source: rtems-tools
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @8d035f8   Aug 20, 2013, 4:17:22 PM mb.dhananjay Refactor - pretty printers moved to pretty module - command and … 4.104.11
(edit) @2c25dc5   Aug 15, 2013, 2:56:30 PM mb.dhananjay Add message_queue subcommand. 4.104.11
(edit) @b743d63   Aug 9, 2013, 12:16:37 PM mb.dhananjay Catch nonvalid indexes. Catch IndexErrors? generated while referancing … 4.104.11
(edit) @a713688   Aug 9, 2013, 12:14:18 PM mb.dhananjay Add task subcommand rtems tasks <index(s)> - Prints tasks by index. 4.104.11
(edit) @4797179   Aug 9, 2013, 8:37:43 AM mb.dhananjay Add subcommand semaphore rtems semaphore <index(s)> : prints rtems … 4.104.11
(edit) @559bd50   Aug 4, 2013, 6:47:39 PM mb.dhananjay Catch invalid object ID. 4.104.11
(edit) @66d0779   Aug 4, 2013, 6:37:47 PM mb.dhananjay Barrier taks queue Print the barrier taks queue. 4.104.11
(edit) @6d89e3c   Aug 1, 2013, 6:50:23 AM mb.dhananjay Refactor - The objects are intialized using the objects rather than … 4.104.11
(edit) @e60a5ee   Jul 30, 2013, 3:24:35 AM mb.dhananjay Fix Task and state printer bugs. - Removed ITRON api objects in … 4.104.11
(edit) @e282b6e   Jul 29, 2013, 10:54:24 AM mb.dhananjay Move todo Why else is there issues? 4.104.11
(edit) @59c4946   Jul 29, 2013, 4:56:02 AM mb.dhananjay New todo 4.104.11
(edit) @8e0de06   Jul 29, 2013, 4:55:38 AM mb.dhananjay Add classic barrier. - Add support for classic barrier object. - Drop … 4.104.11
(edit) @c63080d   Jul 28, 2013, 12:25:22 PM mb.dhananjay Update Readme. ToDo?. 4.104.11
(edit) @b9ee5df   Jul 28, 2013, 9:15:58 AM mb.dhananjay Add region support. Abstractions for classic/region added. 4.104.11
(edit) @c3d06d5   Jul 28, 2013, 7:31:06 AM mb.dhananjay Abstraction for HEAP. Heap_Control Abstraction is added. It will need … 4.104.11
(edit) @09086b4   Jul 27, 2013, 8:41:19 AM mb.dhananjay Support classic/partitions Added support for partition object. 4.104.11
(edit) @086e689   Jul 17, 2013, 10:30:57 AM mb.dhananjay Added support for classic/timers. 4.104.11
(edit) @591fbf6   Jul 16, 2013, 12:47:03 PM mb.dhananjay Fix typo: Global timer control object name. 4.104.11
(edit) @0967a1b   Jul 13, 2013, 11:01:59 AM mb.dhananjay Refactoring - drop _printer suffix from printer classes. 4.104.11
(edit) @a785e25   Jul 12, 2013, 1:37:46 PM mb.dhananjay Add printers to stage. 4.104.11
(edit) @b061a67   Jul 12, 2013, 1:34:37 PM mb.dhananjay Heavy refactoring + Improved mesege queu printing. - pretty printers … 4.104.11
(edit) @6e75f4e   Jul 9, 2013, 4:51:27 PM mb.dhananjay Update readme. Included useage instructions. 4.104.11
(edit) @3856406   Jul 9, 2013, 9:07:20 AM mb.dhananjay Fix pretty printers pretty printers for rtems_id and rtems_attribute 4.104.11
(edit) @f814c76   Jul 8, 2013, 4:12:48 PM mb.dhananjay Messege Queue Objects Added intial support for printing 4.104.11
(edit) @ce55b57   Jul 8, 2013, 4:10:21 PM mb.dhananjay Object can have index from 1 to 'maximum' 4.104.11
(edit) @10bcd5d   Jun 24, 2013, 4:10:59 AM mb.dhananjay Update chains structures - Fixes chains structure parsing - Fix … 4.104.11
(edit) @56a70ae   Jun 17, 2013, 5:10:17 PM mb.dhananjay Intial commit. Chris's intial work on the extenstions. 4.104.11
(edit) @911e710   Jun 17, 2013, 3:31:09 PM mb.dhananjay Initial commit 4.104.11
(edit) @8101cf0   Jul 7, 2014, 9:23:47 PM Joel Sherrill Add newlib-sys-cpuset-const-20140414.diff 4.104.11
(edit) @8cfeec3   Jun 23, 2014, 1:00:30 AM Chris Johns 4.11: Patch so net-snmp 5.7.2.1 builds with RTEMS. 4.104.11
(edit) @100f517   May 9, 2014, 11:50:37 AM Chris Johns covoar: Merger the covoar source from rtems-testing.git. Use waf to … 4.104.11
(edit) @f25fed3   Jun 16, 2014, 3:11:28 AM Chris Johns 4.11: Add ntp patch. This patch has issues related to the clock … 4.104.11
(edit) @c8f4ba6   Jun 9, 2014, 11:41:47 PM Chris Johns rt: Update the documentation. 4.104.11
(edit) @984b06d   Jun 1, 2014, 6:15:28 AM Chris Johns config: Fix the name for the xilinx_zynq_a9_qemu bsp. 4.104.11
(edit) @8fac58f   Jun 1, 2014, 4:46:50 AM Chris Johns config: Add support for the gdbarmsim for the arm920 BSP. 4.104.11
(edit) @288d633   Jun 1, 2014, 4:46:11 AM Chris Johns config: Clean up the qemu configurations. 4.104.11
(edit) @60937e1   Jun 1, 2014, 4:43:03 AM Chris Johns test: Strengthen the timeout handling by killing the process. 4.104.11
(edit) @c04a849   May 31, 2014, 10:03:05 AM Chris Johns tester: Correctly handle contro-c. Add support to kill running tests … 4.104.11
(edit) @5cdcde1   May 19, 2014, 2:49:52 AM Chris Johns 4.11/sparc: GDB 7.7 SIS simulator output patch. 4.104.11
(edit) @ab131bb   May 14, 2014, 11:36:29 PM Joel Sherrill Add jmr3904 GDB simulator support 4.104.11
(edit) @a28e562   May 11, 2014, 11:43:59 PM gmate.amit doc: rtems-tester.txt: Add information for building tests The test … 4.104.11
(edit) @803b63d   Apr 27, 2014, 5:35:01 PM Ben Gras add --filter to specify the set of selected tests. . parameter is a … 4.104.11
(edit) @47d652c   May 8, 2014, 12:39:07 PM Chris Johns gdb: Fix lm32 simulator's UART code. Builds on MinGW. 4.104.11
(edit) @a35f890   Apr 30, 2014, 1:13:14 PM Chris Johns tools/gdb: Simulator inline fixes in the cgen code. 4.104.11
(edit) @9e78f60   Apr 30, 2014, 6:22:37 AM Chris Johns tools/microblaze: Fix the building of libgcc. 4.104.11
(edit) @4efea40   Apr 28, 2014, 11:18:14 PM Chris Johns bsp: Clean up the BBxM BSP configuration. 4.104.11
(edit) @bd0fbd6   Apr 28, 2014, 11:10:14 PM Chris Johns bsp: Break on the terminate halt to get fatal handlers run. 4.104.11
(edit) @4e8f984   Apr 24, 2014, 7:52:32 AM Chris Johns bsp: Add Beagleboard xM support. 4.104.11
(edit) @b45ca52   Apr 10, 2014, 8:21:24 AM Chris Johns tester: Fix the psim script. 4.104.11
(edit) @f756b51   Apr 10, 2014, 8:21:01 AM Chris Johns gdb: pr 16827, fix sim on Mavrick. 4.104.11
(edit) @05d2385   Mar 26, 2014, 5:45:19 AM Chris Johns bsp: Add psim. 4.104.11
(edit) @a116962   Mar 26, 2014, 5:45:06 AM Chris Johns tester: The process returns an exit code not an errno. 4.104.11
(edit) @ec18d1d   Mar 20, 2014, 8:21:16 PM Joel Sherrill gcc-4.8.2-rtems4.11-20140349.diff: New file 4.104.11
(edit) @e959da9   Mar 19, 2014, 4:15:31 AM Chris Johns 4.11/gdb: Fix detecting python when building GDB on FreeBSD 10.0. … 4.104.11
(edit) @f91e023   Feb 17, 2014, 7:04:46 AM Chris Johns Add the documentation. 4.104.11
(edit) @11d4b89   Feb 17, 2014, 6:56:03 AM Chris Johns Add README. Also add a git ignore. 4.104.11
(edit) @50fdf12   Feb 14, 2014, 7:30:06 PM Chris Johns rt: Add the rtems-tester. 4.104.11
(edit) @8f75c4a   Feb 12, 2014, 2:18:33 AM Chris Johns libffi: Fix for Fedora 64bit pkg-config file. 4.104.11
(edit) @29734ec   Jan 18, 2014, 6:27:13 AM Chris Johns gdb/sparc: SIS gdb output fix, add nouartrx. Fix the output from the … 4.104.11
(edit) @b2589cb   Aug 14, 2013, 3:49:27 AM Chris Johns gcc: Switch GCC to the posix thread model. Change from the RTEMS … 4.104.11
(edit) @98f78dc   Jul 15, 2013, 11:58:54 PM Chris Johns The cxa_atexit support is a reqirement for destructor registration … 4.104.11
(edit) @6651de8   May 30, 2013, 11:43:40 PM Chris Johns Add Joel's stack_t patch. 4.104.11
(edit) @bba0b78   May 22, 2013, 6:47:01 AM verm Add patch to remove times.c from PowerPC newlib. 4.104.11
(edit) @acdef36   May 16, 2013, 8:13:31 AM verm Add three patches from Anthony Green to fix moxie tools. … 4.104.11
(edit) @440c97f   Apr 14, 2013, 10:25:05 PM Chris Johns Regenerate the patch cleanly. 4.104.11
(edit) @65575cc   Apr 13, 2013, 8:23:52 AM Chris Johns Update the 4.7.2 patch to 4.7.3. 4.104.11
(edit) @eba19fa   Apr 5, 2013, 3:24:01 AM Chris Johns Update to the patch Joel merged. 4.104.11
(edit) @926ef3c   Apr 2, 2013, 9:39:03 PM Chris Johns PR target/56771. Require 64-bit int for arm*-*-rtems[.0-9]*. 4.104.11
(edit) @9d711f4   Apr 2, 2013, 6:48:38 AM Chris Johns Fix to build in cygwin. 4.104.11
(edit) @4c5ffb2   Mar 20, 2013, 6:27:49 AM Chris Johns Fix the sed breakage on FreeBSD. 4.104.11
(edit) @038b250   Mar 19, 2013, 6:16:54 AM Chris Johns Add the current rtems-4.10 patches. 4.104.11
(edit) @ce77d87   Mar 15, 2013, 1:10:20 AM Chris Johns Import the 4.9 patches. 4.104.11
(edit) @f0c9bae   Mar 11, 2013, 8:31:18 AM Sebastian Huber Add latest GCC 4.7 ARM to EABI patch This patch is included in the … 4.104.11
(edit) @cb328a1   Mar 11, 2013, 6:16:02 AM Chris Johns Regenerate the ARM EABI patch for gcc-4.7.2 sources. 4.104.11
(edit) @94c5d74   Mar 11, 2013, 12:50:53 AM Chris Johns ARM EABI patch. 4.104.11
(edit) @e42bad3   Mar 10, 2013, 10:28:55 PM Chris Johns Move current patches in to the repo. 4.104.11
(edit) @5749230   Mar 10, 2013, 3:31:57 AM Chris Johns Regerated version of Joel's patch so patch -p1 works. 4.104.11
(edit) @0e90000   Mar 10, 2013, 1:35:37 AM Chris Johns Use a better name for the patch. 4.104.11
(edit) @25e43e1   Mar 10, 2013, 1:27:22 AM Chris Johns Microblaze gcc-4.7.2 patch from Joel. 4.104.11
(edit) @df78032   Mar 8, 2013, 7:44:32 AM Chris Johns MIPS memcpy fixes. … 4.104.11
(edit) @6d5bfb0   Mar 6, 2013, 3:25:00 PM Gedare Bloom Clean up. Remove all files to prepare repo for a new life. … 4.104.11
(edit) @7234c70   Sep 6, 2012, 4:09:49 AM Chris Johns Move .cvsignore to .gitignore. Update ChangeLog?. 4.104.11
(edit) @68c9b8a   Aug 4, 2012, 12:29:24 PM Chris Johns Remove CVS Id and update the copyright year. 4.104.11
(edit) @5a44122   Aug 4, 2012, 12:17:50 PM Chris Johns Comments clean up. 4.104.11
(edit) @e801762   Aug 4, 2012, 12:17:33 PM Chris Johns Use the crossrpms repo and not the RTEMS source. 4.104.11
(edit) @db789e3   Aug 4, 2012, 12:17:05 PM Chris Johns Clean up. 4.104.11
(edit) @f51e691   Aug 4, 2012, 12:16:48 PM Chris Johns Do not build with zlib. 4.104.11
(edit) @6b88114   Dec 6, 2011, 11:44:37 PM Chris Johns Add /usr/local to the host cflags on FreeBSD. 4.104.11
(edit) @8548cd7   Dec 6, 2011, 6:37:57 AM Chris Johns Add a hack to work around make not being a macro in the spec files. 4.104.11
(edit) @594f41f   Dec 5, 2011, 8:53:17 PM Chris Johns Fix the host verison in FreeBSD. Allow the top of the src to crossrpms. 4.104.11
(edit) @a2bc901   Dec 5, 2011, 11:32:44 AM Chris Johns Add FreeBSD support. 4.104.11
(edit) @a86cd82   Jun 9, 2011, 5:59:32 AM Chris Johns 2011-06-09 Chris Johns <chrisj@…> * … 4.104.11
(edit) @faa8181   Feb 22, 2011, 3:46:44 AM Chris Johns 2011-02-22 Chris Johns <chrisj@…> * … 4.104.11
(edit) @31d4e80   Aug 31, 2010, 12:58:45 AM Chris Johns 2010-08-31 Chris Johns <chrisj@…> * … 4.104.11
(edit) @9eb5c92   Aug 28, 2010, 11:01:20 PM Chris Johns 2010-08-29 Chris Johns <chrisj@…> * … 4.104.11
(edit) @f1a0bde   Aug 13, 2010, 4:40:44 AM Chris Johns 2010-08-13 Chris Johns <chrisj@…> * … 4.104.11
(edit) @0b29e44   Aug 12, 2010, 10:40:57 PM Chris Johns 2010-08-13 Chris Johns <chrisj@…> * … 4.104.11
(edit) @120137a   Aug 12, 2010, 9:09:55 PM Chris Johns 2010-08-13 Chris Johns <chrisj@…> * … 4.104.11
(edit) @dc2ed4f   Aug 9, 2010, 4:50:30 AM Chris Johns 2010-08-09 Chris Johns <chrisj@…> * … 4.104.11
(edit) @7231f49   Aug 9, 2010, 1:29:43 AM Chris Johns 2010-08-09 Chris Johns <chrisj@…> * specbuilder, … 4.104.11
