source: rtems-tools
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @5afb2b8   Sep 10, 2014, 3:10:20 AM Chris Johns rtems-tld: Fix warnings in the generated code. 4.104.11
(edit) @2d5de2e   Sep 10, 2014, 1:16:26 AM Chris Johns Fix the error message. 4.104.11
(edit) @67369b1   Sep 10, 2014, 1:15:29 AM Chris Johns Fix the tempfile output code to handle line breaks better. 4.104.11
(edit) @30a7f06   Sep 10, 2014, 1:14:06 AM Chris Johns Make the verbose take the level and return the level if valid. This … 4.104.11
(edit) @b7ad4a2   Sep 8, 2014, 10:40:13 PM Chris Johns linkers: If no RTEMS path is provied see if the prefix can be used. 4.104.11
(edit) @6fb1409   Sep 8, 2014, 10:20:41 PM Chris Johns rtems-tld: Add entry and exit trace support. 4.104.11
(edit) @2126ea7   Sep 8, 2014, 9:29:41 AM Chris Johns rtems-tld: Generate arg and ret code in the wrapper. 4.104.11
(edit) @17c8364   Sep 8, 2014, 6:37:32 AM Chris Johns Fix building on CentOS 6.5. 4.104.11
(edit) @6506aa1   Sep 8, 2014, 6:06:48 AM Chris Johns RTEMS trace linker builds trace applications. The trace linker builds … 4.104.11
(edit) @b28e8b3   Sep 7, 2014, 4:31:18 AM Chris Johns Refactor the rld-rtems support to remove the globals. 4.104.11
(edit) @32cd4fc   Sep 7, 2014, 12:47:00 AM Chris Johns rtems-tld: Add --wrapper option to aid testing. The --wrapper option … 4.104.11
(edit) @3f5e31f   Sep 7, 2014, 12:45:36 AM Chris Johns Chanhe the base temp file name to 'rld--'. 4.104.11
(edit) @c4c8218   Sep 6, 2014, 11:59:25 AM Chris Johns Fix rtems-ld to keep tmep files around while building. 4.104.11
(edit) @8807135   Sep 6, 2014, 10:19:45 AM Chris Johns Refactor the CC flags. Fix the various linkers. The trace linker is … 4.104.11
(edit) @a916fa4   Sep 6, 2014, 10:19:08 AM Chris Johns Fxi the split call. 4.104.11
(edit) @a72a9e35   Sep 6, 2014, 10:17:56 AM Chris Johns Add a path str. Remove the duplicate split call. 4.104.11
(edit) @b233be7   Sep 6, 2014, 10:15:48 AM Chris Johns Trim the return value from a package file. 4.104.11
(edit) @31bf375   Sep 5, 2014, 8:18:11 AM Chris Johns Remove march/mcpu and add RTEMS BSP and cflags support. 4.104.11
(edit) @7ccb670   Sep 5, 2014, 8:16:40 AM Chris Johns Add support for RTEMS BSP or user supplied CFLAGS. Remove march/mcpu. … 4.104.11
(edit) @2f48445   Sep 5, 2014, 8:10:46 AM Chris Johns Return the requested label. This completes this code to a basic … 4.104.11
(edit) @40fd7a0   Sep 1, 2014, 3:26:47 AM Chris Johns rld: Split the file into a path module for path specific functions. … 4.104.11
(edit) @e5165d2   Aug 9, 2014, 12:32:50 PM Peng.Fan Fix getopt_long usage When passing shorhand options, getopt_long … 4.104.11
(edit) @097f1fd   Aug 7, 2014, 8:15:06 AM Chris Johns rtms-tld: Refactor the code to match a better configuration format. 4.104.11
(edit) @4fd758e   Aug 5, 2014, 1:02:35 PM Chris Johns rtems-tld: Add wrapper support and start the generator coding. 4.104.11
(edit) @a136346   Aug 5, 2014, 1:01:15 PM Chris Johns Fix temporary file handling and add tempfile write support. Move the … 4.104.11
(edit) @058d502   Aug 4, 2014, 5:09:39 AM Chris Johns rtems-tld: Add generator loading support. 4.104.11
(edit) @0a21024   Aug 3, 2014, 11:50:56 PM Chris Johns rtems-tld: Add recursive parsing of headers and defines. 4.104.11
(edit) @b6d7f5f   Aug 3, 2014, 11:19:55 PM Chris Johns rtems-tld: Add trace configuration support. Extend the configuration … 4.104.11
(edit) @ea29902   Aug 1, 2014, 6:44:32 AM Chris Johns Add initial support for the RTEM Trace Linker. The RTEMS Trace Linker … 4.104.11
(edit) @2ce23a3   Aug 1, 2014, 6:47:11 AM Chris Johns Fix building on Windows with the latest MSVC. Remove some warnings. 4.104.11
(edit) @427acf3   Jul 24, 2014, 3:09:03 AM Peng.Fan std::list should be sorted before unique std::list should be sorted … 4.104.11
(edit) @53ed116   Aug 30, 2013, 1:42:58 PM van.freenix Implement a new tool 'rtems-ra' rtems-ra supports converting an elf … 4.104.11
(edit) @64309e0   Aug 24, 2013, 10:19:15 AM van.freenix Ignore common section and null(index 0) section Signed-off-by: Peng … 4.104.11
(edit) @37a7a7c   Aug 24, 2013, 10:10:54 AM van.freenix RA format support for rtems-ld 1. Automatically place object files in … 4.104.11
(edit) @5eb6604   Aug 29, 2013, 11:41:23 AM van.freenix Fix archive writer 1. align to even address 2. Fix the use of … 4.104.11
(edit) @59c3ebd   Aug 4, 2013, 2:35:42 PM van.freenix Add rpath support 4.104.11
(edit) @347c9b5   Aug 1, 2013, 8:15:07 AM van.freenix Add section size for rap details Add elf section size to the section … 4.104.11
(edit) @39f48c9   Jul 26, 2013, 9:45:01 AM van.freenix Add object file details to RAP format This change added the object … 4.104.11
(edit) @76d3b89   Jul 22, 2013, 1:44:15 AM van.freenix collect 'STT_NOTYPE' symbols 4.104.11
(edit) @f291594   Jul 21, 2013, 4:39:21 PM van.freenix fix relocation records order 4.104.11
(edit) @c14133e   Jul 18, 2013, 3:05:02 AM van.freenix Add support for relocations which reference local symbols … 4.104.11
(edit) @e23ef3b   Jul 18, 2013, 2:53:18 AM van.freenix Fixed fsec If one object file contains .rodata and .rodata.str1.4 … 4.104.11
(edit) @4b31ced   Jul 18, 2013, 2:49:09 AM van.freenix Fixed layout problem Fixed when only one elf object file is passed to … 4.104.11
(edit) @f4cf8f4   Jul 18, 2013, 11:32:41 PM van.freenix arch specific section support 4.104.11
(edit) @26b46b1   Mar 1, 2013, 4:42:08 AM Chris Johns Fix RELA in RAP formats. Fixed the RELA handling in the merging of … 4.104.11
(edit) @69a123b   Mar 1, 2013, 2:58:56 AM Chris Johns Support the gcc option '-Wl'. Support and ignore the '-Wl,options' … 4.104.11
(edit) @6c4218b   Mar 1, 2013, 12:51:37 AM Chris Johns Fix the trace help. 4.104.11
(edit) @6fae4de   Mar 1, 2013, 12:25:48 AM Chris Johns Fix errors building on CentOS. 4.104.11
(edit) @2bcaf0c   Jan 23, 2013, 3:04:11 AM Chris Johns Update the documentation 4.104.11
(edit) @e78e2b0   Jan 22, 2013, 11:08:09 AM Chris Johns Documentation. 4.104.11
(edit) @32d5401   Jan 15, 2013, 6:03:04 AM Chris Johns Fixed the layout output to give to all the needed detail. 4.104.11
(edit) @6801aa2   Jan 1, 2013, 1:04:24 AM Chris Johns Use find_in_strtab when collecting symbols. Remove debug. 4.104.11
(edit) @f43851a   Dec 31, 2012, 7:29:10 AM Chris Johns Sort the relocation records by offset for a section. 4.104.11
(edit) @4e7ec70   Dec 31, 2012, 7:12:25 AM Chris Johns Make layout offsets match image offsets. Add a better strtab search. … 4.104.11
(edit) @06a2cf6   Dec 31, 2012, 7:11:47 AM Chris Johns Sort the relocations by offset to make the overlay work. 4.104.11
(edit) @544de91   Dec 28, 2012, 11:20:22 PM Chris Johns Fix managing weak symbols. Weak symbols where not being managed … 4.104.11
(edit) @800d4fd   Dec 24, 2012, 6:18:23 AM Chris Johns Add the symsect offset to the section reloc. 4.104.11
(edit) @073d244   Dec 24, 2012, 6:17:53 AM Chris Johns Trace the reloc addend. 4.104.11
(edit) @f31cded   Dec 23, 2012, 6:45:34 AM Chris Johns Improved section trace output. Moved the section trace output to … 4.104.11
(edit) @5825009   Dec 23, 2012, 6:04:11 AM Chris Johns Change the long opt from map to overlay. 4.104.11
(edit) @287569c   Dec 23, 2012, 5:57:35 AM Chris Johns Add an overlay output. An overlay shows the hex dump of the section … 4.104.11
(edit) @b9f631e   Dec 23, 2012, 5:54:59 AM Chris Johns Add a memory dump utility. 4.104.11
(edit) @3e902c6   Dec 21, 2012, 6:14:50 AM Chris Johns Fix the reloc symbol name. 4.104.11
(edit) @c487356   Dec 21, 2012, 6:12:07 AM Chris Johns Finish a dump of the RAP file. Fix expanding. 4.104.11
(edit) @6c28ffb   Dec 21, 2012, 6:10:18 AM Chris Johns Set header length. Make sections public. Set the compressed file … 4.104.11
(edit) @4e9b324   Dec 21, 2012, 6:08:17 AM Chris Johns Decompressor fixes. Make reading compressed files more robust … 4.104.11
(edit) @74e89db   Dec 19, 2012, 5:24:48 AM Chris Johns Turn off the debug. 4.104.11
(edit) @8bb0d53   Dec 19, 2012, 5:24:24 AM Chris Johns RAP file utility. Decompressors RAP files. 4.104.11
(edit) @db216fe   Dec 19, 2012, 5:22:37 AM Chris Johns Decompression support added. The compressor can now decompress LZ77 files. 4.104.11
(edit) @b2b811c   Dec 18, 2012, 9:57:00 AM Chris Johns Fixes to load libbsdports on i386. Numerous fixes to load the the … 4.104.11
(edit) @53221a0   Dec 18, 2012, 9:52:18 AM Chris Johns Add object::get_section. Add a method to return a section given the … 4.104.11
(edit) @b5a59dd   Dec 18, 2012, 9:51:41 AM Chris Johns Use cerr for errors and not cout. 4.104.11
(edit) @194160c   Dec 18, 2012, 9:48:35 AM Chris Johns Update the data out pointer. The data pointer was not updating when … 4.104.11
(edit) @13b9f2b   Dec 18, 2012, 9:47:27 AM Chris Johns Add a new trace level. 4.104.11
(edit) @f10123a   Dec 15, 2012, 12:30:46 PM Chris Johns Const sections are not PROGBITS and ALLOC and not EXECINTR or WRITE. 4.104.11
(edit) @d54e81c   Dec 15, 2012, 12:19:21 PM Chris Johns Debug trace changes. 4.104.11
(edit) @b89ad2c6   Dec 15, 2012, 11:44:58 AM Chris Johns i386 related fixes Fix the size of the section calculated in … 4.104.11
(edit) @f4d580b   Dec 12, 2012, 11:07:32 PM Chris Johns Add the section offset to the symbol value. 4.104.11
(edit) @42f766f   Dec 12, 2012, 10:51:03 AM Chris Johns Relocation fixes. These changes implement a suitable relocation … 4.104.11
(edit) @90d8d43   Dec 7, 2012, 10:07:30 PM Chris Johns Add support to demand load relocation records. Support has been added … 4.104.11
(edit) @be8e188   Dec 7, 2012, 10:05:12 PM Chris Johns Add doxygen support. 4.104.11
(edit) @825a10e   Dec 1, 2012, 10:22:24 AM Chris Johns The symbol string is the offset into the symbol table. 4.104.11
(edit) @9ba89e1   Nov 30, 2012, 9:09:02 PM Chris Johns Remove the trace on hack. 4.104.11
(edit) @803c60a   Nov 30, 2012, 9:05:47 PM Chris Johns RAP format up to relocation records completed. Do not write the … 4.104.11
(edit) @1a5bdef   Nov 29, 2012, 8:05:19 AM Chris Johns Add support for a custom RAP file format. The file is a header and a … 4.104.11
(edit) @93e80d5   Nov 29, 2012, 8:04:12 AM Chris Johns Compress as blocks. The LZ77 compressor works with blocks. Each block … 4.104.11
(edit) @9c70d15   Nov 29, 2012, 8:03:37 AM Chris Johns Remove the \0 character after the header. 4.104.11
(edit) @662c504   Nov 29, 2012, 8:02:28 AM Chris Johns Add the index to the section. The index is referenced in the symbol … 4.104.11
(edit) @ea6f8d4   Nov 29, 2012, 8:01:43 AM Chris Johns Add access to the value and info fields of a symbols. 4.104.11
(edit) @dc1c744   Nov 27, 2012, 12:19:15 AM Chris Johns Add machine related data to allow better checking. 4.104.11
(edit) @d99913f   Nov 27, 2012, 12:17:02 AM Chris Johns Remove size_t stream operator. On Darwin the operator works which on … 4.104.11
(edit) @8190102   Nov 26, 2012, 1:14:06 AM Chris Johns Update to the latest framwork requirements. 4.104.11
(edit) @ae353d3   Nov 26, 2012, 12:50:21 AM Chris Johns Comment clean up. 4.104.11
(edit) @eb825b1   Nov 26, 2012, 12:09:35 AM Chris Johns Add RAP format support. 4.104.11
(edit) @cad8b53   Nov 26, 2012, 12:09:06 AM Chris Johns Updated to reflect the framework changes. 4.104.11
(edit) @a458e27   Nov 26, 2012, 12:07:06 AM Chris Johns Add exit label, ELF application and Application. Add an exit label … 4.104.11
(edit) @076d935   Nov 26, 2012, 12:04:57 AM Chris Johns Add writing from images as well as streaming operators. Add the … 4.104.11
(edit) @a5fcdd5   Nov 26, 2012, 12:00:34 AM Chris Johns No archive begin/end on symbols load, image initialise fix, add … 4.104.11
(edit) @4c89c2d   Nov 25, 2012, 11:59:19 PM Chris Johns Update the section details. 4.104.11
(edit) @c6b714f   Nov 25, 2012, 11:57:29 PM Chris Johns Load the sections by default. It is not much extra overhead. Clean up … 4.104.11
