparc/window.S (modified) * spec/build/cpukit/cpusparc.yml (modified) leon,tn-0018: work around GRLIB-TN-0018 errata Overview ======== ... Mon, 25 Nov 2019 08:45:26 GMT Daniel Hellstrom [89d90c0] * cpukit/score/cpu/sparc/cpu_asm.S (modified) sparc,leon: avoid triggering LEON3FT errata TN-0009 Close #4336. Wed, 20 Nov 2019 12:19:35 GMT Daniel Hellstrom [acad761] * cpukit/score/cpu/sparc/sparc-counter-asm.S (modified) sparc,leon: avoid triggering TN-0009 bad sequence Update #4336. Mon, 18 Nov 2019 13:15:02 GMT Daniel Hellstrom [6caff4d6] * bsps/include/grlib/grspw_pkt.h (modified) grlib,grspw_pkt: correct link state enum numbering Not used by the ... Thu, 14 Nov 2019 10:47:21 GMT Martin Aberg [4e0735c6] * bsps/shared/grlib/l2c/l2c.c (modified) leon, l2cache: prevent unused diagnostic access Tue, 11 Dec 2018 16:55:39 GMT Martin Aberg [51564f63] * bsps/include/grlib/ahbstat.h (modified) * bsps/shared/grlib/amba/ahbstat.c (modified) leon, ahbstat: register definitions for AHBSTAT version 1 Fri, 08 Feb 2019 15:30:15 GMT Martin Aberg [8660602] * bsps/include/grlib/grspw_router.h (modified) * bsps/shared/grlib/spw/grspw_router.c (modified) leon, grspw_router: added router_port_link_div() Allows user to set ... Thu, 14 Nov 2019 09:26:21 GMT Daniel Hellstrom [1d804cb] * cpukit/score/cpu/sparc/sparc-access.S (modified) sparc: fix bad register alignment for 64 bit store Tue, 29 Oct 2019 14:17:57 GMT Daniel Hellstrom [dfe7901c] * bsps/sparc/leon3/start/cpucounter.c (modified) leon: restart and load timer counter at initialization Without this ... Fri, 12 Apr 2019 10:20:07 GMT Daniel Hellstrom [9c00cc1] * bsps/shared/grlib/btimer/tlib_ckinit.c (modified) leon,ckinit: avoid assuming 1MHz timer pre-scaler clock Thu, 12 Sep 2019 12:48:29 GMT Daniel Hellstrom [b57436c] * bsps/sparc/leon3/start/amba.c (modified) * bsps/sparc/leon3/start/drvmgr_def_drivers.c (added) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * spec/build/bsps/sparc/leon3/obj.yml (modified) leon3: avoid dependency on apbuart/timer driver Moves ... Fri, 26 Apr 2019 13:18:11 GMT Daniel Hellstrom [053b17ce] * bsps/include/grlib/greth.h (modified) * bsps/shared/grlib/net/greth.c (modified) leon,greth: added support for variable sized descriptor table sizes ... Fri, 12 Apr 2019 20:49:45 GMT Daniel Hellstrom [9bf8a9d1] * bsps/shared/grlib-sources.am (modified) * bsps/shared/grlib/can/grcan.c (modified) * bsps/shared/grlib/can/grcanstd.c (added) * spec/build/bsps/objgrlib.yml (modified) leon,grcan: split out GRCAN non-FD specific support in separate file ... Fri, 12 Apr 2019 20:41:04 GMT Daniel Hellstrom [9c76ca0] * bsps/shared/grlib-sources.am (modified) * bsps/shared/grlib/can/grcan.c (modified) * bsps/shared/grlib/can/grcan_internal.h (added) * bsps/shared/grlib/can/grcanfd.c (added) * spec/build/bsps/objgrlib.yml (modified) leon,grcanfd: split out GRCANFD specific support in separate file ... Fri, 12 Apr 2019 07:35:12 GMT Daniel Hellstrom [43c903a1] * bsps/include/grlib/grcan.h (modified) * bsps/shared/grlib/can/grcan.c (modified) leon,grcan: added support for GRCANFD The new GRCAN_FD IP supports ... Fri, 25 Oct 2019 10:51:53 GMT Daniel Hellstrom [b98d6b67] * bsps/include/grlib/grlib_impl.h (modified) grlib: added 64-bit read no-cache function Update #4324. Fri, 12 Apr 2019 10:54:54 GMT Daniel Hellstrom [65237ba0] * bsps/shared/grlib/can/occan.c (modified) leon,occan: use common CAN baud-rate calculation routine Close #4323. Fri, 12 Apr 2019 10:36:58 GMT Daniel Hellstrom [4d192207] * bsps/shared/grlib/can/grcan.c (modified) leon,grcan: use common CAN baud-rate calculation routine Update #4323. Fri, 12 Apr 2019 09:01:38 GMT Daniel Hellstrom [cff99cf] * bsps/headers.am (modified) * bsps/include/grlib/canbtrs.h (added) * bsps/include/grlib/grcan.h (modified) * bsps/include/grlib/occan.h (modified) * bsps/shared/grlib-sources.am (modified) * bsps/shared/grlib/can/canbtrs.c (added) * spec/build/bsps/objgrlib.yml (modified) leon,can: introduce common CAN baud-rate calculation function ... Fri, 12 Apr 2019 07:45:34 GMT Daniel Hellstrom [68c882ef] * bsps/include/grlib/ambapp_ids.h (modified) * bsps/shared/grlib/amba/ambapp_names.c (modified) grlib,ambapp: added new IP core IDs Fri, 12 Apr 2019 10:17:57 GMT Daniel Hellstrom [e227ae5] * bsps/shared/grlib/spw/grspw.c (modified) leon,grspw: fix for SET_PACKET_SIZE When the DMA table has been ... Mon, 15 Oct 2018 06:46:32 GMT Arvid Bjorkengren [50db7f2] * bsps/shared/grlib/1553/gr1553bc.c (modified) * bsps/shared/grlib/1553/gr1553bm.c (modified) * bsps/shared/grlib/1553/gr1553rt.c (modified) leon,gr1553b: Only align allocated memory. Verify alignment of memory. Mon, 15 Oct 2018 13:05:13 GMT Arvid Bjorkengren [70f87f9e] * bsps/shared/grlib/1553/gr1553b.c (modified) leon,gr1553b: set codec version This is enables the updated codec ... Fri, 12 Oct 2018 08:51:54 GMT Arvid Bjorkengren [3344d029] * bsps/shared/grlib/1553/gr1553rt.c (modified) leon,gr1553rt: Fixed spinlock unlock Thu, 11 Oct 2018 11:46:39 GMT Arvid Bjorkengren [f798a75c] * bsps/shared/grlib/1553/gr1553rt.c (modified) leon,gr1553rt: Fixed memory leak Tue, 19 Dec 2017 12:37:08 GMT Daniel Cederman [0cae482a] * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/syscall.S (modified) sparc: Remove sequences that the B2BST scan script warns about ... Thu, 11 Mar 2021 06:57:48 GMT Sebastian Huber [bfd1b6ee] * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-message-construct-errors.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) * testsuites/validation/tc-task-create-errors.c (modified) validation: Use common wording Wed, 02 Dec 2020 12:42:00 GMT Jan Sommer [9223931] * bsps/headers.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am (modified) bsps/xilinx_zynq: Add SPI driver to autotools build Closes #4320 Wed, 02 Dec 2020 12:31:06 GMT Jan Sommer [06129897] * spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml (modified) * spec/build/bsps/arm/xilinx-zynq/grp.yml (modified) * spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (modified) * spec/build/bsps/objdevspizynq.yml (added) bsps/xilinx_zynq: Add SPI driver to waf Updates #4320 Wed, 02 Dec 2020 12:30:03 GMT Jan Sommer [cc825d0] * bsps/include/dev/spi/cadence-spi-regs.h (added) * bsps/include/dev/spi/cadence-spi.h (added) * bsps/shared/dev/spi/cadence-spi.c (added) bsps/xilinx_zynq: Add SPI driver for cadence-spi Updates #4320 Tue, 09 Mar 2021 12:01:11 GMT Frank Kühndel [14bb077] * cpukit/include/rtems/score/basedefs.h (modified) basedefs: Clarify RTEMS_STRING(), RTEMS_XSTRING() Sat, 06 Mar 2021 15:05:22 GMT Sebastian Huber [ba48f20] * spec/build/bsps/arm/fvp/grp.yml (modified) build: Fix broken link Mon, 08 Mar 2021 15:30:25 GMT Alex White [10db41e] * spec/build/bsps/aarch64/a53/tsta53.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml (modified) spec/aarch64: Enable previously disabled tests This enables several ... Tue, 02 Mar 2021 18:51:46 GMT Ryan Long [fbab832] * cpukit/libmisc/shell/main_help.c (modified) main_help.c: Unchecked return value from library (CID #1437650) CID ... Tue, 02 Mar 2021 16:46:02 GMT Ryan Long [55ba229] * cpukit/libcsupport/src/pwdgrp.c (modified) pwdgrp.c: Fix Unchecked return value from library (CID #1255518) ... Tue, 02 Mar 2021 16:34:36 GMT Ryan Long [8e34aa3] * cpukit/libmisc/shell/main_chmod.c (modified) main_chmod.c: Fix Unchecked return value from library (CID #1063856) ... Tue, 02 Mar 2021 16:08:28 GMT Ryan Long [597e4f4] * cpukit/libmisc/uuid/gen_uuid.c (modified) gen_uuid.c: Fix two Unchecked return value from library errors CID ... Mon, 01 Mar 2021 16:07:42 GMT Ryan Long [3246fa42] * cpukit/libmisc/shell/main_edit.c (modified) main_edit.c: Fix Unchecked return value (CID #1255318) CID 1255318: ... Mon, 08 Mar 2021 09:49:51 GMT Sebastian Huber [e76470df] * testsuites/validation/tc-barrier-delete.c (modified) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-barrier-wait.c (modified) * testsuites/validation/tc-signal-send.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) * testsuites/validation/tc-task-create-errors.c (modified) validation: Use common wording Fri, 05 Mar 2021 20:18:55 GMT Sebastian Huber [1ce127e] * testsuites/validation/tc-barrier-create.c (modified) * testsuites/validation/tc-barrier-release.c (modified) * testsuites/validation/tc-message-construct-errors.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) * testsuites/validation/tc-task-create-errors.c (modified) validation: Use common wording Thu, 04 Mar 2021 19:00:25 GMT Ryan Long [f762b7c2] * bsps/shared/grlib/can/grcan.c (modified) grcan.c: Fix Unused value (CID #1437613) CID 1437613: Unused value ... Wed, 03 Mar 2021 21:07:37 GMT Ryan Long [c57079a] * bsps/shared/grlib/1553/b1553brm.c (modified) b1553brm.c: Fix Unsigned compared against 0 (CID #1399773) CID ... Wed, 03 Mar 2021 20:52:30 GMT Ryan Long [1f29ee4] * bsps/shared/grlib/can/satcan.c (modified) satcan.c: Fix Unsigned compared against 0 (CID #1399768) CID ... Tue, 02 Mar 2021 18:25:53 GMT Ryan Long [f8047788] * bsps/sparc/shared/pci/gr_cpci_gr740.c (modified) gr_cpci_gr740.c: Unchecked return value from library (CID #1437630) ... Tue, 02 Mar 2021 18:17:15 GMT Ryan Long [5f0a7ceb] * bsps/shared/grlib/pci/gr_tmtc_1553.c (modified) gr_tmtc_1553.c: Unchecked return value from library (CID #1399785) ... Tue, 02 Mar 2021 18:10:59 GMT Ryan Long [4c0d9c5a] * bsps/shared/grlib/pci/gr_701.c (modified) gr_701.c: Unchecked return value from library (CID #1399783) CID ... Tue, 02 Mar 2021 18:08:37 GMT Ryan Long [91e38f8] * bsps/shared/grlib/pci/gr_rasta_adcdac.c (modified) gr_rasta_adcdac.c: Fix Unchecked return value from library (CID ... Tue, 02 Mar 2021 18:05:57 GMT Ryan Long [17d525b5] * bsps/shared/grlib/pci/gr_rasta_tmtc.c (modified) gr_rasta_tmtc.c: Fix Unchecked return value from library (CID ... Tue, 02 Mar 2021 18:01:43 GMT Ryan Long [570b558] * bsps/sparc/shared/pci/gr_leon4_n2x.c (modified) gr_leon4_n2x.c: Fix Unchecked return value from library (CID ... Mon, 01 Mar 2021 21:33:10 GMT Ryan Long [0d33d10] * cpukit/libpci/pci_cfg_read.c (modified) pci_cfg_read.c: Fix Missing break in switch (CID #1399723) CID ... Tue, 02 Mar 2021 17:50:59 GMT Ryan Long [b84ce61] * bsps/shared/grlib/pci/gr_rasta_io.c (modified) gr_rasta_io.c: Fix Unchecked return value from library (CID #1399763) ... Tue, 02 Mar 2021 17:40:36 GMT Ryan Long [04436013] * bsps/shared/grlib/pci/gr_rasta_spw_router.c (modified) gr_rasta_spw_router.c: Fix Unchecked return value from library (CID ... Mon, 01 Mar 2021 21:06:41 GMT Ryan Long [c7eb89f8] * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) cpuusagetop.c: Fix three Missing break in switch Coverity errors ... Mon, 01 Mar 2021 20:33:06 GMT Ryan Long [13d6fae] * bsps/shared/grlib/tmtc/grtc.c (modified) grtc.c: Fix four Missing break in switch Coverity errors CID ... Mon, 01 Mar 2021 16:06:48 GMT Ryan Long [1eaf4e46] * bsps/shared/grlib/spw/grspw.c (modified) grspw.c: Fix Unchecked return value (CID #1399781) CID 1399781: ... Mon, 22 Feb 2021 15:39:59 GMT Jan Sommer [6ebf376b] * bsps/shared/dev/serial/zynq-uart.c (modified) bsps/shared: Allow setting baud rate for zynq uart Sat, 20 Feb 2021 03:29:27 GMT Kinsey Moore [f662420] * spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml (modified) spec/aarch64: Rename ZynqMP QEMU BSPs The current ZynqMP BSPs don't ... Fri, 08 Jan 2021 16:13:42 GMT Kinsey Moore [a27ba3f] * bsps/aarch64/shared/start/start.S (modified) bsps/aarch64: Add support for EL2 start Add the stub necessary to ... Mon, 15 Feb 2021 15:05:10 GMT Kinsey Moore [9951cee] * bsps/aarch64/shared/start/start.S (modified) * cpukit/score/cpu/aarch64/aarch64-exception-default.S (modified) bsps/aarch64: RTEMS_DEBUG stack alignment faults Run with stack ... Fri, 08 Jan 2021 01:39:20 GMT Kinsey Moore [9d77c0f4] * spec/build/bsps/arm/raspberrypi/grp.yml (modified) * spec/build/bsps/optstarthyp.yml (moved) spec: Move hypervisor start for use by AArch64 AArch64 on hardware ... Mon, 11 Jan 2021 17:56:36 GMT Alex White [07297812] * spec/build/bsps/aarch64/a53/tsta53.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml (modified) spec/aarch64: Remove sp37 from intermittent tests Mon, 11 Jan 2021 16:23:16 GMT Alex White [9aff7e56] * cpukit/score/cpu/aarch64/cpu.c (modified) * cpukit/score/cpu/aarch64/include/rtems/score/cpu.h (modified) score/aarch64: Fix interrupt level reads Mon, 15 Feb 2021 16:51:37 GMT Kinsey Moore [bbc9974a] * cpukit/include/rtems/linkersets.h (modified) cpukit: Explicitly enforce alignment requirements According to ... Tue, 02 Mar 2021 20:11:49 GMT Kinsey Moore [2ee12f02] * bsps/aarch64/xilinx-zynqmp/include/tm27.h (modified) * bsps/include/dev/irq/arm-gic-tm27.h (modified) bsps: Allow override of ARM TM27 IRQs ZynqMP hardware appears to ... Fri, 19 Feb 2021 14:34:48 GMT Kinsey Moore [6bfbfb5] * bsps/aarch64/shared/start/linkcmds.base (modified) * spec/build/bsps/aarch64/a53/linkcmds_ilp32.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml (modified) bsps/aarch64: Resolve usage of SUBALIGN() Remove usage of ... Thu, 04 Mar 2021 07:12:47 GMT Sebastian Huber [61d688bf] * cpukit/score/cpu/aarch64/cpu_asm.S (modified) aarch64: Fix context switch The ... Wed, 03 Mar 2021 08:23:20 GMT Sebastian Huber [5248395] * cpukit/include/rtems/score/context.h (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/tls.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/tlsallocsize.c (modified) score: Ensure stack alignment requirement Make sure that a ... Wed, 03 Mar 2021 08:36:45 GMT Sebastian Huber [1de00d6] * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems/confdefs/threads.h (modified) * testsuites/sptests/spfatal33/init.c (modified) CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE Ensure that ... Wed, 03 Mar 2021 09:27:52 GMT Sebastian Huber [8fe59be] * spec/build/bsps/aarch64/a53/tsta53.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml (modified) * testsuites/validation/tc-message-construct-errors.c (modified) validation: Fix for 64-bit targets Closes #4179. Wed, 03 Mar 2021 07:04:55 GMT Sebastian Huber [30f6fd5b] * cpukit/include/rtems/rtems/tasks.h (modified) rtems: Fix RTEMS_TASK_STORAGE_ALIGNMENT Make sure we meet the stack ... Wed, 03 Mar 2021 07:39:33 GMT Sebastian Huber [4a765b47] * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/src/percpuasm.c (modified) score: Enforce CPU_STACK_ALIGNMENT requirements Clarify ... Thu, 25 Feb 2021 08:47:08 GMT Jan Sommer [a510e243] * MAINTAINERS (modified) MAINTAINERS: Add myself to write after approval
