@2de37f3
03/09/16 03:27:42 |
Chris Johns |
Python 2 and python 3 refactor fixes.
Updates #2619.
4.105
@a5d243d
03/04/16 01:10:09 |
Chris Johns |
tester: Remove the RT version.py and use the toolkit's version.
4.105
@b0fa2ae
03/03/16 05:46:18 |
Chris Johns |
Update rtems-tool to support Python 2 and 3.
Add solaris and netbsd.
4.105
@0e5d89d
02/29/16 07:02:36 |
Chris Johns |
Add aarch64 and x86_64 binutils and gdb patches.
4.105
@6bc1ece
02/28/16 21:59:26 |
Chris Johns |
Fix ithe automake warning with newer perl versions.
This patch is …
4.105
@3018e2f
02/20/16 01:44:44 |
Chris Johns |
Do not change the Python os.sep setting.
4.105
@7148cae
02/19/16 03:46:15 |
Chris Johns |
Add Windows specific waf support for MSYS2.
Limit the compilers used …
4.105
@de1beea
02/19/16 00:26:51 |
Chris Johns |
Disable installing PYO and PYC. Fix install paths.
Installing PYO and …
4.105
@4351ae5
02/19/16 00:25:50 |
Chris Johns |
Update the version of waf.
Closes #2582.
4.105
@66c6301
01/08/16 06:45:39 |
Sebastian Huber |
rtemstoolkit: Python 3 compatibility
4.105
@606c08c
01/08/16 06:44:52 |
Sebastian Huber |
rtemstoolkit: msys2 compatibility
4.105
@f027f37
01/04/16 10:15:37 |
Sebastian Huber |
linkers: Fix for targets with a small-data area
On certain targets …
4.105
@a7951f2
01/04/16 10:15:28 |
Sebastian Huber |
linkers: Avoid cast
4.105
@f775869
12/15/15 21:37:10 |
Chris Johns |
Fix running rtems-test from inside the git clone.
4.105
@2df531a
12/11/15 00:56:12 |
admin |
bsps/m32rsim*: Remove
closes #2447.
4.105
@ea51d2a
12/14/15 00:49:25 |
admin |
bsps/h8sim*: Remove
closes #2453.
4.105
@a6f5f18
12/11/15 06:15:34 |
Chris Johns |
Fix how to use the waf py feature to get py source and pyo file …
4.105
@3828e50
12/11/15 06:01:51 |
Chris Johns |
VERSION as an INI format file.
One section is supported [version] …
4.105
@8b49f73
12/10/15 01:26:49 |
Chris Johns |
Use the git hash for the revision in the version string.
4.105
@efc4f09
12/09/15 09:08:19 |
Chris Johns |
Add release versioning support.
Support a top level VERSION file that …
4.105
@c9fa179
12/08/15 04:21:03 |
Chris Johns |
Add gitattributes to aid releasing.
4.105
@04a5204
11/12/15 10:15:23 |
Sebastian Huber |
4.105
@ab922fe
11/12/15 06:48:45 |
Chris Johns |
Add tools patches for RTEMS 4.12.
4.105
@5cb66b4
11/11/15 09:18:41 |
Sebastian Huber |
rtd-rtems.cpp: Default to version 4.12
4.105
@baa798a
10/18/15 22:14:57 |
Chris Johns |
Update the versions strings.
4.105
@bd94415
10/18/15 22:14:02 |
Chris Johns |
Update waf to 1.8.15
4.105
@0382b68
10/18/15 08:19:08 |
Chris Johns |
Fix Windows build issues.
Fix biulding the mmap Windows code.
Fix …
4.105
@2f11c36
10/15/15 10:06:05 |
Chris Johns |
Always provide the argument size defines.
4.105
@f11d18b
10/15/15 10:05:29 |
Chris Johns |
Change to use the task implemenation interface.
4.105
@e3df129
09/29/15 10:26:38 |
Chris Johns |
Add a lock model to support different lock models when tracing.
4.105
@711f715
07/22/15 12:03:06 |
Ric Claus |
rtems-test.txt: Some more clarity improvements.
4.105
@5a801c2
07/22/15 11:42:13 |
Ric Claus |
rtems-tester.txt, options.py: Improved clarity and spelling.
4.105
@92935ed
07/22/15 11:38:46 |
Ric Claus |
qemu.cfg: Options changed to capture test output
4.105
@9d266e8
07/22/15 10:11:32 |
Ric Claus |
xilinx_zynq_a9_qemu_smp.mc: Change realview_pbx_a9_qemu reference to …
4.105
@45d4773
08/10/15 12:48:58 |
yangqiao0505 |
add microwindows patches
4.105
@3f3582f
04/19/15 11:04:36 |
Hesham Almatary |
Rename or1ksim BSP to generic_or1k
4.104.115
@a68557d
04/14/15 23:03:28 |
Joel Sherrill |
bf537Stamp: Add configuration files
4.104.115
@d2d91f5
04/04/15 14:24:36 |
Joel Sherrill |
leon3-tsim*: First attempt at LEON3 on tsim support
The rtems-tester …
4.104.115
@c0449d5
04/04/15 14:24:24 |
Joel Sherrill |
lm32_evr_gdbsim: Add configuration files
4.104.115
@7d784d2
04/04/15 14:24:02 |
Joel Sherrill |
psim*.mc: Fix typo
4.104.115
@b6b784c
04/02/15 18:16:56 |
Hesham Almatary |
Add QEMU patch for openrisc to recognize halt signals
4.104.115
@bbad85e
04/02/15 14:52:42 |
Joel Sherrill |
Update gdb-sim-lm32uart.diff to gdb-7.9
4.104.115
@e98d5fa
03/29/15 16:35:59 |
Joel Sherrill |
Add configurations for erc32, leon2, and leon3 in GDB SIS
These …
4.104.115
@b249516
03/29/15 07:06:00 |
Chris Johns |
rtemstoolkit: Add support to return the system path split as paths.
4.104.115
@5032d71
03/29/15 05:37:22 |
Chris Johns |
trace-linker: Update comments.
4.104.115
@bfd2b7d
03/26/15 18:20:45 |
Joel Sherrill |
Add Jiri Gaisler SIS patch set for gdb 7.9
This patch set adds a lot …
4.104.115
@d499e6d
03/27/15 09:21:33 |
Chris Johns |
trace-linker: Add the trace function signatures to the wrapper code.
4.104.115
@f5b639b
03/27/15 03:21:56 |
Chris Johns |
rtems-tester: Remove repeated install line in wscript.
Fixes #2312.
4.104.115
@20feafb
03/26/15 18:20:15 |
Joel Sherrill |
Add rtems-tester configurations for simsh family of BSPs
4.104.115
@b69cd3f
03/26/15 07:23:35 |
Chris Johns |
trace-linker: Add API and POSIX interfaces.
4.104.115
@b988768
03/26/15 06:08:18 |
Chris Johns |
trace-linker: Add Trace Buffering support.
Trace buffering traces …
4.104.115
@1703041
03/24/15 03:37:35 |
Chris Johns |
rtems-tld: Add lock and buffer allocator support to generators.
4.104.115
@29ad92c5
03/23/15 06:19:01 |
Chris Johns |
trace-linker: Add options, names, enables, and triggers.
Move the …
4.104.115
@8531776
03/23/15 06:18:39 |
Chris Johns |
rtemstoolkit: Add an array operator to return recs in a section.
4.104.115
@4585798
03/22/15 04:21:25 |
Chris Johns |
The commit references #2312.
4.104.115
@36e6631
03/18/15 05:44:19 |
Chris Johns |
rtemstoolkit: Remove warning on Windows.
4.104.115
@ea749e5
03/18/15 05:43:30 |
Chris Johns |
Ignore waf files on Windows and Python3 waf files.
4.104.115
@dfc5994
03/17/15 10:37:43 |
Chris Johns |
elftoolchain: Add support for Cygwin.
4.104.115
@b117be8
03/17/15 02:11:57 |
Chris Johns |
gdb/python: Update the support to a recent RTEMS.
4.104.115
@a30ec56
03/12/15 22:29:37 |
Joel Sherrill |
Add configurations for all h8 GDB simulator BSP variants
4.104.115
@8abbe80
03/12/15 22:17:56 |
Joel Sherrill |
Add configurations for all arm GDB simulator BSP variants
4.104.115
@ab5e0c5
03/12/15 21:55:43 |
Joel Sherrill |
Add configuration for m32csim BSP for simulator in GDB
4.104.115
@b938414
03/12/15 18:51:32 |
Joel Sherrill |
Add configuration for m32rsim BSP for simulator in GDB
4.104.115
@71fb99b
03/12/15 17:47:13 |
Joel Sherrill |
Add configurations for all v850 GDB simulator BSP variants
4.104.115
@01a4192
02/22/15 06:07:10 |
asahasra |
Modified waf scripts to have a minimum python version requirement of …
4.104.115
@e143a62
02/16/15 00:27:18 |
Chris Johns |
Fix the chmod octal value to use the correct Python syntax.
4.104.115
@a8c4f3f
02/16/15 00:25:22 |
Chris Johns |
Update the Windows header to direct.h for _mkdir per the MSDN.
4.104.115
@05fe73d
02/08/15 07:40:35 |
Chris Johns |
Fix the tester wscript.
4.104.115
@9600c39
02/08/15 07:14:16 |
Chris Johns |
Fixes to the run the waf built tests when installed.
4.104.115
@b7d48ef
02/08/15 06:12:04 |
Chris Johns |
Install the rtems-test command.
This installs the Python RTEMS …
4.104.115
@7338811
01/20/15 23:52:54 |
Chris Johns |
Remove warning on Linux.
4.104.115
@69c955d
01/20/15 23:51:48 |
Chris Johns |
DEST_OS is linux and not linux2.
4.104.115
@f381f26
01/19/15 21:56:14 |
Chris Johns |
Fix covoar so it builds for Windows.
4.104.115
@3badbb0
01/18/15 07:12:18 |
Chris Johns |
Add support to cross-compile. Use --hosti=.
On FreeBSD use …
4.104.115
@3f47178
01/09/15 14:37:25 |
Sebastian Huber |
Add PowerPC patches for GCC 4.9.2
4.104.115
@8de6f6b
12/18/14 04:15:11 |
Chris Johns |
rtems-tld: Install the libc heap configuration files.
4.104.115
@7fc1edb
12/18/14 04:07:59 |
Chris Johns |
rtems-tld: Add configuration support for libc head tracing.
These …
4.104.115
@d8a82fd
12/04/14 12:02:27 |
Sebastian Huber |
Add SPARC patches for GCC 4.9.2
These patches are already present in …
4.104.115
@af8c147a
11/14/14 22:19:09 |
Jiri Gaisler |
gdb patch to add leon2/3 support to sis
This fixes the commit …
4.104.115
@4bdba3e
12/02/14 04:50:02 |
Chris Johns |
tools/gdb: Add a patch for gdb-7.7/gdb-7.8 SPARC.
This patch updates …
4.104.115
@efae4ae
11/08/14 07:00:28 |
Chris Johns |
toolkit: Print dependents in resolver.
4.104.115
@066a64b
11/08/14 06:59:40 |
Chris Johns |
toolkit: Raise a user error and not an internal one.
4.104.115
@b1e9ab9
11/20/14 18:46:43 |
Joel Sherrill |
main-page.cpp: Fix spelling issue
4.104.115
@b9c0a04
11/06/14 01:05:38 |
Chris Johns |
linkers: Disable .type statements in symbol code.
Some of the …
4.104.115
@53e387d
11/04/14 08:39:57 |
Chris Johns |
linkers: Merge the standard libraries into the user library paths.
4.104.115
@ddbab71
11/03/14 22:40:15 |
Chris Johns |
Fix buffer leak on error.
4.104.115
@0f93ea6
11/03/14 22:03:06 |
Ben Gras |
fix buffer size problem
(triggered runtime error on my machine)
4.104.115
@e4014f0
07/23/14 16:20:19 |
ben |
typo
4.104.115
@2015c85
10/31/14 15:52:36 |
Ben Gras |
fix for open() not taking a std::string
4.104.115
@fdb1fe6
10/30/14 06:55:18 |
Chris Johns |
linkers: Add base image symbol to ELF object file generation.
This …
4.104.115
@aac2949
10/28/14 08:14:02 |
Chris Johns |
linkers: Add kernel symbol support.
The rtems-sym tool has been …
4.104.115
@3fd45d3
10/28/14 08:13:47 |
Chris Johns |
toolkit: Fix the map formatting.
4.104.115
@df7fd26
10/28/14 08:13:19 |
Chris Johns |
toolkit: Update the comment.
4.104.115
@23bbbfd
09/07/14 01:16:58 |
Hesham Almatary |
Add new OpenRISC/or1ksim BSP script using qemu
4.104.115
@6ae559c
09/21/14 22:23:39 |
Chris Johns |
rtems-tld: Make printk the default generator.
4.104.115
@5025439
09/21/14 04:24:37 |
Chris Johns |
rtems-tld: Add config options, fix void args, and SCore traces.
4.104.115
@149a8a6
09/20/14 22:50:56 |
Chris Johns |
rtems-tld: Remove forced trace message.
4.104.115
@435d879
09/13/14 02:26:45 |
Chris Johns |
rtk: Build fastlz into the rld library.
Do not build as an object per …
4.104.115
@73eb48a
09/13/14 02:20:19 |
Chris Johns |
rtk: Fix buffer leak in rld::path::abs_path.
4.104.115
@87e0e76
09/13/14 02:09:16 |
Chris Johns |
Refactor code into the RTEMS Toolkit.
4.104.115
