# # ChangeLog for / in rtems-tools # # Generated by Trac 1.2.1.dev0 # 04/25/24 10:57:29 Mon, 16 Apr 2018 01:55:01 GMT Chris Johns [ec419a0] * rtemstoolkit/rld-rap.cpp (modified) rtemstoolkit/rap: Ignore R_ARM_V4BX relocation records Note, this ... Sat, 14 Apr 2018 04:15:07 GMT Chris Johns [82c8788] * linkers/rtems-ld.cpp (modified) * linkers/rtems-ra.cpp (modified) * rtemstoolkit/rld-files.cpp (modified) * rtemstoolkit/rld-files.h (modified) * rtemstoolkit/rld-outputter.cpp (modified) * rtemstoolkit/rld-outputter.h (modified) rtemstoolkit/rtl-file: Remove a file on close if requested Close #3395 Tue, 10 Apr 2018 04:00:09 GMT Chris Johns [b7c4753] * tester/rt/test.py (modified) teater: Filter out an *.norun.* executables. Tue, 10 Apr 2018 03:59:43 GMT Chris Johns [cf641a6] * tester/rt/bsps.py (modified) tester: List .ini files for BSPs with --list-bsps. Tue, 10 Apr 2018 03:59:11 GMT Chris Johns [c5286cd] * wscript (modified) waf: Add getcwd() to sys.path as waf has changed. Tue, 10 Apr 2018 01:46:11 GMT Chris Johns [252d21c] * tester/rt/check.py (modified) bsp-builder: Collect2 messages are errors. Thu, 01 Feb 2018 18:48:21 GMT Joel Sherrill [6e468c7] * tester/rtems/rtems-bsps-powerpc.ini (modified) rtems-bsps-powerpc.ini: Add PowerPC qemu BSPs Wed, 31 Jan 2018 23:51:54 GMT Chris Johns [005f995] * tester/rt/check.py (modified) rtems-bsp-builder: Remove stray %s from the run log message. Close #3278 Wed, 31 Jan 2018 22:42:59 GMT Chris Johns [623a641] * tester/rt/check.py (modified) * tester/rtems/rtems-bsps-powerpc.ini (modified) rtems-bsp-builder: Add a check for invalid ARCH and BSP names. If ... Tue, 02 Jan 2018 22:59:31 GMT Joel Sherrill [0333442] * tester/covoar/covoar.cc (modified) tester/covoar/covoar.cc: Add missing throw keyword Why clang caught ... Tue, 05 Dec 2017 14:03:44 GMT Joel Sherrill [b516a58] * tester/covoar/covoar.cc (modified) tester/covoar/covoar.cc: Exit using exit() rather than just throwing. ... Tue, 05 Dec 2017 13:52:21 GMT Joel Sherrill [149144f] * tester/covoar/covoar.cc (modified) tester/covoar/covoar.cc: Clean up formatting (tabs, braces, ... Wed, 22 Nov 2017 10:32:20 GMT Sebastian Huber [c432d89] * tester/rtems/testing/bsps/qoriq_e6500_64.ini (added) Add tester qoriq_e6500_64.ini Wed, 22 Nov 2017 10:32:05 GMT Sebastian Huber [f010b51] * tester/rtems/testing/bsps/qoriq_e6500_32.ini (added) Add tester qoriq_e6500_32.ini Wed, 22 Nov 2017 09:31:23 GMT Sebastian Huber [2248c9a] * tester/rtems/rtems-bsps-tiers.ini (modified) Add imx7 and qoriq_e500 to tier-1 Tue, 21 Nov 2017 15:00:00 GMT Sebastian Huber [3ba9c03] * tester/rtems/testing/bsps/qoriq_e500.ini (added) Add tester qoriq_e500.ini Fri, 10 Nov 2017 08:42:23 GMT Sebastian Huber [3a32d15] * tools/WARNING (added) Add tool patches warning Update #2949. Sun, 05 Nov 2017 07:48:20 GMT Chris Johns [30218f5] * tester/rt/config.py (modified) * tester/rt/report.py (modified) * tester/rt/run.py (modified) * tester/rt/test.py (modified) tester: Add reporting the RTEMS version, build and tools. Update #3217. Fri, 10 Nov 2017 08:38:48 GMT Sebastian Huber [9f34b38] * tools/5/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff (deleted) * tools/5/binutils/binutils-2.26-gas-reloc.patch (deleted) * tools/5/binutils/binutils-2.26-rtems-aarch64-x86_64.patch (deleted) * tools/5/gdb/gdb-7.11-aarch64-x86_64.patch (deleted) * tools/5/gdb/gdb-7.11-erc32-common-run.diff (deleted) * tools/5/gdb/gdb-7.11-erc32-endian-fix.diff (deleted) * tools/5/gdb/gdb-7.11-erc32-printf_filtered.diff (deleted) * tools/5/gdb/gdb-7.11-sis-leon2-leon3.diff (deleted) * tools/5/gdb/gdb-7.9-aarch64-x86_64.patch (deleted) * tools/5/gdb/gdb-sim-arange-inline.diff (deleted) * tools/5/gdb/gdb-sim-cgen-inline.diff (deleted) * tools/5/gdb/patch-gdb-python-python-config.py (deleted) Remove tools/5 patches Update #3220. Thu, 09 Nov 2017 08:54:14 GMT Sebastian Huber [6f5cfad] * tester/rtems/testing/bsps/imx7.ini (added) Add tester imx7.ini Update #3090. Thu, 09 Nov 2017 08:41:34 GMT Sebastian Huber [469e362] * tools/5/gdb/gdb-7.11-erc32-common-run.diff (added) * tools/5/gdb/gdb-7.11-erc32-endian-fix.diff (added) * tools/5/gdb/gdb-7.11-erc32-printf_filtered.diff (added) * tools/5/gdb/gdb-7.11-sis-leon2-leon3.diff (added) * tools/5/gdb/patch-gdb-python-python-config.py (added) Add tools/5 patches Update #3220. Thu, 09 Nov 2017 08:35:29 GMT Sebastian Huber [a70b8e6] * tools/5/binutils/binutils-2.26-gas-reloc.patch (added) Add tools/5 patch Update #3220. Thu, 09 Nov 2017 08:25:43 GMT Sebastian Huber [52f3790] * tools/5/gdb/gdb-7.9-aarch64-x86_64.patch (added) Add tools/5 patch Update #3220. Thu, 09 Nov 2017 08:07:35 GMT Sebastian Huber [2da1356] * tools/5/binutils/binutils-2.26-rtems-aarch64-x86_64.patch (added) * tools/5/gdb/gdb-7.11-aarch64-x86_64.patch (added) * tools/5/gdb/gdb-sim-cgen-inline.diff (added) Add tools/5 patches Update #3220. Thu, 09 Nov 2017 08:05:14 GMT Sebastian Huber [b5a4b15] * tools/5/gdb/gdb-sim-arange-inline.diff (added) Add tools/5 patch Update #3220. Thu, 09 Nov 2017 07:44:21 GMT Sebastian Huber [aff8c47] * tools/5/automake/automake-1.12.6-bugzilla.redhat.com-1239379.diff (added) Add tools/5 patch Update #3220. Wed, 08 Nov 2017 08:46:25 GMT Sebastian Huber [e5dad3c] * rtemstoolkit/version.py (modified) * tester/rtems/version.cfg (modified) * wscript (modified) Change RTEMS version from 4.12 to 5 Update #3220. Sat, 04 Nov 2017 00:22:08 GMT Chris Johns [24d51f7] * tester/rt/report.py (modified) * tester/rt/test.py (modified) tester: Change the mail subject so it list by BSP in the archives. ... Fri, 03 Nov 2017 07:20:31 GMT Chris Johns [42e39d2] * tester/rt/config.py (modified) * tester/rt/test.py (modified) tester: Fix the output so the report end analysis works. Fri, 03 Nov 2017 06:57:37 GMT Chris Johns [c68beb8] * rtemstoolkit/host.py (modified) * tester/rt/config.py (modified) * tester/rt/run.py (added) * tester/rt/test.py (modified) * tester/rtems-run (added) * tester/wscript (modified) tester: Add the rtems-run command. Fri, 03 Nov 2017 06:56:48 GMT Chris Johns [7e85878] * tester/rtems/testing/bsps/xilinx_zynq_zedboard.ini (modified) tester: Make the mandatory items appear first. Wed, 01 Nov 2017 03:30:32 GMT Chris Johns [0fe3a4b] * tester/rt/check.py (modified) tester: Fix rtems-bsp-builder reporting bug Sat, 28 Oct 2017 02:45:23 GMT Hesham Almatary [35b9c0c] * tester/rtems/rtems-bsps-riscv32.ini (added) * tester/rtems/rtems-bsps-riscv64.ini (added) * tester/rtems/testing/bsps/riscv64_generic.ini (added) * tester/rtems/testing/bsps/riscv64_generic.mc (added) * tester/rtems/testing/bsps/riscv_generic.ini (added) * tester/rtems/testing/bsps/riscv_generic.mc (added) * tester/rtems/testing/spike.cfg (added) Tester - RISC-V: Add spike simulator and scripts/bsp for riscv ports ... Tue, 24 Oct 2017 23:21:22 GMT Chris Johns [bb218b6] * tester/rt/test.py (modified) tester: Minor fix to the test results mail. Tue, 24 Oct 2017 23:13:28 GMT Chris Johns [c73e030] * tester/rt/test.py (modified) tester: Check mail parameters early so users can fix. Tue, 24 Oct 2017 22:03:43 GMT Chris Johns [41d0c34] * tester/rt/test.py (modified) * tester/rtems/testing/bsps/arm1136jfs-run.ini (modified) * tester/rtems/testing/bsps/arm1136jfs.ini (modified) * tester/rtems/testing/bsps/arm1136js-run.ini (modified) * tester/rtems/testing/bsps/arm1136js.ini (modified) * tester/rtems/testing/bsps/arm7tdmi-run.ini (modified) * tester/rtems/testing/bsps/arm7tdmi.ini (modified) * tester/rtems/testing/bsps/arm920-run.ini (modified) * tester/rtems/testing/bsps/arm920.ini (modified) * tester/rtems/testing/bsps/armcortexa9-run.ini (modified) * tester/rtems/testing/bsps/armcortexa9.ini (modified) * tester/rtems/testing/bsps/beagleboardxm.ini (modified) * tester/rtems/testing/bsps/beagleboneblack.ini (modified) * tester/rtems/testing/bsps/bf537Stamp-run.ini (modified) * tester/rtems/testing/bsps/bf537Stamp.ini (modified) * tester/rtems/testing/bsps/erc32-run.ini (modified) * tester/rtems/testing/bsps/erc32-sis.ini (modified) * tester/rtems/testing/bsps/erc32.ini (modified) * tester/rtems/testing/bsps/generic_or1k.ini (modified) * tester/rtems/testing/bsps/h8sxsim-run.ini (modified) * tester/rtems/testing/bsps/h8sxsim.ini (modified) * tester/rtems/testing/bsps/jmr3904-run.ini (modified) * tester/rtems/testing/bsps/jmr3904.ini (modified) * tester/rtems/testing/bsps/leon2-run.ini (modified) * tester/rtems/testing/bsps/leon2-sis.ini (modified) * tester/rtems/testing/bsps/leon2.ini (modified) * tester/rtems/testing/bsps/leon3-run.ini (modified) * tester/rtems/testing/bsps/leon3-sis.ini (modified) * tester/rtems/testing/bsps/leon3.ini (modified) * tester/rtems/testing/bsps/leon3_tsim-run.ini (modified) * tester/rtems/testing/bsps/leon3_tsim.ini (modified) * tester/rtems/testing/bsps/lm32_evr_gdbsim-run.ini (modified) * tester/rtems/testing/bsps/lm32_evr_gdbsim.ini (modified) * tester/rtems/testing/bsps/m32csim-run.ini (modified) * tester/rtems/testing/bsps/m32csim.ini (modified) * tester/rtems/testing/bsps/mcf5235.ini (modified) * tester/rtems/testing/bsps/pc.ini (modified) * tester/rtems/testing/bsps/psim-run.ini (modified) * tester/rtems/testing/bsps/psim.ini (modified) * tester/rtems/testing/bsps/realview_pbx_a9_qemu.ini (modified) * tester/rtems/testing/bsps/simsh1-run.ini (modified) * tester/rtems/testing/bsps/simsh1.ini (modified) * tester/rtems/testing/bsps/simsh2-run.ini (modified) * tester/rtems/testing/bsps/simsh2.ini (modified) * tester/rtems/testing/bsps/simsh2e-run.ini (modified) * tester/rtems/testing/bsps/simsh2e.ini (modified) * tester/rtems/testing/bsps/simsh4-run.ini (modified) * tester/rtems/testing/bsps/simsh4.ini (modified) * tester/rtems/testing/bsps/sis-run.ini (modified) * tester/rtems/testing/bsps/sis.ini (modified) * tester/rtems/testing/bsps/v850e1sim-run.ini (modified) * tester/rtems/testing/bsps/v850e1sim.ini (modified) * tester/rtems/testing/bsps/v850e2sim-run.ini (modified) * tester/rtems/testing/bsps/v850e2sim.ini (modified) * tester/rtems/testing/bsps/v850e2v3sim-run.ini (modified) * tester/rtems/testing/bsps/v850e2v3sim.ini (modified) * tester/rtems/testing/bsps/v850esim-run.ini (modified) * tester/rtems/testing/bsps/v850esim.ini (modified) * tester/rtems/testing/bsps/v850essim-run.ini (modified) * tester/rtems/testing/bsps/v850essim.ini (modified) * tester/rtems/testing/bsps/v850sim-run.ini (modified) * tester/rtems/testing/bsps/v850sim.ini (modified) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.ini (modified) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.ini (modified) * tester/rtems/testing/bsps/xilinx_zynq_zc706.ini (modified) * tester/rtems/testing/bsps/xilinx_zynq_zc706_qemu.ini (modified) * tester/rtems/testing/bsps/xilinx_zynq_zedboard.ini (modified) tester: Add a BSP field to each BSP INI configuration section. The ... Tue, 24 Oct 2017 21:53:27 GMT Chris Johns [a248471] * rtemstoolkit/configuration.py (modified) rtemstoolkit: Remove test import for YAML. Closes #3204. Tue, 24 Oct 2017 10:35:21 GMT Chris Johns [bf58911] * rtemstoolkit/configuration.py (modified) * rtemstoolkit/macros.py (modified) * rtemstoolkit/path.py (modified) * tester/rt/config.py (modified) * tester/rt/report.py (modified) * tester/rt/test.py (modified) * tester/rtems/testing/bsps/arm1136jfs-run.ini (added) * tester/rtems/testing/bsps/arm1136jfs.ini (moved) * tester/rtems/testing/bsps/arm1136jfs.mc (deleted) * tester/rtems/testing/bsps/arm1136js-run.ini (added) * tester/rtems/testing/bsps/arm1136js.ini (moved) * tester/rtems/testing/bsps/arm1136js.mc (deleted) * tester/rtems/testing/bsps/arm7tdmi-run.ini (added) * tester/rtems/testing/bsps/arm7tdmi.ini (moved) * tester/rtems/testing/bsps/arm7tdmi.mc (deleted) * tester/rtems/testing/bsps/arm920-run.ini (moved) * tester/rtems/testing/bsps/arm920.ini (added) * tester/rtems/testing/bsps/arm920.mc (deleted) * tester/rtems/testing/bsps/armcortexa9-run.ini (moved) * tester/rtems/testing/bsps/armcortexa9.ini (added) * tester/rtems/testing/bsps/armcortexa9.mc (deleted) * tester/rtems/testing/bsps/beagleboardxm.ini (added) * tester/rtems/testing/bsps/beagleboardxm.mc (deleted) * tester/rtems/testing/bsps/beagleboneblack.ini (added) * tester/rtems/testing/bsps/beagleboneblack.mc (deleted) * tester/rtems/testing/bsps/bf537Stamp-run.ini (added) * tester/rtems/testing/bsps/bf537Stamp.ini (moved) * tester/rtems/testing/bsps/bf537Stamp.mc (deleted) * tester/rtems/testing/bsps/erc32-run.ini (moved) * tester/rtems/testing/bsps/erc32-sis.ini (added) * tester/rtems/testing/bsps/erc32.ini (moved) * tester/rtems/testing/bsps/erc32.mc (deleted) * tester/rtems/testing/bsps/generic_or1k.ini (moved) * tester/rtems/testing/bsps/h8sxsim-run.ini (added) * tester/rtems/testing/bsps/h8sxsim.ini (moved) * tester/rtems/testing/bsps/h8sxsim.mc (deleted) * tester/rtems/testing/bsps/jmr3904-run.ini (moved) * tester/rtems/testing/bsps/jmr3904.ini (moved) * tester/rtems/testing/bsps/leon2-run.ini (moved) * tester/rtems/testing/bsps/leon2-sis.ini (moved) * tester/rtems/testing/bsps/leon2.ini (added) * tester/rtems/testing/bsps/leon2.mc (deleted) * tester/rtems/testing/bsps/leon3-run.ini (moved) * tester/rtems/testing/bsps/leon3-sis.ini (added) * tester/rtems/testing/bsps/leon3.ini (moved) * tester/rtems/testing/bsps/leon3.mc (deleted) * tester/rtems/testing/bsps/leon3_tsim-run.ini (moved) * tester/rtems/testing/bsps/leon3_tsim.ini (added) * tester/rtems/testing/bsps/leon3_tsim.mc (deleted) * tester/rtems/testing/bsps/lm32_evr_gdbsim-run.ini (added) * tester/rtems/testing/bsps/lm32_evr_gdbsim-run.mc (deleted) * tester/rtems/testing/bsps/lm32_evr_gdbsim.ini (added) * tester/rtems/testing/bsps/lm32_evr_gdbsim.mc (deleted) * tester/rtems/testing/bsps/m32csim-run.ini (moved) * tester/rtems/testing/bsps/m32csim.ini (added) * tester/rtems/testing/bsps/m32csim.mc (deleted) * tester/rtems/testing/bsps/mcf5235.ini (added) * tester/rtems/testing/bsps/mcf5235.mc (deleted) * tester/rtems/testing/bsps/pc.ini (added) * tester/rtems/testing/bsps/pc.mc (deleted) * tester/rtems/testing/bsps/psim-run.ini (moved) * tester/rtems/testing/bsps/psim.ini (added) * tester/rtems/testing/bsps/psim.mc (deleted) * tester/rtems/testing/bsps/realview_pbx_a9_qemu.ini (moved) * tester/rtems/testing/bsps/simsh1-run.ini (moved) * tester/rtems/testing/bsps/simsh1.ini (added) * tester/rtems/testing/bsps/simsh1.mc (deleted) * tester/rtems/testing/bsps/simsh2-run.ini (moved) * tester/rtems/testing/bsps/simsh2.ini (added) * tester/rtems/testing/bsps/simsh2.mc (deleted) * tester/rtems/testing/bsps/simsh2e-run.ini (added) * tester/rtems/testing/bsps/simsh2e.ini (moved) * tester/rtems/testing/bsps/simsh2e.mc (deleted) * tester/rtems/testing/bsps/simsh4-run.ini (moved) * tester/rtems/testing/bsps/simsh4.ini (added) * tester/rtems/testing/bsps/simsh4.mc (deleted) * tester/rtems/testing/bsps/sis-run.ini (added) * tester/rtems/testing/bsps/sis.ini (moved) * tester/rtems/testing/bsps/sis.mc (deleted) * tester/rtems/testing/bsps/v850e1sim-run.ini (added) * tester/rtems/testing/bsps/v850e1sim.ini (moved) * tester/rtems/testing/bsps/v850e1sim.mc (deleted) * tester/rtems/testing/bsps/v850e2sim-run.ini (moved) * tester/rtems/testing/bsps/v850e2sim.ini (added) * tester/rtems/testing/bsps/v850e2sim.mc (deleted) * tester/rtems/testing/bsps/v850e2v3sim-run.ini (added) * tester/rtems/testing/bsps/v850e2v3sim.ini (moved) * tester/rtems/testing/bsps/v850e2v3sim.mc (deleted) * tester/rtems/testing/bsps/v850esim-run.ini (moved) * tester/rtems/testing/bsps/v850esim.ini (added) * tester/rtems/testing/bsps/v850esim.mc (deleted) * tester/rtems/testing/bsps/v850essim-run.ini (moved) * tester/rtems/testing/bsps/v850essim.ini (added) * tester/rtems/testing/bsps/v850essim.mc (deleted) * tester/rtems/testing/bsps/v850sim-run.ini (moved) * tester/rtems/testing/bsps/v850sim.ini (added) * tester/rtems/testing/bsps/v850sim.mc (deleted) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.ini (moved) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.ini (moved) * tester/rtems/testing/bsps/xilinx_zynq_zc706.ini (moved) * tester/rtems/testing/bsps/xilinx_zynq_zc706.mc (deleted) * tester/rtems/testing/bsps/xilinx_zynq_zc706_qemu.ini (added) * tester/rtems/testing/bsps/xilinx_zynq_zedboard.ini (added) * tester/rtems/testing/bsps/xilinx_zynq_zedboard.mc (deleted) * tester/rtems/testing/qemu.cfg (modified) tester: Refactor to use INI format files for BSP configurations. - ... Mon, 23 Oct 2017 04:22:34 GMT Chris Johns [5251361] * tester/rt/config.py (modified) * tester/rt/report.py (modified) * tester/rtems/testing/bsps/xilinx_zynq_zedboard.mc (modified) tester: Add an executable file name filter. The exe filter lets a ... Sun, 22 Oct 2017 07:09:39 GMT Chris Johns [7051ba5] * rtemstoolkit/mailer.py (modified) * tester/rt/check.py (modified) * tester/rtems/rtems-bsps-tiers.ini (modified) bsb-builder: Add email support, and config report types. Sat, 21 Oct 2017 06:05:00 GMT Chris Johns [b1d2db9] * tester/rtems/testing/bsps/beagleboneblack.mc (modified) * tester/rtems/testing/bsps/pc.mc (modified) * tester/rtems/testing/bsps/xilinx_zynq_zedboard.mc (modified) tester: Update BeagleBone Black, PC and Zedboard configurations. Sat, 21 Oct 2017 05:59:14 GMT Chris Johns [f1e8fd4] * tester/rt/config.py (modified) tester: Add pretest and posttest target commands with @ARCH@, @BSP@ ... Sat, 21 Oct 2017 05:10:22 GMT Chris Johns [cec5878] * tester/rt/test.py (modified) tester: Remove pass status messages from the email log posts. Sat, 21 Oct 2017 05:09:30 GMT Chris Johns [af6a54d] * tester/rt/config.py (modified) tester: Use a target ON command before the first test. Sat, 21 Oct 2017 05:09:00 GMT Chris Johns [ac679ba] * tester/rt/telnet.py (modified) tester: Print the host and port on error in telnet connect. Fri, 13 Oct 2017 16:31:47 GMT Chris Johns [0054585] * tester/covoar/wscript (modified) tester/covoar: Use standard waf modules for linking. Use the ... Thu, 12 Oct 2017 10:52:59 GMT Sebastian Huber [b76fa74] * linkers/rtems-score-coremutex.ini (deleted) * linkers/rtems-score-object.ini (modified) * linkers/rtems-score-thread.ini (modified) * linkers/rtems-score-threadq.ini (added) * linkers/rtems-score.ini (modified) * linkers/wscript (modified) linkers: Update due to API changes Update #3160. Wed, 11 Oct 2017 19:25:10 GMT Chris Johns [5e40b4a] * tester/rt/report.py (modified) tester: Fix excluded fails processing. Wed, 11 Oct 2017 19:13:47 GMT Chris Johns [89e8c2a] * tester/rt/report.py (modified) * tester/rt/test.py (modified) tester: Add support to email results. Wed, 11 Oct 2017 19:13:13 GMT Chris Johns [fce29b0] * tester/rt/config.py (modified) tester: Change the capture console prompt to avoid email reply ... Wed, 11 Oct 2017 19:11:16 GMT Chris Johns [dc5de5f] * rtemstoolkit/mailer.py (modified) rtemstoolkit: Update the mailer module to the option interface. Wed, 11 Oct 2017 19:09:52 GMT Chris Johns [7c032b0] * rtemstoolkit/log.py (modified) rtemstoolkit: Add a capture hook to logging. Wed, 11 Oct 2017 19:08:31 GMT Chris Johns [7f11670] * rtemstoolkit/options.py (modified) rtemstoolkit: Fix error message in options. Wed, 11 Oct 2017 11:50:52 GMT Chris Johns [b4b61b5] * tester/rtems/testing/bsps/pc.mc (added) testing: Add a PC BSP configuration. Wed, 11 Oct 2017 11:50:16 GMT Chris Johns [2d6d1c5] * tester/rtems/testing/bsps/beagleboneblack.mc (modified) * tester/rtems/testing/bsps/xilinx_zynq_zedboard.mc (modified) testing: Update BSP configurations. Wed, 11 Oct 2017 11:49:17 GMT Chris Johns [4b76b8e] * tester/rt/tftp.py (modified) testing: Generate console message on a second TFTP exe request. Wed, 11 Oct 2017 11:48:46 GMT Chris Johns [0eb8400] * tester/rt/report.py (modified) testing: Print the output after the result. Easier to find and review ... Tue, 10 Oct 2017 18:07:15 GMT Sebastian Huber [5df7c3c] * rtemstoolkit/wscript (modified) * tester/wscript (modified) Install missing files Tue, 10 Oct 2017 02:30:31 GMT Chris Johns [662e1f7] * tester/rt/config.py (modified) * tester/rt/test.py (modified) tester: Add a tester off to turn the target off when finished. ... Sat, 07 Oct 2017 07:57:24 GMT Chris Johns [9580804] * tester/rt/config.py (modified) * tester/rtems/testing/bsps/xilinx_zynq_zedboard.mc (modified) Add a target start and target reset to manage boards that do not boot ... Thu, 05 Oct 2017 03:24:11 GMT Chris Johns [68cbfc3] * tester/rtems/testing/bsps/xilinx_zynq_zedboard.mc (added) tester: Add Zedboard. Thu, 05 Oct 2017 03:21:33 GMT Chris Johns [2ae9b6d] * tester/rt/telnet.py (modified) tester: Telnet console reopens the connection if it fails or closes. ... Thu, 05 Oct 2017 03:21:01 GMT Chris Johns [0737b46] * tester/rt/config.py (modified) tester: Add a target reset regular expression to detect a reset. Thu, 21 Sep 2017 11:34:34 GMT Chris Johns [3c7cd05] * tester/rt/config.py (modified) tester: Fix the TFTP ok to kill deadlock. Thu, 21 Sep 2017 11:33:56 GMT Chris Johns [3ed65c0] * tester/rt/tftp.py (modified) Lower the step size for the TFTP timeout. Thu, 21 Sep 2017 08:26:20 GMT Chris Johns [3a867a4] * tester/rt/config.py (modified) * tester/rt/console.py (modified) * tester/rt/report.py (modified) * tester/rt/stty.py (modified) * tester/rt/telnet.py (added) * tester/rt/test.py (modified) * tester/rt/tftp.py (added) * tester/rt/tftpy/COPYING (added) * tester/rt/tftpy/README (added) * tester/rt/tftpy/TftpClient.py (added) * tester/rt/tftpy/TftpContexts.py (added) * tester/rt/tftpy/TftpPacketFactory.py (added) * tester/rt/tftpy/TftpPacketTypes.py (added) * tester/rt/tftpy/TftpServer.py (added) * tester/rt/tftpy/TftpShared.py (added) * tester/rt/tftpy/TftpStates.py (added) * tester/rt/tftpy/__init__.py (added) * tester/rtems/testing/bsps/beagleboneblack.mc (added) * tester/rtems/testing/tftp.cfg (added) Add TFTP as a back end option for testing. Add telnet as a console ... Thu, 21 Sep 2017 07:45:39 GMT Chris Johns [fa81491] * rtemstoolkit/__init__.py (modified) * rtemstoolkit/reraise.py (added) Move the reraise logic into the tool kit. Thu, 14 Sep 2017 23:05:38 GMT Joel Sherrill [875c071] * rtemstoolkit/rld-compression.cpp (modified) rtemstoolkit/rld-compression.cpp: Fix warning for comparing signed to ... Thu, 14 Sep 2017 23:04:55 GMT Joel Sherrill [f4378ea] * tester/covoar/DesiredSymbols.cc (modified) tester/covoar/DesiredSymbols.cc: Now compiles on Cygwin Thu, 14 Sep 2017 02:21:08 GMT Chris Johns [8e64821] * rtemstoolkit/rld-files.cpp (modified) rtemstoolkit: Remove throw from file::image destructor. Wed, 13 Sep 2017 15:45:30 GMT Cillian O'Donnell [f4773ac] * tester/covoar/DesiredSymbols.cc (modified) * tester/covoar/ReportsBase.cc (modified) * tester/covoar/TraceConverter.cc (modified) * tester/covoar/covoar.cc (modified) covoar: Add function defs to fix Windows build errors. Closes #3129 Sun, 10 Sep 2017 21:11:19 GMT Chris Johns [cb0677b] * tester/covoar/wscript (modified) Add Windows includes so the rtemstoolkit builds. Closes #3128. Sat, 26 Aug 2017 08:15:58 GMT Cillian O'Donnell [f9a4b2c] * tester/covoar/covoar.cc (modified) * tester/covoar/wscript (modified) covoar: Remove config file and test critical options are valid. Sat, 26 Aug 2017 08:15:57 GMT Cillian O'Donnell [4600903] * tester/covoar/CoverageReaderQEMU.cc (modified) covoar/CoverageReaderQEMU.cc: Remove trace block matching check. ... Sat, 26 Aug 2017 08:15:56 GMT Cillian O'Donnell [6a4859e] * tester/covoar/ObjdumpProcessor.cc (modified) * tester/covoar/ObjdumpProcessor.h (modified) * tester/covoar/TraceConverter.cc (modified) * tester/covoar/TraceReaderLogQEMU.cc (modified) * tester/covoar/TraceReaderLogQEMU.h (modified) * tester/covoar/TraceWriterQEMU.cc (modified) * tester/covoar/TraceWriterQEMU.h (modified) * tester/covoar/covoar.cc (modified) covoar: Use rld tempfile and add signals to clean up in event of ... Sat, 26 Aug 2017 08:15:55 GMT Krzysztof Miesowicz [4cee5c3] * tester/covoar/wscript (modified) covoar/wscript: Add paths to rtemstoolkit to build. Co-Author: ... Sat, 26 Aug 2017 08:15:54 GMT Cillian O'Donnell [9534157] * tester/covoar/ObjdumpProcessor.cc (modified) covoar/ObjdumpProcessor.cc: Remove jump tables from the end of ... Sat, 26 Aug 2017 08:15:53 GMT Hermann Felbinger [cb018bc] * tester/covoar/CoverageMap.cc (modified) * tester/covoar/CoverageMap.h (modified) * tester/covoar/CoverageMapBase.cc (modified) * tester/covoar/CoverageMapBase.h (modified) * tester/covoar/DesiredSymbols.cc (modified) * tester/covoar/DesiredSymbols.h (modified) * tester/covoar/ExecutableInfo.cc (modified) * tester/covoar/ExecutableInfo.h (modified) * tester/covoar/ObjdumpProcessor.cc (modified) covoar: Add information to improve diagnostics. Sat, 26 Aug 2017 08:15:52 GMT Hermann Felbinger [b857151] * tester/covoar/ReportsBase.cc (modified) * tester/covoar/ReportsHtml.cc (modified) covoar: Fix buffer overflow and fix br tag in html report. ... Sat, 26 Aug 2017 08:15:51 GMT Fabien Chouteau [05b4cfb] * tester/covoar/qemu-traces.h (modified) covoar/qemu-traces.h: Change to match current couverture-qemu file. Sat, 26 Aug 2017 08:15:50 GMT Cillian O'Donnell [67d48e2] * rtemstoolkit/host.py (modified) rtemstoolkit/host.py: Change option to search parent directory in ... Tue, 22 Aug 2017 14:54:48 GMT Sebastian Huber [fd0bcc5] * tester/rtems/rtems-bsps-powerpc.ini (modified) tester: Add qoriq_e6500_64 Update #3082. Sun, 20 Aug 2017 07:19:06 GMT Chris Johns [f2bb439] * rtemstoolkit/libiberty/libiberty.h (modified) rtemstoolkit/libiberty: Fix broken configure detection. The file ... Wed, 16 Aug 2017 08:09:59 GMT Chris Johns [78bbe4c] * linkers/rtems-exeinfo.cpp (modified) * rtemstoolkit/libiberty/ansidecl.h (modified) * rtemstoolkit/libiberty/concat.c (modified) * rtemstoolkit/libiberty/cp-demangle.c (modified) * rtemstoolkit/libiberty/cp-demangle.h (modified) * rtemstoolkit/libiberty/cplus-dem.c (modified) * rtemstoolkit/libiberty/d-demangle.c (added) * rtemstoolkit/libiberty/demangle.h (modified) * rtemstoolkit/libiberty/environ.h (added) * rtemstoolkit/libiberty/libiberty.h (modified) * rtemstoolkit/libiberty/make-temp-file.c (modified) * rtemstoolkit/libiberty/mkstemps.c (modified) * rtemstoolkit/libiberty/pex-common.c (modified) * rtemstoolkit/libiberty/pex-common.h (modified) * rtemstoolkit/libiberty/pex-djgpp.c (modified) * rtemstoolkit/libiberty/pex-msdos.c (modified) * rtemstoolkit/libiberty/pex-one.c (modified) * rtemstoolkit/libiberty/pex-unix.c (modified) * rtemstoolkit/libiberty/pex-win32.c (modified) * rtemstoolkit/libiberty/rust-demangle.c (added) * rtemstoolkit/libiberty/safe-ctype.c (modified) * rtemstoolkit/libiberty/safe-ctype.h (modified) * rtemstoolkit/libiberty/stpcpy.c (modified) * rtemstoolkit/libiberty/xmalloc.c (added) * rtemstoolkit/libiberty/xmemdup.c (added) * rtemstoolkit/libiberty/xstrdup.c (added) * rtemstoolkit/libiberty/xstrerror.c (added) * rtemstoolkit/rld-buffer.h (modified) * rtemstoolkit/rld-files.cpp (modified) * rtemstoolkit/rld-files.h (modified) * rtemstoolkit/rld-symbols.cpp (modified) * rtemstoolkit/rld-symbols.h (modified) * rtemstoolkit/wscript (modified) linkers/exe-info Support ARM static constructors. Note, ARM ... Mon, 07 Aug 2017 06:01:59 GMT Sebastian Huber [0ea1c27] * tester/rtems/rtems-bsps-arm.ini (modified) tester: Add imx7 Mon, 31 Jul 2017 14:29:48 GMT Joel Sherrill [581b071] * tester/rtems/rtems-bsps-i386.ini (modified) rtems-bsps-i386.ini: Remove Edison Mon, 31 Jul 2017 05:33:56 GMT Sebastian Huber [738716d] * tester/rtems/rtems-bsps-powerpc.ini (modified) tester: Update BSP names Mon, 17 Jul 2017 08:42:42 GMT Jiri Gaisler [9f72ea6] * tester/rtems/testing/bsps/erc32-sis.mc (added) * tester/rtems/testing/bsps/leon2-sis.mc (added) * tester/rtems/testing/bsps/leon3-sis.mc (added) Added test scripts for standalone sis Mon, 10 Jul 2017 06:12:29 GMT Sebastian Huber [e37f132] * tools/4.12/newlib/newlib-cygwin-git-461152e4ebd94f7d8b1e20f4cd1c704138ba2083.patch (added) Add Newlib patch Original patch contains a Cygwin part which is not ... Mon, 12 Jun 2017 11:47:36 GMT Sebastian Huber [50eb61d] * tools/4.12/gcc/PR-ada-81070.diff (added) Add PR-ada-81070.diff Wed, 31 May 2017 12:15:59 GMT Chris Johns [d67c20a] * tester/rt/check.py (modified) rtems-bsp-builder: Use the profile's architecture's BSP lists. Wed, 31 May 2017 08:26:18 GMT Cillian O'Donnell [718b230] * rtemstoolkit/rld-process.h (modified) rtemstoolkit/rld-process.h: Include rld.h to find 'strings' definition Wed, 24 May 2017 02:27:38 GMT Chris Johns [37a0843] * tester/rt/check.py (modified) rtems-bsp-builder: Refactor to add jobs. This change adds job ... Wed, 24 May 2017 02:27:22 GMT Chris Johns [4c24f40] * rtemstoolkit/log.py (modified) rtemstoolkit: Improve performance. Wed, 24 May 2017 02:12:55 GMT Chris Johns [52cfa18] * tester/rtems/rtems-bsps-powerpc.ini (modified) rtems-bsp-builder: Fix the powerpc configuration. Thu, 18 May 2017 05:22:43 GMT Chris Johns [61ddcfc] * tester/rtems/rtems-bsps.ini (modified) rtems-bsp-builder: Add as a build type. Tue, 16 May 2017 06:43:19 GMT Chris Johns [ed80d2c] * rtemstoolkit/wscript (modified) rtemstoolkit: Add the configuration.py module to the install. Mon, 15 May 2017 01:48:44 GMT Chris Johns [ef38b5d] * rtemstoolkit/configuration.py (added) * tester/rt/check.py (modified) rtemstoolkit: Add Python INI configuration support. Mon, 15 May 2017 01:29:46 GMT Chris Johns [9a8a03c] * tester/rt/check.py (modified) * tester/rtems/rtems-bsps-arm.ini (added) * tester/rtems/rtems-bsps-bfin.ini (added) * tester/rtems/rtems-bsps-epiphany.ini (added) * tester/rtems/rtems-bsps-i386.ini (added) * tester/rtems/rtems-bsps-lm32.ini (added) * tester/rtems/rtems-bsps-m32c.ini (added) * tester/rtems/rtems-bsps-m68k.ini (added) * tester/rtems/rtems-bsps-mips.ini (added) * tester/rtems/rtems-bsps-moxie.ini (added) * tester/rtems/rtems-bsps-nios2.ini (added) * tester/rtems/rtems-bsps-or1k.ini (added) * tester/rtems/rtems-bsps-powerpc.ini (added) * tester/rtems/rtems-bsps-sh.ini (added) * tester/rtems/rtems-bsps-sparc.ini (added) * tester/rtems/rtems-bsps-sparc64.ini (added) * tester/rtems/rtems-bsps-tiers.ini (added) * tester/rtems/rtems-bsps-v850.ini (added) * tester/rtems/rtems-bsps.ini (modified) rtems-bsp-builder: Add all architectures and BSPs. - Add support to ... Wed, 10 May 2017 11:09:02 GMT Chris Johns [85e14e0] * tester/rt/check.py (modified) * tester/rtems/rtems-bsps.ini (modified) rtems-bsp-builder: Fix excluding builds. Excluding builds was not ...
