# # ChangeLog for config/rtems-bsps-powerpc.ini in rtems-tools # # Generated by Trac 1.2.1.dev0 # 04/18/24 07:02:55 Tue, 02 Oct 2018 06:49:54 GMT Chris Johns [5416cfa] * config/rtems-bsps-arm.ini (moved) * config/rtems-bsps-bfin.ini (moved) * config/rtems-bsps-epiphany.ini (moved) * config/rtems-bsps-i386.ini (moved) * config/rtems-bsps-lm32.ini (moved) * config/rtems-bsps-m32c.ini (moved) * config/rtems-bsps-m68k.ini (moved) * config/rtems-bsps-mips.ini (moved) * config/rtems-bsps-moxie.ini (moved) * config/rtems-bsps-nios2.ini (moved) * config/rtems-bsps-or1k.ini (moved) * config/rtems-bsps-powerpc.ini (moved) * config/rtems-bsps-riscv.ini (moved) * config/rtems-bsps-riscv32.ini (moved) * config/rtems-bsps-riscv64.ini (moved) * config/rtems-bsps-sh.ini (moved) * config/rtems-bsps-sparc.ini (moved) * config/rtems-bsps-sparc64.ini (moved) * config/rtems-bsps-tiers.ini (moved) * config/rtems-bsps-v850.ini (moved) * config/rtems-bsps.ini (moved) * config/wscript (added) * rtemstoolkit/__init__.py (modified) * rtemstoolkit/rtems.py (added) * rtemstoolkit/wscript (modified) * tester/rt/check.py (modified) * wscript (modified) config: Create a config directory and move the RTEMS arch/bsp data to ...
