# # ChangeLog for linkers/rtems-score-thread.ini in rtems-tools # # Generated by Trac 1.2.1.dev0 # 04/25/24 05:50:31 Sun, 21 Sep 2014 04:24:37 GMT Chris Johns [5025439] * linkers/rtems-api.ini (added) * linkers/rtems-score-coremutex.ini (added) * linkers/rtems-score-heap.ini (added) * linkers/rtems-score-object.ini (added) * linkers/rtems-score-thread.ini (added) * linkers/rtems-score.ini (added) * linkers/rtems-tld.cpp (modified) * linkers/rtems.ini (modified) * linkers/rtld-base.ini (modified) * linkers/rtld-print.ini (added) * linkers/wscript (modified) * rtemstoolkit/rld-config.cpp (modified) * rtemstoolkit/rld-config.h (modified) rtems-tld: Add config options, fix void args, and SCore traces.
