@e98d5fa
03/29/15 16:35:59 |
Joel Sherrill |
Add configurations for erc32, leon2, and leon3 in GDB SIS
These …
4.104.115
@b249516
03/29/15 07:06:00 |
Chris Johns |
rtemstoolkit: Add support to return the system path split as paths.
4.104.115
@5032d71
03/29/15 05:37:22 |
Chris Johns |
trace-linker: Update comments.
4.104.115
@bfd2b7d
03/26/15 18:20:45 |
Joel Sherrill |
Add Jiri Gaisler SIS patch set for gdb 7.9
This patch set adds a lot …
4.104.115
@d499e6d
03/27/15 09:21:33 |
Chris Johns |
trace-linker: Add the trace function signatures to the wrapper code.
4.104.115
@f5b639b
03/27/15 03:21:56 |
Chris Johns |
rtems-tester: Remove repeated install line in wscript.
Fixes #2312.
4.104.115
@20feafb
03/26/15 18:20:15 |
Joel Sherrill |
Add rtems-tester configurations for simsh family of BSPs
4.104.115
@b69cd3f
03/26/15 07:23:35 |
Chris Johns |
trace-linker: Add API and POSIX interfaces.
4.104.115
@b988768
03/26/15 06:08:18 |
Chris Johns |
trace-linker: Add Trace Buffering support.
Trace buffering traces …
4.104.115
@1703041
03/24/15 03:37:35 |
Chris Johns |
rtems-tld: Add lock and buffer allocator support to generators.
4.104.115
@29ad92c5
03/23/15 06:19:01 |
Chris Johns |
trace-linker: Add options, names, enables, and triggers.
Move the …
4.104.115
@8531776
03/23/15 06:18:39 |
Chris Johns |
rtemstoolkit: Add an array operator to return recs in a section.
4.104.115
@4585798
03/22/15 04:21:25 |
Chris Johns |
Update the version of waf.
The commit references #2312.
4.104.115
@36e6631
03/18/15 05:44:19 |
Chris Johns |
rtemstoolkit: Remove warning on Windows.
4.104.115
@ea749e5
03/18/15 05:43:30 |
Chris Johns |
Ignore waf files on Windows and Python3 waf files.
4.104.115
@dfc5994
03/17/15 10:37:43 |
Chris Johns |
elftoolchain: Add support for Cygwin.
4.104.115
@b117be8
03/17/15 02:11:57 |
Chris Johns |
gdb/python: Update the support to a recent RTEMS.
4.104.115
@a30ec56
03/12/15 22:29:37 |
Joel Sherrill |
Add configurations for all h8 GDB simulator BSP variants
4.104.115
@8abbe80
03/12/15 22:17:56 |
Joel Sherrill |
Add configurations for all arm GDB simulator BSP variants
4.104.115
@ab5e0c5
03/12/15 21:55:43 |
Joel Sherrill |
Add configuration for m32csim BSP for simulator in GDB
4.104.115
@b938414
03/12/15 18:51:32 |
Joel Sherrill |
Add configuration for m32rsim BSP for simulator in GDB
4.104.115
@71fb99b
03/12/15 17:47:13 |
Joel Sherrill |
Add configurations for all v850 GDB simulator BSP variants
4.104.115
@01a4192
02/22/15 06:07:10 |
asahasra |
Modified waf scripts to have a minimum python version requirement of …
4.104.115
@e143a62
02/16/15 00:27:18 |
Chris Johns |
Fix the chmod octal value to use the correct Python syntax.
4.104.115
@a8c4f3f
02/16/15 00:25:22 |
Chris Johns |
Update the Windows header to direct.h for _mkdir per the MSDN.
4.104.115
@05fe73d
02/08/15 07:40:35 |
Chris Johns |
Fix the tester wscript.
4.104.115
@9600c39
02/08/15 07:14:16 |
Chris Johns |
Fixes to the run the waf built tests when installed.
4.104.115
@b7d48ef
02/08/15 06:12:04 |
Chris Johns |
Install the rtems-test command.
This installs the Python RTEMS …
4.104.115
@7338811
01/20/15 23:52:54 |
Chris Johns |
Remove warning on Linux.
4.104.115
@69c955d
01/20/15 23:51:48 |
Chris Johns |
DEST_OS is linux and not linux2.
4.104.115
@f381f26
01/19/15 21:56:14 |
Chris Johns |
Fix covoar so it builds for Windows.
4.104.115
@3badbb0
01/18/15 07:12:18 |
Chris Johns |
Add support to cross-compile. Use --hosti=.
On FreeBSD use …
4.104.115
@3f47178
01/09/15 14:37:25 |
Sebastian Huber |
Add PowerPC patches for GCC 4.9.2
4.104.115
@8de6f6b
12/18/14 04:15:11 |
Chris Johns |
rtems-tld: Install the libc heap configuration files.
4.104.115
@7fc1edb
12/18/14 04:07:59 |
Chris Johns |
rtems-tld: Add configuration support for libc head tracing.
These …
4.104.115
@d8a82fd
12/04/14 12:02:27 |
Sebastian Huber |
Add SPARC patches for GCC 4.9.2
These patches are already present in …
4.104.115
@af8c147a
11/14/14 22:19:09 |
Jiri Gaisler |
gdb patch to add leon2/3 support to sis
This fixes the commit …
4.104.115
@4bdba3e
12/02/14 04:50:02 |
Chris Johns |
tools/gdb: Add a patch for gdb-7.7/gdb-7.8 SPARC.
This patch updates …
4.104.115
@efae4ae
11/08/14 07:00:28 |
Chris Johns |
toolkit: Print dependents in resolver.
4.104.115
@066a64b
11/08/14 06:59:40 |
Chris Johns |
toolkit: Raise a user error and not an internal one.
4.104.115
@b1e9ab9
11/20/14 18:46:43 |
Joel Sherrill |
main-page.cpp: Fix spelling issue
4.104.115
@b9c0a04
11/06/14 01:05:38 |
Chris Johns |
linkers: Disable .type statements in symbol code.
Some of the …
4.104.115
@53e387d
11/04/14 08:39:57 |
Chris Johns |
linkers: Merge the standard libraries into the user library paths.
4.104.115
@ddbab71
11/03/14 22:40:15 |
Chris Johns |
Fix buffer leak on error.
4.104.115
@0f93ea6
11/03/14 22:03:06 |
Ben Gras |
fix buffer size problem
(triggered runtime error on my machine)
4.104.115
@e4014f0
07/23/14 16:20:19 |
ben |
typo
4.104.115
@2015c85
10/31/14 15:52:36 |
Ben Gras |
fix for open() not taking a std::string
4.104.115
@fdb1fe6
10/30/14 06:55:18 |
Chris Johns |
linkers: Add base image symbol to ELF object file generation.
This …
4.104.115
@aac2949
10/28/14 08:14:02 |
Chris Johns |
linkers: Add kernel symbol support.
The rtems-sym tool has been …
4.104.115
@3fd45d3
10/28/14 08:13:47 |
Chris Johns |
toolkit: Fix the map formatting.
4.104.115
@df7fd26
10/28/14 08:13:19 |
Chris Johns |
toolkit: Update the comment.
4.104.115
@23bbbfd
09/07/14 01:16:58 |
Hesham Almatary |
Add new OpenRISC/or1ksim BSP script using qemu
4.104.115
@6ae559c
09/21/14 22:23:39 |
Chris Johns |
rtems-tld: Make printk the default generator.
4.104.115
@5025439
09/21/14 04:24:37 |
Chris Johns |
rtems-tld: Add config options, fix void args, and SCore traces.
4.104.115
@149a8a6
09/20/14 22:50:56 |
Chris Johns |
rtems-tld: Remove forced trace message.
4.104.115
@435d879
09/13/14 02:26:45 |
Chris Johns |
rtk: Build fastlz into the rld library.
Do not build as an object per …
4.104.115
@73eb48a
09/13/14 02:20:19 |
Chris Johns |
rtk: Fix buffer leak in rld::path::abs_path.
4.104.115
@87e0e76
09/13/14 02:09:16 |
Chris Johns |
Refactor code into the RTEMS Toolkit.
4.104.115
@749ddf1
09/13/14 00:47:07 |
Chris Johns |
waf: Include waf in the souce tree and updated README on building.
4.104.115
@543a4d1
09/12/14 22:49:31 |
Chris Johns |
Merge branch 'git://git.rtems.org/chrisj/rtl-host.git' to linkers.
4.104.115
@e0b8975
09/12/14 22:48:17 |
Chris Johns |
Remove invalid file that was added.
4.104.115
@7168ab3
09/10/14 03:10:45 |
Chris Johns |
rtems-tld: Add a printk generator.
4.104.115
@5afb2b8
09/10/14 03:10:20 |
Chris Johns |
rtems-tld: Fix warnings in the generated code.
4.104.115
@2d5de2e
09/10/14 01:16:26 |
Chris Johns |
Fix the error message.
4.104.115
@67369b14
09/10/14 01:15:29 |
Chris Johns |
Fix the tempfile output code to handle line breaks better.
4.104.115
@30a7f06
09/10/14 01:14:06 |
Chris Johns |
Make the verbose take the level and return the level if valid.
This …
4.104.115
@b7ad4a2
09/08/14 22:40:13 |
Chris Johns |
linkers: If no RTEMS path is provied see if the prefix can be used.
4.104.115
@6fb1409
09/08/14 22:20:41 |
Chris Johns |
rtems-tld: Add entry and exit trace support.
4.104.115
@2126ea7
09/08/14 09:29:41 |
Chris Johns |
rtems-tld: Generate arg and ret code in the wrapper.
4.104.115
@17c8364
09/08/14 06:37:32 |
Chris Johns |
Fix building on CentOS 6.5.
4.104.115
@6506aa1
09/08/14 06:06:48 |
Chris Johns |
RTEMS trace linker builds trace applications.
The trace linker builds …
4.104.115
@b28e8b3
09/07/14 04:31:18 |
Chris Johns |
Refactor the rld-rtems support to remove the globals.
4.104.115
@32cd4fc
09/07/14 00:47:00 |
Chris Johns |
rtems-tld: Add --wrapper option to aid testing.
The --wrapper option …
4.104.115
@3f5e31f
09/07/14 00:45:36 |
Chris Johns |
Chanhe the base temp file name to 'rld--'.
4.104.115
@c4c8218
09/06/14 11:59:25 |
Chris Johns |
Fix rtems-ld to keep tmep files around while building.
4.104.115
@8807135
09/06/14 10:19:45 |
Chris Johns |
Refactor the CC flags. Fix the various linkers. The trace linker is …
4.104.115
@a916fa4
09/06/14 10:19:08 |
Chris Johns |
Fxi the split call.
4.104.115
@a72a9e35
09/06/14 10:17:56 |
Chris Johns |
Add a path str. Remove the duplicate split call.
4.104.115
@b233be7
09/06/14 10:15:48 |
Chris Johns |
Trim the return value from a package file.
4.104.115
@31bf375
09/05/14 08:18:11 |
Chris Johns |
Remove march/mcpu and add RTEMS BSP and cflags support.
4.104.115
@7ccb6701
09/05/14 08:16:40 |
Chris Johns |
Add support for RTEMS BSP or user supplied CFLAGS. Remove march/mcpu.
4.104.115
@2f48445
09/05/14 08:10:46 |
Chris Johns |
Return the requested label.
This completes this code to a basic …
4.104.115
@40fd7a0
09/01/14 03:26:47 |
Chris Johns |
rld: Split the file into a path module for path specific functions.
4.104.115
@e5165d2
08/09/14 12:32:50 |
Peng.Fan |
Fix getopt_long usage
When passing shorhand options, getopt_long …
4.104.115
@3162858
08/26/14 04:57:57 |
Chris Johns |
gdb-python: Update so 'rtems task' lists the classic tasks.
This is a …
4.104.115
@4dbd0db
08/24/14 23:48:23 |
Chris Johns |
Fix README mistakes.
4.104.115
@504e1de
08/24/14 23:40:57 |
Chris Johns |
gdb-python: Add waf script to install under a prefix.
4.104.115
@f750e82
08/24/14 23:39:26 |
Chris Johns |
gdb-python: Clean up and ignore waf generated files.
4.104.115
@bd0b98d
08/26/13 16:42:25 |
mb.dhananjay |
Add cpu registers to task output.
4.104.115
@5a4834c
08/26/13 15:35:59 |
mb.dhananjay |
Remove the header.
4.104.115
@61154bf
08/26/13 15:26:30 |
mb.dhananjay |
Add watchdog seconds command
- prints the watchdog chain managed at …
4.104.115
@1fcff75
08/26/13 15:05:57 |
mb.dhananjay |
Fix wdticks command
- Type is Chain_Control
- chain.node.next -> null
4.104.115
@a4d0739
08/25/13 17:34:20 |
mb.dhananjay |
Add helper func.
- tests a bit at specified position.
4.104.115
@a7176a8
08/25/13 17:33:44 |
mb.dhananjay |
Add watchdog ticks command.
- ToDo? : Fix watchdog states.
4.104.115
@04d95ec
08/25/13 13:00:48 |
mb.dhananjay |
Added register class
- sparc.register, basic represenation of sparc's …
4.104.115
@788a715
08/25/13 09:26:57 |
mb.dhananjay |
Add sparc PSR
- added a class to print SPARC status register
4.104.115
@7a415d4
08/24/13 14:56:06 |
mb.dhananjay |
Catch empty task names,
- All the tasks do not have a name.
4.104.115
@a245635
08/24/13 09:38:16 |
mb.dhananjay |
Add subcommand
rtems tod - prints the time of day.
4.104.115
@a0bf9f2
08/23/13 04:28:22 |
mb.dhananjay |
Update README.md
Fix Links.
4.104.115
@b5c4f41
08/23/13 04:25:48 |
mb.dhananjay |
Update README.md
Fix indentation.
4.104.115
