@6f5cfad
11/09/17 08:54:14 |
Sebastian Huber |
Add tester imx7.ini
Update #3090.
5
@469e362
11/09/17 08:41:34 |
Sebastian Huber |
Add tools/5 patches
Update #3220.
5
@a70b8e6
11/09/17 08:35:29 |
Sebastian Huber |
Add tools/5 patch
Update #3220.
5
@52f3790
11/09/17 08:25:43 |
Sebastian Huber |
Add tools/5 patch
Update #3220.
5
@2da1356
11/09/17 08:07:35 |
Sebastian Huber |
Add tools/5 patches
Update #3220.
5
@b5a4b15
11/09/17 08:05:14 |
Sebastian Huber |
Add tools/5 patch
Update #3220.
5
@aff8c47
11/09/17 07:44:21 |
Sebastian Huber |
Add tools/5 patch
Update #3220.
5
@e5dad3c
11/08/17 08:46:25 |
Sebastian Huber |
Change RTEMS version from 4.12 to 5
Update #3220.
5
@24d51f7
11/04/17 00:22:08 |
Chris Johns |
tester: Change the mail subject so it list by BSP in the archives.
5
@42e39d2
11/03/17 07:20:31 |
Chris Johns |
tester: Fix the output so the report end analysis works.
5
@c68beb8
11/03/17 06:57:37 |
Chris Johns |
tester: Add the rtems-run command.
5
@7e85878
11/03/17 06:56:48 |
Chris Johns |
tester: Make the mandatory items appear first.
5
@0fe3a4b
11/01/17 03:30:32 |
Chris Johns |
tester: Fix rtems-bsp-builder reporting bug
5
@35b9c0c
10/28/17 02:45:23 |
Hesham Almatary |
Tester - RISC-V: Add spike simulator and scripts/bsp for riscv ports
5
@bb218b6
10/24/17 23:21:22 |
Chris Johns |
tester: Minor fix to the test results mail.
5
@c73e030
10/24/17 23:13:28 |
Chris Johns |
tester: Check mail parameters early so users can fix.
5
@41d0c34
10/24/17 22:03:43 |
Chris Johns |
tester: Add a BSP field to each BSP INI configuration section.
The …
5
@a248471
10/24/17 21:53:27 |
Chris Johns |
rtemstoolkit: Remove test import for YAML.
Closes #3204.
5
@bf58911
10/24/17 10:35:21 |
Chris Johns |
tester: Refactor to use INI format files for BSP configurations.
5
@5251361
10/23/17 04:22:34 |
Chris Johns |
tester: Add an executable file name filter.
The exe filter lets a BSP …
5
@7051ba5
10/22/17 07:09:39 |
Chris Johns |
bsb-builder: Add email support, and config report types.
5
@b1d2db9
10/21/17 06:05:00 |
Chris Johns |
tester: Update BeagleBone? Black, PC and Zedboard configurations.
5
@f1e8fd4
10/21/17 05:59:14 |
Chris Johns |
tester: Add pretest and posttest target commands with @ARCH@, @BSP@ …
5
@cec5878
10/21/17 05:10:22 |
Chris Johns |
tester: Remove pass status messages from the email log posts.
5
@af6a54d
10/21/17 05:09:30 |
Chris Johns |
tester: Use a target ON command before the first test.
5
@ac679ba
10/21/17 05:09:00 |
Chris Johns |
tester: Print the host and port on error in telnet connect.
5
@0054585
10/13/17 16:31:47 |
Chris Johns |
tester/covoar: Use standard waf modules for linking.
Use the standard …
5
@b76fa74
10/12/17 10:52:59 |
Sebastian Huber |
linkers: Update due to API changes
Update #3160.
5
@5e40b4a
10/11/17 19:25:10 |
Chris Johns |
tester: Fix excluded fails processing.
5
@89e8c2a
10/11/17 19:13:47 |
Chris Johns |
tester: Add support to email results.
5
@fce29b0
10/11/17 19:13:13 |
Chris Johns |
tester: Change the capture console prompt to avoid email reply …
5
@dc5de5f
10/11/17 19:11:16 |
Chris Johns |
rtemstoolkit: Update the mailer module to the option interface.
5
@7c032b0
10/11/17 19:09:52 |
Chris Johns |
rtemstoolkit: Add a capture hook to logging.
5
@7f11670
10/11/17 19:08:31 |
Chris Johns |
rtemstoolkit: Fix error message in options.
5
@b4b61b5
10/11/17 11:50:52 |
Chris Johns |
testing: Add a PC BSP configuration.
5
@2d6d1c5
10/11/17 11:50:16 |
Chris Johns |
testing: Update BSP configurations.
5
@4b76b8e
10/11/17 11:49:17 |
Chris Johns |
testing: Generate console message on a second TFTP exe request.
5
@0eb8400
10/11/17 11:48:46 |
Chris Johns |
testing: Print the output after the result. Easier to find and review …
5
@5df7c3c
10/10/17 18:07:15 |
Sebastian Huber |
Install missing files
5
@662e1f7
10/10/17 02:30:31 |
Chris Johns |
tester: Add a tester off to turn the target off when finished.
5
@9580804
10/07/17 07:57:24 |
Chris Johns |
Add a target start and target reset to manage boards that do not boot …
5
@68cbfc3
10/05/17 03:24:11 |
Chris Johns |
tester: Add Zedboard.
5
@2ae9b6d
10/05/17 03:21:33 |
Chris Johns |
tester: Telnet console reopens the connection if it fails or closes.
5
@0737b46
10/05/17 03:21:01 |
Chris Johns |
tester: Add a target reset regular expression to detect a reset.
5
@3c7cd05
09/21/17 11:34:34 |
Chris Johns |
tester: Fix the TFTP ok to kill deadlock.
5
@3ed65c0
09/21/17 11:33:56 |
Chris Johns |
Lower the step size for the TFTP timeout.
5
@3a867a4
09/21/17 08:26:20 |
Chris Johns |
Add TFTP as a back end option for testing. Add telnet as a console …
5
@fa81491
09/21/17 07:45:39 |
Chris Johns |
Move the reraise logic into the tool kit.
5
@875c071
09/14/17 23:05:38 |
joel |
rtemstoolkit/rld-compression.cpp: Fix warning for comparing signed to …
5
@f4378ea
09/14/17 23:04:55 |
joel |
tester/covoar/DesiredSymbols.cc: Now compiles on Cygwin
5
@8e64821
09/14/17 02:21:08 |
Chris Johns |
rtemstoolkit: Remove throw from file::image destructor.
5
@f4773ac
09/13/17 15:45:30 |
cpodonnell8 |
covoar: Add function defs to fix Windows build errors.
Closes #3129
5
@cb0677b
09/10/17 21:11:19 |
Chris Johns |
Add Windows includes so the rtemstoolkit builds.
Closes #3128.
5
@f9a4b2c
08/26/17 08:15:58 |
cpodonnell8 |
covoar: Remove config file and test critical options are valid.
5
@4600903
08/26/17 08:15:57 |
cpodonnell8 |
covoar/CoverageReaderQEMU.cc: Remove trace block matching check.
This …
5
@6a4859e
08/26/17 08:15:56 |
cpodonnell8 |
covoar: Use rld tempfile and add signals to clean up in event of …
5
@4cee5c3
08/26/17 08:15:55 |
Krzysztof Miesowicz |
covoar/wscript: Add paths to rtemstoolkit to build.
Co-Author: …
5
@9534157
08/26/17 08:15:54 |
cpodonnell8 |
covoar/ObjdumpProcessor.cc: Remove jump tables from the end of …
5
@cb018bc
08/26/17 08:15:53 |
hermann19829 |
covoar: Add information to improve diagnostics.
5
@b857151
08/26/17 08:15:52 |
hermann19829 |
covoar: Fix buffer overflow and fix br tag in html report.
Co-Author: …
5
@05b4cfb
08/26/17 08:15:51 |
chouteau |
covoar/qemu-traces.h: Change to match current couverture-qemu file.
5
@67d48e2
08/26/17 08:15:50 |
cpodonnell8 |
rtemstoolkit/host.py: Change option to search parent directory in …
5
@fd0bcc5
08/22/17 14:54:48 |
Sebastian Huber |
tester: Add qoriq_e6500_64
Update #3082.
5
@f2bb439
08/20/17 07:19:06 |
Chris Johns |
rtemstoolkit/libiberty: Fix broken configure detection.
The file …
5
@78bbe4c
08/16/17 08:09:59 |
Chris Johns |
linkers/exe-info Support ARM static constructors.
Note, ARM …
5
@0ea1c27
08/07/17 06:01:59 |
Sebastian Huber |
tester: Add imx7
5
@581b071
07/31/17 14:29:48 |
joel |
rtems-bsps-i386.ini: Remove Edison
5
@738716d
07/31/17 05:33:56 |
Sebastian Huber |
tester: Update BSP names
5
@9f72ea6
07/17/17 08:42:42 |
Jiri Gaisler |
Added test scripts for standalone sis
5
@e37f132
07/10/17 06:12:29 |
Sebastian Huber |
Add Newlib patch
Original patch contains a Cygwin part which is not …
5
@50eb61d
06/12/17 11:47:36 |
Sebastian Huber |
Add PR-ada-81070.diff
5
@d67c20a
05/31/17 12:15:59 |
Chris Johns |
rtems-bsp-builder: Use the profile's architecture's BSP lists.
5
@718b230
05/31/17 08:26:18 |
cpodonnell8 |
rtemstoolkit/rld-process.h: Include rld.h to find 'strings' definition
5
@37a0843
05/24/17 02:27:38 |
Chris Johns |
rtems-bsp-builder: Refactor to add jobs.
This change adds job support …
5
@4c24f40
05/24/17 02:27:22 |
Chris Johns |
rtemstoolkit: Improve performance.
5
@52cfa18
05/24/17 02:12:55 |
Chris Johns |
rtems-bsp-builder: Fix the powerpc configuration.
5
@61ddcfc
05/18/17 05:22:43 |
Chris Johns |
rtems-bsp-builder: Add as a build type.
5
@ed80d2c
05/16/17 06:43:19 |
Chris Johns |
rtemstoolkit: Add the configuration.py module to the install.
5
@ef38b5d
05/15/17 01:48:44 |
Chris Johns |
rtemstoolkit: Add Python INI configuration support.
5
@9a8a03c
05/15/17 01:29:46 |
Chris Johns |
rtems-bsp-builder: Add all architectures and BSPs.
- Add support to …
5
@85e14e0
05/10/17 11:09:02 |
Chris Johns |
rtems-bsp-builder: Fix excluding builds.
Excluding builds was not …
5
@ad15f6b
04/27/17 20:49:23 |
Chris Johns |
rtems-bsp-builder: Fix passes report alignment.
5
@096c95e
04/27/17 20:36:32 |
Chris Johns |
rtems-bsp-tester: Make the failure and pass report more compact.
5
@fc22d2a
04/26/17 12:07:15 |
Chris Johns |
rtems-bsp-builder: Fix time in warnings report, wrapping in reports.
5
@c2df65b
04/26/17 10:01:23 |
Chris Johns |
rtems-bsp-builder: Fix access when there are no messages.
5
@ab57e79
04/24/17 23:32:18 |
Chris Johns |
rtems-test: Fix gdb bug.
5
@9e7ed07
04/24/17 23:31:37 |
Chris Johns |
rtemstoolkit: Set proc buffering to 0 to not block on smaller reads.
5
@b89a7e4b
04/24/17 22:40:19 |
Chris Johns |
rtems-bsp-builder: Fix the build sets excludes.
5
@5d1edd5
04/24/17 16:39:56 |
Chris Johns |
rtems-bsp-builder: Refactor for better config format, warnings and …
5
@224fb21
04/24/17 16:38:40 |
Chris Johns |
rtemstoolkit: Add a textbox module for formatted reporting.
5
@4370924
04/24/17 14:32:53 |
Chris Johns |
execute: Use the io python module for output capture.
This change …
5
@7d3350d
04/24/17 14:31:44 |
Chris Johns |
rtemstoolkit: Move host support access into a separate module.
Moving …
5
@15a3e06
04/04/17 03:32:03 |
Chris Johns |
tester: Add support for expected-fail, user-input, and benchmarks.
5
@5ca8bad
04/03/17 10:24:06 |
Chris Johns |
waf: Upgrade to the latest release waf-1.9.9.
This fixes build …
5
@bce090b
03/27/17 23:20:14 |
Chris Johns |
rtems-bsp-builder: Fix the counts to accumulate.
5
@7ef4c2b
03/21/17 14:55:19 |
Sebastian Huber |
patch: ARM: Fix IEEE-754 sqrt optimization
Update #2948.
5
@d1f542f
03/21/17 14:06:07 |
Sebastian Huber |
patch: ARM: Optimize IEEE-754 sqrt implementation
Update #2948.
5
@056bd4b
03/15/17 04:23:40 |
Chris Johns |
rtems-bsp-builder: Fix profile error message.
5
@e4b3143
03/15/17 04:23:05 |
Chris Johns |
rtems-syms: Fix usage help.
5
@31e22e3
01/08/17 22:05:18 |
Chris Johns |
libelf: Use minimal environment for C translation with readelf.
The …
5
