# # ChangeLog for rtemstoolkit/check.py in rtems-tools # # Generated by Trac 1.2.1.dev0 # 05/31/24 00:21:32 Fri, 23 Nov 2018 04:02:52 GMT Chris Johns [7e5cdea] * README (modified) * rtemstoolkit/__init__.py (modified) * rtemstoolkit/check.py (modified) * rtemstoolkit/config.py (modified) * rtemstoolkit/darwin.py (modified) * rtemstoolkit/freebsd.py (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/host.py (modified) * rtemstoolkit/linux.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/mailer.py (modified) * rtemstoolkit/netbsd.py (modified) * rtemstoolkit/options.py (modified) * rtemstoolkit/path.py (modified) * rtemstoolkit/rtems.py (modified) * rtemstoolkit/solaris.py (modified) * rtemstoolkit/textbox.py (modified) * rtemstoolkit/version.py (modified) * rtemstoolkit/windows.py (modified) * wscript (modified) rtemstoolkit: Add unit testing for the python modules - Add support ... Wed, 03 Oct 2018 01:38:09 GMT Chris Johns [3bd8def] * config/rtems-version.ini (added) * rtemstoolkit/check.py (modified) * rtemstoolkit/options.py (modified) * rtemstoolkit/rtems.py (modified) * rtemstoolkit/version.py (modified) * tester/rt/check.py (modified) * tester/rt/options.py (modified) * tester/rt/run.py (modified) * tester/rt/test.py (modified) * wscript (modified) config: Consolidate the version information into a single ... Thu, 03 Mar 2016 05:46:18 GMT Chris Johns [b0fa2ae] * rtemstoolkit/__init__.py (modified) * rtemstoolkit/check.py (modified) * rtemstoolkit/config.py (modified) * rtemstoolkit/darwin.py (modified) * rtemstoolkit/error.py (modified) * rtemstoolkit/execute.py (modified) * rtemstoolkit/freebsd.py (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/linux.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/mailer.py (modified) * rtemstoolkit/netbsd.py (added) * rtemstoolkit/options.py (modified) * rtemstoolkit/path.py (modified) * rtemstoolkit/solaris.py (added) * rtemstoolkit/version.py (modified) * rtemstoolkit/windows.py (modified) * tester/rt/config.py (modified) * tester/rt/console.py (modified) * tester/rt/gdb.py (modified) * tester/rt/options.py (modified) * tester/rt/pygdb/__init__.py (modified) * tester/rt/pygdb/mi_parser.py (modified) * tester/rt/pygdb/spark.py (modified) * tester/rt/test.py (modified) * tester/rt/version.py (deleted) * tester/rtems-test (modified) Update rtems-tool to support Python 2 and 3. Add solaris and ... Thu, 12 Nov 2015 10:15:23 GMT Sebastian Huber [04a5204] * rtemstoolkit/check.py (modified) * rtemstoolkit/config.py (modified) * rtemstoolkit/error.py (modified) * rtemstoolkit/execute.py (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/mailer.py (modified) * rtemstoolkit/options.py (modified) * rtemstoolkit/path.py (modified) * rtemstoolkit/version.py (modified) * tester/rt/config.py (modified) * tester/rt/console.py (modified) * tester/rt/gdb.py (modified) * tester/rt/options.py (modified) * tester/rt/pygdb/mi_parser.py (modified) * tester/rt/pygdb/spark.py (modified) * tester/rt/stty.py (modified) * tester/rt/test.py (modified) * tester/rt/version.py (modified) * tools/gdb/python/__init__.py (modified) * tools/gdb/python/classic.py (modified) * tools/gdb/python/heaps.py (modified) * tools/gdb/python/helper.py (modified) * tools/gdb/python/rtems.py (modified) * tools/gdb/python/sparc.py (modified) * tools/gdb/python/supercore.py (modified) * tools/gdb/python/watchdog.py (modified) Python 3 compatibility Fri, 14 Feb 2014 19:30:06 GMT Chris Johns [50fdf12] * rtemstoolkit/.gitignore (added) * rtemstoolkit/__init__.py (added) * rtemstoolkit/check.py (added) * rtemstoolkit/config.py (added) * rtemstoolkit/darwin.py (added) * rtemstoolkit/error.py (added) * rtemstoolkit/execute.py (added) * rtemstoolkit/freebsd.py (added) * rtemstoolkit/git.py (added) * rtemstoolkit/linux.py (added) * rtemstoolkit/log.py (added) * rtemstoolkit/macros.py (added) * rtemstoolkit/mailer.py (added) * rtemstoolkit/options.py (added) * rtemstoolkit/path.py (added) * rtemstoolkit/version.py (added) * rtemstoolkit/windows.py (added) * tester/.gitignore (added) * tester/config/base.cfg (added) * tester/config/checks.cfg (added) * tester/rt/__init__.py (added) * tester/rt/config.py (added) * tester/rt/console.py (added) * tester/rt/gdb.py (added) * tester/rt/options.py (added) * tester/rt/pygdb/__init__.py (added) * tester/rt/pygdb/mi_parser.py (added) * tester/rt/pygdb/spark.py (added) * tester/rt/report.py (added) * tester/rt/stty.py (added) * tester/rt/test.py (added) * tester/rt/version.py (added) * tester/rtems-test (added) * tester/rtems/testing/bsps/mcf5235.mc (added) * tester/rtems/testing/bsps/realview_pbx_a9_qemu.mc (added) * tester/rtems/testing/bsps/sis-run.mc (added) * tester/rtems/testing/bsps/sis.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_zc706.mc (added) * tester/rtems/testing/console.cfg (added) * tester/rtems/testing/defaults.mc (added) * tester/rtems/testing/gdb.cfg (added) * tester/rtems/testing/qemu.cfg (added) * tester/rtems/testing/run.cfg (added) * tester/rtems/testing/testing.mc (added) * tester/rtems/version.cfg (added) rt: Add the rtems-tester.
