# # ChangeLog for tools in rtems-tools # # Generated by Trac 1.2.1.dev0 # 04/24/24 16:57:12 Mon, 15 Jul 2013 23:58:54 GMT Chris Johns [98f78dc] * tools/4.11/gcc/gcc-4.8.1-rtems4.11-20130709.diff (added) The __cxa_atexit support is a reqirement for destructor registration ... Thu, 30 May 2013 23:43:40 GMT Chris Johns [6651de8] * tools/4.11/newlib/newlib-sys-signal-20130532.diff (added) Add Joel's stack_t patch. Wed, 22 May 2013 06:47:01 GMT Amar Takhar [bba0b78] * tools/4.11/newlib/powerpc/newlib-remove-machine-powerpc-times_c.diff (added) Add patch to remove times.c from PowerPC newlib. Thu, 16 May 2013 08:13:31 GMT Amar Takhar [acdef36] * tools/4.11/binutils/moxie/binutils-2.22-rtems4.11-moxie-20130516.diff (added) Add three patches from Anthony Green to fix moxie tools. ... Sun, 14 Apr 2013 22:25:05 GMT Chris Johns [440c97f] * tools/4.11/gcc/gcc-4.7.3-rtems4.11-20130413.diff (deleted) * tools/4.11/gcc/gcc-4.7.3-rtems4.11-20130414.diff (added) Regenerate the patch cleanly. Sat, 13 Apr 2013 08:23:52 GMT Chris Johns [65575cc] * tools/4.11/gcc/gcc-4.7.3-rtems4.11-20130413.diff (added) Update the 4.7.2 patch to 4.7.3. Fri, 05 Apr 2013 03:24:01 GMT Chris Johns [eba19fa] * tools/4.11/gcc/arm/gcc-4.7-rtems4.11-arm-eabi-libcpp-20130403.diff (added) * tools/4.11/gcc/arm/gcc-arm-to-eabi-part2-20130402.diff (deleted) Update to the patch Joel merged. Tue, 02 Apr 2013 21:39:03 GMT Chris Johns [926ef3c] * tools/4.11/gcc/arm/gcc-arm-to-eabi-part2-20130402.diff (added) PR target/56771. Require 64-bit int for arm*-*-rtems[.0-9]*. Tue, 02 Apr 2013 06:48:38 GMT Chris Johns [9d711f4] * tools/4.10/binutils/cygwin/binutils-2.20.1-cygwin-w64-20130324.diff (added) Fix to build in cygwin. Wed, 20 Mar 2013 06:27:49 GMT Chris Johns [4c5ffb2] * tools/4.10/gdb/bfin/gdb-7.3.1-bfin-sim-fix-sed-20130319.diff (added) Fix the sed breakage on FreeBSD. Tue, 19 Mar 2013 06:16:54 GMT Chris Johns [038b250] * tools/4.10/binutils/binutils-2.20.1-rtems4.10-20100826.diff (added) * tools/4.10/gcc/gcc-core-4.4.7-rtems4.10-20120314.diff (added) * tools/4.10/gcc/gcc-g++-4.4.7-rtems4.10-20120314.diff (added) * tools/4.10/gdb/gdb-7.3.1-rtems4.10-20120918.diff (added) * tools/4.10/newlib/newlib-1.18.0-rtems4.10-20110518.diff (added) Add the current rtems-4.10 patches. Fri, 15 Mar 2013 01:10:20 GMT Chris Johns [ce77d87] * tools/4.9/gcc/gcc-core-4.3.2-rtems4.9-20090825.diff (added) * tools/4.9/gdb/gdb-6.8-rtems4.9-20091111.diff (added) * tools/4.9/newlib/newlib-1.16.0-rtems4.9-20090324.diff (added) Import the 4.9 patches. Mon, 11 Mar 2013 08:31:18 GMT Sebastian Huber [f0c9bae] * tools/4.11/gcc/arm/gcc-4.7-arm-to-eabi-20120511-2.diff (deleted) * tools/4.11/gcc/arm/gcc-4.7-arm-to-eabi-20130306.diff (moved) Add latest GCC 4.7 ARM to EABI patch This patch is included in the ... Mon, 11 Mar 2013 06:16:02 GMT Chris Johns [cb328a1] * tools/4.11/gcc/arm/gcc-4.7-arm-to-eabi-20120511-2.diff (added) Regenerate the ARM EABI patch for gcc-4.7.2 sources. Mon, 11 Mar 2013 00:50:53 GMT Chris Johns [94c5d74] * tools/4.11/gcc/arm/gcc-4.7-arm-to-eabi-20120511.diff (added) ARM EABI patch. Sun, 10 Mar 2013 22:28:55 GMT Chris Johns [e42bad3] * tools/4.11/binutils/binutils-2.22-rtems4.11-20120427.diff (added) * tools/4.11/binutils/moxie/binutils-2.22-rtems4.11-moxie-20130214.diff (added) * tools/4.11/binutils/nios2/nios2-binutils-2.20-rtems-20110703.diff (added) * tools/4.11/gcc/gcc-4.5.3-strsignal-1.diff (added) * tools/4.11/gcc/gcc-4.7.2-rtems4.11-20121026.diff (added) * tools/4.11/gcc/nios2/nios2-gcc-4.1-rtems-20110818.diff (added) * tools/4.11/gdb/gdb-7.5-rtems4.11-20121003.diff (added) * tools/4.11/gdb/moxie/gdb-7.5.1-rtems4.11-moxie-20130214.diff (added) * tools/4.11/newlib/nios2/nios2-newlib-1.19.0-rtems-20110720.diff (added) Move current patches in to the repo. Sun, 10 Mar 2013 03:31:57 GMT Chris Johns [5749230] * tools/4.11/gcc/microblaze/gcc-4.7.2-microblaze-ldscript-2.diff (added) Regerated version of Joel's patch so patch -p1 works. Sun, 10 Mar 2013 01:35:37 GMT Chris Johns [0e90000] * tools/4.11/gcc/microblaze/gcc-4.7.2-microblaze-ldscript-1.diff (moved) Use a better name for the patch. Sun, 10 Mar 2013 01:27:22 GMT Chris Johns [25e43e1] * tools/4.11/gcc/microblaze/rtems-gcc-microblaze-ldscript-1.diff (added) Microblaze gcc-4.7.2 patch from Joel. Fri, 08 Mar 2013 07:44:32 GMT Chris Johns [df78032] * tools/4.11/newlib/mips/newlib-2.0.0-mips-memcpy-20130107.diff (added) * tools/4.11/newlib/mips/newlib-2.0.0-mips-memcpy-20130219.diff (added) MIPS memcpy fixes. ...
