source: rtems-tools
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @a1d4930   11/21/12 00:05:04 Chris Johns Set the correct header size field. 4.104.115
(edit) @fe19d06   11/20/12 23:40:01 Chris Johns Fix archive GNU extension and make image read/write follow POSIX. Fix … 4.104.115
(edit) @fd8a2c5   11/20/12 08:53:24 Chris Johns Add support to write a metadata ELF file. This also adds support to … 4.104.115
(edit) @9b66527   11/19/12 02:13:52 Chris Johns Only look for standard library paths if standard libraries and enabled. 4.104.115
(edit) @596e5fa   11/18/12 23:37:37 Chris Johns Add set_header support to the ELF files. 4.104.115
(edit) @1976825   11/18/12 23:36:34 Chris Johns Resolve the ld and user undefines. 4.104.115
(edit) @ead8da1   11/18/12 23:35:51 Chris Johns Add configure option --c-opts to allow special options for testing. 4.104.115
(edit) @8ad4837   11/18/12 23:35:15 Chris Johns Fix warning from clang. 4.104.115
(edit) @f1cf3a9   11/17/12 20:37:02 Chris Johns Better handling of archive open/close and begin/end. 4.104.115
(edit) @065ac15   11/17/12 06:42:22 Chris Johns Remove dead code. 4.104.115
(edit) @977c3de   11/17/12 06:34:33 Chris Johns Refactor the ELF support to allow ELF write suppport. The refactoring … 4.104.115
(edit) @0b65a28   11/17/12 06:31:56 Chris Johns Fix spelling. 4.104.115
(edit) @16e4346   10/23/12 01:46:59 Chris Johns Add FastLZ support. 4.104.115
(edit) @810d0ad   10/23/12 00:58:34 Chris Johns Fix repeats in output when cmd line objects depend on each other. If … 4.104.115
(edit) @7ec2c5a   10/22/12 14:12:47 Chris Johns Ignore working files. 4.104.115
(edit) @8f0740b   10/22/12 14:12:29 Chris Johns Script to test the linker. Run after building the linker. 4.104.115
(edit) @898fa13   10/22/12 14:11:04 Chris Johns Fix the verbose level. 4.104.115
(edit) @8d1ab1f   10/22/12 14:10:45 Chris Johns Add script output dbug messages. 4.104.115
(edit) @ef4061f   10/22/12 14:10:23 Chris Johns Fix the command line arguments help. 4.104.115
(edit) @7461924   09/17/12 00:13:55 Chris Johns Rename rld-gcc. Add -C option. Add a -C (also --cc) option to allow … 4.104.115
(edit) @aef6d90   09/16/12 23:37:29 Chris Johns Update the help to something useful. 4.104.115
(edit) @1ec9633   09/16/12 23:37:07 Chris Johns Add rebuild and tags build commands 4.104.115
(edit) @993aa67   09/15/12 07:58:00 Chris Johns Fix the waf script. 4.104.115
(add) @ec24a37   05/06/12 22:47:11 Chris Johns Add to git. 4.104.115
