# # ChangeLog for tools/4.10 in rtems-tools # # Generated by Trac 1.2.1.dev0 # 05/02/24 15:10:21 Fri, 02 Sep 2016 08:16:57 GMT Chris Johns [4fdd883] * tools/4.10/newlib/nios2/nios2-newlib-1.19.0-rtems-20110720.diff (added) 4.10: Add NIOS2 newlib patch. Fri, 02 Sep 2016 08:03:11 GMT Chris Johns [32b861f] * tools/4.10/gcc/nios2/nios2-gcc-4.1-rtems-20110818.diff (added) 4.10: Add NIOS2 gcc patch. Fri, 02 Sep 2016 07:56:09 GMT Chris Johns [5af5b04] * tools/4.10/binutils/nios2/nios2-binutils-2.20-rtems-20110703.diff (added) 4.10: Add NIOS2 binutils patch. Fri, 02 Sep 2016 07:00:50 GMT Chris Johns [a46a8d3] * tools/4.10/gdb/patch-gdb-python-python-config.py (added) 4.10: Add FreeBSD Python patch. Fri, 02 Sep 2016 06:56:49 GMT Chris Johns [3f17371] * tools/4.10/gdb/gdb-7.11-erc32-common-run.diff (added) * tools/4.10/gdb/gdb-7.11-erc32-endian-fix.diff (added) * tools/4.10/gdb/gdb-7.11-erc32-printf_filtered.diff (added) 4.10: Add the gdb-7.11 ERC patches to 4.10. Fri, 02 Sep 2016 03:18:17 GMT Chris Johns [3581fab] * tools/4.10/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff (added) 4.10: Add the automake patch to the 4.10 patches. Thu, 07 Jan 2016 14:14:29 GMT Götz Pfeiffer [87bca99] * tools/4.10/gdb/gdb-7.3.1-rtems4.10-20151123.diff (added) Bugfix: gdb-7.3.1 couldn't be build with a modern texinfo package. ... Thu, 07 Jan 2016 14:13:50 GMT Götz Pfeiffer [47ec083] * tools/4.10/gcc/gcc-core-4.4.7-rtems4.10-20151123.diff (added) Bugfix: gcc-4.4.7 couldn't be build with a modern texinfo package. ... Thu, 07 Jan 2016 14:13:05 GMT Götz Pfeiffer [45d2402] * tools/4.10/binutils/binutils-2.20.1-rtems4.10-20151123.diff (added) Bugfix: binutils-2.20.1 couldn't be build with a modern texinfo ... Tue, 02 Apr 2013 06:48:38 GMT Chris Johns [9d711f4] * tools/4.10/binutils/cygwin/binutils-2.20.1-cygwin-w64-20130324.diff (added) Fix to build in cygwin. Wed, 20 Mar 2013 06:27:49 GMT Chris Johns [4c5ffb2] * tools/4.10/gdb/bfin/gdb-7.3.1-bfin-sim-fix-sed-20130319.diff (added) Fix the sed breakage on FreeBSD. Tue, 19 Mar 2013 06:16:54 GMT Chris Johns [038b250] * tools/4.10/binutils/binutils-2.20.1-rtems4.10-20100826.diff (added) * tools/4.10/gcc/gcc-core-4.4.7-rtems4.10-20120314.diff (added) * tools/4.10/gcc/gcc-g++-4.4.7-rtems4.10-20120314.diff (added) * tools/4.10/gdb/gdb-7.3.1-rtems4.10-20120918.diff (added) * tools/4.10/newlib/newlib-1.18.0-rtems4.10-20110518.diff (added) Add the current rtems-4.10 patches.
