# # ChangeLog for tools in rtems-tools # # Generated by Trac 1.2.1.dev0 # 05/04/24 22:17:30 Tue, 21 Mar 2017 14:55:19 GMT Sebastian Huber [7ef4c2b] * tools/4.11/newlib/arm/newlib-ARM-Optimize-IEEE-754-sqrt-implementation.diff (modified) patch: ARM: Fix IEEE-754 sqrt optimization Update #2948. Tue, 21 Mar 2017 14:06:07 GMT Sebastian Huber [d1f542f] * tools/4.11/newlib/arm/newlib-ARM-Optimize-IEEE-754-sqrt-implementation.diff (added) patch: ARM: Optimize IEEE-754 sqrt implementation Update #2948. Fri, 23 Dec 2016 08:06:01 GMT Sebastian Huber [516f931] * tools/4.12/newlib/RTEMS-Add-user-defined-name-to-thread-queues.patch (added) Add Newlib patch for RTEMS 4.12 Tue, 15 Nov 2016 00:00:08 GMT Joel Sherrill [e2af743] * tools/4.12/gdb/gdb-7.11-sis-leon2-leon3.diff (added) Add 4.12/.../gdb-7.11-sis-leon2-leon3.diff from gaisler.org Mon, 14 Nov 2016 22:04:04 GMT Joel Sherrill [b5caf21] * tools/4.12/binutils/binutils-2.26-gas-reloc.patch (added) Add 4.12/.../binutils-2.26-gas-reloc.patch from gaisler.org Fri, 02 Sep 2016 08:16:57 GMT Chris Johns [4fdd883] * tools/4.10/newlib/nios2/nios2-newlib-1.19.0-rtems-20110720.diff (added) 4.10: Add NIOS2 newlib patch. Fri, 02 Sep 2016 08:03:11 GMT Chris Johns [32b861f] * tools/4.10/gcc/nios2/nios2-gcc-4.1-rtems-20110818.diff (added) 4.10: Add NIOS2 gcc patch. Fri, 02 Sep 2016 07:56:09 GMT Chris Johns [5af5b04] * tools/4.10/binutils/nios2/nios2-binutils-2.20-rtems-20110703.diff (added) 4.10: Add NIOS2 binutils patch. Fri, 02 Sep 2016 07:00:50 GMT Chris Johns [a46a8d3] * tools/4.10/gdb/patch-gdb-python-python-config.py (added) 4.10: Add FreeBSD Python patch. Fri, 02 Sep 2016 06:56:49 GMT Chris Johns [3f17371] * tools/4.10/gdb/gdb-7.11-erc32-common-run.diff (added) * tools/4.10/gdb/gdb-7.11-erc32-endian-fix.diff (added) * tools/4.10/gdb/gdb-7.11-erc32-printf_filtered.diff (added) 4.10: Add the gdb-7.11 ERC patches to 4.10. Fri, 02 Sep 2016 03:18:17 GMT Chris Johns [3581fab] * tools/4.10/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff (added) 4.10: Add the automake patch to the 4.10 patches. Wed, 16 Mar 2016 04:18:34 GMT Chris Johns [0bbd2de] * .gitignore (modified) * tools/4.12/gdb/gdb-7.11-erc32-common-run.diff (added) * tools/4.12/gdb/gdb-7.11-erc32-endian-fix.diff (added) * tools/4.12/gdb/gdb-7.11-erc32-printf_filtered.diff (added) 4.12: Patches for ERC simualtor for gdb-7.11. The patches fix the ... Fri, 11 Mar 2016 07:12:55 GMT Chris Johns [a44fedf] * tools/4.12/gdb/gdb-7.11-aarch64-x86_64.patch (added) Add a gdb-7.11 patch for 4.12. Thu, 07 Jan 2016 14:14:29 GMT Götz Pfeiffer [87bca99] * tools/4.10/gdb/gdb-7.3.1-rtems4.10-20151123.diff (added) Bugfix: gdb-7.3.1 couldn't be build with a modern texinfo package. ... Thu, 07 Jan 2016 14:13:50 GMT Götz Pfeiffer [47ec083] * tools/4.10/gcc/gcc-core-4.4.7-rtems4.10-20151123.diff (added) Bugfix: gcc-4.4.7 couldn't be build with a modern texinfo package. ... Thu, 07 Jan 2016 14:13:05 GMT Götz Pfeiffer [45d2402] * tools/4.10/binutils/binutils-2.20.1-rtems4.10-20151123.diff (added) Bugfix: binutils-2.20.1 couldn't be build with a modern texinfo ... Mon, 29 Feb 2016 07:02:36 GMT Chris Johns [0e5d89d] * tools/4.12/binutils/binutils-2.26-rtems-aarch64-x86_64.patch (added) * tools/4.12/gdb/gdb-7.9-aarch64-x86_64.patch (added) Add aarch64 and x86_64 binutils and gdb patches. Sun, 28 Feb 2016 21:59:26 GMT Chris Johns [6bc1ece] * tools/4.12/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff (added) Fix ithe automake warning with newer perl versions. This patch is ... Fri, 19 Feb 2016 03:46:15 GMT Chris Johns [7148cae] * linkers/wscript (modified) * rtemstoolkit/wscript (modified) * tester/covoar/wscript (modified) * tester/wscript (modified) * tools/gdb/python/wscript (modified) * wafwindows.py (added) * wscript (modified) Add Windows specific waf support for MSYS2. Limit the compilers ... Fri, 19 Feb 2016 00:26:51 GMT Chris Johns [de1beea] * rtemstoolkit/config.py (modified) * rtemstoolkit/execute.py (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/path.py (modified) * rtemstoolkit/version.py (modified) * rtemstoolkit/wscript (modified) * tester/rtems-test (modified) * tester/wscript (modified) * tools/gdb/python/wscript (modified) * wscript (modified) Disable installing PYO and PYC. Fix install paths. Installing PYO ... Thu, 12 Nov 2015 10:15:23 GMT Sebastian Huber [04a5204] * rtemstoolkit/check.py (modified) * rtemstoolkit/config.py (modified) * rtemstoolkit/error.py (modified) * rtemstoolkit/execute.py (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/mailer.py (modified) * rtemstoolkit/options.py (modified) * rtemstoolkit/path.py (modified) * rtemstoolkit/version.py (modified) * tester/rt/config.py (modified) * tester/rt/console.py (modified) * tester/rt/gdb.py (modified) * tester/rt/options.py (modified) * tester/rt/pygdb/mi_parser.py (modified) * tester/rt/pygdb/spark.py (modified) * tester/rt/stty.py (modified) * tester/rt/test.py (modified) * tester/rt/version.py (modified) * tools/gdb/python/__init__.py (modified) * tools/gdb/python/classic.py (modified) * tools/gdb/python/heaps.py (modified) * tools/gdb/python/helper.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/sparc.py (modified) * tools/gdb/python/supercore.py (modified) * tools/gdb/python/watchdog.py (modified) Python 3 compatibility Thu, 12 Nov 2015 06:48:45 GMT Chris Johns [ab922fe] * tools/4.12/gdb/gdb-sim-arange-inline.diff (added) * tools/4.12/gdb/gdb-sim-cgen-inline.diff (added) * tools/4.12/gdb/patch-gdb-python-python-config.py (added) Add tools patches for RTEMS 4.12. Mon, 10 Aug 2015 12:48:58 GMT YANG Qiao [45d4773] * tools/4.11/microwindows/microwindows-0.93-dev-without-keyboard.diff (added) * tools/4.11/microwindows/microwindows-0.93-dev.diff (added) add microwindows patches Thu, 02 Apr 2015 18:16:56 GMT Hesham ALMatary [b6b784c] * tools/qemu/0001-openrisc-terminate-qemu-process-upon-receiving-a-hal.patch (added) Add QEMU patch for openrisc to recognize halt signals Thu, 02 Apr 2015 14:52:42 GMT Joel Sherrill [bbad85e] * tools/4.11/gdb/lm32/gdb-7.9-lm32uart.diff (added) Update gdb-sim-lm32uart.diff to gdb-7.9 Thu, 26 Mar 2015 18:20:45 GMT Joel Sherrill [bfd2b7d] * tools/4.11/gdb/sparc/7.9/0001-sim-erc32-Disassembly-in-stand-alone-mode-did-not-wo.patch (added) * tools/4.11/gdb/sparc/7.9/0002-sim-erc32-Corrected-wrong-CPU-implementation-and-ver.patch (added) * tools/4.11/gdb/sparc/7.9/0003-sim-erc32-Perform-pseudo-init-if-binary-linked-to-no.patch (added) * tools/4.11/gdb/sparc/7.9/0004-sim-erc32-Use-fenv.h-for-host-FPU-access.patch (added) * tools/4.11/gdb/sparc/7.9/0005-sim-erc32-Remove-unused-defines-in-Makefile-and-swit.patch (added) * tools/4.11/gdb/sparc/7.9/0006-sim-erc32-Fix-incorrect-simulator-performance-report.patch (added) * tools/4.11/gdb/sparc/7.9/0007-sim-erc32-File-loading-via-command-line-did-not-work.patch (added) * tools/4.11/gdb/sparc/7.9/0008-sim-erc32-Added-v-command-line-switch-for-verbose-ou.patch (added) * tools/4.11/gdb/sparc/7.9/0009-sim-erc32-Removed-type-mismatch-compiler-warnings.patch (added) * tools/4.11/gdb/sparc/7.9/0010-sim-erc32-Switched-emulated-memory-to-host-endian-or.patch (added) * tools/4.11/gdb/sparc/7.9/0011-sim-erc32-use-SIM_AC_OPTION_HOSTENDIAN-to-probe-for-.patch (added) * tools/4.11/gdb/sparc/7.9/0012-sim-erc32-Use-memory_iread-function-for-instruction-.patch (added) * tools/4.11/gdb/sparc/7.9/0013-sim-erc32-Fix-a-few-compiler-warnings.patch (added) * tools/4.11/gdb/sparc/7.9/0014-sim-erc32-Use-gdb-callback-for-UART-I-O-when-linked-.patch (added) * tools/4.11/gdb/sparc/7.9/0015-sim-erc32-Access-memory-subsystem-through-struct-mem.patch (added) * tools/4.11/gdb/sparc/7.9/0016-sim-erc32-Use-readline.h-for-readline-types-and-func.patch (added) * tools/4.11/gdb/sparc/7.9/0017-sim-erc32-Move-local-extern-declarations-into-sis.h.patch (added) * tools/4.11/gdb/sparc/7.9/0018-sim-erc32-Add-support-for-LEON3-processor-emulation.patch (added) * tools/4.11/gdb/sparc/7.9/0019-sim-erc32-Add-support-for-LEON2-processor-emulation.patch (added) * tools/4.11/gdb/sparc/7.9/0020-sim-erc32-Updated-documentation.patch (added) * tools/4.11/gdb/sparc/7.9/0021-sim-erc32-Add-data-watchpoint-support.patch (added) * tools/4.11/gdb/sparc/7.9/0022-Add-watchpoint-support-to-gdb-simulator-interface.patch (added) * tools/4.11/gdb/sparc/7.9/0023-sim-erc32-ELF-loading-could-fail-on-unaligned-sectio.patch (added) Add Jiri Gaisler SIS patch set for gdb 7.9 This patch set adds a ... Tue, 17 Mar 2015 02:11:57 GMT Chris Johns [b117be8] * tools/gdb/python/chains.py (modified) * tools/gdb/python/classic.py (modified) * tools/gdb/python/mutex.py (added) * tools/gdb/python/rbtrees.py (added) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/threads.py (modified) * tools/gdb/python/time.py (added) gdb/python: Update the support to a recent RTEMS. Sun, 22 Feb 2015 06:07:10 GMT Adit Sahasrabudhe [01a4192] * tester/wscript (modified) * tools/gdb/python/wscript (modified) Modified waf scripts to have a minimum python version requirement of ... Sun, 08 Feb 2015 06:12:04 GMT Chris Johns [b7d48ef] * linkers/wscript (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/wscript (modified) * tester/rt/options.py (modified) * tester/rt/test.py (modified) * tester/rtems-test (modified) * tester/rtems/testing/defaults.mc (modified) * tester/wscript (modified) * tools/gdb/python/wscript (modified) Install the rtems-test command. This installs the Python RTEMS ... Fri, 09 Jan 2015 14:37:25 GMT Sebastian Huber [3f47178] * tools/4.11/gcc/powerpc/gcc-4.9.2-RTEMS-Add-e6500-multilibs-for-PowerPC.patch (added) * tools/4.11/gcc/powerpc/gcc-4.9.2-RTEMS-Fix-MPC8540-multilibs-for-PowerPC.patch (added) * tools/4.11/gcc/powerpc/gcc-4.9.2-RTEMS-Use-MULTILIB_REQUIRED-for-PowerPC.patch (added) Add PowerPC patches for GCC 4.9.2 Thu, 04 Dec 2014 12:02:27 GMT Sebastian Huber [d8a82fd] * tools/4.11/gcc/sparc/gcc-4.9.2-leon3v7.diff (added) * tools/4.11/gcc/sparc/gcc-4.9.2-rtems-multilibs.diff (added) Add SPARC patches for GCC 4.9.2 These patches are already present ... Fri, 14 Nov 2014 22:19:09 GMT Jiri Gaisler [af8c147a] * tools/4.11/gdb/sparc/gdb-7.7-7.8-sis-leon2-leon3-fixup.diff (modified) gdb patch to add leon2/3 support to sis This fixes the commit ... Tue, 02 Dec 2014 04:50:02 GMT Chris Johns [4bdba3e] * tools/4.11/gdb/sparc/gdb-7.7-7.8-sis-leon2-leon3-fixup.diff (added) tools/gdb: Add a patch for gdb-7.7/gdb-7.8 SPARC. This patch ... Sat, 13 Sep 2014 00:47:07 GMT Chris Johns [749ddf1] * .gitignore (modified) * README (modified) * linkers/wscript (modified) * tester/covoar/wscript (modified) * tester/wscript (added) * tools/gdb/python/wscript (modified) * waf (added) * wscript (added) waf: Include waf in the souce tree and updated README on building. ... Tue, 26 Aug 2014 04:57:57 GMT Chris Johns [3162858] * tools/gdb/python/__init__.py (modified) * tools/gdb/python/chains.py (modified) * tools/gdb/python/classic.py (modified) * tools/gdb/python/configuration.py (added) * tools/gdb/python/heaps.py (modified) * tools/gdb/python/helper.py (modified) * tools/gdb/python/objects.py (modified) * tools/gdb/python/percpu.py (added) * tools/gdb/python/pretty.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/sparc.py (modified) * tools/gdb/python/supercore.py (modified) * tools/gdb/python/supercore_printer.py (modified) * tools/gdb/python/threads.py (modified) * tools/gdb/python/watchdog.py (modified) * tools/gdb/python/wscript (modified) gdb-python: Update so 'rtems task' lists the classic tasks. This is ... Sun, 24 Aug 2014 23:40:57 GMT Chris Johns [504e1de] * tools/gdb/python/wscript (added) gdb-python: Add waf script to install under a prefix. Sun, 24 Aug 2014 23:39:26 GMT Chris Johns [f750e82] * tools/gdb/python/.gitignore (modified) gdb-python: Clean up and ignore waf generated files. Mon, 26 Aug 2013 16:42:25 GMT Dhananjay Balan [bd0b98d] * tools/gdb/python/classic.py (modified) * tools/gdb/python/sparc.py (modified) Add cpu registers to task output. Mon, 26 Aug 2013 15:35:59 GMT Dhananjay Balan [5a4834c] * tools/gdb/python/rtems.py (modified) Remove the header. Mon, 26 Aug 2013 15:26:30 GMT Dhananjay Balan [61154bf] * tools/gdb/python/main.py (modified) * tools/gdb/python/objects.py (modified) * tools/gdb/python/rtems.py (modified) Add watchdog seconds command - prints the watchdog chain managed at ... Mon, 26 Aug 2013 15:05:57 GMT Dhananjay Balan [1fcff75] * tools/gdb/python/objects.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/watchdog.py (modified) Fix wdticks command - Type is Chain_Control - chain.node.next -> null Sun, 25 Aug 2013 17:34:20 GMT Dhananjay Balan [a4d0739] * tools/gdb/python/helper.py (modified) Add helper func. - tests a bit at specified position. Sun, 25 Aug 2013 17:33:44 GMT Dhananjay Balan [a7176a8] * tools/gdb/python/chains.py (modified) * tools/gdb/python/main.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/watchdog.py (modified) Add watchdog ticks command. - ToDo : Fix watchdog states. Sun, 25 Aug 2013 13:00:48 GMT Dhananjay Balan [04d95ec] * tools/gdb/python/sparc.py (modified) Added register class - sparc.register, basic represenation of ... Sun, 25 Aug 2013 09:26:57 GMT Dhananjay Balan [788a715] * tools/gdb/python/sparc.py (added) Add sparc PSR - added a class to print SPARC status register Sat, 24 Aug 2013 14:56:06 GMT Dhananjay Balan [7a415d4] * tools/gdb/python/classic.py (modified) * tools/gdb/python/objects.py (modified) * tools/gdb/python/threads.py (modified) Catch empty task names, - All the tasks do not have a name. Sat, 24 Aug 2013 09:38:16 GMT Dhananjay Balan [a245635] * tools/gdb/python/main.py (modified) * tools/gdb/python/objects.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/supercore.py (modified) Add subcommand rtems tod - prints the time of day. Fri, 23 Aug 2013 04:28:22 GMT Dhananjay Balan [a0bf9f2] * tools/gdb/python/README.md (modified) Update README.md Fix Links. Fri, 23 Aug 2013 04:25:48 GMT Dhananjay Balan [b5c4f41] * tools/gdb/python/README.md (modified) Update README.md Fix indentation. Fri, 23 Aug 2013 04:25:07 GMT Dhananjay Balan [52fc200] * tools/gdb/python/README.md (modified) Update Readme. Add wiki pages, usage instructions etc. Wed, 21 Aug 2013 13:01:01 GMT Dhananjay Balan [8da0a37] * tools/gdb/python/rtems.py (modified) Complete index subcommands. Wed, 21 Aug 2013 12:42:36 GMT Dhananjay Balan [ddbc530] * tools/gdb/python/rtems.py (modified) Refactor subcommands - index commands inherit from a parent class. Tue, 20 Aug 2013 16:28:16 GMT Dhananjay Balan [d4fc2d5] * tools/gdb/python/rtems.py (modified) Categories the commands. The subcommands fall onto DATA. See ... Tue, 20 Aug 2013 16:17:22 GMT Dhananjay Balan [8d035f8] * tools/gdb/python/__init__.py (modified) * tools/gdb/python/helper.py (modified) * tools/gdb/python/main.py (added) * tools/gdb/python/pretty.py (added) * tools/gdb/python/rtems.py (modified) Refactor - pretty printers moved to pretty module - command and ... Thu, 15 Aug 2013 14:56:30 GMT Dhananjay Balan [2c25dc5] * tools/gdb/python/rtems.py (modified) Add message_queue subcommand. Fri, 09 Aug 2013 12:16:37 GMT Dhananjay Balan [b743d63] * tools/gdb/python/rtems.py (modified) Catch nonvalid indexes. Catch IndexErrors generated while ... Fri, 09 Aug 2013 12:14:18 GMT Dhananjay Balan [a713688] * tools/gdb/python/rtems.py (modified) Add task subcommand rtems tasks - Prints tasks by index. Fri, 09 Aug 2013 08:37:43 GMT Dhananjay Balan [4797179] * tools/gdb/python/rtems.py (modified) Add subcommand semaphore rtems semaphore : prints rtems ... Sun, 04 Aug 2013 18:47:39 GMT Dhananjay Balan [559bd50] * tools/gdb/python/rtems.py (modified) Catch invalid object ID. Sun, 04 Aug 2013 18:37:47 GMT Dhananjay Balan [66d0779] * tools/gdb/python/classic.py (modified) Barrier taks queue Print the barrier taks queue. Thu, 01 Aug 2013 06:50:23 GMT Dhananjay Balan [6d89e3c] * tools/gdb/python/classic.py (modified) * tools/gdb/python/rtems.py (modified) Refactor - The objects are intialized using the objects rather ... Tue, 30 Jul 2013 03:24:35 GMT Dhananjay Balan [e60a5ee] * tools/gdb/python/classic.py (modified) * tools/gdb/python/supercore_printer.py (modified) * tools/gdb/python/threads.py (modified) Fix Task and state printer bugs. - Removed ITRON api objects in ... Mon, 29 Jul 2013 10:54:24 GMT Dhananjay Balan [e282b6e] * tools/gdb/python/README.md (modified) Move todo Why else is there issues? Mon, 29 Jul 2013 04:56:02 GMT Dhananjay Balan [59c4946] * tools/gdb/python/README.md (modified) New todo Mon, 29 Jul 2013 04:55:38 GMT Dhananjay Balan [8e0de06] * tools/gdb/python/classic.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/supercore.py (modified) Add classic barrier. - Add support for classic barrier object. - ... Sun, 28 Jul 2013 12:25:22 GMT Dhananjay Balan [c63080d] * tools/gdb/python/README.md (modified) Update Readme. ToDo. Sun, 28 Jul 2013 09:15:58 GMT Dhananjay Balan [b9ee5df] * tools/gdb/python/classic.py (modified) * tools/gdb/python/heaps.py (modified) * tools/gdb/python/helper.py (modified) * tools/gdb/python/objects.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/supercore.py (modified) Add region support. Abstractions for classic/region added. Sun, 28 Jul 2013 07:31:06 GMT Dhananjay Balan [c3d06d5] * tools/gdb/python/heaps.py (added) Abstraction for HEAP. Heap_Control Abstraction is added. It will ... Sat, 27 Jul 2013 08:41:19 GMT Dhananjay Balan [09086b4] * tools/gdb/python/classic.py (modified) * tools/gdb/python/classic_printer.py (modified) * tools/gdb/python/rtems.py (modified) Support classic/partitions Added support for partition object. Wed, 17 Jul 2013 10:30:57 GMT Dhananjay Balan [086e689] * tools/gdb/python/classic.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/watchdog.py (modified) Added support for classic/timers. Tue, 16 Jul 2013 12:47:03 GMT Dhananjay Balan [591fbf6] * tools/gdb/python/objects.py (modified) Fix typo: Global timer control object name. Sat, 13 Jul 2013 11:01:59 GMT Dhananjay Balan [0967a1b] * tools/gdb/python/__init__.py (modified) * tools/gdb/python/classic.py (modified) * tools/gdb/python/classic_printer.py (modified) * tools/gdb/python/helper.py (added) * tools/gdb/python/objects.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/supercore.py (modified) * tools/gdb/python/supercore_printer.py (modified) Refactoring - drop _printer suffix from printer classes. Fri, 12 Jul 2013 13:37:46 GMT Dhananjay Balan [a785e25] * tools/gdb/python/classic_printer.py (added) * tools/gdb/python/supercore.py (added) * tools/gdb/python/supercore_printer.py (added) Add printers to stage. Fri, 12 Jul 2013 13:34:37 GMT Dhananjay Balan [b061a67] * tools/gdb/python/__init__.py (modified) * tools/gdb/python/chains.py (modified) * tools/gdb/python/classic.py (modified) * tools/gdb/python/objects.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/threads.py (modified) Heavy refactoring + Improved mesege queu printing. - pretty printers ... Tue, 09 Jul 2013 16:51:27 GMT Dhananjay Balan [6e75f4e] * tools/gdb/python/README.md (modified) Update readme. Included useage instructions. Tue, 09 Jul 2013 09:07:20 GMT Dhananjay Balan [3856406] * tools/gdb/python/classic.py (modified) * tools/gdb/python/objects.py (modified) Fix pretty printers pretty printers for rtems_id and rtems_attribute Mon, 08 Jul 2013 16:12:48 GMT Dhananjay Balan [f814c76] * tools/gdb/python/classic.py (modified) * tools/gdb/python/rtems.py (modified) Messege Queue Objects Added intial support for printing Mon, 08 Jul 2013 16:10:21 GMT Dhananjay Balan [ce55b57] * tools/gdb/python/objects.py (modified) Object can have index from 1 to 'maximum' Mon, 24 Jun 2013 04:10:59 GMT Dhananjay Balan [10bcd5d] * tools/gdb/python/chains.py (modified) * tools/gdb/python/objects.py (modified) * tools/gdb/python/threads.py (modified) Update chains structures - Fixes chains structure parsing - Fix ... Mon, 17 Jun 2013 17:10:17 GMT Dhananjay Balan [56a70ae] * tools/gdb/python/__init__.py (added) * tools/gdb/python/chains.py (added) * tools/gdb/python/classic.py (added) * tools/gdb/python/objects.py (added) * tools/gdb/python/rtems.py (added) * tools/gdb/python/threads.py (added) * tools/gdb/python/watchdog.py (added) Intial commit. Chris's intial work on the extenstions. Mon, 17 Jun 2013 15:31:09 GMT Dhananjay Balan [911e710] * tools/gdb/python/.gitignore (added) * tools/gdb/python/README.md (added) Initial commit Mon, 07 Jul 2014 21:23:47 GMT Joel Sherrill [8101cf0] * tools/4.11/newlib/newlib-sys-cpuset-const-20140414.diff (added) Add newlib-sys-cpuset-const-20140414.diff Mon, 23 Jun 2014 01:00:30 GMT Chris Johns [8cfeec3] * tools/4.11/net-snmp/rtems-net-snmp-5.7.2.1-20140623.patch (added) 4.11: Patch so net-snmp 5.7.2.1 builds with RTEMS. Mon, 16 Jun 2014 03:11:28 GMT Chris Johns [f25fed3] * tools/4.11/ntp/rtems-ntp-4.2.6p5.diff (added) 4.11: Add ntp patch. This patch has issues related to the clock ... Mon, 19 May 2014 02:49:52 GMT Chris Johns [5cdcde1] * tools/4.11/gdb/sparc/gdb-7.7-sis-output-nouartrx.diff (added) 4.11/sparc: GDB 7.7 SIS simulator output patch. Thu, 08 May 2014 12:39:07 GMT Chris Johns [47d652c] * tools/4.11/gdb/lm32/gdb-sim-lm32uart.diff (added) gdb: Fix lm32 simulator's UART code. Builds on MinGW. Wed, 30 Apr 2014 13:13:14 GMT Chris Johns [a35f890] * tools/4.11/gdb/gdb-sim-cgen-inline.diff (added) tools/gdb: Simulator inline fixes in the cgen code. Wed, 30 Apr 2014 06:22:37 GMT Chris Johns [9e78f60] * tools/4.11/gcc/microblaze/rtems-gcc-microblaze-libgcc-20131017.diff (added) tools/microblaze: Fix the building of libgcc. Thu, 10 Apr 2014 08:21:01 GMT Chris Johns [f756b51] * tools/4.11/gdb/gdb-sim-arange-inline.diff (added) gdb: pr 16827, fix sim on Mavrick. Thu, 20 Mar 2014 20:21:16 GMT Joel Sherrill [ec18d1d] * tools/4.11/gcc/v850/gcc-4.8.2-rtems4.11-20140349.diff (added) gcc-4.8.2-rtems4.11-20140349.diff: New file Wed, 19 Mar 2014 04:15:31 GMT Chris Johns [e959da9] * tools/4.11/gdb/patch-gdb-python-python-config.py (added) 4.11/gdb: Fix detecting python when building GDB on FreeBSD 10.0. ... Wed, 12 Feb 2014 02:18:33 GMT Chris Johns [8f75c4a] * tools/libffi/libffi-pkg-config-lib64-fix.diff (added) libffi: Fix for Fedora 64bit pkg-config file. Sat, 18 Jan 2014 06:27:13 GMT Chris Johns [29734ec] * tools/4.11/gdb/sparc/gdb-7.6.2-sis-output-nouartrx.diff (added) gdb/sparc: SIS gdb output fix, add nouartrx. Fix the output from ... Wed, 14 Aug 2013 03:49:27 GMT Chris Johns [b2589cb] * tools/4.11/gcc/gcc-rtems-thread-model-posix-1.diff (added) gcc: Switch GCC to the posix thread model. Change from the RTEMS ... Mon, 15 Jul 2013 23:58:54 GMT Chris Johns [98f78dc] * tools/4.11/gcc/gcc-4.8.1-rtems4.11-20130709.diff (added) The __cxa_atexit support is a reqirement for destructor registration ... Thu, 30 May 2013 23:43:40 GMT Chris Johns [6651de8] * tools/4.11/newlib/newlib-sys-signal-20130532.diff (added) Add Joel's stack_t patch. Wed, 22 May 2013 06:47:01 GMT Amar Takhar [bba0b78] * tools/4.11/newlib/powerpc/newlib-remove-machine-powerpc-times_c.diff (added) Add patch to remove times.c from PowerPC newlib. Thu, 16 May 2013 08:13:31 GMT Amar Takhar [acdef36] * tools/4.11/binutils/moxie/binutils-2.22-rtems4.11-moxie-20130516.diff (added) Add three patches from Anthony Green to fix moxie tools. ... Sun, 14 Apr 2013 22:25:05 GMT Chris Johns [440c97f] * tools/4.11/gcc/gcc-4.7.3-rtems4.11-20130413.diff (deleted) * tools/4.11/gcc/gcc-4.7.3-rtems4.11-20130414.diff (added) Regenerate the patch cleanly. Sat, 13 Apr 2013 08:23:52 GMT Chris Johns [65575cc] * tools/4.11/gcc/gcc-4.7.3-rtems4.11-20130413.diff (added) Update the 4.7.2 patch to 4.7.3.
