@61ddcfc
05/18/17 05:22:43 |
Chris Johns |
rtems-bsp-builder: Add as a build type.
5
@ed80d2c
05/16/17 06:43:19 |
Chris Johns |
rtemstoolkit: Add the configuration.py module to the install.
5
@ef38b5d
05/15/17 01:48:44 |
Chris Johns |
rtemstoolkit: Add Python INI configuration support.
5
@9a8a03c
05/15/17 01:29:46 |
Chris Johns |
rtems-bsp-builder: Add all architectures and BSPs.
- Add support to …
5
@85e14e0
05/10/17 11:09:02 |
Chris Johns |
rtems-bsp-builder: Fix excluding builds.
Excluding builds was not …
5
@ad15f6b
04/27/17 20:49:23 |
Chris Johns |
rtems-bsp-builder: Fix passes report alignment.
5
@096c95e
04/27/17 20:36:32 |
Chris Johns |
rtems-bsp-tester: Make the failure and pass report more compact.
5
@fc22d2a
04/26/17 12:07:15 |
Chris Johns |
rtems-bsp-builder: Fix time in warnings report, wrapping in reports.
5
@c2df65b
04/26/17 10:01:23 |
Chris Johns |
rtems-bsp-builder: Fix access when there are no messages.
5
@ab57e79
04/24/17 23:32:18 |
Chris Johns |
rtems-test: Fix gdb bug.
5
@9e7ed07
04/24/17 23:31:37 |
Chris Johns |
rtemstoolkit: Set proc buffering to 0 to not block on smaller reads.
5
@b89a7e4b
04/24/17 22:40:19 |
Chris Johns |
rtems-bsp-builder: Fix the build sets excludes.
5
@5d1edd5
04/24/17 16:39:56 |
Chris Johns |
rtems-bsp-builder: Refactor for better config format, warnings and …
5
@224fb21
04/24/17 16:38:40 |
Chris Johns |
rtemstoolkit: Add a textbox module for formatted reporting.
5
@4370924
04/24/17 14:32:53 |
Chris Johns |
execute: Use the io python module for output capture.
This change …
5
@7d3350d
04/24/17 14:31:44 |
Chris Johns |
rtemstoolkit: Move host support access into a separate module.
Moving …
5
@15a3e06
04/04/17 03:32:03 |
Chris Johns |
tester: Add support for expected-fail, user-input, and benchmarks.
5
@5ca8bad
04/03/17 10:24:06 |
Chris Johns |
waf: Upgrade to the latest release waf-1.9.9.
This fixes build …
5
@bce090b
03/27/17 23:20:14 |
Chris Johns |
rtems-bsp-builder: Fix the counts to accumulate.
5
@7ef4c2b
03/21/17 14:55:19 |
Sebastian Huber |
patch: ARM: Fix IEEE-754 sqrt optimization
Update #2948.
5
@d1f542f
03/21/17 14:06:07 |
Sebastian Huber |
patch: ARM: Optimize IEEE-754 sqrt implementation
Update #2948.
5
@056bd4b
03/15/17 04:23:40 |
Chris Johns |
rtems-bsp-builder: Fix profile error message.
5
@e4b3143
03/15/17 04:23:05 |
Chris Johns |
rtems-syms: Fix usage help.
5
@31e22e3
01/08/17 22:05:18 |
Chris Johns |
libelf: Use minimal environment for C translation with readelf.
The …
5
@516f931
12/23/16 08:06:01 |
Sebastian Huber |
Add Newlib patch for RTEMS 4.12
5
@a72a462a
12/12/16 22:56:25 |
Chris Johns |
bsp-builder: Fix final output errors.
5
@d3d771e
11/30/16 23:21:13 |
Chris Johns |
bsp-builder: Add support for builds.
Add build support where a build …
5
@8a7be63
11/29/16 21:13:33 |
Chris Johns |
bsp-bulder: Get the end time when building an architecture.
5
@e2af743
11/15/16 00:00:08 |
joel |
Add 4.12/.../gdb-7.11-sis-leon2-leon3.diff from gaisler.org
5
@b5caf21
11/14/16 22:04:04 |
joel |
Add 4.12/.../binutils-2.26-gas-reloc.patch from gaisler.org
5
@4fdd883
09/02/16 08:16:57 |
Chris Johns |
4.10: Add NIOS2 newlib patch.
5
@32b861f
09/02/16 08:03:11 |
Chris Johns |
4.10: Add NIOS2 gcc patch.
5
@5af5b04
09/02/16 07:56:09 |
Chris Johns |
4.10: Add NIOS2 binutils patch.
5
@a46a8d3
09/02/16 07:00:50 |
Chris Johns |
4.10: Add FreeBSD Python patch.
5
@3f17371
09/02/16 06:56:49 |
Chris Johns |
4.10: Add the gdb-7.11 ERC patches to 4.10.
5
@3581fab
09/02/16 03:18:17 |
Chris Johns |
4.10: Add the automake patch to the 4.10 patches.
5
@a252faf
08/30/16 08:10:17 |
Chris Johns |
bsp-builder: Results format fixes.
4.105
@06c3ccd
08/29/16 01:47:04 |
Chris Johns |
bsp-builder: Fix bugs.
4.105
@e9fb4c5
08/25/16 06:14:57 |
Chris Johns |
bsp-builder: Add lm3s6965_qemu to ARM bsp list. Fix network-debug options.
4.105
@f7f0704
08/25/16 06:13:18 |
Chris Johns |
bsp-builder: Fix column printing of the arch/bsp.
4.105
@885aebd
08/25/16 05:54:23 |
Chris Johns |
linkers/syms: Add weak symbols to the global symbol table.
Add any …
4.105
@8e13939
08/19/16 01:56:09 |
Chris Johns |
bsp-builder: Print one results report only.
4.105
@9a1daba
08/18/16 23:55:03 |
Chris Johns |
bsp-builder: Fix results report columns.
4.105
@3a92a54
08/18/16 11:00:50 |
Chris Johns |
bsp-builder: Add ARM bsps.
4.105
@51e19af
08/18/16 11:00:29 |
Chris Johns |
bsp-builder: Support per BSP excludes.
4.105
@57e4172
08/18/16 04:24:45 |
Chris Johns |
tester: handle compile argument warnings.
4.105
@1676b9c
08/18/16 04:24:13 |
Chris Johns |
rtemstoolkit: Trace opening a macro file.
4.105
@3e14594
07/06/16 07:58:56 |
Chris Johns |
Add rtems-bsp-builder.
This is a testing tool that builds BSPs with a …
4.105
@6c94148
04/03/16 06:26:36 |
Chris Johns |
linkers: Demangle the C++ labels in the .ctors/.dtors sections.
Show …
4.105
@c81066f
04/03/16 05:42:51 |
Chris Johns |
linkers: Add a tool to show RTEMS executable information.
4.105
@635a28f
04/03/16 05:41:08 |
Chris Johns |
rtemstoolkit: Add a buffer helper class to insert and extract data.
4.105
@8dc2772
04/03/16 05:39:58 |
Chris Johns |
rtemstoolkit: Add the address to the section.
4.105
@2e97351
04/03/16 05:38:14 |
Chris Johns |
rtemstoolkit: Add an address table of symbols key by the symbol …
4.105
@0c0b2d4
04/03/16 05:37:01 |
Chris Johns |
rtemstoolkit: Add version number parsing to get major, minor, …
4.105
@dfa2468
03/16/16 10:39:39 |
Chris Johns |
tester: Fix reraising an exception with Python2 and Python3.
Updates …
4.105
@4bcf18b
03/16/16 05:22:35 |
Chris Johns |
tester/sis: Provide the -nouartrx to avoid blocking on stdin.
4.105
@1845e91
03/16/16 05:21:57 |
Chris Johns |
tester: Provide a gdb kill method to aid clean ups on ctrl-C.
4.105
@0bbd2de
03/16/16 04:18:34 |
Chris Johns |
4.12: Patches for ERC simualtor for gdb-7.11.
The patches fix the …
4.105
@6f8b07c
03/14/16 03:59:11 |
Chris Johns |
rtemstoolkit: Fix execute's writer thread to not eval() the input.
4.105
@a44fedf
03/11/16 07:12:55 |
Chris Johns |
Add a gdb-7.11 patch for 4.12.
4.105
@87bca99
01/07/16 14:14:29 |
pfeiffer |
Bugfix: gdb-7.3.1 couldn't be build with a modern texinfo package.
4.105
@47ec083
01/07/16 14:13:50 |
pfeiffer |
Bugfix: gcc-4.4.7 couldn't be build with a modern texinfo package.
4.105
@45d2402
01/07/16 14:13:05 |
pfeiffer |
Bugfix: binutils-2.20.1 couldn't be build with a modern texinfo …
4.105
@c9ed248
03/09/16 03:34:26 |
Chris Johns |
Remove exception test code left in.
Updates #2619.
4.105
@6fa359c
03/09/16 03:29:14 |
Chris Johns |
Master branch version is 4.12.
4.105
@b7a9c81
03/09/16 03:28:57 |
Chris Johns |
sis: Option not present with SPARC sim.
4.105
@2de37f3
03/09/16 03:27:42 |
Chris Johns |
Python 2 and python 3 refactor fixes.
Updates #2619.
4.105
@a5d243d
03/04/16 01:10:09 |
Chris Johns |
tester: Remove the RT version.py and use the toolkit's version.
4.105
@b0fa2ae
03/03/16 05:46:18 |
Chris Johns |
Update rtems-tool to support Python 2 and 3.
Add solaris and netbsd.
4.105
@0e5d89d
02/29/16 07:02:36 |
Chris Johns |
Add aarch64 and x86_64 binutils and gdb patches.
4.105
@6bc1ece
02/28/16 21:59:26 |
Chris Johns |
Fix ithe automake warning with newer perl versions.
This patch is …
4.105
@3018e2f
02/20/16 01:44:44 |
Chris Johns |
Do not change the Python os.sep setting.
4.105
@7148cae
02/19/16 03:46:15 |
Chris Johns |
Add Windows specific waf support for MSYS2.
Limit the compilers used …
4.105
@de1beea
02/19/16 00:26:51 |
Chris Johns |
Disable installing PYO and PYC. Fix install paths.
Installing PYO and …
4.105
@4351ae5
02/19/16 00:25:50 |
Chris Johns |
Update the version of waf.
Closes #2582.
4.105
@66c6301
01/08/16 06:45:39 |
Sebastian Huber |
rtemstoolkit: Python 3 compatibility
4.105
@606c08c
01/08/16 06:44:52 |
Sebastian Huber |
rtemstoolkit: msys2 compatibility
4.105
@f027f37
01/04/16 10:15:37 |
Sebastian Huber |
linkers: Fix for targets with a small-data area
On certain targets …
4.105
@a7951f2
01/04/16 10:15:28 |
Sebastian Huber |
linkers: Avoid cast
4.105
@f775869
12/15/15 21:37:10 |
Chris Johns |
Fix running rtems-test from inside the git clone.
4.105
@2df531a
12/11/15 00:56:12 |
admin |
bsps/m32rsim*: Remove
closes #2447.
4.105
@ea51d2a
12/14/15 00:49:25 |
admin |
bsps/h8sim*: Remove
closes #2453.
4.105
@a6f5f18
12/11/15 06:15:34 |
Chris Johns |
Fix how to use the waf py feature to get py source and pyo file …
4.105
@3828e50
12/11/15 06:01:51 |
Chris Johns |
VERSION as an INI format file.
One section is supported [version] …
4.105
@8b49f73
12/10/15 01:26:49 |
Chris Johns |
Use the git hash for the revision in the version string.
4.105
@efc4f09
12/09/15 09:08:19 |
Chris Johns |
Add release versioning support.
Support a top level VERSION file that …
4.105
@c9fa179
12/08/15 04:21:03 |
Chris Johns |
Add gitattributes to aid releasing.
4.105
@04a5204
11/12/15 10:15:23 |
Sebastian Huber |
4.105
@ab922fe
11/12/15 06:48:45 |
Chris Johns |
Add tools patches for RTEMS 4.12.
4.105
@5cb66b4
11/11/15 09:18:41 |
Sebastian Huber |
rtd-rtems.cpp: Default to version 4.12
4.105
@baa798a
10/18/15 22:14:57 |
Chris Johns |
Update the versions strings.
4.105
@bd94415
10/18/15 22:14:02 |
Chris Johns |
Update waf to 1.8.15
4.105
@0382b68
10/18/15 08:19:08 |
Chris Johns |
Fix Windows build issues.
Fix biulding the mmap Windows code.
Fix …
4.105
@2f11c36
10/15/15 10:06:05 |
Chris Johns |
Always provide the argument size defines.
4.105
@f11d18b
10/15/15 10:05:29 |
Chris Johns |
Change to use the task implemenation interface.
4.105
@e3df129
09/29/15 10:26:38 |
Chris Johns |
Add a lock model to support different lock models when tracing.
4.105
@711f715
07/22/15 12:03:06 |
Ric Claus |
rtems-test.txt: Some more clarity improvements.
4.105
@5a801c2
07/22/15 11:42:13 |
Ric Claus |
rtems-tester.txt, options.py: Improved clarity and spelling.
4.105
@92935ed
07/22/15 11:38:46 |
Ric Claus |
qemu.cfg: Options changed to capture test output
4.105
@9d266e8
07/22/15 10:11:32 |
Ric Claus |
xilinx_zynq_a9_qemu_smp.mc: Change realview_pbx_a9_qemu reference to …
4.105
