# # ChangeLog for tester/covoar/DesiredSymbols.cc in rtems-tools # # Generated by Trac 1.2.1.dev0 # 05/06/24 14:01:21 Thu, 24 May 2018 21:25:38 GMT Chris Johns [e04699b] * tester/covoar/DesiredSymbols.cc (modified) tester/covoar: Do not load an executable's local symbols. Wed, 25 Apr 2018 20:33:58 GMT Cillian O'Donnell [3e187ba] * tester/covoar/DesiredSymbols.cc (modified) * tester/covoar/DesiredSymbols.h (modified) * tester/covoar/ExecutableInfo.cc (modified) * tester/covoar/ExecutableInfo.h (modified) * tester/covoar/ObjdumpProcessor.cc (modified) * tester/covoar/app_common.h (modified) * tester/covoar/covoar.cc (modified) * tester/covoar/wscript (modified) * tester/rtems/testing/bsps/leon3-qemu-cov.ini (added) * tester/rtems/testing/bsps/leon3-qemu.ini (added) * tester/rtems/testing/coverage/Categories.txt (added) * tester/rtems/testing/coverage/Explanations.txt (added) * tester/rtems/testing/coverage/SPARC-Annul-Slot-Explanation.txt (added) * tester/rtems/testing/coverage/score-symbols.ini (added) * tester/rtems/testing/coverage/style.css (added) * tester/rtems/testing/qemu.cfg (modified) * tester/rtems/testing/testing.mc (modified) covoar: Add symbol set reader and ELF data parser to covoar. Add ... Thu, 14 Sep 2017 23:04:55 GMT Joel Sherrill [f4378ea] * tester/covoar/DesiredSymbols.cc (modified) tester/covoar/DesiredSymbols.cc: Now compiles on Cygwin Wed, 13 Sep 2017 15:45:30 GMT Cillian O'Donnell [f4773ac] * tester/covoar/DesiredSymbols.cc (modified) * tester/covoar/ReportsBase.cc (modified) * tester/covoar/TraceConverter.cc (modified) * tester/covoar/covoar.cc (modified) covoar: Add function defs to fix Windows build errors. Closes #3129 Sat, 26 Aug 2017 08:15:53 GMT Hermann Felbinger [cb018bc] * tester/covoar/CoverageMap.cc (modified) * tester/covoar/CoverageMap.h (modified) * tester/covoar/CoverageMapBase.cc (modified) * tester/covoar/CoverageMapBase.h (modified) * tester/covoar/DesiredSymbols.cc (modified) * tester/covoar/DesiredSymbols.h (modified) * tester/covoar/ExecutableInfo.cc (modified) * tester/covoar/ExecutableInfo.h (modified) * tester/covoar/ObjdumpProcessor.cc (modified) covoar: Add information to improve diagnostics. Mon, 19 Jan 2015 21:56:14 GMT Chris Johns [f381f26] * tester/covoar/DesiredSymbols.cc (modified) * tester/covoar/ReportsBase.cc (modified) * tester/covoar/covoar.cc (modified) Fix covoar so it builds for Windows. Fri, 09 May 2014 11:50:37 GMT Chris Johns [100f517] * tester/covoar/.gitignore (added) * tester/covoar/05_ascending.gif (added) * tester/covoar/05_descending.gif (added) * tester/covoar/05_unsorted.gif (added) * tester/covoar/ConfigFile.cc (added) * tester/covoar/ConfigFile.h (added) * tester/covoar/CoverageFactory.cc (added) * tester/covoar/CoverageFactory.h (added) * tester/covoar/CoverageMap.cc (added) * tester/covoar/CoverageMap.h (added) * tester/covoar/CoverageMapBase.cc (added) * tester/covoar/CoverageMapBase.h (added) * tester/covoar/CoverageRanges.cc (added) * tester/covoar/CoverageRanges.h (added) * tester/covoar/CoverageReaderBase.cc (added) * tester/covoar/CoverageReaderBase.h (added) * tester/covoar/CoverageReaderQEMU.cc (added) * tester/covoar/CoverageReaderQEMU.h (added) * tester/covoar/CoverageReaderRTEMS.cc (added) * tester/covoar/CoverageReaderRTEMS.h (added) * tester/covoar/CoverageReaderSkyeye.cc (added) * tester/covoar/CoverageReaderSkyeye.h (added) * tester/covoar/CoverageReaderTSIM.cc (added) * tester/covoar/CoverageReaderTSIM.h (added) * tester/covoar/CoverageWriterBase.cc (added) * tester/covoar/CoverageWriterBase.h (added) * tester/covoar/CoverageWriterRTEMS.cc (added) * tester/covoar/CoverageWriterRTEMS.h (added) * tester/covoar/CoverageWriterSkyeye.cc (added) * tester/covoar/CoverageWriterSkyeye.h (added) * tester/covoar/CoverageWriterTSIM.cc (added) * tester/covoar/CoverageWriterTSIM.h (added) * tester/covoar/DesiredSymbols.cc (added) * tester/covoar/DesiredSymbols.h (added) * tester/covoar/Doxyfile (added) * tester/covoar/ExecutableInfo.cc (added) * tester/covoar/ExecutableInfo.h (added) * tester/covoar/Explanations.cc (added) * tester/covoar/Explanations.h (added) * tester/covoar/GcovData.cc (added) * tester/covoar/GcovData.h (added) * tester/covoar/GcovFunctionData.cc (added) * tester/covoar/GcovFunctionData.h (added) * tester/covoar/Makefile (added) * tester/covoar/ObjdumpProcessor.cc (added) * tester/covoar/ObjdumpProcessor.h (added) * tester/covoar/ReportsBase.cc (added) * tester/covoar/ReportsBase.h (added) * tester/covoar/ReportsHtml.cc (added) * tester/covoar/ReportsHtml.h (added) * tester/covoar/ReportsText.cc (added) * tester/covoar/ReportsText.h (added) * tester/covoar/SymbolTable.cc (added) * tester/covoar/SymbolTable.h (added) * tester/covoar/TargetBase.cc (added) * tester/covoar/TargetBase.h (added) * tester/covoar/TargetFactory.cc (added) * tester/covoar/TargetFactory.h (added) * tester/covoar/Target_arm.cc (added) * tester/covoar/Target_arm.h (added) * tester/covoar/Target_i386.cc (added) * tester/covoar/Target_i386.h (added) * tester/covoar/Target_lm32.cc (added) * tester/covoar/Target_lm32.h (added) * tester/covoar/Target_m68k.cc (added) * tester/covoar/Target_m68k.h (added) * tester/covoar/Target_powerpc.cc (added) * tester/covoar/Target_powerpc.h (added) * tester/covoar/Target_sparc.cc (added) * tester/covoar/Target_sparc.h (added) * tester/covoar/TraceConverter.cc (added) * tester/covoar/TraceList.cc (added) * tester/covoar/TraceList.h (added) * tester/covoar/TraceReaderBase.cc (added) * tester/covoar/TraceReaderBase.h (added) * tester/covoar/TraceReaderLogQEMU.cc (added) * tester/covoar/TraceReaderLogQEMU.h (added) * tester/covoar/TraceWriterBase.cc (added) * tester/covoar/TraceWriterBase.h (added) * tester/covoar/TraceWriterQEMU.cc (added) * tester/covoar/TraceWriterQEMU.h (added) * tester/covoar/app_common.cc (added) * tester/covoar/app_common.h (added) * tester/covoar/configFile.txt (added) * tester/covoar/configfile_test.cc (added) * tester/covoar/coverage_converter.cc (added) * tester/covoar/covmerge.cc (added) * tester/covoar/covoar.cc (added) * tester/covoar/covoar.css (added) * tester/covoar/covoar_flow.doc (added) * tester/covoar/filter.gif (added) * tester/covoar/mkExplanation (added) * tester/covoar/qemu-dump-trace.c (added) * tester/covoar/qemu-log.h (added) * tester/covoar/qemu-traces.h (added) * tester/covoar/rtemscov_header.h (added) * tester/covoar/skyeye_header.h (added) * tester/covoar/table.js (added) * tester/covoar/wscript (added) covoar: Merger the covoar source from rtems-testing.git. Use waf to ...
