@f43851a
12/31/12 07:29:10 |
Chris Johns |
Sort the relocation records by offset for a section.
4.104.115
@4e7ec70
12/31/12 07:12:25 |
Chris Johns |
Make layout offsets match image offsets. Add a better strtab search.
4.104.115
@06a2cf6
12/31/12 07:11:47 |
Chris Johns |
Sort the relocations by offset to make the overlay work.
4.104.115
@544de91
12/28/12 23:20:22 |
Chris Johns |
Fix managing weak symbols.
Weak symbols where not being managed …
4.104.115
@800d4fd
12/24/12 06:18:23 |
Chris Johns |
Add the symsect offset to the section reloc.
4.104.115
@073d244
12/24/12 06:17:53 |
Chris Johns |
Trace the reloc addend.
4.104.115
@f31cded
12/23/12 06:45:34 |
Chris Johns |
Improved section trace output.
Moved the section trace output to …
4.104.115
@5825009
12/23/12 06:04:11 |
Chris Johns |
Change the long opt from map to overlay.
4.104.115
@287569c
12/23/12 05:57:35 |
Chris Johns |
Add an overlay output.
An overlay shows the hex dump of the section …
4.104.115
@b9f631e
12/23/12 05:54:59 |
Chris Johns |
Add a memory dump utility.
4.104.115
@3e902c6
12/21/12 06:14:50 |
Chris Johns |
Fix the reloc symbol name.
4.104.115
@c487356
12/21/12 06:12:07 |
Chris Johns |
Finish a dump of the RAP file. Fix expanding.
4.104.115
@6c28ffb
12/21/12 06:10:18 |
Chris Johns |
Set header length. Make sections public.
Set the compressed file …
4.104.115
@4e9b324
12/21/12 06:08:17 |
Chris Johns |
Decompressor fixes.
Make reading compressed files more robust …
4.104.115
@74e89db
12/19/12 05:24:48 |
Chris Johns |
Turn off the debug.
4.104.115
@8bb0d53
12/19/12 05:24:24 |
Chris Johns |
RAP file utility. Decompressors RAP files.
4.104.115
@db216fe
12/19/12 05:22:37 |
Chris Johns |
Decompression support added.
The compressor can now decompress LZ77 files.
4.104.115
@b2b811c
12/18/12 09:57:00 |
Chris Johns |
Fixes to load libbsdports on i386.
Numerous fixes to load the the …
4.104.115
@53221a0
12/18/12 09:52:18 |
Chris Johns |
Add object::get_section.
Add a method to return a section given the …
4.104.115
@b5a59dd
12/18/12 09:51:41 |
Chris Johns |
Use cerr for errors and not cout.
4.104.115
@194160c
12/18/12 09:48:35 |
Chris Johns |
Update the data out pointer.
The data pointer was not updating when …
4.104.115
@13b9f2b
12/18/12 09:47:27 |
Chris Johns |
Add a new trace level.
4.104.115
@f10123a
12/15/12 12:30:46 |
Chris Johns |
Const sections are not PROGBITS and ALLOC and not EXECINTR or WRITE.
4.104.115
@d54e81c
12/15/12 12:19:21 |
Chris Johns |
Debug trace changes.
4.104.115
@b89ad2c6
12/15/12 11:44:58 |
Chris Johns |
i386 related fixes
Fix the size of the section calculated in …
4.104.115
@f4d580b
12/12/12 23:07:32 |
Chris Johns |
Add the section offset to the symbol value.
4.104.115
@42f766f
12/12/12 10:51:03 |
Chris Johns |
Relocation fixes.
These changes implement a suitable relocation …
4.104.115
@90d8d43
12/07/12 22:07:30 |
Chris Johns |
Add support to demand load relocation records.
Support has been added …
4.104.115
@be8e188
12/07/12 22:05:12 |
Chris Johns |
Add doxygen support.
4.104.115
@825a10e
12/01/12 10:22:24 |
Chris Johns |
The symbol string is the offset into the symbol table.
4.104.115
@9ba89e1
11/30/12 21:09:02 |
Chris Johns |
Remove the trace on hack.
4.104.115
@803c60a
11/30/12 21:05:47 |
Chris Johns |
RAP format up to relocation records completed.
Do not write the …
4.104.115
@1a5bdef
11/29/12 08:05:19 |
Chris Johns |
Add support for a custom RAP file format.
The file is a header and a …
4.104.115
@93e80d5
11/29/12 08:04:12 |
Chris Johns |
Compress as blocks.
The LZ77 compressor works with blocks. Each block …
4.104.115
@9c70d15
11/29/12 08:03:37 |
Chris Johns |
Remove the \0 character after the header.
4.104.115
@662c504
11/29/12 08:02:28 |
Chris Johns |
Add the index to the section.
The index is referenced in the symbol …
4.104.115
@ea6f8d4
11/29/12 08:01:43 |
Chris Johns |
Add access to the value and info fields of a symbols.
4.104.115
@dc1c744
11/27/12 00:19:15 |
Chris Johns |
Add machine related data to allow better checking.
4.104.115
@d99913f
11/27/12 00:17:02 |
Chris Johns |
Remove size_t stream operator.
On Darwin the operator works which on …
4.104.115
@8190102
11/26/12 01:14:06 |
Chris Johns |
Update to the latest framwork requirements.
4.104.115
@ae353d3
11/26/12 00:50:21 |
Chris Johns |
Comment clean up.
4.104.115
@eb825b1
11/26/12 00:09:35 |
Chris Johns |
Add RAP format support.
4.104.115
@cad8b53
11/26/12 00:09:06 |
Chris Johns |
Updated to reflect the framework changes.
4.104.115
@a458e27
11/26/12 00:07:06 |
Chris Johns |
Add exit label, ELF application and Application.
Add an exit label …
4.104.115
@076d935
11/26/12 00:04:57 |
Chris Johns |
Add writing from images as well as streaming operators.
Add the …
4.104.115
@a5fcdd5
11/26/12 00:00:34 |
Chris Johns |
No archive begin/end on symbols load, image initialise fix, add …
4.104.115
@4c89c2d
11/25/12 23:59:19 |
Chris Johns |
Update the section details.
4.104.115
@c6b714f
11/25/12 23:57:29 |
Chris Johns |
Load the sections by default. It is not much extra overhead.
Clean up …
4.104.115
@1d60a4a
11/25/12 23:46:40 |
Chris Johns |
Split trace to have without and with symbols.
4.104.115
@3f37835
11/22/12 05:22:22 |
Chris Johns |
Split out the compression code for reuse.
4.104.115
@c2657cd
11/21/12 06:40:44 |
Chris Johns |
Clean archive names for every output format other than scripts.
4.104.115
@7b2762f
11/21/12 02:36:32 |
Chris Johns |
Make the entry point an unresolved symbol.
4.104.115
@43ec8b0
11/21/12 02:36:04 |
Chris Johns |
Set the default value for empty symbols to 0 to match the const char* …
4.104.115
@c46980e
11/21/12 02:04:47 |
Chris Johns |
Add entry point support.
4.104.115
@b770b0c
11/21/12 02:04:19 |
Chris Johns |
Make getting objects const.
4.104.115
@9ba4e48
11/21/12 01:12:50 |
Chris Johns |
Remove the warning about the warnings option on newer gccs.
4.104.115
@6565f0c
11/21/12 01:12:21 |
Chris Johns |
Enforce the header is created before using it on Linux.
4.104.115
@c1d1636
11/21/12 01:11:49 |
Chris Johns |
Add header to remove warning on Linux.
4.104.115
@eb34811
11/21/12 00:07:12 |
Chris Johns |
Output application format files.
Added support for an RTEMS RAP …
4.104.115
@a1d4930
11/21/12 00:05:04 |
Chris Johns |
Set the correct header size field.
4.104.115
@fe19d06
11/20/12 23:40:01 |
Chris Johns |
Fix archive GNU extension and make image read/write follow POSIX.
Fix …
4.104.115
@fd8a2c5
11/20/12 08:53:24 |
Chris Johns |
Add support to write a metadata ELF file.
This also adds support to …
4.104.115
@9b66527
11/19/12 02:13:52 |
Chris Johns |
Only look for standard library paths if standard libraries and enabled.
4.104.115
@596e5fa
11/18/12 23:37:37 |
Chris Johns |
Add set_header support to the ELF files.
4.104.115
@1976825
11/18/12 23:36:34 |
Chris Johns |
Resolve the ld and user undefines.
4.104.115
@ead8da1
11/18/12 23:35:51 |
Chris Johns |
Add configure option --c-opts to allow special options for testing.
4.104.115
@8ad4837
11/18/12 23:35:15 |
Chris Johns |
Fix warning from clang.
4.104.115
@f1cf3a9
11/17/12 20:37:02 |
Chris Johns |
Better handling of archive open/close and begin/end.
4.104.115
@065ac15
11/17/12 06:42:22 |
Chris Johns |
Remove dead code.
4.104.115
@977c3de
11/17/12 06:34:33 |
Chris Johns |
Refactor the ELF support to allow ELF write suppport.
The refactoring …
4.104.115
@0b65a28
11/17/12 06:31:56 |
Chris Johns |
Fix spelling.
4.104.115
@16e4346
10/23/12 01:46:59 |
Chris Johns |
Add FastLZ support.
4.104.115
@810d0ad
10/23/12 00:58:34 |
Chris Johns |
Fix repeats in output when cmd line objects depend on each other.
If …
4.104.115
@7ec2c5a
10/22/12 14:12:47 |
Chris Johns |
Ignore working files.
4.104.115
@8f0740b
10/22/12 14:12:29 |
Chris Johns |
Script to test the linker. Run after building the linker.
4.104.115
@898fa13
10/22/12 14:11:04 |
Chris Johns |
Fix the verbose level.
4.104.115
@8d1ab1f
10/22/12 14:10:45 |
Chris Johns |
Add script output dbug messages.
4.104.115
@ef4061f
10/22/12 14:10:23 |
Chris Johns |
Fix the command line arguments help.
4.104.115
@7461924
09/17/12 00:13:55 |
Chris Johns |
Rename rld-gcc. Add -C option.
Add a -C (also --cc) option to allow …
4.104.115
@aef6d90
09/16/12 23:37:29 |
Chris Johns |
Update the help to something useful.
4.104.115
@1ec9633
09/16/12 23:37:07 |
Chris Johns |
Add rebuild and tags build commands
4.104.115
@993aa67
09/15/12 07:58:00 |
Chris Johns |
Fix the waf script.
4.104.115
@ec24a37
05/06/12 22:47:11 |
Chris Johns |
Add to git.
4.104.115
