# # ChangeLog for / in rtems-tools # # Generated by Trac 1.2.1.dev0 # 04/24/24 08:16:13 Mon, 08 Sep 2014 22:40:13 GMT Chris Johns [b7ad4a2] * linkers/rld.cpp (modified) * linkers/rld.h (modified) * linkers/rtems-ld.cpp (modified) * linkers/rtems-tld.cpp (modified) linkers: If no RTEMS path is provied see if the prefix can be used. Mon, 08 Sep 2014 22:20:41 GMT Chris Johns [6fb1409] * linkers/rld-config.cpp (modified) * linkers/rld-config.h (modified) * linkers/rtems-tld.cpp (modified) * linkers/rtld-base.ini (modified) rtems-tld: Add entry and exit trace support. Mon, 08 Sep 2014 09:29:41 GMT Chris Johns [2126ea7] * linkers/rtems-tld.cpp (modified) * linkers/rtld-base.ini (modified) rtems-tld: Generate arg and ret code in the wrapper. Mon, 08 Sep 2014 06:37:32 GMT Chris Johns [17c8364] * linkers/rld-path.cpp (modified) Fix building on CentOS 6.5. Mon, 08 Sep 2014 06:06:48 GMT Chris Johns [6506aa1] * linkers/rld-cc.cpp (modified) * linkers/rld-cc.h (modified) * linkers/rld-config.cpp (modified) * linkers/rld-config.h (modified) * linkers/rld-path.cpp (modified) * linkers/rld-path.h (modified) * linkers/rld.cpp (modified) * linkers/rld.h (modified) * linkers/rtems-ld.cpp (modified) * linkers/rtems-tld.cpp (modified) * linkers/wscript (modified) RTEMS trace linker builds trace applications. The trace linker ... Sun, 07 Sep 2014 04:31:18 GMT Chris Johns [b28e8b3] * linkers/rld-cc.cpp (modified) * linkers/rld-rtems.cpp (modified) * linkers/rld-rtems.h (modified) * linkers/rld.h (modified) * linkers/rtems-ld.cpp (modified) * linkers/rtems-tld.cpp (modified) Refactor the rld-rtems support to remove the globals. Sun, 07 Sep 2014 00:47:00 GMT Chris Johns [32cd4fc] * linkers/ (added) * linkers/rld-path.cpp (modified) * linkers/rld-path.h (modified) * linkers/rld-process.cpp (modified) * linkers/rld-process.h (modified) * linkers/rld.h (modified) * linkers/rtems-tld.cpp (modified) rtems-tld: Add --wrapper option to aid testing. The --wrapper ... Sun, 07 Sep 2014 00:45:36 GMT Chris Johns [3f5e31f] * linkers/libiberty/make-temp-file.c (modified) Chanhe the base temp file name to 'rld--'. Sat, 06 Sep 2014 11:59:25 GMT Chris Johns [c4c8218] * linkers/rtems-tld.cpp (modified) Fix rtems-ld to keep tmep files around while building. Sat, 06 Sep 2014 10:19:45 GMT Chris Johns [8807135] * linkers/rld-cc.cpp (modified) * linkers/rld-cc.h (modified) * linkers/rld-process.cpp (modified) * linkers/rld-process.h (modified) * linkers/rld-rtems.cpp (modified) * linkers/rtems-ld.cpp (modified) * linkers/rtems-ra.cpp (modified) * linkers/rtems-syms.cpp (modified) * linkers/rtems-tld.cpp (modified) * linkers/rtld-base.ini (modified) * linkers/test-trace-1.h (added) * linkers/test-trace-2.h (added) Refactor the CC flags. Fix the various linkers. The trace linker is ... Sat, 06 Sep 2014 10:19:08 GMT Chris Johns [a916fa4] * linkers/rld-path.cpp (modified) Fxi the split call. Sat, 06 Sep 2014 10:17:56 GMT Chris Johns [a72a9e35] * linkers/rld.cpp (modified) * linkers/rld.h (modified) Add a path str. Remove the duplicate split call. Sat, 06 Sep 2014 10:15:48 GMT Chris Johns [b233be7] * linkers/pkgconfig.cpp (modified) Trim the return value from a package file. Fri, 05 Sep 2014 08:18:11 GMT Chris Johns [31bf375] * linkers/rtems-ld.cpp (modified) * linkers/rtems-tld.cpp (modified) * linkers/wscript (modified) Remove march/mcpu and add RTEMS BSP and cflags support. Fri, 05 Sep 2014 08:16:40 GMT Chris Johns [7ccb6701] * linkers/rld-cc.cpp (modified) * linkers/rld-cc.h (modified) * linkers/rld-path.cpp (modified) * linkers/rld-path.h (modified) * linkers/rld-rtems.cpp (added) * linkers/rld-rtems.h (added) * linkers/rld.h (modified) Add support for RTEMS BSP or user supplied CFLAGS. Remove march/mcpu. ... Fri, 05 Sep 2014 08:10:46 GMT Chris Johns [2f48445] * linkers/pkgconfig.cpp (modified) * linkers/pkgconfig.h (modified) Return the requested label. This completes this code to a basic ... Mon, 01 Sep 2014 03:26:47 GMT Chris Johns [40fd7a0] * linkers/rld-cc.cpp (modified) * linkers/rld-cc.h (modified) * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) * linkers/rld-outputter.cpp (modified) * linkers/rld-path.cpp (added) * linkers/rld-path.h (added) * linkers/rld-process.cpp (modified) * linkers/rld-resolver.cpp (modified) * linkers/rtems-ld.cpp (modified) * linkers/rtems-ra.cpp (modified) * linkers/rtems-rapper.cpp (modified) * linkers/rtems-syms.cpp (modified) * linkers/rtems-tld.cpp (modified) * linkers/wscript (modified) rld: Split the file into a path module for path specific functions. ... Sat, 09 Aug 2014 12:32:50 GMT Peng Fan [e5165d2] * linkers/rtems-ld.cpp (modified) * linkers/rtems-ra.cpp (modified) * linkers/rtems-rapper.cpp (modified) Fix getopt_long usage When passing shorhand options, getopt_long ... Thu, 07 Aug 2014 08:15:06 GMT Chris Johns [097f1fd] * linkers/rld-config.cpp (modified) * linkers/rld-config.h (modified) * linkers/rld-rap.cpp (modified) * linkers/rld.h (modified) * linkers/rtems-tld.cpp (modified) * linkers/rtld-base.ini (modified) * linkers/test-trace.ini (modified) rtms-tld: Refactor the code to match a better configuration format. Tue, 05 Aug 2014 13:02:35 GMT Chris Johns [4fd758e] * linkers/rld.h (modified) * linkers/rtems-tld.cpp (modified) rtems-tld: Add wrapper support and start the generator coding. Tue, 05 Aug 2014 13:01:15 GMT Chris Johns [a136346] * linkers/rld-cc.cpp (modified) * linkers/rld-process.cpp (modified) * linkers/rld-process.h (modified) * linkers/rtems-ld.cpp (modified) * linkers/rtems-ra.cpp (modified) * linkers/rtems-rapper.cpp (modified) * linkers/rtems-syms.cpp (modified) Fix temporary file handling and add tempfile write support. Move ... Mon, 04 Aug 2014 05:09:39 GMT Chris Johns [058d502] * linkers/rld-config.cpp (modified) * linkers/rld-config.h (modified) * linkers/rld.h (modified) * linkers/rtems-tld.cpp (modified) * linkers/rtld-base.ini (added) * linkers/test-trace.ini (modified) rtems-tld: Add generator loading support. Sun, 03 Aug 2014 23:50:56 GMT Chris Johns [0a21024] * linkers/rld.h (modified) * linkers/rtems-tld.cpp (modified) * linkers/rtems.ini (modified) * linkers/test-trace.ini (modified) rtems-tld: Add recursive parsing of headers and defines. Sun, 03 Aug 2014 23:19:55 GMT Chris Johns [b6d7f5f] * linkers/rld-config.cpp (modified) * linkers/rld-config.h (modified) * linkers/rld.h (modified) * linkers/rtems-tld.cpp (modified) * linkers/rtems.ini (added) * linkers/test-fsigs.ini (deleted) * linkers/test-trace.ini (modified) rtems-tld: Add trace configuration support. Extend the ... Fri, 01 Aug 2014 06:44:32 GMT Chris Johns [ea29902] * linkers/ConvertUTF.c (added) * linkers/ConvertUTF.h (added) * linkers/SimpleIni.h (added) * linkers/rld-config.cpp (added) * linkers/rld-config.h (added) * linkers/rtems-tld.cpp (added) * linkers/test-fsigs.ini (added) * linkers/test-trace.ini (added) * linkers/wscript (modified) Add initial support for the RTEM Trace Linker. The RTEMS Trace ... Fri, 01 Aug 2014 06:47:11 GMT Chris Johns [2ce23a3] * linkers/rld-files.cpp (modified) * linkers/rld-outputter.cpp (modified) * linkers/rld-process.cpp (modified) Fix building on Windows with the latest MSVC. Remove some warnings. Thu, 24 Jul 2014 03:09:03 GMT Peng Fan [427acf3] * linkers/rld-outputter.cpp (modified) std::list should be sorted before unique std::list should be sorted ... Fri, 30 Aug 2013 13:42:58 GMT Peng Fan [53ed116] * linkers/rld-outputter.cpp (modified) * linkers/rld-outputter.h (modified) * linkers/rtems-ld.cpp (modified) * linkers/rtems-ra.cpp (added) * linkers/wscript (modified) Implement a new tool 'rtems-ra' rtems-ra supports converting an elf ... Sat, 24 Aug 2013 10:19:15 GMT Peng Fan [64309e0] * linkers/rld-rap.cpp (modified) Ignore common section and null(index 0) section Signed-off-by: Peng ... Sat, 24 Aug 2013 10:10:54 GMT Peng Fan [37a7a7c] * linkers/rld-outputter.cpp (modified) * linkers/rld-outputter.h (modified) * linkers/rtems-ld.cpp (modified) RA format support for rtems-ld 1. Automatically place object files ... Thu, 29 Aug 2013 11:41:23 GMT Peng Fan [5eb6604] * linkers/rld-elf-types.h (modified) * linkers/rld-elf.cpp (modified) * linkers/rld-files.cpp (modified) Fix archive writer 1. align to even address 2. Fix the use of ... Sun, 04 Aug 2013 14:35:42 GMT Peng Fan [59c3ebd] * linkers/rld-rap.cpp (modified) * linkers/rld-rap.h (modified) * linkers/rtems-ld.cpp (modified) * linkers/rtems-rapper.cpp (modified) Add rpath support Thu, 01 Aug 2013 08:15:07 GMT Peng Fan [347c9b5] * linkers/rld-rap.cpp (modified) * linkers/rtems-rapper.cpp (modified) Add section size for rap details Add elf section size to the ... Fri, 26 Jul 2013 09:45:01 GMT Peng Fan [39f48c9] * linkers/rld-rap.cpp (modified) * linkers/rld-rap.h (modified) * linkers/rtems-ld.cpp (modified) * linkers/rtems-rapper.cpp (modified) Add object file details to RAP format This change added the object ... Mon, 22 Jul 2013 01:44:15 GMT Peng Fan [76d3b89] * linkers/rld-rap.cpp (modified) collect 'STT_NOTYPE' symbols Sun, 21 Jul 2013 16:39:21 GMT Peng Fan [f291594] * linkers/rld-rap.cpp (modified) fix relocation records order Thu, 18 Jul 2013 03:05:02 GMT Peng Fan [c14133e] * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) * linkers/rld-rap.cpp (modified) Add support for relocations which reference local symbols ... Thu, 18 Jul 2013 02:53:18 GMT Peng Fan [e23ef3b] * linkers/rld-rap.cpp (modified) Fixed fsec If one object file contains .rodata and .rodata.str1.4 ... Thu, 18 Jul 2013 02:49:09 GMT Peng Fan [4b31ced] * linkers/rld-rap.cpp (modified) Fixed layout problem Fixed when only one elf object file is passed ... Thu, 18 Jul 2013 23:32:41 GMT Peng Fan [f4cf8f4] * linkers/rld-elf.cpp (modified) arch specific section support Fri, 01 Mar 2013 04:42:08 GMT Chris Johns [26b46b1] * linkers/rld-rap.cpp (modified) * linkers/rtems-rapper.cpp (modified) Fix RELA in RAP formats. Fixed the RELA handling in the merging of ... Fri, 01 Mar 2013 02:58:56 GMT Chris Johns [69a123b] * linkers/rtems-ld.cpp (modified) Support the gcc option '-Wl'. Support and ignore the '-Wl,options' ... Fri, 01 Mar 2013 00:51:37 GMT Chris Johns [6c4218b] * linkers/rtems-ld.cpp (modified) * linkers/rtems-rapper.cpp (modified) * linkers/rtems-syms.cpp (modified) Fix the trace help. Fri, 01 Mar 2013 00:25:48 GMT Chris Johns [6fae4de] * linkers/rld-rap.cpp (modified) * linkers/rtems-rapper.cpp (modified) * linkers/rtems-utils.h (modified) Fix errors building on CentOS. Wed, 23 Jan 2013 03:04:11 GMT Chris Johns [2bcaf0c] * linkers/rld-files.h (modified) Update the documentation Tue, 22 Jan 2013 11:08:09 GMT Chris Johns [e78e2b0] * linkers/main-page.cpp (added) * linkers/rld-compression.h (modified) * linkers/rld-elf.h (modified) * linkers/rld-files.h (modified) * linkers/rld-outputter.h (modified) * linkers/rld-rap.h (modified) * linkers/rtems-utils.h (modified) * linkers/rtl-host.conf (modified) * linkers/wscript (modified) Documentation. Tue, 15 Jan 2013 06:03:04 GMT Chris Johns [32d5401] * linkers/rtems-rapper.cpp (modified) Fixed the layout output to give to all the needed detail. Tue, 01 Jan 2013 01:04:24 GMT Chris Johns [6801aa2] * linkers/rld-rap.cpp (modified) Use find_in_strtab when collecting symbols. Remove debug. Mon, 31 Dec 2012 07:29:10 GMT Chris Johns [f43851a] * linkers/rld-rap.cpp (modified) Sort the relocation records by offset for a section. Mon, 31 Dec 2012 07:12:25 GMT Chris Johns [4e7ec70] * linkers/rld-rap.cpp (modified) Make layout offsets match image offsets. Add a better strtab search. ... Mon, 31 Dec 2012 07:11:47 GMT Chris Johns [06a2cf6] * linkers/rtems-rapper.cpp (modified) Sort the relocations by offset to make the overlay work. Fri, 28 Dec 2012 23:20:22 GMT Chris Johns [544de91] * linkers/rld-elf.cpp (modified) * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) * linkers/rld-outputter.cpp (modified) * linkers/rld-resolver.cpp (modified) * linkers/rld-resolver.h (modified) * linkers/rld-symbols.cpp (modified) * linkers/rld-symbols.h (modified) * linkers/rtems-ld.cpp (modified) Fix managing weak symbols. Weak symbols where not being managed ... Mon, 24 Dec 2012 06:18:23 GMT Chris Johns [800d4fd] * linkers/rld-rap.cpp (modified) Add the symsect offset to the section reloc. Mon, 24 Dec 2012 06:17:53 GMT Chris Johns [073d244] * linkers/rtems-rapper.cpp (modified) Trace the reloc addend. Sun, 23 Dec 2012 06:45:34 GMT Chris Johns [f31cded] * linkers/rld-rap.cpp (modified) Improved section trace output. Moved the section trace output to ... Sun, 23 Dec 2012 06:04:11 GMT Chris Johns [5825009] * linkers/rtems-rapper.cpp (modified) Change the long opt from map to overlay. Sun, 23 Dec 2012 05:57:35 GMT Chris Johns [287569c] * linkers/rtems-rapper.cpp (modified) Add an overlay output. An overlay shows the hex dump of the section ... Sun, 23 Dec 2012 05:54:59 GMT Chris Johns [b9f631e] * linkers/rtems-utils.cpp (added) * linkers/rtems-utils.h (added) * linkers/wscript (modified) Add a memory dump utility. Fri, 21 Dec 2012 06:14:50 GMT Chris Johns [3e902c6] * linkers/rtems-rapper.cpp (modified) Fix the reloc symbol name. Fri, 21 Dec 2012 06:12:07 GMT Chris Johns [c487356] * linkers/rtems-rapper.cpp (modified) Finish a dump of the RAP file. Fix expanding. Fri, 21 Dec 2012 06:10:18 GMT Chris Johns [6c28ffb] * linkers/rld-outputter.cpp (modified) * linkers/rld-rap.cpp (modified) * linkers/rld-rap.h (modified) Set header length. Make sections public. Set the compressed file ... Fri, 21 Dec 2012 06:08:17 GMT Chris Johns [4e9b324] * linkers/rld-compression.cpp (modified) * linkers/rld-compression.h (modified) Decompressor fixes. Make reading compressed files more robust ... Wed, 19 Dec 2012 05:24:48 GMT Chris Johns [74e89db] * linkers/rld-compression.cpp (modified) Turn off the debug. Wed, 19 Dec 2012 05:24:24 GMT Chris Johns [8bb0d53] * linkers/rtems-rapper.cpp (added) * linkers/wscript (modified) RAP file utility. Decompressors RAP files. Wed, 19 Dec 2012 05:22:37 GMT Chris Johns [db216fe] * linkers/rld-compression.cpp (modified) * linkers/rld-compression.h (modified) Decompression support added. The compressor can now decompress LZ77 ... Tue, 18 Dec 2012 09:57:00 GMT Chris Johns [b2b811c] * linkers/rld-rap.cpp (modified) Fixes to load libbsdports on i386. Numerous fixes to load the the ... Tue, 18 Dec 2012 09:52:18 GMT Chris Johns [53221a0] * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) Add object::get_section. Add a method to return a section given the ... Tue, 18 Dec 2012 09:51:41 GMT Chris Johns [b5a59dd] * linkers/rtems-ld.cpp (modified) Use cerr for errors and not cout. Tue, 18 Dec 2012 09:48:35 GMT Chris Johns [194160c] * linkers/rld-compression.cpp (modified) Update the data out pointer. The data pointer was not updating when ... Tue, 18 Dec 2012 09:47:27 GMT Chris Johns [13b9f2b] * linkers/rld.h (modified) Add a new trace level. Sat, 15 Dec 2012 12:30:46 GMT Chris Johns [f10123a] * linkers/rld-rap.cpp (modified) Const sections are not PROGBITS and ALLOC and not EXECINTR or WRITE. Sat, 15 Dec 2012 12:19:21 GMT Chris Johns [d54e81c] * linkers/rld-elf.cpp (modified) * linkers/rld-files.cpp (modified) * linkers/rld-rap.cpp (modified) * linkers/rld-symbols.cpp (modified) Debug trace changes. Sat, 15 Dec 2012 11:44:58 GMT Chris Johns [b89ad2c6] * linkers/rld-elf.cpp (modified) * linkers/rld-rap.cpp (modified) * linkers/rld-resolver.cpp (modified) * linkers/rld-symbols.cpp (modified) i386 related fixes Fix the size of the section calculated in ... Wed, 12 Dec 2012 23:07:32 GMT Chris Johns [f4d580b] * linkers/rld-rap.cpp (modified) Add the section offset to the symbol value. Wed, 12 Dec 2012 10:51:03 GMT Chris Johns [42f766f] * linkers/rld-elf.cpp (modified) * linkers/rld-elf.h (modified) * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) * linkers/rld-rap.cpp (modified) Relocation fixes. These changes implement a suitable relocation ... Fri, 07 Dec 2012 22:07:30 GMT Chris Johns [90d8d43] * linkers/rld-elf-types.h (modified) * linkers/rld-elf.cpp (modified) * linkers/rld-elf.h (modified) * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) * linkers/rld-rap.cpp (modified) * linkers/rld-symbols.cpp (modified) * linkers/rld-symbols.h (modified) Add support to demand load relocation records. Support has been ... Fri, 07 Dec 2012 22:05:12 GMT Chris Johns [be8e188] * linkers/.gitignore (modified) * linkers/rtl-host.conf (added) * linkers/waf-tools/doxygen.py (added) * linkers/wscript (modified) Add doxygen support. Sat, 01 Dec 2012 10:22:24 GMT Chris Johns [825a10e] * linkers/rld-rap.cpp (modified) The symbol string is the offset into the symbol table. Fri, 30 Nov 2012 21:09:02 GMT Chris Johns [9ba89e1] * linkers/rld-rap.cpp (modified) Remove the trace on hack. Fri, 30 Nov 2012 21:05:47 GMT Chris Johns [803c60a] * linkers/rld-outputter.cpp (modified) * linkers/rld-rap.cpp (modified) * linkers/rld-rap.h (modified) RAP format up to relocation records completed. Do not write the ... Thu, 29 Nov 2012 08:05:19 GMT Chris Johns [1a5bdef] * linkers/rld-rap.cpp (modified) Add support for a custom RAP file format. The file is a header and ... Thu, 29 Nov 2012 08:04:12 GMT Chris Johns [93e80d5] * linkers/rld-compression.cpp (modified) * linkers/rld-compression.h (modified) Compress as blocks. The LZ77 compressor works with blocks. Each ... Thu, 29 Nov 2012 08:03:37 GMT Chris Johns [9c70d15] * linkers/rld-outputter.cpp (modified) Remove the \0 character after the header. Thu, 29 Nov 2012 08:02:28 GMT Chris Johns [662c504] * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) Add the index to the section. The index is referenced in the symbol ... Thu, 29 Nov 2012 08:01:43 GMT Chris Johns [ea6f8d4] * linkers/rld-symbols.cpp (modified) * linkers/rld-symbols.h (modified) Add access to the value and info fields of a symbols. Tue, 27 Nov 2012 00:19:15 GMT Chris Johns [dc1c744] * linkers/rld-rap.cpp (modified) Add machine related data to allow better checking. Tue, 27 Nov 2012 00:17:02 GMT Chris Johns [d99913f] * linkers/rld-compression.h (modified) Remove size_t stream operator. On Darwin the operator works which ... Mon, 26 Nov 2012 01:14:06 GMT Chris Johns [8190102] * linkers/rtems-syms.cpp (modified) Update to the latest framwork requirements. Mon, 26 Nov 2012 00:50:21 GMT Chris Johns [ae353d3] * linkers/rld-rap.cpp (modified) * linkers/rld-rap.h (modified) Comment clean up. Mon, 26 Nov 2012 00:09:35 GMT Chris Johns [eb825b1] * linkers/rld-rap.cpp (added) * linkers/rld-rap.h (added) * linkers/wscript (modified) Add RAP format support. Mon, 26 Nov 2012 00:09:06 GMT Chris Johns [cad8b53] * linkers/rtems-ld.cpp (modified) Updated to reflect the framework changes. Mon, 26 Nov 2012 00:07:06 GMT Chris Johns [a458e27] * linkers/rld-outputter.cpp (modified) * linkers/rld-outputter.h (modified) Add exit label, ELF application and Application. Add an exit label ... Mon, 26 Nov 2012 00:04:57 GMT Chris Johns [076d935] * linkers/rld-compression.cpp (modified) * linkers/rld-compression.h (modified) Add writing from images as well as streaming operators. Add the ... Mon, 26 Nov 2012 00:00:34 GMT Chris Johns [a5fcdd5] * linkers/rld-files.cpp (modified) * linkers/rld-files.h (modified) No archive begin/end on symbols load, image initialise fix, add ... Sun, 25 Nov 2012 23:59:19 GMT Chris Johns [4c89c2d] * linkers/rld-elf.h (modified) Update the section details. Sun, 25 Nov 2012 23:57:29 GMT Chris Johns [c6b714f] * linkers/rld-elf.cpp (modified) Load the sections by default. It is not much extra overhead. Clean ... Sun, 25 Nov 2012 23:46:40 GMT Chris Johns [1d60a4a] * linkers/rld.h (modified) Split trace to have without and with symbols. Thu, 22 Nov 2012 05:22:22 GMT Chris Johns [3f37835] * linkers/rld-compression.cpp (added) * linkers/rld-compression.h (added) * linkers/rld-outputter.cpp (modified) * linkers/wscript (modified) Split out the compression code for reuse. Wed, 21 Nov 2012 06:40:44 GMT Chris Johns [c2657cd] * linkers/rld-outputter.cpp (modified) Clean archive names for every output format other than scripts. Wed, 21 Nov 2012 02:36:32 GMT Chris Johns [7b2762f] * linkers/rtems-ld.cpp (modified) Make the entry point an unresolved symbol.
