@16b25be
04/25/18 23:21:07 |
joel |
SPARC: ngmp replaced with specific CPU model BSPs
5
@c2d0d0e
02/06/18 00:31:59 |
joel |
tester/rtems/rtems-bsps-powerpc.ini: Fix typo
5
@14a1c097
06/01/18 22:32:59 |
reachvidu |
Updating trace buffer configuration
5
@e04699b
05/24/18 21:25:38 |
Chris Johns |
tester/covoar: Do not load an executable's local symbols.
5
@70dac81
05/14/18 19:26:21 |
cpodonnell8 |
covoar: Fix build path checks for multiple executables.
5
@b0b9366
05/06/18 03:21:18 |
Chris Johns |
rtemstoolkit: More warning fixes to ConvertUTF.c
5
@feafa6f
04/30/18 23:08:12 |
joel |
_elftc.h: Make compile on Cygwin
5
@14c7f25
04/28/18 08:12:46 |
Chris Johns |
tester/covoar: Remove the C part of main and convert to C++
This is a …
5
@3e187ba
04/25/18 20:33:58 |
cpodonnell8 |
covoar: Add symbol set reader and ELF data parser to covoar.
Add …
5
@e0a52a4
04/30/18 05:50:03 |
Chris Johns |
rtemstoolkit: Remove warnings generated on Windows for fall-thru.
5
@4bb3996
04/30/18 05:34:48 |
Chris Johns |
rtemstoolkit: Add libdwarf from elftoolchain.
The code is taken from: …
5
@771e7f1
04/30/18 04:20:32 |
Chris Johns |
rtemstoolkit: Update elftoolchain to the latest code.
The update is …
5
@6f48c91
04/30/18 03:39:09 |
Chris Johns |
Revert "rtemstoolkit: Update elftoolchain to the latest code."
This …
5
@0c5db2d
04/29/18 01:55:37 |
Chris Johns |
The update is …
5
@2586350
04/23/18 07:42:54 |
Chris Johns |
tester: Fix the configure debug option.
The option is …
5
@ec419a0
04/16/18 01:55:01 |
Chris Johns |
rtemstoolkit/rap: Ignore R_ARM_V4BX relocation records
Note, this …
5
@82c8788
04/14/18 04:15:07 |
Chris Johns |
rtemstoolkit/rtl-file: Remove a file on close if requested
Close #3395
5
@b7c4753
04/10/18 04:00:09 |
Chris Johns |
teater: Filter out an *.norun.* executables.
5
@cf641a6
04/10/18 03:59:43 |
Chris Johns |
tester: List .ini files for BSPs with --list-bsps.
5
@c5286cd
04/10/18 03:59:11 |
Chris Johns |
waf: Add getcwd() to sys.path as waf has changed.
5
@252d21c
04/10/18 01:46:11 |
Chris Johns |
bsp-builder: Collect2 messages are errors.
5
@6e468c7
02/01/18 18:48:21 |
joel |
rtems-bsps-powerpc.ini: Add PowerPC qemu BSPs
5
@005f995
01/31/18 23:51:54 |
Chris Johns |
rtems-bsp-builder: Remove stray %s from the run log message.
Close #3278
5
@623a641
01/31/18 22:42:59 |
Chris Johns |
rtems-bsp-builder: Add a check for invalid ARCH and BSP names.
If …
5
@0333442
01/02/18 22:59:31 |
joel |
tester/covoar/covoar.cc: Add missing throw keyword
Why clang caught …
5
@b516a58
12/05/17 14:03:44 |
joel |
tester/covoar/covoar.cc: Exit using exit() rather than just throwing.
5
@149144f
12/05/17 13:52:21 |
joel |
tester/covoar/covoar.cc: Clean up formatting (tabs, braces, …
5
@c432d89
11/22/17 10:32:20 |
Sebastian Huber |
Add tester qoriq_e6500_64.ini
5
@f010b51
11/22/17 10:32:05 |
Sebastian Huber |
Add tester qoriq_e6500_32.ini
5
@2248c9a
11/22/17 09:31:23 |
Sebastian Huber |
Add imx7 and qoriq_e500 to tier-1
5
@3ba9c03
11/21/17 15:00:00 |
Sebastian Huber |
Add tester qoriq_e500.ini
5
@3a32d15
11/10/17 08:42:23 |
Sebastian Huber |
Add tool patches warning
Update #2949.
5
@30218f5
11/05/17 07:48:20 |
Chris Johns |
tester: Add reporting the RTEMS version, build and tools.
Update #3217.
5
@9f34b38
11/10/17 08:38:48 |
Sebastian Huber |
Remove tools/5 patches
Update #3220.
5
@6f5cfad
11/09/17 08:54:14 |
Sebastian Huber |
Add tester imx7.ini
Update #3090.
5
@469e362
11/09/17 08:41:34 |
Sebastian Huber |
Add tools/5 patches
Update #3220.
5
@a70b8e6
11/09/17 08:35:29 |
Sebastian Huber |
Add tools/5 patch
Update #3220.
5
@52f3790
11/09/17 08:25:43 |
Sebastian Huber |
Add tools/5 patch
Update #3220.
5
@2da1356
11/09/17 08:07:35 |
Sebastian Huber |
Add tools/5 patches
Update #3220.
5
@b5a4b15
11/09/17 08:05:14 |
Sebastian Huber |
Add tools/5 patch
Update #3220.
5
@aff8c47
11/09/17 07:44:21 |
Sebastian Huber |
Add tools/5 patch
Update #3220.
5
@e5dad3c
11/08/17 08:46:25 |
Sebastian Huber |
Change RTEMS version from 4.12 to 5
Update #3220.
5
@24d51f7
11/04/17 00:22:08 |
Chris Johns |
tester: Change the mail subject so it list by BSP in the archives.
5
@42e39d2
11/03/17 07:20:31 |
Chris Johns |
tester: Fix the output so the report end analysis works.
5
@c68beb8
11/03/17 06:57:37 |
Chris Johns |
tester: Add the rtems-run command.
5
@7e85878
11/03/17 06:56:48 |
Chris Johns |
tester: Make the mandatory items appear first.
5
@0fe3a4b
11/01/17 03:30:32 |
Chris Johns |
tester: Fix rtems-bsp-builder reporting bug
5
@35b9c0c
10/28/17 02:45:23 |
Hesham Almatary |
Tester - RISC-V: Add spike simulator and scripts/bsp for riscv ports
5
@bb218b6
10/24/17 23:21:22 |
Chris Johns |
tester: Minor fix to the test results mail.
5
@c73e030
10/24/17 23:13:28 |
Chris Johns |
tester: Check mail parameters early so users can fix.
5
@41d0c34
10/24/17 22:03:43 |
Chris Johns |
tester: Add a BSP field to each BSP INI configuration section.
The …
5
@a248471
10/24/17 21:53:27 |
Chris Johns |
rtemstoolkit: Remove test import for YAML.
Closes #3204.
5
@bf58911
10/24/17 10:35:21 |
Chris Johns |
tester: Refactor to use INI format files for BSP configurations.
5
@5251361
10/23/17 04:22:34 |
Chris Johns |
tester: Add an executable file name filter.
The exe filter lets a BSP …
5
@7051ba5
10/22/17 07:09:39 |
Chris Johns |
bsb-builder: Add email support, and config report types.
5
@b1d2db9
10/21/17 06:05:00 |
Chris Johns |
tester: Update BeagleBone? Black, PC and Zedboard configurations.
5
@f1e8fd4
10/21/17 05:59:14 |
Chris Johns |
tester: Add pretest and posttest target commands with @ARCH@, @BSP@ …
5
@cec5878
10/21/17 05:10:22 |
Chris Johns |
tester: Remove pass status messages from the email log posts.
5
@af6a54d
10/21/17 05:09:30 |
Chris Johns |
tester: Use a target ON command before the first test.
5
@ac679ba
10/21/17 05:09:00 |
Chris Johns |
tester: Print the host and port on error in telnet connect.
5
@0054585
10/13/17 16:31:47 |
Chris Johns |
tester/covoar: Use standard waf modules for linking.
Use the standard …
5
@b76fa74
10/12/17 10:52:59 |
Sebastian Huber |
linkers: Update due to API changes
Update #3160.
5
@5e40b4a
10/11/17 19:25:10 |
Chris Johns |
tester: Fix excluded fails processing.
5
@89e8c2a
10/11/17 19:13:47 |
Chris Johns |
tester: Add support to email results.
5
@fce29b0
10/11/17 19:13:13 |
Chris Johns |
tester: Change the capture console prompt to avoid email reply …
5
@dc5de5f
10/11/17 19:11:16 |
Chris Johns |
rtemstoolkit: Update the mailer module to the option interface.
5
@7c032b0
10/11/17 19:09:52 |
Chris Johns |
rtemstoolkit: Add a capture hook to logging.
5
@7f11670
10/11/17 19:08:31 |
Chris Johns |
rtemstoolkit: Fix error message in options.
5
@b4b61b5
10/11/17 11:50:52 |
Chris Johns |
testing: Add a PC BSP configuration.
5
@2d6d1c5
10/11/17 11:50:16 |
Chris Johns |
testing: Update BSP configurations.
5
@4b76b8e
10/11/17 11:49:17 |
Chris Johns |
testing: Generate console message on a second TFTP exe request.
5
@0eb8400
10/11/17 11:48:46 |
Chris Johns |
testing: Print the output after the result. Easier to find and review …
5
@5df7c3c
10/10/17 18:07:15 |
Sebastian Huber |
Install missing files
5
@662e1f7
10/10/17 02:30:31 |
Chris Johns |
tester: Add a tester off to turn the target off when finished.
5
@9580804
10/07/17 07:57:24 |
Chris Johns |
Add a target start and target reset to manage boards that do not boot …
5
@68cbfc3
10/05/17 03:24:11 |
Chris Johns |
tester: Add Zedboard.
5
@2ae9b6d
10/05/17 03:21:33 |
Chris Johns |
tester: Telnet console reopens the connection if it fails or closes.
5
@0737b46
10/05/17 03:21:01 |
Chris Johns |
tester: Add a target reset regular expression to detect a reset.
5
@3c7cd05
09/21/17 11:34:34 |
Chris Johns |
tester: Fix the TFTP ok to kill deadlock.
5
@3ed65c0
09/21/17 11:33:56 |
Chris Johns |
Lower the step size for the TFTP timeout.
5
@3a867a4
09/21/17 08:26:20 |
Chris Johns |
Add TFTP as a back end option for testing. Add telnet as a console …
5
@fa81491
09/21/17 07:45:39 |
Chris Johns |
Move the reraise logic into the tool kit.
5
@875c071
09/14/17 23:05:38 |
joel |
rtemstoolkit/rld-compression.cpp: Fix warning for comparing signed to …
5
@f4378ea
09/14/17 23:04:55 |
joel |
tester/covoar/DesiredSymbols.cc: Now compiles on Cygwin
5
@8e64821
09/14/17 02:21:08 |
Chris Johns |
rtemstoolkit: Remove throw from file::image destructor.
5
@f4773ac
09/13/17 15:45:30 |
cpodonnell8 |
covoar: Add function defs to fix Windows build errors.
Closes #3129
5
@cb0677b
09/10/17 21:11:19 |
Chris Johns |
Add Windows includes so the rtemstoolkit builds.
Closes #3128.
5
@f9a4b2c
08/26/17 08:15:58 |
cpodonnell8 |
covoar: Remove config file and test critical options are valid.
5
@4600903
08/26/17 08:15:57 |
cpodonnell8 |
covoar/CoverageReaderQEMU.cc: Remove trace block matching check.
This …
5
@6a4859e
08/26/17 08:15:56 |
cpodonnell8 |
covoar: Use rld tempfile and add signals to clean up in event of …
5
@4cee5c3
08/26/17 08:15:55 |
Krzysztof Miesowicz |
covoar/wscript: Add paths to rtemstoolkit to build.
Co-Author: …
5
@9534157
08/26/17 08:15:54 |
cpodonnell8 |
covoar/ObjdumpProcessor.cc: Remove jump tables from the end of …
5
@cb018bc
08/26/17 08:15:53 |
hermann19829 |
covoar: Add information to improve diagnostics.
5
@b857151
08/26/17 08:15:52 |
hermann19829 |
covoar: Fix buffer overflow and fix br tag in html report.
Co-Author: …
5
@05b4cfb
08/26/17 08:15:51 |
chouteau |
covoar/qemu-traces.h: Change to match current couverture-qemu file.
5
@67d48e2
08/26/17 08:15:50 |
cpodonnell8 |
rtemstoolkit/host.py: Change option to search parent directory in …
5
@fd0bcc5
08/22/17 14:54:48 |
Sebastian Huber |
tester: Add qoriq_e6500_64
Update #3082.
5
@f2bb439
08/20/17 07:19:06 |
Chris Johns |
rtemstoolkit/libiberty: Fix broken configure detection.
The file …
5
@78bbe4c
08/16/17 08:09:59 |
Chris Johns |
linkers/exe-info Support ARM static constructors.
Note, ARM …
5
@0ea1c27
08/07/17 06:01:59 |
Sebastian Huber |
tester: Add imx7
5
