# # ChangeLog for rtemstoolkit/rld-files.h in rtems-tools # # Generated by Trac 1.2.1.dev0 # 05/31/24 04:40:14 Sat, 13 Sep 2014 02:09:16 GMT Chris Johns [87e0e76] * linkers/README (modified) * linkers/wscript (modified) * rtemstoolkit/ConvertUTF.c (moved) * rtemstoolkit/ConvertUTF.h (moved) * rtemstoolkit/SimpleIni.h (moved) * rtemstoolkit/elftoolchain/common/Makefile (moved) * rtemstoolkit/elftoolchain/common/_elftc.h (moved) * rtemstoolkit/elftoolchain/common/elfdefinitions.h (moved) * rtemstoolkit/elftoolchain/common/native-elf-format (moved) * rtemstoolkit/elftoolchain/common/os.Linux.mk (moved) * rtemstoolkit/elftoolchain/common/uthash.h (moved) * rtemstoolkit/elftoolchain/libelf/Makefile (moved) * rtemstoolkit/elftoolchain/libelf/Version.map (moved) * rtemstoolkit/elftoolchain/libelf/_libelf.h (moved) * rtemstoolkit/elftoolchain/libelf/_libelf_ar.h (moved) * rtemstoolkit/elftoolchain/libelf/_libelf_config.h (moved) * rtemstoolkit/elftoolchain/libelf/elf.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_begin.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_begin.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_cntl.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_cntl.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_data.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_end.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_end.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_errmsg.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_errmsg.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_errno.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_fill.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_fill.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_flag.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_flagdata.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getarhdr.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getarhdr.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_getarsym.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getarsym.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_getbase.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getbase.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_getdata.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getident.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getident.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_getphdrnum.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getphnum.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getscn.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getshdrnum.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getshdrstrndx.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getshnum.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_getshstrndx.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_hash.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_hash.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_kind.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_kind.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_memory.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_memory.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_next.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_next.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_phnum.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_rand.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_rand.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_rawfile.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_rawfile.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_scn.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_shnum.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_shstrndx.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_strptr.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_strptr.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_types.m4 (moved) * rtemstoolkit/elftoolchain/libelf/elf_update.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_update.c (moved) * rtemstoolkit/elftoolchain/libelf/elf_version.3 (moved) * rtemstoolkit/elftoolchain/libelf/elf_version.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf.h (moved) * rtemstoolkit/elftoolchain/libelf/gelf_cap.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_checksum.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_checksum.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_dyn.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_ehdr.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_fsize.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_fsize.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getcap.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getclass.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getclass.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getdyn.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getehdr.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getmove.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getphdr.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getrel.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getrela.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getshdr.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getsym.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getsyminfo.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_getsymshndx.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_move.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_newehdr.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_newphdr.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_phdr.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_rel.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_rela.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_shdr.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_sym.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_syminfo.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_symshndx.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_update_ehdr.3 (moved) * rtemstoolkit/elftoolchain/libelf/gelf_xlate.c (moved) * rtemstoolkit/elftoolchain/libelf/gelf_xlatetof.3 (moved) * rtemstoolkit/elftoolchain/libelf/libelf.h (moved) * rtemstoolkit/elftoolchain/libelf/libelf_align.c (moved) * rtemstoolkit/elftoolchain/libelf/libelf_allocate.c (moved) * rtemstoolkit/elftoolchain/libelf/libelf_ar.c (moved) * rtemstoolkit/elftoolchain/libelf/libelf_ar_util.c (moved) * rtemstoolkit/elftoolchain/libelf/libelf_checksum.c (moved) * rtemstoolkit/elftoolchain/libelf/libelf_convert.m4 (moved) * rtemstoolkit/elftoolchain/libelf/libelf_data.c (moved) * rtemstoolkit/elftoolchain/libelf/libelf_ehdr.c (moved) * rtemstoolkit/elftoolchain/libelf/libelf_extended.c (moved) * rtemstoolkit/elftoolchain/libelf/libelf_fsize.m4 (moved) * rtemstoolkit/elftoolchain/libelf/libelf_msize.m4 (moved) * rtemstoolkit/elftoolchain/libelf/libelf_phdr.c (moved) * rtemstoolkit/elftoolchain/libelf/libelf_shdr.c (moved) * rtemstoolkit/elftoolchain/libelf/libelf_xlate.c (moved) * rtemstoolkit/elftoolchain/libelf/mmap_win32.c (moved) * rtemstoolkit/elftoolchain/libelf/os.FreeBSD.mk (moved) * rtemstoolkit/elftoolchain/libelf/os.NetBSD.mk (moved) * rtemstoolkit/fastlz.c (moved) * rtemstoolkit/fastlz.h (moved) * rtemstoolkit/libiberty/ansidecl.h (moved) * rtemstoolkit/libiberty/concat.c (moved) * rtemstoolkit/libiberty/cp-demangle.c (moved) * rtemstoolkit/libiberty/cp-demangle.h (moved) * rtemstoolkit/libiberty/cplus-dem.c (moved) * rtemstoolkit/libiberty/demangle.h (moved) * rtemstoolkit/libiberty/libiberty.h (moved) * rtemstoolkit/libiberty/make-temp-file.c (moved) * rtemstoolkit/libiberty/mkstemps.c (moved) * rtemstoolkit/libiberty/pex-common.c (moved) * rtemstoolkit/libiberty/pex-common.h (moved) * rtemstoolkit/libiberty/pex-djgpp.c (moved) * rtemstoolkit/libiberty/pex-msdos.c (moved) * rtemstoolkit/libiberty/pex-one.c (moved) * rtemstoolkit/libiberty/pex-unix.c (moved) * rtemstoolkit/libiberty/pex-win32.c (moved) * rtemstoolkit/libiberty/safe-ctype.c (moved) * rtemstoolkit/libiberty/safe-ctype.h (moved) * rtemstoolkit/libiberty/stpcpy.c (moved) * rtemstoolkit/pkgconfig.cpp (moved) * rtemstoolkit/pkgconfig.h (moved) * rtemstoolkit/rld-cc.cpp (moved) * rtemstoolkit/rld-cc.h (moved) * rtemstoolkit/rld-compression.cpp (moved) * rtemstoolkit/rld-compression.h (moved) * rtemstoolkit/rld-config.cpp (moved) * rtemstoolkit/rld-config.h (moved) * rtemstoolkit/rld-elf-types.h (moved) * rtemstoolkit/rld-elf.cpp (moved) * rtemstoolkit/rld-elf.h (moved) * rtemstoolkit/rld-files.cpp (moved) * rtemstoolkit/rld-files.h (moved) * rtemstoolkit/rld-outputter.cpp (moved) * rtemstoolkit/rld-outputter.h (moved) * rtemstoolkit/rld-path.cpp (moved) * rtemstoolkit/rld-path.h (moved) * rtemstoolkit/rld-process.cpp (moved) * rtemstoolkit/rld-process.h (moved) * rtemstoolkit/rld-rap.cpp (moved) * rtemstoolkit/rld-rap.h (moved) * rtemstoolkit/rld-resolver.cpp (moved) * rtemstoolkit/rld-resolver.h (moved) * rtemstoolkit/rld-rtems.cpp (moved) * rtemstoolkit/rld-rtems.h (moved) * rtemstoolkit/rld-symbols.cpp (moved) * rtemstoolkit/rld-symbols.h (moved) * rtemstoolkit/rld.cpp (moved) * rtemstoolkit/rld.h (moved) * rtemstoolkit/rtems-utils.cpp (moved) * rtemstoolkit/rtems-utils.h (moved) * rtemstoolkit/wscript (added) * wscript (modified) Refactor code into the RTEMS Toolkit.
