# # ChangeLog for tester in rtems-tools # # Generated by Trac 1.2.1.dev0 # 04/25/24 10:15:50 Mon, 12 Dec 2016 22:56:25 GMT Chris Johns [a72a462a] * tester/rt/check.py (modified) bsp-builder: Fix final output errors. Wed, 30 Nov 2016 23:21:13 GMT Chris Johns [d3d771e] * tester/rt/check.py (modified) * tester/rtems/rtems-bsps.ini (modified) bsp-builder: Add support for builds. Add build support where a ... Tue, 29 Nov 2016 21:13:33 GMT Chris Johns [8a7be63] * tester/rt/check.py (modified) bsp-bulder: Get the end time when building an architecture. Tue, 30 Aug 2016 08:10:17 GMT Chris Johns [a252faf] * tester/rt/check.py (modified) bsp-builder: Results format fixes. Mon, 29 Aug 2016 01:47:04 GMT Chris Johns [06c3ccd] * tester/rt/check.py (modified) bsp-builder: Fix bugs. Thu, 25 Aug 2016 06:14:57 GMT Chris Johns [e9fb4c5] * tester/rtems/rtems-bsps.ini (modified) bsp-builder: Add lm3s6965_qemu to ARM bsp list. Fix network-debug ... Thu, 25 Aug 2016 06:13:18 GMT Chris Johns [f7f0704] * tester/rt/check.py (modified) bsp-builder: Fix column printing of the arch/bsp. Fri, 19 Aug 2016 01:56:09 GMT Chris Johns [8e13939] * tester/rt/check.py (modified) bsp-builder: Print one results report only. Thu, 18 Aug 2016 23:55:03 GMT Chris Johns [9a1daba] * tester/rt/check.py (modified) bsp-builder: Fix results report columns. Thu, 18 Aug 2016 11:00:50 GMT Chris Johns [3a92a54] * tester/rtems/rtems-bsps.ini (modified) bsp-builder: Add ARM bsps. Thu, 18 Aug 2016 11:00:29 GMT Chris Johns [51e19af] * tester/rt/check.py (modified) bsp-builder: Support per BSP excludes. Thu, 18 Aug 2016 04:24:45 GMT Chris Johns [57e4172] * tester/rt/check.py (modified) tester: handle compile argument warnings. Wed, 06 Jul 2016 07:58:56 GMT Chris Johns [3e14594] * rtemstoolkit/version.py (modified) * tester/rt/check.py (added) * tester/rtems-bsp-builder (added) * tester/rtems/rtems-bsps.ini (added) * tester/wscript (modified) Add rtems-bsp-builder. This is a testing tool that builds BSPs with ... Wed, 16 Mar 2016 10:39:39 GMT Chris Johns [dfa2468] * tester/rt/test.py (modified) tester: Fix reraising an exception with Python2 and Python3. ... Wed, 16 Mar 2016 05:22:35 GMT Chris Johns [4bcf18b] * tester/rtems/testing/bsps/sis-run.mc (modified) * tester/rtems/testing/bsps/sis.mc (modified) tester/sis: Provide the -nouartrx to avoid blocking on stdin. Wed, 16 Mar 2016 05:21:57 GMT Chris Johns [1845e91] * tester/rt/gdb.py (modified) tester: Provide a gdb kill method to aid clean ups on ctrl-C. Mon, 14 Mar 2016 03:59:11 GMT Chris Johns [6f8b07c] * rtemstoolkit/execute.py (modified) * tester/rt/gdb.py (modified) * tester/rt/report.py (modified) * tester/rt/test.py (modified) rtemstoolkit: Fix execute's writer thread to not eval() the input. ... Wed, 09 Mar 2016 03:34:26 GMT Chris Johns [c9ed248] * tester/rt/test.py (modified) Remove exception test code left in. Updates #2619. Wed, 09 Mar 2016 03:29:14 GMT Chris Johns [6fa359c] * tester/rtems/version.cfg (modified) Master branch version is 4.12. Wed, 09 Mar 2016 03:28:57 GMT Chris Johns [b7a9c81] * tester/rtems/testing/bsps/sis-run.mc (modified) sis: Option not present with SPARC sim. Wed, 09 Mar 2016 03:27:42 GMT Chris Johns [2de37f3] * rtemstoolkit/config.py (modified) * rtemstoolkit/execute.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * tester/rt/test.py (modified) Python 2 and python 3 refactor fixes. Updates #2619. Fri, 04 Mar 2016 01:10:09 GMT Chris Johns [a5d243d] * tester/wscript (modified) tester: Remove the RT version.py and use the toolkit's version. Thu, 03 Mar 2016 05:46:18 GMT Chris Johns [b0fa2ae] * rtemstoolkit/__init__.py (modified) * rtemstoolkit/check.py (modified) * rtemstoolkit/config.py (modified) * rtemstoolkit/darwin.py (modified) * rtemstoolkit/error.py (modified) * rtemstoolkit/execute.py (modified) * rtemstoolkit/freebsd.py (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/linux.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/mailer.py (modified) * rtemstoolkit/netbsd.py (added) * rtemstoolkit/options.py (modified) * rtemstoolkit/path.py (modified) * rtemstoolkit/solaris.py (added) * rtemstoolkit/version.py (modified) * rtemstoolkit/windows.py (modified) * tester/rt/config.py (modified) * tester/rt/console.py (modified) * tester/rt/gdb.py (modified) * tester/rt/options.py (modified) * tester/rt/pygdb/__init__.py (modified) * tester/rt/pygdb/mi_parser.py (modified) * tester/rt/pygdb/spark.py (modified) * tester/rt/test.py (modified) * tester/rt/version.py (deleted) * tester/rtems-test (modified) Update rtems-tool to support Python 2 and 3. Add solaris and ... Fri, 19 Feb 2016 03:46:15 GMT Chris Johns [7148cae] * linkers/wscript (modified) * rtemstoolkit/wscript (modified) * tester/covoar/wscript (modified) * tester/wscript (modified) * tools/gdb/python/wscript (modified) * wafwindows.py (added) * wscript (modified) Add Windows specific waf support for MSYS2. Limit the compilers ... Fri, 19 Feb 2016 00:26:51 GMT Chris Johns [de1beea] * rtemstoolkit/config.py (modified) * rtemstoolkit/execute.py (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/path.py (modified) * rtemstoolkit/version.py (modified) * rtemstoolkit/wscript (modified) * tester/rtems-test (modified) * tester/wscript (modified) * tools/gdb/python/wscript (modified) * wscript (modified) Disable installing PYO and PYC. Fix install paths. Installing PYO ... Tue, 15 Dec 2015 21:37:10 GMT Chris Johns [f775869] * tester/rtems-test (modified) Fix running rtems-test from inside the git clone. Fri, 11 Dec 2015 00:56:12 GMT Aun-Ali Zaidi [2df531a] * tester/rtems/testing/bsps/m32rsim-run.mc (deleted) * tester/rtems/testing/bsps/m32rsim.mc (deleted) bsps/m32rsim*: Remove closes #2447. Mon, 14 Dec 2015 00:49:25 GMT Aun-Ali Zaidi [ea51d2a] * tester/rtems/testing/bsps/h8sim-run.mc (deleted) * tester/rtems/testing/bsps/h8sim.mc (deleted) bsps/h8sim*: Remove closes #2453. Fri, 11 Dec 2015 06:15:34 GMT Chris Johns [a6f5f18] * rtemstoolkit/wscript (modified) * tester/wscript (modified) Fix how to use the waf py feature to get py source and pyo file ... Wed, 09 Dec 2015 09:08:19 GMT Chris Johns [efc4f09] * .gitignore (modified) * linkers/rtems-ld.cpp (modified) * linkers/rtems-ra.cpp (modified) * linkers/rtems-rapper.cpp (modified) * linkers/rtems-syms.cpp (modified) * linkers/rtems-tld.cpp (modified) * linkers/wscript (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/options.py (modified) * rtemstoolkit/rld-rtems.cpp (modified) * rtemstoolkit/rld.cpp (modified) * rtemstoolkit/version.py (modified) * rtemstoolkit/wscript (modified) * tester/rt/test.py (modified) * tester/rtems-test (modified) * tester/wscript (modified) * wscript (modified) Add release versioning support. Support a top level VERSION file ... Thu, 12 Nov 2015 10:15:23 GMT Sebastian Huber [04a5204] * rtemstoolkit/check.py (modified) * rtemstoolkit/config.py (modified) * rtemstoolkit/error.py (modified) * rtemstoolkit/execute.py (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/mailer.py (modified) * rtemstoolkit/options.py (modified) * rtemstoolkit/path.py (modified) * rtemstoolkit/version.py (modified) * tester/rt/config.py (modified) * tester/rt/console.py (modified) * tester/rt/gdb.py (modified) * tester/rt/options.py (modified) * tester/rt/pygdb/mi_parser.py (modified) * tester/rt/pygdb/spark.py (modified) * tester/rt/stty.py (modified) * tester/rt/test.py (modified) * tester/rt/version.py (modified) * tools/gdb/python/__init__.py (modified) * tools/gdb/python/classic.py (modified) * tools/gdb/python/heaps.py (modified) * tools/gdb/python/helper.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/sparc.py (modified) * tools/gdb/python/supercore.py (modified) * tools/gdb/python/watchdog.py (modified) Python 3 compatibility Sun, 18 Oct 2015 22:14:57 GMT Chris Johns [baa798a] * rtemstoolkit/options.py (modified) * tester/rt/version.py (modified) Update the versions strings. Sun, 18 Oct 2015 08:19:08 GMT Chris Johns [0382b68] * linkers/wscript (modified) * rtemstoolkit/elftoolchain/libelf/mmap_win32.c (modified) * rtemstoolkit/wscript (modified) * tester/rt/console.py (modified) * tester/rt/gdb.py (modified) * tester/rtems-test (modified) * tester/wscript (modified) * wscript (modified) Fix Windows build issues. Fix biulding the mmap Windows code. Fix ... Wed, 22 Jul 2015 11:38:46 GMT Ric Claus [92935ed] * tester/rtems/testing/qemu.cfg (modified) qemu.cfg: Options changed to capture test output Wed, 22 Jul 2015 10:11:32 GMT Ric Claus [9d266e8] * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.mc (modified) xilinx_zynq_a9_qemu_smp.mc: Change realview_pbx_a9_qemu reference to ... Sun, 19 Apr 2015 11:04:36 GMT Hesham ALMatary [3f3582f] * tester/rtems/testing/bsps/generic_or1k.mc (moved) Rename or1ksim BSP to generic_or1k Tue, 14 Apr 2015 23:03:28 GMT Joel Sherrill [a68557d] * tester/rtems/testing/bsps/bf537Stamp-run.mc (added) * tester/rtems/testing/bsps/bf537Stamp.mc (added) bf537Stamp: Add configuration files Sat, 04 Apr 2015 14:24:36 GMT Joel Sherrill [d2d91f5] * tester/rtems/testing/bsps/leon3-tsim-cmds (added) * tester/rtems/testing/bsps/leon3_tsim-run.mc (added) * tester/rtems/testing/bsps/leon3_tsim.mc (added) leon3-tsim*: First attempt at LEON3 on tsim support The ... Sat, 04 Apr 2015 14:24:24 GMT Joel Sherrill [c0449d5] * tester/rtems/testing/bsps/lm32_evr_gdbsim-device-tree (added) * tester/rtems/testing/bsps/lm32_evr_gdbsim-run.mc (added) * tester/rtems/testing/bsps/lm32_evr_gdbsim.mc (added) lm32_evr_gdbsim: Add configuration files Sat, 04 Apr 2015 14:24:02 GMT Joel Sherrill [7d784d2] * tester/rtems/testing/bsps/psim-run.mc (modified) * tester/rtems/testing/bsps/psim.mc (modified) psim*.mc: Fix typo Sun, 29 Mar 2015 16:35:59 GMT Joel Sherrill [e98d5fa] * tester/rtems/testing/bsps/erc32-run.mc (added) * tester/rtems/testing/bsps/erc32.mc (added) * tester/rtems/testing/bsps/leon2-run.mc (added) * tester/rtems/testing/bsps/leon2.mc (added) * tester/rtems/testing/bsps/leon3-run.mc (added) * tester/rtems/testing/bsps/leon3.mc (added) Add configurations for erc32, leon2, and leon3 in GDB SIS These ... Fri, 27 Mar 2015 03:21:56 GMT Chris Johns [f5b639b] * tester/wscript (modified) rtems-tester: Remove repeated install line in wscript. Fixes #2312. Thu, 26 Mar 2015 18:20:15 GMT Joel Sherrill [20feafb] * tester/rtems/testing/bsps/simsh1-run.mc (added) * tester/rtems/testing/bsps/simsh1.mc (added) * tester/rtems/testing/bsps/simsh2-run.mc (added) * tester/rtems/testing/bsps/simsh2.mc (added) * tester/rtems/testing/bsps/simsh2e-run.mc (added) * tester/rtems/testing/bsps/simsh2e.mc (added) * tester/rtems/testing/bsps/simsh4-run.mc (added) * tester/rtems/testing/bsps/simsh4.mc (added) Add rtems-tester configurations for simsh family of BSPs Thu, 12 Mar 2015 22:29:37 GMT Joel Sherrill [a30ec56] * tester/rtems/testing/bsps/h8sim-run.mc (added) * tester/rtems/testing/bsps/h8sim.mc (added) * tester/rtems/testing/bsps/h8sxsim-run.mc (added) * tester/rtems/testing/bsps/h8sxsim.mc (added) Add configurations for all h8 GDB simulator BSP variants Thu, 12 Mar 2015 22:17:56 GMT Joel Sherrill [8abbe80] * tester/rtems/testing/bsps/arm1136jfs-run.mc (added) * tester/rtems/testing/bsps/arm1136jfs.mc (added) * tester/rtems/testing/bsps/arm1136js-run.mc (added) * tester/rtems/testing/bsps/arm1136js.mc (added) * tester/rtems/testing/bsps/arm7tdmi-run.mc (added) * tester/rtems/testing/bsps/arm7tdmi.mc (added) * tester/rtems/testing/bsps/arm920-run.mc (added) * tester/rtems/testing/bsps/arm920.mc (modified) * tester/rtems/testing/bsps/armcortexa9-run.mc (added) * tester/rtems/testing/bsps/armcortexa9.mc (added) Add configurations for all arm GDB simulator BSP variants Thu, 12 Mar 2015 21:55:43 GMT Joel Sherrill [ab5e0c5] * tester/rtems/testing/bsps/m32csim-run.mc (added) * tester/rtems/testing/bsps/m32csim.mc (added) Add configuration for m32csim BSP for simulator in GDB Thu, 12 Mar 2015 18:51:32 GMT Joel Sherrill [b938414] * tester/rtems/testing/bsps/m32rsim-run.mc (added) * tester/rtems/testing/bsps/m32rsim.mc (added) Add configuration for m32rsim BSP for simulator in GDB Thu, 12 Mar 2015 17:47:13 GMT Joel Sherrill [71fb99b] * tester/rtems/testing/bsps/v850e1sim-run.mc (added) * tester/rtems/testing/bsps/v850e1sim.mc (added) * tester/rtems/testing/bsps/v850e2sim-run.mc (added) * tester/rtems/testing/bsps/v850e2sim.mc (added) * tester/rtems/testing/bsps/v850e2v3sim-run.mc (added) * tester/rtems/testing/bsps/v850e2v3sim.mc (added) * tester/rtems/testing/bsps/v850esim-run.mc (added) * tester/rtems/testing/bsps/v850esim.mc (added) * tester/rtems/testing/bsps/v850essim-run.mc (added) * tester/rtems/testing/bsps/v850essim.mc (added) * tester/rtems/testing/bsps/v850sim-run.mc (added) * tester/rtems/testing/bsps/v850sim.mc (added) Add configurations for all v850 GDB simulator BSP variants Sun, 22 Feb 2015 06:07:10 GMT Adit Sahasrabudhe [01a4192] * tester/wscript (modified) * tools/gdb/python/wscript (modified) Modified waf scripts to have a minimum python version requirement of ... Mon, 16 Feb 2015 00:27:18 GMT Chris Johns [e143a62] * tester/wscript (modified) Fix the chmod octal value to use the correct Python syntax. Mon, 16 Feb 2015 00:25:22 GMT Chris Johns [a8c4f3f] * tester/covoar/ReportsBase.cc (modified) Update the Windows header to direct.h for _mkdir per the MSDN. Sun, 08 Feb 2015 07:40:35 GMT Chris Johns [05fe73d] * tester/wscript (modified) Fix the tester wscript. Sun, 08 Feb 2015 07:14:16 GMT Chris Johns [9600c39] * rtemstoolkit/darwin.py (modified) * tester/rt/gdb.py (modified) * tester/rt/options.py (modified) * tester/rt/test.py (modified) * tester/rtems/testing/defaults.mc (modified) * tester/wscript (modified) Fixes to the run the waf built tests when installed. Sun, 08 Feb 2015 06:12:04 GMT Chris Johns [b7d48ef] * linkers/wscript (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/wscript (modified) * tester/rt/options.py (modified) * tester/rt/test.py (modified) * tester/rtems-test (modified) * tester/rtems/testing/defaults.mc (modified) * tester/wscript (modified) * tools/gdb/python/wscript (modified) Install the rtems-test command. This installs the Python RTEMS ... Mon, 19 Jan 2015 21:56:14 GMT Chris Johns [f381f26] * tester/covoar/DesiredSymbols.cc (modified) * tester/covoar/ReportsBase.cc (modified) * tester/covoar/covoar.cc (modified) Fix covoar so it builds for Windows. Wed, 23 Jul 2014 16:20:19 GMT Ben Gras [e4014f0] * tester/rt/test.py (modified) typo Sun, 07 Sep 2014 01:16:58 GMT Hesham ALMatary [23bbbfd] * tester/rtems/testing/bsps/or1ksim.mc (added) Add new OpenRISC/or1ksim BSP script using qemu Sat, 13 Sep 2014 00:47:07 GMT Chris Johns [749ddf1] * .gitignore (modified) * README (modified) * linkers/wscript (modified) * tester/covoar/wscript (modified) * tester/wscript (added) * tools/gdb/python/wscript (modified) * waf (added) * wscript (added) waf: Include waf in the souce tree and updated README on building. ... Fri, 09 May 2014 11:50:37 GMT Chris Johns [100f517] * tester/covoar/.gitignore (added) * tester/covoar/05_ascending.gif (added) * tester/covoar/05_descending.gif (added) * tester/covoar/05_unsorted.gif (added) * tester/covoar/ConfigFile.cc (added) * tester/covoar/ConfigFile.h (added) * tester/covoar/CoverageFactory.cc (added) * tester/covoar/CoverageFactory.h (added) * tester/covoar/CoverageMap.cc (added) * tester/covoar/CoverageMap.h (added) * tester/covoar/CoverageMapBase.cc (added) * tester/covoar/CoverageMapBase.h (added) * tester/covoar/CoverageRanges.cc (added) * tester/covoar/CoverageRanges.h (added) * tester/covoar/CoverageReaderBase.cc (added) * tester/covoar/CoverageReaderBase.h (added) * tester/covoar/CoverageReaderQEMU.cc (added) * tester/covoar/CoverageReaderQEMU.h (added) * tester/covoar/CoverageReaderRTEMS.cc (added) * tester/covoar/CoverageReaderRTEMS.h (added) * tester/covoar/CoverageReaderSkyeye.cc (added) * tester/covoar/CoverageReaderSkyeye.h (added) * tester/covoar/CoverageReaderTSIM.cc (added) * tester/covoar/CoverageReaderTSIM.h (added) * tester/covoar/CoverageWriterBase.cc (added) * tester/covoar/CoverageWriterBase.h (added) * tester/covoar/CoverageWriterRTEMS.cc (added) * tester/covoar/CoverageWriterRTEMS.h (added) * tester/covoar/CoverageWriterSkyeye.cc (added) * tester/covoar/CoverageWriterSkyeye.h (added) * tester/covoar/CoverageWriterTSIM.cc (added) * tester/covoar/CoverageWriterTSIM.h (added) * tester/covoar/DesiredSymbols.cc (added) * tester/covoar/DesiredSymbols.h (added) * tester/covoar/Doxyfile (added) * tester/covoar/ExecutableInfo.cc (added) * tester/covoar/ExecutableInfo.h (added) * tester/covoar/Explanations.cc (added) * tester/covoar/Explanations.h (added) * tester/covoar/GcovData.cc (added) * tester/covoar/GcovData.h (added) * tester/covoar/GcovFunctionData.cc (added) * tester/covoar/GcovFunctionData.h (added) * tester/covoar/Makefile (added) * tester/covoar/ObjdumpProcessor.cc (added) * tester/covoar/ObjdumpProcessor.h (added) * tester/covoar/ReportsBase.cc (added) * tester/covoar/ReportsBase.h (added) * tester/covoar/ReportsHtml.cc (added) * tester/covoar/ReportsHtml.h (added) * tester/covoar/ReportsText.cc (added) * tester/covoar/ReportsText.h (added) * tester/covoar/SymbolTable.cc (added) * tester/covoar/SymbolTable.h (added) * tester/covoar/TargetBase.cc (added) * tester/covoar/TargetBase.h (added) * tester/covoar/TargetFactory.cc (added) * tester/covoar/TargetFactory.h (added) * tester/covoar/Target_arm.cc (added) * tester/covoar/Target_arm.h (added) * tester/covoar/Target_i386.cc (added) * tester/covoar/Target_i386.h (added) * tester/covoar/Target_lm32.cc (added) * tester/covoar/Target_lm32.h (added) * tester/covoar/Target_m68k.cc (added) * tester/covoar/Target_m68k.h (added) * tester/covoar/Target_powerpc.cc (added) * tester/covoar/Target_powerpc.h (added) * tester/covoar/Target_sparc.cc (added) * tester/covoar/Target_sparc.h (added) * tester/covoar/TraceConverter.cc (added) * tester/covoar/TraceList.cc (added) * tester/covoar/TraceList.h (added) * tester/covoar/TraceReaderBase.cc (added) * tester/covoar/TraceReaderBase.h (added) * tester/covoar/TraceReaderLogQEMU.cc (added) * tester/covoar/TraceReaderLogQEMU.h (added) * tester/covoar/TraceWriterBase.cc (added) * tester/covoar/TraceWriterBase.h (added) * tester/covoar/TraceWriterQEMU.cc (added) * tester/covoar/TraceWriterQEMU.h (added) * tester/covoar/app_common.cc (added) * tester/covoar/app_common.h (added) * tester/covoar/configFile.txt (added) * tester/covoar/configfile_test.cc (added) * tester/covoar/coverage_converter.cc (added) * tester/covoar/covmerge.cc (added) * tester/covoar/covoar.cc (added) * tester/covoar/covoar.css (added) * tester/covoar/covoar_flow.doc (added) * tester/covoar/filter.gif (added) * tester/covoar/mkExplanation (added) * tester/covoar/qemu-dump-trace.c (added) * tester/covoar/qemu-log.h (added) * tester/covoar/qemu-traces.h (added) * tester/covoar/rtemscov_header.h (added) * tester/covoar/skyeye_header.h (added) * tester/covoar/table.js (added) * tester/covoar/wscript (added) covoar: Merger the covoar source from rtems-testing.git. Use waf to ... Sun, 01 Jun 2014 06:15:28 GMT Chris Johns [984b06d] * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.mc (modified) config: Fix the name for the xilinx_zynq_a9_qemu bsp. Sun, 01 Jun 2014 04:46:50 GMT Chris Johns [8fac58f] * tester/rtems/testing/bsps/arm920.mc (added) config: Add support for the gdbarmsim for the arm920 BSP. Sun, 01 Jun 2014 04:46:11 GMT Chris Johns [288d633] * tester/rtems/testing/bsps/realview_pbx_a9_qemu.mc (modified) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.mc (modified) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.mc (modified) * tester/rtems/testing/bsps/xilinx_zynq_zc706_qemu.mc (added) * tester/rtems/testing/qemu.cfg (modified) config: Clean up the qemu configurations. Sun, 01 Jun 2014 04:43:03 GMT Chris Johns [60937e1] * tester/rt/config.py (modified) test: Strengthen the timeout handling by killing the process. Sat, 31 May 2014 10:03:05 GMT Chris Johns [c04a849] * rtemstoolkit/execute.py (modified) * rtemstoolkit/stacktraces.py (added) * tester/rt/bsps.py (added) * tester/rt/config.py (modified) * tester/rt/test.py (modified) tester: Correctly handle contro-c. Add support to kill running ... Wed, 14 May 2014 23:36:29 GMT Joel Sherrill [ab131bb] * tester/rtems/testing/bsps/jmr3904-run.mc (added) * tester/rtems/testing/bsps/jmr3904.mc (added) Add jmr3904 GDB simulator support Sun, 27 Apr 2014 17:35:01 GMT Ben Gras [803b63d] * tester/rt/test.py (modified) add --filter to specify the set of selected tests. . parameter is ... Mon, 28 Apr 2014 23:18:14 GMT Chris Johns [4efea40] * tester/rtems/testing/bsps/beagleboardxm.mc (modified) bsp: Clean up the BBxM BSP configuration. Mon, 28 Apr 2014 23:10:14 GMT Chris Johns [bd0fbd6] * tester/rtems/testing/bsps/beagleboardxm.mc (modified) bsp: Break on the terminate halt to get fatal handlers run. Thu, 24 Apr 2014 07:52:32 GMT Chris Johns [4e8f984] * tester/rtems/testing/bsps/beagleboardxm.mc (added) bsp: Add Beagleboard xM support. Thu, 10 Apr 2014 08:21:24 GMT Chris Johns [b45ca52] * tester/rtems/testing/bsps/psim-run.mc (modified) tester: Fix the psim script. Wed, 26 Mar 2014 05:45:19 GMT Chris Johns [05d2385] * tester/rtems/testing/bsps/psim-device-tree (added) * tester/rtems/testing/bsps/psim-run.mc (added) * tester/rtems/testing/bsps/psim.mc (added) bsp: Add psim. Wed, 26 Mar 2014 05:45:06 GMT Chris Johns [a116962] * tester/rt/config.py (modified) tester: The process returns an exit code not an errno. Fri, 14 Feb 2014 19:30:06 GMT Chris Johns [50fdf12] * rtemstoolkit/.gitignore (added) * rtemstoolkit/__init__.py (added) * rtemstoolkit/check.py (added) * rtemstoolkit/config.py (added) * rtemstoolkit/darwin.py (added) * rtemstoolkit/error.py (added) * rtemstoolkit/execute.py (added) * rtemstoolkit/freebsd.py (added) * rtemstoolkit/git.py (added) * rtemstoolkit/linux.py (added) * rtemstoolkit/log.py (added) * rtemstoolkit/macros.py (added) * rtemstoolkit/mailer.py (added) * rtemstoolkit/options.py (added) * rtemstoolkit/path.py (added) * rtemstoolkit/version.py (added) * rtemstoolkit/windows.py (added) * tester/.gitignore (added) * tester/config/base.cfg (added) * tester/config/checks.cfg (added) * tester/rt/__init__.py (added) * tester/rt/config.py (added) * tester/rt/console.py (added) * tester/rt/gdb.py (added) * tester/rt/options.py (added) * tester/rt/pygdb/__init__.py (added) * tester/rt/pygdb/mi_parser.py (added) * tester/rt/pygdb/spark.py (added) * tester/rt/report.py (added) * tester/rt/stty.py (added) * tester/rt/test.py (added) * tester/rt/version.py (added) * tester/rtems-test (added) * tester/rtems/testing/bsps/mcf5235.mc (added) * tester/rtems/testing/bsps/realview_pbx_a9_qemu.mc (added) * tester/rtems/testing/bsps/sis-run.mc (added) * tester/rtems/testing/bsps/sis.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_zc706.mc (added) * tester/rtems/testing/console.cfg (added) * tester/rtems/testing/defaults.mc (added) * tester/rtems/testing/gdb.cfg (added) * tester/rtems/testing/qemu.cfg (added) * tester/rtems/testing/run.cfg (added) * tester/rtems/testing/testing.mc (added) * tester/rtems/version.cfg (added) rt: Add the rtems-tester.
