source: rtems-tools
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @cb0677b   Sep 10, 2017, 9:11:19 PM Chris Johns Add Windows includes so the rtemstoolkit builds. Closes #3128.
(edit) @f9a4b2c   Aug 26, 2017, 8:15:58 AM cpodonnell8 covoar: Remove config file and test critical options are valid.
(edit) @4600903   Aug 26, 2017, 8:15:57 AM cpodonnell8 covoar/CoverageReaderQEMU.cc: Remove trace block matching check. This …
(edit) @6a4859e   Aug 26, 2017, 8:15:56 AM cpodonnell8 covoar: Use rld tempfile and add signals to clean up in event of …
(edit) @4cee5c3   Aug 26, 2017, 8:15:55 AM Krzysztof Miesowicz covoar/wscript: Add paths to rtemstoolkit to build. Co-Author: …
(edit) @9534157   Aug 26, 2017, 8:15:54 AM cpodonnell8 covoar/ObjdumpProcessor.cc: Remove jump tables from the end of …
(edit) @cb018bc   Aug 26, 2017, 8:15:53 AM hermann19829 covoar: Add information to improve diagnostics.
(edit) @b857151   Aug 26, 2017, 8:15:52 AM hermann19829 covoar: Fix buffer overflow and fix br tag in html report. Co-Author: …
(edit) @05b4cfb   Aug 26, 2017, 8:15:51 AM chouteau covoar/qemu-traces.h: Change to match current couverture-qemu file.
(edit) @67d48e2   Aug 26, 2017, 8:15:50 AM cpodonnell8 rtemstoolkit/host.py: Change option to search parent directory in …
(edit) @fd0bcc5   Aug 22, 2017, 2:54:48 PM Sebastian Huber tester: Add qoriq_e6500_64 Update #3082.
(edit) @f2bb439   Aug 20, 2017, 7:19:06 AM Chris Johns rtemstoolkit/libiberty: Fix broken configure detection. The file …
(edit) @78bbe4c   Aug 16, 2017, 8:09:59 AM Chris Johns linkers/exe-info Support ARM static constructors. Note, ARM …
(edit) @0ea1c27   Aug 7, 2017, 6:01:59 AM Sebastian Huber tester: Add imx7
(edit) @581b071   Jul 31, 2017, 2:29:48 PM joel rtems-bsps-i386.ini: Remove Edison
(edit) @738716d   Jul 31, 2017, 5:33:56 AM Sebastian Huber tester: Update BSP names
(edit) @9f72ea6   Jul 17, 2017, 8:42:42 AM Jiri Gaisler Added test scripts for standalone sis
(edit) @e37f132   Jul 10, 2017, 6:12:29 AM Sebastian Huber Add Newlib patch Original patch contains a Cygwin part which is not …
(edit) @50eb61d   Jun 12, 2017, 11:47:36 AM Sebastian Huber Add PR-ada-81070.diff
(edit) @d67c20a   May 31, 2017, 12:15:59 PM Chris Johns rtems-bsp-builder: Use the profile's architecture's BSP lists.
(edit) @718b230   May 31, 2017, 8:26:18 AM cpodonnell8 rtemstoolkit/rld-process.h: Include rld.h to find 'strings' definition
(edit) @37a0843   May 24, 2017, 2:27:38 AM Chris Johns rtems-bsp-builder: Refactor to add jobs. This change adds job support …
(edit) @4c24f40   May 24, 2017, 2:27:22 AM Chris Johns rtemstoolkit: Improve performance.
(edit) @52cfa18   May 24, 2017, 2:12:55 AM Chris Johns rtems-bsp-builder: Fix the powerpc configuration.
(edit) @61ddcfc   May 18, 2017, 5:22:43 AM Chris Johns rtems-bsp-builder: Add as a build type.
(edit) @ed80d2c   May 16, 2017, 6:43:19 AM Chris Johns rtemstoolkit: Add the configuration.py module to the install.
(edit) @ef38b5d   May 15, 2017, 1:48:44 AM Chris Johns rtemstoolkit: Add Python INI configuration support.
(edit) @9a8a03c   May 15, 2017, 1:29:46 AM Chris Johns rtems-bsp-builder: Add all architectures and BSPs. - Add support to …
(edit) @85e14e0   May 10, 2017, 11:09:02 AM Chris Johns rtems-bsp-builder: Fix excluding builds. Excluding builds was not …
(edit) @ad15f6b   Apr 27, 2017, 8:49:23 PM Chris Johns rtems-bsp-builder: Fix passes report alignment.
(edit) @096c95e   Apr 27, 2017, 8:36:32 PM Chris Johns rtems-bsp-tester: Make the failure and pass report more compact.
(edit) @fc22d2a   Apr 26, 2017, 12:07:15 PM Chris Johns rtems-bsp-builder: Fix time in warnings report, wrapping in reports. …
(edit) @c2df65b   Apr 26, 2017, 10:01:23 AM Chris Johns rtems-bsp-builder: Fix access when there are no messages.
(edit) @ab57e79   Apr 24, 2017, 11:32:18 PM Chris Johns rtems-test: Fix gdb bug.
(edit) @9e7ed07   Apr 24, 2017, 11:31:37 PM Chris Johns rtemstoolkit: Set proc buffering to 0 to not block on smaller reads.
(edit) @b89a7e4b   Apr 24, 2017, 10:40:19 PM Chris Johns rtems-bsp-builder: Fix the build sets excludes.
(edit) @5d1edd5   Apr 24, 2017, 4:39:56 PM Chris Johns rtems-bsp-builder: Refactor for better config format, warnings and …
(edit) @224fb21   Apr 24, 2017, 4:38:40 PM Chris Johns rtemstoolkit: Add a textbox module for formatted reporting.
(edit) @4370924   Apr 24, 2017, 2:32:53 PM Chris Johns execute: Use the io python module for output capture. This change …
(edit) @7d3350d   Apr 24, 2017, 2:31:44 PM Chris Johns rtemstoolkit: Move host support access into a separate module. Moving …
(edit) @15a3e06   Apr 4, 2017, 3:32:03 AM Chris Johns tester: Add support for expected-fail, user-input, and benchmarks. …
(edit) @5ca8bad   Apr 3, 2017, 10:24:06 AM Chris Johns waf: Upgrade to the latest release waf-1.9.9. This fixes build …
(edit) @bce090b   Mar 27, 2017, 11:20:14 PM Chris Johns rtems-bsp-builder: Fix the counts to accumulate.
(edit) @7ef4c2b   Mar 21, 2017, 2:55:19 PM Sebastian Huber patch: ARM: Fix IEEE-754 sqrt optimization Update #2948.
(edit) @d1f542f   Mar 21, 2017, 2:06:07 PM Sebastian Huber patch: ARM: Optimize IEEE-754 sqrt implementation Update #2948.
(edit) @056bd4b   Mar 15, 2017, 4:23:40 AM Chris Johns rtems-bsp-builder: Fix profile error message.
(edit) @e4b3143   Mar 15, 2017, 4:23:05 AM Chris Johns rtems-syms: Fix usage help.
(edit) @31e22e3   Jan 8, 2017, 10:05:18 PM Chris Johns libelf: Use minimal environment for C translation with readelf. The …
(edit) @516f931   Dec 23, 2016, 8:06:01 AM Sebastian Huber Add Newlib patch for RTEMS 4.12
(edit) @a72a462a   Dec 12, 2016, 10:56:25 PM Chris Johns bsp-builder: Fix final output errors.
(edit) @d3d771e   Nov 30, 2016, 11:21:13 PM Chris Johns bsp-builder: Add support for builds. Add build support where a build …
(edit) @8a7be63   Nov 29, 2016, 9:13:33 PM Chris Johns bsp-bulder: Get the end time when building an architecture.
(edit) @e2af743   Nov 15, 2016, 12:00:08 AM joel Add 4.12/.../gdb-7.11-sis-leon2-leon3.diff from gaisler.org
(edit) @b5caf21   Nov 14, 2016, 10:04:04 PM joel Add 4.12/.../binutils-2.26-gas-reloc.patch from gaisler.org
(edit) @4fdd883   Sep 2, 2016, 8:16:57 AM Chris Johns 4.10: Add NIOS2 newlib patch.
(edit) @32b861f   Sep 2, 2016, 8:03:11 AM Chris Johns 4.10: Add NIOS2 gcc patch.
(edit) @5af5b04   Sep 2, 2016, 7:56:09 AM Chris Johns 4.10: Add NIOS2 binutils patch.
(edit) @a46a8d3   Sep 2, 2016, 7:00:50 AM Chris Johns 4.10: Add FreeBSD Python patch.
(edit) @3f17371   Sep 2, 2016, 6:56:49 AM Chris Johns 4.10: Add the gdb-7.11 ERC patches to 4.10.
(edit) @3581fab   Sep 2, 2016, 3:18:17 AM Chris Johns 4.10: Add the automake patch to the 4.10 patches.
(edit) @a252faf   Aug 30, 2016, 8:10:17 AM Chris Johns bsp-builder: Results format fixes. 4.10
(edit) @06c3ccd   Aug 29, 2016, 1:47:04 AM Chris Johns bsp-builder: Fix bugs. 4.10
(edit) @e9fb4c5   Aug 25, 2016, 6:14:57 AM Chris Johns bsp-builder: Add lm3s6965_qemu to ARM bsp list. Fix network-debug options. 4.10
(edit) @f7f0704   Aug 25, 2016, 6:13:18 AM Chris Johns bsp-builder: Fix column printing of the arch/bsp. 4.10
(edit) @885aebd   Aug 25, 2016, 5:54:23 AM Chris Johns linkers/syms: Add weak symbols to the global symbol table. Add any … 4.10
(edit) @8e13939   Aug 19, 2016, 1:56:09 AM Chris Johns bsp-builder: Print one results report only. 4.10
(edit) @9a1daba   Aug 18, 2016, 11:55:03 PM Chris Johns bsp-builder: Fix results report columns. 4.10
(edit) @3a92a54   Aug 18, 2016, 11:00:50 AM Chris Johns bsp-builder: Add ARM bsps. 4.10
(edit) @51e19af   Aug 18, 2016, 11:00:29 AM Chris Johns bsp-builder: Support per BSP excludes. 4.10
(edit) @57e4172   Aug 18, 2016, 4:24:45 AM Chris Johns tester: handle compile argument warnings. 4.10
(edit) @1676b9c   Aug 18, 2016, 4:24:13 AM Chris Johns rtemstoolkit: Trace opening a macro file. 4.10
(edit) @3e14594   Jul 6, 2016, 7:58:56 AM Chris Johns Add rtems-bsp-builder. This is a testing tool that builds BSPs with a … 4.10
(edit) @6c94148   Apr 3, 2016, 6:26:36 AM Chris Johns linkers: Demangle the C++ labels in the .ctors/.dtors sections. Show … 4.10
(edit) @c81066f   Apr 3, 2016, 5:42:51 AM Chris Johns linkers: Add a tool to show RTEMS executable information. 4.10
(edit) @635a28f   Apr 3, 2016, 5:41:08 AM Chris Johns rtemstoolkit: Add a buffer helper class to insert and extract data. 4.10
(edit) @8dc2772   Apr 3, 2016, 5:39:58 AM Chris Johns rtemstoolkit: Add the address to the section. 4.10
(edit) @2e97351   Apr 3, 2016, 5:38:14 AM Chris Johns rtemstoolkit: Add an address table of symbols key by the symbol … 4.10
(edit) @0c0b2d4   Apr 3, 2016, 5:37:01 AM Chris Johns rtemstoolkit: Add version number parsing to get major, minor, … 4.10
(edit) @dfa2468   Mar 16, 2016, 10:39:39 AM Chris Johns tester: Fix reraising an exception with Python2 and Python3. Updates … 4.10
(edit) @4bcf18b   Mar 16, 2016, 5:22:35 AM Chris Johns tester/sis: Provide the -nouartrx to avoid blocking on stdin. 4.10
(edit) @1845e91   Mar 16, 2016, 5:21:57 AM Chris Johns tester: Provide a gdb kill method to aid clean ups on ctrl-C. 4.10
(edit) @0bbd2de   Mar 16, 2016, 4:18:34 AM Chris Johns 4.12: Patches for ERC simualtor for gdb-7.11. The patches fix the … 4.10
(edit) @6f8b07c   Mar 14, 2016, 3:59:11 AM Chris Johns rtemstoolkit: Fix execute's writer thread to not eval() the input. … 4.10
(edit) @a44fedf   Mar 11, 2016, 7:12:55 AM Chris Johns Add a gdb-7.11 patch for 4.12. 4.10
(edit) @87bca99   Jan 7, 2016, 2:14:29 PM pfeiffer Bugfix: gdb-7.3.1 couldn't be build with a modern texinfo package. … 4.10
(edit) @47ec083   Jan 7, 2016, 2:13:50 PM pfeiffer Bugfix: gcc-4.4.7 couldn't be build with a modern texinfo package. … 4.10
(edit) @45d2402   Jan 7, 2016, 2:13:05 PM pfeiffer Bugfix: binutils-2.20.1 couldn't be build with a modern texinfo … 4.10
(edit) @c9ed248   Mar 9, 2016, 3:34:26 AM Chris Johns Remove exception test code left in. Updates #2619. 4.10
(edit) @6fa359c   Mar 9, 2016, 3:29:14 AM Chris Johns Master branch version is 4.12. 4.10
(edit) @b7a9c81   Mar 9, 2016, 3:28:57 AM Chris Johns sis: Option not present with SPARC sim. 4.10
(edit) @2de37f3   Mar 9, 2016, 3:27:42 AM Chris Johns Python 2 and python 3 refactor fixes. Updates #2619. 4.10
(edit) @a5d243d   Mar 4, 2016, 1:10:09 AM Chris Johns tester: Remove the RT version.py and use the toolkit's version. 4.10
(edit) @b0fa2ae   Mar 3, 2016, 5:46:18 AM Chris Johns Update rtems-tool to support Python 2 and 3. Add solaris and netbsd. … 4.10
(edit) @0e5d89d   Feb 29, 2016, 7:02:36 AM Chris Johns Add aarch64 and x86_64 binutils and gdb patches. 4.10
(edit) @6bc1ece   Feb 28, 2016, 9:59:26 PM Chris Johns Fix ithe automake warning with newer perl versions. This patch is … 4.10
(edit) @3018e2f   Feb 20, 2016, 1:44:44 AM Chris Johns Do not change the Python os.sep setting. 4.10
(edit) @7148cae   Feb 19, 2016, 3:46:15 AM Chris Johns Add Windows specific waf support for MSYS2. Limit the compilers used … 4.10
(edit) @de1beea   Feb 19, 2016, 12:26:51 AM Chris Johns Disable installing PYO and PYC. Fix install paths. Installing PYO and … 4.10
(edit) @4351ae5   Feb 19, 2016, 12:25:50 AM Chris Johns Update the version of waf. Closes #2582. 4.10
(edit) @66c6301   Jan 8, 2016, 6:45:39 AM Sebastian Huber rtemstoolkit: Python 3 compatibility 4.10
