@ddbab71
11/03/14 22:40:15 |
Chris Johns |
Fix buffer leak on error.
4.104.115
@0f93ea6
11/03/14 22:03:06 |
Ben Gras |
fix buffer size problem
(triggered runtime error on my machine)
4.104.115
@e4014f0
07/23/14 16:20:19 |
ben |
typo
4.104.115
@2015c85
10/31/14 15:52:36 |
Ben Gras |
fix for open() not taking a std::string
4.104.115
@fdb1fe6
10/30/14 06:55:18 |
Chris Johns |
linkers: Add base image symbol to ELF object file generation.
This …
4.104.115
@aac2949
10/28/14 08:14:02 |
Chris Johns |
linkers: Add kernel symbol support.
The rtems-sym tool has been …
4.104.115
@3fd45d3
10/28/14 08:13:47 |
Chris Johns |
toolkit: Fix the map formatting.
4.104.115
@df7fd26
10/28/14 08:13:19 |
Chris Johns |
toolkit: Update the comment.
4.104.115
@23bbbfd
09/07/14 01:16:58 |
Hesham Almatary |
Add new OpenRISC/or1ksim BSP script using qemu
4.104.115
@6ae559c
09/21/14 22:23:39 |
Chris Johns |
rtems-tld: Make printk the default generator.
4.104.115
@5025439
09/21/14 04:24:37 |
Chris Johns |
rtems-tld: Add config options, fix void args, and SCore traces.
4.104.115
@149a8a6
09/20/14 22:50:56 |
Chris Johns |
rtems-tld: Remove forced trace message.
4.104.115
@435d879
09/13/14 02:26:45 |
Chris Johns |
rtk: Build fastlz into the rld library.
Do not build as an object per …
4.104.115
@73eb48a
09/13/14 02:20:19 |
Chris Johns |
rtk: Fix buffer leak in rld::path::abs_path.
4.104.115
@87e0e76
09/13/14 02:09:16 |
Chris Johns |
Refactor code into the RTEMS Toolkit.
4.104.115
@749ddf1
09/13/14 00:47:07 |
Chris Johns |
waf: Include waf in the souce tree and updated README on building.
4.104.115
@543a4d1
09/12/14 22:49:31 |
Chris Johns |
Merge branch 'git://git.rtems.org/chrisj/rtl-host.git' to linkers.
4.104.115
@e0b8975
09/12/14 22:48:17 |
Chris Johns |
Remove invalid file that was added.
4.104.115
@7168ab3
09/10/14 03:10:45 |
Chris Johns |
rtems-tld: Add a printk generator.
4.104.115
@5afb2b8
09/10/14 03:10:20 |
Chris Johns |
rtems-tld: Fix warnings in the generated code.
4.104.115
@2d5de2e
09/10/14 01:16:26 |
Chris Johns |
Fix the error message.
4.104.115
@67369b14
09/10/14 01:15:29 |
Chris Johns |
Fix the tempfile output code to handle line breaks better.
4.104.115
@30a7f06
09/10/14 01:14:06 |
Chris Johns |
Make the verbose take the level and return the level if valid.
This …
4.104.115
@b7ad4a2
09/08/14 22:40:13 |
Chris Johns |
linkers: If no RTEMS path is provied see if the prefix can be used.
4.104.115
@6fb1409
09/08/14 22:20:41 |
Chris Johns |
rtems-tld: Add entry and exit trace support.
4.104.115
@2126ea7
09/08/14 09:29:41 |
Chris Johns |
rtems-tld: Generate arg and ret code in the wrapper.
4.104.115
@17c8364
09/08/14 06:37:32 |
Chris Johns |
Fix building on CentOS 6.5.
4.104.115
@6506aa1
09/08/14 06:06:48 |
Chris Johns |
RTEMS trace linker builds trace applications.
The trace linker builds …
4.104.115
@b28e8b3
09/07/14 04:31:18 |
Chris Johns |
Refactor the rld-rtems support to remove the globals.
4.104.115
@32cd4fc
09/07/14 00:47:00 |
Chris Johns |
rtems-tld: Add --wrapper option to aid testing.
The --wrapper option …
4.104.115
@3f5e31f
09/07/14 00:45:36 |
Chris Johns |
Chanhe the base temp file name to 'rld--'.
4.104.115
@c4c8218
09/06/14 11:59:25 |
Chris Johns |
Fix rtems-ld to keep tmep files around while building.
4.104.115
@8807135
09/06/14 10:19:45 |
Chris Johns |
Refactor the CC flags. Fix the various linkers. The trace linker is …
4.104.115
@a916fa4
09/06/14 10:19:08 |
Chris Johns |
Fxi the split call.
4.104.115
@a72a9e35
09/06/14 10:17:56 |
Chris Johns |
Add a path str. Remove the duplicate split call.
4.104.115
@b233be7
09/06/14 10:15:48 |
Chris Johns |
Trim the return value from a package file.
4.104.115
@31bf375
09/05/14 08:18:11 |
Chris Johns |
Remove march/mcpu and add RTEMS BSP and cflags support.
4.104.115
@7ccb6701
09/05/14 08:16:40 |
Chris Johns |
Add support for RTEMS BSP or user supplied CFLAGS. Remove march/mcpu.
4.104.115
@2f48445
09/05/14 08:10:46 |
Chris Johns |
Return the requested label.
This completes this code to a basic …
4.104.115
@40fd7a0
09/01/14 03:26:47 |
Chris Johns |
rld: Split the file into a path module for path specific functions.
4.104.115
@e5165d2
08/09/14 12:32:50 |
Peng.Fan |
Fix getopt_long usage
When passing shorhand options, getopt_long …
4.104.115
@3162858
08/26/14 04:57:57 |
Chris Johns |
gdb-python: Update so 'rtems task' lists the classic tasks.
This is a …
4.104.115
@4dbd0db
08/24/14 23:48:23 |
Chris Johns |
Fix README mistakes.
4.104.115
@504e1de
08/24/14 23:40:57 |
Chris Johns |
gdb-python: Add waf script to install under a prefix.
4.104.115
@f750e82
08/24/14 23:39:26 |
Chris Johns |
gdb-python: Clean up and ignore waf generated files.
4.104.115
@bd0b98d
08/26/13 16:42:25 |
mb.dhananjay |
Add cpu registers to task output.
4.104.115
@5a4834c
08/26/13 15:35:59 |
mb.dhananjay |
Remove the header.
4.104.115
@61154bf
08/26/13 15:26:30 |
mb.dhananjay |
Add watchdog seconds command
- prints the watchdog chain managed at …
4.104.115
@1fcff75
08/26/13 15:05:57 |
mb.dhananjay |
Fix wdticks command
- Type is Chain_Control
- chain.node.next -> null
4.104.115
@a4d0739
08/25/13 17:34:20 |
mb.dhananjay |
Add helper func.
- tests a bit at specified position.
4.104.115
@a7176a8
08/25/13 17:33:44 |
mb.dhananjay |
Add watchdog ticks command.
- ToDo? : Fix watchdog states.
4.104.115
@04d95ec
08/25/13 13:00:48 |
mb.dhananjay |
Added register class
- sparc.register, basic represenation of sparc's …
4.104.115
@788a715
08/25/13 09:26:57 |
mb.dhananjay |
Add sparc PSR
- added a class to print SPARC status register
4.104.115
@7a415d4
08/24/13 14:56:06 |
mb.dhananjay |
Catch empty task names,
- All the tasks do not have a name.
4.104.115
@a245635
08/24/13 09:38:16 |
mb.dhananjay |
Add subcommand
rtems tod - prints the time of day.
4.104.115
@a0bf9f2
08/23/13 04:28:22 |
mb.dhananjay |
Update README.md
Fix Links.
4.104.115
@b5c4f41
08/23/13 04:25:48 |
mb.dhananjay |
Update README.md
Fix indentation.
4.104.115
@52fc200
08/23/13 04:25:07 |
mb.dhananjay |
Update Readme.
Add wiki pages, usage instructions etc.
4.104.115
@8da0a37
08/21/13 13:01:01 |
mb.dhananjay |
Complete index subcommands.
4.104.115
@ddbc530
08/21/13 12:42:36 |
mb.dhananjay |
Refactor subcommands
- index commands inherit from a parent class.
4.104.115
@d4fc2d5
08/20/13 16:28:16 |
mb.dhananjay |
Categories the commands.
The subcommands fall onto DATA.
See …
4.104.115
@8d035f8
08/20/13 16:17:22 |
mb.dhananjay |
Refactor
- pretty printers moved to pretty module
- command and …
4.104.115
@2c25dc5
08/15/13 14:56:30 |
mb.dhananjay |
Add message_queue subcommand.
4.104.115
@b743d63
08/09/13 12:16:37 |
mb.dhananjay |
Catch nonvalid indexes.
Catch IndexErrors? generated while referancing …
4.104.115
@a713688
08/09/13 12:14:18 |
mb.dhananjay |
Add task subcommand
rtems tasks <index(s)> - Prints tasks by index.
4.104.115
@4797179
08/09/13 08:37:43 |
mb.dhananjay |
Add subcommand semaphore
rtems semaphore <index(s)> : prints rtems …
4.104.115
@559bd50
08/04/13 18:47:39 |
mb.dhananjay |
Catch invalid object ID.
4.104.115
@66d0779
08/04/13 18:37:47 |
mb.dhananjay |
Barrier taks queue
Print the barrier taks queue.
4.104.115
@6d89e3c
08/01/13 06:50:23 |
mb.dhananjay |
Refactor
- The objects are intialized using the objects rather than …
4.104.115
@e60a5ee
07/30/13 03:24:35 |
mb.dhananjay |
Fix Task and state printer bugs.
- Removed ITRON api objects in …
4.104.115
@e282b6e
07/29/13 10:54:24 |
mb.dhananjay |
Move todo
Why else is there issues?
4.104.115
@59c4946
07/29/13 04:56:02 |
mb.dhananjay |
New todo
4.104.115
@8e0de06
07/29/13 04:55:38 |
mb.dhananjay |
Add classic barrier.
- Add support for classic barrier object.
- Drop …
4.104.115
@c63080d
07/28/13 12:25:22 |
mb.dhananjay |
Update Readme.
ToDo?.
4.104.115
@b9ee5df
07/28/13 09:15:58 |
mb.dhananjay |
Add region support.
Abstractions for classic/region added.
4.104.115
@c3d06d5
07/28/13 07:31:06 |
mb.dhananjay |
Abstraction for HEAP.
Heap_Control Abstraction is added. It will need …
4.104.115
@09086b4
07/27/13 08:41:19 |
mb.dhananjay |
Support classic/partitions
Added support for partition object.
4.104.115
@086e689
07/17/13 10:30:57 |
mb.dhananjay |
Added support for classic/timers.
4.104.115
@591fbf6
07/16/13 12:47:03 |
mb.dhananjay |
Fix typo: Global timer control object name.
4.104.115
@0967a1b
07/13/13 11:01:59 |
mb.dhananjay |
Refactoring
- drop _printer suffix from printer classes.
4.104.115
@a785e25
07/12/13 13:37:46 |
mb.dhananjay |
Add printers to stage.
4.104.115
@b061a67
07/12/13 13:34:37 |
mb.dhananjay |
Heavy refactoring + Improved mesege queu printing.
- pretty printers …
4.104.115
@6e75f4e
07/09/13 16:51:27 |
mb.dhananjay |
Update readme.
Included useage instructions.
4.104.115
@3856406
07/09/13 09:07:20 |
mb.dhananjay |
Fix pretty printers
pretty printers for rtems_id and rtems_attribute
4.104.115
@f814c76
07/08/13 16:12:48 |
mb.dhananjay |
Messege Queue Objects
Added intial support for printing
4.104.115
@ce55b57
07/08/13 16:10:21 |
mb.dhananjay |
Object can have index from 1 to 'maximum'
4.104.115
@10bcd5d
06/24/13 04:10:59 |
mb.dhananjay |
Update chains structures
- Fixes chains structure parsing
- Fix …
4.104.115
@56a70ae
06/17/13 17:10:17 |
mb.dhananjay |
Intial commit.
Chris's intial work on the extenstions.
4.104.115
@911e710
06/17/13 15:31:09 |
mb.dhananjay |
Initial commit
4.104.115
@097f1fd
08/07/14 08:15:06 |
Chris Johns |
rtms-tld: Refactor the code to match a better configuration format.
4.104.115
@4fd758e
08/05/14 13:02:35 |
Chris Johns |
rtems-tld: Add wrapper support and start the generator coding.
4.104.115
@a136346
08/05/14 13:01:15 |
Chris Johns |
Fix temporary file handling and add tempfile write support.
Move the …
4.104.115
@058d502
08/04/14 05:09:39 |
Chris Johns |
rtems-tld: Add generator loading support.
4.104.115
@0a21024
08/03/14 23:50:56 |
Chris Johns |
rtems-tld: Add recursive parsing of headers and defines.
4.104.115
@b6d7f5f
08/03/14 23:19:55 |
Chris Johns |
rtems-tld: Add trace configuration support.
Extend the configuration …
4.104.115
@ea29902
08/01/14 06:44:32 |
Chris Johns |
Add initial support for the RTEM Trace Linker.
The RTEMS Trace Linker …
4.104.115
@2ce23a3
08/01/14 06:47:11 |
Chris Johns |
Fix building on Windows with the latest MSVC.
Remove some warnings.
4.104.115
@427acf3
07/24/14 03:09:03 |
Peng.Fan |
std::list should be sorted before unique
std::list should be sorted …
4.104.115
@8101cf0
07/07/14 21:23:47 |
Joel Sherrill |
Add newlib-sys-cpuset-const-20140414.diff
4.104.115
@8cfeec3
06/23/14 01:00:30 |
Chris Johns |
4.11: Patch so net-snmp 5.7.2.1 builds with RTEMS.
4.104.115
