# # ChangeLog for rtemstoolkit/linux.py in rtems-tools # # Generated by Trac 1.2.1.dev0 # 05/05/24 21:19:39 Mon, 24 Apr 2017 14:31:44 GMT Chris Johns [7d3350d] * rtemstoolkit/config.py (modified) * rtemstoolkit/darwin.py (modified) * rtemstoolkit/freebsd.py (modified) * rtemstoolkit/host.py (added) * rtemstoolkit/linux.py (modified) * rtemstoolkit/netbsd.py (modified) * rtemstoolkit/options.py (modified) * rtemstoolkit/solaris.py (modified) * rtemstoolkit/windows.py (modified) * tester/rt/stty.py (modified) rtemstoolkit: Move host support access into a separate module. ... Thu, 03 Mar 2016 05:46:18 GMT Chris Johns [b0fa2ae] * rtemstoolkit/__init__.py (modified) * rtemstoolkit/check.py (modified) * rtemstoolkit/config.py (modified) * rtemstoolkit/darwin.py (modified) * rtemstoolkit/error.py (modified) * rtemstoolkit/execute.py (modified) * rtemstoolkit/freebsd.py (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/linux.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/mailer.py (modified) * rtemstoolkit/netbsd.py (added) * rtemstoolkit/options.py (modified) * rtemstoolkit/path.py (modified) * rtemstoolkit/solaris.py (added) * rtemstoolkit/version.py (modified) * rtemstoolkit/windows.py (modified) * tester/rt/config.py (modified) * tester/rt/console.py (modified) * tester/rt/gdb.py (modified) * tester/rt/options.py (modified) * tester/rt/pygdb/__init__.py (modified) * tester/rt/pygdb/mi_parser.py (modified) * tester/rt/pygdb/spark.py (modified) * tester/rt/test.py (modified) * tester/rt/version.py (deleted) * tester/rtems-test (modified) Update rtems-tool to support Python 2 and 3. Add solaris and ... Fri, 14 Feb 2014 19:30:06 GMT Chris Johns [50fdf12] * rtemstoolkit/.gitignore (added) * rtemstoolkit/__init__.py (added) * rtemstoolkit/check.py (added) * rtemstoolkit/config.py (added) * rtemstoolkit/darwin.py (added) * rtemstoolkit/error.py (added) * rtemstoolkit/execute.py (added) * rtemstoolkit/freebsd.py (added) * rtemstoolkit/git.py (added) * rtemstoolkit/linux.py (added) * rtemstoolkit/log.py (added) * rtemstoolkit/macros.py (added) * rtemstoolkit/mailer.py (added) * rtemstoolkit/options.py (added) * rtemstoolkit/path.py (added) * rtemstoolkit/version.py (added) * rtemstoolkit/windows.py (added) * tester/.gitignore (added) * tester/config/base.cfg (added) * tester/config/checks.cfg (added) * tester/rt/__init__.py (added) * tester/rt/config.py (added) * tester/rt/console.py (added) * tester/rt/gdb.py (added) * tester/rt/options.py (added) * tester/rt/pygdb/__init__.py (added) * tester/rt/pygdb/mi_parser.py (added) * tester/rt/pygdb/spark.py (added) * tester/rt/report.py (added) * tester/rt/stty.py (added) * tester/rt/test.py (added) * tester/rt/version.py (added) * tester/rtems-test (added) * tester/rtems/testing/bsps/mcf5235.mc (added) * tester/rtems/testing/bsps/realview_pbx_a9_qemu.mc (added) * tester/rtems/testing/bsps/sis-run.mc (added) * tester/rtems/testing/bsps/sis.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_zc706.mc (added) * tester/rtems/testing/console.cfg (added) * tester/rtems/testing/defaults.mc (added) * tester/rtems/testing/gdb.cfg (added) * tester/rtems/testing/qemu.cfg (added) * tester/rtems/testing/run.cfg (added) * tester/rtems/testing/testing.mc (added) * tester/rtems/version.cfg (added) rt: Add the rtems-tester.
