@52fc200
08/23/13 04:25:07 |
mb.dhananjay |
Update Readme.
Add wiki pages, usage instructions etc.
4.104.115
@8da0a37
08/21/13 13:01:01 |
mb.dhananjay |
Complete index subcommands.
4.104.115
@ddbc530
08/21/13 12:42:36 |
mb.dhananjay |
Refactor subcommands
- index commands inherit from a parent class.
4.104.115
@d4fc2d5
08/20/13 16:28:16 |
mb.dhananjay |
Categories the commands.
The subcommands fall onto DATA.
See …
4.104.115
@8d035f8
08/20/13 16:17:22 |
mb.dhananjay |
Refactor
- pretty printers moved to pretty module
- command and …
4.104.115
@2c25dc5
08/15/13 14:56:30 |
mb.dhananjay |
Add message_queue subcommand.
4.104.115
@b743d63
08/09/13 12:16:37 |
mb.dhananjay |
Catch nonvalid indexes.
Catch IndexErrors? generated while referancing …
4.104.115
@a713688
08/09/13 12:14:18 |
mb.dhananjay |
Add task subcommand
rtems tasks <index(s)> - Prints tasks by index.
4.104.115
@4797179
08/09/13 08:37:43 |
mb.dhananjay |
Add subcommand semaphore
rtems semaphore <index(s)> : prints rtems …
4.104.115
@559bd50
08/04/13 18:47:39 |
mb.dhananjay |
Catch invalid object ID.
4.104.115
@66d0779
08/04/13 18:37:47 |
mb.dhananjay |
Barrier taks queue
Print the barrier taks queue.
4.104.115
@6d89e3c
08/01/13 06:50:23 |
mb.dhananjay |
Refactor
- The objects are intialized using the objects rather than …
4.104.115
@e60a5ee
07/30/13 03:24:35 |
mb.dhananjay |
Fix Task and state printer bugs.
- Removed ITRON api objects in …
4.104.115
@e282b6e
07/29/13 10:54:24 |
mb.dhananjay |
Move todo
Why else is there issues?
4.104.115
@59c4946
07/29/13 04:56:02 |
mb.dhananjay |
New todo
4.104.115
@8e0de06
07/29/13 04:55:38 |
mb.dhananjay |
Add classic barrier.
- Add support for classic barrier object.
- Drop …
4.104.115
@c63080d
07/28/13 12:25:22 |
mb.dhananjay |
Update Readme.
ToDo?.
4.104.115
@b9ee5df
07/28/13 09:15:58 |
mb.dhananjay |
Add region support.
Abstractions for classic/region added.
4.104.115
@c3d06d5
07/28/13 07:31:06 |
mb.dhananjay |
Abstraction for HEAP.
Heap_Control Abstraction is added. It will need …
4.104.115
@09086b4
07/27/13 08:41:19 |
mb.dhananjay |
Support classic/partitions
Added support for partition object.
4.104.115
@086e689
07/17/13 10:30:57 |
mb.dhananjay |
Added support for classic/timers.
4.104.115
@591fbf6
07/16/13 12:47:03 |
mb.dhananjay |
Fix typo: Global timer control object name.
4.104.115
@0967a1b
07/13/13 11:01:59 |
mb.dhananjay |
Refactoring
- drop _printer suffix from printer classes.
4.104.115
@a785e25
07/12/13 13:37:46 |
mb.dhananjay |
Add printers to stage.
4.104.115
@b061a67
07/12/13 13:34:37 |
mb.dhananjay |
Heavy refactoring + Improved mesege queu printing.
- pretty printers …
4.104.115
@6e75f4e
07/09/13 16:51:27 |
mb.dhananjay |
Update readme.
Included useage instructions.
4.104.115
@3856406
07/09/13 09:07:20 |
mb.dhananjay |
Fix pretty printers
pretty printers for rtems_id and rtems_attribute
4.104.115
@f814c76
07/08/13 16:12:48 |
mb.dhananjay |
Messege Queue Objects
Added intial support for printing
4.104.115
@ce55b57
07/08/13 16:10:21 |
mb.dhananjay |
Object can have index from 1 to 'maximum'
4.104.115
@10bcd5d
06/24/13 04:10:59 |
mb.dhananjay |
Update chains structures
- Fixes chains structure parsing
- Fix …
4.104.115
@56a70ae
06/17/13 17:10:17 |
mb.dhananjay |
Intial commit.
Chris's intial work on the extenstions.
4.104.115
@911e710
06/17/13 15:31:09 |
mb.dhananjay |
Initial commit
4.104.115
@8101cf0
07/07/14 21:23:47 |
Joel Sherrill |
Add newlib-sys-cpuset-const-20140414.diff
4.104.115
@8cfeec3
06/23/14 01:00:30 |
Chris Johns |
4.11: Patch so net-snmp 5.7.2.1 builds with RTEMS.
4.104.115
@100f517
05/09/14 11:50:37 |
Chris Johns |
covoar: Merger the covoar source from rtems-testing.git.
Use waf to …
4.104.115
@f25fed3
06/16/14 03:11:28 |
Chris Johns |
4.11: Add ntp patch.
This patch has issues related to the clock …
4.104.115
@c8f4ba6
06/09/14 23:41:47 |
Chris Johns |
rt: Update the documentation.
4.104.115
@984b06d
06/01/14 06:15:28 |
Chris Johns |
config: Fix the name for the xilinx_zynq_a9_qemu bsp.
4.104.115
@8fac58f
06/01/14 04:46:50 |
Chris Johns |
config: Add support for the gdbarmsim for the arm920 BSP.
4.104.115
@288d633
06/01/14 04:46:11 |
Chris Johns |
config: Clean up the qemu configurations.
4.104.115
@60937e1
06/01/14 04:43:03 |
Chris Johns |
test: Strengthen the timeout handling by killing the process.
4.104.115
@c04a849
05/31/14 10:03:05 |
Chris Johns |
tester: Correctly handle contro-c.
Add support to kill running tests …
4.104.115
@5cdcde1
05/19/14 02:49:52 |
Chris Johns |
4.11/sparc: GDB 7.7 SIS simulator output patch.
4.104.115
@ab131bb
05/14/14 23:36:29 |
Joel Sherrill |
Add jmr3904 GDB simulator support
4.104.115
@a28e562
05/11/14 23:43:59 |
gmate.amit |
doc: rtems-tester.txt: Add information for building tests
The test …
4.104.115
@803b63d
04/27/14 17:35:01 |
Ben Gras |
add --filter to specify the set of selected tests.
. parameter is a …
4.104.115
@47d652c
05/08/14 12:39:07 |
Chris Johns |
gdb: Fix lm32 simulator's UART code. Builds on MinGW.
4.104.115
@a35f890
04/30/14 13:13:14 |
Chris Johns |
tools/gdb: Simulator inline fixes in the cgen code.
4.104.115
@9e78f60
04/30/14 06:22:37 |
Chris Johns |
tools/microblaze: Fix the building of libgcc.
4.104.115
@4efea40
04/28/14 23:18:14 |
Chris Johns |
bsp: Clean up the BBxM BSP configuration.
4.104.115
@bd0fbd6
04/28/14 23:10:14 |
Chris Johns |
bsp: Break on the terminate halt to get fatal handlers run.
4.104.115
@4e8f984
04/24/14 07:52:32 |
Chris Johns |
bsp: Add Beagleboard xM support.
4.104.115
@b45ca52
04/10/14 08:21:24 |
Chris Johns |
tester: Fix the psim script.
4.104.115
@f756b51
04/10/14 08:21:01 |
Chris Johns |
gdb: pr 16827, fix sim on Mavrick.
4.104.115
@05d2385
03/26/14 05:45:19 |
Chris Johns |
bsp: Add psim.
4.104.115
@a116962
03/26/14 05:45:06 |
Chris Johns |
tester: The process returns an exit code not an errno.
4.104.115
@ec18d1d
03/20/14 20:21:16 |
Joel Sherrill |
gcc-4.8.2-rtems4.11-20140349.diff: New file
4.104.115
@e959da9
03/19/14 04:15:31 |
Chris Johns |
4.11/gdb: Fix detecting python when building GDB on FreeBSD 10.0.
4.104.115
@f91e023
02/17/14 07:04:46 |
Chris Johns |
Add the documentation.
4.104.115
@11d4b89
02/17/14 06:56:03 |
Chris Johns |
Add README.
Also add a git ignore.
4.104.115
@50fdf12
02/14/14 19:30:06 |
Chris Johns |
rt: Add the rtems-tester.
4.104.115
@8f75c4a
02/12/14 02:18:33 |
Chris Johns |
libffi: Fix for Fedora 64bit pkg-config file.
4.104.115
@29734ec
01/18/14 06:27:13 |
Chris Johns |
gdb/sparc: SIS gdb output fix, add nouartrx.
Fix the output from the …
4.104.115
@b2589cb
08/14/13 03:49:27 |
Chris Johns |
gcc: Switch GCC to the posix thread model.
Change from the RTEMS …
4.104.115
@98f78dc
07/15/13 23:58:54 |
Chris Johns |
The cxa_atexit support is a reqirement for destructor registration …
4.104.115
@6651de8
05/30/13 23:43:40 |
Chris Johns |
Add Joel's stack_t patch.
4.104.115
@bba0b78
05/22/13 06:47:01 |
verm |
Add patch to remove times.c from PowerPC newlib.
4.104.115
@acdef36
05/16/13 08:13:31 |
verm |
Add three patches from Anthony Green to fix moxie tools.
4.104.115
@440c97f
04/14/13 22:25:05 |
Chris Johns |
Regenerate the patch cleanly.
4.104.115
@65575cc
04/13/13 08:23:52 |
Chris Johns |
Update the 4.7.2 patch to 4.7.3.
4.104.115
@eba19fa
04/05/13 03:24:01 |
Chris Johns |
Update to the patch Joel merged.
4.104.115
@926ef3c
04/02/13 21:39:03 |
Chris Johns |
PR target/56771. Require 64-bit int for arm*-*-rtems[.0-9]*.
4.104.115
@9d711f4
04/02/13 06:48:38 |
Chris Johns |
Fix to build in cygwin.
4.104.115
@4c5ffb2
03/20/13 06:27:49 |
Chris Johns |
Fix the sed breakage on FreeBSD.
4.104.115
@038b250
03/19/13 06:16:54 |
Chris Johns |
Add the current rtems-4.10 patches.
4.104.115
@ce77d87
03/15/13 01:10:20 |
Chris Johns |
Import the 4.9 patches.
4.104.115
@f0c9bae
03/11/13 08:31:18 |
Sebastian Huber |
Add latest GCC 4.7 ARM to EABI patch
This patch is included in the …
4.104.115
@cb328a1
03/11/13 06:16:02 |
Chris Johns |
Regenerate the ARM EABI patch for gcc-4.7.2 sources.
4.104.115
@94c5d74
03/11/13 00:50:53 |
Chris Johns |
ARM EABI patch.
4.104.115
@e42bad3
03/10/13 22:28:55 |
Chris Johns |
Move current patches in to the repo.
4.104.115
@5749230
03/10/13 03:31:57 |
Chris Johns |
Regerated version of Joel's patch so patch -p1 works.
4.104.115
@0e90000
03/10/13 01:35:37 |
Chris Johns |
Use a better name for the patch.
4.104.115
@25e43e1
03/10/13 01:27:22 |
Chris Johns |
Microblaze gcc-4.7.2 patch from Joel.
4.104.115
@df78032
03/08/13 07:44:32 |
Chris Johns |
MIPS memcpy fixes.
4.104.115
@6d5bfb0
03/06/13 15:25:00 |
Gedare Bloom |
Clean up. Remove all files to prepare repo for a new life.
4.104.115
@7234c70
09/06/12 04:09:49 |
Chris Johns |
Move .cvsignore to .gitignore. Update ChangeLog?.
4.104.115
@68c9b8a
08/04/12 12:29:24 |
Chris Johns |
Remove CVS Id and update the copyright year.
4.104.115
@5a44122
08/04/12 12:17:50 |
Chris Johns |
Comments clean up.
4.104.115
@e801762
08/04/12 12:17:33 |
Chris Johns |
Use the crossrpms repo and not the RTEMS source.
4.104.115
@db789e3
08/04/12 12:17:05 |
Chris Johns |
Clean up.
4.104.115
@f51e691
08/04/12 12:16:48 |
Chris Johns |
Do not build with zlib.
4.104.115
@6b88114
12/06/11 23:44:37 |
Chris Johns |
Add /usr/local to the host cflags on FreeBSD.
4.104.115
@8548cd7
12/06/11 06:37:57 |
Chris Johns |
Add a hack to work around make not being a macro in the spec files.
4.104.115
@594f41f
12/05/11 20:53:17 |
Chris Johns |
Fix the host verison in FreeBSD. Allow the top of the src to crossrpms.
4.104.115
@a2bc901
12/05/11 11:32:44 |
Chris Johns |
Add FreeBSD support.
4.104.115
@a86cd82
06/09/11 05:59:32 |
Chris Johns |
2011-06-09 Chris Johns <chrisj@…>
4.104.115
@faa8181
02/22/11 03:46:44 |
Chris Johns |
2011-02-22 Chris Johns <chrisj@…>
4.104.115
@31d4e80
08/31/10 00:58:45 |
Chris Johns |
2010-08-31 Chris Johns <chrisj@…>
4.104.115
@9eb5c92
08/28/10 23:01:20 |
Chris Johns |
2010-08-29 Chris Johns <chrisj@…>
4.104.115
@f1a0bde
08/13/10 04:40:44 |
Chris Johns |
2010-08-13 Chris Johns <chrisj@…>
4.104.115
