# # ChangeLog for / in rtems-tools # # Generated by Trac 1.2.1.dev0 # 04/19/24 22:53:53 Tue, 09 Jul 2013 16:51:27 GMT Dhananjay Balan [6e75f4e] * tools/gdb/python/README.md (modified) Update readme. Included useage instructions. Tue, 09 Jul 2013 09:07:20 GMT Dhananjay Balan [3856406] * tools/gdb/python/classic.py (modified) * tools/gdb/python/objects.py (modified) Fix pretty printers pretty printers for rtems_id and rtems_attribute Mon, 08 Jul 2013 16:12:48 GMT Dhananjay Balan [f814c76] * tools/gdb/python/classic.py (modified) * tools/gdb/python/rtems.py (modified) Messege Queue Objects Added intial support for printing Mon, 08 Jul 2013 16:10:21 GMT Dhananjay Balan [ce55b57] * tools/gdb/python/objects.py (modified) Object can have index from 1 to 'maximum' Mon, 24 Jun 2013 04:10:59 GMT Dhananjay Balan [10bcd5d] * tools/gdb/python/chains.py (modified) * tools/gdb/python/objects.py (modified) * tools/gdb/python/threads.py (modified) Update chains structures - Fixes chains structure parsing - Fix ... Mon, 17 Jun 2013 17:10:17 GMT Dhananjay Balan [56a70ae] * tools/gdb/python/__init__.py (added) * tools/gdb/python/chains.py (added) * tools/gdb/python/classic.py (added) * tools/gdb/python/objects.py (added) * tools/gdb/python/rtems.py (added) * tools/gdb/python/threads.py (added) * tools/gdb/python/watchdog.py (added) Intial commit. Chris's intial work on the extenstions. Mon, 17 Jun 2013 15:31:09 GMT Dhananjay Balan [911e710] * tools/gdb/python/.gitignore (added) * tools/gdb/python/README.md (added) Initial commit Mon, 07 Jul 2014 21:23:47 GMT Joel Sherrill [8101cf0] * tools/4.11/newlib/newlib-sys-cpuset-const-20140414.diff (added) Add newlib-sys-cpuset-const-20140414.diff Mon, 23 Jun 2014 01:00:30 GMT Chris Johns [8cfeec3] * tools/4.11/net-snmp/rtems-net-snmp-5.7.2.1-20140623.patch (added) 4.11: Patch so net-snmp 5.7.2.1 builds with RTEMS. Fri, 09 May 2014 11:50:37 GMT Chris Johns [100f517] * tester/covoar/.gitignore (added) * tester/covoar/05_ascending.gif (added) * tester/covoar/05_descending.gif (added) * tester/covoar/05_unsorted.gif (added) * tester/covoar/ConfigFile.cc (added) * tester/covoar/ConfigFile.h (added) * tester/covoar/CoverageFactory.cc (added) * tester/covoar/CoverageFactory.h (added) * tester/covoar/CoverageMap.cc (added) * tester/covoar/CoverageMap.h (added) * tester/covoar/CoverageMapBase.cc (added) * tester/covoar/CoverageMapBase.h (added) * tester/covoar/CoverageRanges.cc (added) * tester/covoar/CoverageRanges.h (added) * tester/covoar/CoverageReaderBase.cc (added) * tester/covoar/CoverageReaderBase.h (added) * tester/covoar/CoverageReaderQEMU.cc (added) * tester/covoar/CoverageReaderQEMU.h (added) * tester/covoar/CoverageReaderRTEMS.cc (added) * tester/covoar/CoverageReaderRTEMS.h (added) * tester/covoar/CoverageReaderSkyeye.cc (added) * tester/covoar/CoverageReaderSkyeye.h (added) * tester/covoar/CoverageReaderTSIM.cc (added) * tester/covoar/CoverageReaderTSIM.h (added) * tester/covoar/CoverageWriterBase.cc (added) * tester/covoar/CoverageWriterBase.h (added) * tester/covoar/CoverageWriterRTEMS.cc (added) * tester/covoar/CoverageWriterRTEMS.h (added) * tester/covoar/CoverageWriterSkyeye.cc (added) * tester/covoar/CoverageWriterSkyeye.h (added) * tester/covoar/CoverageWriterTSIM.cc (added) * tester/covoar/CoverageWriterTSIM.h (added) * tester/covoar/DesiredSymbols.cc (added) * tester/covoar/DesiredSymbols.h (added) * tester/covoar/Doxyfile (added) * tester/covoar/ExecutableInfo.cc (added) * tester/covoar/ExecutableInfo.h (added) * tester/covoar/Explanations.cc (added) * tester/covoar/Explanations.h (added) * tester/covoar/GcovData.cc (added) * tester/covoar/GcovData.h (added) * tester/covoar/GcovFunctionData.cc (added) * tester/covoar/GcovFunctionData.h (added) * tester/covoar/Makefile (added) * tester/covoar/ObjdumpProcessor.cc (added) * tester/covoar/ObjdumpProcessor.h (added) * tester/covoar/ReportsBase.cc (added) * tester/covoar/ReportsBase.h (added) * tester/covoar/ReportsHtml.cc (added) * tester/covoar/ReportsHtml.h (added) * tester/covoar/ReportsText.cc (added) * tester/covoar/ReportsText.h (added) * tester/covoar/SymbolTable.cc (added) * tester/covoar/SymbolTable.h (added) * tester/covoar/TargetBase.cc (added) * tester/covoar/TargetBase.h (added) * tester/covoar/TargetFactory.cc (added) * tester/covoar/TargetFactory.h (added) * tester/covoar/Target_arm.cc (added) * tester/covoar/Target_arm.h (added) * tester/covoar/Target_i386.cc (added) * tester/covoar/Target_i386.h (added) * tester/covoar/Target_lm32.cc (added) * tester/covoar/Target_lm32.h (added) * tester/covoar/Target_m68k.cc (added) * tester/covoar/Target_m68k.h (added) * tester/covoar/Target_powerpc.cc (added) * tester/covoar/Target_powerpc.h (added) * tester/covoar/Target_sparc.cc (added) * tester/covoar/Target_sparc.h (added) * tester/covoar/TraceConverter.cc (added) * tester/covoar/TraceList.cc (added) * tester/covoar/TraceList.h (added) * tester/covoar/TraceReaderBase.cc (added) * tester/covoar/TraceReaderBase.h (added) * tester/covoar/TraceReaderLogQEMU.cc (added) * tester/covoar/TraceReaderLogQEMU.h (added) * tester/covoar/TraceWriterBase.cc (added) * tester/covoar/TraceWriterBase.h (added) * tester/covoar/TraceWriterQEMU.cc (added) * tester/covoar/TraceWriterQEMU.h (added) * tester/covoar/app_common.cc (added) * tester/covoar/app_common.h (added) * tester/covoar/configFile.txt (added) * tester/covoar/configfile_test.cc (added) * tester/covoar/coverage_converter.cc (added) * tester/covoar/covmerge.cc (added) * tester/covoar/covoar.cc (added) * tester/covoar/covoar.css (added) * tester/covoar/covoar_flow.doc (added) * tester/covoar/filter.gif (added) * tester/covoar/mkExplanation (added) * tester/covoar/qemu-dump-trace.c (added) * tester/covoar/qemu-log.h (added) * tester/covoar/qemu-traces.h (added) * tester/covoar/rtemscov_header.h (added) * tester/covoar/skyeye_header.h (added) * tester/covoar/table.js (added) * tester/covoar/wscript (added) covoar: Merger the covoar source from rtems-testing.git. Use waf to ... Mon, 16 Jun 2014 03:11:28 GMT Chris Johns [f25fed3] * tools/4.11/ntp/rtems-ntp-4.2.6p5.diff (added) 4.11: Add ntp patch. This patch has issues related to the clock ... Mon, 09 Jun 2014 23:41:47 GMT Chris Johns [c8f4ba6] * doc/rtems-tester.txt (modified) rt: Update the documentation. Sun, 01 Jun 2014 06:15:28 GMT Chris Johns [984b06d] * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.mc (modified) config: Fix the name for the xilinx_zynq_a9_qemu bsp. Sun, 01 Jun 2014 04:46:50 GMT Chris Johns [8fac58f] * tester/rtems/testing/bsps/arm920.mc (added) config: Add support for the gdbarmsim for the arm920 BSP. Sun, 01 Jun 2014 04:46:11 GMT Chris Johns [288d633] * tester/rtems/testing/bsps/realview_pbx_a9_qemu.mc (modified) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.mc (modified) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.mc (modified) * tester/rtems/testing/bsps/xilinx_zynq_zc706_qemu.mc (added) * tester/rtems/testing/qemu.cfg (modified) config: Clean up the qemu configurations. Sun, 01 Jun 2014 04:43:03 GMT Chris Johns [60937e1] * tester/rt/config.py (modified) test: Strengthen the timeout handling by killing the process. Sat, 31 May 2014 10:03:05 GMT Chris Johns [c04a849] * rtemstoolkit/execute.py (modified) * rtemstoolkit/stacktraces.py (added) * tester/rt/bsps.py (added) * tester/rt/config.py (modified) * tester/rt/test.py (modified) tester: Correctly handle contro-c. Add support to kill running ... Mon, 19 May 2014 02:49:52 GMT Chris Johns [5cdcde1] * tools/4.11/gdb/sparc/gdb-7.7-sis-output-nouartrx.diff (added) 4.11/sparc: GDB 7.7 SIS simulator output patch. Wed, 14 May 2014 23:36:29 GMT Joel Sherrill [ab131bb] * tester/rtems/testing/bsps/jmr3904-run.mc (added) * tester/rtems/testing/bsps/jmr3904.mc (added) Add jmr3904 GDB simulator support Sun, 11 May 2014 23:43:59 GMT Kumar Amit Mehta [a28e562] * doc/rtems-tester.txt (modified) doc: rtems-tester.txt: Add information for building tests The test ... Sun, 27 Apr 2014 17:35:01 GMT Ben Gras [803b63d] * tester/rt/test.py (modified) add --filter to specify the set of selected tests. . parameter is ... Thu, 08 May 2014 12:39:07 GMT Chris Johns [47d652c] * tools/4.11/gdb/lm32/gdb-sim-lm32uart.diff (added) gdb: Fix lm32 simulator's UART code. Builds on MinGW. Wed, 30 Apr 2014 13:13:14 GMT Chris Johns [a35f890] * tools/4.11/gdb/gdb-sim-cgen-inline.diff (added) tools/gdb: Simulator inline fixes in the cgen code. Wed, 30 Apr 2014 06:22:37 GMT Chris Johns [9e78f60] * tools/4.11/gcc/microblaze/rtems-gcc-microblaze-libgcc-20131017.diff (added) tools/microblaze: Fix the building of libgcc. Mon, 28 Apr 2014 23:18:14 GMT Chris Johns [4efea40] * tester/rtems/testing/bsps/beagleboardxm.mc (modified) bsp: Clean up the BBxM BSP configuration. Mon, 28 Apr 2014 23:10:14 GMT Chris Johns [bd0fbd6] * tester/rtems/testing/bsps/beagleboardxm.mc (modified) bsp: Break on the terminate halt to get fatal handlers run. Thu, 24 Apr 2014 07:52:32 GMT Chris Johns [4e8f984] * tester/rtems/testing/bsps/beagleboardxm.mc (added) bsp: Add Beagleboard xM support. Thu, 10 Apr 2014 08:21:24 GMT Chris Johns [b45ca52] * tester/rtems/testing/bsps/psim-run.mc (modified) tester: Fix the psim script. Thu, 10 Apr 2014 08:21:01 GMT Chris Johns [f756b51] * tools/4.11/gdb/gdb-sim-arange-inline.diff (added) gdb: pr 16827, fix sim on Mavrick. Wed, 26 Mar 2014 05:45:19 GMT Chris Johns [05d2385] * tester/rtems/testing/bsps/psim-device-tree (added) * tester/rtems/testing/bsps/psim-run.mc (added) * tester/rtems/testing/bsps/psim.mc (added) bsp: Add psim. Wed, 26 Mar 2014 05:45:06 GMT Chris Johns [a116962] * tester/rt/config.py (modified) tester: The process returns an exit code not an errno. Thu, 20 Mar 2014 20:21:16 GMT Joel Sherrill [ec18d1d] * tools/4.11/gcc/v850/gcc-4.8.2-rtems4.11-20140349.diff (added) gcc-4.8.2-rtems4.11-20140349.diff: New file Wed, 19 Mar 2014 04:15:31 GMT Chris Johns [e959da9] * tools/4.11/gdb/patch-gdb-python-python-config.py (added) 4.11/gdb: Fix detecting python when building GDB on FreeBSD 10.0. ... Mon, 17 Feb 2014 07:04:46 GMT Chris Johns [f91e023] * doc/.gitignore (added) * doc/asciidoc/BUGS (added) * doc/asciidoc/BUGS.txt (added) * doc/asciidoc/CHANGELOG (added) * doc/asciidoc/CHANGELOG.txt (added) * doc/asciidoc/COPYING (added) * doc/asciidoc/COPYRIGHT (added) * doc/asciidoc/INSTALL (added) * doc/asciidoc/INSTALL.txt (added) * doc/asciidoc/MANIFEST (added) * doc/asciidoc/Makefile.in (added) * doc/asciidoc/README (added) * doc/asciidoc/README.txt (added) * doc/asciidoc/a2x.py (added) * doc/asciidoc/asciidoc.conf (added) * doc/asciidoc/asciidoc.py (added) * doc/asciidoc/asciidocapi.py (added) * doc/asciidoc/common.aap (added) * doc/asciidoc/configure (added) * doc/asciidoc/configure.ac (added) * doc/asciidoc/dblatex/asciidoc-dblatex.sty (added) * doc/asciidoc/dblatex/asciidoc-dblatex.xsl (added) * doc/asciidoc/dblatex/dblatex-readme.txt (added) * doc/asciidoc/doc/a2x.1 (added) * doc/asciidoc/doc/a2x.1.txt (added) * doc/asciidoc/doc/article-docinfo.xml (added) * doc/asciidoc/doc/article.pdf (added) * doc/asciidoc/doc/article.txt (added) * doc/asciidoc/doc/asciidoc.1 (added) * doc/asciidoc/doc/asciidoc.1.txt (added) * doc/asciidoc/doc/asciidoc.conf (added) * doc/asciidoc/doc/asciidoc.dict (added) * doc/asciidoc/doc/asciidoc.txt (added) * doc/asciidoc/doc/asciidocapi.txt (added) * doc/asciidoc/doc/asciimathml.txt (added) * doc/asciidoc/doc/book-multi.txt (added) * doc/asciidoc/doc/book.epub (added) * doc/asciidoc/doc/book.txt (added) * doc/asciidoc/doc/customers.csv (added) * doc/asciidoc/doc/epub-notes.txt (added) * doc/asciidoc/doc/faq.txt (added) * doc/asciidoc/doc/images/icons/README (added) * doc/asciidoc/doc/images/icons/callouts/1.png (added) * doc/asciidoc/doc/images/icons/callouts/10.png (added) * doc/asciidoc/doc/images/icons/callouts/11.png (added) * doc/asciidoc/doc/images/icons/callouts/12.png (added) * doc/asciidoc/doc/images/icons/callouts/13.png (added) * doc/asciidoc/doc/images/icons/callouts/14.png (added) * doc/asciidoc/doc/images/icons/callouts/15.png (added) * doc/asciidoc/doc/images/icons/callouts/2.png (added) * doc/asciidoc/doc/images/icons/callouts/3.png (added) * doc/asciidoc/doc/images/icons/callouts/4.png (added) * doc/asciidoc/doc/images/icons/callouts/5.png (added) * doc/asciidoc/doc/images/icons/callouts/6.png (added) * doc/asciidoc/doc/images/icons/callouts/7.png (added) * doc/asciidoc/doc/images/icons/callouts/8.png (added) * doc/asciidoc/doc/images/icons/callouts/9.png (added) * doc/asciidoc/doc/images/icons/caution.png (added) * doc/asciidoc/doc/images/icons/example.png (added) * doc/asciidoc/doc/images/icons/home.png (added) * doc/asciidoc/doc/images/icons/important.png (added) * doc/asciidoc/doc/images/icons/next.png (added) * doc/asciidoc/doc/images/icons/note.png (added) * doc/asciidoc/doc/images/icons/prev.png (added) * doc/asciidoc/doc/images/icons/tip.png (added) * doc/asciidoc/doc/images/icons/up.png (added) * doc/asciidoc/doc/images/icons/warning.png (added) * doc/asciidoc/doc/images/smallnew.png (added) * doc/asciidoc/doc/images/tiger.png (added) * doc/asciidoc/doc/latex-backend.txt (added) * doc/asciidoc/doc/latex-bugs.txt (added) * doc/asciidoc/doc/latex-filter.pdf (added) * doc/asciidoc/doc/latex-filter.txt (added) * doc/asciidoc/doc/latexmath.txt (added) * doc/asciidoc/doc/latexmathml.txt (added) * doc/asciidoc/doc/main.aap (added) * doc/asciidoc/doc/music-filter.pdf (added) * doc/asciidoc/doc/music-filter.txt (added) * doc/asciidoc/doc/publishing-ebooks-with-asciidoc.txt (added) * doc/asciidoc/doc/slidy-example.txt (added) * doc/asciidoc/doc/slidy.txt (added) * doc/asciidoc/doc/source-highlight-filter.pdf (added) * doc/asciidoc/doc/source-highlight-filter.txt (added) * doc/asciidoc/doc/testasciidoc.txt (added) * doc/asciidoc/docbook-xsl/asciidoc-docbook-xsl.txt (added) * doc/asciidoc/docbook-xsl/chunked.xsl (added) * doc/asciidoc/docbook-xsl/common.xsl (added) * doc/asciidoc/docbook-xsl/epub.xsl (added) * doc/asciidoc/docbook-xsl/fo.xsl (added) * doc/asciidoc/docbook-xsl/htmlhelp.xsl (added) * doc/asciidoc/docbook-xsl/manpage.xsl (added) * doc/asciidoc/docbook-xsl/text.xsl (added) * doc/asciidoc/docbook-xsl/xhtml.xsl (added) * doc/asciidoc/docbook45.conf (added) * doc/asciidoc/examples/website/ASCIIMathML.js (added) * doc/asciidoc/examples/website/CHANGELOG.txt (added) * doc/asciidoc/examples/website/INSTALL.txt (added) * doc/asciidoc/examples/website/LaTeXMathML.js (added) * doc/asciidoc/examples/website/README-website.txt (added) * doc/asciidoc/examples/website/README.txt (added) * doc/asciidoc/examples/website/a2x.1.txt (added) * doc/asciidoc/examples/website/asciidoc-docbook-xsl.txt (added) * doc/asciidoc/examples/website/asciidoc-graphviz-sample.txt (added) * doc/asciidoc/examples/website/asciidoc.css (added) * doc/asciidoc/examples/website/asciidoc.js (added) * doc/asciidoc/examples/website/asciidocapi.txt (added) * doc/asciidoc/examples/website/asciimathml.txt (added) * doc/asciidoc/examples/website/build-website.sh (added) * doc/asciidoc/examples/website/customers.csv (added) * doc/asciidoc/examples/website/epub-notes.txt (added) * doc/asciidoc/examples/website/faq.txt (added) * doc/asciidoc/examples/website/images/highlighter.png (added) * doc/asciidoc/examples/website/images/icons/README (added) * doc/asciidoc/examples/website/images/icons/callouts/1.png (added) * doc/asciidoc/examples/website/images/icons/callouts/10.png (added) * doc/asciidoc/examples/website/images/icons/callouts/11.png (added) * doc/asciidoc/examples/website/images/icons/callouts/12.png (added) * doc/asciidoc/examples/website/images/icons/callouts/13.png (added) * doc/asciidoc/examples/website/images/icons/callouts/14.png (added) * doc/asciidoc/examples/website/images/icons/callouts/15.png (added) * doc/asciidoc/examples/website/images/icons/callouts/2.png (added) * doc/asciidoc/examples/website/images/icons/callouts/3.png (added) * doc/asciidoc/examples/website/images/icons/callouts/4.png (added) * doc/asciidoc/examples/website/images/icons/callouts/5.png (added) * doc/asciidoc/examples/website/images/icons/callouts/6.png (added) * doc/asciidoc/examples/website/images/icons/callouts/7.png (added) * doc/asciidoc/examples/website/images/icons/callouts/8.png (added) * doc/asciidoc/examples/website/images/icons/callouts/9.png (added) * doc/asciidoc/examples/website/images/icons/caution.png (added) * doc/asciidoc/examples/website/images/icons/example.png (added) * doc/asciidoc/examples/website/images/icons/home.png (added) * doc/asciidoc/examples/website/images/icons/important.png (added) * doc/asciidoc/examples/website/images/icons/next.png (added) * doc/asciidoc/examples/website/images/icons/note.png (added) * doc/asciidoc/examples/website/images/icons/prev.png (added) * doc/asciidoc/examples/website/images/icons/tip.png (added) * doc/asciidoc/examples/website/images/icons/up.png (added) * doc/asciidoc/examples/website/images/icons/warning.png (added) * doc/asciidoc/examples/website/images/smallnew.png (added) * doc/asciidoc/examples/website/images/tiger.png (added) * doc/asciidoc/examples/website/index.txt (added) * doc/asciidoc/examples/website/latex-backend.txt (added) * doc/asciidoc/examples/website/latex-bugs.txt (added) * doc/asciidoc/examples/website/latex-filter.txt (added) * doc/asciidoc/examples/website/latexmathml.txt (added) * doc/asciidoc/examples/website/layout1.conf (added) * doc/asciidoc/examples/website/layout1.css (added) * doc/asciidoc/examples/website/layout2.conf (added) * doc/asciidoc/examples/website/layout2.css (added) * doc/asciidoc/examples/website/main.aap (added) * doc/asciidoc/examples/website/manpage.txt (added) * doc/asciidoc/examples/website/music-filter.txt (added) * doc/asciidoc/examples/website/newlists.txt (added) * doc/asciidoc/examples/website/newtables.txt (added) * doc/asciidoc/examples/website/plugins.txt (added) * doc/asciidoc/examples/website/publishing-ebooks-with-asciidoc.txt (added) * doc/asciidoc/examples/website/slidy-example.txt (added) * doc/asciidoc/examples/website/slidy.txt (added) * doc/asciidoc/examples/website/source-highlight-filter.txt (added) * doc/asciidoc/examples/website/support.txt (added) * doc/asciidoc/examples/website/testasciidoc.txt (added) * doc/asciidoc/examples/website/userguide.txt (added) * doc/asciidoc/examples/website/version83.txt (added) * doc/asciidoc/examples/website/xhtml11-quirks.css (added) * doc/asciidoc/filters/code/code-filter-readme.txt (added) * doc/asciidoc/filters/code/code-filter-test.txt (added) * doc/asciidoc/filters/code/code-filter.conf (added) * doc/asciidoc/filters/code/code-filter.py (added) * doc/asciidoc/filters/graphviz/asciidoc-graphviz-sample.txt (added) * doc/asciidoc/filters/graphviz/graphviz-filter.conf (added) * doc/asciidoc/filters/graphviz/graphviz2png.py (added) * doc/asciidoc/filters/latex/latex-filter.conf (added) * doc/asciidoc/filters/latex/latex2png.py (added) * doc/asciidoc/filters/music/music-filter-test.txt (added) * doc/asciidoc/filters/music/music-filter.conf (added) * doc/asciidoc/filters/music/music2png.py (added) * doc/asciidoc/filters/source/source-highlight-filter-test.txt (added) * doc/asciidoc/filters/source/source-highlight-filter.conf (added) * doc/asciidoc/help.conf (added) * doc/asciidoc/html4.conf (added) * doc/asciidoc/html5.conf (added) * doc/asciidoc/images/highlighter.png (added) * doc/asciidoc/images/icons/README (added) * doc/asciidoc/images/icons/callouts/1.png (added) * doc/asciidoc/images/icons/callouts/10.png (added) * doc/asciidoc/images/icons/callouts/11.png (added) * doc/asciidoc/images/icons/callouts/12.png (added) * doc/asciidoc/images/icons/callouts/13.png (added) * doc/asciidoc/images/icons/callouts/14.png (added) * doc/asciidoc/images/icons/callouts/15.png (added) * doc/asciidoc/images/icons/callouts/2.png (added) * doc/asciidoc/images/icons/callouts/3.png (added) * doc/asciidoc/images/icons/callouts/4.png (added) * doc/asciidoc/images/icons/callouts/5.png (added) * doc/asciidoc/images/icons/callouts/6.png (added) * doc/asciidoc/images/icons/callouts/7.png (added) * doc/asciidoc/images/icons/callouts/8.png (added) * doc/asciidoc/images/icons/callouts/9.png (added) * doc/asciidoc/images/icons/caution.png (added) * doc/asciidoc/images/icons/example.png (added) * doc/asciidoc/images/icons/home.png (added) * doc/asciidoc/images/icons/important.png (added) * doc/asciidoc/images/icons/next.png (added) * doc/asciidoc/images/icons/note.png (added) * doc/asciidoc/images/icons/prev.png (added) * doc/asciidoc/images/icons/tip.png (added) * doc/asciidoc/images/icons/up.png (added) * doc/asciidoc/images/icons/warning.png (added) * doc/asciidoc/images/smallnew.png (added) * doc/asciidoc/images/tiger.png (added) * doc/asciidoc/install-sh (added) * doc/asciidoc/javascripts/ASCIIMathML.js (added) * doc/asciidoc/javascripts/LaTeXMathML.js (added) * doc/asciidoc/javascripts/asciidoc.js (added) * doc/asciidoc/javascripts/slidy.js (added) * doc/asciidoc/javascripts/toc.js (added) * doc/asciidoc/lang-de.conf (added) * doc/asciidoc/lang-el.conf (added) * doc/asciidoc/lang-en.conf (added) * doc/asciidoc/lang-es.conf (added) * doc/asciidoc/lang-fr.conf (added) * doc/asciidoc/lang-hu.conf (added) * doc/asciidoc/lang-it.conf (added) * doc/asciidoc/lang-nl.conf (added) * doc/asciidoc/lang-pt-BR.conf (added) * doc/asciidoc/lang-ru.conf (added) * doc/asciidoc/lang-uk.conf (added) * doc/asciidoc/latex.conf (added) * doc/asciidoc/main.aap (added) * doc/asciidoc/slidy.conf (added) * doc/asciidoc/stylesheets/asciidoc.css (added) * doc/asciidoc/stylesheets/docbook-xsl.css (added) * doc/asciidoc/stylesheets/pygments.css (added) * doc/asciidoc/stylesheets/slidy.css (added) * doc/asciidoc/stylesheets/toc2.css (added) * doc/asciidoc/stylesheets/xhtml11-quirks.css (added) * doc/asciidoc/tests/asciidocapi.py (added) * doc/asciidoc/tests/data/deprecated-quotes.txt (added) * doc/asciidoc/tests/data/filters-test.txt (added) * doc/asciidoc/tests/data/lang-de-man-test.txt (added) * doc/asciidoc/tests/data/lang-de-test.txt (added) * doc/asciidoc/tests/data/lang-en-man-test.txt (added) * doc/asciidoc/tests/data/lang-en-test.txt (added) * doc/asciidoc/tests/data/lang-es-man-test.txt (added) * doc/asciidoc/tests/data/lang-es-test.txt (added) * doc/asciidoc/tests/data/lang-fr-man-test.txt (added) * doc/asciidoc/tests/data/lang-fr-test.txt (added) * doc/asciidoc/tests/data/lang-hu-man-test.txt (added) * doc/asciidoc/tests/data/lang-hu-test.txt (added) * doc/asciidoc/tests/data/lang-it-man-test.txt (added) * doc/asciidoc/tests/data/lang-it-test.txt (added) * doc/asciidoc/tests/data/lang-nl-man-test.txt (added) * doc/asciidoc/tests/data/lang-nl-test.txt (added) * doc/asciidoc/tests/data/lang-pt-BR-man-test.txt (added) * doc/asciidoc/tests/data/lang-pt-BR-test.txt (added) * doc/asciidoc/tests/data/lang-ru-man-test.txt (added) * doc/asciidoc/tests/data/lang-ru-test.txt (added) * doc/asciidoc/tests/data/lang-uk-man-test.txt (added) * doc/asciidoc/tests/data/lang-uk-test.txt (added) * doc/asciidoc/tests/data/oldtables.txt (added) * doc/asciidoc/tests/data/open-block-test.txt (added) * doc/asciidoc/tests/data/rcs-id-marker-test.txt (added) * doc/asciidoc/tests/data/testcases.conf (added) * doc/asciidoc/tests/data/testcases.txt (added) * doc/asciidoc/tests/data/utf8-bom-test.txt (added) * doc/asciidoc/tests/data/utf8-examples.txt (added) * doc/asciidoc/tests/testasciidoc.conf (added) * doc/asciidoc/tests/testasciidoc.py (added) * doc/asciidoc/text.conf (added) * doc/asciidoc/themes/flask/flask.css (added) * doc/asciidoc/themes/volnitsky/volnitsky.css (added) * doc/asciidoc/vim/ftdetect/asciidoc_filetype.vim (added) * doc/asciidoc/vim/syntax/asciidoc.vim (added) * doc/asciidoc/wordpress.conf (added) * doc/asciidoc/xhtml11-quirks.conf (added) * doc/asciidoc/xhtml11.conf (added) * doc/images/icons/README (added) * doc/images/icons/callouts/1.png (added) * doc/images/icons/callouts/10.png (added) * doc/images/icons/callouts/11.png (added) * doc/images/icons/callouts/12.png (added) * doc/images/icons/callouts/13.png (added) * doc/images/icons/callouts/14.png (added) * doc/images/icons/callouts/15.png (added) * doc/images/icons/callouts/2.png (added) * doc/images/icons/callouts/3.png (added) * doc/images/icons/callouts/4.png (added) * doc/images/icons/callouts/5.png (added) * doc/images/icons/callouts/6.png (added) * doc/images/icons/callouts/7.png (added) * doc/images/icons/callouts/8.png (added) * doc/images/icons/callouts/9.png (added) * doc/images/icons/caution.png (added) * doc/images/icons/example.png (added) * doc/images/icons/home.png (added) * doc/images/icons/important.png (added) * doc/images/icons/next.png (added) * doc/images/icons/note.png (added) * doc/images/icons/prev.png (added) * doc/images/icons/tip.png (added) * doc/images/icons/up.png (added) * doc/images/icons/warning.png (added) * doc/images/rtemswhitebg.jpg (added) * doc/rtems-tester.txt (added) * doc/wscript (added) Add the documentation. Mon, 17 Feb 2014 06:56:03 GMT Chris Johns [11d4b89] * .gitignore (added) * README (added) Add README. Also add a git ignore. Fri, 14 Feb 2014 19:30:06 GMT Chris Johns [50fdf12] * rtemstoolkit/.gitignore (added) * rtemstoolkit/__init__.py (added) * rtemstoolkit/check.py (added) * rtemstoolkit/config.py (added) * rtemstoolkit/darwin.py (added) * rtemstoolkit/error.py (added) * rtemstoolkit/execute.py (added) * rtemstoolkit/freebsd.py (added) * rtemstoolkit/git.py (added) * rtemstoolkit/linux.py (added) * rtemstoolkit/log.py (added) * rtemstoolkit/macros.py (added) * rtemstoolkit/mailer.py (added) * rtemstoolkit/options.py (added) * rtemstoolkit/path.py (added) * rtemstoolkit/version.py (added) * rtemstoolkit/windows.py (added) * tester/.gitignore (added) * tester/config/base.cfg (added) * tester/config/checks.cfg (added) * tester/rt/__init__.py (added) * tester/rt/config.py (added) * tester/rt/console.py (added) * tester/rt/gdb.py (added) * tester/rt/options.py (added) * tester/rt/pygdb/__init__.py (added) * tester/rt/pygdb/mi_parser.py (added) * tester/rt/pygdb/spark.py (added) * tester/rt/report.py (added) * tester/rt/stty.py (added) * tester/rt/test.py (added) * tester/rt/version.py (added) * tester/rtems-test (added) * tester/rtems/testing/bsps/mcf5235.mc (added) * tester/rtems/testing/bsps/realview_pbx_a9_qemu.mc (added) * tester/rtems/testing/bsps/sis-run.mc (added) * tester/rtems/testing/bsps/sis.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_a9_qemu_smp.mc (added) * tester/rtems/testing/bsps/xilinx_zynq_zc706.mc (added) * tester/rtems/testing/console.cfg (added) * tester/rtems/testing/defaults.mc (added) * tester/rtems/testing/gdb.cfg (added) * tester/rtems/testing/qemu.cfg (added) * tester/rtems/testing/run.cfg (added) * tester/rtems/testing/testing.mc (added) * tester/rtems/version.cfg (added) rt: Add the rtems-tester. Wed, 12 Feb 2014 02:18:33 GMT Chris Johns [8f75c4a] * tools/libffi/libffi-pkg-config-lib64-fix.diff (added) libffi: Fix for Fedora 64bit pkg-config file. Sat, 18 Jan 2014 06:27:13 GMT Chris Johns [29734ec] * tools/4.11/gdb/sparc/gdb-7.6.2-sis-output-nouartrx.diff (added) gdb/sparc: SIS gdb output fix, add nouartrx. Fix the output from ... Wed, 14 Aug 2013 03:49:27 GMT Chris Johns [b2589cb] * tools/4.11/gcc/gcc-rtems-thread-model-posix-1.diff (added) gcc: Switch GCC to the posix thread model. Change from the RTEMS ... Mon, 15 Jul 2013 23:58:54 GMT Chris Johns [98f78dc] * tools/4.11/gcc/gcc-4.8.1-rtems4.11-20130709.diff (added) The __cxa_atexit support is a reqirement for destructor registration ... Thu, 30 May 2013 23:43:40 GMT Chris Johns [6651de8] * tools/4.11/newlib/newlib-sys-signal-20130532.diff (added) Add Joel's stack_t patch. Wed, 22 May 2013 06:47:01 GMT Amar Takhar [bba0b78] * tools/4.11/newlib/powerpc/newlib-remove-machine-powerpc-times_c.diff (added) Add patch to remove times.c from PowerPC newlib. Thu, 16 May 2013 08:13:31 GMT Amar Takhar [acdef36] * tools/4.11/binutils/moxie/binutils-2.22-rtems4.11-moxie-20130516.diff (added) Add three patches from Anthony Green to fix moxie tools. ... Sun, 14 Apr 2013 22:25:05 GMT Chris Johns [440c97f] * tools/4.11/gcc/gcc-4.7.3-rtems4.11-20130413.diff (deleted) * tools/4.11/gcc/gcc-4.7.3-rtems4.11-20130414.diff (added) Regenerate the patch cleanly. Sat, 13 Apr 2013 08:23:52 GMT Chris Johns [65575cc] * tools/4.11/gcc/gcc-4.7.3-rtems4.11-20130413.diff (added) Update the 4.7.2 patch to 4.7.3. Fri, 05 Apr 2013 03:24:01 GMT Chris Johns [eba19fa] * tools/4.11/gcc/arm/gcc-4.7-rtems4.11-arm-eabi-libcpp-20130403.diff (added) * tools/4.11/gcc/arm/gcc-arm-to-eabi-part2-20130402.diff (deleted) Update to the patch Joel merged. Tue, 02 Apr 2013 21:39:03 GMT Chris Johns [926ef3c] * tools/4.11/gcc/arm/gcc-arm-to-eabi-part2-20130402.diff (added) PR target/56771. Require 64-bit int for arm*-*-rtems[.0-9]*. Tue, 02 Apr 2013 06:48:38 GMT Chris Johns [9d711f4] * tools/4.10/binutils/cygwin/binutils-2.20.1-cygwin-w64-20130324.diff (added) Fix to build in cygwin. Wed, 20 Mar 2013 06:27:49 GMT Chris Johns [4c5ffb2] * tools/4.10/gdb/bfin/gdb-7.3.1-bfin-sim-fix-sed-20130319.diff (added) Fix the sed breakage on FreeBSD. Tue, 19 Mar 2013 06:16:54 GMT Chris Johns [038b250] * tools/4.10/binutils/binutils-2.20.1-rtems4.10-20100826.diff (added) * tools/4.10/gcc/gcc-core-4.4.7-rtems4.10-20120314.diff (added) * tools/4.10/gcc/gcc-g++-4.4.7-rtems4.10-20120314.diff (added) * tools/4.10/gdb/gdb-7.3.1-rtems4.10-20120918.diff (added) * tools/4.10/newlib/newlib-1.18.0-rtems4.10-20110518.diff (added) Add the current rtems-4.10 patches. Fri, 15 Mar 2013 01:10:20 GMT Chris Johns [ce77d87] * tools/4.9/gcc/gcc-core-4.3.2-rtems4.9-20090825.diff (added) * tools/4.9/gdb/gdb-6.8-rtems4.9-20091111.diff (added) * tools/4.9/newlib/newlib-1.16.0-rtems4.9-20090324.diff (added) Import the 4.9 patches. Mon, 11 Mar 2013 08:31:18 GMT Sebastian Huber [f0c9bae] * tools/4.11/gcc/arm/gcc-4.7-arm-to-eabi-20120511-2.diff (deleted) * tools/4.11/gcc/arm/gcc-4.7-arm-to-eabi-20130306.diff (moved) Add latest GCC 4.7 ARM to EABI patch This patch is included in the ... Mon, 11 Mar 2013 06:16:02 GMT Chris Johns [cb328a1] * tools/4.11/gcc/arm/gcc-4.7-arm-to-eabi-20120511-2.diff (added) Regenerate the ARM EABI patch for gcc-4.7.2 sources. Mon, 11 Mar 2013 00:50:53 GMT Chris Johns [94c5d74] * tools/4.11/gcc/arm/gcc-4.7-arm-to-eabi-20120511.diff (added) ARM EABI patch. Sun, 10 Mar 2013 22:28:55 GMT Chris Johns [e42bad3] * tools/4.11/binutils/binutils-2.22-rtems4.11-20120427.diff (added) * tools/4.11/binutils/moxie/binutils-2.22-rtems4.11-moxie-20130214.diff (added) * tools/4.11/binutils/nios2/nios2-binutils-2.20-rtems-20110703.diff (added) * tools/4.11/gcc/gcc-4.5.3-strsignal-1.diff (added) * tools/4.11/gcc/gcc-4.7.2-rtems4.11-20121026.diff (added) * tools/4.11/gcc/nios2/nios2-gcc-4.1-rtems-20110818.diff (added) * tools/4.11/gdb/gdb-7.5-rtems4.11-20121003.diff (added) * tools/4.11/gdb/moxie/gdb-7.5.1-rtems4.11-moxie-20130214.diff (added) * tools/4.11/newlib/nios2/nios2-newlib-1.19.0-rtems-20110720.diff (added) Move current patches in to the repo. Sun, 10 Mar 2013 03:31:57 GMT Chris Johns [5749230] * tools/4.11/gcc/microblaze/gcc-4.7.2-microblaze-ldscript-2.diff (added) Regerated version of Joel's patch so patch -p1 works. Sun, 10 Mar 2013 01:35:37 GMT Chris Johns [0e90000] * tools/4.11/gcc/microblaze/gcc-4.7.2-microblaze-ldscript-1.diff (moved) Use a better name for the patch. Sun, 10 Mar 2013 01:27:22 GMT Chris Johns [25e43e1] * tools/4.11/gcc/microblaze/rtems-gcc-microblaze-ldscript-1.diff (added) Microblaze gcc-4.7.2 patch from Joel. Fri, 08 Mar 2013 07:44:32 GMT Chris Johns [df78032] * tools/4.11/newlib/mips/newlib-2.0.0-mips-memcpy-20130107.diff (added) * tools/4.11/newlib/mips/newlib-2.0.0-mips-memcpy-20130219.diff (added) MIPS memcpy fixes. ... Wed, 06 Mar 2013 15:25:00 GMT Gedare Bloom [6d5bfb0] * ChangeLog (deleted) * README (deleted) * specbuilder/sb-build (deleted) * specbuilder/sb-crossgcc (deleted) * specbuilder/sb-setup (deleted) * specbuilder/sb-specdump (deleted) * specbuilder/sb-status (deleted) * specbuilder/sb-versions (deleted) * specbuilder/specbuilder/.gitignore (deleted) * specbuilder/specbuilder/build.py (deleted) * specbuilder/specbuilder/config.sub (deleted) * specbuilder/specbuilder/crossgcc.py (deleted) * specbuilder/specbuilder/darwin.py (deleted) * specbuilder/specbuilder/defaults.py (deleted) * specbuilder/specbuilder/error.py (deleted) * specbuilder/specbuilder/execute.py (deleted) * specbuilder/specbuilder/freebsd.py (deleted) * specbuilder/specbuilder/linux.py (deleted) * specbuilder/specbuilder/log.py (deleted) * specbuilder/specbuilder/perl.prov (deleted) * specbuilder/specbuilder/perl.req (deleted) * specbuilder/specbuilder/rtems.py (deleted) * specbuilder/specbuilder/setup.py (deleted) * specbuilder/specbuilder/spec.py (deleted) * specbuilder/specbuilder/status.py (deleted) * specbuilder/specbuilder/version.py (deleted) * specbuilder/specbuilder/windows.py (deleted) Clean up. Remove all files to prepare repo for a new life. ... Thu, 06 Sep 2012 04:09:49 GMT Chris Johns [7234c70] * ChangeLog (modified) * specbuilder/specbuilder/.gitignore (moved) Move .cvsignore to .gitignore. Update ChangeLog. Sat, 04 Aug 2012 12:29:24 GMT Chris Johns [68c9b8a] * specbuilder/sb-build (modified) * specbuilder/sb-crossgcc (modified) * specbuilder/sb-setup (modified) * specbuilder/sb-specdump (modified) * specbuilder/sb-status (modified) * specbuilder/sb-versions (modified) * specbuilder/specbuilder/build.py (modified) * specbuilder/specbuilder/crossgcc.py (modified) * specbuilder/specbuilder/darwin.py (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/error.py (modified) * specbuilder/specbuilder/execute.py (modified) * specbuilder/specbuilder/freebsd.py (modified) * specbuilder/specbuilder/linux.py (modified) * specbuilder/specbuilder/log.py (modified) * specbuilder/specbuilder/rtems.py (modified) * specbuilder/specbuilder/setup.py (modified) * specbuilder/specbuilder/spec.py (modified) * specbuilder/specbuilder/status.py (modified) * specbuilder/specbuilder/version.py (modified) * specbuilder/specbuilder/windows.py (modified) Remove CVS Id and update the copyright year. Sat, 04 Aug 2012 12:17:50 GMT Chris Johns [5a44122] * specbuilder/specbuilder/spec.py (modified) Comments clean up. Sat, 04 Aug 2012 12:17:33 GMT Chris Johns [e801762] * specbuilder/specbuilder/setup.py (modified) Use the crossrpms repo and not the RTEMS source. Sat, 04 Aug 2012 12:17:05 GMT Chris Johns [db789e3] * specbuilder/specbuilder/perl.prov (modified) Clean up. Sat, 04 Aug 2012 12:16:48 GMT Chris Johns [f51e691] * specbuilder/specbuilder/darwin.py (modified) Do not build with zlib. Tue, 06 Dec 2011 23:44:37 GMT Chris Johns [6b88114] * specbuilder/specbuilder/freebsd.py (modified) Add /usr/local to the host cflags on FreeBSD. Tue, 06 Dec 2011 06:37:57 GMT Chris Johns [8548cd7] * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/freebsd.py (modified) Add a hack to work around make not being a macro in the spec files. Mon, 05 Dec 2011 20:53:17 GMT Chris Johns [594f41f] * specbuilder/specbuilder/freebsd.py (modified) * specbuilder/specbuilder/setup.py (modified) Fix the host verison in FreeBSD. Allow the top of the src to crossrpms. Mon, 05 Dec 2011 11:32:44 GMT Chris Johns [a2bc901] * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/freebsd.py (added) Add FreeBSD support. Thu, 09 Jun 2011 05:59:32 GMT Chris Johns [a86cd82] * ChangeLog (modified) * specbuilder/specbuilder/build.py (modified) * specbuilder/specbuilder/crossgcc.py (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/linux.py (modified) * specbuilder/specbuilder/spec.py (modified) 2011-06-09 Chris Johns * ... Tue, 22 Feb 2011 03:46:44 GMT Chris Johns [faa8181] * ChangeLog (modified) * specbuilder/sb-versions (added) * specbuilder/specbuilder/build.py (modified) * specbuilder/specbuilder/crossgcc.py (modified) * specbuilder/specbuilder/darwin.py (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/setup.py (modified) * specbuilder/specbuilder/spec.py (modified) * specbuilder/specbuilder/version.py (added) * specbuilder/specbuilder/windows.py (added) 2011-02-22 Chris Johns * ... Tue, 31 Aug 2010 00:58:45 GMT Chris Johns [31d4e80] * ChangeLog (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/linux.py (added) 2010-08-31 Chris Johns * ... Sat, 28 Aug 2010 23:01:20 GMT Chris Johns [9eb5c92] * ChangeLog (modified) * specbuilder/specbuilder/defaults.py (modified) 2010-08-29 Chris Johns * ... Fri, 13 Aug 2010 04:40:44 GMT Chris Johns [f1a0bde] * ChangeLog (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/rtems.py (modified) * specbuilder/specbuilder/setup.py (modified) 2010-08-13 Chris Johns * ... Thu, 12 Aug 2010 22:40:57 GMT Chris Johns [0b29e44] * ChangeLog (modified) * specbuilder/specbuilder/setup.py (modified) 2010-08-13 Chris Johns * ... Thu, 12 Aug 2010 21:09:55 GMT Chris Johns [120137a] * ChangeLog (modified) * specbuilder/specbuilder/build.py (modified) * specbuilder/specbuilder/darwin.py (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/rtems.py (added) * specbuilder/specbuilder/setup.py (modified) 2010-08-13 Chris Johns * ... Mon, 09 Aug 2010 04:50:30 GMT Chris Johns [dc2ed4f] * ChangeLog (modified) * specbuilder/specbuilder/defaults.py (modified) * specbuilder/specbuilder/perl.prov (added) * specbuilder/specbuilder/perl.req (added) * specbuilder/specbuilder/setup.py (modified) * specbuilder/specbuilder/spec.py (modified) 2010-08-09 Chris Johns * ... Mon, 09 Aug 2010 01:29:43 GMT Chris Johns [7231f49] * ChangeLog (added) * specbuilder/sb-build (added) * specbuilder/sb-crossgcc (added) * specbuilder/sb-setup (added) * specbuilder/sb-specdump (added) * specbuilder/sb-status (added) * specbuilder/specbuilder/.cvsignore (added) * specbuilder/specbuilder/build.py (added) * specbuilder/specbuilder/config.sub (added) * specbuilder/specbuilder/crossgcc.py (added) * specbuilder/specbuilder/darwin.py (added) * specbuilder/specbuilder/defaults.py (added) * specbuilder/specbuilder/error.py (added) * specbuilder/specbuilder/execute.py (added) * specbuilder/specbuilder/log.py (added) * specbuilder/specbuilder/setup.py (added) * specbuilder/specbuilder/spec.py (added) * specbuilder/specbuilder/status.py (added) 2010-08-09 Chris Johns * ... Mon, 09 Aug 2010 01:04:21 GMT Chris Johns [2dc8560] This commit was generated by cvs2svn to compensate for changes in r2, ... Mon, 09 Aug 2010 01:04:21 GMT Chris Johns [78c9ac0] * README (added) Create RTEMS Tools.
