# # ChangeLog for linkers/rld-symbols.h in rtems-tools # # Generated by Trac 1.2.1.dev0 # 05/28/24 05:48:04 Fri, 28 Dec 2012 23:20:22 GMT Chris Johns [544de91] * linkers/rld-elf.cpp (modified) * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) * linkers/rld-outputter.cpp (modified) * linkers/rld-resolver.cpp (modified) * linkers/rld-resolver.h (modified) * linkers/rld-symbols.cpp (modified) * linkers/rld-symbols.h (modified) * linkers/rtems-ld.cpp (modified) Fix managing weak symbols. Weak symbols where not being managed ... Fri, 07 Dec 2012 22:07:30 GMT Chris Johns [90d8d43] * linkers/rld-elf-types.h (modified) * linkers/rld-elf.cpp (modified) * linkers/rld-elf.h (modified) * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) * linkers/rld-rap.cpp (modified) * linkers/rld-symbols.cpp (modified) * linkers/rld-symbols.h (modified) Add support to demand load relocation records. Support has been ... Thu, 29 Nov 2012 08:01:43 GMT Chris Johns [ea6f8d4] * linkers/rld-symbols.cpp (modified) * linkers/rld-symbols.h (modified) Add access to the value and info fields of a symbols. Wed, 21 Nov 2012 02:36:04 GMT Chris Johns [43ec8b0] * linkers/rld-symbols.h (modified) Set the default value for empty symbols to 0 to match the const char* ... Sat, 17 Nov 2012 06:34:33 GMT Chris Johns [977c3de] * linkers/rld-elf-types.h (modified) * linkers/rld-elf.cpp (modified) * linkers/rld-elf.h (modified) * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) * linkers/rld-outputter.cpp (modified) * linkers/rld-resolver.cpp (modified) * linkers/rld-symbols.cpp (modified) * linkers/rld-symbols.h (modified) * linkers/rld.cpp (modified) * linkers/rtems-ld.cpp (moved) * linkers/rtems-syms.cpp (added) * linkers/wscript (modified) Refactor the ELF support to allow ELF write suppport. The ... Sun, 06 May 2012 22:47:11 GMT Chris Johns [ec24a37] * linkers/README (added) * linkers/elftoolchain/common/Makefile (added) * linkers/elftoolchain/common/_elftc.h (added) * linkers/elftoolchain/common/elfdefinitions.h (added) * linkers/elftoolchain/common/native-elf-format (added) * linkers/elftoolchain/common/os.Linux.mk (added) * linkers/elftoolchain/common/uthash.h (added) * linkers/elftoolchain/libelf/Makefile (added) * linkers/elftoolchain/libelf/Version.map (added) * linkers/elftoolchain/libelf/_libelf.h (added) * linkers/elftoolchain/libelf/_libelf_ar.h (added) * linkers/elftoolchain/libelf/_libelf_config.h (added) * linkers/elftoolchain/libelf/elf.3 (added) * linkers/elftoolchain/libelf/elf.c (added) * linkers/elftoolchain/libelf/elf_begin.3 (added) * linkers/elftoolchain/libelf/elf_begin.c (added) * linkers/elftoolchain/libelf/elf_cntl.3 (added) * linkers/elftoolchain/libelf/elf_cntl.c (added) * linkers/elftoolchain/libelf/elf_data.c (added) * linkers/elftoolchain/libelf/elf_end.3 (added) * linkers/elftoolchain/libelf/elf_end.c (added) * linkers/elftoolchain/libelf/elf_errmsg.3 (added) * linkers/elftoolchain/libelf/elf_errmsg.c (added) * linkers/elftoolchain/libelf/elf_errno.c (added) * linkers/elftoolchain/libelf/elf_fill.3 (added) * linkers/elftoolchain/libelf/elf_fill.c (added) * linkers/elftoolchain/libelf/elf_flag.c (added) * linkers/elftoolchain/libelf/elf_flagdata.3 (added) * linkers/elftoolchain/libelf/elf_getarhdr.3 (added) * linkers/elftoolchain/libelf/elf_getarhdr.c (added) * linkers/elftoolchain/libelf/elf_getarsym.3 (added) * linkers/elftoolchain/libelf/elf_getarsym.c (added) * linkers/elftoolchain/libelf/elf_getbase.3 (added) * linkers/elftoolchain/libelf/elf_getbase.c (added) * linkers/elftoolchain/libelf/elf_getdata.3 (added) * linkers/elftoolchain/libelf/elf_getident.3 (added) * linkers/elftoolchain/libelf/elf_getident.c (added) * linkers/elftoolchain/libelf/elf_getphdrnum.3 (added) * linkers/elftoolchain/libelf/elf_getphnum.3 (added) * linkers/elftoolchain/libelf/elf_getscn.3 (added) * linkers/elftoolchain/libelf/elf_getshdrnum.3 (added) * linkers/elftoolchain/libelf/elf_getshdrstrndx.3 (added) * linkers/elftoolchain/libelf/elf_getshnum.3 (added) * linkers/elftoolchain/libelf/elf_getshstrndx.3 (added) * linkers/elftoolchain/libelf/elf_hash.3 (added) * linkers/elftoolchain/libelf/elf_hash.c (added) * linkers/elftoolchain/libelf/elf_kind.3 (added) * linkers/elftoolchain/libelf/elf_kind.c (added) * linkers/elftoolchain/libelf/elf_memory.3 (added) * linkers/elftoolchain/libelf/elf_memory.c (added) * linkers/elftoolchain/libelf/elf_next.3 (added) * linkers/elftoolchain/libelf/elf_next.c (added) * linkers/elftoolchain/libelf/elf_phnum.c (added) * linkers/elftoolchain/libelf/elf_rand.3 (added) * linkers/elftoolchain/libelf/elf_rand.c (added) * linkers/elftoolchain/libelf/elf_rawfile.3 (added) * linkers/elftoolchain/libelf/elf_rawfile.c (added) * linkers/elftoolchain/libelf/elf_scn.c (added) * linkers/elftoolchain/libelf/elf_shnum.c (added) * linkers/elftoolchain/libelf/elf_shstrndx.c (added) * linkers/elftoolchain/libelf/elf_strptr.3 (added) * linkers/elftoolchain/libelf/elf_strptr.c (added) * linkers/elftoolchain/libelf/elf_types.m4 (added) * linkers/elftoolchain/libelf/elf_update.3 (added) * linkers/elftoolchain/libelf/elf_update.c (added) * linkers/elftoolchain/libelf/elf_version.3 (added) * linkers/elftoolchain/libelf/elf_version.c (added) * linkers/elftoolchain/libelf/gelf.3 (added) * linkers/elftoolchain/libelf/gelf.h (added) * linkers/elftoolchain/libelf/gelf_cap.c (added) * linkers/elftoolchain/libelf/gelf_checksum.3 (added) * linkers/elftoolchain/libelf/gelf_checksum.c (added) * linkers/elftoolchain/libelf/gelf_dyn.c (added) * linkers/elftoolchain/libelf/gelf_ehdr.c (added) * linkers/elftoolchain/libelf/gelf_fsize.3 (added) * linkers/elftoolchain/libelf/gelf_fsize.c (added) * linkers/elftoolchain/libelf/gelf_getcap.3 (added) * linkers/elftoolchain/libelf/gelf_getclass.3 (added) * linkers/elftoolchain/libelf/gelf_getclass.c (added) * linkers/elftoolchain/libelf/gelf_getdyn.3 (added) * linkers/elftoolchain/libelf/gelf_getehdr.3 (added) * linkers/elftoolchain/libelf/gelf_getmove.3 (added) * linkers/elftoolchain/libelf/gelf_getphdr.3 (added) * linkers/elftoolchain/libelf/gelf_getrel.3 (added) * linkers/elftoolchain/libelf/gelf_getrela.3 (added) * linkers/elftoolchain/libelf/gelf_getshdr.3 (added) * linkers/elftoolchain/libelf/gelf_getsym.3 (added) * linkers/elftoolchain/libelf/gelf_getsyminfo.3 (added) * linkers/elftoolchain/libelf/gelf_getsymshndx.3 (added) * linkers/elftoolchain/libelf/gelf_move.c (added) * linkers/elftoolchain/libelf/gelf_newehdr.3 (added) * linkers/elftoolchain/libelf/gelf_newphdr.3 (added) * linkers/elftoolchain/libelf/gelf_phdr.c (added) * linkers/elftoolchain/libelf/gelf_rel.c (added) * linkers/elftoolchain/libelf/gelf_rela.c (added) * linkers/elftoolchain/libelf/gelf_shdr.c (added) * linkers/elftoolchain/libelf/gelf_sym.c (added) * linkers/elftoolchain/libelf/gelf_syminfo.c (added) * linkers/elftoolchain/libelf/gelf_symshndx.c (added) * linkers/elftoolchain/libelf/gelf_update_ehdr.3 (added) * linkers/elftoolchain/libelf/gelf_xlate.c (added) * linkers/elftoolchain/libelf/gelf_xlatetof.3 (added) * linkers/elftoolchain/libelf/libelf.h (added) * linkers/elftoolchain/libelf/libelf_align.c (added) * linkers/elftoolchain/libelf/libelf_allocate.c (added) * linkers/elftoolchain/libelf/libelf_ar.c (added) * linkers/elftoolchain/libelf/libelf_ar_util.c (added) * linkers/elftoolchain/libelf/libelf_checksum.c (added) * linkers/elftoolchain/libelf/libelf_convert.m4 (added) * linkers/elftoolchain/libelf/libelf_data.c (added) * linkers/elftoolchain/libelf/libelf_ehdr.c (added) * linkers/elftoolchain/libelf/libelf_extended.c (added) * linkers/elftoolchain/libelf/libelf_fsize.m4 (added) * linkers/elftoolchain/libelf/libelf_msize.m4 (added) * linkers/elftoolchain/libelf/libelf_phdr.c (added) * linkers/elftoolchain/libelf/libelf_shdr.c (added) * linkers/elftoolchain/libelf/libelf_xlate.c (added) * linkers/elftoolchain/libelf/mmap_win32.c (added) * linkers/elftoolchain/libelf/os.FreeBSD.mk (added) * linkers/elftoolchain/libelf/os.NetBSD.mk (added) * linkers/libiberty/ansidecl.h (added) * linkers/libiberty/concat.c (added) * linkers/libiberty/cp-demangle.c (added) * linkers/libiberty/cp-demangle.h (added) * linkers/libiberty/cplus-dem.c (added) * linkers/libiberty/demangle.h (added) * linkers/libiberty/libiberty.h (added) * linkers/libiberty/make-temp-file.c (added) * linkers/libiberty/mkstemps.c (added) * linkers/libiberty/pex-common.c (added) * linkers/libiberty/pex-common.h (added) * linkers/libiberty/pex-djgpp.c (added) * linkers/libiberty/pex-msdos.c (added) * linkers/libiberty/pex-one.c (added) * linkers/libiberty/pex-unix.c (added) * linkers/libiberty/pex-win32.c (added) * linkers/libiberty/safe-ctype.c (added) * linkers/libiberty/safe-ctype.h (added) * linkers/libiberty/stpcpy.c (added) * linkers/main.cpp (added) * linkers/pkgconfig.cpp (added) * linkers/pkgconfig.h (added) * linkers/rld-elf-types.h (added) * linkers/rld-elf.cpp (added) * linkers/rld-elf.h (added) * linkers/rld-files.cpp (added) * linkers/rld-files.h (added) * linkers/rld-gcc.cpp (added) * linkers/rld-gcc.h (added) * linkers/rld-outputter.cpp (added) * linkers/rld-outputter.h (added) * linkers/rld-process.cpp (added) * linkers/rld-process.h (added) * linkers/rld-resolver.cpp (added) * linkers/rld-resolver.h (added) * linkers/rld-symbols.cpp (added) * linkers/rld-symbols.h (added) * linkers/rld.cpp (added) * linkers/rld.h (added) * linkers/win32/ar.h (added) * linkers/win32/sys/cdefs.h (added) * linkers/win32/sys/errno.h (added) * linkers/win32/sys/mman.h (added) * linkers/win32/sys/queue.h (added) * linkers/wscript (added) Add to git.
