Search:
Preferences
About Trac
Wiki
Timeline
Roadmap
View Tickets
Search
Context Navigation
View Latest Revision
Notice:
We have migrated to GitLab launching 2024-05-01 see here:
https://gitlab.rtems.org/
source:
rtems-tools
linkers
Revision Log Mode:
Stop on copy
Follow copies
Show only adds and deletes
View log starting at
and back to
Show at most
revisions per page.
Show full log messages
Legend:
Added
Modified
Copied or renamed
Diff
Rev
Age
Author
Log Message
(edit)
@1976825
11/18/12 23:36:34
Chris Johns
Resolve the ld and user undefines.
4.10
4.11
5
(edit)
@ead8da1
11/18/12 23:35:51
Chris Johns
Add configure option --c-opts to allow special options for testing.
4.10
4.11
5
(edit)
@8ad4837
11/18/12 23:35:15
Chris Johns
Fix warning from clang.
4.10
4.11
5
(edit)
@f1cf3a9
11/17/12 20:37:02
Chris Johns
Better handling of archive open/close and begin/end.
4.10
4.11
5
(edit)
@065ac15
11/17/12 06:42:22
Chris Johns
Remove dead code.
4.10
4.11
5
(edit)
@977c3de
11/17/12 06:34:33
Chris Johns
Refactor the ELF support to allow ELF write suppport. The refactoring …
4.10
4.11
5
(edit)
@0b65a28
11/17/12 06:31:56
Chris Johns
Fix spelling.
4.10
4.11
5
(edit)
@16e4346
10/23/12 01:46:59
Chris Johns
Add FastLZ support.
4.10
4.11
5
(edit)
@810d0ad
10/23/12 00:58:34
Chris Johns
Fix repeats in output when cmd line objects depend on each other. If …
4.10
4.11
5
(edit)
@7ec2c5a
10/22/12 14:12:47
Chris Johns
Ignore working files.
4.10
4.11
5
(edit)
@8f0740b
10/22/12 14:12:29
Chris Johns
Script to test the linker. Run after building the linker.
4.10
4.11
5
(edit)
@898fa13
10/22/12 14:11:04
Chris Johns
Fix the verbose level.
4.10
4.11
5
(edit)
@8d1ab1f
10/22/12 14:10:45
Chris Johns
Add script output dbug messages.
4.10
4.11
5
(edit)
@ef4061f
10/22/12 14:10:23
Chris Johns
Fix the command line arguments help.
4.10
4.11
5
(edit)
@7461924
09/17/12 00:13:55
Chris Johns
Rename rld-gcc. Add -C option. Add a -C (also --cc) option to allow …
4.10
4.11
5
(edit)
@aef6d90
09/16/12 23:37:29
Chris Johns
Update the help to something useful.
4.10
4.11
5
(edit)
@1ec9633
09/16/12 23:37:07
Chris Johns
Add rebuild and tags build commands
4.10
4.11
5
(edit)
@993aa67
09/15/12 07:58:00
Chris Johns
Fix the waf script.
4.10
4.11
5
(add)
@ec24a37
05/06/12 22:47:11
Chris Johns
Add to git.
4.10
4.11
5
Note:
See
TracRevisionLog
for help on using the revision log.
Download in other formats:
RSS Feed
ChangeLog
