@9ba4e48
11/21/12 01:12:50 |
Chris Johns |
Remove the warning about the warnings option on newer gccs.
4.104.115
@6565f0c
11/21/12 01:12:21 |
Chris Johns |
Enforce the header is created before using it on Linux.
4.104.115
@c1d1636
11/21/12 01:11:49 |
Chris Johns |
Add header to remove warning on Linux.
4.104.115
@eb34811
11/21/12 00:07:12 |
Chris Johns |
Output application format files.
Added support for an RTEMS RAP …
4.104.115
@a1d4930
11/21/12 00:05:04 |
Chris Johns |
Set the correct header size field.
4.104.115
@fe19d06
11/20/12 23:40:01 |
Chris Johns |
Fix archive GNU extension and make image read/write follow POSIX.
Fix …
4.104.115
@fd8a2c5
11/20/12 08:53:24 |
Chris Johns |
Add support to write a metadata ELF file.
This also adds support to …
4.104.115
@9b66527
11/19/12 02:13:52 |
Chris Johns |
Only look for standard library paths if standard libraries and enabled.
4.104.115
@596e5fa
11/18/12 23:37:37 |
Chris Johns |
Add set_header support to the ELF files.
4.104.115
@1976825
11/18/12 23:36:34 |
Chris Johns |
Resolve the ld and user undefines.
4.104.115
@ead8da1
11/18/12 23:35:51 |
Chris Johns |
Add configure option --c-opts to allow special options for testing.
4.104.115
@8ad4837
11/18/12 23:35:15 |
Chris Johns |
Fix warning from clang.
4.104.115
@f1cf3a9
11/17/12 20:37:02 |
Chris Johns |
Better handling of archive open/close and begin/end.
4.104.115
@065ac15
11/17/12 06:42:22 |
Chris Johns |
Remove dead code.
4.104.115
@977c3de
11/17/12 06:34:33 |
Chris Johns |
Refactor the ELF support to allow ELF write suppport.
The refactoring …
4.104.115
@0b65a28
11/17/12 06:31:56 |
Chris Johns |
Fix spelling.
4.104.115
@16e4346
10/23/12 01:46:59 |
Chris Johns |
Add FastLZ support.
4.104.115
@810d0ad
10/23/12 00:58:34 |
Chris Johns |
Fix repeats in output when cmd line objects depend on each other.
If …
4.104.115
@7ec2c5a
10/22/12 14:12:47 |
Chris Johns |
Ignore working files.
4.104.115
@8f0740b
10/22/12 14:12:29 |
Chris Johns |
Script to test the linker. Run after building the linker.
4.104.115
@898fa13
10/22/12 14:11:04 |
Chris Johns |
Fix the verbose level.
4.104.115
@8d1ab1f
10/22/12 14:10:45 |
Chris Johns |
Add script output dbug messages.
4.104.115
@ef4061f
10/22/12 14:10:23 |
Chris Johns |
Fix the command line arguments help.
4.104.115
@7461924
09/17/12 00:13:55 |
Chris Johns |
Rename rld-gcc. Add -C option.
Add a -C (also --cc) option to allow …
4.104.115
@aef6d90
09/16/12 23:37:29 |
Chris Johns |
Update the help to something useful.
4.104.115
@1ec9633
09/16/12 23:37:07 |
Chris Johns |
Add rebuild and tags build commands
4.104.115
@993aa67
09/15/12 07:58:00 |
Chris Johns |
Fix the waf script.
4.104.115
@ec24a37
05/06/12 22:47:11 |
Chris Johns |
Add to git.
4.104.115
