# # ChangeLog for rtemstoolkit/elftoolchain/libdwarf/dwarf_die.c in rtems-tools # # Generated by Trac 1.2.1.dev0 # 05/19/24 22:30:13 Mon, 30 Apr 2018 05:34:48 GMT Chris Johns [4bb3996] * rtemstoolkit/elftoolchain/libdwarf/Makefile (added) * rtemstoolkit/elftoolchain/libdwarf/Version.map (added) * rtemstoolkit/elftoolchain/libdwarf/_libdwarf.h (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf.h (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_abbrev.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_comp_dir.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_const_value_string.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_dataref.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_flag.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_location_expr.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_name.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_producer.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_ref_address.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_reference.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_signed_const.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_string.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_AT_targ_address.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_arange.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_die_to_debug.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_directory_decl.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_expr_addr.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_expr_gen.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_fde_inst.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_file_decl.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_frame_cie.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_frame_fde.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_funcname.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_line_entry.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_pubname.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_typename.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_varname.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_add_weakname.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_arange.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_attr.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_attr.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_attrlist.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_attroffset.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_attrval.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_attrval_signed.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_child.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_cu.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_dealloc.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_dealloc.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_def_macro.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_die.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_die_abbrev_code.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_die_link.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_diename.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_dieoffset.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_dump.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_end_macro_file.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_errmsg.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_errmsg.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_errno.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_expand_frame_instructions.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_expr_current_offset.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_expr_into_block.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_fde_cfa_offset.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_find_macro_value_start.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_finish.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_finish.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_form.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_formaddr.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_formblock.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_formexprloc.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_formflag.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_formref.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_formsig8.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_formstring.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_formudata.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_frame.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_funcs.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_AT_name.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_abbrev.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_abbrev_children_flag.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_abbrev_code.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_abbrev_entry.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_abbrev_tag.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_address_size.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_arange.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_arange_info.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_aranges.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_cie_index.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_cie_info.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_cie_of_fde.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_cu_die_offset.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_die_infotypes_flag.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_elf.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_fde_at_pc.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_fde_info_for_all_regs.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_fde_info_for_all_regs3.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_fde_info_for_cfa_reg3.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_fde_info_for_reg.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_fde_info_for_reg3.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_fde_instr_bytes.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_fde_list.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_fde_n.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_fde_range.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_form_class.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_funcs.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_globals.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_loclist_entry.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_macro_details.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_pubtypes.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_ranges.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_relocation_info.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_relocation_info_count.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_section_bytes.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_section_max_offsets.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_str.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_types.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_vars.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_get_weaks.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_hasattr.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_hasform.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_highpc.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_init.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_init.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_lineno.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_lineno.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_lne_end_sequence.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_lne_set_address.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_loclist.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_loclist.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_loclist_from_expr.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_macinfo.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_nametbl.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_new_die.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_new_expr.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_new_fde.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_next_cu_header.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_next_types_section.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_object_init.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_arange.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_attr.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_die.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_expr.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_finish.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_frame.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_funcs.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_init.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_lineno.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_macinfo.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_nametbl.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_pubnames.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_reloc.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_sections.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_types.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_vars.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pro_weaks.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_producer_init.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_producer_set_isa.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pubnames.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_pubtypes.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_ranges.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_reloc.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_reset_section_bytes.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_sections.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_set_frame_cfa_value.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_set_reloc_application.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_seterrarg.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_seterror.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_srcfiles.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_srclines.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_start_macro_file.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_str.c (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_tag.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_transform_to_disk_form.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_types.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_undef_macro.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_vars.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_vendor_ext.3 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_weaks.m4 (added) * rtemstoolkit/elftoolchain/libdwarf/dwarf_whatattr.3 (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf.h (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_abbrev.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_arange.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_attr.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_die.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_elf_access.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_elf_init.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_error.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_frame.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_info.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_init.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_lineno.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_loc.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_loclist.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_macinfo.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_nametbl.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_ranges.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_reloc.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_rw.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_sections.c (added) * rtemstoolkit/elftoolchain/libdwarf/libdwarf_str.c (added) * rtemstoolkit/elftoolchain/libdwarf/os.NetBSD.mk (added) * rtemstoolkit/wscript (modified) rtemstoolkit: Add libdwarf from elftoolchain. The code is taken ...
