# # ChangeLog for README in rtems-tools # # Generated by Trac 1.2.1.dev0 # 04/25/24 04:36:44 Fri, 23 Nov 2018 04:02:52 GMT Chris Johns [7e5cdea] * README (modified) * rtemstoolkit/__init__.py (modified) * rtemstoolkit/check.py (modified) * rtemstoolkit/config.py (modified) * rtemstoolkit/darwin.py (modified) * rtemstoolkit/freebsd.py (modified) * rtemstoolkit/git.py (modified) * rtemstoolkit/host.py (modified) * rtemstoolkit/linux.py (modified) * rtemstoolkit/log.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/mailer.py (modified) * rtemstoolkit/netbsd.py (modified) * rtemstoolkit/options.py (modified) * rtemstoolkit/path.py (modified) * rtemstoolkit/rtems.py (modified) * rtemstoolkit/solaris.py (modified) * rtemstoolkit/textbox.py (modified) * rtemstoolkit/version.py (modified) * rtemstoolkit/windows.py (modified) * wscript (modified) rtemstoolkit: Add unit testing for the python modules - Add support ... Sat, 13 Sep 2014 00:47:07 GMT Chris Johns [749ddf1] * .gitignore (modified) * README (modified) * linkers/wscript (modified) * tester/covoar/wscript (modified) * tester/wscript (added) * tools/gdb/python/wscript (modified) * waf (added) * wscript (added) waf: Include waf in the souce tree and updated README on building. ... Sun, 24 Aug 2014 23:48:23 GMT Chris Johns [4dbd0db] * README (modified) Fix README mistakes. Mon, 17 Feb 2014 06:56:03 GMT Chris Johns [11d4b89] * .gitignore (added) * README (added) Add README. Also add a git ignore. Wed, 06 Mar 2013 15:25:00 GMT Gedare Bloom [6d5bfb0] * ChangeLog (deleted) * README (deleted) * specbuilder/sb-build (deleted) * specbuilder/sb-crossgcc (deleted) * specbuilder/sb-setup (deleted) * specbuilder/sb-specdump (deleted) * specbuilder/sb-status (deleted) * specbuilder/sb-versions (deleted) * specbuilder/specbuilder/.gitignore (deleted) * specbuilder/specbuilder/build.py (deleted) * specbuilder/specbuilder/config.sub (deleted) * specbuilder/specbuilder/crossgcc.py (deleted) * specbuilder/specbuilder/darwin.py (deleted) * specbuilder/specbuilder/defaults.py (deleted) * specbuilder/specbuilder/error.py (deleted) * specbuilder/specbuilder/execute.py (deleted) * specbuilder/specbuilder/freebsd.py (deleted) * specbuilder/specbuilder/linux.py (deleted) * specbuilder/specbuilder/log.py (deleted) * specbuilder/specbuilder/perl.prov (deleted) * specbuilder/specbuilder/perl.req (deleted) * specbuilder/specbuilder/rtems.py (deleted) * specbuilder/specbuilder/setup.py (deleted) * specbuilder/specbuilder/spec.py (deleted) * specbuilder/specbuilder/status.py (deleted) * specbuilder/specbuilder/version.py (deleted) * specbuilder/specbuilder/windows.py (deleted) Clean up. Remove all files to prepare repo for a new life. ... Mon, 09 Aug 2010 01:04:21 GMT Chris Johns [78c9ac0] * README (added) Create RTEMS Tools.
